RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
0 Members and 50 Guests are viewing this topic.
gotoluc
Quote from: minde4000 on April 09, 2009, 08:50:20 PM
Hey gotoluc. Check this interesting LC (I would think it might work as LC not sure about those diodes) pickup coil setup. Do you know the frequency of your secondary pickup coil standing waves the one that you aim for? You could tune your secondary as LC with those (I would use tunable) 2 caps. If it is LC..
Here it is: http://hibp.ecse.rpi.edu/~john/hi_power_xtal_set.gif
Hi minde4000,
thanks for your post. I'm not sure I understand your question or how it relates to the crystal radio schematic ???
No need to explain as that may cause more questions as I don't know much about this stuff.
Thanks for sharing
Luc
Quote from: Thaelin on April 09, 2009, 09:21:27 PM
   Hi Luc:
    Hey , have been really busy with the rally up comming here. Just realized I hadn't posted
the power factor file. See below.  Its a blast.!
thaelin
Hi Thaelin,
thanks for the power factor correction pdf.
Interesting to see and read ;)
Luc
gotoluc
Hi everyone,
below is a new video I just made which is a test I would like to share. It is not quite on topic but I think it could be worked into Resonance.
What I am finding is if a certain size of Neo Magnet is introduced in a certain size opening of a Air Core Coil and is Pulsed with Sine Wave or  Square Wave the Magnet starts to Oscillates at a certain Frequency, nothing new right!... what is new to me is it started to reduces the Amp draw of the Coil and at a certain frequency I was able to reduce the input power by about 350% or from 79 milli amps to 23 mili amps.
I find this to be an interesting effect!... we also need to keep in mind that I'm using a off the shelve coil core opening and magnet I had. I am quite sure the effect can get much more efficient once we study it better and find the best configurations.
Video Link: http://www.youtube.com/watch?v=J2qVcwJN9hY
Some of you maybe thinking what would happen if a load is attached :-\.... would it still show a reduction of current ???... and the answer is yes!   I did try it with a load and it definitely shows current reduction as the frequency rises. The load was a tinny 12vdc car dash bulb and the brightness of the bulb goes up as the frequency rises and the amp draw goes down to a point where the magnet can no longer hold in the core opening on its own and falls out if the frequency gets too high.
Please tell me what you think of this effect.
Luc
minde4000
I wonder what is the perm magnet field frequency?
Cap-Z-ro
That is very interesting Luc...have you considered the addition of a secondary coil to the mix also ?
Regards...
gotoluc
Quote from: Cap-Z-ro on April 10, 2009, 06:00:10 PM
Regards...
Hi Cap-Z-ro,
yes that is most definitely on the list to do.
The idea of exploring the use of a Magnet with Resonance came to me after concluding that resonance alone will not give extra energy but maybe by incorporating the flux of a permanent magnet with resonance would have more potential.
Also, Magnacoaster's system is supposedly using PM flux to boost voltage and amps, so why would it not work with resonance!
My video demo of the vibrating magnet is not even close to being at resonance. It is just to demonstrate that there is an interesting effect between coil and magnet using true AC. From what I know it's going to take a real large coil to resonate at such low frequency that a magnet can oscillate at.
Without experimenting we won't know though
Stay tuned.
Luc
