Any ACTUAL OU devices on this whole forum
Started by Permanente, May 17, 2016, 08:10:37 PM
jimbo
Hi Gothic
Nice but you will need to feed off a radio wave source and be outside .with these caps you can be under water under ground or on Mars it makes no difference and is not dependent on any one completely stand alone .
Liberty
Quote from: jimbo on July 31, 2016, 06:45:48 PM
Hi liberty  no ground was about 10 foot out and only two feet deep!   The POS line was about four ft long but setting next to me. Was the power box .I've been on line for weeks looking at everything related to this kind of charging trying to find a flaw any thing that would show me an mistake just something any thing but every were I looked I would find more and more confirmation of its working alot of it  on physics sites teaching on fundamentals of induction magnetic and electrostatic the magnetic ihad no use for you know that the first person I found who worked this was benfrankin he called it an economical way of charging lyenden jars! .people get lost in the goppely goup of the series formula which only addresses capacity but says nothing about the induction factor involved the charge cloning going on the caps regauging to there new i
Sercomstances  make it simple with a magnet the North or South Pole will induce a polarity in several nails it pics up each nail is a magnet now it may even retain it when separated from the source mag. But that's really not very useful but with a several caps it does the same thing but now when you short one out bang useful energy .then reloads it's self automatically !!!!. Clean and green as it can be. No solid state to fry with an solar flare no emp bom damage real good  stuff. Just get to work I wound to see blisters on ever finger.
Jimbo,
Why don't you design a circuit to gate out the charge to a light or motor, possibly a capacitor which is hooked to this light or motor.  When the caps reach a top charge, have a transistor of some sort turn on and allow the power from the cap to discharge to your load.  Do this with each cap.  See if it will run a light or motor continually with out power input from any source that you supply.  At least show there is no current flow from the input to justify the output.  If it works, you will make people happy here.  Make a youtube video out of it to show people a working model.
Liberty
"Converting Magnetic Force Into Motion"
Liberty Permanent Magnet Motor
jimbo
Im looking into it a chip I think it was a 4212( i might be wrong) run by a 555 the first chip used as a sequential runner to switch a role of MOSFETs sequencely  .I'm a little tight on money right now so I'm working on a mechanical wheel switcher. And them there's the picking out the right power MOSFETs. What's hard about this device is that it's a pulser not easy to access power but looping it would stop the negative commentary. It's hot as hell here around 100 alot and no AC .I'm tired most of the time.so work is slow but that helps in deciding how to make it better the first time  more thought and less wrong creation..hay just run the series cap formula and that's been a standard for centuries. I found a RC calculator on line which if I use right should give me numbers on the series string caps relating to power I would have to put a cheat in it for the resistor value like a one. Give it a little time and I will get there.but if you use the series formula remember  that DC doesn't flow Thu any cap unless it's trashed .and each cap in the series has the same charge in electrons so the charge. Cap can only charge to the same level as the rest.but the capacitance does change and this give a different voltage reading on your meter.but when each is shorted there all the same. Jim out.
RoliK
Hi,
your conecept is simular to this one:
https://www.youtube.com/watch?v=eGD9o7D4To8
Instead of the brass rod/coil you are using standard caps.
I tried this system also.
First with a coaxial cable instead of the rod/coil setup.
AC 220V --> Phase connect to copper core wire of coaxial cable (100m box) Other end of the core wire is insulated.
From Woven copper shield --> 4 Watt LED AC 220V --> Earth
Other end from Woven copper shield is insulated.
There is no electrical connection from Phase to Earth.
Result: The 4 Watt LED lights. Not very bright, but it lights.
The coaxial cable works in this case like a capacitor, so I replaced it with a standard cap for 250AC, and it works too, with better results.
The 4 Watt Bulb lights a little bit brighter.
I was using standard earth home connection and if I use more caps, my residual-current device acts!
I was asking an electrican, and he told me, thats because of the Leakage of the caps and that the earth connection is nothing else as the N-wire in this case.
So you "steel" some energy from the mains, until its so much current that the residual-current device acts.
I hope I did not make too many mistakes, English is not my main language.
RoliK
Update:
I made the test again and a second test with 12V Battery and 300W 220AC Inverter instead of the AC mains direct.
With AC mains, the 4 Watt LED light as same as last time.
With battery/inverter setup the LED do not light. I only got 10V AC between woven copper shield and earth.
So I tried 12V LED 1Watt, and it light, but very very weak.
Update health:
One other point. Always when I do this experiments, I got a feeling in my legs, if I do longer it will be a slight pain!
I heard from other tester, similar feelings, and I know from one guy makeing tests with similar setups, that he has really big problems with one leg, now since some months!!!
mfg RoliK
