Coral Castle 50 year old secret - NOW here REVELED
Started by hammuraby, February 26, 2009, 08:42:03 AM
hammuraby
http://en.wikipedia.org/wiki/Coral_Castle
we begin to see if at least the BASES, are clear to all.
1) if my weigh is 102 kg and on part of a fixed pulley-weel I apply my force till (102x 9,8) 1000Nm
and therefore i will  raise a weight till 100 kg
The ROPE will came in my direction  .....
2) if the weight that I must raise e' of 200kg (1960Nm)
i will use a mobile pulley which give a relationship of 2:1;
while it pulls from a part 1000Nm against (1960Nm: 2)=980Nm
The ROPE will came in my direction  ..... (not important, but ..... mt X2)
3) if the weight will be greater, i can use a gears with a  greater rapport,
at least 4:1 if will to raise 400kg; 10:1 in order to raise 1000 kg… etc… etc…
4a) the forces aplicate trought the arms on the FULCRUM-GEAR  , will be determined from relationship (4: 1, or, 10: 1), between two sides of the same one, like in a lever.... and this NM is a USEFULL DATA
THIS DECIDE the DIRECTION of the ROPE  ( Coral Castle, if the water pump, or, fall)
4a) the relationship is like  the arm  on a BALANCE ….
 between two opposite forces,  the DOMINANT force determine the direction of the flow  then, if I can rise  , or, i go up boar.
own, like in a balance;
Turz
Ciao Pota ti giro questo utile link http://www.wordreference.com/ per tradurre le parole che non conosci:
non puoi scrivere "carrucola" altrimenti in un forum come questo con gente da tutto mondo riesci a farti capire
Ti prego di continuare quello che scrivi è interessante e ci sono persone disposte a seguirti se riesci ad esprimere i concetti con le parole giuste.
per la cronaca...
IT carrucola = ENG pulley
suggerimento numero due: prima di pubblicare il post puoi usare il bottone "Spell Check" che ti fa un controllo ortografico e ti segnala le parole che non "tornano"
Continua che ti seguo sul forum
Alessandro
Padova
hammuraby
hi tuz, i had try to do what you say, and the spelling say ....good.
may be is not a problem of words, but how i make a sentence...
then, i had read something about your intrests.
you that speak and write a perfect English :
will you write what is your own thinking about??
my be you can help me to intrest someone to understand a system for a free-powered elevator, w/out power income needs.....
just sometime, when rain , collect a water from roof,and parking.......into the designed water-brik reffilled pool
but this work at the same in a building, whit a reservoir on roof; whit a 100% discharge power recycled
whatever, if you use that system for discharge a trucks or navy, you can have more power to recharge;
because the point that start the RISE is upper then the point of you place the loud...
many tanks for the attention
hammuraby
when is read a basic fhisic datas exponed in reply#8
on how this sistem work, i try to link this data whit a sample in the picture:
the heaviness that pull in a tube (d 16 cm = 176 cm2)
from the pool (refilled whit fired brik, sicurity first of all !!)
to the underground water (60.00mt) is
ALLTIME 10 000 Nm
when you need to rise a loud like 6000Kg
the gear for be in balance is 10:60 on a conic gear box...
it will be raise whit 10:61 and the water go DOWN the sink..
then when you leave down the loud the gear have to stay on 10:59
at the same time the water is pomping UP in a waterPool
closed the cicle , you have wasted only less then 2% of the energy needed
usually for a lifter machine....
RESULTs: you can recharge the pool whit a elettric pump, and 1 kWh can make a LLOOTT of work befoure the accumulator-pool need a recharge; this possible by collect rain water!
