Are Tommey Reed´s pulse motor circuits overunity ?
Started by powercat, April 13, 2009, 06:40:33 PM
chrisC
Quote from: nievesoliveras on April 27, 2009, 09:00:13 PM
The thing is that we are looking for the circuit that has a PWM and is working in order to replicate it. The one kindly posted by @groundloop here: http://www.overunity.com/index.php?topic=7241.msg174681#msg174681 does not have the PWM circuit or chip number included.
Jesus
With efficiency of at least 400% at 30% duty cycle will absorb any kind of PWM chip you're likely to find. You can even use a 555 timer and some external components and that will still be OK.
cheers
chrisC
nievesoliveras
Quote from: chrisC on April 27, 2009, 09:03:32 PM
cheers
chrisC
Thank you @chrisc !
I am begining to think that it seems that nobody has replicated it yet and have gotten the mentioned OU.
With OU I mean that the circuit gets its battery charged from itself. I would be happy with the battery just not discharging.
Jesus
powercat
Jesus
@nievesoliveras  ;)
Tommey's Pulse Generator basic pwm
http://www.youtube.com/watch?v=0wocuKldVGw&feature=channel_page
cat
When logic and proportion Have fallen
Go ask Alice When she's ten feet tall
nievesoliveras
Quote from: powercat on April 27, 2009, 09:12:06 PM
@nievesoliveras  ;)
cat
Thank you @powercat !
I will wait a little bit for confirmation from other members that the circuit works and I will send for the needed parts from my next part time job money.
Jesus
bolt
The optimal pulse width is 38.2% (Fibo) for this setup.
This is why Tommy is seeing 30% better then 50% but he don't know the math behind it.
The system gain is (1.618 * Q of the coil)- System losses.
This is standard book values no magic etheric space dust here. All was shown by JML labs experiments, ARK Research and Bordland labs for longitudinal gain more then 10 years ago and elsewhere its all well published.
So back EMF or forward gain is a stochastic energy gain 1.618 over isotropic minus losses its OU,  if he can make losses small enough. Load must match perfect resonance to o/p. If you are charging batteries then battery acts as large capacitor. Will change system from OU to non OU states as it charges and discharges and creates resonance changes that must be addressed.
OU is real not dreams you need to know how to find it and use it. Above equations work for Newman, Bedini, coil bangers, and many other coil spiking systems and motors they all work the same on basic book values RF.  and 99.99% of people have no idea what it is even when they build it.
If you want more single stage OU power gain then Q is the easiest thing that can be addressed. Bigger coils, lower losses etc and more advanced use negative entropy looping and multi phase feedback aka TPU etc. So for three phase system its (1.73 * 1.618 * Q) Notice how much gain we have now. This is why RotoVerter system is so efficient. A 7.5 Horse Power 100lb motor will turn at 2800 rpm on just 10 to 15 watts.
Looping is an entire new problem due to impeadance matching networks are usually lossy and kill the last bit of OU.  That is why easier to show i/p power to separate o/p. Not as simple as putting a wire from out to in.
