Dr. Stiffler's "New" Quantum Energy Reciever.
Started by synchro1, August 05, 2015, 08:20:49 AM
Void
Quote from: Hoppy on August 11, 2015, 01:33:05 PM
Further experimentation reveals that if I attach a croc clip lead to either of the capacitor leads and hold the metal clip at the other end of the lead, then I can see the same steadily rising voltage as shown in Dr. Stiffler's video, up to around 3V. Connecting the clip directly to my house earth will slowly discharge the capacitor. I suspect that my body is acting as an antenna, receiving EM smog.
Hi Hoppy. In my case connecting the mains earth ground wire to the negative terminal on the output eletrolytic capacitor
causes it to charge much faster and to a higher voltage, or also if I touch my finger to some of the connection points in the
circuit, but the electrolytic capacitor is of course most probably just charging primarily from AC mains field pickup in such a case, and
those are expected results when touching circuit points with a finger or connecting the mains ground wire in. I think we really need to see
how the charge rate compares when Dr. Stiffler removes the magnets and then adds the magnets back in, one pair at a time. The chances
of at least some of the capacitor charging being due to EM fields such as from the mains and other EM radiation sources like nearby cell phone towers
and WIFI access points, etc., are pretty high without steps being taken to show that such things are not a significant factor in Dr. Stiffler's setup.
All the best...
Hoppy
Hi Void,
I see very little effect when connecting a ground earth to the cap neg lead. As I mentioned in my first post, I would also like to see Dr. Stiffler comparing performance by using a hand held meter.
gotoluc
Quote from: DrStiffler on August 11, 2015, 12:29:19 PM
In a week or two I hope to post a new video which goes into detain and also includes charging of a 3F cap.
Take Care and stay reasonable.
Charging a 3F capacitor would be quite a feat!
I'll be  8) out for that
Luc
Void
Quote from: Hoppy on August 11, 2015, 02:05:53 PM
Hi Hoppy. Yes, a hand held battery powered DVM would also be very helpful, as a mains connected
bench DVM (if that was the case) may possibly not have its leads fully isolated from the mains, or may at least be
bringing the mains EM field in closer proximity to the circuit under test through mains field pickup in its wiring.
Between these two things of comparing the charge rate with no magnets in place and adding them back in a
pair at a time, and using a battery powered hand held type DVM preferably out in a back yard or park some
distance away from any mains connected equipment or mains wiring would be very obvious things that need to be tried.
The setup could also be placed in a microwave oven with the microwave unplugged and the door closed, and the output cap
voltage could be measured just before placing it in the microwave oven and then immediately after opening the microwave
oven door again, after leaving it in the oven with the door closed for a couple of minutes or so.
All the best...
synchro1
So everyone does not go off in Left Field on this presentation, the center mass between the magnet chain is ONLY a pickup. What is going on here is totally magnetic as far as the signal pickup. Think a moment can a magnetic field be modulated? Do all magnetic fields intertwine (assuming field lines can attach). Could plain old permanent magnets be used to intercept fluctuations from other varying (including earth) fields and combine (amplify?) them in such a way that energy can be extracted?
No this is far from simple, yet it is not all that complex once on looks in the right direction.
@ Dr. Stiffler,
Quote:
                           " The center mass between the magnet chain is ONLY a pickup".
That puts the "Tesla Bifilar Pancake Coil" high on the list of good potential pickups, right? That's the one I hit "Paydirt" with!
