TinMan's "Over Faraday HV HHO production"
Started by ramset, November 20, 2016, 04:28:24 AM
ramset
Hmmm
Well ,Brad is at an event [with family] for a few days ,
on the above comments which now read   "..."
I suspect there will ultimately be much conjecture on the actual MO of what Brad has done !
and plenty of scrutiny , but that's why we're here !!
respectfully
Chet K
Thanks Grandma
i_ron
Quote from: ramset on November 25, 2016, 09:23:11 AM
Hmmm
respectfully
Chet K
Chet,
To preserve the sanity of this thread I would suggest you have Stefan ban the thread wreckers barbosi and erfinder (Steve Gillis) immediately. He has nothing to bring to this group but the ability to take it down to the cesspool level.
Ron
barbosi
Quote from: i_ron on November 25, 2016, 11:08:52 AM
Chet,
Ron
Panicked over 3 dots? Asking help from someone with more chutzpah than you?
When the Power of Love overcomes the Love of Power, there will be peace.
wattsup
@TinMan
It's been a while. Hope you are keeping well.
About your set-up running at 60Hz, look, maybe you can try this side test.
With your set-up the way it is, find yourself a step down transformer. Connect the lower voltage side in series with negative that is coming from the rectifier to your stack. See the gas output volume. Then add a bulb as load on the high voltage side of the step down transformer. Then try the same thing in series on the positive side of the rectifier. Then if you want you can try it both ways with the higher side of the step down transformer in series.
See if there is an increase in gas production in one or more of those ways.
I'll leave it at that. Keep well.
wattsup
tinman
QuoteIts Faraday's law.
It may be his,but it is not mine.
QuoteOnly the current is responsible for the amount of gas produced.
That is incorrect.
If it were only current responsible for the production of HHO,then why a minimal voltage requirement?.
QuoteThat's why 4 amps makes 10 times the gas that 0.4 makes regardless of the voltage required to pass the current. Try it out side by side 4A in a strong electrolyte vs 0.4 in tap water.
Are you talking direct current,or total average current?
I have already tested my setup against a direct current,and my setup is far more efficient.
Brad
Perhaps wait and see the results i get at the end of this project.
