The Tesla Project
Started by allcanadian, January 22, 2008, 05:56:53 PM
Grumpy
Quote from: Erfinder on March 20, 2008, 03:48:55 PM
(battery) (inductance)  (capacitor)  (primary)  (secondary)
Yes, this is understood.
        -Frank Edwards
armagdn03
Quote from: am1ll3r on March 20, 2008, 03:04:50 PM
Also standing out on the limb... This will probally need some correcting but have a look.
The genius of this circuit is the gain in from the occilations that are formed simply by turning it off. (Make and break of the circuit controller).
So far this is my understanding of it...
-am1ll3r
What program do you use to create these?
I wish I could turn my brain off sometimes, then I could get some sleep.
am1ll3r
A program called snagit.
http://www.techsmith.com/screen-capture.asp?CMP=KgoogleStmhome
wattsup
@am1ll3r
Nice work with the graphics.
You did this with Snagit. Geez must have taken you ages. I use it to grab video images. Pretty snazzy work indeed.
But there are so many graphics that trying to make heads or tales would take some time to see if there are any mistakes, but this would be a major task because you have lots of things going on there. I am not completely fluent enough, well more like confident enough to explain.
Plus guys like @AC or @Erfinder would need so much time to review each graphic that I think it will not be feasible to clarify each one. Just identifying locations on each graphic for each correction, etc., would take a long time.
So don't get mad if there is not much comment because the task is tremendous. The lack of comment has no bearing on the level of appreciation people will have for the actual work you put into this. Good on ya.
bocas
This is what I have learned so far working with the parts Erfinder gave us.  The L/R of both inductors is important.  My first L2 (primary)inductor had too small of resistance (2.3 ohms) which gave it too long of charge time.   My relay contacts arced too much so that I would lose a lot of the "self-induced current" back through the battery instead of through L2 and C1. I found that a 23 ohm primary helped everything run better.  My contacts still arc, but not as bad.  I found that Tesla wrote many patents about his circuit controller to try and prevent this loss of "self-induced current".
Bocas
