Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
synchro1
Hienrich Hertz's first wireless broadcast discharged two capacitors between electrodes and transmitted the power to a wire loop where a spark appeared. Two matching capacitors on the receiver end would register a change in charge voltage before the spark appeared in the wire loop receiver. (In resonance).
@Raycathode,
Capacitve power transforms into electromagnetic energy inside the LED. This would take place on the receiver end on Mars, not in transition. Capacitance is all potential and the quantum infinite voltage in counter space. The magnetic wave is material in time.
synchro1
Every magnet is connected to the same "No Location" outside space and shares this intimate bond. Every magnet core is quantum entangled.
Not only could "Synchro Coils" transmit and receive longitudinal broadcast waves, but they could transfer power to each other.
One 9 volt battery, could charge millions of batteries by raising the scaler potential across the channels through receiver "Synchro Coils" and one queen transmitter. All our broadcasts could be transmitted by static continuum, through this self charging power receiver as Dr. Dollard demonstrated in his Wardencliff replication. We could tear the overhead wire grid down.
The difference between the two is mega- watts for Wardenclyff and milli-watts for the Synchro coil.
synchro1
            The "Synchro coil" has an antenna in counter space and it's ground in the magnet field!
        The value of the infinite voltage in the magnet core is C squared. The value of magnetism is M.
        E=MC2
            The speed of light squared is the value of infinite voltage and the speed of the scaler wave.
                                           The energy in the magnet is perpetual!
                              The cosmic expansion is the Universe demagnetizing.
                         We are the BEMF of a field collapse transitioning to capacitance.
synchro1
Tesla's wireless power transmitter and receiver system requires a ground or one wire. The "Synchro Coils" are grounded in the permanent magnet field. That's the difference between these two systems.
The "Synchro Coil" does not need an Earth ground or any connection whatsoever. The static matrix would eliminate BAUD times for digital uploads and make Elon Musk's satellite Star Web obsolete.
We modulate the potential in the resonant magnet tanks. This is a scaler value. Two tuned "Synchro Coils" in resonance will rise in mutual voltage from power to one. A second receiver would rise in voltage at the same rate with no additional input to the transmitter. Modulating the voltage would carry a signal both digital and sine.
synchro1
Two Synchro Coils in resonance, one with a DMM connected to the capacitor electrodes and the other a battery would
register a rise in voltage when the primary was charged by the battery. This is the scaler wave radio!
Adding a second Synchro Coil receiver in resonance would register the same rise in voltage increasing the COP of the system by 100%. The potential can be modulated and result in a super luminal communication system.
The bifilar capacitor LC tank resonant frequency needs to be 13.56. This would be the base frequency of the wireless system.
The magnet cores grow bonded by "Quantum entanglement" at that resonance and theoretically should be able to communicate instantly at any distance in Outer Space by modulating Scaler Potential.
