RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
gotoluc
Quote from: Groundloop on December 28, 2008, 04:54:44 AM
@Wattsup,
Luc asked me to look into a circuit that used the 4013 and IRF640 because he had those components.
When I designed that circuit I relalized that I needed two high side drivers to get it to work. I desided to
use the IR2103 since I already have used the IR2103 and knew that IC. The data sheet for the IR2103
states that one should use a decoupling capacitor on both the low side switching (at the input of the IC)
and at the high side of the switching. These capacitors will help average the current going to the IC so that
the wires and other parts stay cold. The 100 nano Farad capacitor on the high side will help to reduce
heat in the diode. The IR2103 is designed to operate at up to 600 volt on the high floating side. The IC is
also tolerant to negative transient voltage and dV/dt immune. The hexfets used has internal diodes between
drain and source and will survive voltages up to the rated voltage for the types used. But you know Luc. He
immediately cranked his variable transformer up to 50 volt and ran the circuit. LOL
The back emf voltage pulses from the coil is brutal at this voltage level. He was operating the circuit very close
to the maximal voltage level permitted by the components used because of the  back emf voltage spikes.
Luckily for us, Luc did not know that. The circuit barely held together and he found the new "effect" in his output coils.
Then he found that the initially used diode (1N4007) was warm when running the circuit. It is my best guess that some
of the back emf voltage was "burned" away as heat in this diode and when we change it to a faster type then the voltage
spikes had nowhere to go. The hexfets internal diodes was not fast enough to channel the back emf voltage back
to the power source so something had to give in at some point in the testing. The IR2103 was the one that couldn't
take it because of over voltage so the little IC just caved in and burnt the high side internal mosfet transistor. Then Chris31
chipped in and suggested a change in the design that will keep the IR2103 safe. I added the components he suggested
but has not tested the new circuit. There you go, now you know why this circuit is designed the way it turned out to be.
Now we has designed a new switch based on what we learned about the old circuit. I do not know if the new circuits
will be better or worse than the old one because I have never tried to run a coil as a load at these high voltage levels
before. I understand that we need transistors with a high voltage capability etc. The new design uses "floating" switches
that are powered directly from the high voltage side of the circuit. But, knowing Luc, he will probably crank up the
input voltage to 100 volt and just vaporize the transistors and opto couplers. LOL
That said, this is a good thing. Without Luc's testing we will never know what it takes to make a good circuit that
can survive the high voltages and also display the "effect" he discovered. So we are on a road of testing and designing
good circuits that can do the job and still work another day. I think that if we work together will will archive that goal.
I all in for P-Type mosfets and other circuit solutions. Anybody that has good ideas if free to design circuits solutions
and post them here. Please do a drawing of your deviation circuit and post it here. Your design may be very good and
can be the next circuit we build.
Now I would like to address a "phenomena" still floating around on free energy forums. People like to group other
people. I often hear words like EE's and OU's. I do not like it at all. In here we are a bunch of people working for
a common goal. There is no "us" or "them". We are all just peoples doing the best we can to develop something
that may work some day to help solve the energy problem once and for all. I can only look at myself as an example.
I started out my working career as a fisher man. Then I completed three years at college and was educated as an
radio and TV repair man. This is the only school years for me. I have played with electronics as a hobby since I was
approx. 9 years old. Now at 51, I have studied many books and try to keep up with the changing world as best as I can.
Does this makes me an EE? Yes and no. But in any case, I have had great fun with electronics as a hobby and for
the last 5 years also researching free energy circuits. I think is is the fun that keep me going.
Groundloop.
Excellent post Groundloop ;)
This is the exact story of the events that have taken place. Thank you for taking the time to write all this information and about your personal life background and experiences. I am truly grateful for all you have done to date and for speaking from your heart about the importance of working as a group or team since this is the key element to having success. When we divide ourselves we loose touch with our truth which is,... All comes from ONE and All returns to One. If you experience separation, that is illusion. Illusion is a part of the Cosmic design that gives the One a measurable experiences. The more you stay in this illusionary divided state... the less Power and Knowledge you have... the less Power and Knowledge you have the deeper you are in this illusionary state... hence, our World at this time. We all want perpetual motion but we live in perpetual illusion, to which translates to ignorance of our One and only Truth. Our Truth is, infinite Knowledge and Bliss. The ONE aka God, has sent us His Son many times to help us out of this illusionary state. Buddha, Jesus, Allah, Zorastra, Nanak All are from the same! and have all the same fundamental teachings to Love every One and help every One... but still man failed to see the similar lessons in these teachings and reinterpret the teachings to fit his illusionary state and created religious divisions within his illusionary state ???... now you are starting to see all the layers we have created form all this ignorance???... it doesn't just end there!... during all this play of illusion, some decided they should have more then the other (caused by ignorance that all is One) and over time we have refined this art of selfish greed and it is known to us today as capitalism!... we have even created an education system that teach you the more you have the more successful you are ??? ... reality check please ::)... we are trading our Mother Earth for green pieces of paper (aka money) to do what again ???... we are a very sick bunch and need a serious reality check :o... Jesus let man sacrifice his body to teach man many lessons... detachment of this illusionary world is One ;)... I'm sure many can think of other reasons... Jesus also said, "do as I do and the Kingdom of God will be yours"  and what did Jesus or any of His incarnations do?... was he busy accumulating money or things?  no!... He was Loving and Helping All and mostly those in need! which can only comes from a state of Oneness Awareness! which is the Real Truth and Knowledge.   So why are we not following all these teachings?... ignorance! fueled by ignorance?... or maybe your illusion will create the illusion that all what Luc just wrote is his own illusionary state?... you decide :)
I wrote all this in order to confirm what Groundloop was sharing and maybe to help you understand from where I'm coming from. So I'm with Groundloop on this one! we need to work together as One and share. I have faith by working together is a Higher state of Consciousness and we will receive the Knowledge in due time.
Thank you all for your interest and sharing at this time.
I will leave you with this quick video to which I received today form someone. I do not want you to follow anything! just listen to the message: http://oneminuteshift.com/videos/babaji_video/the_power_of_vibration
Love and Peace to All
Luc
Cap-Z-ro
Haven't watched the video as yet luc...but you certainly have the correct approach to life.
What people cannot grasp...is that when you work to fill your cup only, your task will never end...nor will your discontent.
When your mission is to fill the cups of everyone, your task will be effortless due to the state of satisfaction and well being which accompanies you, as you journey through life filling cups along the way.
Regards...
gotoluc
Quote from: Cap-Z-ro on December 28, 2008, 02:13:53 PM
Regards...
Very well summarized Cap-Z-ro ;)
Thank you for also sharing
Luc
Well, the interesting phenomena keep on happening. Today I was able to light up a NE-2 neon bulb, and a string of 3 LEDs...all in series. Yes, a 90 volt neon bulb and 3, 1.5 volt LEDs, all in series. I would not have predicted this, at these relatively low frequencies of oscillation.
http://www.youtube.com/watch?v=BwbdvDms0Bk
gotoluc
Hi TinselKoala,
excellent video demo ;)  and very interesting stuff we can do with this energy ;D
Thanks for sharing
Luc
