@Nostradam
many thanks for finding this.
Looks like it is really Steven Mark, his voice sounds familar.
Hmm,nice prototype.
The only thing what bothers me is the flat wood
thing plate in the upper case half.
What is behind it ?
Could there be any flat sized batteries be hidden
or is there just a flat coil behind it or something simular ?
Also this unit does not seem to have the effect, that it doesn?t work
when one puts it upside down !?
The magnet seems tobe pretty strong in this unit, so is this some kind of hint ?
Also the magnet is now fixed inside the coil, so no movement between coil and
magnet.
If this works somehow via Barkhausen Resonance effects, I wonder, if
the 2 mentioned transformers are just impedance transformers
to match the impedance of the 25 Watts bulb or if they play any
other role in it ?
The circuit board surely looks a bit like a switched power supply,
maybe it is from a 12 Volts DC to 120 Volts AC converter and
changed and fitted to the Barkhausen-Resonance application ???
What is curious, that the maybe  ? flatcoil ? behind the wood panel in the
upper half case seems to be in series with ths output bulb
and the transformer.
The wire from the big transformer goes first behind this panel
and then comes back to the bulb, so transformer output coil,
panel and bulb are in series !
That means, if the thing behind the panel is really a flat coil
with lots of capacitance or a flat condensor,
then the transformer and panel thing must be in resonance and
this seems to be an LCR circuit, where the 25 Watts bulb is the R load resistor.
Regards, Stefan.
aarnold
we don't need a transformer to ligth a bulb..... why does he use one?
GM
Quote from: aarnold on August 23, 2006, 10:16:48 AM
Maybe the output voltage of his earlier device is to low?
In his newer (toroid) designs he could fit the coil windings to get the right voltage
to drive a 120 volt light bulb directly.
And I am able to relate if he worked with small voltages on his first experiments.
This will reduce te "Ouch-effect" ;D
Markus
Nali2001
Is it just me or is the guy in this video:
http://video.google.com/videoplay?docid=-6540638039071490742&q=magnet
probably the same guy from this video:
http://video.google.com/videoplay?docid=-635987818295327978&q=utterly+amazing
http://video.google.com/videoplay?docid=-4298347669641896403&q=utterly+amazing
I reconized the way he talks\explains and also the voice sounds familiar.
Also the guys wears the same rings on both hands in both video's.
Big ring on right hand and smaller ring on left hand. Conpare the video's!
Does not per-se proove anything. But I'm quite conviced this is the same guy.
The plate probably is made from the same material as the rods.
What do you think?
