Stanley Meyer Explained
Started by h20power, March 15, 2009, 06:34:59 PM
h20power
Quote from: wfchobby on September 13, 2011, 01:20:06 AM
Hi H2opower
that looks like a nicely built cell set - i notice that the design appears to work like a capacitor in that the only area of water contact is between the 2 tubes - what about the centerer of the inner tube - is it left open because i was wondering how you circulated the water from the top to bottom sections of the cell.
With the resonant cavity drawing, diagram attached, where is the earth symbolized connection on the water inlet connected to.? I'm unclear of its purpose - is it for setting a electrical polarity on the water entering the cavity.?
the question: On the VIC coil driving the cell - has anyone contemplated what would happen in the circuit if the secondary had a centerer tap and that centerer tap electrically connects to the water in the cell. ?
What I was curious about was the earthing/grounding of the inlet, and as the vic/chokes/cell are effectively a closed circuit.
Even referring to fig 8-11 of the rotary vic on the alternator setup, the diagram clearly says - water bath electrical ground 0v.
For a ground point for the water, as seen on the inlet of the "resonant cavity", is that applicable to a WFC and if so could a ground, zero point, be utilized by a centerer tap on the secondary for as an example for reference, as seen in a simple dual rail psu circuit.??
I can see 2 diagrams that refer to the water being 0v, wfc422da and fig 8-11. Writing by others suggests that on a vic circuit and cell they can get high voltages across the electrodes/plates but little output, so might an area to explore be the potential of the watter as in the 2 Meyer's diagrams?
is a cell a water bath and resonant cavity.?
BTW - anyone find the kontera.com and infolinks.com underlining of "hotwords in posts and the forum a nuisance? - use Noscript with firefox to prevent the scripts for konterra.com and infolinks.com from being used -  makes the page much cleaner to read
Hi wfchobby,
The ground to me just is showing water is being used as a ground and not being grounded to an outside source as that would mess the whole process up. Water is also being used as a resistor as well as a dielectric by Meyer. I added some new information on the topic here: http://www.hereticalbuilders.com/showthread.php?t=174 that you might find very useful.
In the ER 10 design the center electrodes are solid and have been machined to allow water to flow through the system just as Meyer's dune buggy ER. A few changes where made to the original design but it is fairly close to that of the dune buggy's ER. As of right now I don't see anything else like it on the market so I guess I am the first to make something like that of Meyer's new stuff before he switch over to the direct injection system.
I hope you find the heretical builder link useful as I put a lot of time into adding science to the work of Meyer for everyone to learn and know. I am not perfect but I think I did an okay job in trying to show the science behind the patents.
Let me know if it helped or not?
h2opower
wfchobby
Hi H2opower, i like your work, nice and neat.
Thank you for the hereticalbuilders link - very useful thanks will take several reads to absorb. To my mind with the limited space in engine bays the injectors are the way to go because the multiple cells are just too bulky, im interested to see how you progress with the injector system.
h20power
http://www.newenergyfunding.com/campaign/detail/985
With this technology we can take the control of energy away from those that sell energy and give it to the people. If you're reading this can you see it in your heart to support this technology at a time when it needs you the most? Even a $5 donation helps for just as a drop can eventually fill a bucket your donations can make this a successful campaign and a new brighter future will be our new way of life.
Thanks Everyone for your support,
h2opower
markdansie
Would appreciate some data like power in gas out.
I hope your experiments work out.
Here is a recent article I wrote for those new to the water for fuel concept.
http://revolution-green.com/2013/06/05/water-powered-cars-and-generators/
Kind Regards
h20power
Quote from: markdansie on June 08, 2013, 12:15:15 PM
Kind Regards
Hi Mark,
I want you to take a close look at what I tell you in this reply as I assure you that I am talking like no one else you have ever heard from before, okay? Dig into your notes and see if you can find a single person saying the things I have said in this post.
The way Meyer's technology works is just like an ozone generator that makes use of an ionizing electrical field for the most part.
An ozone generator draws in O2 molecules and breaks them down into monatomic Oxygen gas atoms by way of ionization. Nothing comes together inside of the ionizing electrical field but once these monatomic gases are back in our atmosphere they quickly find O2 molecules to form O3 with. Meyer's technology is just about the same but this time water molecules H2O are being separated by way of ionization. Unlike O2 molecules these atoms need to be sparked off in order to recombine but they are broken down in the exact same way.
Now to prevent these monatomic gas atoms from reaching a stable state longer the electrons are taken away from the system by the electron extraction circuit. This is how Meyer's technology actually works no BS. The atoms within the water molecules are ionized and those electrons furthest away from the protons are the first in line to get stripped away from the atoms, but in this case those atoms have the job of holding the water molecules together. Now the water molecules can withstand to lose one electron and remain intact, part of it's own self ionization properties, but the loss of two and it simply falls apart into its component atoms hydrogen and oxygen.
It has taken me over six years to figure this technology out and more than another year afterwards to get all the items together to build it correctly. In the most basic of explanations a lot of energy was added to the system electronically as hydrogen still seems to perform the role of an energy carrier as the water that it is being used from is not destroyed in the process. In order to run a car another device Meyer calls the, "Gas Processor," is needed which will remove a small amount of mass from the oxygen atoms being drawn in through the intake system and in physics if you decrease the mass of an atom you increase it's energy potential and how many oxygen molecules are being drawn into the intake system? As you can now begin to see a lot of instability was added to the system. This is not Dr. Faraday's electrolysis method but a whole new take on breaking the bonds of the water molecules and how to make best use of the gases thereafter. In this system there are no bubblers being used as that would stabilize that unstable gases which would result in a loss of energy.
There are only two sides to this coin. One, on the side of this technology and the energy independence it brings, and the other side of the coin being on the side of the systems of energy enslavement from which we are currently all trapped in right now. I am sorry but those are your choices love them or hate them that is just reality as you will support one by default rather you like it or not. Sure there have been a lot of frauds out there trying to make a buck off of everyone but listen to the way I talk about this technology as it is something you truly haven't heard of before.
But note plans are being worked on to showcase this technology so that you can actually view it working correctly, okay? As you do have a right to see this technology in action, just bear with me as things are being put together for you, okay? Thanks
Job 38: 22-23 http://www.newenergyfunding.com/campaign/detail/985
Take care and God Bless,
h2opower
