RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
gotoluc
Quote from: wattsup on January 05, 2009, 07:11:48 PM
@armagdn03
You mentioned you were driving the ozone patent with an AC square wave.
Hi wattsup,
below is what armagdn03 wrote!... pulsed DC is used in the Tesla ozone Patent.  Luc
Part of armagdn03 post:
When I get down and dirty pulsing resonant components, and want to use pulsed DC, Teslas Inductive collapse trick as shown in the Apparatus for the Production of Ozone is fantastic. Not only can the high self inductance coil be made to do work with its magnetic field for no extra power draw (huge ass hint, Bedini "stole" this idea from Tesla by the way) but it raises the potential corresponding to the dI/dt Faraday law formula, meaning switching times can up your voltage.
Cap-Z-ro
Luc, is it possible to adjust the pulse rate on Tesla's Apparatus for the Production of Ozone ?
Regards...
gotoluc
Quote from: Cap-Z-ro on January 05, 2009, 09:11:32 PM
Regards...
I don't know since I never built a real working model. Obviously armagdn03 has a working model!...maybe allcanadian can answer your question also since I'm quite sure he has a working model ;D and started a topic a while back: http://www.overunity.com/index.php?topic=3972.0 called "The Tesla Project"  which is mostly on Tesla's Apparatus for the Production of Ozone.
Luc
wattsup
@gotoluc
Thanks. I did read his post but my question was what was he using for pulsing. The question is always what where you using for pulsing. I have done it with manual micro contact, motorized indented rotating wheel and micro contact, self oscillating relay with capacitor bank speed control and mosfets with FG, audio frequency control.
In the Project thread you will learn something very important about current reversals.
@armagdn03
I forget to say thanks for the huge ass hint. You can have one coil of high inductance, or, 6 smaller coils of high inductance wound around electro-magnet cores turning one side of a dual sided magnetic rotor with generator coils on the other side feeding power back to source and you are still left with the working circuit output. Yeh. That's a good loop.
sparks
      If we go back to gotoluc picking up the nodes to the wave distributed along his pulsed coil of high self-inductance he used a flurescent bulb.   I would hope that someone noticed it is attached to nothing.  It was responding to the electric field anomaly at this point on the coil.   There was a pole and a current of some sort to light up that bulb.  Folks will say there is no real power there you can lightup flurescent bulbs with just voltage.   You can charge up capacitors with just voltage also and discharge them to get some amps latter on.  The electric field will FLOW from what is perceived as positive to negative.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
