Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
das aloda bullspit
@sutra
Is it possible it possible to make a crystal cell that uses features from hutchinsons/mechanical type and also properties from rieds cells/semiconductive energetic diode type
I am trying to combine these two together to make a hybrid 3rd cell that may have properties of both cells.
I have alot of barium titanate 99 percent pureand other minerals and thing of that sort I am also going to try sintering some of these chemicals together using a microwave it has a magnetic energy and it will heat it upto 400 degrees ion whitch i gan take it out and put it into a metal tube add a rod of metal and polarize it with bursts of 600.000 volts from my vandegraff
which only usues static electricity and three spheres and a massive mayo layden jar all hooked up together in a configuration for more power
I hope this goes well :-\
...........B..................
mrbr00k5
@das aloda bullspit
That sounds like an awesome idea. You've got some nice ingredients and equipment. The van de graff generator should work well for this. Keep us posted. ;D
das aloda bullspit
I will try  I cannot get photos for this still as there seems to be something up with my computers camera software i maybe some time with this idea as one of my van de graaffs have broken and my triplex wimhurst broke aswell...has anyone thought of connecting tasers together to create a generator they are almost continual pulses and it may work upto 1kv if you hook them together i tried with a cell once with alotof lutetium oxide in it it got to .80 volts then for some reason when shoretd it arked and the tube busted open and the crystals went everywhere..dont know quite why..all my stuff does ound impressive but its not that good its just old microwaves vandegraffs radio emmiters a mini stove and a taser based electric generator oh.. and a vaccuumm tube glass bell....and as for my engriedeints i get them off ebay and my old science teacher gave me a lot of themi didnt buy the niobium or bismuth iths my schools iff i was to doit it the school would take alot of the credit for giving me the ingriedients   and i would be happy with that :)
jeanna
Welcome to mrbrook5!!
Thank you.
You made an awesome post with all the info needed.
wow!
This idea to use the colors for semiconductor effect is brilliant.
I hope I can find this bornite.
I have a pretty chrysocolla rock, but maybe I need to go for a ride (16 hours) and visit a great little rock shop. I need the excuse to go., and bornite looks like a good excuse to me.
Thanks for your great ideas and particularly thanks for sharing them so generously.
In a funny way, all the elements here are what we have been grinding and combining - even the sulphide. Ian had a story about that early on... Thanks so much for helping to put it together.
jeanna
das aloda bullspit
Oh as a replyto an earlier post about magnetic allignent and magnetic iron powders in cells .has anyone tried tou use any crushed neodynium oxide found in harddrive magnets, and added it to your mixes? It could under voltage cause a verry unusual effect and also when you talk about heating things up but not melting them but getting them to stick together there is a prosess called sintering wikipedia should fill you in also has anyone tried using verry strong magnets put over the copper posts and stuff to align it better also the niobium seemed to work pretty well in my cells if albeit abit strange results from microtester oh by the way is no longerat 6h volts the wierd scifie dr who effect ive dubbed it has ceased it is at 1.09 volts and quite stable im going to try r salt manganese aluminium special alloy from my old teachers metal collection abit of germanium fro the semi-con Btitanatefor the p. zofx and some other low resistance stuff oh and i heard that the hiroshima cell H made costedover 3000 dollars to fabricate i heard
