Overunity is it possible?
Started by lltfdaniel1, October 08, 2017, 01:41:49 PM
lltfdaniel1
Some may want me to be pointed to a magnet induction motor that is much more efficient when compared to an electric motor with use of switches and parallel path techniques.
I seem to think even with this method the magnet will slowly degrade in strength over time but yes you will get a cop over 1 with this method no doubt so that leaves me the question, where is the energy coming from???
I seem to think it is the magnets alone but i could be solely be mistaken.
Yes i can see very clearly that these magnet motors with parallel path technology will most certainly give you a cop above 1 so for a magnet motor this is great news, i tried to ignore it but yeah.
right i have been told it is the driving force regarding the overunity magnet motor and i can understand that perfectly well and yes there is real power torque in the process of the magnet motor giving you a cop above 1.
Somewhere there is an unbalanced force in the magnet motor i need that to be defined clearly, so i know the bigger picture as to where it is getting its energy from.
I know am brain dead but yeah, the design of the magnet motor does not need unbalanced stators, just apply a electric force in a parallel manner and that will give you or should a cop above 1 with switching effect so in effect it is extracting energy and that can self run the magnet motor with that extracted energy with energy to spare over, if there is a real driving force then it would do that.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
I have worked out regarding the magnet motor it won't get cold it isn't an open circuit thus it won't run of its extracted energy .
lltfdaniel1
If the magnet motor is open then you will be able to extract power from the environment for sure and if you reach the threshold it will turn into implosion where the circuit gets colder not hot
lltfdaniel1
I need to know how to do a cold circuit and how to transition it to a hot circuit.
Inter exchange of energy between them both so it won't implode or explode between the two circuits.when they reach the threshold.
I am confident there is a well known process for this to make it a reality.
If they know how to stop it expoldeing then the mirror equivalent is?
Need to know more about the cold energy which makes the circuit get colder and colder.
Why because it is a holy grail in energy extraction.
From my physics standpoint I know it will implode and is cold electric and the very nature of this force is unbalanced but a different imbalance that I know of and little is known about it.
All about the dipole so the earth is my dipole and using the earth's own cold electric against it self,how to stop it expoldeing and inter exchange energy this way.
lltfdaniel1
Yea I can see the circuit so it is passable.
To overcome this is like the same as having no friction so it works in retrospect the method for this exists and will find and share.
when your at threshold the vacuum/cold electric then starts to fluctuate wildly giving you this unbalanced power which is the holy grail of energy extraction, there is indeed a process for this like the same with having no friction when i mean no friction, you see friction in a magnet motor and you think it won't work but the magnet motor does work because there is no friction involved in the process like the same with the heat pump extracting heat in your fridge.
But with this to overcome and stop the circuit exploding or imploding  and the process i believe is well known you will also overcome all obstacles with these processes.
So yea if any of you know the process to bypass the implode in your face problem then give it a go and what will happen is the vacuum will be fluctuating wildly meaning there is a lot of power/torque the holy grail of free energy on your doorstep
So vacuum/cold electric then starts to fluctuate wildly is the last nail in the coffin meaning it has succeeded in doing what i want it to do out of all my posts here.[/size]
Maybe use particle accelerator only to excite the vacuum so it goes wild with fluctuations???
Just use a particle accelerator to bypass the speed limit and modified it so the particle accelerator antenna doesn't implode or explode with a process which bypasses the limit so it is in the threshold?.
It would be near the speed of light but there is a process which allows it to be dead 0 seconds and be the speed of light using process that i was on about and the very thing would be the earths own cold electric/vaccum being excited with wild fluctuation done with the particle accelerator.
The particle accelerator has to be a fully open circuit for this to work so you don't have to worry about imploding in your face etc.
There are negative ions in the sky so it will still work idea is that is it powered by static electric.
So yea from harvested static the partial accelerator starts off and gains speed until it hits the fresh hold then done automatically from the earth i now have quantum fluctuation going on in the antenna which is the key and last nail in the coffin and wallah.
