RESONANCE EFFECTS FOR EVERYONE TO SHARE
Started by gotoluc, December 03, 2008, 01:26:15 AM
0 Members and 102 Guests are viewing this topic.
gotoluc
Quote from: najman100 on December 06, 2008, 12:29:50 AM
Hello LUC
i just watched your vid2 and i wonder if you apply dc square will you get the same effect ?
Najman
Hi Najman,
I'm no electronic expert as I'm learning as I go but I think if I just used DC and pulse it with a transistor at the same frequency the coil is resonating with the output of the signal generator I don't think it's going to work as I think the output of the SG has a 50 ohm impedance matching transformer, so I think it is tuned to resonate with this combination.
I could be wrong about this, so if anyone wants to add information please do as this is a public sharing forum and ideas can develop when we share and work together ;)
One way or the other I will continue to test and develop and share the findings.
Thank you for this good question.
Luc
wings
gotoluc
Thanks for the link wings ;)
Looks good and thanks for sharing
Luc
kewlhead
Quote from: gotoluc on December 05, 2008, 09:12:15 PM
Hi kewlhead,
I'm not sure if I really understand your question ???... the coil is resonating with square wave AC but the Capacitor is charged by DC via the dual diodes off one side of the coil. Adding the Earth ground to either the positive or negative side of the diode plug increases the charge voltage for a reason I do not yet understand. Is it extracting that energy from the Earth?... I think it is but I can't prove it.
Hope this helps.
Luc
Thanks Luc, I was try'n to learn what arbitrary ground is.....  I ve heard referance to abitrary as not being there  and thought maybe when you removed the ground wire it may have been considered abitrary .
forest
gotoluc:
I have just a few ideas I'd like to share with you, but I don't expect you to do it for me.It's just for your consideration.
What is going on if you connect led or diode to the ground wire ? Doe it matter in what direction is it connected ? Does it produce light ? Is it measurable current from ground with ammeter ?  Did you tried with various coils ? What are the results compared to self-induction of coil ? I suspect that a coil with much longer winding should give a much better results, faster charge maybe.
Thank you for wonderful experiments ! Please don't give up !
