DIY ACID FREE CARBON BATTERIES
Started by Bizzy, February 23, 2011, 11:05:49 AM
Bizzy
Quote from: b_rads on February 24, 2011, 11:02:43 AM
Update on conduit cell battery.  This is my pride and joy build due to the simplicity, and cost.  The six cells in this battery took about an hour to build and the consumable part (conduit) cost less than fifty cents.  All other parts of the battery are reusable.  This picture was taken after 120 plus hours of continous run time.
Hi Brad,
That is a nice set up you have!... how much voltage are you getting per cell?
Bizzy
Bizzy
I know there will be some magnesium degredation while the circuits are closed, will there be any degregation when the circuit is open??
Bizzy
b_rads
Quote from: Bizzy on February 24, 2011, 12:02:07 PM
Hi Brad,
Bizzy
Under load the conduit battery is putting out 2.54v - below is a sketch of how I have them connected.  Given that - under load you would assume each cell is producing about 0.84v.  I have noticed in the past when connecting multiple cells the voltage does not always add up like you think it would.  I have no explanation for that.
Brad S
b_rads
Quote from: Bizzy on February 24, 2011, 12:05:39 PM
Bizzy
My guess would be some degradation does occur - but I am just guessing.
Bizzy
Quote from: b_rads on February 24, 2011, 12:27:47 PM
Interesting originally I thought there would be no or just very minimal degregation, just as you would put the metals on a shelf next to each other if there was no current there would be no reaction
I may just have to build a single cell set it up like the others and put it on a shelf. However because of the cost I may build two of your conduit cells. One to sit on a shelf and the other to run so I have somthing to compare it too.
Bizzy
