Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
Yadaraf
Quote from: Omnibus on March 15, 2008, 03:46:05 AM
I was looking again at @CLaNZeR's video. The device seems to slow down. Was it spun initially by hand or the spinning started by simply adjusting the wings as in @smOky2's case? The wind down seems peculiar, though, much longer than expected. Mine comes to a stop earlier and differently when set in motion by hand but that may be just because the conditions of my experiment are different.
Omni,
As I recall you were going to buy the SuperMagnetMan Erector Kit.  If you are using that kit, then I don't believe you've replicated CLaNZeR's device, since the small 0.5" neos do not create a stable rotating octahedron without glue of some kind.  The neos are so strong and so close to each other that the octahedron caves in when attached to the stator.  However, it might be possible to replicate sm0ky2's device using the 0.5" neos.
Cheers :)
Yada..
CLaNZeR
I think this is a nice Magnetic Bearing with reduced friction.
So would be good for experiementing with as a rotor.
Here is second video.
Shows a big difference between coupling the joining ball bearing N-N or N-S
Hi Res download link:
http://www.overunity.org.uk/CLaNZeRSFairFieldReplication2.wmv
Or Youtube
http://www.youtube.com/watch?v=Vwvrl9aesz8
Off to check out Grahams new video.
Cheers
Sean.
Omnibus
@Yadaraf,
That's correct, I'm working with that SuperMagnetMan Erector Kit. The symmetric octahedron can be built just fine with it. Unfortunately, as we also see in @CLaNZeR's video it decelerates (in some configurations faster than in others) just as anything else trivial does.
CTG Labs
A man after my own heart with the RAPID Catalogue in the background!
Quote from: CLaNZeR on March 15, 2008, 07:53:32 AM
Or Youtube
Cheers
Sean.
