The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
dean_mcgowan
@ronette
superb .. yes this is the document i read recently and thankyou for re introducing it to the forum . it is extrememely valuable for the novices in this field to help gain an understanding of the basic principals of what is to be considered.
I personally believe it is required reading.
Though others might disagree.
Regards,
Dean
AhuraMazda
Functionally, a thermionc valve works like its semiconductor counter part but for it it work you had to have an electron cloud. Read this http://en.wikipedia.org/wiki/Space_charge.
AM
JohnMalkovich
Thaelin
Has this thread been totally abandoned in persuit of the Turbo? Granted that there was a lot of good info found there but I feel the real thruth still lies here.
The more I read the last post of mannix, the more I think that the inner wire should be induced with freq1 and the four outside coils (two pairs) inject the other two freqs to cause it to speed up. As this happens there are peaks that cause the vibrations.
Have to get this sig gen working. First try failed to work right. Some sleep and then back at it.
sugra
Grumpy
Not abandoned.
Everyone is hard at work.
Try pulsing outer coils and collect with inner.  Let it run for a while with just pulses to build the field up on the collector.
Run pulses through a diode (or bridge) and use as trigger for switching device to make shorter.
You might even strigger several switches with one trigger pulse to pulse several coils at once.
        -Frank Edwards
