Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
Bruce_TPU
@ Bob.R
The Story told to me WAS of Sound waves, from a earphone placed on a wire input.  It produced massive ammounts of electricity!  The earphone was plugged into an FM radio.  All of this was BEFORE brnbrade posted last night.  he wired direct to his headphone output and did not use the same method to produce the waves.  :)
Cheers,
Bruce
brnbrade
 Hi btentzer
I make little moving demonstrate my experiment concept.
Tks
Thedane
Quote from: brnbrade on June 24, 2007, 03:00:24 PM
Hi btentzer
Tks
Hi brnbrade,
Your video shows an analogue meter where the needle follows the music - and not much more.
(To me it also looks like you're taking the output from your stereo and channels it through a transformer - something that is NOT even close to unity.)
May I ask which concept it is that you're trying to show?
//TheDane
brnbrade
Quote from: Thedane on June 24, 2007, 03:19:18 PM
Hi btentzer
Tks
Hi brnbrade,
//TheDane
//TheDane
Yes. Here anything of more for the moment.
The one that I wanted to show as the sound waves balances.
That inside of the one of my device also scale.
And it is known that a magnetic field varying in the time generates energy.
How yes, so fast the primary ones to balance the secondary ones they collect more energy.
It is it that me leaning of that everything.
http://www.youtube.com/watch?v=Y6UTQLRW9bs&mode=related&search=
regards
Bruce_TPU
Hi Brnbrade,
You are right.  The voltage fluctuates with the beat oscillations of the station.  I just finished hooking up stereo wires from a headphone output of an FM radio to a transformer.  WAS NOT looking for OU, before everyone floods me!  LOL
I noticed some weird things.  At the bottom of the FM dial there was .001 readings, nothing there.  I hit 101 on up and things looked better with readings between .8 mv and 1.2 volts.  I then did a little mobius loop from outputs to inputs with diodes to input the feedback and got it up to between 6 and 7 volts.  So the faster the pulse of this wave I think the more power will be generated in the proper circuit potential, with the correct frequencies.  Also, as I adjusted the gain it had a direct affect on voltage output.
Remember what SM says about the TPU?
"You can begin to collect the current and dissipate it with no need for
amplification because the signal source also becomes the feed for
the power source and has the natural tendency to run with gain.
Brnbrade, what size pvc did you use to wrap your wire?  We would like to try to repeat what you have done.  Have you tried it again today?
