Peter Davey Heater
Started by storre, February 09, 2008, 11:00:32 AM
forest
Imagine : no motor, no bearings yet still fast cavitation. it's wonderful, it's music .I'm totally after that! Put those heaters on the market and release plans everywhere!
Sorry,I can't resist..
forest
nul-points
hi Boguslaw
picture of one of Davey's heaters without casing below
i haven't looked at the Thrapp device yet - i must do that
the device can operate without shorting because the water between the live & neutral electrodes acts as a relatively low impedance (resistance) between them and current flows from the live to the neutral & heats the water in its path
by arranging the electrodes concentrically, the inner electrode is live, the next electrode is neutral and the outer casing is earthed
the shortest, easiest path for the electricity to flow is from the central live electrode to the middle neutral electrode - the gap between electrodes is adjusted to give the required resistance of water path (& therefore current flow) which provides suitably fast heating without blowing a fuse (checkout NerzhDishual's experiments!)
so, little or no current should flow from the live to the earth - but even if it did (and i guess a small amount will, due to the bubbling mixing the water up) then the longer electric path thro' the water from the live electrode to the earth casing will have a higher resistance than to the neutral, so most current will flow, as on conventional element heaters, between live & neutral
does that make sense? i'm not sure i explained it that well !  :)
microcavitation in water can be caused by processes which put large amounts of physical (acoustic) pressure into small volumes of water (even if those small, localised, volumes are within a larger volume of water generally - eg, vibration together of solid parts, compression due to rotating or linear pistons, explosions etc)
i believe that possibly one of the first discoveries of this type of activity was noticed in the bow-waves of ships travelling at speed - sonoluminescence was noticed & was eventually linked with the acoustic turbulence caused in the water by the action of the bow hitting the water
it CAN be done by the power in acoustic standing waves - but, as i mentioned, this really needs a calm stable environment in the water - which we don't have here
i see what you're saying about a rotation in the water - but i think this would be closer to vortex behavior investigated by Victor Schauberger, which is a different, but still possibly OU-type effect
i'll try to look out some relevant microcavitation links - but they shouldn't be hard to find using Google
...just seen that you've added some more posts whilst i was replying - i'll have to check those out later tonight, thanks
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
devrimogun
Quote from: nul-points on June 08, 2008, 08:26:52 PM
LOL@ Lady Sherlock
dayum, does that mean i need to start shaving my legs?!?
(nul-points = ugly, 6'2", 205lbs / 1.88m 93kilo, ex-rugby player!)  ;D
Sorry Nul. I thought Sandy would be a woman's name. You know - Grease for example.
"Saandy can't you see, I'm in misery. We made a start now we're apart there's nothing left for me......."
Anyway, next generation Sherlock then. Hows that?
ND has a major error in his assembly. Davey's has a curved handle and he boils his water using
his hand to put the device inside. The reason is probably to let the cups vibrate more efficiently.
His cups is nothing like Davey's cups and still 1.1COP? (Although fuse blows very soon).
ND will get there as soon as someone sends him bells of the size that is mentioned in the detailed
construction document :) and a handle :)
devrimogun
Quote from: forest on June 09, 2008, 07:02:52 AM
Hi nul-points,
First : where did you got any pictures of Davey  heater without spherical casing ? I cannot find any , except some very suspicious article on kellyNet based on work of even more suspicious Polish (unfortunately) proffesor (?) (I have nothing against him but all his articles even if very interesting are in fact used to promote his extravagant theory.I would not trust them in details)
Boguslaw
I do not think that the spherical casing is anything but an attempt to hide what's inside
from curious eyes like ours. The device is simple! Look at ND there getting 1.1COP with
a setup that hardly resembles Davey's thing.
I mentioned before : If something works it works in many different shapes and ways.
For the moment I propose to assemble something that looks exactly like the device
in the document chapter14.pdf.
Storre you were going to assemble one. What happened to you?
Grinding tooooo easy remember?
