Cavitation. The key to overunity?
Started by Pirate88179, November 29, 2008, 10:50:09 AM
sparks
    Order and Chaos  Yid and the Yang     Create order and the chaotic will spread quickly into the vacated field.  When we remove the chaotic from water it freezes and forms a more ordered state.  When the ice melts it draws into it's lattice disorder and becomes chaotic.
   An analogy would be 20 people using the same amount of energy running in random directions within a ring.  There are all sorts of people trying to pass through this ring of running around people but they cant because of the random motion of the 20 people within the ring.  Then the 20 people are "ordered" to use their energy to jump up and down instead of back and forth.   Now the ambient field or crowd can easily pass through or into the ring.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Magnethos
Quote from: sparks on December 27, 2008, 10:44:15 AM
I remember that I read Tachyonic energy is an universal particle, but we can only get energy from it if we use a High Level Order Material. I also remember that energy absorbtion from the vacuum is a process of Negative entropy (reverse entropy) that turns chaos(entropy) in order and this process is known as negentropy, and using the negentropy process we can tap energy from the vacuum, by ordering the virtual photons, I think this process is something related with the polarization process or something similar. We must also know that ElectroMagnetic energy is ANY order in the Virtual Photon Flux of the Vacuum.
So, with our theory, we can say that Cold is something related with order and Hot/Positive is something related with chaos. Cold/Negative energy can get energy from the vacuum, so the energy can be ordered by turning chaos into order (Negentropy). Hot means disorder-chaos.
This sounds interesting...  ;)
madddann
Magnethos
"Boiling point is related with Pressure."
- There you go!
"So, with our theory, we can say that Cold is something related with order and Hot/Positive is something related with chaos. Cold/Negative energy can get energy from the vacuum, so the energy can be ordered by turning chaos into order (Negentropy). Hot means disorder-chaos."
- What about that: ok let's start somewhere... difference in pressure is a potential - from that we can get particle motion - from motion friction - from friction heat - from heat again pressure... Yes there are EM waves also in there, their frequency increases with heat (i think gravity is just a certain combination of all that) and maybe something else, but just to see better the entire picture in a simple way...
Now lets see the particle motion part - from that we can get difference in pressure - pressure increase in front of particle, pressure decrease at the back and right there is most probably cavitation going on. But what really is that? For what i can understand, the process is similar to a vortex process - it balances - moves the difference in pressure (energy), like a tornado or hurricane. what if you imagine a black hole? For what i know it does the same thing. And right there right through that hole the energy flows. Does this ring any bells? ...this thing can move the energy from a lower state to a higher state (or vice versa - not sure about that).
I just wrote this down from my thoughts in hope that it would help, so please correct me if you think i'm wrong somewhere...
Dann
Magnethos
madddann
I think you're right because I read other work of a guy that was saying the same as you.
"Boiling point is related with pressure."
If anyone want see this, here you have a video
http://www.youtube.com/watch?v=ZRZhzX67xHY
I have found another interesting video where the guy boils water using ice
NOTE: I don't know if this video is a fake.
http://www.youtube.com/watch?v=PDoMBfSUSnY
Look at the similarities in both videos. When we decrease the pressure, water boils. When we put ice, water boils. So... water is absorsbing something... Maybe thermal energy in form of radiation?
Some days ago I thought about if melting point is related with resonance and not with temperature. Because if the boiling point is related with pressure, melting point is not related with heat... maybe it's related with ressonance. And I thought a possible way to perform a Cold Fussion(melting) experiment.
The theory you say seems to be ok, but remember there is also a 2nd electricity: The Cold/Negative electricity. In this kind of electricity when you draw more power, the system colds down more and more instead of heating up. I discussed what really is Thermal Energy (hot or cold), since cold is not
cold generation. Cold seems to be Heat absorbtion. I have discussed something related with pressure difference and the energy generation. I said that energy generation is possible while the poles are assymetrical. When the poles are assymetrical, there is a pressure difference of the virtual particles and electric generation is possible. I think amperage is not the amount of electrons that a dipole can draw in an amount of time. I believe amperage is the tame to turn from an asymmetric poles to a symmetric poles.
Discussion here: http://www.overunity.com/index.php?topic=6384.0
I read gravitons are photon/antiphoton pairs.  Maybe Gravity is the opposite form of inertia, like an inverse inertia.
And I believe electricity are just photons, not electrons.
QuoteFor what i can understand, the process is similar to a vortex process -
I read in a book that attraction in magnets isn't due to the South-N or N-S. Magnetic attraction is due to Vortex running in the same direction or vortex running in different directions.
spinner
Quote from: TheBuzz on December 25, 2008, 01:28:56 PM
I built something along this line recently and the transformer seemed to resonate at 21MHZ - the ferro nuclear resonant frequency of iron. I don't have a frequency counter that goes that high but based on my old scope appeared to be right in that range and was similar to Meyer's burst waves that he was showing at the end of his notes.
The ferro-nuclear resonant frequency of an Iron?
An Iron acts as a very good EM/heat converter when used as a core in High-frequency coils....... The magnetic lag of an iron is somewhere in the range of a few milliseconds..... That means a coil / energy with a frequency of a few tens of kHz or above is converted mostly to heat.
A 21 Mhz circuit with an iron core? RF heater....
It is just a tutorial and an interesting one at that. Also get to know a little more about Marinov. He figured out the Hubbard trick and his work shows how to start the coil with a glancing arc against the inductor. Read the Seattle intelligence  article of the boat account and how Hubbard arced / struck a wire against a metal plate for five minutes until he got it working.
Marinov? Stefan? PM?
;D
"Ex nihilo nihil"
