Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
0 Members and 36 Guests are viewing this topic.
wattsup
@magpwr
First post. Congrats.
Good idea. I am just wondering about the duct tape. Seems rather thick and too heavy duty but trying is learning.
Once your coils are wound, leave the trigger coil with long enough wire so you can try a few more or less turns as this is making a difference.
Bruce_TPU
Quote from: 4Tesla on December 18, 2007, 01:30:31 AM
(snip)
@btentzer
Can you please post photos of your toroids so I can see how you wound them.
Thanks,
4Tesla
@ 4Tesla
I posted some very good pictures, in the start of this thread, of my toroid and what was my setup at that time.  I hope that it helps.
Holiday Cheers,
Bruce
4Tesla
Thanks Bruce.. I found it..
Are the coils wrapped like this
101010101010
or like this
11111110000000
Thanks,
4Tesla
Quote from: btentzer on November 17, 2007, 09:30:47 PM
Well,
The best time tonight, no power, LED flashing is 4min 45 sec.  I tried a wrap around the circumference in different configuration, but no go.  I sure would like to get to that 2.5 hours, EM!   ;)
I will be attempting the use of many different capacitors and see if there is any difference.  If I beat my 4min 45 second on time, I'll let you know.
Cheers,
Bruce
plengo
I have some good news. I have created a reproduction of my design with a simplified coil and two transistor instead of a mosfet. The coil is just a small spool, about 2" width, 1" high, 1/2" hole, with 51 turns of 23 and 26 awg wire. It is running beautifully and battery is steadly charging. It started with a 3.5volts and now is 5.35v. It is inside a Faraday cage to guarantee is not RF or something else feeding energy to it.
I also decided to run a test with my older device (the one posted here and on video) using a fully charged 9v regular battery and it is lighting up four LEDs fully bright. Here is the cool thing: it is NOT running the battery down at all. It instantly dropped the voltage from 9.17v to 7.80v (because of the LEDs voltage drop) and it is running for over 24 hous now and the final voltage my wife told on the phone (im at work now) is about 7.95v. So. It is not only running full force but is also charging itself up.
What I was looking for into this test is to know if this will discharge the battey to a very low voltage first and then go up or if it would run full power and then go up.
I think this is something to be explored in more deph. If you guys agree and are willing to participate I would like to know if should I open a new thread or here is fine?
Fausto.
Bruce_TPU
Quote from: plengo on December 18, 2007, 04:32:16 PM
Fausto.
@ Fausto
Wonderful work!  Please continue in this thread.  It sounds as if you have achieved the goal of this thread, and that is a continuous running LED.
I would suggest several things.
1.  Post an updated circuit, including all values for caps, etc.
2.  Post a picture of your coil.  Post a picture of your battery, and of your circuit.
3.  continue to run your LED's.  IF it is truly charging itself, it will continue to light the LED's as long as the battery is good.
4.  I am purchasing a rechargable battery today.  Have you tried this with different types of rechargable batteries?
I would like to replicate this, also, using my 2" toroid.
Quote from: 4Tesla on December 18, 2007, 04:28:32 PM
101010101010
or like this
11111110000000
Thanks,
4Tesla
@4Tesla
101010101010   ;D
Holiday Cheers,
Bruce
