RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
0 Members and 41 Guests are viewing this topic.
gotoluc
Hi everyone,
the research I do is intended to hopefully find an energy solutions to help the less fortunate of the World. I do not want to create waste of researchers time, money and resources. I need to find a way to test my setup so that we are all 100% confident of what we are seeing in my video demonstration.
I have an idea to test my setup and would like your opinion to see if my thinking is correct or not.
I'm thinking of buying enough 9v batteries so once connect in series I'll have the 47vdc I did my video test 8 with. I'll start the circuit with no load and monitor the volts and then I'll load the coils and see if the volts drop. If the volts don't drop and the caps charge then we know that what ever is at the capacitors (which are also under load) is extra power at no cost of amps. I think this should make it indisputable since the batteries in series will show instantaneously a voltage drop with an extra load since the power reserve is really equal to a single 9v battery.
Please let me know if you think this test is good or not.
Thank you all for your time :)
Luc
otto
Hello all,
@gotoluc
the voltage will drop!! This IS the reason I said you should use a core. With a core the voltage should be stable when you connect a load.
Otto
gotoluc
Thank you Otto for your quick reply! ... your comment is noted ;)
I would like to hear as many replies as possible, so please post.
thanks for all sharing to help.
Luc
Groundloop
Luc,
I have a proposal for a over unity test.
See attached drawing.
The challenge is to use proper designed coils and enough coils
to get a useful output.
Groundloop.
gotoluc
Hi Groundloop,
thanks for your suggestion. I is a very good idea! the only thing is it does involve more time in retuning of the pickup coils and in the end I may loose what I have.
Do you not think the battery idea is a good enough test?... if it shows good results, then I could build your proposed circuit idea to which I really like ;D.
What do you think?
Thanks for sharing
Luc
