Thanks to ALL for your help!!
Buoyancy wheel inside two conditions.
Started by Low-Q, March 04, 2009, 11:29:44 AM
ramset
Vidar
LOTS of variables[opportunities] in your system
I am drawn like the moth to the flame on these ,your's more so .One thing you just said was you found the resistance on the vacuum was not linear to distance?
Chet
Thanks Grandma
Low-Q
The force on 1cm2 is 1 kilo regardless of the vacuum volume, but when one of the pistons is under water, the water weight will push the piston down. So magnetism is the counter force for that weight.
hansvonlieven
@ Vidar,
Why have the vacuum there at all, why not vent the cylinders?
Where is the advantage?
Hans von Lieven
Low-Q
Quote from: hansvonlieven on March 06, 2009, 02:13:48 AM
@ Vidar,
Hans von Lieven
I have been thinking on the same idea. Thank you for reminding me :)
Also when I look at the drawing, I should only have a straight bar magnet at the bottom and the same on the top, with the same pole pointing up on both. This will reduce cogging when the rotor magnet is approaching and leaving the bottom magnet, as the top magnet will attract the rotor magnet as much as the bottom magnet will push it away.
One more thing: If the counterforce from the magnets is great enough, we can maybe fill the tank all the way up with water.
Br.
Vidar
Low-Q
Quote from: ramset on March 05, 2009, 06:13:36 PM
Vidar
Chet
Hi,
My last reply was made with my cellphone, so here I will explain further.
It could seem to be some misunderstandings in my explanations earlier. I meant that th vacuum volume is less on the right side, not the force that pulls the vacuum.
And there isn.t that much variables. You have:
Buoyancy
Gravity
Magnetism
Gravity and magnetism cancells out the weight of the water pushing on the pistons.
Magnetism cannot affect the weight of water. So that buoyancy force is the only force left.
Force can again acellerate mass untill friction limits the speed. So there you go - A spinning wheel.
But I will again mention that I'm rather sceptical to this. I'm just trying to make ideas I cannot understand fully. It is my form of brain workout :)
[off-topic]I hope you fly AROUND the fire, as moth tends to burn up rather quickly when flying OVER or THROUGH fire ;D.[/off-topic]
Br.
Vidar
