Well, I have not been to secret, and so I do not confuse myself, I need to explain a few things about my invention.
It uses multiple channels of water to transfer energy to the same number of air pockets, each air pocket is sandwiched between two pistons, the layered pistons apply a direct upward force on a hydraulic cylinder.
Each channel of water increases the "Head" and thus increases the pressure in the air pocket - to be clear each air pocket has a different amount of air pressure increasing in succession.
Since the greater pressure is in the lowest, each piston has a greater force than the one above it.
Now, this upward action of this set up is not much different than the same action you would get from a pneumatic cylinder.
10 psi on a 1000 inch (squared) piston will roughly lift 10,000 pounds - so will my design.
The main difference between my system and that cylinder is the down stroke, after the load is removed, the input is allowed to vent, my design keeps that exaust pressure at exactly half of the input.
In our photo's you will see two Z.E.D.s that is because we use the exhaust pressure from on side to supply half the fuel for the other.
You can guess the net gain...
More tommorrow, it is late.
mr.wayne@hydroenergyrevolution.com
www.mrwaynesbrain.com (http://www.mrwaynesbrain.com)
If I let the next part go unsaid - it would save a lot of trouble explaining......
As I said before - my machine physically acts like a pneumatic cylinder on the up stroke - that is only in outward measurement and repeatability.
The internal driving force of the machine is buoyancy.
Most people I meet think that Buoyancy is caused by discplacment - it seems to make sense - like saying walking makes a foot print.
It is pressure differential - acting upon a surface that makes buoyancy.
It is repeatable and true to expect roughly 62 pounds of upward force from a 12 inch cube of discplacement, the error that is often made is assuming the discplacement "causes" the upward force.
Yes a cube lifts 62 pounds that is because 12 inches of "differential" pressure is .43 pounds or 12 x .43 = 61.92
My machine layers the differential pressures so that 144 cubic inches of discplacement lifts 682 pounds.
The design makes "buoyancy" operate at values nearly exactly like a pneumatic cylinder.
What my design on the up stroke does - is important - it creates buoyancy - equal to the pressure times surface area -
"instantly upon adding energy" Normally - when dealing with buoyancy - you have a major set back on HP because of the fill and dump time add so much time to the process - it eats any gain you could hope for -
infact - I would say that straight buoyancy is under 30% efficient - just due to the fill and dump time.
I do not have that loss of time.
Oops - got to go to church.
More later.
Look forward to a video or schematic. Good work.
Congratulations on your device and concept. In looking at your device on the web site I see one thing that would be a concern unless this can be scaled up affordably. It would appear from the size of the units (and I would expect considerable cost to construct units that large) that this may be a working overunity device but for only getting 500 watts it would be very expensive. Comments?
I will think of what i can send - the internal of the tank is pretty ingenious ..Maybe I will send an AVI.
Very scale-able but this is not a small system - you could use it to produce hydrogen fuel for free, but not fit this thing in a car.
It could replace a cruise ship motor, tanker ect.
The only way to make this thing affordable is to use it for large loads, or large demands.
That is why we call it a "base power" free like wind and solar - just running all the time.
On the website http://www.mrwaynesbrain.com/index.php/demonstration-model it is claimed that the demonstration model generates 500 Watts. But how much power is put in to make the "hydraulic fluid" flow? There seems to be at least one pump (photo 3/7) which needs electricity? In a contraption in which several Kilowatts float around easily some 500 Watts show up somewhere.
What I see is an idea which needs a lot of money to be built and no substantial proof so far that it will work, just words or concepts.
Whatever it is, the strange thing is, that the inventor posts in an open forum, dedicated to disclosing how a machine works, but does not give any details.
I never understand why inventors enjoy talking in riddles. Does the inventor think he can get money from this forum by making bald claims? Does he want to satisfy a strange urge to be in the center of attention?
So, what does the inventor want? If he had a working machine, he would not need to hang around here. People would beg him to take their money or he would be taken away by men in black (depending on what you believe will happen in case OU is really found).
Nobody has to give away his ideas for free, but why boast, when it has to stay secret. What sense does it make to say "I have something but I am not going to tell what it is"? This is the worst advertising an inventor can do. This is how you loose all credibility. What idiot invests because of a web site that says nothing?
It is very clear which companies, universities or government institutions would look into credible claims, no website necessary. Even for very modest "innovations" you can easily get funding (of course you have to show something). I know some people who got money for new sensors, even training equipment or ways of drilling holes in a mountain. If there is something, money flows in. And these people just filed their "innovation" with the local "chamber of industry and commerce (innovation section)". Specially "renewable energy ideas" easily find funding if credible. And if you believe in a conspiracy, go to the "green party", they would love to present a "new energy source" in case it really worked (because they would get a lot of political bonus out of it, but they are of course not prepared to believe in words or concepts).
Any technology that really worked was immediately believed and funding was never a problem. It sometimes took decades till a technology was useful and profitable (some never were), but proof was always available. But in the so called "OU field", every now and then someone comes and wants to sell secrets instead of proof.
And a new "secret" appears in this forum every few months and always disappears rapidly because it turns out to be an illusion at best or a scam at worst. No men in black necessary.
Greetings, Conrad
I hope I do not get lost - jumping around.
The next thing that must be understood is that when you are "creating buoyancy" you are discplacing a fluid - usually with air.
Yes, the pressure differential acts on the horizontal surface unequally to cause an upward lift, but that is not the only thing going on - the fluid is moving out of the way, and the air pressure is equalizing to the "Head".
In my design, when we are filling the Buoyant part, we are moving the water level higher - that increases the internal pressure because it increases the head.
Head is the depth of the fluid, do not confuse that with the "height" of the fluid....
You can have depth without much height - an example take a 50 foot water hose and coil (three foot diameter) it onto a wall rack - both ends up - now imagine the water level "transparent hose" fills the lower half of every ring, and air is present in the upper half of every ring.
The pressure in the bottom most of the hose would be 1.5' head x .43 psi = .645
The pressure at both ends of the hose is 0 psi, the pressure is in the air pocket is 0.
Since you would have about 10 wraps of hose - how much pressure would it take to move the water down one side and near crest the other?
And what would the pressure changes be?
Each hose ring would have the potential to resist 3 feet worth of head, 10 wraps = 30 feet of head 30 x .43 = 12.9 psi at the end closest to you - and the pressure would drop the same each layer.
You measure 30 feet of head pressure at three feet high.
more later
Thank you Conrad for you analysis........you left out a little, Greetings anyway, I do not think you are trying to hide anything.
I always have a hard time waiting until Christmas to open presents....... Sounds like you and I have something in common.
Be patient, I have had to explain this to 18 engineers, and they always ask the same questions - which is what I am covering first.
To sum up what I have said so far:
Creating buoyancy is not locked in design by the volume of discplacement. Instead :having a pressure Differential acting upon a horizontal surface translates into a upward force in water.
Water and air behave differently when a force is applied - water transfers the force and will compress air, Air stores energy and can pressurize water.
Head pressure can create pressure, and the head can be separated by air and retain its pressure building property.
The machine is big - not for cars, not for single homes, not for airplanes
The machine is powerful, one could power an apartment complex, be used to generate hydrogen fuel, power a cruise boat, or hooked in series to power a city.
The 500watt model is not for sale - unless someone wants to buy the company.
I have also said - just having the idea is not enough, even building it is not enough, you need a support network and a team willing to verify and spread the word.
My motivation to share this with all of you - is purely to validate what each of you have dreamed is possible, and just maybe - you will direct me to the like minded people who will join the company.
I am nobody, But I am sincerely concerned for the worlds need of energy, and the impact supporting unsustainable and unsafe energy production.
Lastly - I am not concerned about what other people think about my efforts, no disrespect - but if I were to listen to all the nay Sayers -I would have never tried.
I have tried and succeeded, and It took a year to get all of my ducks in a row, legal protection, business plan, web page, share certificates, LLC and I am building the business team now.
You may not of realized it, but you are the first group of people I have shared this with - outside of my respected community.
I am not surprised by the way I am treated - even here - everyone thinks money will just fall from tree's when the O/U discovery is made. To use the need of money to deny a claim is unexperianced reasoning.
Have any of you offered to help, not yet, most everyone is looking for the fault.
Skepticism is a sign of intellect, but facts are little more reliable -and more important.
Finally - I will show you - in between meetings, I chose this group from many to release the discovery too.
More later.
Mr Wayne
Dear Mr Wayne ,
many thanks for sharing it here.
But I have not yet understood your principle.
A video or a few more graphics would really help.
You must know, that many of us are skeptical at your
principle cause there were many ideas before your own,
which turned out not to work, although they were very
ingenious.
So the skepticism is of course very high and
only a good video or pictures that show exactly
the working principle could get you many more followers and helpers.
As you already have a patent, it would really help
to see a video with some spoken explanations.
Many thanks in advance and looking forward to see more.
I still have the hope that somebody can crack the trick or law
of buoyancy.
Regards, Stefan.
I agree, but what about internationally?
Do you see the same protection?
@ inventor,
Very liked your last reasoning. please, go on..
Dear inventor:
You say: "- even here - everyone thinks money will just fall from tree's when the O/U discovery is made. To use the need of money to deny a claim is unexperianced reasoning."
What we get over an over again is:
- It would work if I put in more money.
- It just has to be made bigger to work which needs money.
- The principle is clear, I just need money to build it.
- It only needs one more thing to work which I can not get or build without money.
- This shows how it should work in principle, but I can not build the real thing without money.
And so on, you probably understand what I want to say: It is difficult to get money for a principle which yet has to be shown to work.
Money comes in easily if there is substance. And the substance has to be pretty tangible in case of an OU claim because the OU-world is full of misguided individuals. Yes, we all want a new clean reliable and affordable energy. But a mere wish or intention will not be funded.
A working machine will make its way. But I doubt that one single individual will get the credit and the financial benefit. Like with all "discoveries" (in contrast to an "invention"), it needs many thinkers to bring it from concept to a useful technology.
Who "invented" electricity? Who "invented" atomic energy? Who "invented" the hydroelectric power station? Who "invented" the wind mill? Who invented photo voltaic? Who invented the steam engine, the combustion engine? There might be individuals who mad a big contribution, but they were never alone. A "new technology" is not "invented", it is "developed" over time by many people and in many ways.
The biggest idiocy in our time is "I invent something and then I will be rich". This can be true for a gadget (based on well known technology), but never for a "new technology".
Yes, financial rewards seldom fall in the right place. But this is a political issue and has nothing to do with "technology". Only the little guy has to follow the rules. The powerful ones just take what they want. You can never beat that with "ducks in a row".
So, what should a "inventor of an OU-device" do? I do not know, I have never seen one who did it right! First of all, I have never seen a working OU-device. And once we really see one, I am sure that it can not be hidden. Who then reaps the benefits? I am sure it will not be us the people! And there will be hundreds of inventors and patent holders.
Greetings, Conrad
@ Condra,
you certtainly express a point based on what the man said, but i think lets give him a chance to explain the principle shall we?]
it maybe require large sums of money (lets assume for now) to run this machine cost efficiently, but a prototype i suppose could be constructed with a minimal amount of money and some tinkering right?
If that is not the case, even the inventor bears some real allien technology, since it cannot be easily replicated it would fall to the theory zone anyway.
ps: I suppose you have heard Kapanadze's last Hydro Ou alleged machine. perhaps it works on same technology? (how many could be there?)
Is that technology (fluid based) could be also sought at the electrical equivalence for easy replication or just try for an experiment (since electricity has astonishing resemblence to fluid mechanics)
ps2: this site by default goes to twilight zone. Everything said here should be treated with some tolerance. Otherwise, by default OU is out of the question so no need to talk about it, right?
Quote from: baroutologos on April 11, 2011, 04:21:19 AM
@ Condra,
Sorry, if I sound like a denier. I state what I need to see to make me believe. A investor has to see even more than me (a very tolerant searcher for OU).
The inventor wants to be believed. This is a lot to ask in case of an OU-claim.
If someone wants to explain his "invention", I am more than ready to listen. But I do not listen to "secrets" or "things that have to be protected". If you have a secret, keep it. If you have something to protect, hide it. But then, do not talk in riddles. Disclose it or seek investment (by help of nondisclosure agreements). There is no middle ground. The middle ground is gibberish and make believe. There are thousands of books and web sites talking about OU, they just can not deliver. I do not need more of that.
I am not making any rules, I state my unimportant opinion. Everybody can do as he pleases. For me there is no explanation without disclosure. But I do not demand disclosure, I demand consistency when something is said. "I have OU, but I can not tell you" is nonsense, that makes me sad. I have seen and heard it too often.
If people like to talk in riddles, fine, I will not take part in such a discussion. But many seem to like that. Fine, no problem. I will not interfere.
If I have said to much, my apologies.Greetings, Conrad
Conrad, very well said.
If you would like to see my working device - you are welcome to come on over, I love sharing the discovery, No one has gone away disappointed.
As far as experience of so many come and goes........ is that not with every attempt at innovation.
The process of discovery if full of failures, measurement errors, misguided at temps, and over optimistic claims.
When someone does hit it just right, like the "intermittent windshield wiper" .....no one worries anymore about the effort it took, the diligence it required, the tenacity to not give up. And yes, a big company comes and gobbles them up.
I wonder how many truly great ideas have went away from a need to fund, or to get people to listen.
I do not claim to have all the answers to the problem, but I do have a very over unity device.
A very good point you made: "Bigger"
When I built my first attempt - it was a "full scale bucket brigade" with modern improvements - that was before I truly understood how buoyancy worked - I have Photos. I learned a great deal with hands on and practical application.
(I am on design number seven - and it is works very well) I would say that I am an expert on what does not work, as well :)
One thing I heard from critics, and have confirmed with my physical research is that if it does not work on the small, it will not work on the big - (with a little disclaimer - your drag in a over all system does not reduce at the same rate as you can reduce the design).
And in functionality - if drag is going to be an issue - your machine is not worth the effort to build.
My models 5 and 6 were also over unity, (125) those designs each had four energy conversions, at the end of the day - the only thing I had to "sell" was $300 worth of electrons (a year) from a $35,000 dollar machine.
Very much a waste of time, my goal has not been to disprove the laws of physics, but to build a system that produces in an abundance.
I am going to post this chat, and go back to explaining my system.
Thank all of you for the interest. It is en courageing.
Mr Wayne
The principle of operation.
The water hose example I gave earlier is critical to understanding my process. Please review it if you did not already consider it.
I am going to use real numbers from the Z.E.D. in the photo's on my web site.
The Inner chamber(where all externally applied force is applied -{input}), has a horizontal surface area of 707 square inches. and is 20 inches tall.
It is the open end of the hose where force is applied (hose example).
When that Z.E.D. is at rest (fully down), the internal pressure is 1.8 psi Due to head pressure this pressure cannot be removed - unless the system is drained or reversed (vacuum applied).
1.8 psi is not sufficient to overcome the weight of the upward mobile parts - so in Essence, it is sunk (an absence of buoyancy).
In this position, as in the water hose, we are at rest - with no real work potentail, other than the natural head.
When air/or water is injected into that chamber - the displacement moves the first body of water and results in a transfer of the the "applied force" to the next pocket of air, that air is pressurized and the energy is transfered to the next body of water, that water transfers the force to the next pocket of air, that air stores the energy and so on through the system.
Each pocket of air has stored energy, each body of water does two things, transfers the energy and adds back pressure (head) to the internal chamber.
Successively, as in the water hose example. The greatest pressure is in the center and has a pressure drop equal to the additional head - until atmosphere is reached - the end of the hose.
This process is called precharge, it requires an input volume up to the volume of the second body of water from the center chamber - if this volume is exceeded, water will be transfered to the air pocket - and blow the operation. Since pressure must be overcome to blow over, limits on the input pressure solve this problem.
Each successive body and air had to be sized to match the different circumference, and match that volume to the different pressures successively.
Water volume is a constant controlled by clearance, air volume changes with pressure (roughing it worked) but our modeling of our large system was much more precise (higher efficiency).
Prior to this point - the only work that has occurred has been input - we are completely buoyant at this point, held in place by resistance to the "float" by hydraulic pressure - until our upward force exceeds the minimum.
Opps, you do not know where the buoyancy cam from, two places - first we raised the water around the system - twice its original depth, and secondly, we applied the air pockets (pressure) - individually to horizontal surfaces.
The forces combine and are centered at the shaft to the hydraulic cylinder.
That covers our precharge - work prior to stroke.
The volume required to create the lift is determined by how much you want to lift - my little Z.E.D can lift 7000 pounds, or 500 pounds - the resistance at the hydraulic cylinder limits the force that can be created, it also regulates the input.
If addition effort (pressure and voluem is input) and the required force is exceeded - the hydraulic cylinder captures the force and transfers it it to the accumulator.
The accumulator is where you set the system pressure - and you must match the diameter of the hydraulic cylinder to to force applied and the pressure needed.
The little Z.E.D. has a cylinder with a piston surface area of 4.9 square inches, so if we wanted to operate at 7000psi, we would produce 7000/4.9 = 1400 psi hydraulic.
That number is ideal, and leaves no room for error in chamber sizing, our little model was tested in four ranges, 1,100, 900, 700, 500 psi.
We changed the accumulator pressure set point to control the system pressure.
In conclusion of the recharge status,
Couple of notes:
On our demo model, the volume of input required to reach fully charged is 1/11 of the total requirement to stroke.
(and yes the bigger models are more accurately sized - thus have an even better ratio).
The pressure required is directly related to the newly created head, which also translates to the output force.
4 psi in the precharge translates to over 3200 pound force in actual measurement - if you do the math my inner chamber has only 707 square inches, and we are lifting a series of layers, so the 4 psi x the 707 square inch's does not match = 2828 - load, this is because each successive layer is larger in diameter than the next - so the upward force has a larger surface area than the downward force between layers.
Most of the extra lift is eaten up in the process of lifting layers and overcoming static pressure on the hydraulics.
Yes, the increasing large surfaces areas do create overunity by themself - but as I said about my last two models, nothing to sell.
The real gain comes later,
This may seem like a lot of work to do slight better than a pneumatic cylinder - well that is because - it is not the lift that I had to overcome in my design:
The second hurdle in using buoyancy to generate energy - HOW DO YOU SINK AN OBJECT THAT IS NORMALLY BOUYANT - WHILE MAINTAINING THE FIRST HURDLE - HOW DO YOU REDUCE THE VOLUME REQUIRED TO MAKE AN OBJECT BOUYANT?
I bold these, not to yell - but they are the right questions that had to be answered to make my overunity device work.
I stumbled (during my early models - how to overcome the volume issue - lots of applications to that design. It took down right hard effort and lots of real MONEY to answer the second.
Thank God the first discovery was enough to convince people to help.
More later.
Mr. Wayne
Quote from: mrwayne on April 11, 2011, 06:18:34 AM
The Inner chamber (where all externally applied force is applied -{input}), has a horizontal surface area of 707 cubic inches. and is 20 inches tall.
Dear MrWayne,
English is my second language and I am a 'metric, SI' guy so I wonder whether "Imperial" guys use
cubic inch for quantifying surface area instead of
square inch?
And later in your description, you use that cubic inch data for further calculations like this:
The little Z.E.D. has a cylinder with a piston surface area of 4.9 cubic inches, so if we wanted to operate at 7000psi, we would produce 7000/4.9 = 1400 psi hydraulic.
and
4 psi in the recharge translates to over 3200 pound force - if you do the math my inner chamber has only 707 cubic inches, and we are lifting a series of layers, so the 4 psi x the 707 cubic inch's does not match = 2828 this is because each successive layer is larger in diameter than the next - so the upward force has a larger surface area than the downward force -
so I wonder if these calculations are still ok? I ask this because in metric system it is not at all the same if I use cubic centimeter for measuring Volume instead of square centimeter for measuring Area.
Thanks, Gyula
Dear Conrad,
I do not think I was talking in riddles? Maybe I talk too much, I have been accused of being long winded ;)
But you make a very good point, it has made me pause, should I disclose this or keep it secret?
I have no reason to disclose my discovery, I do not need you to validate my working proto type?
My intentions are obvious and stated: To Bring Free Energy to its proper Revolution, my plan is marketing, licensing, and manufacturing the machines.
It appears that your advice is - if I truly have "over unity" I should keep it a secret to protects the rights.
You could be right.....it does make sense - in a self preservation mindset.
Little personal note:
I struggle with the wisdom of sharing/secrecy.
If you share, you risk loosing your control of the substance, if you do not share, you risk loosing the benefit to the world.
My motivation for this invention is not for my personal gain, but I also invested five years of my life and nearly my entire portfolio to get the point I am at, with the expectation of using it to provide for my family.
I do not think it is wrong to hope for an income from the discovery, and if I can do that and disclose - I will.
I thought solving the sink issue was hard, now I am darned if I share, darned if I don't?
From your advice, I will discuss the operation - but not share the inner design.
I will remain glad to share with anyone that comes to see and signs a NDA, and I have never charged a person.
I do expect the right person to show up that has the same vision, and the ability to execute it, or help me execute it.
I have made many copies of everything and distributed it, for protection.
Thanks for your input.
I think i will still do a video -everyone already can figure out what free energy would mean to the world, we don't need a bunch of hype, just get it done, manufacturing - and the right people.
Yeah, thanks on the cubic inch correction, I meant "Square" I was thinking surface area not diameter of the cylinder and it just came out Wong.
Thanks I will fix it.
mrWayne
Yes ,You need to decide If you're Open Source,That's the theme here.
The amount of people that come here and do what you are doing is unbelievable,And we never see a device in public [not once]!
People work their life away for a meager paycheck ,and if their lucky a watch after 25-30 years.........
Your work of the last few years Can change the whole world forever!
Comes down to a Choice.
Wisdom?? [you already Know the right thing to do!]
It will take Courage
Courage Springs Forth from Love!
Chet
Thanks Chet,
Can anyone answer - legally ...
Does "open source" mean giving up your rights of inventorship?
Such as implying you are giving it away freely?
Can you share your discovery without giving up the rights to it?
I understand it can be copied as soon as the first production model is out of my protection?
what are the limitations of this forum, in protecting an inventor, who wants to share, but not throw it away?
I am in the process of mutually signing a non disclosure for a green company in Australia, does that lose all value here?
Wayne
Buddy,
Unfortunately you need to see a lawyer,And in the long run.. The lawyer will be the Guy that makes the Money on this!
Par for the Course!
Good luck!
Chet
PS
Tell you what,There is a Guy Up in Canada "Thane Heinz",From Ottawa University
He also has a "Tidal" device ,Look him up .
Several people here have gotten Patent info /offers of help from him.
We thought he was Open Source also?
Quote from: mrwayne on April 11, 2011, 08:58:18 AM
Thanks Chet,
Wayne
Since the explosion of the internet the patent protection/ inventors protection is a bit murky. If you write about your idea on a forum or web page it is considered 'Published'. If published you must wait one year prior to patenting.
Regardless, I had a family member who worked for a patent company and there is a seldom spoken process that most company's don't want you to know. It is called 'Poor man's Patent' and this is something anyone can do for cheap. Also it puts the Government on YOUR side.
The 'Poor Man's Patent' is legal in the USA I'm not sure about other countries. It goes like this.
Step 1:
Define your invention in
complete detail on paper. Include print-outs of this forum and pictures. Do not be lazy here, it must be in DETAIL as it would be used in a court of law. You must prove, beyond a shadow of a doubt, that the idea is yours.
Step 2:
Place all data in a US postal office envelope, you will be mailing this to yourself. The post office will 'stamp' your envelope with a 'Date' (very important) Note: When this happens it becomes Government certified.
Step 3:
When you receive the package in the mail '
DO NOT OPEN IT....NEVER!!!!!' This is a sealed Government certified package.
The purpose If someone takes your idea, even a company, you have a SEALED document Government and TIME stamped that contains enough information to prove 'Who' is the inventor.
This package must only be open in a court of law by a judge Only a judge can open the sealed document. If you tamper with it 'You lose' keep it in a safe spot until that day comes.
Above is 100% legal but not known by many.
Regards and good luck.
Core
You are right, I will ask my lawyer.
To date, my attorney has charged me some where over $24,000 on this one patent.
He is expensive, but at least he is honest - he originally refused to "waste my money" by patenting another "over unity device"
After he and his engineer team (NDA) studied my machine, performed the patent search and they did come to the house (demo), they insisted on being the patent lawyers - but not for free.
I pray I am the exception to the rule.
All I know for sure- it wont be the design that stops me.
Thanks and greetings.
OK, the real over unity device is going off line.
If and when I am sure it is safe, I will release all IP here, you all deserve to know.
Concerning the Z.E.D. it requires seven square feet of air at atmosphere (prior to compression) to complete a stroke.
The compressed PSI is of course set by the resistance to the travel, the travel stroke length is also determined by the pressure.
So my internal design converts 7cf of air into Buoyancy - that lifts equates to 4 psi = 3200 pounds and travels eleven inches, 7 psi = 5500 pounds at 8 inches.
Those are the real world numbers - and the weight of moving parts has already been subtracted.
That is not much more than a standard air cylinder - the difference is - the exhaust.
When the system is topped out -(the hydraulic system has stored the upward force), the system doe not reverse itself.
in fact the inner most chamber is forced downward when its pressure drops - by the head pressure in the layers above it.
This causes the layers to separate and continue to push down during entire exhaust.
It is like a loaded spring releasing.
We use that air to assist in the operation of the other Z.E.D
In short the Exhaust supplies over half of the power needed to raise the other side.
And then we switch directions.
Less than half of the energy captured in a single side going up is used to supply the input energy.
All of our input is performed hydraulically, and all of the energy the generator (ran by the excess) produces is free.
No compressor, no noise, and the only wear parts - besides the electrical generation - is the seals in the four hydraulic cylinders.
I have four cylinders, two larger, and two half that size, the larger captures the energy, the smaller assist in pushing the air to the other side.
pretty simple to verify. one stroke for one stroke.
I think I will leave the rest as Conrad said - Secret for the protection.
But I am willing to share with most anyone with a non disclosure.
You will see the old rule of thumbs going away, and those of you that just knew it in your hearts - are right.
Thank you Core,
I believe the patent laws were just changed to - "first to file" is awarded the patent.
This was just a month ago, they took out the "moment of inspiration".
Which is why the poor mans method worked.
Wayne
Quote from: mrwayne on April 11, 2011, 07:05:55 AM
Dear Conrad,
My advice: Disclose fully or stop saying anything in public!
You say: "my plan is marketing, licensing, and manufacturing the machines."If this is your plan, you should not say anything in public before you have patented (in multiple ways) and manufactured many useful machines.
It just does not make sense to talk about something which one is not prepared to explain and proof in all details. Doing this just angers people because you want their consent or admiration without making it possible to check your claims. "Sharing" and "trying to make money" are two pairs of shoes, if you want to wear both you look funny.
If you want or need money, stay with the money makers and stop showing off in public. First of all, erase your silly website. It scares away all serious investors. And people who think about OU hate it even more, because it is a tease.
If you want to share (which means giving up all claims and all control) prepare comprehensible documentation of all necessary details and hand it out for free so that people can make their own experiments. You will want as many independent replications as possible (in order to be believed) and you will want as many people as possible to try to make money from it (which will make the device reasonably priced). Many people do not realize, once truly and fully disclosed, nobody can patent it any more. And of course, nobody has any hold over it any more. There can always be patents on new details, but who needs them, there are always alternatives.
From your rumblings, insinuations and riddles, I gather, that you seem to believe in a new principle of using buoyancy to generate excess energy. If this principle is valid, there will be endless ways to take advantage of it. You will only be able to patent a few ways of using this principle, never all possible implementations. So, eventually it will be out of your hands.
If I had invented an OU machine I would go for publicity, handing out all information for free in order to stay credible. But I am an old man who has enough to live comfortably.
My opinion: if you want to make money, buy something for 1000 Dollars and sell it for 10.000 Dollars, you will live comfortably with this 10% gain. (The point of this silly advice: in order to make money, you do not even have to understand how to calculate percentages, you just have to be prepared to take advantage of somebody.) In other words, either make money or try to be a good guy, you can not be both. The money maker who wants to be liked is a sorry sight. And the good guy who wants to do good for money is even worse.
Greetings, Conrad
The contradiction or the wish that can not be fulfilled:
The inventor of an OU device wants to be believed, but he does not want to give away the details. But without knowing the details nobody can check his claim and therefore nobody will believe him.
Remarks:
The inventor of an OU device says "I do not have to proof anything to you". Yes, you have to proof everything for free if you want me to believe. The way out: the inventor has to give up the silly wish that I should believe him without irrefutable proof.
So, if you have invented an OU device and you do not want to give away every tiny little detail or secret, stop asking people to believe you. Stop wanting to be admired. Stop rambling, stop insinuating, stop seeking the consent of people who can not form an opinion, because they can not check what you claim.
So, if you have invented an OU device and you want to make money from it, stop the silly wish to present yourself as a "savior". Stop playing the guy who wants to save the world. Stop playing the guy who does it for my good. Be a good business man and make money if you can. I can deal with any business man if he can sell me something I can use or something I think I need. If this something is not yet ready for practical use, well, keep it, I wont buy it. A business transaction has its own rules, which have to work out if you want to succeed.
If you want to sell something, "believe" is not an option. The device must work, it must deliver what you promise, there has to be a warranty in case it does not work, the life span of the device has to be reasonable, repair service and guaranty period has to be offered, and so on.
Ahh, your device needs further development, it is not ready to be manufactured and sold.
Well, why do you need me to believe you? Why do you need my admiration, I (and the general public) will never invest. You only have to convince an investor (and not me or the general public).
And according to my experience with investors, they have their own personal likes and dislikes. Some even are prepared to believe tall stories, because they have too much money and like to play a risky game every now and then (like gambling). There, with the investors, you play your "make believe game", your "energy revolution tale", your "I have found a secret" story. Money makers are suckers for secrecy, they will like it, they believe in "lets protect this secret first".
If you want fame, you have to give away the reasons for your fame for free. If you want money, keep your secrets and talk to people who believe in money.
My opinion, why OU is the worst possible choice for money making:
If ever we find OU, it will be a new source of energy or a new way of transforming one kind of energy into an other kind of energy. In other words, it will be a new law of nature not yet discovered.
Once this is discovered, there will be millions of ways to use that principle and it will take decades till something really useful comes out of it. The "discoverer" (who may see himself as an "inventor") will not be believed for a long time. Mainstream science and public opinion have a high inertia which needs first of all "time" to be overcome.
You can not patent a law of nature (or a principle), only a way of using that law by help of a contraption. And there will be endless ways of implementing a principle. There will be thousands of patents.
It is by no means assured that the discoverer of a new law of nature will get credit for his discovery. Clever business men will come out with it with a new name and a new spin. Mainstream scientists will present it in their own words and claim fame. Hundreds of people will claim that they have found it before you. Many will sell books about it.
Well, I think I have made myself more than clear.
Greetings, Conrad
unfortunately, Conrad speaks the ultimate truth.
My bet is you never going to make big money out of any OU device. Not the amounts you though anyway.
your best business bet is to sell custom based devices locally or with small and agile businesses.
Seeking large corporations to sign multi-million dollar deals is a dead-end i am afraid. On the other hand if you share it, you may risk to lose rights and large sums of "potential" money, but certainly be my hero. (especially if i can replicate that :P )
Thank all of you for your help!
I have been contacted by open minded people - looking for the anomaly - proof of the impossible.
Dear Conrad,
I did not join this furum for philosophy, or for self - engrandment - but to share the joy of my hard research.
I recognize "small pie" thinking, and most of the time it is right, logical, pessimistic, and seemingly wise.
We need to encourage others, at your age you understand a great deal, be careful, no man plants a tree that he expects to climb, but instead he thinks of future generations.
I choose to be "Naive" because at heart, I am an adventurer, explorer, motivated by discovery of the unknown.
It is sad when Experience suppresses others, you may think you are helping, you can never know, one day someone will succeed, - but how much wiser it would have been to help those willing to try, rather than dash dreams.
What was the cost to you, nothing.
What was the real cost of failure - nothing,
and the real cost of giving up - everything.
I can not imagine that this forum was created, and joined by a group of people to watch, proclaim, and ensure that others fail.
I love trouble shooting, solving problems, - I find no room for impossible.
Even if I had failed myself. I would choose to believe it was eventually possible myself.
Live long and strong!
Wayne
Wayne
Thanks!
Keep us in the loop!
Chetkremens@gmail.com
Wayne says: "I can not imagine that this forum was created, and joined by a group of people to watch, proclaim, and ensure that others fail."
Wayne says: "but to share the joy of my hard research"
Wayne says: "one day someone will succeed, - but how much wiser it would have been to help those willing to try, rather than dash dreams."
The only thing I say (over and over again): As a mentally sane person one can not believe in something that is not disclosed in every detail.
Since you do not want to disclose every detail, what is there to discuss besides "philosophy", "insinuations" or "metaphors"?
I do not want you to fail, in the contrary, I tell you what is possible and what is not possible (so that you can succeed):
It is not possible to make people believe in something they can not understand and check in every detail.
It might be possible to convince someone to give you money (but this most probably needs keeping the secret).
In order to make people believe in the unknowable (in a secret that is not disclosed), founding a religion is much better.
I do not want to interfere in this thread, because some might enjoy to talk "philosophy", "possibilities" and "I tell you it works". Therefore, over and out!
Conrad
Links and text from Stefan:
http://www.youtube.com/watch?v=ZkxrLzcp0Z8
http://www.youtube.com/watch?v=0JUj42h6j7Y
Z.E.D. Zydro Energy Device.principle video 1
This is the principle used by the Wayne Travis ZED device built at:
http://hydroenergyrevolution.com/ (http://hydroenergyrevolution.com/)
As you can see it needs less air to be pumped under the plastic-bucket
and has the same lift energy capability and thus you get an energy gain, as you don´t need
much pump energy to bring the air down there...
THE ZED device uses this principle to self-run self-looped.
Well done Wayne and team !
Regards, Stefan
Wayne Travis seems like a really nice guy but he should be investing his time and effort somewhere else because his theory is not correct from what I can see! Others may disagree with me.
Perhaps someone can explain where the mistake is and then pass the explanation back to him. I would hate to see him spend serious money on this project!
Quote from: MileHigh on May 23, 2012, 12:06:52 AM
Regards, Stefan
why can't you explain and pass it on to us.
Also it looks like they already have a working machine.
He needs to Open Source his machine.
I posted with permission from Wayne the 2 principle videos to my youtube account at:
Also the hard skeptic Mark Dansie says that this device works.
The main effect is that only the height of the air in the plastic cup counts !
Not the volume ! So you only need to pump a very low amount of air under the plastic cups
which needs very low amount of energy. Then you can gain the massive lift energy by buoyancy which is much more than the used pump energy to get the air inside the platic cup.!
So you have a big energy gain there !
Hope this helps...
Also have a look at their website for more informations.
Regards, Stefan.
Thank you for your concern.
We completed the closed looped system in November last year.
We just finished our Data collection/Alpha Model.
It was the best use of our money ;-)
Buoyancy is caused by pressure diffirentials x surface area - not by volume
Archimede's describes the "least amount of lift from a volume of air" much overlooked, which is what the "Travis Effect" demonstrates.
Wayne
Either I am thick, or I am missing something here. There are two inverted vessels in a tank of water. Both contain air, one is about three quarters full of air, the other contains only about one twentieth as much air . Both are prevented from floating to the surface by a two pound weight. You could have a third vessel with no air in it at all, that is,full of water. It too could be held in position by a two pound weight. What would that prove?
Please will someone help me to understand what is being claimed here.
Not thick, just missed the key point.
Look closely at the begining of Tom's second Video, be careful to notice the Repulsive force he describes.
That force is proportional to the total lift in the container with 24 oz of air.
In your example 'the weight on a cup filled with only water' does not have the repulsion.
Wayne:
The problem with your system is that the repulsive (or buoyancy) force in the inverted glass with the very small amount of air in it is not the same as the repulsive force in the glass that is filled with air.
The glass that is filled with air provides this repulsive force for the full travel of the glass from the bottom of the aquarium to the top of the aquarium.
The glass that has the small amount of air in it provides the large repulsive force as long as it does not move upwards. The moment it starts to move upwards the repulsive force starts to decrease rapidly. After the glass has moved upwards about one centimeter, then the "extra" repulsive force is all gone.
So the glass with the small about of air in it can only do a small fraction of the buoyancy-related work (upwards force x displacement) as compared to the glass that is filled with air.
Quote from: MileHigh on May 23, 2012, 10:30:42 AM
Wayne:
MileHigh,
Am willing to bet you that if a colored liquid were poured into the bottom of his containers that it would show there is a depression around them. This depression would ensure that the there is a flat bottom for them to stand on. You know, other wise they might tip over if filled with your favorite refreshment. You can tell this by the curvature at the bottom.
But pushing air downwards is not trick. While he mentions ounces, it would actually be if he were using a liquid of that volume.
""many air-density tables state the density of dry air to be 1.25 kg/m
3. That's equal to 0.000 722 546 ounce/cubic inch.
Read more: http://wiki.answers.com/Q/What_is_the_volume_of_air_that_weighs_one_ounce#ixzz1vhiYNqNh
"The glass that has the small amount of air in it provides the large repulsive force as long as it does not move upwards. The moment it starts to move upwards the repulsive force starts to decrease rapidly. After the glass has moved upwards about one centimeter, then the "extra" repulsive force is all gone."
You are right, very wise, My invention solved this, as well as a few you have not yet commented on ;)
Wayne
Quote from: mrwayne on May 23, 2012, 10:47:47 AM
Wayne
Correct me if I'm wrong but you're relying on hydraulic theory. ie., if a tube has a surface area of 10^2" and has 10 lbs. of force applied to it, then it has a lift potential of 1lb. per ^2 inch. And if the surface area is reduced to 5^2", then it has the potential of 2lb. per ^2 inch, right ?
With your demo, once lift has started, the surface area changes because the insert does not rise with the vessel being lifted.
It's funny though. With what I am working on, I can pump 2 lbs. of water over 20" high with a 1 lb. weight dropping 4 inches.
Still, I am after a working device (Bessler's Wheel) and not merely a demonstration of known theory. After all, hyraulics is used in many fields to multiply force well above what most people would think is achieveable. Even pneumatics is used which is merely air or an inert gas replacing a liquid which is not compressible.
@All, a pic of how containers are designed for mass production to ensure they are stable.
edited to add; almost missed it myself, oops :o
Since the air is being compressed by the water in the tank, by decreasing the surface area of the water acting on it, it decreases on a proportionate scale the work it can do.
This simply means the insert reduces the work the compressed air can do so it has no advantage over not using the insert. Why it can't possibly work.
Here is now the video of the Wayne Travis ZED device in action:
http://www.youtube.com/watch?v=cSy_33t86gc
It was first shown in the last Smartscarecrow show last Thursday night.
Regards, Stefan.
MrWayne: I have a few questions. First, is there a video of your device in operation for a reasonable amount of time, powered or unpowered?
Next, some particulars:
Does your device require an external source of power? For example, do you need to run a compressor to store some compressed air, are there water pumps running, is there a big battery or a mains connection?
For how long does it "run" when it is not attached to an external power supply, including a tank of compressed air?
When it stops, why (or how) does it stop? Is a reservoir depleted, has the friction become too great, or like that. Or does it simply keep on running when it's disconnected from its power source? If the latter, PM me and I will start piling money into the armored car to bring to you.
These are questions concerning the current operation of a real device, not the theoretical predictions of how it will perform once you've got the kinks worked out. Do you have a "self runner" now, that requires no continuing source of external power, yet it continues to operate, producing useful work?
Now I also have some "theoretical" type questions about the demonstration of the cups in the aquarium and the operation of the system.
You do realise that whenever you do the work to submerge a volume of air, you also are _lifting_ an equal quantity of water an equivalent height, right? In fact it is raising this water that causes the "repulsion" you feel when you are pushing the air-filled cup down in the water: you are lifting a cup "full of water" to the top of the aquarium.
Now, imagine a spherical glass ball with a large hole in the bottom, like your cup but only spherical. Fill it with water and submerge, placing the weight on top. Now bubble air into it from underneath until it is neutrally buoyant. You now have "lift" that is equal to the weight. Right?
What happened to the water you displaced with your bubbles? If you carefully note the water level of the external container, you will find that it has risen, from its low point when the sphere was full of water, to a higher point now that the sphere is full of the air you pumped into it. In other words, when you pumped the air into your chamber, you pumped an equal quantity of water OUT, all the way up to the top of the external container. This represents stored energy. It is in the water that you lifted, NOT so much in the air.
Now.... introduce a balloon into your neutrally buoyant sphere of air. Start pumping WATER into the balloon, displacing the air in the sphere. Does the sphere become more buoyant during this process? What happens to the water level in the external container when you do this?
Or.... don't use an inner balloon or a pump at all, just make a little leak in the top of the sphere. As the air runs out and water runs in.... does the sphere become more buoyant during the process? What happens to the water level in the external container when you do this?
Thanks in advance--
--TK
(Yes, that's right, the disinformation campaign that has been trying to keep me distracted and confined to a single thread is breaking down and I am escaping once in a while to check activity in the "real world" of PM motors, buoyancy drives, gravity wheels and functionless electronic circuits.)
Yes Wayne, would be interesting to know if the shown ZED device in the posted video:
http://www.youtube.com/watch?v=cSy_33t86gc (http://www.youtube.com/watch?v=cSy_33t86gc)
is still having external valves control via external batteries or grid power and
what is the total input energy this way and what is the total output energy.
Many thanks.
Regards. Stefan.
P.S: I have merged the 2 threads about it now into this one.
Quote from: TinselKoala on May 23, 2012, 12:24:43 PM
Thanks in advance--
--TK
>> You do realise that whenever you do the work to submerge a volume of air, you also are _lifting_ an equal quantity of water an equivalent height, right? <<
This is wrong. He is displacing an equivalent amount of water. Height is relative to the surface area which helps to determine the volume in the tank.
An example is if there are 2 tanks and one has the surface area of 1 square foot and the other 10 square feet, the tank with 10 square feet of surface area would have it's water level lifted 1/10th that of the tank with 1 square foot of surface area.
Also, the surface area of the tank, is it more or less than the surface area of air in the cup ? This would give a ratio as to any rise in height of the water in the tank being displaced.
Jim
p.s. In theory, what Wayne has proposed is theorhetically possible. I would think though that using purely mechanical means to demonstrate the system is 100% isolated would be helpful.
Wayne just emailed me about the sound his machine did in the video:
Stefan,
My only problem with that video - we had dry bushings on the new cylinders -
that one is embarrassing to me.
Well I told him, it is better to hear the machine in operatiom than to mute the sound...
With oil or graphite in the bushings this moining sound would probably be gone.
Anyway, I hope he will answer a few questions about the total input and output power.
Regards, Stefan.
A video will not show anything but the external functions. Inside the ZED the Travis effect is used to act as a pressure increaser - not in the simple form shown in Tom's demo -instead we have a much inhanced version.
We were in the middle of a DOE when we filmed this video, so I am a bit emberrassed that it is being shown.
The "Travis Effect" is what made it possible.
Yes, we do maintain all pressures, and build excess pressure - no external inputs, and no emmissions.
I know this is an Open source site, I am not open sourceing, I am keeping a promise to Stefan 9allowing his group to see our O/U machine.
Those parties who wish to get involved can contact Mark Dansie, or myself in regards to joining our team.
With proper NDA, and constructive valid intentions, we will disclose to process.
Otherwise I have to protect our current interests and so I can not disclose our process completly to this or any other site.
Please do not ask, and do not profane me for being professional.
Each Engineer that has reviewed our process states that we are ten years ahead of the competition, I would like to keep it that way for a while.
Wayne
Well, you are right. Maybe they are pulling my chain.
But they put their money where their mouth is..... and they are extremely respected individuals in the technology field.
Another point - who is my comptetion in the free energy field - do you have one currently being Alpha tested..... makes a difference.
Now that you make the point - it is kind of a silly statement, unless you realize they just confirmed/with their "credentials on the line" to their peers that we have a fully functional O/U device.
Stefan asked me about input and output,
Now this will make sense to all of you, no input.....
Back in May/June of last when Mark flew over the first time, we had a demo model which had the sole purpose of testing the input and the out put.
By that standard we were good then, but the barr was raised - as I see very often - If it is really exceeding the input - then it should be able to run itself - and then some.
So from June till November we installed HMI and controls to enable a self running system - it was crude and I can share the video of that model running out side.
http://www.youtube.com/watch?v=q-0TITC4Wrc (http://www.youtube.com/watch?v=q-0TITC4Wrc)
This was a competly self runner - the video man is Mark Dansie.
Then the bar was raised again - clean it up, secure it, and add data collection - we finished this week.
Wayne
"Well i don't care about their "credentials or what they say or confirm, untill i see it with my own eye's, and since you are not into sharing the principles it's not worth my time and money to get involved.
Like you said a video proves nothing."
Nobody is asking you to believe, and we are keeping a promise here to Stefan, not trying to convince you.
We are not the tooth fairy - do your due dillgense, ignore, or watch from a distance. But slander what you do not know or can not find out from your comfort zone is poor manners, and is illogical.
Good day.
My Desire, and my companies vision, is to bring Energy Independence, through our clean technology to those that are wise enough to seek it.
It has not changed since the first discovery, nor through the many hard trails and discoveries that came along the way.
Please do not compare us to those that did not invite - openly - the pure peer review of skepticism.
We were vetted - before we allowed others to help.
I am sorry for the example that others set: And I would warn to be even more cautious in coming months - Our discovery was fraught with obstacles to overcome - and our own engineer argued feverishly over ever solution I invented - until he saw it work.
If someone thinks they have free energy and tries to ride on our success - Make sure they are vetted.
We have proven that O/U can be mechanically accomplished - that should open minds once again - but not at the expense of proper and due diligence.
(not to you - I understand, but to those involved)
Peace and blesssings
Wayne
Quote from: hartiberlin on May 23, 2012, 02:23:16 PM
Many thanks.
Regards. Stefan.
From Wayne
No, neither of the systems are connected to an external source - the system does have a small battery to run the computer and valves, the internal battery is recharged by the generator and also runs a load.
Many Question keep returning to a gride connected system - those are not closed looped.
ZED is a Close looped system - no externals - with excess production.
That model is only Demo, meant only for testing - not engineered for longevity.
Hi mrwayne,
Very nice work here from what i have observed in your video explanation i can already see theoretically 3 mechanical ways to exploit this effect to build selfrunners in a small scale and maybe more efficiently (water pomp, water turbine , and depression turbine in the last case no water involved) . I am sure many other engineers out there will come up with many other ways to use it. So what i suggest you is to open source your project allow replication and spreading and benefit from your platform you can still make as much money or even more with this project open sourced by building a strong community around you then a patent license because people will easily exploit this effect anyway just follow the examples of the computer industry you will succeed. someone says here an effect can't be patented and he is right .In your case the great achievement seems to be the discovery not the invention.
tnx Sid
Wayne:
Quote"The glass that has the small amount of air in it provides the large repulsive force as long as it does not move upwards. The moment it starts to move upwards the repulsive force starts to decrease rapidly. After the glass has moved upwards about one centimeter, then the "extra" repulsive force is all gone."
How did you solve it?
Please don't be offended but I can tell you what the pattern is. You will not reveal how the system allegedly works and before too long we will never hear from you again. Eventually your web site will disappear.
James Kwok and his alleged "Hidro" system and I think there was a guy Simon Wu that was convinced that he invented "pendulum power." They are both out of the picture now, presumably because nothing ever worked.
If you want to be real you have to provide credible evidence that you have something.
I note the presence of the one item that no free energy overunity machine seems to be without: a battery.
Quote from: MileHigh on May 23, 2012, 09:15:06 PM
Wayne:
Quote from: TinselKoala on May 23, 2012, 09:15:28 PM
and cue the trolls...
the Travis effect is = expand air on a larger surface you create a depression and increase buoyancy physic 101.
just like a hot air balloon. many other people have used this principle for their devices some of them are even discussed here on this forum sadly there is more theory here than experiment .to build a device all you have to do is to displace the air from a low surface area to a bigger surface area vice versa the increased buoyancy will provide the required energy to displace . the energy is in the air it self .
Good day.
Wow,
My system does have a small 12v battery, to run the HMI, that runs the valves and track the data.
Something most people realize - that we are running a hydraulic motor - Self powered, a Generator - self powered, - a dual pumping system with a surface area of 525 inches - self powered, a HMI with to valves 25 sensors and self powered - hydraulics self powered, and burning two light bulbs self powered .....while creating a force of 5500 pounds and capturing it - self powered.....
And someone takes the time to complain of a batterythat can not possible do all of that.....you have witnessed an impossible machine.
When I was young an old man told me the boat left shore and both the people on the boat and the shore thought the other was shrinking.
Nice to smile
Quote from: sidneo on May 23, 2012, 09:32:34 PM
Good day.
Thanks for the comment.
Wayne
Wayne:
QuoteMy system does have a small 12v battery, to run the HMI, that runs the valves and track the data.
Is "HMI" human-machine interface? If the valves are solenoid valves don't they consume a moderate amount of power when they are energized? Do you know what your average battery power consumption is?
Reading your quote above I can speculate something like this:
<unknown energy source> -> dual pumping system -> hydraulic motor -> generator -> two light bulbs
So is the "unknown energy source" your special effect in action? Honestly, it looks like a really tempting place to put a tank of pressurized air.
Note you say the HMI and the valves and sensors are powered by the battery, and then you say the HMI and valves and sensors are "self powered." So which is it?
Quotewhile creating a force of 5500 pounds and capturing it - self powered.....
The above statement doesn't make any sense. Just mentioning force alone has no meaning.
Do you have any preliminary specifications for your device? As you can see from above, there are several issues with your quoted text.
Thanks,
Gen charges the battery to drive the control system?
Video cam + Ustream to show 24/7 working?
Hello Milehigh,
You missed the point, so I must be very poor at explaining things.
here is what I was trying to point out - The ZED has no input and we have at least five clear energy conversions (losses), or power drains in the system, we are performing an enormous amount of work (more than a 3 inch by 4 inch 12volt battery can provide).
Each of the components have ineffiecient systems in themselves - the sum total of losses through well known equipment - is more that the battery could handle - unless as you pointed out - hidden power - or excess energy from somehwere - in our case - The Travis Effect - fully understood and utilized.
Even in the video Mark Dansie made of the last model, back in november, Mark laughed in the video about our weights - (which were a successful attempt to capture the ramp of the power curve at long strokes - they are gone because I invented a better solution with our new one ZED).
To the observed and unnoticed point:
You see - we were moving 900 pounds of weight back and forth - continuosly - self sustained - free energy and all the things (losses) I mentioned above about this unit.
If the only thing you knew was that we were moving the weight (just the weight) completley free - you would realize you were seeing the potential source for abundant free energy that this world needs.
Some people see a water fall, wind, Solar, volcanic heat, all have potential - all have one common attribute - work is being done - with no input from us.
I saw the potential in a the Travis Effect, caused by gravity - we just had to think of a way to capture it - and after much expense (nearly a half million dollars) and hard work - thousands of experiments - we succedded. (I have had nearly 100 people volunteer, and help through the process).
The best part is - the resiliance of the design - we do not have a system that barely runs and slowly runs down - what good is that? We have one that we are scalling to meet the power demand.
We overcome obvious losses in the system and then do extra work.
I am glad if you can see it, it is for the world, what is right before our eyes - is the future of energy production - one day - believer or not - you will at least be able to tell your grandkids - I was there.
Pressurized tank - Ok - you got me - did not think anyone would notice that lol
But seriously I do get your point, and I respect it - to be clear - We have had complete and unimpeded full and thorough inspection of our systems. If you were under NDA, you could check for yourself.
I understand first - you have not had complete access - uninhibited access.
He who has nothing to hide - behaves accordingly - but professionally with due dillignese NDA.
Do not forget - We prove it on paper using simple and also complex physics. (note to future free energy inventors - if it does not work in the simple math - it will not get better in the complex).
We have fully modeled the scalability of the system of 25kw, 50kw, and 100kw systems.
It take about 45 minutes to explain the succesful use of the Travis effect - most of that time is explaining the progression of the machine how we overcome the inherint obsticles to it use.
At the end of the disclosure - a common statement is - "It is amazing it (free energy) is that simple" followed by "How did you think of it?"
Which I answer with lots and lots of trial, failure, persistance, and a big dose of God's blessing.
I am not going to dissapear and loose the web site like some else claimed, but I have taken two days out of my time while the crew performed DOE's without me - if you want to be kept up to date with our progress and partnerships
Write me at mr.wayne@hydroenergyrevolution.com
Ask Sandy to add you to our private update list.
Otherwise - God bless you all, I have enjoyed our time together.
Thank you Stefan for your part of all this.
Wayne
In childhood, we had a toy. Bottle, the bottleneck (from wine) are filled with water. In it, we put a small bottle closed with an elastic surface. We have a small bottle filled with water with a little air. The bottle had to float in water. If we push the stopper in a large bottle (we have created pressure), a small bottle went down like a stone. If we allowed the stopper (we created a vacuum) competed bottle quickly to the surface. I think it is the principle of work ZED.
Sorry for my imperfect English.
What Sano is describing is a toy "diver". We used to use the globe of a torch bulb with the brass bit removed . You placed it in a bottle full of water . As you tightened the stopper, the diver would sink. Water was being forced into the bulb through a small hole in the glass at the bottom . Slackening the stopper caused the diver to rise.
Quote from: mrwayne on May 24, 2012, 08:00:27 AM
Hello Milehigh,
Wayne
Not sure if it's sad to say, but Bessler realized 300 years ago that bellows could pump. It's in his drawings. He did show using a lever to increase the potential of work a bellows could do. Nothing new with what you are saying.
What I am working on is ahead of you easily. What I think is that your device is missing something. One thing that you can point to that shows clear energy potential increase. Like using leverage as Bessler did to have useable energy. With you, it's not clearly visible.
As with Bessler, when his wheel rotated, the weighted levers were reset. Generators require torque to operate as they do rotate (today's goal).
My experience has taught me the more elaborate the explanation, the more likely it is not to be genuine.
Jim
Hello Jim,
Good luck with your 'better' project, you must be 20 years ahead.
Food for thought:
Do you know how much volume it would take to lift 5,500 pounds using buoyancy? Even just six inches, and be able to repeat it again all in under 6 seconds? That means fill - rise - vent and then sink.
If you do, take that volume - divide it by 40, and you are half way to matching the reduced input required in the "Travis Effect".
What does the term "troll" refer too?
Wayne
The Bellows cost $900, a 30 inch dia cylinder cost $19,800 - simply a choice of movers.
Wayne
I would describe a "Troll" as someone whose posts are always negative and argumentative, whose sole purpose is to disrupt and deny.
Hi Wayne,
many thanks for posting the video from
Mark Dansie !
To all the skeptics here on the thread, if the "over-skeptic" Mark Dansie says, that it works, I just believe him
and he has seen and measured it at least 2 times how much I have heard !
I have grabbed 2 pictures from the recent video and enhanced them where one can now better
see the Wattmeter being shown, showing 29.1 Watts.
Wayne is this the power lighting up the 2 red bulbs above the Wattmeter ?
So this is the current power output from the generator above it ?
Is the generator driven by the water going through it ?
Does it have a gearbox to speedup the RPM, cause it is running pretty slow ?
Also if this is not open source it is the first device I finally see, that works contineously on
buoyancy and does not spill the used water...
Maybe it has really to do with the air pressure changing in the Travis effect and thus
extracting its energy more on a calorimetrical process by cooling the water and thus converting
the heat of the water to mechanical energy via the Travis effect.
Just cooling so much water down by 1 degree Celsius should give you a few KWatts of output.
And the heat will always flow back to the water from the outside environment...
Well done !
Regards, Stefan.
Quote from: mrwayne on May 24, 2012, 01:10:16 PM
Hello Jim,
Food for thought:
Wayne
Wayne
Considering I had surgery interupt my build, troll is what peole do when they go fishing. My father did it for many years as well as work at Boeing in their R & D department. I also worked at Boeing and do know something of what it takes to develop an idea.
As far as what it takes to lift, as I have mentioned on here is that water can be displaced. For some reason, your aquarium did more for the people in here to consider that.
What Bessler realised is quite simple ( I have spent a few years on it, so it is to me :D ), but using leverage allows someone to actually pump up water to a height greater than the weight dropping drops. You're a diver, you should know that water's pressure doubles at 33 feet in depth. This means a column of water 33 feet high has twice the pressure at the bottom as at the top. Basic math. What this means is that to pump water to that a height equalling 1 second of gravity is a weight with twice the mass as the water has.
In this example, a water column holding a pound of water would require 2 pounds of pressure to have equilibrium, right ?
Then if 1/2 pound of water drops from 16.5 feet, how much work can that perform ? That is a lot of potential and something I see missing in your invention. Specifically, that a static head is not created that creates an opposing force greater than the potential that created it.
Just talking engineering Wayne, don't see a need for name calling, but since you do have a patent, am not sure why people have a difficult time understanding the specific discovery you made that allows for overunity. By the way, sorry to say but the money you spent only lets us know you have deep pockets.
edited to correct mass
Hello Stefan, Hello Stefan,
Yes those are the bulbs, and that is the power being generated from the Data Collection model during that DOE, 40 watts Excess was the amount we were "challenged with" for our Extraordinary Proof - that challenge dictated the size and power of the system.
You are making the system harder than it is, no high level engineering here - just unique application
Or Unique energy conversion system - hence the name Zydro Energy Device
Boiler plate technology - that is what our Skeptic said about it.
The water in the Bags is pressed into the Travis effect - That effect creates buoyancy,
the Buoyancy pressurizes the Hydraulic fluid,
The Hydraulic fluid powers the Pump that spins the generator and presses the water into the Travis Effect again.
The excess energy is bled off into lights.
The Point is this; Archimedes' principal has long been assumed to say volume and buoyancy are intrinsically locked - they are not.
We have proved it, and have ongoing testing.
We have also proved that in this certain limited realm of physics - the laws of entropy, thermal dynamics and the philosophy of 'Trolls' are wrong.I had to review a stack of buoyancy patents my attorneys pulled during the Patent search, two main themes - water from a higher source - water fall, river, damn, all work.
OR Volume based systems like bucket brigades or sealed ropes, tubes Accordians, all relying on Volume.
Not one used the understanding of Pressure diffirentials and surfaces - that excited the patent engineers like nothing else!
You would not believe how many peoples life dreams have been realized by this discovery - and those are just the ones involved.
Mark Dansie, is a dead honest man, protecting investors, Grandma's, and uninformed people - He is a man I am glad to call a friend.
I am honored he speaks highly of our project, I checked his reputation before I allowed him to come - and unlike what I have seen many other inventors do - I asked him to come - If I was wrong, dellusional, poor theory, I wanted to know before I wasted anymore of my time or that of my family's.
He has a good nose for smelling rats...... Must have cat in him ;-)
Wayne
Hi Wayne, many thanks for your informations.
What means DOE ?
Is your patent application already online available, so can we already look at some drawings
or is that still under NDA ?
So this Data collection ZED machine model currently outputs around 30 to 40 Watts of contineous free electrical power
for the bulbs, right ?
Well done !
Regards, Stefan.
DOE
Design Of Experiment's
Not professionally of course - but at the inventors level
We test our understanding of the system and its interacting reactions by applying changes to the system and then measure the reaction to see if it reacted properly.
We only have one input, but it causes a chain reaction within the system that has nine seperate measurements, it is how we identify the sweet spot in variable conditions.
This Data allows us to predict the similar outcomes in the larger systems.
The Patent Numbe on the ZED 7 Stickers were patent pending - provisional numbers - we rolled over into a full patent last year and recieved new numbers. Now, my attorneys set up a plan to manage the release of drawings - so no - you can not find them. Unless you are under NDA ;-)
Sorry for that, parts of this world are not honest - Conrad was right about protecting the invention.
Wayne
Wayne,
I think it's funny that you refer to me as a troll. You have shown me were I am wrong.
I have always worked open source. It seems that credible people are above this. My mistake.
Jim
Well done Wayne,
the ultimate test will be successful replications, I look forward to the day when this is possible.
Until then the speculation is likely to continue.
Wayne,
I notice that you haven't answered my questions but I don't really care.
QuoteIf the only thing you knew was that we were moving the weight (just the weight) completley free - you would realize you were seeing the potential source for abundant free energy that this world needs.
Sorry but I have to correct you here. Seeing a weight move up and down in a repeating cycle on a machine means nothing. It does not demonstrate the production of energy at all.
Here is what I care about: When do you plan on doing a bona fide real working demo of your system? You mention a model with a 25 kilowatt output? Will you being doing a demo of that? If not, how much power output? With whatever power output you do plan on demoing, how are you going to demo that?
What do you envision for a demo? I mean the location, what you will show, how it will be shown, who will verify it, what will it entail, etc, etc?
If you can answer those questions with substance, and give a date, that will give the readers here something to look forward to.
Thanks,
Just a little reality check for everyone:
The demo clips with the inverted cups where one has a small amount of trapped air and the other has a large amount of trapped air prove absolutely nothing. It's the water pressure at the lower extremity of the air volume that creates air pressure in the trapped volume of air. The air pressure pushing on the top inside surface of the inverted cups is what creates the buoyancy. In both cases the air pressure is the same as long as the cup with the smaller amount of trapped air is pushed down so it is very close to the mold. So nothing at all is proved in those clips, it's all normal and expected behaviour.
Then in the third clip you see a big machine that appears to have air bellows and it moves and makes sounds and there is a little control panel and there are some lights on it. That proves nothing at all.
In my opinion anybody that believes this system is real right now based on the information made available is making a mistake.
So as far as I am concerned, the ball is in Wayne's court. The burden of proof rests on his shoulders and extraordinary claims demand extraordinary evidence.
MileHigh.
it is producing contineously 30 Watts on the 2 red bulbs above the Wattmeter...
So these 30 Watts are the free energy output .
Have again a look at the videos I posted on my youtube channel or
go to the overunity.com homepage and let them all play in a row...
Regards, Stefan.
Is that 30w output enough to power the HMI and valves?
Stefan,
Unfortunately all gravity and buoyancy based free energy propositions have been unsuccessful as far as I am aware. If you want to accept seeing two lit light bulbs and some numbers on an LCD display as constituting proof that the system is working as claimed that is your prerogative. I don't share your opinion.
Wayne,
This system needs to be Open Sourced.
We need to see schematics, diagrams, and videos showing inside and out.
Other than that forget about it, this forum is not the place for your system.
Please take a look at http://peswiki.com/energy/OS this link should help in your decision.
And also http://www.overunity.com/1821/open-source-vs-patenting
Peace.
Quote from: MileHigh on May 24, 2012, 10:41:42 PM
Stefan,
Yes, but you also did not see it yet in person,
so your opinion is also prerogative.
As hard skeptic Mark Dansie and his associates claim that it fully
works, I just tend to believe them !
Also the device seems not to be so simple as the 2 Travis effect videos
with the pichers under water
show it...
If you look at the video from Mark Dansie you can see, that he has a "Valve-tree"
and that there are probably many partial cycles involved, otherwise he would not need so many valves..
Regards, Stefan.
Quote from: Ghost on May 25, 2012, 03:14:49 AM
Are you deciding this ? I guess not ! ;) ;D
Quote from: hartiberlin on May 25, 2012, 05:51:33 AM
No, it’s a suggestion since this forum supposedly is suppose to be Open Source?
Maybe you should refine the theme here for overunity.com because you're confusing me now.
But then again I think you're just pulling my chain considering the smiley faces? :-)
I agree that it would be better to open source this, if this is the first
real design that uses buoyance to get free energy out of using
water and gravity.
But I also understand the inventor who has put all
his money and the funds of his associates for the last several years into
such a "Rude Goldberg" type machine
and now they want some return out of their money and work or some more for it...
Regards, Stefan.
Here is a collage of some pictures of the ZED device which was posted at Peswiki.com
I hope it is okay to put this here as a mirror.
Many thanks.
He can still make money as Open Source.
Look at the Linux operating system and how they did it. google "copyright vs copyleft".
Also check out the Linux movie "Revolution OS". just google it.
I suggest doing it the way Linux did it.
He can still have all rights to his system and still make money as Open Source. I don't think this necessarily only apply to software, should also work for mechanical systems.
Not everyone can build his system, this creates jobs, kits to sell, maintenance jobs, etc.
Everyone benefits including him and mother earth.
Wayne
You have to open source and you need successful replications to prove that your Technology Works
No one can steal your design............. if I make your device it would be illegal for me to sell it without your permission.
And as for other companies trying to claim your idea, I don't see an argument there, you have invented something so unique that has never been seen before, the choice is yours but as we have seen before many times on this forum if you don't Open source the likelihood is that nothing will ever become of your device, we have all seen it time and time again over many years, so again it's up to you to really change history
Quote from: hartiberlin on May 25, 2012, 05:50:51 AM
show it...
Regards, Stefan.
Stefan,
The valve tree is possibly to control vacuum. This could explain the deep tone the device emits. It's basically making a speaker out of the bellows they are using. And such tones are made by motion, not the movement of air.
All this would mean is that he is using air operated actuators under vacuum. In engineering as in science, the inverse is always true.
What is missing though is the discharge from the battery. This would show if it's continuous or if it has spikes when the valves are being operated. It would help to convince us skeptics.
Jim
A quick couple of notes:
The system you see is three complete and separate systems:
(1)The ZED operates with four valves - it is quite simple.
(2)The hoses and wires are for measuring pressures and collecting Data.
(3)The rest of the valves are for an "initialization" process - When we were reviewed - I was required to
to completely empty the system of all air (pressure) water, and hydraulic fluid (pressure)
and then re- set the system up from scratch - this was expected - but a pain in the tail.
So my team designed an automated process - to both empty the system and then refill it, and then one button turns the whole thing on. and after Initialization - it is physically disconnected from the source.
Now a key point - initialization only happens once, it is just to show the skeptic. The system can be stopped and restarted as many times as desired - with no additional inputs.
Other than pushing the start button LOL -
This ZED is a three layer system- and we monitor two aspects of each layer and track the data - it produces a pretty clear picture of what is going on inside.
We are further along in our research than anyone on this forum understands yet.
OPEN SOURCE comments:
I do have a reason for posting here - and not disclosing:
Yes we have all labored hard - and we do expect to fund our business, and if the Beta process is not funded - no one will work on a project that will be legally taken from them.
To be clear Our hearts are as like those who want open sourcing - with many of the frontiers this process has revealed - we are in a unique position to effect the world.
Our License agreement is nearly an open source, it definitely meets the intention of open sourcing - getting the power out to the people - eliminated emissions and bringing energy independence.
It empowers those who have prepared, and have the desire and ability to make this happen in short fashion.
While many people have been arguing, other have been setting up meetings, for such an end.
A NEW FRONTIER:
We will not go by the waist side, we will never surrender, never give up.
Do not think for one moment that this has been an easy journey - but certainly an adventure!
I promise, you who wish open sourcing will not be disappointed.
My apologie to Jim for the Troll comment.
We are in this together, and some questions will not be answered except to those that need to know.
Wayne Travis
Wayne, I wish you well and hope you succeed in what ever you want to achieve. It is great that you built this impressive machine.
But I want to repeat what I said (over and over again): As a mentally sane person one can not believe in something that is not disclosed in every detail.
I do not want to be rude, but one can say it in short: "If you want to disclose, speak up! If you want to keep a secret, shut up!"
I also want to state again my opinion, why OU is the worst possible choice for money making:
So, for me nothing has changed, nothing remains to be said. Once you are prepared to disclose, I will be back. Till then, good luck.
Greetings, Conrad
(One can read in detail what I said on pages 1 to 3 of this thread.)
Hello Wayne:
I believe that you are taking advantage of the change in surface area which in turn is using surface tension to your advantage. Clever idea. Doing so causes the water to expand energy to create more surface tension in order to do work.
Are you taking water temperature measurements? If so, do you see a cooling effect on the water over time? This could be the source of your energy.
Chris
Hi Wayne ,
it would be great if you could do another video explaining just your start process
and explaining in detail your power output and how you measure it and how the generator
is connected to the system.
You could do it this way, that you don´t give away the secret inside the machine, but show to everyone,
how you get the power out there and what kind of bulbs you power there above the power meter...etc.,..
Just do a good narration in the video so the whole machine gets more clearer also to people who are no
engineers and have zero technical knowledge.
Just imagine tell somebody, who never heard about this yet the facts about this machine and what it can do and
how you want to scale it up...
By the way, scaling it up into the KiloWatts range will be probably pretty hard with the current design,
as this is only outputting about 30 Watts for this size ?
So how big do you have to do it for to get at least 1000 Watts out ?
Or does this scale up with the used air pressure inside ?
Can you get still more power out of it with the same size, if you build the
components more robust, so it can withstand higher pressures ?
Can you please also show in a next video the 2 red bulbs you are using there ?
Are they really rated at 15 Watts each ?
Many thanks.
Regards, Stefan.
Hi Wayne ,
I have one question if i may .what happen when if you replace the molded cement in the youtube video with another recipient full of water ? does it have the same buoyancy as the simple recipient full of air all the way up?
I am asking this question because as silly as it sound its what seems to be implied in the video other wise the
"travis effect" will be hardly mechanically usefull unless there is somethink else than what as been showed in the video.
I wanted to clarify some things.
I think this is a good exercise for Wayne being reviewed and this is just a taste of what he will have to go through when third party validation takes place. (the money people are a tough crowd) It is however hard to have a sensible argument or a full review when a lot of the information is missing, and while the technology is under development that has to be the way it is.
I have seen the device run in person in what I call manual mode. Over the last few months Wayne and his team have been working to fully automate it and gather data to assist in the new design.
I have not signed off on it and publicly stated this many times until I can see it run non stop for at least two days with no inputs.
However I am optimistic about this being achieved, especially seeing some of the data and discussions with his engineers.
The next hurdle once this is achieved it increasing the power outputs.
I am very happy you all asked the questions and many are valid, but on the other hand its difficult for Wayne to answer with his hands tied behind his back by not being able to disclose too much.
Once I have seen it run for two days non stop I will report back (with Wayne s permission)
Kind Regards to you all
Mark
Mark is right,
The education I have gained from this group is well appreciated.
And I share in your frustration - which stems from not being able to share completly.
Many of you have asked Questions that make me say "YES! they are begining to get it."
I wish you were here - because right now, right here in the lab, touching and feeling the discoveries, overcoming new barriers, is the joy of inventing.
Not money, not fame, but the that thrill and accomplishment of discovery, and of creating a way to overcome - that is a job well done for an inventor.
I am done here, those who requested will be added to my update list.
God Bless you all.
Wayne
Just a couple of points regarding the "Travis effect". A better illustration would have been as follows. Have a see-saw [teeter-totter] mounted above the water tank. Now have a vertical rod from each end of this seesaw descending to and attached to the two cups. This would better show that the bouyancy of the two cups were equal , in spite of the different amounts of air.
It has been said that the up thrust on the right cup will diminish as it rises away from the concrete block, and the shape of the enclosed air changes . Suppose that we replace that concrete block with another inverted cup that is full of water, and is exactly the same size and shape as the concrete . And we fix it to the outer cup, so that it rises with it. Does this cure the diminishing up thrust problem?
Your described demo is the one I use in my lab,
When the two equal contianers have the same diffirential pressure (not volume)- they will balance.
Volume does not matter on the Travis side unless you don't have enough to equal the diffirential.
Now what you can observe - is this add weight to the Archimedes' side and it will sink.
Add weight to the Travis Effect side - and the pressure diffirential increases to match the weight.
Sinks a little and then bounces back (repulsion)
So adding weight to the Travis side, and it sinks a little and bounces back . That is very intersting, I will have to try this for myself .
Could you please comment on my second paragraph , about replacing the concrete block with another cup, and attaching that cup to the original Travis cup?
If you attach the displacement to the cup "brick or water" the Travis effect is nuetralized because the water becomes a weight when surrounded by air (in simple terms).
The buoyancy with that design is exactly equal to Archimedes'
The "Travis effect" will not work with a submarine -
key to the design of the invention is opposite forces not connected - connected leads to nothing.
Quote from: mrwayne on May 26, 2012, 04:47:19 PM
Yeah, but what would work better is what water districts use, a water tower. Call me Mr. Obvious if you like. But it does take less energy to pump water to an elevation of 128 feet than the work it creates. That would supply a hydro geneerator.
After all, using something as old as a bellwos, if it moves 6 inches to close, it could as an example use 2 pounds of force to have 1 pound of water at an elevation of 33 feet.
In Newton's term's, if it free falls, it will have the same force. The trick is that the water at the base would have the same force. This would mean that the 2 pounds of force would be a part of a staic head which means that for 33 feet of movement, 2 pounds of force would be generated.
If every inch in the static head represented 1 pound of water, then where is the overunity ? it's in the leverage. Leverage (torque) amplifies force, even in a hydrogenerator. It could generate 4 times the force doubling it's power requirement.
And entirely environmentally friendly. I just have to wonder why someone doesn't try something like that.
Still, best of luck on your discovery and wish you all the success you deserve.
Jim
edited to correct the math and errors in concept ;D :o
I took a 1 qt container and taped some lawn trimmer string on the sides
so that a second matching container could not go down all the way
leaving a small air space at the top and sides.
And then I filled that 1st container with water and a lid so it
had no boyancy and inverted it into a bucket of water.
Then I pushed a second matching container down over the first container
squeezing most of the air out till only a little was at the top and
sides and it had very little lifting pressure. - disappointing....
Then I took the same 2nd container and pushed it down in the water
and it had much more lifting pressure.
Its easy to try.
I'm curious if others get similar or better results on this basic experiment.
Norman
Hello Norman,
I am a little confused by what you wrote - i just mean I do not understand what you did.
But - your experiment sounds very familiar - I had both cups in my hands - in the tub, both inverted one completly full of water, one completly full of air.
Carefully feel how much the water filled cup weighs - not much at all (under water)
Carefully feel how much the buoyancy in the air filled cup (full submerged)
Now, in that same condition - both cups fully submerged - slowly lower the air cup over the water cup,
What you will notice is this -
the water filled cup will "increase" in downwad force (like a weight)
The air will begin escaping the air filled cup, (should see a loss in buoyancy right ;-)?
But the buyancy of the air filed cup does not change - even as the air escapes - because the diffirential pressure acting upon the surface area has not changed
If you reach bottom, the water cup will now weigh the same as the lift in the cup.
The weight in the water filled cup increased a lot of air was lost in the air filled cup, and the buoyant force is the same as you started.
Now begin to lift the partially filled air cup - almost instantly the weight of the water cup dissapears, and the buoyancy of the air cup is reduced to nill.
NOW - think a little diffiretly then my critics - if you reverse the process - you can turn both of those forces on (the weight and the buoyancy very quickly with little very little dicplacement -
Now - do you know why Buoyancy has never been succesfully utilized - it takes too long to get the conatiner to fill and to sink - oops solved that
You now know how to nearly skip that fill and drain time -
p.s this is only the begining of our process - so don't try to jump to the end with conlcusions
Good Job all of you who look!
Wayne
OK Wayne I'll try this again.
experiment 1
I took a 1 qt container and taped some lawn trimmer string vertically on the outer sides
( simple spacers evened out and simetrical )
so that a second matching container could not fit down on top of it all the way
And then I filled that 1st container with water and put a lid on it and turned
it upside down and put it into a bucket of water. - result - it has neutral buoyancy.
Then I pushed a second matching upside down container into the water and down over the first container squeezing most of the air out till just like the video only a little air was at the top and sides and when it was in position with a little air on top and some on the sides
where the spacers were it disappointingly it had very little lifting pressure.
experiment 2
Then I removed that 2nd container from the bucket of water which filled it with air and then I pushed it down in the water and it had much more lifting pressure than experiment 1.
I expected experiment 1 to have nearly equal lifting pressure to experiment 2.
Its easy to try this. I hope this makes it clearer.
Norman
When it comes to grasping new concepts, even simple ones, they can be very hard to grasp, or maybe people, including me, are just lazy. I have previously criticised the Travis Effect video. I have suggested that the use of a see-saw, or if you like an inverted beam balance be used to compare the upthrust on the two cups.
My point is this. If the Travis effect, on its own is capable of overunity, Then it should be possible to build a self running machine based on this principle alone. It does not have to show a fantastic COP, and it does not need to be fully self acting . By that I mean that it would be acceptable to manually operate valves, etc, as long as no energy is added by hand to the device.
If this is not the case, then there are other undisclosed principles involved. It would be useful to know, either way. Are we for instance saying , that if we pump a small amount of air into the travis device , that the energy we can harvest from the resultant bouyancy is greater than the energy necessary to pump the air?
Correct, by itself - as presented "is not" super effecient, which I why I authorized that part of the machine to be released.
Even last year I was trying to explain that - yet the desire from all was to jump to the end.
You see how hard it was to understand at first - and the rest of the system is mind boggling - if you do not understand the "Travis effect" I do not wish to present gibberish - which is what I would sound like with that effect misunderstood.
It is the key that had to be understood to build a device to harvest net energy from buoyancy.
And you see how such a simple thing can be overlooked.
Peace and blessings
neptune
in a closed system a staic head will 2psi of force, tne same static head open to tne atmosphere will have 14psi,
tnis is somethinb engineers know.
Regardless if the system can be made OU is not the point. Fact remains the COST per WATT is extremely expensive, not for DIY solution and therefore cannot even compete with a 100w solar panel or small windmill.
This project is probably only ever going to make a museum item regardless if it works or not. There are far better alternatives.
Really?
Is this just a bait comment - question, come on....... you conclude that how?
Ok, I will bite -
We initally come in costing the same as Solar PV for a comparable wattage - unless you remember that solar works 6 hours a day at its peak ability.......
We are partnering with Solar PV manufacturers - for obvious mutual benifits.
"This is why the "Third Party" evalaution has stated - this will replace both Solar PV and Wind alternative energy".
It will aslo increase the Demand for Alternatives since the Return On the Investment is better than Fossil Fuel - a first for alternative energy.
Hope that helps,
Wayne
Wayne:
QuoteIt will aslo increase the Demand for Alternatives since the Return On the Investment is better than Fossil Fuel
I am pretty sure that all of us would like to see your ROI calculations. Can you share them with us?
Milehigh,
You mad bro?
No, I am not sharing our business plan with you, sorry, you know better than to expect that.
But, a little thinking will go a long way.
What is your electricity worth?
My bill is .10kwh, actually one of the lower prices in the world.
How many kwh can a 100kw system provide depends on the system;
Those costs are pretty well documented - as well as the asset utilization.
Our system has two major advantages - boiler plate manufacturing, Solar is a little more complex
And at least 4X the asset utilization - regardless of the weather.
Wayne
Quote from: microcontroller on May 28, 2012, 07:55:33 AM
Bull Shit.
I know exactly what you are doing.
Come on guy's don't be fooled by this man.
I always keep my word, and I tell the truth even when it hurts.
I try to be respectful, even to those who don't return the courtesy.
You do not knwo what you speak, but you do have passion.
And "Time will tell" regardless of your passionate disbelief.
I gave a training class to a group that will be acting as representatives -
The vision was clear - Get this to the world, at personal financial sacrafice.
Your comments, if they could - work to be counter productive to that mission.
Have patience, Wayne
Wayne, I have to commend you for the way you respond to the naysayers and name callers.
It shows the real character of a man.
With me - name callers and bad mouthers get crossed off real fast and I don't even bother
to read what they type.
If I don't understand something I will ask a question rather than condem the person or
the idea.
Norman
Stefan,
I was wondering if this is the right part of the forum for MrWaynes work.
Jim
Wayne,
I don't think that your ROI model would be revealing your business plan at all. I find it very strange that you would state that. Showing the ROI says practically nothing about your system. So what if you say what the approximate cost is, what's that going to change?
QuoteHow many kwh can a 100kw system provide depends on the system
You have made a good half-dozen or so statements like this that erode your credibility.
@All,
When a hydraulic cylinder extends into a bellows, it changes the air pressure.
This would make it easier to lift the other bellow using vacuum.
What I dont unfrstand is how the potential that created the work is reversed. This where many good ideas fail.
Jim
I think what you have exposed is more than what you are demonstrating. The amount or volume of water displaced for a buoyant condition is NOT dependent on the volume of air used, that is one part of what you are showing with the corresponding piece being that a buoyant vessel within the water column losses that value when surrounded by a pocket of air.
You are on the right path, well done -
I can not reveal anymore than I have in this group, so please correspond privately - if you wish to know more
I am tired of the pettyness and distraction of some of the members here - my work goes on.
As always you may contact me through my web site.
or at mr.wayne@hydroenergyrevolution.com
God Bless you all
Quote from: johnny874 on May 28, 2012, 03:19:24 PM
@All,
Jim
Hello Jim,
The Bellows simply act to transfer the equalization between columns, nothing new here -
Since we always have head in both columns - no vacuum
We move water not air - and we do not expand or compress the air that is no our system.
Quote from: MileHigh on May 28, 2012, 02:06:43 PM
Wayne,
Milehigh,
You make it clear what you understand and don't - and you make it clear what your opinions are - God Bless them - you waste my valuable time and my energy.
Nearly everyone of your notes are character attacks and disinformation.
Happy Memorial Day, time for a hot dog and some fishing!
Good day.
Wayne:
They are not character attacks and disinformation, you are just trying to spin it that way. Between this forum and the article on pesn dot com you are simply getting feedback from people with differing opinions. You are promoting buoyancy as a way to get free energy and the problem is that buoyancy as a mechanism for free energy has never worked. So the burden of proof is on you and realistically, we have no verifiable proof that you have something.
Sure, the story sounds great. You have engaged with engineers and the people in your home town have helped you out. It all sounds pretty cool but we have only got your words to go on.
When do you plan on offering the world definitive proof and how do you plan on going about to accomplish that? Is there something wrong with that question?
Don't try to spin plain talk as something else.
PS:
This comment from you:
The answer is that it doesn't depend on the "system" and quite honestly I don't know what "system" you are referring to. A 100 kW system can produce 100 kWh of energy in one hour, or 2400 kWh of energy in 24 hours. There is no dependence on anything like you are trying to imply. Your choice of words indicates that you are not familiar with the terminology relating to electrical power and energy. If you are developing these kinds of alleged free energy systems based on buoyancy you should be familiar with all of this terminology and how to use it properly.
Thanks Milehigh,
Proper comparison of energy producing devices include asset utlilization.
Wind and Solar do not run all the time, roughly 25% asset utilization.
We do not have the issue.
So in costing a system - you must consider that, nothing new.
Wayne
Here is an interesting diagram compliments of Mark Euthanasius:
Here is a picture of what we are doing - which your drawing does not represent.
I will disregard your comments until you do understand.
Wayne
Milehigh
"Portion of displace volume occupied by the shot glass does not change displaced water volume and does not change cup mass"
But from your drawing it change the volume of air in the big cup under W2. So the air pressure in the big cup under W2 will be more than the air pressure under W1.
So the upward force of big cup under W2 will be more than the upward force of big cup under W1.
Oops,
On my drawing
The word "difference" is misspelled twice. Also I the unit "CFM" should just be "CF"
(Thanks Tom)
Wayne
Just a test reply to see why I can't post a reply with an attachment to this thread.
Quote from: vince on May 29, 2012, 11:46:25 AM
Attachment type, perhaps? There is a list of allowed file types; .bmp for example isn't one of them.
Jejeho:
The upward force is the same in both cases.
QuoteFrom Wikipedia, the free encyclopedia
Archimedes (287 BC - 212 BC), the discoverer of this principle
Archimedes' principle is a law of physics stating that the upward force (buoyancy) exerted on a body immersed in a fluid is equal to the weight of the amount of fluid the body displaces. In other words, an immersed object is buoyed up by a force equal to the weight of the fluid it displaces. This principle is named after its discoverer, Archimedes of Syracuse.[1]"
In both cases, the amount of displaced water is the same.
Wayne:
It appears that you have tricked yourself into thinking that you are getting the same lifting power with a smaller volume of air. Your fixed solid cylinder inside the flotation cylinder is just displacing some of the air inside the flotation cylinder that allegedly demonstrates the "Travis Effect."
The work that you have to expend to fill the flotation cylinder with the smaller amount of air vs. the amount of work that you can get back from the buoyancy x displacement of the flotation cylinder is the real issue. The work that you put in will be equal or greater than the work that you get out. This is what you are failing to look at. You are deluding yourself when you look at your diagram and thinking that you are getting a gain.
Repeat, you are simply failing to examine how much work it takes to fill the cylinder with air in the first place and instead you are comparing the two cylinders and seeing a difference there.
It makes me wonder if you used a tank of compressed air to power the prototype because you were so convinced that you had energy gains that you thought it would "just be a technicality" to remove the tank of compressed air and switch over to a self-powering setup.
People that are interested can check out the discussion on pesn dot com.
Better luck next time but that's the way it really is.
Hi MileHigh,
Wayne said already that no air is going in or out, so it is a closed cycle.
Maybe you should call hard Skeptic Mark Dansie and let it explain to you or
you are going also to visit Wayne ?
The only 2 things that are different is the air volume to have the same lift force !
So in the Travis effect case you need less energy to pump the air under the bucket from below.
How his complete cycle and his machine really works is still a mystery to me.
Only one cylinder at the time is pushing, but what is the other cylinder then doing at this instance ?
Where is its air stored for later reuse ?
As this works somehow like a see-saw the lift must be switchable on and off...
When it is off, where does the air go ??
Maybe if someone has an idea we can try to reverse engineer it over here ! ;)
Regards, Stefan.
Milehigh,
You speak that which you do not know as fact, and you have ignored much of what we have said.
You can wait until our third party validation resumes, and until then -
You are wasting your time, and mine. We have the working models, and have been collecting Data.
So you are makeing a show for yourself at my expense.
You might consider the tone at which you deny our process, it is going to emberass you.
Wayne
Hello Stefan,
We do not move air in our system, just water through the bellows.
The air valves in the cabinet are for the original set up - they are disconnected and do not ever run again.
You won't need to reverse engineer - we are designing the agreements in such a manner that it makes it a no brianer to work with us.
This is good for the world.
We have very good additional third party representatives lined up my Mark Dansie, Mike Raymond and some I can not name yet under "CDA", they are respected professionals.
Thanks for your web site, since I can not disclose the Inventive portion of the ZED machine, I see that I will just fall under continued Character attack.
I have been advised by some of those professionals to stop responding.
My website will still be available, and you are welcome to contact me in the future.
Wayne Travis
Here is my take on the Z.E.P. based on the very first post by mrwayne and pictures from his website.
I believe there are three cylinders that are clustered together in the belows. Each of the cyl. has an intermediate piston or diaphram that traps air in the uppermost chamber. the lower portion of each cylinder has a feed opening of some sort to supply water to it with appropriate valving. the cylinders get smaller as they stack on each other. Only a small amount of water injection is needed to cause the intermediate pistons to rise and the travis effect will cause each of outer cylinders to rise a limited amount with a force that is proportional to the surface area that the air chamber is acting upon. As each cylinder reaches its limit the next one above it is fed with water and so on until all three have reached their limit. That limit would be full extension of the belows. The belows are filled with water from the each of the main tanks which are pressurized and maintain head pressure on the system. Because the travis effect acts thru a very short distance the total stroke is relatively short while the force is proportional to the surface area of each piston. The advantage of his system is that you do not need to inject a large amount of air to achieve the bouancy force but rather a small amount of water to cause the trapped air pocket to do the same work via the travis effect as the the conventional way of using the bouancy.
I'm guessing that a cylinder is attached to both sides of the pendulum arm and as it swings it creates a pressure in each cyl. which is fed to either a hydraulic accumulater or an apropriate sized hydraulic motor. The narrator states the end result in the video. That why that hydraulic motor you see turning in the video is turning slowly and at a varied speed.
Very clever indeed!
I'm trying to post a jpeg diagram with this but for some reason I cannot get it to work.
Vince
Stefan:
Different air volumes have the same lifting force with one major difference. The smaller air volume can not sustain the same amount of force x displacement as compared to the larger air volume.
Wayne:
I'm not attacking your character and I wish that you would stop saying that. You have no substance to back up that claim. Sometimes I talk plain talk and you should not try to spin that as a character attack. I don't remember the details about your system in part because you play word and riddle games to drop hints. I tune out.
All that I can tell you is that the diagram you posted with the "Travis Effect" is unremarkable and doesn't show anything special. You appear to believe that it does.
You have stated that the system works so I will wait for news of a definitive demo that is going to be verified by independent third parties. Mother Nature is not on your side however.
I can't explain the conflict between your claim and what we know about buoyancy and gravity:
QuoteThe Model pictured is our Data collection model
We use a special method to activate and deactivate
Buoyancy in such a system to allow
that "Buoyancy" to be used in conjunction with
gravity to be able to provide excess energy.
The extra Energy is currently converted
into Electricity for the purpose of
Demonstrating our systems ability to exceed
its own operating cost and provide Net Energy
Can you tell us when you plan some kind of demo that will be verified by independent third-party testers?
Vince,
can you please send me the drawing?: tibor.gats at gmail dot com
I'd like to understand Z.E.P., but from your description I don't see how these cylinders are arranged.
Thanks,
Tibor
Quote from: hartiberlin on May 29, 2012, 01:57:41 PM
Hi MileHigh,
Regards, Stefan.
Stefan,
What might be happening is that when one weight drops, it lifts another. D@mn, I just quoted Bessler. :o I think it would be easier to work with vacuum than with compressed air. It is possible he is using compressed air. What could be happening is that as the bellows opens, it loses pressure.
This would still require a vacuum side to lift the other bellow inverting the Travis Effect. This effect mirrors hydraulics which I am using in bessler's wheel. That does not reverse direction and resets because of rotation and continuous flow.
With what Mr. Wayne has, he would need a diaphram that can change the potential of the 2 sides. this would require a lot of movement. This would most likley be used in conjunction with heavy weights to store momentum and carry past the failure point to where it has a chance to work. After all, f = ma. A heavy enough weight would have stored energy from being on the side with the highest air pressure.
A vacuum would lift the opposing side operating the hydraulics that powers the generator. Outside of this, not sure what would have a chance of working. This is because if pressurized air is working to cause one effect, then a vacuum would be needed to compliment it in it's opposing behavior.
Reversing directions when dealing with a high energy potential (even slow movement) requires a significant change in pressure and/or force.
And considering patents do protect the inventor and others in here have posted their patent numbers, do need to be suspicious of why being here with a working idea worth money.
Jim
@All,
Go open the hood or trunk of your car. Opens easily, Travis Effect.
Jim
Quote from: vince on May 29, 2012, 03:28:47 PM
Very clever indeed!
Vince
Vince sounds good, but hard to understand.
Just send me the pictuire by email and I will post it.
hartiberlin@gmail.com
How is he then doing one side pumping the other side and how
does he reverse this ?
P.S. By reverse engineer I meant not to "steal" the invention, but to ponder about
its function principle without the need to sign an NDA.
If the function principle is known a few independant replications will really help
to make the claims more valid....and can prove its validity.
But I think this technology is also too complex to be pirated on the small scale and is only good for
large cooperations or for larger communities generating their own energy.
As it seems upscaling into the KiloWatts or MegaWatts range will require very large building blocks, if the shown
protoype can only deliver around 30 Watts at its already pretty big size....
So I will rather play with JouleThief or Joule Ringer circuits and a solar panel to charge
up a battery bank and generate this way my own power, much easier and much smaller
ti build...
but to know the principle of the Travis effect is intriguing...
MileHigh,
With all due respect, you are a dick. You have (with help from a few others) now run off an individual who had something new for me (and possibly others?) to study and learn from.
I am pleased with the fact that you now are being less rude. But being a polite dick vs. a rude dick does not detract from the fact that you are still being a dick.
Please allow for the inventor to be questioned and allow for their answers to be presented and questioned in a more "Gyula" like way?
Thanks,
M.
You know, I was looking at James Kwok's Hidro (the latest design here);
http://www.youtube.com/watch?feature=player_embedded&v=oV5wFTfsTSs
and it seems to be using the same type of system as the one shown in this thread.
Kwok's Hidro has changed for the latest design. There are no longer air cylinders that move up and down by buoyancy. Check out the videos and new design.
http://pesn.com/2012/03/12/9602055_Hidro_Reveals_1_MW_Plant_Design/
eerily similar to this thread.
Mondrasek:
Wayne played the professional victim instead of trying to answer some simple questions that anybody interested in the proposition would want to ask.
How can you say that there was something to study and learn? He gave no details, and instead took the "philosophical route" and also played the "dropping big hints" game. If the guy was real he would have had something to say. Gravity and buoyancy are not sources of free energy and Wayne's "trick" as shown in his diagram was meaningless.
Don't expect to ever see something working.
I agree with Mondrasek,
You chose to ignore that we have already been through third party testing, and you have added ingnorant insults, slanders, and hopes for my demise - to most every post.
I do not play the victim, you attack.
You have slandered me repeatedly on two other web/blog sites.
I have tried very hard to be respectful -
My patience for you comes from my respect, and understanding of the responsibility I have for the gift I have been trusted to bring to the world.
I have the truth, you have misunderstanding and disrespect -
You do not just accuse me;
You spit on the 88 members, engineers, scientists, and skeptics that have already comfirmed our work.
Good people have embraced our work, our research, and we are moving on with thier friendship.
Your disposition to attack that which you do not understand will leave you holding a cold empty plate.
Yes, more philosophy - I am a man not a machine.
May God bring peace to your heart.
Yes, more faith -
Wisdom and belief in something greater than yourself - is my character - not a spin.
My focus - Bringing clean, sustainable, and free energy to the world, and thanking God with every breath of clean air.
Wayne Travis
Quote from: mrwayne on May 31, 2012, 08:28:30 AM
Yes, more faith -
Wayne Travis
Wayne,
Considering with me, 5 surgeries in 3 years and fresh off my last one and twice you refered to me as a troll.
I should be saying what you are. Yet I am building something 99.999999999% of German's don't believe is possible.
after all, pressure is pressure and it pumps. I do know one thing about machines, reversing direction is an expensive
propostition. This is because motion has to be stopped in one direction and restarted in another. How much energy is
lost due to accelerating something ? It requires more energy than something in continuous motion in one direction.
Myself though, believe you believed you had discovered something and put out a good effort. But for 3rd party
verification, I think when it is achnowledged as being in daily use will work for me.
Conradelektro sent me a link about the Casimir Effect. That is one thing odd about scientists, they like publishing
their work and having it peer reviewed. Of course, if you have a working prototype as you claim, you should have
no problem attracting investors. If not, then I would have to wonder why people wouldn't be trusting you with their
money.
Jim
This guy is obviously NOT going to Open Source his machine.
Just like many others we’ve seen in the past, there is no future for non-open sourced free energy machines. Do you really think the Feds/Government wants clean free energy machines openly available to the general public? No! Why? Because Revolution (energy independence) is only a step away from clean free energy machines and the Feds/Government knows this. And if you take that away from the Feds/Government then they lose control of the general public of the world, which that would mean bad news for the Feds/government. No matter how much you patent or copyright the invention, the Feds/Government will do whatever it can to put a stop to it. If anything they will use your discovery to their benefit and most likely make you disappear at worst. The general public will never have access to free and clean energy machines as long as the Feds/Government is concerned. So when people try to take their free energy discovery non-open sourced route for commercial business, they will only go so far (not far at all), and the people of the world will continue as is, slaves of the corrupt Feds/Government who runs the energy monopoly of the world for their own benefit and not everyone else.
Mark my words!
Peace.
Quote from: johnny874 on May 31, 2012, 09:13:58 AM
Wayne,
I do not remember calling you a troll, I do remember you saying I did, and I am remember apologizing because you took it that way - Regardless of my intent - if you took it that way - I take responsibility and sincerely apologize.
I will pray for your healing.
Wayne
Wayne,
You show me where I am "attacking" and "slandering" you. Go ahead, quote what you think is relevant and I will respond.
You claim you have third-party verification. Do you have some links? If you are just making this claim yourself then it is meaningless. The test report has to come from the third party themselves.
QuoteMy focus - Bringing clean, sustainable, and free energy to the world, and thanking God with every breath of clean air.
Thank the sun and photosynthesis for your breath of clean air because that's where it's coming from.
Quote from: mrwayne on May 23, 2012, 11:26:21 PM
Wow,
My system does have a small 12v battery, to run the HMI, that runs the valves and track the data.
Something most people realize - that we are running a hydraulic motor - Self powered, a Generator - self powered, - a dual pumping system with a surface area of 525 inches - self powered, a HMI with to valves 25 sensors and self powered - hydraulics self powered, and burning two light bulbs self powered .....while creating a force of 5500 pounds and capturing it - self powered.....
And someone takes the time to complain of a batterythat can not possible do all of that.....you have witnessed an impossible machine.
When I was young an old man told me the boat left shore and both the people on the boat and the shore thought the other was shrinking.
Nice to smile
@Stefan,
I think this is the info needed to reverse engineer it or to tell him how to make it work.
After all, haven't seen the patent. So any patent after this date with this information, well...
His pumps have 10 psi and lift a bar (1 r MrWayne, just paying attention to detail here :D ).
As the bellows expands, the hydraulic unit comes down with it maintaining the 10 psi of pressure.
At the same time, if converted at a 1:10 ratio, then of the 250 square inches of surface area, pumps with a surface area of 25 square inches would have theorhetically 100 psi to have a greater push downward operating the hydraulics being lifted in the opposing bellows.
This would mean there are 2 parts in the bellows and one dropping faster than the other.
The one thing I still don't understand is how they would change the potential from one side to the other. Changing air volume/pressure in something like this I would think would be critical to it's operational ability. It's what would give one side an advantage.
About the only way that I know of to try something like this would be the cylinders with 100 psi would need to use a part of their potential to move the air/gas of the opposing system depressurizing it. If that's where the gain comes from (the 100 psi cylinders), then it would need to use a part of it to change the air pressure/volume in the opposing bellow assembly. Then it would be this difference in potential that would be realized in the functioning of this type of machine.
Jim
MileHigh,
Quote from: MileHigh on May 31, 2012, 12:15:43 AM
I agree that you asked some very good questions that I too would like to have heard answered. However, those questions were either directly after or part of messages that were just dripping with thinly veiled passive aggressive statements. You then hid behind statements of feigned innocence such that you were only speaking plainly and were not intending to be offensive. Passive aggression is exactly how many of your statements were intended and received.
Also, completely ignoring statements from the inventor and instead telling your impression of what he really did or thinks is more behavior befitting RA than I would expect from you.
A first example: The "Travis effect" showed a behavior unknown to me. I understand that it is nothing new and fully explained by known physics. But it was new to me and therefor something I would study and learn. That is why I read this forum.
I am pleased to see that Mr. Wayne has returned. And I hope he is allowed and does offer more details and some answers to yours and others questions.
Thanks,
M.
in this way?
for experiment you can use small glasses , you can feel the difference in your hand.
added a more clear drawing
Quote from: wings on May 31, 2012, 03:43:37 PM
in this way?
I think it's done something like this. It would be a cylinder inside of another cylinder.
The inner cylinder as an example would have 20 psi, the cylinder or space beneath it would have 10 psi. Because of this difference, the cylinder with 20 psi would expand downward.
Because it has the hydraulic assembly in it occupying space, the pressure remains constant.
While this is happening, the space beneath the cylinder which has 10 psi is being compressed. Because the riser tubes total 1/10th the surface area, their pressure would be 100 psi. This would increase the push downward opening the bellowing lifting the opposing one and generating hydraulic pressure.
Why the system doesn't seem to work for Mr Wayne is his team never figured out a way to change the air pressure in the opposing inner air cylinder. This can be resolved by having a line feed a small pump that opens an expansion chamber attached to the opposing inner air chamber. When this happens, the air pressure is reduced allowing the other air chamber to become the greater force. Directionality is important.
And when the bellows are going to change direction, a spring which has more force than the air pressure in the cylinder empties the expansion chamber and is held in a locked position.
If something like this is possible, it can be demonstrated mechanically. otherwise how would anyone know where potential is failing to be realized ?
Jim
edited to add;
the reason I show one bellows lower than the other which is not necessary is to convey the direction in which the work is being performed.
p.s., Mr Wayne, if your team of engineers haven't thought of this, then I'm not sure you are 10 years ahead of anyone. Just my humble opinion.
".s., Mr Wayne, if your team of engineers haven't thought of this, then I'm not sure you are 10 years ahead of anyone. Just my humble opinion."
Hello Jim,
I like your thinking, you continually show a full grasp of what you are talking about -
Every now and then you hit on something good.
You are Sherlock Holmes of Over unity ;-)
Keep up the good work.
Wayne
I tried this experiment this morning and didnt see any ting unusual.
I may be missing the point but ???
Anyway
1. two containers in a water bath with a mug of water on top. The inside pink container is filled with water. The white container is filled with air and the black fuzzy line is the water line inside and outside the container. Filled the mug on top with just enough water to ofset the bouyancy of the white container.
2. Removed the inner pink container without lifting the white one out of the water so that all of the air in the white container stayed in it. Replaced the mug on top with the same amount of water in it. Still just the right amount of water to ofset the bouyancy ???????
maybe I am thick but I dont get it.???
Cannot say for sure yet, but I think I may have met someone who knows the inventor. Local.
She was telling me of a machine her customer invented, along with other inventions, successful, that operates like what we see here in the vid. I had shown it to her off of the home page, and she believes it is it.
She said his name is Juan, but I wont tell the last name here for now. She noticed the JR on one of the fins or weights above the fluid pumps has the letters painted on one of them, and she said that must be him, as R is J's Partner. ;]
She is going to get in touch with him to see if we can meet.. ;]
A seemingly small world. We will see.
Mags
Quote from: gsmsslsb on May 31, 2012, 06:31:42 PM
Anyway
2. Removed the inner pink container without lifting the white one out of the water so that all of the air in the white container stayed in it. Replaced the mug on top with the same amount of water in it. Still just the right amount of water to ofset the bouyancy ??? ??? ?
maybe I am thick but I dont get it. ???
In your experiment the top white container should have been slightly higher up out of the water while in the equilibrium position in case #1 vs. case #2. You would have to mark/measure that height vs. the surface of the water to see clearly. This is how the effect should manifest in your experiment.
Having less air in the white container (or more water in the cup to produce same) should increase the difference in height of the two cases. Also, a smaller gap between the outer white and inner pink container should likewise show the difference in the two heights more dramatically.
M.
Mondrasek:
The tone of my posts was not unreasonable and challenging people that just might be doing these things for untoward reasons is not an unreasonable thing to do. For example, if just one person demanded that RomeroUK show the voltage waveform after the FWBR outputs he would have been busted right then and there. It was so obvious that this should have been done and even people that have been playing with pulse motors for years never asked for that. So it's healthy to be inquisitive and it's actually necessary. If you are suspicious of something you have a right to express yourself and state your suspicions.
If you did serious research spanning the 19th, 20th, and 21st centuries for people pitching free energy from buoyancy I would not be surprised if you found that there were hundreds of charlatans that promoted this concept for their own financial gain.
This clip will make you think:
http://www.youtube.com/watch?v=T69TOuqaqXI
Just went to the beginning of the thread, as I had not taken a close look at this device yet. I see it is Mr Wayne Travis that is the inventor claiming this device. And He is apparently in Oklahoma and I am in FL. Sooo, maybe my friends friend has something different or similar.
The JR thing is odd. ??? Small alternate worlds? ;]
We had been talking about me meeting this guy since last week. Today she was explaining more of what he had shown her of the device and this vid on the home page clicked for me. I thought I made a connection and had shown her the vid. By her reaction to the vid, I thought they were the same. She also said she didnt recognize the man in the vid though, but she said she has not met R yet of JR. Oh well.
There is always room for 1 more device out there.
Maybe these guys should meet. From my friends description, it seems they have somewhat the same idea. 2 pumps similar to what is shown here, slow pendulum action and uses presure via pump actions. Also from her description, Waynes vid device is somewhat faster than what she has seen. My perception initially was that Waynes device seemed awful slow. But there is apparently one that is slower. ;] Just cracking a joke there. ;]
Hi Wayne. Are you associated with anyone in FL that is working on this type of device also? From what I understand Juan has patents on portions of his device, so it might be of interest to see if there are similarities between the devices.
Will try to have more info soon.
Mags
@All,
Just watched a show on the Science channel called How Do They Do It ?
They had hovercratfs on it. And on this one hovercraft which could hover 3 feet above the ground, could have a man working under it with a hatch open because the air pressure was so low. How low was it ? One claim was it could run over a land mine. To demonstrate this,
they had it run over an egg. The egg didn't crack.
By now, you're probably wondering, how much does this hovercraft weigh ? It comes in at
a light 20 tons. It's also 65 feet long and, hmmm, maybe you'd prefer to read a little something about it for yourself ?
ttp://www.thinkdefence.co.uk/2010/05/fdr-littoral-2/ (http://www.thinkdefence.co.uk/2010/05/fdr-littoral-2/)
I guess it's about air compression.
Jim
@Wayne,
I think this is the answer you came here to find.
Myself, I like posting with people like MoRo, Webby1 and Raphael Ti, they are my kind of people.
With the picture, the cap can be lifted by the opposing cyclinder dropping. It does not use the Travis Effect but uses principles in hydraulic Theory. Since you are a religious sort, my gift if God gave me one is not engineering. i have worked hard to elarn it and understand it. A gift is something that comes easily.
With the picture, the 20 psi area can move away from the cap. If so, even the 10 psi area can do so as well but more slowly. In a fixed concept, as the 20 psi area expands, it will seek equilibrium with the 10 psi area. Even Jesus said there must be balance in all things but doubt he was refering to engineering.
As the 2 areas seek equilibrium, the piston in the floor of the assembly is moved downward with 10 psi acting upon it's surface. If the primary (large) piston has 3 times the surface area of the piston in the cyclinder beneath it, that would result in 30 psi of hydraulic not pneumatic pressure. Hydraulics is not compressible and would lift the opposing cap a height equal to it's movement. It would be this lift that would reduce it's 20 psi area to something lower, even 10 psi which would allow for a greater chance of operation.
If it can not be demonstrated mechanically in one direction, it would not be worth pursuing further. The components are all capable of being tested independently and as an assembly.
Something any engineer should be knowledgeable of and understand.
The basic reason it could work ? The hydraulic pressure which helps to change the primary motive pressures comes as a result of waste energy.
And if this works Wayne, don't thank me.
Jim
p.s. the Travis Effect would only help in moving the low pressure (10 psi) chamber lower. It's the hydraulic cap at the bottom which everyone has ignored :o
" @Wayne,
Myself, I like posting with people like MoRo, Webby1 and Raphael Ti, they are my kind of people."
Jim
Hello Jim,
I like'm also.
Sorry, lost in translation, I can not tell what you are showing, what are the functions of the picture - cap - 20 psi, 10 psi? It looks like the assembly moves as one piece - down.
Thanks Wayne
Wayne
Wayne:
I challenged you with this:
You ignored what I said. So please no more whining.
Looking forward to something substantive showing that you have something.
Also, if you really have something, why don't you simply open-source it right now for the benefit of all mankind? Surely that's more important than your pocketbook.
How come whenever an inventor claims that he or she has something that will completely transform the world and end wars and hunger and usher in the Age of Aquarius.... It's always a "big secret?"
Why is that?
"I challenged you with this:"
Milehigh,
You double down.....
I wait for an apology.
Until then - Good day.
Wayne,
I am sorry.
I can tell you one thing. If I had discovered Fire 2.0 I sure as hell would open source it. Why try to become the "Bill Gates of Buoyancy?" Why? Do you really want a mansion with 20 bathrooms? Wouldn't you prefer to start spreading the word so all of the starving people in the world would have easier access to energy so they could feed themselves and better their lives?
If you open sourced a free energy buoyancy device that ultimately saves millions and millions of people from starvation, you would be set for life anyways. You could make a fortune on speaking tours.
Wayne, when do you plan on delivering the goods? When will we get to see definitive proof from independent third party testers that what you claim is true? When will you give a demo of your system, something like the system running for a full month driving a generator that powers two kilowatts worth of oven heating elements inside a protective metal cage. We want to see the red glow 24/7 on a webcam monitoring system. We want to have volunteers taking shifts so they can observe the system in person and monitor the voltages across the oven heating elements and feel the heat with their hands. Can you do something like that?
Thank you for the question,
We are currently being assisted by friends of Mark to set up the extended testing and degradation analysis (with the Data collection model).
We are upgrading the processor to be able to track real time and continous Data.
We have raised our own personal "Bar" to exceed the proof beyond speculation.
At the same time, our engineers are arranging the manufacture of the next scaled up model the first Beta model, we have meetings Tuesday with the manufacture bidding for the job.
Regards to open sourcing - I have seen the notes from others here where Open sourcing - is assumed to be a way to avert supressions, and greed. We have seen no supression - beyound what was felt here and or casued by unbelief - and I am dedicated to make sure that the benifits of this machine reach the world.
I love the business model we are currently entertaining, but we have a couple more professional strategic planing presentations to review - we will see.
"Deliver the goods"
I see the question is regarding the Proof of concept - third party testing.
Some assumptions on this site are that we are here to seek approval, I came here to share the excitement, and answer questions within limits.
The third party testing is being done for the people and groups that are helping to provide the resources that will "actually make these available" - that is more important than the hope that if it was let go - any one would spend the money to try in something they do not believe in.
We will be releasing to scientific journals and presenting the Data professionally, when Marks Group reccomends.
I look forward to the longevity runs as well, Next weekend is when we have the help to set up the new plc equipment and software.
Thank You
Wayne
Wayne:
I wish you the best of luck. Please note that when results are shared publicly that you are going get feedback from all sides.
If I can make a suggestion, you should to show the device driving a load. Just seeing it "self running" is not enough. Will the device have an output shaft? Assuming it does there is no reason not to show the output shaft driving a generator that is clearly driving a big electrical load with live measurements and all wires exposed.
As an example, you could set it up on an asphalt surface, and you should clearly show that there is not an electrical outlet box embedded in the asphalt before you set up. A setup on regular ground will not cut it. Then just drive a big electrical load continuously for a month.
Quote from: microcontroller on June 02, 2012, 01:19:33 AM
The only thing he is going to share is overunity excitement ;D LOL
Place your bets please.
Our current corrupt Government will never let clean self running free energy machines be accessible to the general public of the world. Especially commercially. NEVER! Why? It will destroy the Government’s general control of the world population. Look at others who have achieved free energy and tried to make it commercial, never happened and never will as long as this corrupt Government is concerned.
I bet all the money I possess microcontroller :)
@All,
This is for a watts calculator. With what I am working on, I would be generating about 6 watts of power
by using a wheel with 1/2 Nm of force. That would be 1 kg at 1/2 meter.
To generate 25 watts takes 4 kg's @ 1 meter from it's axis of rotation. And it would need to rotate @ 60 rpm.
Sorry folks but can't accept that Wayne's invention is developing that amount of power. If so, I would have
to think it would be easily demonstrated that it is a working prototype.
To Wayne, I like engineering and have worked with complex systems, one's more complex than yours. Myself,
I know a 12 volt battery could allow your system to work while causing a sufficient pressure differential to give
it the appearance of it actually working. But 25 watts requires something that would be self sustaining in an
obvious way.
@All, here's a watts calculator. .
Jim
http://www.magtrol.com/support/motorpower_calc.html (http://api.viglink.com/api/click?format=go&key=0de1c882bae3a5d7344e394b19608218&loc=http%3A%2F%2Fwww.overunity.com%2F12223%2Fhow-to-build-a-bessler-type-wheel%2Fnew%2F%23new&v=1&libid=1338643046622&out=http%3A%2F%2Fwww.magtrol.com%2Fsupport%2Fmotorpower_calc.html&ref=http%3A%2F%2Fwww.overunity.com%2F12223%2Fhow-to-build-a-bessler-type-wheel%2F30%2Fpost%2Flast_msg%2F324591%2F&title=How%20To%20Build%20A%20Bessler%20Type%20Wheel%23new%23new&txt=http%3A%2F%2Fwww.magtrol.com%2Fsupport%2Fmotorpower_calc.html&jsonp=vglnk_jsonp_13386431303751)
edited to add;
@All, pressure sensors don't need plumbing. With a tree that is connected with tubing to other components
is something not needed unless air pressure is being converted into hydraulic pressure. And for this, a large
piston in the bottom or top of the bellows would be the best location. Hydraulic lines tend to be rigid as a
result of being under high pressure. But this would require only one line per bellow.
And for changing the primary air pressure for work would require only changing the area of that bellow by
using either a diaphram or an expansion chamber like the cap I mentioned. And neither is visible in the videos.
If some how Wayne's invention works (which I doubt), it is poorly engineered.
Thanks Johnny,
Our system has three seperate and comlete systems
and I see this has added to the confusion of our operation and system.
System one -
The simple over unity portion - its capture and operating system - very basic.
System Two -
The Data collection system 25 transducers and hoses and wires to connect them all.
(yes they could belocated next to the source - we located them together so they could be isolated - good planning when you have to go through peer review)
System Three -
The initialization process.
Exist for only one reason - to allow the peer group to measure the initail filling of the system.
It is locked out after that operation and is no longer needed.
I am glad you are a better engineer - We need them.
What you infere in your statement is both confusion of our process, I understand - who could have ever understood the stages of "Extra Ordinary Proof" and "Complete analysis of an Actual OU device.
A black box running a load - as many assume would be enough - only adds extreme questions - and funding an operation on that leads to nothing.
Scientific anaylsis is the only responsible direction to take, for both the Inventor, the investor, and the world - or else it gets now where.
Now trust me - If you had engineered a mechanical free energy device - you would be going to the same extreme efforts to put it togther - not for the best engineering - but the best function and isolation for our purpose of analysis.
This has been a learning curve for me also.
Wayne
Quote from: johnny874 on June 02, 2012, 09:26:08 AM
@All,
Hi johnny874,It appears there is a misprint on the quote above, the 4Kg (mass) should be 4 Newtons (force), and that is the weight about 0.16kg or 160grams, in order to get 25 Watts, from 1 m arm (radious of rotaion) at 60 rpm.Thanks for the link/analysisMike
Quote from: mikestocks2006 on June 02, 2012, 11:20:24 AM
Hi johnny874,
Mike
Just a misunderstanding. Still, for 1kg with 1/2 meter from it's axis needs to rotate at 60 rpm for 25 watts of power. Doubt your device generates that much energy.
Thank you Johnny,
"Doubt your device generates that much energy."
Well, after the converting the Buoyancy into hydraulic production, then splitting that production to run the Internal operating system, and then using the left over production to runa hydraulic motor - which then turns the Generator - thats about what we have ..
Now jumping ahead on the logic - if you have looked at the machine and calculater the size of the tanks and realized that there is not enough mass discplacment to cause enough buoyancy to generate that much energy - You are right - in your logic Because you impose the limitation of buoyancy to mass.
To be clear - using the external mass to predict the Buoyant field - will agree with your conclusion - it is counter intuitive to assume we are gaining on the mass discplacement - under those limitations.
We have been clear - our layering system concentrates the physical effects of Mass displacement - and is the key to our process - and our IP.
Thank you.
Wayne
Hello Microcontroller,
We all get that you do not understand our process,
You speak as though you have "all understanding" by denying what you do not know - and then accuse us of playing god...
My only request for you;
May you have Peace.
Wayne
Quote from: microcontroller on June 02, 2012, 01:35:15 PM
errr i neeed to rrrrespond i need to hit that reply button it makes me feel goood let's make some shit up about converting the Buoyancy into hydraulic production and add some more bull about our layering system and they will give me some more attention it makes me feel like a god and i'm not going to show anything har har har
Here is what I don't understand: A guy comes to OVERUNITY.COM forums to tell us about his (supposed) OVERUNITY device. There are videos of obviously very expensive machines. There is a know de-bunker who has visited, witnessed, and not been able to rule out the possibility that there is something to his claim.
Why are you mocking him?
Anyone who claims to believe in OU is usually labeled as a nutter believing in pseudoscience, right? But isn't this the website where we listen to them and try to help them find the error in their idea or help them move forward with their idea?
Please don't take me as some sort of zealot who believes that Mr. Wayne has found "the Holy Grail."
I believe we need to show him the respect he has repeatedly showed us.
I also agree with MileHigh that serious questions should be presented to him. We can only learn more from his answers.
Thanks,
M.
Here is a simple study of the effect of adding a "Travis effect" type fixed displacement member inside of a buoyancy device. The device is designed to have the water (not air) introduced from the bottom. So we start with everything only in air at one atmosphere. As the water is pumped in and rises it will cause the air trapped inside the "piston" chamber to compress slightly. Assuming a simple isothermic case where P1*V1=P2*V2 the reduced air volume and resultant head pressure available for buoyancy is calculated. In order to allow for both cases to still have 12 inches of possible stroke I found that I could only block 33.4" of the inside of the piston air chamber with the selected 22" diameter cylinder.
The results show that, due to the reduced amount of air and subsequent reduced volume reduction due to compression, a higher head pressure and resultant buoyancy force can be achieved in case #2. But I was unable to find any other significant results.
Please note that this is just a simple ideal case study where all members are 100% ridged, massless, and have no material thickness.
Thanks,
M.
M.,
I think where he lost me was when he started thanking God for the great things he is going to do.
With me, I like working out in the open. I have no need to keep secrets.
Then again everyone knows I believe Bessler war succesful and was highly intelligent.
Could be where I am different, I don,t mind doing what,s already been accomplished.
I still find Bessler and what it takes to replicating his work worth while.
Jim
Jim,
I too have chased after the Bessler wheel. I've done dozens of simulations, all that I can get close to unity! But unfortunately no success.
If you are a fan of Bessler you then know that he also gave all credit for his wheel to God. He was holding out for the sum he required to "sell" his invention for the purpose of funding some religious academy I recall? Others can correct the details.
I am fine with anyone not believing Mr. Wayne's claims for any reason. I just want a mature and respectful exchange since, so far, I have seen no requests for funds, replication, or other resource wasting items. So I cannot label this a scam that is hurting anyone. Instead, it has inspired me to study and learn several new things. For that I am indebted.
I appreciate everyone who helps to expose and drive off scammers. As well as those who help to educate the misguided and misled. I don't believe we have any hard evidence of any of those malign intentions so far. All evidence for those conclusions is so far circumstantial, I believe. So I say, ask questions. And listen carefully to the responses. Study, and learn. At least until something more solid than "I've seen this pattern of behavior before and it never ends up satisfying me"! is evident.
I appreciate that everyone's threshold for calling something a scam is different. But just because some individual's tolerance has already been breached, it should not be taken as the reason to be disrespectful to an individual that may still have valuable input to the rest of the community.
Thanks,
M.
Wayne:
I am going to share a few thoughts with you.
For starters, for your demo I would disconnect your entire monitoring apparatus for the first run. In your outdoor clip you can see what looks like an oilfield Christmas tree of high pressure hydraulic and/or pneumatic hoses. Your monitoring system could easily be powering your device and nobody would know any better. Plus, seeing 25 or so digital strip-chart recordings of your sensor information is just going to make people glaze over.
Repeat, strip off your entire sensor array and just do a bare-bones demonstration of your system for your first demo. Run it for a month continuously and show it outputting power in an absolutely unambiguous way. Seeing a set of lights mounted on a panel with a digital watt meter is NOT a way to demonstrate the alleged output power of your device.
What about what you plan to demo? In my opinion you can sketch out what you plan to do without revealing anything. So what do you have? It looks like your buoyancy system will be used to run a hydraulic pump. Will the pressurized hydraulic oil power some kind of oil turbine (not sure of the correct nomenclature) that then runs a generator? I am sure that we are all curious to know how you take the power supplied by the buoyancy system and turn it into something useful. What will the form of the output power be in? How much power? How will you measure it? What will the load be? Are you using a COTS electrical generator? If yes, who is the manufacturer and what is the model number?
In your groaning clip, we see what appears to be an electric motor that is driving a hydraulic pump. Is this true? Where does the electrical power to drive the motor come from? What is the pressurized hydraulic oil being used for?
What is going on in both the groaning clip and the outdoor clip in terms of what you are doing with your alleged free power from your buoyancy system? It appears that there are hydraulics and pneumatics running and you already stated that there is a battery running some stuff. Both the pneumatics and the hydraulics require a power source, and your slow oscillating alleged free energy buoyancy systems seen in both clips makes you wonder how you convert that into pneumatic and hydraulic power.
I could go on for a long time with questions. I don't feel any of these questions are invasive and infringe on your alleged core IP built around the buoyancy system. All that I see in those clips appears to be two contraptions that are powered by compressed air or hydraulic oil or a battery setup. I don't get any sense that those two setups have a core power source that is driving the system. To me it looks like both setups are being driven from some sort of power source. That is my honest opinion.
You say that you have to pressurize the system when you start it up. Well, you are putting energy into the system in the form of compressed air when you start it up. How much compressed air energy do you put into the setup at the start? How large is the compressed air volume and what is the PSI or kilopascals?
If you say that none of the compressed air provided to the system at startup ever loses pressure, then how come you have to repressurize it every time you start it up?
So Wayne, I doubt that you will answer my questions. Right now your proposition has very little meat on the bone. It's up to you to decide to answer or not before your demo for your investors.
If you have learned anything from this posting perhaps it is that your clips just generate a long list of questions for some people, they don't prove anything.
MH,
Great post. I just want to disclose a thought I had that differed from your "take away" from viewing the groaning video. I had assumed that the "electric motor that is driving a hydraulic pump" that you described below was actually the reverse: A hydraulic motor (powered by the output of the system) running a generator to power the electronics by keeping the battery charged. Excess electrical output was then being put into the lights. I had not considered what you wrote. I look forward to a clarification by Mr. Wayne.
Quote from: MileHigh on June 03, 2012, 03:16:43 PM
Also, we should give a link to the "groaning video". Is that here? I personally saw it on PESN and don't know if it is local.
Thanks,
M.
Maybe user Microcontroller and Milehigh will stop posting here as wild speculations without having seen the actual
device does not bring us any further...!
Many thanks for your understanding..
Any further attacks of the inventor will be punished by me.
Maybe johnny874
can still draw a few better pictures when he has some time as the ones posted are hard to understand
and he seems to be the only one who has understood the full principle.
Please also use color in your biger drawings and let us know where the
water level is located in your drawings.
Many thanks.
Regards, Stefan.
Quote from: mondrasek on June 03, 2012, 05:11:45 PM
Yes, it was already stated by the inventor, that it is a generator powering the light bulbs from the internal hydraulic
fluids flowiing in the system and it outputs around 30 Watts what the Power meter shows !
You all should read before speculating wrongly especially user Milehigh who seems not to read or
seems to mix up things on purpose... !
Stefan:
No I am not mixing up any things on purpose. I can't remember all the details partly because the presentation is not very good.
I will respect your wishes and I am done with this thread. I am not 'attacking' anybody with my postings. There is a good implicit message in my postings about asking questions. I don't know why people seem shy or afraid to ask questions. There are probably 20 good questions that I asked about this proposition and they may never be answered. Just look at the example of the RomeroUK fiasco. If just one person had insisted that Romero showed the output voltage from the FWBR bus he would have been busted right there. Instead, nobody asked him that question and hundreds of people spent thousands of hours and thousands of dollars for nothing. Wattsup busted Romero when he analyzed his video clips. He found what I predicted that he would find. There is nothing wrong with asking questions, and even what would be considered tough questions are sometimes appropriate.
Quote from: hartiberlin on June 03, 2012, 06:06:52 PM
Sorry, but it looks like a big electric motor and a hydraulic pump to me, too. It's also not turning very fast, apparently. A slow, high-torque motor, controlled by a PWM controller, driving a hydraulic pump, can do a lot of useful work at low RPM. But a hydraulic motor driving a generator to make useful electric power --- will have to turn the generator shaft at a faster and relatively steady speed.
And there is more than thirty watts just in the _audio_ output power of that groaning monster!!
It would be trivial for the inventor to permanently put this issue to rest by a simple demonstration or a closeup with meters attached to the right wires. Will he do so? I certainly would.... if I could.
MileHigh's point about the compressed air is also very important. It is a stored power source, and if it has to be replenished for the device to keep running..... well, that's not good. Why can't it power its own air compressor?
I do not mean this rudley - but ask questions individually and not in a long list,
and please - not ones that have not already been answered by me or by the critics.
If you do not like the answer - asking again does not mean I am going to change them to fit into your parameters.
It was expalined to me the Heroic work done to uncover a fraud, and you have referanced that several times.
I am glad people were protected - my approach was to be completley open and honest to those who honored us enough to come and investigsate - last year when I released my work on this site.
That was a long and year ago, we have been reviewed.
What you look for now - that moment of discovery like where "insisted that Romero showed the output voltage from the FWBR" is long past.
We have been vetted, it was for our benifit - not yours - and one of the vetters - has spoken five times on the hope he has for our mechanical free energy and what it means to the world.
The only sin we have committed was denying this site the hero moment - well - it won't happen - because - we have been speaking the truth - period.
I said before:
We have been busting it to get our system converted to a Data collection model to "Verify and confirm the engineering models and expectations" and to "Provide the Data for the Scientific team preparing for our white sheets and journals."
I do not expect to even ask for an "investors" - without due dilligense - who would expect an investor to support an unsubstantiated claim - I do not. What investor is going to go to this site or any other to get approval?
Since The Travis effect made the first sustainable free energy machine possible - or at least at the moment:
Let me share with you the process and efforts required - notice that getting approval for an overuntiy web site is missing.
Let me share the process again: - no skipping, no cheating, all due dilligenses have to be done - (remember this when you say things like "if he had something - he would be running his house off of it" - those that call that logic - don't really have any experiance)
Genisis (Travis Effect) Years to discover.
Eureka (how the Travis effect works - according to physics)
Design (turn the discovery into a machine on paper)
Research and Develop system (engineering and certification)
Build working Input /out put system (table top simple system)
Build operational system (perpetual motion)
Feasibility (build Closed looped system)
Build Data collection model (scientific review and verification)
(We are here)
Alpha Model (scale ablility to demonstrate range of anomoly)
Beta Models (durability and sustainability)
Production models, manuals, expertise, and so on.
(all of this is very expensive - so the next time you bash an inventor for needing funding - think a little omg)
In closing:
We have a solid team of professionals - you have been reminded of that.
Some of them have spoken here, and you ignored them.
I understand you want to analyze the system - but you are too late, should have helped last year when I asked.
I tried hard to tell this web site my success last year - and I left politely.
I promised Stefan to return when we were beyound that level of ....bunk.
I have been insulted for my faith, my engineering, called a fraud, had improper drawings labled "Hydroenergy fallacy" accused of being greedy, accused of many things.
I pray that "the good intentions", meant to protect others from fraud - will be matured.
Opinons and slanders have nothing to do with good investigation - stick with the facts.
Ask facts - not slime laden comments with preassumed conclusions in the wording, and posistions of denial.
The fact is, you were all given private access to a real Overunity Machine..some of you got it, well done.
Good night.
@Wayne - great discovery.
Since there is much dissention here, hope you don't mind, but I've added some notes to your drawing to hopefully help clear up some of the issues.
This explanation assumes that there is 1 Ft of water above the cylinder tops, thus they can only move up 1 Ft with 185 pounds of force. The Travis insert is 2 Ft in length. It is in a precharge state, but after lift as shown in the bottom picture, the air is at the bottom of the Simple Travis Effect will be at the top and Travis insert bottom will be even with the bottom of the lift cylinder.
The notes I added show that Simple Archimedes required that 1 Cu Ft of air be forced down a total of 9 Ft (2 + 3 + 4) in water.
Simple Travis effect required that 1 Cu Ft of air be forced down 4 Ft in water.
Travis effect only requires .44 of the total force that Archimedes does but has the same lift. Also, the Travis side when using the same PSI, would pressures with air in less time then the Archimedes side, important as Horsepower is directly releated to time.
This is a good start, but it can be improved by increasing the Travis insert length to 2 1/2 feet. Now it only requires that .5 Cu Ft of air be forced down 4 Ft. So now, the Travis effect only requires .22 of the total force that Archimedes does, but still has the same lift.
The challenge now is that it can only move up 6 inches.
But by correctly adding another Travis Effect layer the lift height would go back to 1 Ft as each would lift 6 inches, but now with 370 pounds of lift.
If it was further adjusted so that the lift height of each is 3 inches, it would require 4 layers to lift 1 Ft with 740 pounds of lift. The Travis effect now only requires .11 of the total force required by Archimedes.
The other upside to multiple layers is that it make his buoyancy machine incredibly fast to pressurize and unpressurize while providing an ever greater lift.
This is with 144 square inches surface area, his current at 707 square inches is a monster.
Bottom line: It would help greatly, if more here would just try to understand the unlimited potential of the Travis effect and less on the working of the current system. None of us here, can hope to equal the combined engineering capabilities of the current team.
Larry
Quote from: TinselKoala on June 03, 2012, 09:06:57 PM
Hello Tinsel,
It is just a very poorly matched Hydraulic motor turning a windy nation generator yes - slowly
We have enough excess to use it -mismatched -for our data collection - yes - major losses.
"And there is more than thirty watts just in the _audio_ output power of that
groaning monster!!"
That is so smart lol - I did not think of that! - actually the sound was turned way up..
"MileHigh's point about the compressed air is also very important."
A little bit misleading - we do not have to add water or air a second time - as I have said - stop or start as many times a s you like - run as long as you like -unless you drain the system for repair or leak.
Air input is like this:
1/2 cf 2 psi
1/2 cf 4 psi
1/2 cf 6 psi
Thats it, once per side - never more.
No one swims in an empty pool - well - we do not have buoyancy without water and air.
Thanks Wayne
@mrwaye: Thanks for your prompt answer! Yes, nobody swims in an empty pool, that's for sure, and thanks for clearing up the point about the compressed air. A single charge that isn't depleted is OK with me, certainly !
I wish you luck and I await a full explanation of the workings. I admit that the explanations given so far don't make a lot of sense to me yet. I'm glad to see Mondrasek lending his analytic skills to the thread.
Can you point out, in the photos on the website slideshow, just where the power pistons are that convert the motion to hydraulic pressure? Are they the horizontal double-acting cylinders at the bottom of the big trusswork?
No, they are the ones up top of the ZED tanks, in the outside video - they are white (single rod)
And on the inside system - they are the Grey and black ones (double rod).
Very simple conversion of Lateral force into Hydraulic fluid under pressure.
Thanks Wayne
Well I just received my first update from the mailing list Mr. Wayne said we could all request to join. It came out late last night, 11:37 PM EST. In it he states that the patent is now online. Anyone able to locate it?
Thanks,
M.
Stefan,
This is what I think Wayne is attempting. The left side would use comprssed air to expand. When this happens,
the right side is lifted. This is when the "Travis Effect" would pump water/fluid tp power the hydraulic motor.
One thing I have come to understand about the Travis Effect is that it is a poor idea. By increasing the motion
or movement of a shaft, it's inefficient design is made to appear more effecient by placing an object in the
cylinder. Any engineer I know would use a hydraulic cylinder that has less depth.
Since air is compressible, this is what has the only potential to be taken advantage of. This is because air/gas can
be compressed or allowed to expand. There is nothing I have seen in the design that has something that attempts
to manipulate the air pressure by changing the physical volume of the cylinder. This would be about the only
opportunity to do so.
With Bessler's wheel, it uses compression to pump/move water/fluid in one direction. Overunity is achieved
because a lever can increase the potential of a mass. And since the weight/lever assembly would need to be reset,
the rotation of the wheel does this. With the basic example, a 2.2lb. or 1 kg weight 1/2 meter or 20 inches from
axis of rotation can be lifted/pumped or moved by a 1.1 or 1/2kg weight. And the 1kg weight can be lifted 37.5 cm's
while the weight performing the work (the lighter weight) only moves/drops 15 cm's.
It's interesting in a way but I don't think most people have worked with pressurized systems.
Jim
edited to change pics
Patent: http://www.faqs.org/patents/app/20120117957 (http://www.faqs.org/patents/app/20120117957)
Hello All, .
The key to understanding the system - or even the patent - is to understand the Buoyancy utilization of the "Travis Effect"
We spent five days trying to wade thru the claims by some that it was impossible to defeat the "volume" requirement of Buouyancy and that it was impossible to have the ability to capture more buoyancy than the mass of the object could float.
With those under our belt for most - you can then realize how the design of our machine operates.
The layering system as designed, has been tested and patented, it is a unique arrangment of the Travis Effect - Each Layer has the ability to capture the mass of the Buoyancy as if it were stand alone - that is why the effeciency increases with the number of layers.
The theory of decay has competition.... and this..... is a good thing.
Thank you for the questions.
Wayne Travis
I hope, everybody understands: A patent application (not even a granted patent) is no proof that it works. The patent office only checks whether something similar "was published" before. The patent office does not check the correct functioning of the claimed machine or process.
Nevertheless the patent publication gives us something to talk about.
http://worldwide.espacenet.com/searchResults?NUM=US20120117957
It still may be that crucial concepts are not included in the patent. Is this the case?
If everything is in the patent we can start a meaningful discussion. And Wayne could start to disclose meaningful data.
But as I know the world, he is bound by some money matters to keep secrets.
Greetings, Conrad
Quote from: conradelektro on June 05, 2012, 08:44:19 AM
Greetings, Conrad
Exactly, a patent don't mean shit! And doesn’t prove anything!
Conrad is correct,
Just a filing alone does not prove a machine works - I appreciate facts.
In our case, we supplied enough information to build a fully functional machine - that uses buoyancy in a uniques concept to provide net energy from the exchange.
I had to make a decision as the inventor - leave crucial information out - in an effort to undercut theft, to hide our true purpose (net energy), or to fully disclose -
My policy from the begining - and continues - to be completly honest. That decision to publish the patent - without crucial information left out - meant we had to have a very strong patent - close to $40 grand later - you get to read it for free - online!
Now we have things not in "this" patent - Sustantial improvements being covered under additional writing. which meant much more $$ (Please do not ask questions regarding those, I will not be discussing those until they are released as well).
Due dilligense - not becasue "money matters" - I have full authority in all matters.
The rules regarding patents makes it standard to prohibit such discussions until the process is in a released stage - as is the state of our core design.
Data release will be a business decision - We are sharing our work - not asking for approval.
Those with real curiosity - or able to get involved can contact me regarding that and other information.
mr.wayne@hydroenergyrevolution.com
Thanks Conrad for the clear and steady mind, it protects individuals.
Wayme Travis
Quote from: mrwayne on June 05, 2012, 09:17:01 AM
Conrad is correct,
Wayme Travis
Wayne,
I think aboiut the only improvements that would allow your device to work are what I am illustrating.
By using low pressure air to create hydraulic pressure, then a spring or even air can be compressed in an
attempt to close an expansion chamber. One thing that would help in this is if the pneumatic piston had a
spring itself could compress. Springs are an equal exchange item. As such, when compression occurs
from closing thew expansion chamber, there is some give in the high pressure air chamber.
Then when it is closed, the spring under the oneumatic piston would help to maintain high pressure air in
that chamber while it expqands along with the low pressure chamber. By having them both expand, the h.p.
more quickly of course would allow for more work to be performed.
Be that as it may, it is difficult to discuss engineering when a claim is made but there is nothing that supports
those claims.
Jim
For this device to be overunity it is required that more head pressure is available for boyancy than is present in the entire water head. That is clearly not possible with a single cylinder in either a simple Archemedian set up or the simple "Travis effect" set ups we have compared.
With this design Mr. Wayne has nested three cylinders. They all use the same water head. So to be overunity, the sum of the heads for the three cylinders must be greater than the single water head. Or in the picture below, B + C + D must be greater than A. That is clearly the case.
He has a workable overunity bouyancy device design. From the video's I would say he also has the devices built.
Thanks,
M.
Quote from: mondrasek on June 05, 2012, 11:24:28 AM
With this design Mr. Wayne has nested three cylinders. They all use the same water head. So to be overunity, the sum of the heads for the three cylinders must be greater than the single water head. Or in the picture below, B + C +D must be greater than A. That is clearly the case.
Thanks,
M.
M.,
Out of respect for you and Mr. Travis, I am going to quit following this thread after I point out one incorrect assumption in your previous post.
When B+C+D have a greater effect than A, energy is being lost. This is because the weight (110?) is trying to compress a hydraulic cylinder. Instead, it is lifting a column of water that does not perform work.
In the patent application, section no. 88, Mr. Wayne states that the static heads need to be recharged with air. I would have to believe this is the reason for the compression of the hydraulic cylinder occuring, not because of any effect.
The reality is that A would seek a balance with B+C+D dependent on their respective air pressure. The water columns would adjust accordingly.
@mrwayne,
What are the benefits of moving the water between the two ZEDs vs. moving the air to cycle the buoyancy force back and forth?
Thanks,
M.
Quote from: johnny874 on June 05, 2012, 01:28:07 PM
When B C D have a greater effect than A, energy is being lost. This is because the weight (110?) is trying to compress a hydraulic cylinder.
Sorry @johnny874, but there is no "weight" 110. 110 is the outside wall of the Outer Riser. I think you may be thinking that the rectangular area in which the numbers 188 and 162 are printed is a weight, but it is actually an open top cylindrical chamber.
The rest of your post is also unfortunately wrong in many ways. If you wished to understand better you may want to try rereading the patent.
M.
Quote from: mondrasek on June 05, 2012, 02:05:47 PM
M.
M,
Not sure how your post got to me with my having stopped all notifications.
It is okay, you can call me wrong, especially on this;
The differential air mass exchanger 102a may be connected to at least two units 101a and 101b, when additional work is added to one side of the differential air mass exchanger 102; the cylinder 216 travels in the opposite direction. The additional work can be supplied directly or mechanically. The differential air mass exchanger 102 is utilized to control the speed of the pre-charge and cycle/stroke of the apparatus
Read more: http://www.faqs.org/patents/app/20120117957#ixzz1wwuUjVcO (http://www.faqs.org/patents/app/20120117957#ixzz1wwuUjVcO)
It's the 2nd half of 0088. I did not write that. Air pressure is controlled by something other than the mechanics being cited.
It seems I did read the patent. This is why I designed something where the manipulation of the air pressure comes from manipulating the volume of the cylinder through mechanical/haydraulic and pneumatic means, but using no air exchangers.
Just a flow path where each individual item can be understood on it's own terms as to energy consupmtion and work performed. But as Mr. Wayne posted, they are adding more complexity to this device. I believe it is as I posted earlier,
It seems the more complex something is, the less likely it is to be genuine.
Jim
edited to add; it looks like 104 is the outer wall. 110 seems to be something that occupies the space on top of various riser sections. Like the weight Mr. Wayne used in his aqurarium demonstration.
Jim,
The three buoyant section, 1. the Pod, 2. the Inner Riser, and 3. the Outer Riser all move upwards due to buoyancy and drive a hydraulic accumilator attached above. The motion is controlled by balancing the air pressure through the differential air mass exchanger. The differential air mass exchanger is utilizing a portion of the energy that is stored by the hydraulic accumilator. Each upstroke of a ZED produces more energy than needed to cycle the differential air mass exchanger. So air pressure is 100% being controlled by the mechanics being cited.
Later on in the patent you can read that an alternative way of cycling the buoyancy between the two ZEDs is to move some of the water instead of the air. I believe there may be some advantage to moving the water vs. the air and hope to hear an answer. Might just be economics. The differential (water) mass exchanger is cheaper and has fewer wear items I think.
Thanks,
M.
Quote from: mondrasek on June 05, 2012, 04:38:23 PM
Jim,
Thanks,
M.
Did a quick check on no.110, he is mixing in the "pod" which floats with other systems. None the less, it is still a weighted float.
The prime mover in the what's his name Effect. Also, you failed to mention how water rising outside of this system performing no work creates an advantage. Seriously, if you or Wayne Travis wish to discuss engineering, I am all for it.
But what is being presented fails to address a flow path of cause and effect which can demonstrate a potential gain. Complicating the system is akin to cooking the books in accounting. Just create phoney off shore accounts and no one can follow all the transfers. Enron did it until tthey had to pay the bills.
D@mn me if you will, but pretty soon I'll start coming off as credible for supporting Bessler's work which can be considered using cause and effect and action-reaction. Simply put, I do believe he cheated the laws of physcis by having gravity drop weights twice. Of course, in a rotating wheel, this is possible :D
Once when the are moving upwards and then again on their way down when they are performing work which keeps the wheel rotating. You see, his weights cancel each other out until you consider f=ma. That means it takes energy to rotate the wheel. Simple, just the way I like it.
edited to add;
A quick video showing water is displaced when placed between 2 surfaces. Something I have discussed for the last 2 years or so.
By using a tube, the fluid and it's characteristics can be controlled. This simply means that it can be pumped from one pump to another as the wheel rotates.
And what Bessler realized was that using leverage allowed for more work to be done. This simply means that more fluid could be pumped than what the weight alone could do. And the weight is reset because as the wheel rotates, it drops when passing top center. This allows it to fall again when it is primed (has fluid ready to be pumped).
http://www.youtube.com/watch?v=chyOzgkaDkg&feature=youtu.be (http://www.youtube.com/watch?v=chyOzgkaDkg&feature=youtu.be)
Jim,
If Mr. Wayne's device can work, and the energy gain is from buoyancy, that means the prime mover is gravity I believe. Now gravity is understood to be a Conservative Field of Force (like that of a magnet) and therefor thought to be unable to do work. If this is untrue, and gravity *can* do work, then Bessler's wheel would also have to be reconsidered by many as a possibility.
I wish you the best of luck in figuring out how Bessler did it! I really want to know.
Thanks,
M.
Quote from: mondrasek on June 05, 2012, 01:28:26 PM
@mrwayne,
Thanks,
M.
Very good Question - To create our buoyancy - we essentially raise the water level (increase the head) - at the same time the other side is lowering - the output force from the floating Zed is converted to Hydraulic production - which in a three layer system is barely over unity (regarding the up stroke).
Now the raised head is still in the Zed after the hydraulic fluid is captured.
The energy stored in that head is transfered directly to the other Zed - That energy subtracts from the input cost of the upstroke - guess how much?
In cycle - it happens each direction - or twice a stroke.
Wayne
M
As you said, if.
With Bessler, it is about recognizing what someooe has done.
Jim
M.,
Hello Johnny,
Thanks for being respectful.
What you are refering to as a Hydraulic cylinder is an inlet tube.
What you are refering to as a weight is a empty bowl.
Sorry - patent drawings are not clear.
Section 88 as refered to - is for shut down and venting of pressures and lock out - as it follows, returning from a lockout tagout scenerio - the system would need reset, recharged.
This is not the case during run - just during a maintnence type shut down - as with any energy isolating and removing condition.
Wayne
Quote from: webby1 on June 05, 2012, 03:24:05 PM
Tongue in cheek question:
How much buoyancy can you get from a cup when the water is on the inside?
None
How do you move the water from the inside to the outside?
Air pressure
Actually webby,
The "Travis Effect" works up side down as well - let me explain.
If you attached the inner displacment (like the concrete that Tom showed) to the ceiling (rigid) and then placed a cup around the block (right side up) and then placed a scale under the cup - and filled the gap between the block and the cup with water - instead of Air - the down ward force is equal to the total mass from the top of the water level to the bottom of the cup.
The force pushing down on the cup is equal to the head pressure x the surface area -
The mass (block) suspendid from the ceiling acts as a mass discplacement -
Fun fact.
Wayne
Hello Johnny,
A very simple flow path -
I am suprised by your comments.
The inner system of layers is not pushed down as in your video -
They are held in place by resistance from a production cylinder - the water (or air) - increases the head pressure - which increases the air pressure - the air pressure acts upon the surfaces creating an upward force which overcomes the resistance of the production cylinder.
When the prodcution cylinder is over come - the production is split two ways - to supplement the next half stroke, and to run the generator -
After the stroke length is achieved - the head pressure is transfered to the alternate system, which then uses the pre supplied production + ( plus) the head pressure to stroke again.
(the lowering syetem is refilling it prodcution cylinder on the down portion of the stroke)
and the production is split again for the next half stroke.
Over and over - it is very simple.
You see - head has stored energy, and the compressed air - has stored energy - we do not consume those - we just supplement the transfer from side to side (Zed to Zed)
p.s It is the "Travis Effect"
Thanks Wayne
Hello mrwayne,
thanks for your time and input. I really hope it's not a scam and
your going to succeed to put a working system in the market.
I still have problems grasping the travis effect so I drew a picture of how I understood the
downward travis effect and I would like your opinion.
Is it utterly wrong or is downward pushing force not equal to weight?
All the best,
Prato
Hello Prato
Yes, only fix the "block" with a solid connection. (it could float up - and confuse things)
The Block - or mass displacement does not have to be concrete - you just need to create the flow path so that the small volume of water becomes head pressure.
In buoyancy - the head pressure is converted to air pressure which acts against surfaces -
In hydro pressure - as you have drawn - the head acts directly against the surfaces. same forces - opposite capture method.
Well Done.
(the point on the lack of need for concrete - if the block were hollow - you would see it as buoyany too)
edited to add;
Okay, I get it now. You use an air pump to increase the air pressure in "A" to
lift the block. And when you bleed the air off, it allows the block to compress air
in "D" to create hydraulic pressure.
With what I drew, there is the high pressure area which is the source of energy
for the low pressure area which performs the actual work. As my drawing shows,
only 2 areas are needed. And how any pressure change occurs is observed at that
location.
I think using an air manifold and an air pump really makes it difficult to believe
your system is self powering.
Jim
edit;
Not sure how to put this Wayne, but I think you complicated your idea to such an extent that you probably can't follow it yourself.
Wayne,
Could you make a list of all "add ons" that peform work.
You know, any motor, pump, etc. ?
The difference between my designs and yours is that I
use mechanical means which can be tested independently.
And as I mentioned, creating a static head is not overunity.
It has to be shown how the system can be reversed without
expending any energy to do so, or less than what the system
develops. You don't show this at any time.
You see, when your weight drops, it does create hydraulic
pressure. It also takes an equal amount of work to lift the weight
back to it's original position. This is why I think you use an air pump.
Other wise, your 2 sides would balance each other out in a neutral
position.
Jim
Wayne,
If you would like to do something that would make a difference in the world, give Bessler a thought. Sure there
would be no "hero" moment, but is that really necessary ?
As has been "discovered", a 12 ft. (3.8m) Bessler wheel could generate 400 watts of electricity. With 5 wheels,
that would be 2,000 watts of power. Would that make a difference ? For humanitarian purposes, it could be huge.
Why ? not everybody has running water or even a source of water that doesn't require effort, you know, getting
water from a well. Of course, there are people who would pursue such things with an open source free energy
invention. I know of one person who lives in Egypt.
With me, I like Bessler's work and think he is someone I would have liked to have met. I think a lot of people
will be fascinated by what he knew and did. And at the same time, it would have the added benefit of allowing
some people to help others.
But as I let Stefan know, I will need another surgery. I have an appointment on the 14th and until my situation
is resolved, if I'm not capable of working for my employer, it's best I not build either. As frustrating as that is for
me, it is something I need to accept.
Jim
edited to run spell check
edit;
Hello Jim,
Thats funny...
Wayne
Jim
Hello Jim,
I have no idea of your system - so comparisons are confusing, and good luck.
Again, thanks for your input - when you do understand our process - I hope you are as excited as we are.
Good Luck on your pump.
Wayne
@mrwayne,
I noticed you are also answering questions and disclosing more info over at PESN. Are there any other public forums where you are also active on this subject? I'm just not wanting to miss anything.
Also, I noticed a forum login on your own site, but no sign up. So I assume that is not public. Is there any way to get access to that?
Thanks,
M.
Hello M.
I actually answer private questions first.
I comment on both of the new releases Sterling has added to his site.
And Stefan's site.
I do not use the forum on my web site - just e-mail and phone calls.
Many of the same people visit all three - I have seen the "Travis Effect" show up many places - but I currenlty only have time for the three, I authorized.
Wayne
Wayne,
The patent diagrams have done much to clear up the system process comments in your previous post. It also proves, that as you stated, you have been completely honest in your post. Thank you, this has not always been the case here, and it may restore faith in some.
Your post have given the impression that the overunity is coming from the air pressure in the lifted ZED to supply half the pressure to the other ZED for precharge. This makes sense at a base level, but I don't see how to mathematically solve it.
'Do not forget - We prove it on paper using simple and also complex physics. (note to future free energy inventors - if it does not work in the simple math - it will not get better in the complex).'
Can you show the math proving the overunity?
Larry
Quote from: LarryC on June 06, 2012, 12:49:29 PM
Wayne,
Larry
Hello Larry,
I have a meeting in ten, so I will say - this is a good question, and I apprecaite your logic and wisdom.
Staying honest it the only way to go. Sorry about those that do not hold that value.
I will answer later - I am not a engineer so my answer will be in - inventor - test and rest type language.
Thank you Wayne
Quote from: mrwayne on June 06, 2012, 12:06:33 PM
Jim
Hello Jim,
Wayne
Wayne,
Unfortunately I do understand what you are trying to do. I would say you are in a state of denial.
You spend a lot of money and put a lot of work into something and it doesn't work. Something it
seems you are having trouble accepting. Spending more money further complicating it won't get it to work.
I wish there was someone else who could get you to understand this. Using an air pump to increase
the "bouyancy" effect is basically converting air pressure into hydraulic pressure. There is nothing in your
system that amplifies the potential for work to be performed.
Maybe one day you'll understand being a part of something is better than being on top of the mountain.
Jim
Quote from: johnny874 on June 06, 2012, 01:14:32 PM
Wayne,
Jim
Once again,
We do not use an air pump - (after initialization)
It is not denial my friend -
What 'you' think we have - your are right - but what we have 'you' do not understand.
Wayne
Quote from: mrwayne on June 06, 2012, 01:26:29 PM
Once again,
Wayne
hi Wayne,
how many cycles it can run until the next initialization?
Alex
Once again,
Wayne
Wayne,
You have intentionally misrepresented yourself in this forum. That is plain wrong !!!
To wit, you have a provissional patent. This is not to be confused with an actual patent.
What are the differences ? Namely a provisional patent requires no examination which you claim to
have been subjected to. Seriously, lying like that is not good. Would you like me to show you the post ?
A provisional patent costs $110 and is given just for paying the application fee and submitting a 2 page form.
The purpose of a provisional patent is to help inventors who might wish to market their invention while having
the protection of a PROVISIONAL patent. It requires no patent search, examination or any demonstration of
being an actual invention. The inventor(s) is given 1 year from I believe the filing date to convert the provisional
patent to an actual patent which would require going through the complete patent application process which you
claim to have done. Shame on you !
If your device works as claimed, after initial operation, disconnect the battery. That is the only proof you need
and yet have failed to post a video showing that your invention generates enough electricity to power itself.
And any excuse you make (baseless claim) will mean you want something. What was it you posted ? With a patent
and being able to generate sufficient power to have a new and valuable source of energy would make you quite rich.
edited; not quite rich, you would be thanking God for the great things you are doing ;edited
Who knows, maybe your ego and greed interfered with good judgement.
Still, prove me wrong and disconnect the battery. A simple request.
Quote from: mrwayne on April 11, 2011, 05:12:34 AM
Conrad, very well said.
If you would like to see my working device - you are welcome to come on over, I love sharing the discovery, No one has gone away disappointed.
As far as experience of so many come and goes........ is that not with every attempt at innovation.
The process of discovery if full of failures, measurement errors, misguided at temps, and over optimistic claims.
When someone does hit it just right, like the "intermittent windshield wiper" .....no one worries anymore about the effort it took, the diligence it required, the tenacity to not give up. And yes, a big company comes and gobbles them up.
I wonder how many truly great ideas have went away from a need to fund, or to get people to listen.
I do not claim to have all the answers to the problem, but I do have a very over unity device.
A very good point you made: "Bigger"
When I built my first attempt - it was a "full scale bucket brigade" with modern improvements - that was before I truly understood how buoyancy worked - I have Photos. I learned a great deal with hands on and practical application.
(I am on design number seven - and it is works very well) I would say that I am an expert on what does not work, as well :)
One thing I heard from critics, and have confirmed with my physical research is that if it does not work on the small, it will not work on the big - (with a little disclaimer - your drag in a over all system does not reduce at the same rate as you can reduce the design).
And in functionality - if drag is going to be an issue - your machine is not worth the effort to build.
My models 5 and 6 were also over unity, (125) those designs each had four energy conversions, at the end of the day - the only thing I had to "sell" was $300 worth of electrons (a year) from a $35,000 dollar machine.
Very much a waste of time, my goal has not been to disprove the laws of physics, but to build a system that produces in an abundance.
I am going to post this chat, and go back to explaining my system.
Thank all of you for the interest. It is en courageing.
Mr Wayne
>> When someone does hit it just right, like the "intermittent windshield wiper" .....no one worries anymore about the effort it took, the diligence it required, the tenacity to not give up. And yes, a big company comes and gobbles them up. <<
I saw the movie, can't remember it's name. The guy made like $30 million on his invention. How is this being gobbled up by some company ?
He had patent protection and sued for violating his rights to his patent. The issue the motor companies had was he wanted to manufacture them himself. It was his greed which created the initial problem. He was an engineer and had no manufacturing experience.
Most people would've been glad to have licensed their invention, make the money and let someone else do all the work. He pretty much showed the wrong way to go about things when you realize an invention.
Need to stick with verifiable facts Wayne. I will look for more disinformation in your posts as time goes by.
Jim
edited to add; The movie was called Flash of Genius
http://en.wikipedia.org/wiki/Flash_of_Genius_(film (http://en.wikipedia.org/wiki/Flash_of_Genius_(film))
Quote from: johnny874 on June 06, 2012, 02:57:03 PM
Wayne,
Johnny,
False. The provisional application filed on Nov 9,2010 is under the
Related S.S Application Date section of his standard Patent Application which was filed Nov. 9, 2011 and approved May 17, 2012.
You seem to be just looking to spin any point to attack Wayne.
Larry
Yes, please Jim. You are making a lot of false and slanderous statements. I am not sure if you just do not understand or have some malicious intent. But your conduct is becoming less and less professional and respectful. Please try and reread the patent and try to fully understand the principle. Nothing in Mr. Wayne's Zed is moving due to pressure in closed vessels like a classical hydraulic or pneumatic cylinder. The motion is in an open top system and happens due to buoyancy. It is buoyancy that is being utilized in a unique configuration.
M.
Quote from: telecom on June 06, 2012, 01:52:29 PM
hi Wayne,
Alex
I know this is repeating, I presume you have not read the whole thread - no problem.
Initialization is simply filling the system with the water and then adjusting the "head" with air into position for continuos run.
How many cylces? - Until Mechanical failure -
The system has "no" external inputs once set up, and can be stopped and restarted with a single button.
(as many times as desired).
Wayne
Quote from: mondrasek on June 06, 2012, 04:10:28 PM
Yes, please Jim. You are making a lot of false and slanderous statements. I am not sure if you just do not understand or have some malicious intent. But your conduct is becoming less and less professional and respectful. Please try and reread the patent and try to fully understand the principle. Nothing in Mr Wayne's Zed is moving due to pressure in closed vessels like a classical hydraulic or pneumatic cylinder. The motion is in an open top system and happens due to buoyancy. It is buoyancy that is being utilized in a unique configuration.
M.
M.,
Nothing false about the guy who invented the intermittent wiper making $30 million.
Wayne claimed that large companies gobbled it up.
And here is a link to the USPTO web site and provisional patents. You'll find I have
researched this before which is why I know about it and what it requires. I learned for myself, so if Wayne wishes to say the USPTO is wrong, he can.
http://www.uspto.gov/patents/resources/types/provapp.jsp (http://www.uspto.gov/patents/resources/types/provapp.jsp)
Wayne,
(Correction) - Johhny, you have move from negativity to attack.
We filed the Provisional in Nov 2010, the conversion to a full patent in Nov 2011, and the PCT.
I have the Letters from the patent office and Numbers - you might be confused?
Lets be clear on one point - I may make a spelling error - or mix up a number - or use the wrong symbol
But you have just accused me of lying - Untrue -
I have spent nearly $40,000 for the very best Patent searches - Provisional patent, Conversion, and PCT.
Please be careful with your charges.
I understand a mistake has been made here on your account, your joy in the charge is dissapointing.
Stefan - please handle this.
Wayne
Quote from: mrwayne on June 06, 2012, 05:10:43 PM
Larry, you have move from negativity to attack.
Wayne
Wayne,
Saying that you're protecting your investment because you don't want to be ripped off like the guy who invented the intermittent wipers is not a typing error.
And >> I have spent nearly $40,000 for the very best Patent searches <<
http://www.uspto.gov/web/offices/ac/qs/ope/fee092611.htm#search (http://www.uspto.gov/web/offices/ac/qs/ope/fee092611.htm#search)
Unfortunately, the USPTO charge fees for doing the search. Doubt you could spend $40,000. Anyone can check the link. $620.00 is the highest search fee they charge and that is for a utility search fee which is probably what you would have needed.
When I have tried to discuss engineering with you, your only answer has been that I do not understand. Yet you won't disconnect the battery which you claim is only used to operate the air pump when you initialize your invention. And this suggests that it is what's responsible for what you claim to be an overunity device.
Jim
Quote from: johnny874 on June 06, 2012, 05:23:18 PM
Wayne,
Jim
Johnny,
Our patent attorneys are top notch.
The Battery question has been answered.
You decided the intermitten windshied wiper guy was robbed of money - that is not my focus.
The point of his battle was not the money - but that a scoundrel back by big bucks - claimed they invented it. Did you watch the show?
I have spent to much time - trying to show you respect - as you continue to disrespect our work.
And you are still in my prayers, for your health, the surgery, the Job, and your heart.
Good Day.
Wayne
Quote from: mrwayne on June 06, 2012, 05:39:49 PM
Johnny,
Good Day.
Wayne
Wayne,
I did watch the movie. That is why I wondered about a lot he did.
I have let Stefan know that I am hoping by this weekend to have a demonstration of what Bessler knew 300 years ago. I think it is something everyone will understand.
Simply put, it will be straight forward and will not need an explanation. This si why one critic of Bessler's said it was so simple, a child could build it. He was ridiculing Bessler for being successful.
About the intermittent windshield wiper guy, you are the one who said big companies gobbled it up, I showed your post. I said he made $30 million.
I think this is why we can't be friends.
>> The point of his battle was not the money - but that a scoundrel back by big bucks - claimed they invented it. <<
It was about money. Either that or he was a control freak who wanted to play King Midas or something. After all, he wanted Ford to supply him with the funds to manufacture it and then sell it back to them at his price. That is what he wanted, that kind of control.
This is what I like about Bessler's wheel, I think it's a cool part of history.
And this is why I hope once I demonstrate how he did it that you stay out of it.
Jim
Jim
40k is for the Atty to do the search. I dont doubt it. ;] They have the experience in doing so. I did my own search for a simple idea. I spent a lot of time doing so. But I didnt have to pay any fees at the time either. ;]
Mags
Quote from: Magluvin on June 06, 2012, 06:43:49 PM
Mags
I was also thinking the $40k included the fees to the Atty's to *write* the patent. It is very detailed.
M.
Mags
Every time I use spell check it deletes my post -
Hello Mags,
Not for 'just the patent search' - Those were my fee's so far - we still have much more to go.
I also did my own search - when it came time to really sink my life into this, I had to make sure I was not treading on others work.
Thanks Wayne
Opps gotta run
Quote from: LarryC on June 03, 2012, 09:23:42 PM
Larry
Hi Larry,
you kindly provided a great explanation of the principle, and I was able to follow it up to this point.
But now, can you please expand on how to correctly add another Travis effect layer?
BTW, it just has occurred to me that air can be replaced by a liquid, oil for example. Pumping liquids is much more efficient than pumping air, could add up
to the efficiency of the device.
Alex
Quote from: mrwayne on June 06, 2012, 04:52:08 PM
For those that don't know,you can click on the mrwayne name in the left most area. This will bring you to the mrwayne screen, where you can click on the show post option and get a list of all of his post.
Larry
Quote from: mrwayne on June 06, 2012, 08:33:53 PM
Hello Mags,
Thanks Wayne
I was just guessing. ;] Im sure there are much higher prices than 40k for some patents, and some less, search n all. I could only imagine.
Do you only have 1 pat. ?
Mags
I have physics/mathematical proof that harnessing "the Travis Effect" (AKA Archimedes' principle) can't generate energy that I posted over @ PESN:
Higher water pressure means lesser volume of air which in turn means higher net density which in turn means lower uplift. System where water exerts pressure on air (open chambers / flexible seal) is less efficient than a system where the chambers are completely enclosed so water cannot compress air at depth - so let's use closed chambers(cups) to maximize efficiency:
Quoteg = 9.80665 m/s^2;
Ï(empty cup) = 7850 kg/m^3 (carbon steel - using advanced alloys (1800 kg/m^3), you can get slightly better efficiency);
Ï(water) = 1000 kg/m^3;
Ï(air) = 1.2041 kg/m^3 (at 20 °C and 101 kPa);
V(air/water) = 1.0552 m^3, r(tank) = 0.63156 m (sinking tank);
m(air) = V(air)·Ï(air) = 1.0552 * 1.2041 = 1.27056632 kg;
m(cup) = V(empty cup) * Ï(empty cup) + m(air) = 0.18 * 7850 + 1.27056632 = 1414.27 kg;
m(displaced water) = 4000 kg;
d(cup) = 0.96 m;
d(tank) = 6.2231 m;
F(cup) = Fb - Fg = (4000 - 1414.27) * 9.80665 = 25357.35 N;
W(cup) = F·d = 25357.35 * 0.96 = 24343.06 J;
1) Using heavy tank, using energy to lift:
m(empty tank) = V(air)·Ï(water) - m(air) = 1054 kg;
W(tank) = m(empty tank)·g·d = 64323.26 J;
2) Using light tank, using energy to sink:
Fb(tank) = (V(air)·Ï(water) - m(air))·g = 10336.1037 N;
W(tank) = Fb(tank)·d = 64322.6 J;
3) On-demand air compression:
W = pB·vB·ln(pA / pB) = 151584 * 1.0552 * ln(101325 / 151584) = 64429.52 J;
where pB is water pressure @ 5m (151584 Pa), pA is ambient air pressure (101325 Pa) and vB is the compressed volume;
P.S.:
without the piston/insert, the device would require about 4 times as much energy (over 244 kJ) each cycle which means less than
10% efficiency.
P.P.S.: too bad you can't just magically turn the buoyancy on and off without energy, it would work very well then ;)
(actually, you can turn it off easily, but then you consume energy to turn it on again, and vice versa)
Quote from: KanShi on June 07, 2012, 04:31:17 AM
P.S.: without the piston/insert, the device would require about 4 times as much energy (over 244 kJ) each cycle which means less than 10% efficiency.
Hello Kanshi,
This looks just like the post from another "user" early yesterday and then again under your name - on two of Sterling's links.
As I demonstarted in long detail on that site - your application do not correspond with our system.
To be very clear - We have built several fully functioning models that have been tested, third party.
It would be better to spend your time understanding the system - and impacting the world.
Thanks Wayne
Quote from: mrwayne on June 07, 2012, 08:35:29 AMAs I demonstarted in long detail on that site - your application do not correspond with our system.
Can you or one of your engineers point out
exactly where the equations do not correspond? Because the equations support exactly what you show on those "Travis effect" videos, they just don't support your claim of overunity for the whole device.
Quote from: KanShi on June 07, 2012, 09:55:36 AM
Can you or one of your engineers point out exactly where the equations do not correspond? Because the equations support exactly what you show on those "Travis effect" videos, they just don't support your claim of overunity for the whole device.
Please take time to review the Patent - not the simplified Travis Effect.
Wayne
Wayne,
Not to be yanking your chain but a couple of things to consider.
1) by lifting a cap, it's stored energy's release can be controlled
2) a slightly lower pressure and higher volume can perform more work
3) the hydraulic converter to rotation can act as an expansion chamber reducing useable pressure
4) back pressure reduces efficiency (hydro-electric generators have no back pressure)
5) lower pressure/higher volume around the outside of a fan type blade might be more efficient as it generates more torque
6) line pressure can be converted from high volume/low pressure to low volume/high pressure by using a convergent-divergent nozzle.
Of course, one day I may take the time to learn engineering.
Quote from: telecom on June 06, 2012, 09:50:19 PM
Hi Larry,
Alex
Hi Alex,
Lets call this the complex Travis Effect and much harder to explain.
I recommend that you first look at Travis post #6 on Page 1, then Travis post #15 on Page 2.
#6 helps to understand how the layers increase the head pressure and #15 has a section on how the system is precharged.
I,ve attached patent fig 14,15 and 18 showing half of the vessels next to each other with the water colored in to improve visibility of the water before precharge (14), after precharge (15), and after lift (18).
This precharge technique is very unique as it would seem to require less input cost than by standard methods. I can't prove it does, but the fact that Mark Dansie is on board has convinced me that it works. Mark is one of the top free energy skeptics in the world and debunked many free energy devices all over the world.
Hope this helps,
Larry
Quote from: LarryC on June 07, 2012, 11:43:15 AM
Hi Alex,
Hope this helps,
Larry
Hi Larry,
I just want to point out, that in your first diagram ( post 197) you could picture the Archimedes vessel not vertical, but horizontal.
In this case the total work to charge it with the air would be smaller, equal 3cu ft x 2 feet.
On the surface it appears that Travis effect still takes less energy than Archimedes, but IMHO it only can lift because the air is pressurized , which , unfortunately, requires energy.
If we replace air with a light liquid, such as oil, it will be evident that Travis effect is not working at all - nothing can be lifted.
Again, the lift is done by the pressure in the compressed air.
I think it is pointless to look at the complex Travis effect if simple Travis effect doesn't hold the water.
@Travis,
In Fig 5B the water level in the pod only appears to have gone down 10% and the water level outside the pod has gone to the top. Is the drawing accurate?
Thanks, Larry
Quote from: telecom on June 07, 2012, 12:20:48 PM
Hi Larry,
Hello all,
I am sure you are all aware that we are looking at only a portion of the system, so it is understandable to draw such conclusion.
Here is what I realized when I first noticed the "Travis Effect"
First - the minimal amount of volume it took to begin lift of a certain weight
Second - the speed at which buoyancy could be utilized
Third - that venting and refilling was not necessary to to change the force of a submerged object
Fourth - the relationship to the Work being done was not limited to one direction
I combined those discoveries - and turned them into the patent, the working models and every step of our process - conforms to standard physics - except the entropy notion that mechanical free energy is impossible.
Thank you for your comments.
Wayne Travis
Uh, Wayne,
I talked to God. She told me to give you a simple hydro-generator idea that can work so I can enjoy building my Bessler wheel.
I don't like you, but do want to enjoy my own life.
This idea is quite simple so it might be over your head. I did go to school for stuff like this and thanks to God who gave me a hearing loss, I have had much time to learn about such things. After all, who wants a family when they can spend their time learning engineering, right ?
This idea is that the staic head on the left is pumped into a chamber with a vacuum measured in hg's. For people who have no engineering background, hg's is pronounced inches and is what vacuum is measured in. A vacuum is a pressure below 14.2 psia (pounds per square inch absolute).
At 33 ft. or 9.8m's, a mass of 1 lb. or 1 kg. would have twice the pressure at the bottom of the static head. Any diver would know this, even my brother Paul who did diving for free for the Coast Gaurd. Talk about breaking the rules, he should have been court martialed. He is a strict by the book kind of guy.
The trick is, when pumping water into a vacuum, you are not going against atmospheric pressure. Even at 7.5hg's or 7 psi, a net force of 3.5 psi can be realized. And this simply by using the water in the open side (open to the atmosphere) creating an air tight seal that maintains the vacuum while the water flows.
This is where area to lift vs. pressure comes into play to prevent a static head in the vacuum chamber being of such a height it becomes unworkable.
This is something that can work because it would be manipulating the pressure difference between a constant vacuum and atmospheric pressure.
If you choke on this Wayne, it's okay with me. But as Alex posted, if it doesn't work in the simple, it won't work in the complex. And with this, it's components can be tested for under $100.00. I know, you can't afford something that cost effective.
Now I can enjoy my build which I have spent several years on. It's how I roll, like Bessler 8)
edited to add; correction, a complete vacuum is 30 hg's (inches) or 0 psia. 15 hg's of vacuum is equivalent to 7.1psia.
Was thinking to let it go and see if anyone caught my mistake. It's engineering and something probably everyone in this thread should know.
But who would have thought that a vacuum could perform work ? I mean besides Nature who abhors it.
Quote from: LarryC on June 07, 2012, 12:35:58 PM
@Travis,
Thanks, Larry
Hello Larry - what you have in those three drawings - it the action of using "Air" to move the water - to create the head in the system.
5A - no air yet, 5B Precharge air, 5C stroke
In 5b - you see the quantity required to go from sink to full float - Now since the resistance is overcome - as you add more air - the system moves higher - it makes it appear that the water level satyed the same in the next example.
P.s. We built the air moving system as drawn and the water moving system - the water worked much much better.
Dear Johnny,
After reading all your posts, I have to say.
Wow,
You are really smart, you should go to the Bessler page and teach everyone.
Thanks for the info, it will come in handy.
Wayne
wayne
tnis part of the forum is for gravity power,
your system is mechanical, it is disruptive to this part of the forum,
Quote from: johnny874 on June 07, 2012, 08:28:30 PM
wayne
What force does buoyancy work against John? :o
Mags
in Wayne,s system, it is purely mechanical.
edited
with hydraulic pressure. input equals output.
Quote from: johnny874 on June 07, 2012, 05:35:55 PM
Uh, Wayne,
So you’re saying this system will work?
I’m assuming you haven’t built this in real life, have you?
Looks a lot easier than building your Bessler wheel.
Could you make some more drawings and explanations?
Either send me private message or start a new thread, should probably not post it in here.
Thanks! :)
Quote from: johnny874 on June 07, 2012, 09:24:11 PM
False. Mr. Wayne's system uses BUOYANCY. Buoyancy is the result of gravity acting on fluids of different densities! It is gravity that causes the pressure differentials. And gravity is free, get it?
Here you are correct. With traditional hydraulic systems buoyancy is not part of the equations and you have no mechanism for a gain to create an apparent overunity system.
Thanks,
M.
There is no doubt that I need to spend a lot more time trying to understand this thing. Based on what we are told , I accept that this works, and that it is overunity. I am impressed with Mark Dansie`s opinion . I think that more people, including me would understand and be impressed if a simpler way of explaining this can be found. I believe that the hydraulics is not essential to the device being OU, and is just a convenient form of power transmission.
I understand that in its basic form, the Travis Effect can not form an OU device on its own, so the "layer effect" is used- several basic units in series so to speak.
You could be the best driver in the world, but that does not make you a good driving instructor. Mr Travis obviously knows more about this machine than anyone on earth. But perhaps someone else is better equipped to reach the rest of us. What we need is a set of diagrams, incorporating a simple Travis device, showing how it could be made to do work operating a teeter totter [see-saw].
Double posted: Please see below.
With hydraul pressure, it ir not possible to create another static head that has greater pressure without a corresponding drop in the static head.
Work will always equal mass times distance.
His increased lift is because of lower pressure. He can install 2 pressure gauges in neighboring layers and see this is what is happening.
Jim
All,
Mr. Wayne's invention utilizes the effects of buoyancy. Buoyancy results only in a field of Gravity. Any Force generated by buoyancy is fundamentally different from Forces generated in standard pneumatic or hydraulic systems. Here is a few examples why:
Gravity is a (field of) Force that only acts normal to the surface of the Earth (pulls things towards the center of the Earth). Because Mr. Wayne's device relies on Gravity (buoyancy) it only works if the Zeds are normal to the surface of the Earth (standing up). If you tip the Zeds on their side, they would no longer work. A pneumatic/hydraulic cylinder will work in any orientation.
Gravity is a (field of) Force not found (strongly) in space or in Earth satelites such as the International Space Station. Because Mr. Wayne's device relies on Gravity (buoyancy) it would not operate on the International Space Station. A pneumatic/hydraulic cylinder will still work on the International Space Station.
Many Engineers are not intimately familiar with buoyancy. This was the case for me before studying Mr. Wayne's device and the "Travis Effect". You need to understand buoyancy, Head Pressure, and pressure differentials created by gravity to understand the operation of this device. You cannot understand it if you are thinking this is a pneumatic or hydraulic device that is independent of gravity and buoyancy.
Hope this helps.
M.
Edited to add: Sorry for the double post.
OK Guys and thanks for your help. My problem at this stage is as follows. Take the simple Travis effect . As soon as the Travis vessel lifts a short distance, the effect is lost. We can not overcome this problem by making the displacer block rise with the vessel . So how exactly do we overcome this problem. Is it by restricting the vessels rise to a short distance ? Is this why we need multiple vessels , or layers?
Just suppose that instead of driving a generator, we wanted this machine to drive a winch , raising a weight. Could we replace the hydraulic system with a purely mechanical system, in theory at least?
@neptune,
I believe the "Travis Effect" is important to understand only because most think that buoyancy requires a large volume of air (or other lighter fluid) to be pressent in the buoyant device in order to achieve large buoyancy Forces. It does not. Only the height of the water (head pressure) on the outside of the vessel is important. So Mr. Wayne was able to "nest" additional water columns and buoyant devices within each other, in the area usually assumed to be reserved for just the volume of air most think is necessary.
The result is he has one water head pressure. But he is using that THREE times to create buoyancy.
The single water head pressure is used to create three different head pressures on the three buoyant members in the device. The sum of the three different head pressures is greater than the single water head pressure. This results in overunity. The Force being used to create this imbalance is apparently Gravity.
M.
@mondrasek. Ok , I sort of understand that. Would you care to comment on my last paragraph, about doing away with the hydraulics?
Quote from: neptune on June 08, 2012, 09:44:23 AM
Good thinking,
The Travis Effect does have a predictable and short range - which become design and expectation requirements.
Layering does not help with the stroke length,the primary reason for the layering is to increase the pressure diffirentials in relatively the same space - it is like haveing the Travis Effect mutliple times
Or multiple forces combined - the way it is designed - only one of the layers needs to be changed in order to activate the force in all layers - making it very simple to alternate between an upward force and sink.
Thanks Wayne
Hi
Just to get the record straight, from what I have seen Mr Wayne has something from early tests I saw. However before i sign off on this one It has to be subjected to a continuous two day non stop test, and then be subjected to evaluation by a team of engineers and scientists.
i am impressed with the people involved and the community spirit in which it has been developed.
Time will tell if the device will be proved out but all the signs so far is indicating they may succeed.
Kind Regards
Mark
Quote from: neptune on June 08, 2012, 10:23:27 AM
Neptune, I think the hydraulic accumulator and feedback system could be replaced by a mechanical winch system. Due to the short stroke and high forces being output, I believe a purely mechanical system would end up with a lot of gearing that would, of course, introduce more losses. But that is only a guess.
Right now the output of the system is captured and stored by a hydraulic accumulator. Would it be better for you to visualize a mechanical accumulator run off of the hydraulic capture system? Something like each rising Zed still pushes on a hydraulic cylinder, but instead of that pressure going into the hydraulic accumulator it directly runs a hydraulic motor that is used to winch up a weight. The potential energy stored in the raised weight can be used to back drive the hydraulic motor as a pump to supply hydraulic pressure to other parts of the system, or it could be used purely mechanically or to spin an electric generator. Either conversion method would work. It's just a matter of finding the most efficient (least loss) way of capturing the energy from the buoyant rise of the Zeds.
M.
@Mondrasek. OK that last post was most helpful to me, and hopefully to a lot of other people who do not understand all this and are afraid to ask. I can visualise a hydraulic accumulator . in its simplest form, it is just a balloon! If we pump oil into a balloon, we expend energy stretching the balloon . But we can make use of that energy later by using the oil under pressure to operate a hydraulic ram . Another way we could make an accumulator would be to use a ram to compress a spring. Later, by use of valves , we could allow the spring to compress the ram again, and feed the oil into a second ram .
Now imagine that we want to build a version of this machine that is just a "bare bones" version to use as a teaching aid. We are not too worried about max efficiency , we do not need to drive any massive loads. What would be good is if the machine would run itself. If necessary any switching or valve operation could be done by hand, just as it was in the first steam engines.
So we replace the whole system of hydraulics , including the accumulator with a lever or levers and a spring.From a practical point of view, this machine would be pretty much useless. Except that as a teaching aid it would be priceless. All the cylinders/ tanks could be transparent, and where possible separate volumes of water could be dyed different colours.
The big question here is, is any of this feasible or am I talking BS.
@Mark Dansie . Thank you for your words of encouragement . I realise that you need to see more prolonged tests before totally committing yourself.
Another important question here . So we have 3 cylinders nested inside each other. So to increase the bouoyancy of the whole thing, I am presuming we have to force a [small] amount of air into this system . So to do that we need to input some energy into the system, to pump that air . Am I right in thinking that the energy we can gain by that buoyancy is greater than the energy needed to pump the air?
I am just greatful that there is someone who will answer my questions.
@neptune,
Except for the cost involved, I'd be building a table top version out of acrylic myself! I was thinking different transparent tints of acrylic for the different moving members. But I had not thought of tinting the water.
I was thinking of asking CLaNZeR or TinselKoala. But the cost is too much to ask IMHO. CLaNZeR might want to take a stab at it anyway regardless of expense (he is like that). But both CLaNZeR and TK have interests mainly in magnetics and elctromagnetics respectively.
The patent and my own limited understanding of the device suggest that sizing of each member is important to achieve OU let alone to optimize the design. So we would need a builder or team that could support "the numbers" as well. But maybe Mr. Wayne's team already has such a teaching unit in mind?
M.
Quote from: neptune on June 08, 2012, 11:31:09 AM
If you read the patent carefully you will find in the last few paragraphs that it is possible to move the *water* between the Zeds instead of the air to achieve the same switching of the power units. This is the current way Mr. Wayne's team is going. It is more efficient.
Like always, the air "pre-charge" of air is just to balance the forces of the static system. Then water is pumped into the first Zed to raise the head pressure and initiate the first stroke. That water is then transferred (first half will flow naturally into balance, second half needs to be pumped using some of the captured output from the first stroke) to the second Zed. So in this case, no air is being pumped. Since the water is pumped to the outer most chamber it should be easier for everyone to understand that buoyancy is causing the output motion and force, not classical pneumatics or hydraulics.
And yes, it takes less energy to transfer that second half of the water head to the second Zed than was captured in the first Zed's upstroke. Lather, rinse, and repeat.
M.
Thanks again Mondrasek. So going back to my idea of a teaching aid which would run itself. Simplicity is the key here, not max efficiency . So imagine we have just one Zed in stead of two . [I am just thinking out loud here] So as it alternatively floats and sinks, or rises and falls it drive a crank via a connecting rod. The crankshaft drives a water pump to change the levels as required . Very simple , cheap, low tech, but illustrates the principle . Might be worth some experiments . Maybe Mr Travis built something like this along the way.It would make a fantastic executive toy.
My problem with the patent is that it comes up on the screen very small, and I do not know how to make it bigger , so it is hard work for me to read.
I have been asked for support and permission to have the demo model build, I am keen on the idea.
Wayne
Quote from: neptune on June 08, 2012, 12:11:19 PM
If you are here: http://www.faqs.org/patents/app/20120117957 (http://www.faqs.org/patents/app/20120117957) and on an up to date Miscrosoft Windows Explorer (not sure with other browsers), try holding Ctrl and tapping the + key to make bigger. To make smaller, hold Ctrl and hit -. Ctrl and 0 resets to default.
Hope this helps!
M.
Quote from: mrwayne on June 08, 2012, 12:18:20 PM
So your team will build one?
@Neptune & Mondrasek:[/size]
Thank you for your discussion. It is productive and helpful.
@Wayne: First and foremost, a demo model is imperative and highly instructive.
@Neptune:
Re: your problem with enlarging the text of the patent.
Download the patent, copy & paste to Text Edit, or Word, or whatever program you have for document creation. Then you can enlarge the font as much as you like.
Quote from: mondrasek on June 08, 2012, 11:48:38 AM
@neptune,
M.
I`d love to see a working model built like this!
Thanks for the suggestions from everyone about enlarging the patent.@Mrwayne, I did not fully understand your last post. Are you saying that you would like to build a model, or are you encouraging us to do so. In the light of your experience, do you think it is feasible to build a simple model along the lines I have suggested, with just one group of nesting chambers, and a crank replacing the hydraulics? As you have a patent, you have nothing to loose, and probably much to gain in terms of publicity , by helping us. All we are seeking is to educate ourselves and the public, not trying to profit from your invention, which would of course be illegal and unethical.
Regarding the numbers game, my gut feeling would be, that the concentric cylinders would need to be sized so that the spaces, or volume between them would all be equal.
I would like opinions on sizing, that is , would it be more difficult to make a small model OU than a big one ?
Another thought . For a given size, based on gut feeling, using a liquid with a density higher than water would probably give a higher COP.The problem might be finding such a liquid, after all , all oils are less dense than water
Such a self acting model , if feasible , would help not only to sell this idea, but wake up the world to the reality of alternatives. Perpetual motion machine on your desk, anyone?
Also I disagree that such a machine would need a lot of money to build. Lots of time, yes . (0% of it could be built from junk.
Quote from: neptune on June 08, 2012, 01:49:12 PM
Denser than water and still clear: Glycerin?
Glycerine is a good idea. Second thought . A denser liquid would give greater buoyancy , but this would be offset by slower movement .
I think it scales better for a model though. A less dense fluid would cause a faster action, but in a model you want it to move slower so you can witness everything. I think it might actually make a model act more like an actual small scale replica of a larger unit. Not sure of course.
M.
OK.At this stage we need to make a sort of mental "Block diagram" of what is required to build this model . Here are my initial thoughts.
1 A tank of water.
2 A "block" of 3 concentric cylinders . Need not be transparent in the mark 1 model , use empty food cans.
3 Some kind of frame or lever system to allow[2] to rise and fall a fixed amount without falling over .
4 a flexible tube to connect [2] to [5]
5 A pump to force water or air as required into [2]. This could consist of a large vertical hyperdermic syringe .
By pushing it down with a weight , we can measure input energy [weight x distance it falls. ]
By causing [2] to raise a weight, we can measure output energy. [weight x distance it rises.]
Until and unless we can, by the above methods, show that output exceeds input, it would be futile to proceed further in our attempts to build a self runner .
Anyone agree, disgree? Comments? Total cost thus far less than 10 dollars?
I think you are missing the fact that each cylinder is separated from the next by a ring that is attached to the bottom of the "tank". We must create three "rings of water" into which the three cylinders fit. The outside ring could be a tank as you suggest, but I think another cylindrical shape best represents the concept. This is because to change the entire head pressure means you must change the fluid level in the outermost "ring." So having a tank means more fluid to move to raise or lower the head and therefor less efficiency. You want to minimize the amount of fluid in each ring, without making the gap between the ring and cylinder so small that Reynolds drag impedes the exchange of the fluid.
So for three cylinders, and three "rings", you need a minimum of 6 nesting cylinders that have enough clearance to allow for an adequate amount of fluid to exist that can be exchanged easily (at least on the outside chamber). This is where I thought trying to make one out of acrylic would get expensive...
M.
http://www.youtube.com/watch?v=sNOXFiJ4IDU
@Webby1 . The effect that you describe will no doubt work . The question as ever, is if it is OU or not.
@ OK so the fabrication of [2] is more complex than I at first supposed, and will be correspondingly more expensive .Cylinders will have to be made to specific dimensions. So we really need some input on dimensions and proportions from Mr Wayne, to justify the expense .
Quote from: mondrasek on June 08, 2012, 11:58:15 AM
I'd like to point out that Fig 5B shows that the liquid gap is filled to the top when just 10% of the water is pressured out.
Fig 15 shows that all of the water has been pressured out, so now if the pod rose of 10% of the fill distance then there would be no liquid gap and combined head, which would upset the whole process. Since it is a container, it seems to require that water has to be pumped in to that container to reach the results in Fig 18. In his pictures on his site of his patented device, the water pumps on top have flexible piping running to the bottom of the tanks.
Regards, Larry
@mrwayne, is the precharge method for introducing the air through the pipe into the pod (to pressure balance the static system) exactly the same when you are setting up the system to run by exchanging the water vs. exchanging the air?
Thanks,
M.
Quote from: markdansie on June 08, 2012, 10:38:54 AM
Hi
Kind Regards
Mark
Mark,
If you are allowed to tell us, what is Mr. Wayne's team's next step? How do they go from where they are now to agreements with Siemens, GE, ABB, Hitachi, etc., to start replacing existing nuclear reactors and fossil fuel burning electric generation systems with this new technology?
Thanks,
M.
Get it from the horse's mouth (no offense, Wayne) during yesterday's interview with Gary & Mark on Smart Scarecrow. Wayne comes on soon after 1:13.
http://www.youtube.com/watch?v=rMda6OUOYRw&feature=player_embedded#!
3 new Travis effect Videos online:
http://www.youtube.com/watch?v=fPXBY0Bx0Iw
http://www.youtube.com/watch?v=643UYo-CEx0
http://www.youtube.com/watch?v=z_MLjkt8ti4
Posted with Permissioin from Wayne.
Enjoy !
Regards, Stefan.
Quote from: mondrasek on June 08, 2012, 05:31:14 PM
Thanks,
M.
Sorry Men, + Ladies,
I have been super busy setting up tests.
Now that i am not having to spend so much time on nay sayers - lets get to the fun!
I see where the group has dwindled down to the experimentors - good, lets roll.
OK, the tube in the pod - no - it was when we were transfering the stored energy from one side (Zed tank) to the next the high tube kept the water from getting into the tube.
With the water moving - it is irrelevant - as well as the skirt under the pod - no need when moving water - make your pod full length.
I am still testing - but wanted to guide you on the model -
3 layers is the least effecient - (Over unity), 4 is not much better - build you model at least six layers -250% with two Zeds connected, 190% with one Zed.
Eight layers breaks 350% but new set of variables to deal with (head loss in the outer most layers must be mathced to volume at pressure) - six layers is pretty easy.
Next, be sure to have your upper surface above the water - like in the patent - with extension.
Make the holding tank tight clearnace - just like the layers - it acts as another head storage - big tank wastes it.
Conect the input to the center (bottom) - no elongated tube is needed - use water - not air.
Do not worry about the weight of the layers - it actually improves the system. the weights cancel out when two tanks are connected (why a two Zed system is better than one) - but holds the system in the "Travis Effect".
On that note - once you reach Determine the Ideal lift without weight divide that by three - Make sure your risers weigh that much (add weight) - we are only going to be producing "free" about a third of the total potential - assuming the best system can net the full "Ideal" is another big mistake made - then you have magical energy.
You must have resistance for the system to work - so you never apply work to the system without a load,
Without a load - the system leaves the "Travis effect" you entire operation will be inside of it.
Concerning the load - if you are using the system like a pump- water up a tube - so the riser has to lift the weight of the water in the tube to a higher level - that is a good simple demonstration.
use the higher water pressure to operate your level arm - and you will have a perpetual water fall - you will need to design an over flow - that is what we did with out model 7, we just wasted the extra.
Oops I forgot - M. Mentioned the need for the lower seperator - called RIng walls in the patent - MUST have - without you are back to 37%.
I will give advice as you go, send pictures so I can advise.
My request - these are for personal use - I have an agreement working with a another party.
Two - you agree to put the name on all models "ZED" or Travis Effect..
Three, you must also make me a model - I may be willing to pay your flight to the full size model and
have you stand in front of the full size model for pictures.
Lastly - if you do this as a group effort - I will donate $2000 for materials. Should cover everything but your efforts.
Time to invent!
Wayne Travis
In the third video, when setting the experiment up, does it take the exact same force to submerge the "archimedes cup" with the "3 ounces of air" in it, as it does to submerge the "travis effect" cup with the same amount of air in it?
The first video would seem to indicate that it does not; the TE cup would take a stronger push to submerge it.
Therefore.... there is stored energy in the system, like a compressed spring, and this spring is compressed more on the TE side than on the other side.
When both cups are held down with the same amount of weight in the third video, the TE cup is effectively "lighter" in the water already, so when the air is bubbled into it, of course it rises first.... as long as the block is displacing some air. If the original water level was higher, the TE cup could rise up until the block no longer displaces air, and then ... except for the head start given by the stored energy ... the two cups will rise equally.
Why does this effect occur? I think it is because volume is conserved (or rather, pressure times volume is conserved for a gas) but surface area is not. This means that the gas pressure in the TE cup is greater than in the archimedes cup, even though they both started out with the same volume of gas initially. The gas in the TE cup is compressed more than the gas in the archimedes cup, because a lot of it is forced to a greater depth in the water by the displacer. This compression is stored energy, it requires work, this work is done when the cup is pushed down over the displacer _raising the water level in the external container_ and this work will be returned, minus losses, when the residual weight is further reduced by bubbling in the air from the bottom.
I think this explanation could be tested by linking the two submerged cups with a passive air tube across the air chambers, so that the pressures within them would be the same. (Test to make sure by seeing if it takes the same amount of weight to hold the cups down equally. If not... then there is asymmetric stored energy still.) Then bubble air into them from beneath as before.
http://www.mcmaster.com/#acrylic/=hwgbdp (http://www.mcmaster.com/#acrylic/=hwgbdp)
Quote from: neptune on June 08, 2012, 03:16:40 PM
1 A tank of water.
OK in the light of further info it is time to update the above list. First item 1. I had sort of envisaged putting 2 into a tank, e.g. an aquarium . Bad idea. The tank, should of course be the largest diameter cylinder of 2.
Now item 2 . I referred to this as a block . What I meant was block, as in block diagram, in electronics . So on a diagram you might have a square box or block labelled "Oscillator" . So we know what it does , but we do not concern ourselves with the individual components within . Yesterday , i did not fully understand how these cylinders were arranged , so I called it a block .
Here is my current understanding of this block . Imagine you have three empty baked bean cans . They are all the same height . Their diameters are , 6 inches ,5 inches and 4inches . Put some glue in the bottom of the 6" can, and drop the five inch can inside it. so they are concentric .Drop glue into 5" can , and place the 4" can inside it . Now we have 3 more cans , with diameters 5.5 , 4.5 , and 3.5 inches diameter . We glue these together to form a similar unit to we made with the first 3 cans . We invert this second unit and drop it into the first unit , so that the cans of the second unit interleave with the cans of the first unit . Before we drop it in , we fill the lower unit with water . Can someone confirm , or deny , that this is the basic layout please? I know we can not use food cans because the gaps between adjacent cans needs to be smaller than half an inch .
If my description above is correct , I can now understand the bit about the coiled hosepipe with the lower half of its turns filled with water .
As with any new concept it is vital that we understand the basics or we will never grasp the complex. You can not do simultaneous equations unless you can add 2+2 . I am making progress I hope, but do not fully understand it yet . I am sure I am not alone .
Question . Is the upthrust or buoyancy of a given volume of air dependent on the SHAPE of that volume, and is that upthrust greatest when that volume is elongated in a vertical direction?
Participation without a full understanding is futile.
Momma always told me that two Zeds are better than one !
It is important in these experiments to monitor carefully the water level in the external container. Buoyancy forces arise because of lifted water. The larger the external container, the smaller the _level_ change will be, so it's best to use a container just big enough to hold your cups or other experimental vessels, so that you can see the change in the surface _level_ for a given _volume_ of displacement in your experiment.
Even when you stick a tube from the air pump down into the water and force that first bubble to come out of the tube down at the bottom of the tank: you have just _lifted_ that same _Volume_ of water to the top of the tank, and you can see this volume lift by looking at the small change in the level of the water in the external container. This spherical volume of water that the bubble displaced results in a slight rise in the surface level, spread out over the area of the surface... volume is conserved in the incompressible liquid water. But volume is not conserved with a gas: it is (pressure times volume) that is conserved. PV=nRT.
Take a tank of water, mark the level carefully, then submerge the concrete displacer. The water level rises. Now take a cup with "three ounces" of air in it. (The Fluidounce is a volume measurement so it would be more correct to say "three fluidounces" of air). Submerge the cup. Now the water level rises again, by that same three fluidounces. Now start to lower the cup over the displacer. What happens? Some of the displacer is no longer submerged! It is in air ! In other words, the displacer is trying to occupy the same space as the air does. But half of it, say, is no longer displacing water, it is displacing air, which is pushing water out of its way. Since (pressure times volume) is conserved for a gas (neglecting temperature effects), the gas pressure increases--because the water is pushing back, thanks to gravity-- and the gas volume decreases; this, combined with the fact that part of the displacer isn't displacing water directly any more but is doing it through the "spring" of the trapped air, results in no observable further increase in the external water level... in fact it might drop a bit as the total volume displaced decreases due to the increased compression and decreased volume of the gas. Now you have two stores of energy: the lifted water that raised the level when you first submerged the cup with air, and also the compressed air within the cup itself, which is more compressed by the displacer pushing much of the air further down into the water.
This is good, it is the same pressure in both cups to lift the same load with the same Surface area, assuming you have them at the same depth in the water.
A simple visual, I like it. Also if - the floats /caps - I call them "risers" are identical - then the hieght of the air (from top of the air pocket - to the bottom of the air pocket) will be exactly the same length at any depth to lift the same wieght. which is an indication of the pressure diffirential PD needed to lift
My layman terms; PD X si = lift
Thanks Wayne
@mrwayne,
I seem to remember (from the patent I believe) that a three layered Zed was considered the most efficient? To increase power it was better to size up the entire three layer system rather than add additional layers. Now you are indicating that a six layer system would be more efficient than just three? Am I mixing apples and oranges? Or did changing from transferring water between two Zeds vs. transferring air allow for more layers to raise efficiency further?
Could you please point out where I have gotten off track in my understanding?
Thanks,
M.
Quote from: mrwayne on June 09, 2012, 07:24:20 AM
A generous offer.
TK, do you still have access to a model shop? Would you be willing to build?
I've sent a PM to Sean (CLaNZeR) to see if he is interested in building. But I don't know if that bloke has the time. Plus if he is only at home on weekends it would take much longer than I would like to construct. And I believe it should be made in the US if at all possible, just to honor Mr. Wayne who is in OK.
Wait, where are you now? Still in TX, back in Canadia, elsewhere?
You know I don't expect a serious answer to the last question, right?
M.
Edited to add: Sorry if I might be slighting anyone! I am sure there are others who have the talent and equipment for a build. I'm just looking to the ones I know. Please chime in if you are or know of anyone else who would be a good resource.
@Mondrasek. I would be very grateful if you would comment on my last post. Am I right on the arrangement of cylinders? What about my question on the "shape" of a volume of air .
I would think it unlikely [but not impossible] that there will be a team build on this device, due to members being widely scattered . Individual builds are much more likely .
When I FULLY understand this, I will most likely have a go myself. I am sure this applies to many members.
A patent, being a legal document, is not the best teaching aid.
Quote from: neptune on June 09, 2012, 08:17:45 AM
Two Quick points - tight clearances - Head pressure is head pressure - unless you get to the caplilary effect. SO make it close as you can - and still have a gap.
This will reduce the volume that it takes to activate the Travis Effect - smaller gap - more effecient.
Wayne
oops,
The same thing goes for the thickness of the walls - Small/thin - do worry about the pressure - the effective pressure will only be the total hieght of one layer. so if the layers/cantainer can hold up to the water pressure of it sitting up right full of water (without contortion)- they will hold the pressure in system.
Wayne
@neptune,
I believe you have most of the fundamentals covered with your description of the build in your previous post. Here are the differences and/or next considerations that I have:
1) The walls of the first set of cans may need to become slightly lower from outside to inside. I believe the outermost must be considerably higher than the two inner ones since it houses the water head that is exchanged between the two Zeds and also defines the stroke of the system.
2) The three cans that become the buoyant members (pod and risers) are all attached? That is different than the patent. It may be how the unit operates, but I think it would make assembly a problem. The inner and outer riser need to be installed while allowing for the air inside to be pushed out through a vent in the top. Then the vents are sealed. So they need to be installed one at a time and not as a group of all three.
3) The outer riser needs to have an outer wall that extends up beyond the bottom of the "can". This is again because this defines the stroke of the system. Water must not cover the top of this riser, or we end up with that much more water that needs to be transferred between Zeds.
4) The inner most can needs to be made into a "pod." So an empty, sealed can, with a top and bottom. This is different than the patent since the patent diagrams show a system that exchanges air and we (I assume) are building one that exchanges water. Mr. Wayne has said that this change from air to water exchange allows for a pod of this new configuration that is not in the patent diagrams. Hopefully he will correct my understanding if it is not 100% correct.
5) Finally we need a way to "pre-charge" the system. A way of introducing (pressurized) air from under the "pod" section slowly. It will eventually fill all the "rings" where air is need and balance the water pressure to initialize the system. The risers must be held down when the air is introduced. The pre-charge is complete when bubbles are seen rising in the outermost ring of water. Then the air inlet is sealed and never used again (unless the system needs to be relieved of any potential energy prior to maintenance, etc.).
Am I missing anything?
Hope this helps.
M.
Many thanks to mrwayne and mondrasek for the time you spent helping me. My understanding is progressing by leaps and bounds . A way to introduce air under pressure , and prevent it escaping . For a model, that could be a bicycle tyre pump and valve.
Quote from: neptune on June 09, 2012, 09:47:02 AM
I am headed out -
but wanted to comment:
Shape of the air is not the essential - except in consideration of stroke - then a straight wall matters - they keep the clearances during travel.
For your predictive measurement - pretend that all the layers are stacked on top - not over eachother - sealed and submerged (full of air) that is your Maximum lift your system will have.
Second - collaboration is good - it will take as much effort to build the transfer system as it will the layering system, and then you need brainstorm how you will show the work?
Each can be a seperate job. (just like the real manufacturing process is working out).
The key is to make a decision on the size -
Diameter of the inner chamber will dictate volume needed - keep you stroke lenght short - no more than one inch - (trust me) - will explain later.
So now you can have your volume -
If you find the rubber pump or something without to much static resistance first, you can size the inner tank to it.
Wayne
@Mondrasek: I am afraid that I'm not going to be able to build any intricate models this time, sorry.
But I suggest that you examine, build, and meditate upon the Cartesian Diver, illustrated in a modern form in the video I linked. Water pressure, air volume, buoyancy... it is all there.
In addition, I thought there was already a working, self-powering prototype of this device? Isn't that what the claim is, for the big, groaning, hydraulic/pneumatic device? I'm not sure I understand just what is happening in this thread. If there is a working prototype, let it be carefully examined. A patent is nearly useless for something as complex as this; what's needed is engineering drawings, schematic diagrams of the electronics, the hydraulic and pneumatic circuits detailed, and so on, and this information isn't easily gleaned from the patent. If it is self-powered and can run itself while providing useful work to a load... or even just keep moving, under its own power, not stored power... then this should be clear on careful examination, and any and all efforts are worthwhile to try to understand and promote the discovery. However...
If the illustrated prototype does NOT self-sustain.... then no amount of effort on our parts is going to make it so, because.... well.... buoyancy is nothing but gravity misspelled.
You are all welcome to follow Tinsels suggestion,
No offense really, if you persue I will guide - I have had to overcome many obsitcals to get our system built and running both. Some people offer good educated thought, other seek more.
He is right - we do not need to replicate - it would just be a a teaching tool - and a mark in history.
I love the Gravity mispelled - very clever.
Wayne
Wayne, if your present system works, the one in the video, without supplied external power.... then you don't need to "guide" anyone.
Provide what I suggested: engineering drawings, the electrical schematic, the hydraulic circuit, the pneumatic valvology, from the existing, working prototype, not the patent. Or, if you like, invite some interested impartial third party (like me) to examine and test your working prototype. I can tell you this: if it is self powered, truly, and uses gravity and buoyancy to sustain operation.... I can set you up solid, my man, solid. I'll get rich from being the middleman, but you will get hugely so rich you cannot imagine it, and the world will be a better place very quickly.
Quote from: TinselKoala on June 09, 2012, 11:26:29 AM
Are you kidding me old man? A FULLY FUNDED (well, materials only) build? In acrylic?
Just think how sweet that would look on the shelf next to your mondrasek wheel!
Seriously though, I appreciate you considering the idea. It is a lot to ask, and you are a busy man. I also understand that it is extremely hard to justify if you have to dismiss the principle of it's operation.
I know you will, but I ask anyway: Please continue to monitor this thread and give your sage advise and input when appropriate (as you have been doing).
Also, once you have thoroughly digested the FULLY FUNDED (add disclaimer here) offer, please reconsider.
M.
Tom's new demos are very exciting and promising but the challenge is simple now.
Get 1 or 2 foot pounds to put the air in the cup to lift about 10 foot pounds and then
with some of that work pick up the original 1-2 foot pound weight and
1. remove the air and then
2. repeat the air filling process.
That will be the undeniable proof of the long sought after perpetual motion machine.
I'm very optimistic....
Norman
Quote from: webby1 on June 09, 2012, 05:27:46 PM
A couple of quick questions.
Would 2 layers of lightweight fiberglass be sufficient for strength.
Would 4 layers of wax paper be a sufficient air gap and can that be the same on both sides.
I was thinking that the cylindrical components could all be made at the same time by wrapping them around the pod former starting with the former then 4 layers of wax paper then 2 layers of fiberglass and then 4 layers of wax paper,, so on and so forth.
Webby1, I (just me here) think that on a small scale fiberglass has all the strength needed to stand up to the pressures in the system.
As far as using a few layers of wax paper to create the gaps in the annulus (-es? annulai?), any gap will do, just so long as it is not so small that capillary action takes over (the gap tends to "wick" up water like a sponge). Ultimately I think too small (but bigger than capillary) a gap will also cause (Reynolds) drag on the exchange cycle. But in a model, that is okay. It would just not be the most efficient method for a "production " machine.
M.
Quote from: microcontroller on June 09, 2012, 05:26:19 PM
FULLY FUNDED doesn't mean anything so why are you using capital letters?
It is significant only that every time that I have seen TK build he has spent his OWN moneys to do so. I was hoping that he could be teased into performing a build by being reminded (yes he knows) that he gets to build a cool thing without the personal expense of the materials.
I'd take on a build myself but lack the experience of having worked with acrylic and do not have access to a lathe to ensure clean 90 degree cuts to the tubes.
Microcontroller, do you want to try and make a model?
M.
Microcontroller,
You miss the point. But thank you for telling us all that you could do but will not.
The fact that Mr. Wayne has offered to pay for the build means all those tubes you "have in stock" would not be given for free, right?
I probably should have let you have your say without pointing that out, but, really? Really?
Who do you thing your are fooling?
M.
if he is willing to pay for the build, he can trust Stefan with the money and over seeing the build.
Quote from: microcontroller on June 09, 2012, 09:15:02 PM
I have no idea if you know the value of some of our cnc machines, but i do not think these are included in mr wayne's offer.
You are correct. I am sure you know a lot more than me about this subject.
I apologize for underestimating your skill level.
M.
Quote from: TinselKoala on June 09, 2012, 12:11:21 PM
That is great, I really appreciate it.
Mark Dansie has assembled the team for our Extended runs - critical review and then (assuming of course) the team to prepare our scientific presentation.
He has seen our system running last November, and had full access to our engineering.
Now that we (following his advice) installed the Data collection system and generator to the system - it is time for the follow up - should be about June 28. (I am leaving end of next week to go to a 50th anniversary party)
We do have our working model - actually since May last year, Mark has guided us very carefully - what "extraordinary proof means".
So we are not rushing ahead - doing it right - after the pct cleared - I decided to let the group know where we are.
We are not setting up Middle men - but we never know who will actually become part of the team - so if you are just tongue in check making the offer - no worries.
If you would like to be in the group coming for our final review - let me know, I will bounce it off Mark and make a decision.
Once again - Thank you for the professionalism.
Wayne Travis
How much will it cost to become a part of your group ?
If tk evaluates this and says it works, I want to buy shares in your company!! lol
In the light of newer information, I have had to re evaluate the feasibility of building a model of this device . The problems are as follows .
1 Owing to very poor eyesight , and very limited computer skills ,I am unable to gain much info from the patent.
2 The patent shows a design that works by moving air. It is since discovered that moving water is more efficient, but no revised diagrams are available .
3 To gain reasonable efficiency, fairly close tolerances are needed. So no building from empty baked bean tins.
4 The idea of building from fibreglass and waxed paper was an excellent one . But who is going to risk the investment in time and materials without having concrete info on proportions and dimensions. Trial and error methods could take years, and then costs mount up . Who would invest hundreds of man hours without knowing that there is an excellent chance of success.
5 I am unsure of mrwayne`s motivation in encouraging us to build a model . Maybe he hopes that we will discover new ways to make this better. I do not have a problem with that. However , there is a far greater incentive he could contribute to model building than his $2,000. Of far greater use would be much more info , especially in the form of diagrams, dimensions and proportions . Forget about hydraulics. All we need for now is how to get two ZEDs working . From there it is just conventional engineering.
I would guess with the possible exception of Mondrasek, nobody really understands tis enough to attempt a build.
I agree. more details required to build a scaled down desktop model.
The whole point of having a working model is to show less clever people like me how it works! :)
Someone posted a youtube link to a animation of a similar idea, an animation of the way wayne`s device works (same arrangement as in the patent drawing) would be a start.
At the moment all I have is a vague idea of stacked nested containers filled with tubes linking each one.
@All,
MrWayne has a working device. Hd coukd put a live feed on the internet.
A liue feed would demonstrate his claims are valiid.
edit
If he has oter people build versions of his device, it cottld be considered that he is looking for answers as t6 why it does,t work. This is ojjay as long apr people know why Wayne ir letting them build his invemmtion I would have to think.
Happen to have my work laptop at home so I have access to Autocad. Hope the attached can help some to see what I see.
M.
Hello all,
I apreciate the consideration.
Whats my motivation? That is a good question - I have had many people tell me what they think it is on this site - so let me answer for a change - again - good question.
My motivation as has always been - encourage the thinkers.
Some people live inside a book, or the knowledge contained within - others are wanderers, innovators, looking beyond what they are taught.
We all know that "new" fields of study are found outside the confines of the current education of the time.
Those that have not really looked into the "Travis Effect" have no idea that we are in a new frontier of uses for buoyancy.
Man and Flight, Man on the moon, Solar Energy, Lenar was beaten to a pulp just a few years back - and now how many companies thrive on these teschnologies.
New frontiers are forged by the those with a certain contenance, able to persist - where others are safe to avoid.
I support "extrodianry proof" - History tells us that our intrepertaion of the Laws, our understanding of the books, grows - not from within itself - but from those that question, think, wander, dream.
I support both - that is why our company decided to go the hard route - instead of expecting people to jump on board and run in with support - we expected dream crushers.
But, as our support has shown - for every thousand put downs - a thinker emerges and says - Why not?
If it does work - how?
Those people begin to build - touch, measure - not with simulations from the books - ok..self fulfilling, but from physical experimentation, physical proof - the kind that the writers of the books did - observation.
From time to time, a new observation comes along - upsets things for a while - and the books get better.
As we have shared before - we have already passed three phases of scrutiny - and expect and welcome more.
Our Critical Skeptic said - "this work is changing the dynamic on which mechanical energy is understood" at least for those involved - for now.
My motivation, my friend - to help you and the others get past the mindsets such as we have seen on this site, like the ones I put below.
I know what I have, I know the positive results of the third party review so do nearly 100 others - we have had to know every step of the way - and I know that puts me in the positon of being the one person who is responsible and "knows" that all of these nay sayers are wrong.
Here is a short list of negativitey, poor logic, holding onto the known - attacking the wanderer - just from this site:
No one else has done it in the past - so it must impossible....
The Laws says it can't be done......so it is impossible (kind of makes you wonder why those people are here on an OU site - that surprised me last year - not anymore)
A guy in his garage without "My level of educaton" could not do it......
I didn't waste my time getting an education to believe you could do it...
A guy who goes to church can not be smart enough.............
He must be after money, greed, ...take him down.....
and many who - mine is better than yours so your must be insulted...
as well as If I can not do it then at least I can beat on yours.....
And my fovorite for the week:
Sure he has passed the design phase, engineer reviews, built a test module, built a perpetual running model, built a closed looped model, is being supported by severe skeptics - with continued critical review -
......but if he has trouble with a check valve in the new model that now runs a generator off excess hydraulic prodcution --- I won't waste my time looking...... (p.s. - do you increase the level of review when it doesn't work at the simple level?- thinkabout it)
We all have motivations - they are clear - we show them with our words, our support, our actions, and our lack of them.
I chose to support our fellow kind.
And thank all of you who have sent kind words, encouragment, and the like - you support the improvement of the quality of life for all mankind.
Wayne Travis
Quote from: mondrasek on June 10, 2012, 10:17:10 AM
M.
VERY GOOD,
yes - cap lock on purpose!
Please send me this drawing - I want to use it in our power point - I could replicate the simplistic truth you demonstrated - but I want your version for credit.
Thanks you M.
p.s. you two steps from then end of this section of the design - very close well done.
Wayne
Sorry Wayne, I didn't save the .dwg file. I only hit "print screen" so I could transfer to "Paint" and make a .jpg. I'd be happy to redo it for you once I am back at work and have a real monitor! Working off a laptop screen is painful. I am sure your designers will attest that in CAD, monitor realestate is everything!
I believe I could put in the next two steps. I didn't think it was necessary at this point. I just wanted to illustrate how nesting the sections of a taller system is being done.
Thanks,
M.
This system is really similar to what you guys are doing in this thread:
http://www.youtube.com/watch?feature=player_embedded&v=oV5wFTfsTSs (http://www.youtube.com/watch?feature=player_embedded&v=oV5wFTfsTSs)
It seems to be using the same principles.
@Mr Wayne. I asked exactly what your motivation was , and you came up with an answer that seems OK to me. There are members who have been on this website for many years, and I am one of them . We see ideas come and go. We see measurement mistakes. And unfortunately we see scams and deliberate fraud . I find it impossible to understand these fraudsters, because they gain nothing and loose respect. But their worst crime is that they divert research resources away from worthwhile projects . We all remember Trawoegers pyramid , Mylowes motor, and the Muller dynamo . Between them they cost me £1,000 I could not afford to loose .
So why am I still here? because I still believe in the strong possibility of Free Energy and Overunity . I am just a lot more wary than I once was. From the info available to me , I believe that you have discovered something real. Replication is the way forward, and for that we are going to need a LOT of help from you,[who else can we ask .]
You know what you know as a result of hard work and experiment. The road from the simple Travis Effect demonstration to what you have now, must have been a long and expensive journey. So I need to ask you a very simple question, and I am almost sure you know the answer . Here is my question.
Suppose we have a simple inverted cup , sitting over a Travis block, with no air in it, so it is completely full of water. Then we pump a small amount of air into it , and allow it to lift a weight .So is the energy needed to pump that air , smaller than the "output energy" , of lifting the weight . Hope fully , you can give us a yes, no , or don`t know answer.
@Mondrasek, you are a star. Brilliant diagrams . That is exactly the kind of thing we need.
Quote from: ResinRat2 on June 10, 2012, 11:15:10 AM
Yup, thats the animation I was referring to in my previous post.
How is it similar and what same principles is it using? The only similarity I can see is that it uses a fluid.
Don't want to come off being rude. Please explain what I must be missing?
M.
www.hidroonline.com (http://www.hidroonline.com)
Quote from: Xaverius on June 10, 2012, 01:26:45 PM
Okay guys. How about we set some ground rules for comparisons? Just because any scam out there is using a fluid does not mean it is a direct comparison.
Here is the minimum requirements (IMHO) for any similar technology/scam/idea to be sited:
1) The concept must involve buoyancy.
2) The concept must involve nested cylinders or some other means of displaying the "Travis Effect."
Have a nice day.
M.
I'm not sure if this system uses Travis Effect or not, similarities are hydraulic towers, self perpetuation, electrical generation..........
Quote from: Xaverius on June 10, 2012, 01:57:37 PM
Yep. And it is PATENTED! Care to find that patent?
Quote from: mondrasek on June 10, 2012, 02:05:44 PM
It is patented in Australia and licensed in Indonesia by Inter Pacific Energy.
Quote from: Xaverius on June 10, 2012, 02:11:50 PM
So the patent should be online? Or is it different in Australia? Can you find it?
Quote from: Lakes on June 10, 2012, 11:43:12 AM
I am very familiar with that inventors work, and I am you know him well.
Each man must stand on his own merits.
That is all I care to say for the "comparison".
Quote from: mondrasek on June 10, 2012, 02:14:34 PM
I am not sure how to find it, he gives patent numbers. Perhaps you could perform a search of the Aussie Patent Office?
http://www.jameskwok.com/ (http://www.jameskwok.com/)
I agree with one of the other members, a patent is too difficult to discern the operation of a device. It is more suitable as a legal document (which it is). I prefer a block diagram, followed by a component drawing and then an overall schematic.
Quote from: Xaverius on June 10, 2012, 02:24:35 PM
Ha! I also agree. Patents suck to read. "Leagalese" is a language that may be necessary, but in an annoying kind way IMHO.
M.
Quote from: mrwayne on June 10, 2012, 02:15:07 PM
Sorry guys, I wasn't trying to get anyone upset or insinuate anything. I just wasn't sure if mrwayne was familiar with James Kwok's work. It appears to be using nested cylinders of different diameters. His original design used buoyancy and I am assuming the latest design I linked to uses it as well somewhere in the system.
mrwayne says he is familiar with it so I will leave it at that. Sorry for even saying anything. Scheesh!
Over the years posting here on Overunity I am tired of the ill feelings that pop up. I'm done with this.
Quote from: ResinRat2 on June 10, 2012, 02:47:07 PM
Sorry if I cam accross wrong Resin,
My dissapointment is in my dealings with that inventor, and he has been used as a reason to discredit my work for years - unfairly.
We have nothing in common other than water in our system.
Wayne
Somebody wake up Hicks!
Err, I mean, Sean.
Anyone know where CLaNZeR is these days? I can't post or PM on his forum. Not sure if it is working right or if it is just user error.
M.
Quote from: neptune on June 10, 2012, 11:35:49 AM
Back when I did force calculations I would be quick to answer yes -
Now I will give a clear answer (not as shown in the video) - if you build your system so that the volume of the air you use to stroke is 1/5 of the total volume and the stroke is 1/4 of that same volume -
And YES - the Travis Effect can create more power than it takes to pump the air into itself -
(It is even better if you use that "still pressurized" air to assist filling the next Travis effect).
In simple inventor talk - you have to use a lever to to capture the force and transfer it to the longer end of the lever to allow for the extra stroke length needed to compress the air to the pressure of the depth.
Since the cost of "compression of air" is not the same value of standard buoyancy you must prepare to pay three times as much to compress the air as the value you get out of standard buoyancy- or to produce at least 1cf for the depth.
I am tired, so let me just ball park my expample:
1cf of air submerged = 33% worth of standard buoyancy you start in the hole 66%
1cf of air Travis effect with 5/1 ratio and I/4 stroke = roughly 111% the value of 1cf
This is not much in the plans of supplying power - so we moved well past this.
Wayne
@mrwayne . Thanks for the detailed explanation, and answer to my question. I fully realise that you have moved on a long way beyond this. However, for us guys just starting out on this, we have got to start somewhere, and experience has taught me that it essential to start at the beginning. All I am looking for at this stage is experiments that are cheap and simple, that can be built from junk on a zero budget.
I do not doubt what you have achieved, but there is no substitute for seeing some thing with ones own eyes. My dream has always been to be able to show an experiment where 1 kilogram falling 10 cms will raise 1kilogram 11cms, or higher. I have been trying for about 50 years now, and I am getting old . Maybe the Travis Effect could be the catalyst that makes my dream a reality .
I,ve been trying to find out where the free energy could come from and made a couple of drawing to assist. Hope this helps with some of the patent confushion. Nothing fancy, just keep in mind that the channel sizes are exaggerated for clarity.
The Precharge drawing shows the position of the water at the end of stage 1, 2, and 3.
In stage 1, the water is open and air 1 and air 2 is closed. The force from the water only has to overcome the head in channel 1. As the water flow over into channel 2 gravity will level the water in channel 2 and 3 until the top is reached.
In stage 2, the water is closed, air 1 is open and air 2 is closed. The force from the air only has to overcome the head in channel 2 at the start, then gravity pushes that air up to the top and pushes the water in 2 down, and pushes the water in channel 3 over into channel 4 and 5 where gravity will level the water half way up.
In stage 3, the water is closed, air 1 is closed and air 2 is open. The force from the air only has to overcome the head in channel 4 at the start, then gravity pushes that air up to the top and pushes water up in channel 5.
This is a simple example, in actual process the air in 2 and 4 would need to be rebalanced at the end because as the heads combined the trapped air pressures changed length. Also this would not be the exact sequence in the real process as they may be done in concert, but it is broken up to get a better idea of the total force requirements.
The Travis Effect picture shows the system with exaggerated channels for clarity. The surface areas were based on the drawing using Travis's statement that the top tank was 30" by 20". I used the 3/4 scale on a architectural rule to get the other dimensions. It is easy to see that the inner and outer risers will work like Pneumatic cylinders.
Another interesting fact is that the water channels seem to be around 1" and the air channels are around 2". Don't know the drawings accuracy.
Regards, Larry
Larry,
That was great. Thanks for posting.
You seem to be on the same wavelength that I have been on recently. I am not sure how the change in pressures (due to the risers rising) will affect the air columns in the annuli (rings) on the first stroke after the pre-charge. That is the reason I was hoping for a model built out of acrylic. But I guess I could just do the maths.
I'm a visual kinda person. I would like to "see" the interactions and not just do the maths.
Now try thinking about the two risers and the pod being inserted into place with the "tanks" filled with water. The risers would need to have a vent hole to let out the trapped air. After those risers are installed those vents are then closed for good.
Then start bubbling air in from the center of the bottom of the main tank. Won't everything evetually end up in the configuration of your second diagram?
M.
Quote from: mondrasek on June 10, 2012, 03:05:39 PM
Err, I mean, Sean.
M.
Hi Mondrasek
Sorry to say, not got much time these days as tied up trying to get a factory setup.
http://www.cncdudez.co.uk (http://www.cncdudez.co.uk)
So time very short and no time to play :(
Cheers
Sean.
Quote from: CLaNZeR on June 10, 2012, 04:57:29 PM
Hi Mondrasek
Cheers
Sean.
Okay. Thanks!
Oh, and best wishes on the factory.
Cheers,
M.
Quote from: mondrasek on June 10, 2012, 04:45:26 PM
M. Thanks,
I was trying to show a mainly water transfer system like Fig 19, but with the pod solid as Travis recommended.
In fig 18 it shows how the air channels have been effected with slight water intrusion in the air channel and slight air intrusion in the water channels, it does not seem to be an issue with the narrow channels. Also, there would be some decompression to help keep the balance. So the lift force at end would be less then at the beginning. But without more facts, he may continue to add air with the rise as shown in 5B to 5C.
diagram?
It would, but then you would have to get rid of the air after lift.
If the pressured water in column 1 was released after lift, then the entire system would collapse and gravity would re-level the water in col 2,3,4,5. That pressued water would be used in the other ZED. The patent has said there would be water remaining in the system after collapse.
My issue is that as the pod rises, water would need to be added to the pod container to keep the system in balance. This seems to be an issue in both cases, mainly air (Fig 15 to Fig 18) or mainly water.
Regards, Larry
Quote from: microcontroller on June 10, 2012, 05:36:46 PM
So this is confusing.
When you use pressurized air the system will start to act like a pneumatic cylinder.
In that case the cylinder starts to rise on the air pressure in stead of buoyancy.
Air pressure needs to be below atmospheric pressure otherwise you are overruling buoyancy.
Well I think it needs to be understood that any "air chamber" that is under water is affected by the water pressure. So, for example, if you take a soccer ball and try to drive it to the bottom of a swimming pool you will find that is becomes soft. This is because the water pressure has overcome the air pressure inside the ball. A ball that is normally very hard (due to air pressure) on the surface becomes soft (in relation to the surrounding water pressure) as you go deep in the water.
Initializing a Zed system with compressed air is only NEUTRALIZING the outside pressure from the water. It is not driving anything to move like in a pneumatic or hydraulic cylinder. How could it? The system is open on top.
Ever see a pneumatic or hydraulic system work with an open end (leak)?
Buoyancy.
Check it out.
Great post, BTW.
M.
Check this out for clarity.
Wayne
Quote from: LarryC on June 10, 2012, 05:50:52 PM
I'm with you on this. That is exactly why I would like to *see* a model out of acrylic. I cannot visualize this part of the cycle so far.
I've gotta run now. Have a 4.5 year old who has been left in my care for an hour or two.
Larry, thanks for giving this the mental horsepower I believe it deserves.
M.
Quote from: mrwayne on June 10, 2012, 06:04:15 PM
Wayne
Thanks, this will help a lot.
Regards, Larry
Quote from: mondrasek on June 10, 2012, 06:06:19 PM
M., Back at you.
@All, new Travis drawing with much more detail, let's start trying to understand.
Regards, Larry
Well it is about time for us in the US EST to pay more attention to our families than the forums.
However, AU should be just well into their morning.
Good Morning Gents (and Lasses?)!
I know you guys are more than up to the task of dissecting this one.
Cheers,
M.
I just PM'd Fletcher.
I believe he's a Kiwi now. (Hopefully that will spur some quick response from the opposing AU team.)
Not sure if Fletcher has any Internet access on the beautiful rock he is living on, but I would love to hear his take on things.
M.
Quote from: Seamus101 on June 10, 2012, 09:54:49 PM
This system will never work. There is no way to extract energy from buoyancy in the way described. Buoyancy is a function of gravity, and gravity (at least at newtowian scales) is a conservative field. If you displace a mass in this field then the energy required to return that mass to the starting location is the same (or more if considering mechanical effieciency losses). That this system uses bouyancy is irrelevant, as the conservative field principle still applies.
Sure, that's what I say too. But there seems to be a working prototype that runs itself.... and a patent.
I think MrWayne has come out and said clearly that the prototype runs itself without external power supplied, and produces useful electrical power over and above that required to run its own electronics and air compressor and so on. (I could be wrong about this; I'm just going by what I think he meant when he's been answering questions.) And there will be a team of observers, some of whose names we know, that will be looking it over and reporting, soon.
So it's a mystery for those of us who believe in conservative fields, in the acumen of scientists at the various national Naval Research Laboratories in the East and the West, in the USA and Russia, in China and Germany..., and in physics in general. How can its working be reconciled with what we _think_ we know?
Quote from: Seamus101 on June 11, 2012, 01:13:50 AM
MrWayne is at best mistaken in his beliefs, and possibly now acting fraudulently given that I believe he has an inkling that his system does not actually work as dscribed.
I'd place a bet of any amount you care to mention that any 'overunity' he claims to have measured ( barring ourright fraud) is simply the amount of energy taken to precharge the system with air, or in the case of the fish-tank 'Travis Effect' videos the amount of energy associated with sinking the cup *and* block of cement to the bottom of the tank.
Yes.. to actually generate/consume energy a force needs to be applied over a distance, something that is lacking in any video seen so far.
You make me smile,
We have been working on this for four years - we have been running well over O/U (closed looped) since November 2011 - eye witnesses have reported it here.
In total $500 grand in Research and development - well spent.
I just left a meeting with my engineers, we were reminesing back to when they were hired to prove my system did not work - back then - they told me the same thing you just said - it is a funny
Nice to meet you,
Wayne Travis
Except the fraud part - they know me better.
Quote from: Seamus101 on June 11, 2012, 01:54:43 AM
So describe to me just where you think this source of energy comes from as i completely unconvinced by any demonstration available to me so far. Your video demonstration on you tube of the Travis effect is entirely unconvincing and is easy to refute that it could be a source of energy.
Simply making the appuratus more complex and attempting misdirection won't wash.
Very simple - well forgive me - we have studied it for a long time -
The total buoyancy of our design is equal to the mass discplaced - times the number of layers.
The number of layers reduce the input requirement to activate the buoyancy.
We convert that Buoyancy to hydraulic pressure and volume - it takes one third of that energy to repeat the process - another third is lost in the energy exchanges, and we net the last third.
Where does the energy come from - a super effecient method of making an object buoyant - then stroking and capturing that energy(If you could not see that in the video, well what can I say).
And to top it off - we reuse the exhaust pressure - to supplament the system
So in recap - 100% available - 33% internal operating cost, 33% lost in conversions, Net 33%
Now, I did not misdirect - but you insulted - we do not need unprofessionalism.
This group has been invited to learn of our discovery.
Wayne Travis
It is a bit late for nay-saying,there is a self working model producing excess energy and a patent. It reminds me of the fact that newspapers were still publishing articles to prove that flight was impossible, three or four years after the Wright Brothers flew. And there is still a thick book in our local library proving that man will never fly by pedal power.Time to move on.
A word on dimensions and proportions. If we look at the example of the coiled hosepipe hanging on the wall, each lower half of each turn is full of water. So each separate mass of water has the same volume . So I get the gut feeling that the same should apply inside a ZED. So perhaps it is ideal if all the separate rings of water have the same volume for best efficiency . So perhaps the gaps between cylinders decrease as we move towards the outside of the machine.
The relationship between the diameter of a ZED and its output power is not a linear one. I suspect it is proportional to the cross sectional area. So a small increase in diameter gives a very large increase in power . Sadly, a small decrease in diameter gives a massive power decrease . So there is a minimum realistic size for a working model.
All comments welcome.
@Seamus 101. Mrwayne has already stated the OU is possible with a single layer, however, the COP is only 1.1. So the OU would be lost in the system, for example the friction in an air pump.
@Seamus101. You really need mrwayne to answer those questions, but in the meantime, I will throw in my two cents. In my understanding , which is as yet incomplete, adding layers is basically a way of getting a greater head of water in a compact space. Read and try to understand, in the early posts of this thread, the example of the coiled hosepipe.
I agree that it should be possible to show OU with one layer, but look at the practical difficulties. Suppose we recreate the classical Travis Effect as in the video . So we inject a given amount of air into the cup, using say a hypodermic syringe and a tube . We use a weight to press down the syringe. So we are measuring the input energy. No we are not, because it would probably waste 50% of the input energy in friction in the syringe.
I would actually like to do this experiment, and I have spent much time thinking about it . Here is an idea. Imagine a large U tube, say half a metre high . We half fill it with water. The top of the right arm is now sealed, except for a thin tube which leads to a point under the Travis cup.By adding water to the open left arm , we push air under the cup . We should be able to calculate energy input by what weight of water we add and how far it falls. Very little friction . Output is weight of load x distance it rises.
As for sinking a large object in the ocean , you missed your best chance when they filmed "Titanic."
Neptune said
" I agree that it should be possible to show OU with one layer, but look at the practical difficulties. Suppose we recreate the classical Travis Effect as in the video . So we inject a given amount of air into the cup, using say a hypodermic syringe and a tube . We use a weight to press down the syringe. So we are measuring the input energy. No we are not, because it would probably waste 50% of the input energy in friction in the syringe. "
This is what I intended to do and realized that my syringe has too much friction so decided
to use a bellows/diaphram type air supply. I tried Tom's demo 3 experiment and did not get the same results.
Being puzzled I then took 2 qt containers and discovered that at around the 3 ounce
level line the air provides a good bit of resistance so to test the true Travis effect will require
more air than at the 3 oz level.
I'm still working on the simple demonstration of the Travis principle. When I see the Travis effect I will proceed onward.
Norman
@Norman6538. Hi Norman and good to see you are doing practical stuff. Not all quart containers have the same height to diameter ratio, so you may well have to experiment to find the ideal air volume. They say that great minds think alike, and I was thinking along similar lines, using a balloon as a diaphragm . Things are a bit critical when the expected cop is so small. Good luck, and please post your results, whether positive or negative.
@Seamus101. It is vital to realise that the Travis Effect only operates over a short distance, probably one centimetre in the video example.Once the travis cup starts to rise , and the water level comes up to the top of the concrete block , the effect is finished . So any experiment must make use of this short stroke.
Quote from: Seamus101 on June 11, 2012, 03:10:10 AM
If there is an "exhaust pressure" then perhaps there is an input pressure as well?. Can you absolutely confirm there is no supply of a hydraulic working fluid at a higher head than the exhaust pressure. This would include suppplying fluid at a higher altitude than the exhaust , a supply of pressurised water from a tap, or any other mechanical means (other than this magical bouyancy effect).
The same test would apply to any air in the system.
Thank you,
I realize you have not looked reviewed all that is written: The entire system is closed looped - What I have called exhaust pressure - (and sorry - I see the point of the question created by the term)
By exhaust pressure I do not refer to something leaving the system - I meant the energy still available in the head - at the end of a troke - is transfered laterally - we call the exchange free flow - and since it is the energy transfer during the "down" stroke of one side of the system - we call it exhaust.
Our system have been verified concerning the pressure suspension, increases, and no external energy put into the system - it does not require any external input. - You do have to have the initial water and air in the layers - you do have to start the hydraulics - and the system generates on the first half stroke - twice the fluid consumed.
Wayne
Quote from: Seamus101 on June 11, 2012, 03:35:09 AM
So, if this effect is actually a source of energy then it should be possible to harness it with just one "layer", would you agree? If you don't then the above statement is false.
Thus to convince me you need merely provide a convinicing demonstation of an overunity effect (no matter how small) with this single layer.. I await this explanation with interest.
Hello Seamus,
I really enjoy poping in and shareing - but please take the time to review the Q and A that has already been covered.
We have had plenty of people tounge and checking our system on this site.
To answer your question again, the layering effect in conjunction with the travis effect is required for OU, you break even at three layers on the up stroke -
The reason for failure on all previous Buoyancy attempts: the time to fill and sink eats away from effeciency - it is not a force only calculation.
What you left out of "Work" it is not work over distance - it is work over a distance in certain "time".
The Travis effect merely effects the speed at which the field of gravity - in buoyancy can begin its capture cylce.
The layering system concentrates that effect - you said you watched the video and saw nothing.
You should have noticed the speed at which the reaction to the discplacement overcame the load, and the minimal volume it required. Volume and speed are tied together - and then comes work.
A big mistake all many "tounge and cheek" here have made - was to assume you needed to operate with the same perameters of the submarine type buoyancy.
Well, distance and work is "trumped" with Speed and work - in the Travis Effect.
Look again at video 5, if you do not see anything significant, don't bother wasting your time here.
No effense taken, if you do not do your due dilligense, let us move on.
Wayne Travis
@ Seamus101. The fact that the Travis Effect only operates over a short distance is nothing to do with gravity wells . Think of an internal combustion engine. The piston on the power stroke only operates over a limited distance. If we rebuilt the engine so that the piston could pop right out of the cylinder, all power would be lost after it left the cylinder. Nothing new there . You just need to open your mind a little.
A possible Experiment to measure if OU exists in a single layer Travis Effect device.
We can measure the output by simply measuring what weight we can lift over what distance .
Measuring the input is more problematic.Here is a possible way to do it.
Take a large syringe, and pull out the plunger enough to suck in the required amount of air , say 5 fluid ounces . Take a balloon and inflate it with the syringe. Float it in a fish tank , and by experiment find the exact amount of weight that you need to add to it to cause it to sink such that its centre is level with the bottom edge of the inverted Travis cup. Input = weight x distance you sank it . Job done .
Any comments?
@Webb1. Calling mrwayne devious could be misconstrued as almost an insult, but I am sure that was not your intention. I think what you are saying is that he is very good at "thinking outside the box" and I am in full agreement with that. I too had made the connection between stretching the coiled hose out like a sine wave, and the shape of the path through the concentric cylinders, which is more like a square wave .
But I get the impression that you have seen something above and beyond that. You have had an epiphany, or even a "Eureka" moment, an apt expression when talking of buoyancy and immersing bodies in fluids. Days of brain wracking have failed to fully enlighten me.
My problem is this. In the concentric cylinders, the internal volume increases as the risers and pod lift . Obviously this can not happen in a coiled hose . Nor can I quite understand how a ZED is an extension of the basic Travis Effect demo. I think what may help me and others is this . Would it be possible for someone to draw a diagram of a simplified ZED, having only ONE layer as opposed to three. After all, if we were trying to understand a four stroke engine , we would start with a single cylinder motor cycle engine , not a Rolls Royce Merlin V12 with four valves per cylinder.
By the way, I understood "series charged parallel used " after a bit of thought, thanks.
A single direct question for mrwayne . I am I right in thinking that for max efficiency, the volume of individual masses of water have to be equal, and to achieve this, the gaps between cylinders are not all equal , but diminish as we go from the centre to the outside of the ZED?
Quote from: Seamus101 on June 11, 2012, 06:52:33 AM
It is not too difficult at all.. lets assume the effect is real. In this situation if we connect the two air volumes together with a lever rotating about a pivot we should see that the side employing the 'Travis effect' would be able to continously push the other side down.
What actually happens? the "travis effect" side rises until the pressure on both sides equalises. At this point no further movement is possible. What provided the thrust to provide to move it to this equalised condition.? If you think overunity energy is the answer then there is no hope of understanding even basic concepts of mechanics.
This is right, and is basically the same thing I said in my analysis of the videos. The Travis Effect is due to the compression of the air caused by pushing the cup down over the displacer and represents stored energy. This stored energy is released over the "short range" of the Travis effect: because it is a small compression. The Cartesian Diver video that I linked, as I said, contains many clues to the operation of the Travis effect. There is no mechanism in what is shown and explained in the Travis Effect videos for any excess energy other than that provided by Mr. Hand... all the rest is simply explained by variations in volume and pressure of the gas chambers involved and the difference in the weights _actually_ required to hold the two cups down and the energy supplied by the air pump itself. Equalize the pressure in the two chambers at the start of the experiment by connecting the two air chambers with a small tube, and the Travis Effect will vanish. Since the two chambers started out with the same volume and pressure... and the pressure difference when submerged is the only thing that has changed by the addition of the small connecting tube.... the Travis effect is caused by the difference in pressure caused by pushing the cup down over the displacer, which forces some air deeper into the water. Clearly this is stored energy that is returned as the cup is lifted or allowed to float off the displacer. How could this effect possibly allow any extra energy to enter the system? It seems to be fully understandable from consideration of the pressures and volumes and masses alone, when analyzed properly.
So... I say this: I believe that MrWayne's big system, if it is overunity and running itself without external input other than that required to start it... that first half-cycle-- then it is doing it by some other means than the Travis Effect as shown in the videos.
No offense taken,
I am impressed with the hose anology - you caught on - I told that last year-
I have learned that jumping to the end gets me know where (educating wise)
This system requires more insight than most are willing to afford.
Look at this -
OK I will agree with the figures, but not sure about the formula . I remember from school that pressure = depth times density . The diagram shows 4 columns of water each 12 feet high . So we know that pressure is directly proportional to depth . An equivalent diagram would be a single pipe, 48 feet tall with pressure guages every 12 feet . We know that atmospheric pressure can support a column of water 30 feet in height . [ the limit you can lift water by a suction pump is 30 feet .] So I would expect the pressure at the bottom of a 48 foot column to be about 24 pounds/ sq inch . The formula is this . The pressure at any point in the system is Inlet pressure minus 0.43 x total height of water columns between inlet and measurement point. This formula does not quite work exactly.
I asume your diagram represents a hose so the volume in each column is the same . This will not be true in a ZED unless inter cylinder gaps are adjusted to compensate .
I have said twice previously that we must start at the beginning, so "jumping to the end" will cause problems.,
Quote from: neptune on June 11, 2012, 04:12:22 PM
Bingo!
That is what we refer to as set up - that is the only air put in the system - once..... Make sense now?
A lot of people got hung up on that single point.
Wayne
Thanks mrwayne. Was my formula anywhere near correct, please?
Ok so now we have 4 reservoirs of compressed air . We have switched off the compressor used for initial charge, disconnected it and closed the inlet port . The air pressure in said reservoirs is 5 , 11 , 17 , and 22 psi.
So now we allow the risers to rise . Its a bit like a compound steam engine in that we have different size pistons for different pressures ? And each riser or piston produces the same thrust ? I will say no more until and unless I get confirmation of what I have said . Many thanks.
Dear Seamus,
You are right - I do not talk in your language, I am afraid - if I did - I would probably see as you - you imply for this reason - that I am inferior - I have no reason to be concerned by your opinion.
I would never think to place myself above you.
I do not question your ability, just that your conclusions are extremely premature to your understanding of the system.
You demonstrate you do not understand the system by your comments thus far, many start out that way.
I do undertand our system, very well - I do not insult you for being wrong.
I have asked you for "nothing"
Nor did I ask your opinion - I just welcomed questions.
Thank you,
Wayne Travis
Hello Neptune:
Your on the formula - starting from the outside moving in - the pressure increases (charged) dirctly related to the head and previous head at any given point -
This is not the total hieght x head --- but specifically where the distance is measured (on a connected column of water - inside a layer ) from surface to surface - on that same column.
Little confusing - if one side of the same body of water has six feet and the other has two feet - you have four feet of head ...so 4 X .43 = 1.72 psi
(before I go much further on this - please notice that to increase the head 2 feet - you only need to move one side 1 foot) Big point.
When I said we get 24 feet worth of head by moving three feet - 24 feet were possible - four layers, activated by moving one layer 3 feet - no where else in the world ....
And of course the total head is the direct route to the total force available.
Your in a can of worms now, please ask specific questions around this one.
Wayne
Hey guys,
my guess recording to demo 5 is that even if you have to put in more energy to push down the cup the first time you could harvest that indefinitely considering a system using up and down strokes. I mean in the left cup you would have to remove and add always more air than in the right system once the cup is set in the initial position.
It becomes also apparent in the downward travis effect as once the construction is built in set up you would always have to pump out less water on the right than on the left.
That's how I understood it so far and please point out if I got it wrong. I will look at the patent, too as the drawings so far didn't give me the 'aha'-effect yet.
Keep us updated and good luck.
Prato
Hello group,
Just saw a video of a non aquantince - Tommy Reed.
Here is a link: http://www.youtube.com/watch?v=j2S0taX_1rg (http://www.youtube.com/watch?v=j2S0taX_1rg)
Tommy claims I refuse to answer questions WOW........
I refuse to answer snotty insults laden statements, but never heard from Tommy.
And Tommy states that my generator is powering a hydraulic pump..... from secret wires.
Do ya thing Mark Dansie would have caught that one???
Tommy points to the pressure transducer cables.....
We did not have the generator and motor running when Mark took the video of the Zed system running last November - We have released two videos - with and without the Generator pump running - poor homework Tommy.
The hydraulic MOTOR and GENERATOR was an upgrade for the final critical review.
Tommy owes me an apology, better be quick.
Let me state Publically - He has never spoken to me, nor asked me a question - unless he used a bogus name, Tommy has slandered me, and lied about our process.
I suggest a little homework is done before slandering a good man's character.
Tommy, You have 24 hours to remove that unsubstantiated slander against me, and Apologize - or you
will answer.
You have your fame - and I will follow through, I can back up our claims - with our machine and in court.
Wayne Travis
Wayne,
aoy chance you can post a battery free video ?
I will have my son make a video tracing the wires to where they go - which is directly from the 3 phase ac generator to the rectifier and then directly to the little 12 batteries that power the sensors, record the data - activate the hydraullic valves and power run program. oh yeah and power the light s for fun.
Wayne
Wayne.
With out the battery wotld be just fine.
God Bless
Jim
Quote from: Seamus101 on June 11, 2012, 09:53:39 PM
Does the machine run if you disconnect all these items from an external power supply.? Surely, if it produces overunity energy it would be able to power all these items itself?
The Output of the ZED is Hydraulic fluid under pressure, we use that fluid to both operate the system and the generator which charges the battery - that battery controls and monitors that system.
The system will operate without the pump or generator until the battery no longer power the controls.
Thank you - we are not a magnetic motor (capable of directly generating electricity).
Wayne
Quote from: mrwayne on June 11, 2012, 08:05:03 PM
Hello group,
will answer.
Wayne Travis
It appears Tommy is wise - he has removed the slander video.
Thank you Tommy,
Wayne
Wayne,
where is the live feed ?
"By a happy coincidence this doesn't cost me any more energy to do this as I've rigged up few ropes, pulleys and etxra fabric that allow me to efortlessly change the canopy shape and size at will."
[/size]
Dogs may not normally fly, but parrots do. Ironically, the only time I've ever seen one fly WITHOUT spreadings its wings was placidly perched on a bar of a hang-glider, totally content and deferring maneuvers to his buddy the pilot. Amidst this highly unusual circumstance, the bird did have the good sense to face forward. [/size]
Well, Thank you Seamus,
You have well described the lateral transfer of energy from side to side.
That is one part of our nine part operational process.
No claim of energy production here- it is very important
It does eliminates the energy normally required to overcome the dead weight of the risers -
kinda makes our pneumatics function like a hydraulic cylinder - no need to compress air to stroke.
I say kinda - because - well we lift more per pound of pressure x surface area than a hydraulic cylinder can with the same area and pressure - a lot more (wouldn't be over unity if we didn't).
Just a disposition change between the two systems - setting the stage of the next step.
I am going to presume your pet levitating comments are some kind of inside joke?
Wayne
Quote from: Seamus101 on June 12, 2012, 07:33:29 AM
Well sort of :) ... but if you expand on your comment that
"The Travis effect merely effects the speed at which the field of gravity - in buoyancy can begin its capture cylce." then one is inevitably drawn to the conclusion that the effect could also be used to create levitation as it implies some sort of 'gravity shield' field modification.
I think you are missing the gist of his statement. His comment didn't mean gravity shield, but getting something to be ready and able to fall from the influence of gravity...faster...from a higher point. The counterweights, or return load in this case.
I believe that the gist was that if you can remove the upward buoyancy -faster- then the weights up top can drop on down faster...faster cycling = faster return to next stage. More cycles = more output.
Kind of like kicking out the chair from under a hanging man faster, so he falls faster. Bad analogy, but one can either kick out a chair fast from under them, or deflate a balloon from beneath their feet slow. If you've got a lot of hanging to do, and who doesn't these days, can't have people protesting your gubment and whatnot, then you want a faster reset cycle.
All this here seems to me in a way to be somewhat of a hydraulic energy storage system... a hydraulic capacitor/battery in a way once charged and balancing.
Hydraulic stuff is can be pretty efficient. I recall somebody, can't remember the name who claimed to run a hydraulic motor from a smaller steam or gas engine, and their car went along mighty fine speed on next to no horsepower input. Cannot recall that inventor though...was a long time back. Maybe a farmer/engineer. Can't remember the name or where I read about it. Wish I could.
I have to admit that I am most disappointed at the amount of nay sayers we are getting here. I have made my position clear, in that based on the evidence so far, I am a believer. I fully respect the rights of those who think otherwise. If the naysayers are right, their day will come and they will be free to say "I told you so" as many times as they wish. Even if you think that the odds against this being real are 14,000,000 to one , give it a chance. Let it run its course. Those odds are the same as the national lottery. What you are doing is like rushing into the studio where the lottery is being drawn, insulting the staff, and smashing the machines. And all because you did not win last week and you do not think you will win this week. And yet there is a winner to every lottery . So if you don`t like the odds, don`t buy a ticket . Go watch the football instead.
The time that mrwayne has to spend on the naysayers could be better spent teaching those who would dearly like to learn, rather than trying to get through to those who will never see beyond nit picking definitions, and the Gospel According To Saint Newton.
Quote from: Seamus101 on June 12, 2012, 08:12:23 AM
No, I'm not misunderstanding his statement at all. It may not be obvious to you but this statement implies exactly what I said.
To fall "faster/longer/from a higher point et al and end up with a net gain in energy of the masses involved would necessarily imply a localised change in the acceleration due to gravity during the time the motion occured.
I actually don't think so as you could pump out the air in a container creating a vacuum ONCE. After that things inside the vacuum would fall faster as there's less friction falling and it would also take less energy to lift an object to a certain height inside the vacuum for the same reason or am I missing something?
Prato
Look, here's the argument in a nutshell.
Conventional physics says this device cannot be "overunity"... that is, a net "producer" of energy. This does not require a lot of analysis because it is based on first principles: the _fact_ that gravity is a conservative field of force and gravity is the source of buoyancy effects. The present device confounds pure buoyancy with lifting effects due to gas pressure transmitted through various incompressible fluids, and there are a number of well-known loss mechanisms that are clearly evident in the actual design, yet there is nothing evident in the design that would allow it to operate without replenishing some original store of energy, like the "precharge" with compressed air. This is the default position of conventional physics, a field that many of us have studied in university and which... we thought.... was well-understood.
Now we are presented with a device that, IF it works as described and represented, isn't just a clever mechanism. Rather, the device MUST be "violating" some kind of "law" of physics that nobody has ever been able to violate before, and it's overturning not just some need to plug into the grid for a while, but Thermodynamics itself. "Energy cannot be created or destroyed", remember? This device, since it has no connections to "zipons" or the Zero Point Field or the radio station next door.... must be creating energy that wasn't there before, if it is operating as claimed.
See the problem? This device is OVERTURNING CONVENTIONAL PHYSICS and yet..... it's not being swarmed over by teams of scientists eager to earn a Nobel Prize for the discovery of how to extract useful work from a conservative field of force.
Therefore the "incredulity" level must be high. The bar that MrWayne has to clear, for acceptance, is very high indeed, if he is to be believed. So those who are disrespecting the "naysayers" (mostly me and Seamus at this point, it seems) are really kind of out-of-line. Because it is the NAYSAYERS who are representing the mass of hundreds of years of physics and mechanics and mathematics that MrWayne is attempting to overturn with his simple device. If he cannot convince a bunch of people on an internet forum.... how is he ever going to convince the scientists at GE or Siemens? Look at dealing with the "naysayers" here as good practice.
Which brings up an obvious (to me) question: where are the scientists?
And like I said before... if MrWayne can convince _me_, then I can convince others... much more important others.... to take a real, hard look at the device and its principle of operation..... and if THEY are convinced, then the world will begin changing for the better immediately.
So far, the analyses and drawings and Travis Effect videos have not been sufficiently convincing to me. I suppose that at this point I'd need to see the device itself and poke around a bit, since I'm not seeing any rigorous and convincing mathematical analysis that shows how it would work.
And as Seamus pointed out, if there is confusion about basic terminology like energy and power, torque and pressure, gradients and volumes.... then it will be very difficult to communicate effectively. There is a standard terminology in use, standard mathematical procedures for analyzing systems.... so please, let's not confuse power with energy in our discussions; this has led to major errors and wasted efforts in the past and _some people_ are still terminally confused about the difference.
Quote from: Seamus101 on June 12, 2012, 08:26:55 AM
Picking apart a diagram and pointing out the inconsistencies is hardly nay-saying. If this thing works (and I don't discount the very small possibility that it might) then surely a robust theory of why it works is equally valid to search for.
The problem as I see it is that you have not even begun to search. This is a new discovery, and untill you fully understand it, including information yet to be divulged , you are not in a position to judge.
TinselKoala asks where are the scientists. Do you really need to ask. They are busy maintaining the status quo, not even daring to take a sideways glance at things like this , lest it tarnish their professional reputation, and terminate their fat salaries.
I too have been to university, but some of the most gifted innovators I have met, did not .
A serious suggestion. Why don`t you guys start another thread with a title such as " Why the Travis Effect can not possibly ever work, nor any similar idea, and we are all condemned to a future of cold and starvation"
That way those of us who wish to learn will be in a better position to do so.
OK. Back to technical matters . A basic question for mrwayne. The machine itself is complex, involving several subsystems. My understanding is that the OU happens in the ZED itself. So my question is this.
Can one ZED onits own or at worst 2 ZEDs working together show overunity without additional systems.
If we are using just one ZED, we would need a water pump to supply the inlet, and a way to measure the input energy. We would use a the Zed to raise a weight to measure the output as in force x distance, but the weight MUST be removed at the top of the stroke. It can be replaced again after the downstroke to be lifted again.
My reason for asking this question is this. One ZED , or even two, could be built by an experimenter . Then if OU can be shown at this time, there is the motivation to carry on and build a self running machine.
Quote from: TinselKoala on June 12, 2012, 09:15:31 AM
I think the level -is- (appropriately) high.
I'm still on the fence about this one, appropriately, since I can't see it, measure it, or touch it more than over YouTube so far, and because a) none of these things ever do seem to work in the end, there's a neutrino problem somewhere (meaning a measurement error), and b) I read about it online...where the world is nebulous and funky, and known to be vaporous. I await more news.
Time will tell all about The Colossus of Chickasha.
OMG ;D
I'll send more later when I get time.
Regards, Larry
@webby1. I like your explanation, and your way of looking at it. However there is a little bit of a dilemma here that I can not quite get my head around .
Look at this real life example. Two guys set out on a journey on a flat level road . The plan is to travel until each of them has expended 200 calories of energy. One decides to walk, and the other chooses to ride a bicycle. At the end of the competition, the bike guy has travelled 3 times as far as the walker. This, although true seems strange, because a bike has mechanical losses. We know a bike is not OU. so the only possible conclusion is that walking is a very inefficient form of locomotion.
So if we assume that raising a weight by pumping air into a submerged tank[disregarding pump inefficiency]
is a 100% efficient process, then this must show that the Travis Effect is OU.
In the diagrams the pod, inner riser, and outer riser lift as a unit. Am I right in thinking they are fixed together at the top, but fixed in such a way that air can flow through this join?
@Larryc. Where in heavens name did you get that from?
Do we know what units are used to measure "head"? would that be feet or inches , presumably feet.]
What units are used to measure "Force"? is that really pounds?
Yes it is pounds.
Quote from: neptune on June 12, 2012, 09:42:58 AM
Come on, are you trying to suppress and censor discussion? Put all the naysayers aside, where you won't even look at what they are saying, and prevent them from commenting here? Do you know how typical that tactic is, coming from people who don't turn out to have what they claim?
Even MrWayne himself isn't afraid to engage with your "naysayers", and that is good and appropriate.
Now... on the issue of scientists, status quo, and universities: I assure you, if you gather together a handful of physics _graduate students_ and show them the working prototype that runs on its own, creating energy from buoyancy..... you will immediately have a bunch of scientists crawling all over you, _competing_ with each other to be the first to explain and exploit scientifically the Travis Effect phenomenon.
Scientist careers are made by INNOVATION, not protecting some kind of status quo ante. And they award the Noble Prize not to protectors of the pearly gates, but to people who expand them and make major NEW contributions to knowledge. Your view of science and scientists is simply erroneous. Where, for example, did that fast computer that you are reading these words come from? Certainly not from scientists who were interested in maintaining some kind of closed system. The electronics in your computer work because they are packed in there by people who thoroughly understand _conventional thermodynamics_ which doesn't have any holes in it and which can be used to predict _precisely and accurately_ such things as energy flows.
Or maybe you think aliens gave us the transistor and large-scale integration.
(Fat salaries for scientists? I am all for that.... too bad it hardly ever happens. The scientists who DO make a lot of money do it.... by innovating.)
@TK. I am more than willing to discuss the points you raise.I fully respect your views. However, just not on this thread , because it just gets in the way of people who want to study this, and then make an unbiased assesment of it .
A LarryC. It has occurred to me that rather than having found a new source of info , you have just done some very clever calculations based on info gleaned from the demonstration diagrams. If this is the case, well done .
The only problem with that, is that some info on the diagrams is not to scale, and as far as I can see, that takes nothing away from what you have show. Unfortunately, however, it does not enable us to accurately calculate some further stuff. We can not for instance calculate the volume of water needed for the inlet phase, because we do not know the width of the inter cylinder gaps. That is a pity because if we knew what that volume was [and the inlet pressure which we already know] we could calculate the energy input per stroke .
The calculation of these gaps is, as I have previously stated , is not easy . The gaps have to get narrower as we work from the centre of the device towards the outside , because we want the volume of water in each stage to be the same , and of course the circumference is increasing at each stage. Coupled with that we have been told that the gaps want to be as narrow as possible .
A practical problem I can forsee is this .When building a model , we really need a way to determine water levels in the various parts of the apparatus. I am not sure that this would be completely solved by the use of transparent building materials, and adding dyes to each volume of water .
OMG, the follow up. The OMG was meant as a eureka moment and I am still smiling.
This was not intended to be an example of the perfect system, it is intended for the understanding of how the system is producing overunity.
The spreadsheet was developed on the 8 PSI in the precharge equates to 18.6 of water head (8/.43). The surface diameters were based on the stated fact that the first surface is 30". The other surfaces were based on the drawing dimensions and the stated fact that each lower surface has less lift then the one above due to Travis effect.
I showed the Full Precharge and Full lift as they are the most important to understand. Note that the full lift has more water than the Precharge. This is required in order to maintain the heads, which maintains the air pressure on the inner Riser surfaces as the system lifts. The spreadsheet shows the force produce by each surface. The actual lift force is equal to the difference between the surface above and the surface below.
So as long as water is being forced in to keep up with the lift height, the system will continue to produce much greater lift force than what is required to force the water in (marked in red). Of course this sounds impossible, but the key is that the riser are huge precharged pneumatic cylinders with Travis effect inserts to keep the air requirement down. The water is not lifting the system, only maintaining the head.
Water is almost incompressible. Air is easy to compress and is allready compressed at Full Precharge.
The spreadsheet is included below above the picture, but you need to click on it to view.
Regards, Larry
Quote from: neptune on June 12, 2012, 10:01:50 AM
@ LarryC. So based on your Eureka moment , and your calculations, how would you answer my question above, noting the bit about "The weight must be removed ".
Quote from: webby1 on June 12, 2012, 02:09:23 PM
MrWayne is not getting out any more energy than what is being provided by an interaction with gravity, he IS supplying something :) just like a damn\hydroelectric facility. Build the damn and nature supplies everything else, but you have to guide it through something YOU can take advantage of.
The damn (hydroelectric facility) is a good thought experiment. The flaw is the water coming out after it flowed through the turbine. The water was put in the reservoir behind the damn by solar power (rain, inflow from a river) and then drops through the machinery. The water was higher up before going into the machinery (generator) and is lower down afterwards. The difference in height is the determining factor for the amount of energy which can be generated.
What bothers me most in the Travis concept, is the "closed system". After it is set up, while running, the Travis machine does not suck water or air in and does not let water or air out.
It could let heat in and cool it, but this is not claimed.
To claim it lets "gravity" in and destroys it or makes it lighter, is a bold concept which is difficult to accept.
As far as I understand:
There are two "pumps" in the system. One pump is a "conventional pump or known convection" which transports air from one cavity to an other in order to
reset the system (system is brought to state A). The second "pump" is the "Travis pump" which
sets the system up (system is brought to state B).
The claim is, that
setting the system up costs less than resetting the system (and consequently the net difference can be harvested as output power).
In other words: state B has more energy than state A or at least has the same energy, but going from state A to B (Travis effect) costs less than going from state B back to A (conventional pump or known convection).
And exactly that is not proven, neither by a calculation nor by a self running system. Also the patent application ultimately just states that without any attempt to proof it (no calculation, no energy balance sheet).
I am not very keen on calculations and theories, because they could be false or based on false assumptions. So, let us hope that Mr. Travis can eventually demonstrate a self running machine with some net output. "Self running" would be best, because input versus output calculations or measurements are always very difficult and will always be questioned.
Greetings, Conrad
Quote from: neptune on June 12, 2012, 12:57:28 PM
@neptune, I believe the pod, inner riser, and outer riser do lift together, if properly restrained by the hydraulic accumulator system and not allowed to stroke beyond design limits. But there is no reason for them to be attached together at the top. In the patent I believe it states that they can be separated by spacers/bumpers and this allows for the air gap and geometry shown in the illustrations.
M.
Deleted due to double post.
@mondrasek, thanks for clearing that up.
@Conradelektro. He already claims a self runner with net output. He has said that those willing to travel and sign an NDA can go and have a look .
Wayne,
can you do me a favor and post that as a Christian you will respect my reruest to not involve yourself with my efforts to demonstrate that Johann Bessler who was a devout Christian did build a perpetual wheel that worked.
Thank You in advance.
Jim
Hello Team,
First let me say, We are being reviewed - by the best, you do not get the "best" unless you have demonstrated at least a solid chance of success.
Secondly, I am not on this site - as I have stated repeatedly - to convince you of anything, you have claimed the job for your self.
Nay sayers are welcome if the remain respectful - floating dogs is not, once if funny - repeatedly - that is something else.
If you want to know for sure - get in your car, on a plane and knock on my door - I love sharing our work.
Don't expect that from your insults I am going to feel obligated to you.
We have released our progress and I have spent considerable time sharing our hard earned research with those respectful enough study and ask.
Lastly regarding The Law - we have yet to claim and will not claim "over Ideal" or more than the energy available in the simple physics of our design -
We have very clearly claimed to be able to operate at a lower than we can generate. I have even explained how.
The entire thread on defying the laws is your interpretation of what we have - not ours.
The Travis effect (in its simple form) as Tom demonstrated - had a lower operating cost than the standard - very clear and simple - if you do not see it - well I understand if you do not come.
Wayne Travis
Wayne,
I made a simple request.
Is something wrong ?
The travis effect does not account for back pressure caused by back pressure.
Sorry but not my problem.
Jim
Three answers:
History, the first unit Mark came and checked was a simple input outout system - and we passed - that was in May of last year, so yes. It is a simple measurement of the volume and pressure required for the hydro input - compared to the Hydraulic out put - volume and pressure.
Works just like a pressure increaser - except the out put volume and pressure is greater than the a pressure increaser could produce.
The Second Model Mark tested was Closed looped - we merely bled off the excess fluid and ran totally free - we were not trying to charge the CP battery.
Second Part of the question - yes one Zed six layers is 190% two of the same systems linked 260%.
Out put energy is merely a portion of the "ideal," the ideal is a factor of width and height and number of layers.
The efficiency is not rated from the ideal - we are always under the ideal - efficiency is a factor of comparison to the internal operating cost.
To be clear - let me use this analogy - a six cylinder car - four cylinder provide free energy - two require input - at the end of the day we have a six cylinder engine running self powered with a net free energy of two cylinders. Much less than ideal - but free none the less.
Third Question:
Contact me privately and I will put you in touch with the authorized manufacturer of our Educational demo models - work with him - he is solving the same functional questions.
Wayne Travis
Johhny,
I am respecting the personal request you sent me - no communication.
If you have changed your mind - please advise.
WT
Quote from: webby1 on June 12, 2012, 04:57:57 PM
I chose the Damn analogy *because* we know the ins and the outs of the system, that has not always the case however. Like man can not fly, at the time of that statement many things were simply not known, but we learn.
The "Travis effect" shows an advantage in using a non-compressible item to replace a large volume that would otherwise require extra input to fill, it shows that you do not need to fill the whole volume with your input substance, hence a reduction in costs of operation. I actually have been playing with a movable item filling the volume, just having fun and gaining understanding of the effect and ways of using it, this is making a float with weight sink.
If I use the buoyant value inside an accumulator to move something up and down and all that, have I diminished the function of the accumulator?
Hmmm,,, multi-tasking
I saw a post a while back, and got distracted by ..stuff again.
But if we can get back on track - I wanted to clarify the staging model I sent a couple of days ago -
It showed a weight on top - do not confuse this weight with the load on the system - the load is the Hydraulic cylinder not drawn - we were discussing water levels and pressures - with horrible spelling errors.......
The weights have three functions - (and they do eat part of the Ideal) but they do not add to the cost of the system in fact -they reduce the input costs:
For fun - can you tell me three energy savings from the weight on a two tank system:
To pick on your brain there is four dramatic reductions in the cost of operation directly from the Weight.
I had a science teacher rather sure that I was lost when I disclosed that a single system was 190% and a double was 260% efficient.
She was pretty sure of herself, my own engineer argued with me for two hours until he modeled it -
Not getting all out of your system - just does not compute to an engineer - and hence where the error in the search for free energy begins. The logic is - you must plan to take everything out of a system.. and if you take everything out of a system ---- you have to put it all back in again - you can gain nothing.
But if you leave energy trapped in the system - changes things allot - a non technical term.
Wayne Travis
Wayne,
the request was for no involvement with Bessler.
His work will show what travis missed.
J
Quote from: johnny874 on June 13, 2012, 12:31:01 AM
Wayne,
J
Thank you.
WT
Wayne,
Is it so difficult to say you will let myself and otherr pursue Besslers work without worrying about you involving yourself ?
After all, you are the travis behind the travis effect, right ?
It seems you have a lot to lose. Like I said, I feel sorry for you but you are a grown man and will be able to deal with it.
It is not my mistake, maybe next time if there is one for you, you might listen to what others have to say.
Jim
corrected spelling
Johnny, what seems to be your problem? You are acting as if Wayne is in the Bessler thread bothering you, just as you are doing in Waynes thread here. But I dont see Wayne posting over there.
So why dont you go and work on your stuff, instead of posting this nonsense here?
Get a grip dude.
Mags
@Seamus101. I can not help but respect you are you are obviously educated, and you are a thinker. You have taken the time to analyse this phenomenon, and reached a conclusion that there is no OU here. If you are right, all will be revealed and resolved in time.Perhaps your best plan would be to just wait and see?
@mrwayne. If I understand you correctly, you are saying that the weight is not part of the load. So it essential to the working of the machine, and it rises and falls with each stroke . The net energy needed it to raise and lower it will be small, because what energy we put in to lift it, we get back as it falls. I would guess, but am not yet certain , that when we use two ZEDS, the weights counterbalance each other to a large extent. You say the actual load is the hydraulic system .
OK but in a simple demonstration model, we may want to avoid the complexity and expense of hydaulics.
But we still need a load as we know that the machine needs a load . Could the load be a mechanical ratchet system used to constantly raise a weight? By that i mean a "new" weight, other than the weights mentioned previously.
Quote from: Magluvin on June 13, 2012, 08:04:03 AM
Get a grip dude.
Mags
Mag,
Me and Wayne have pm'ed some. Something he said to me.
I guess though it is unfortunate I went to school to understand systems like this.
Compression creates a low pressure high velocity discharge. Engineers have worked with this for years.
The reason it becomes high velocity is because of the back pressure caused by compression.
I was going to say that when he sees what I will be demonstrating, he can build it. Of course, what is
not understood about Bessler was that he was using his work to demonstrate his faith. He used 3 crosses
placed around his wheels as a "sign" to have faith. Some how, everyone has missed this clue of his. It could
be they lack the discerning mind he says a person needs.
And one thing I could be missing is he might not be able to work with his hands.
Sorry Wayne, Happy Hunting :D
Quote from: neptune on June 13, 2012, 08:50:31 AM
The load can be what ever you desire - pump water, turn a ratchet, hydraulic pressure - but without a load - the system will simply rise without building head -
Larry was dead right when he recognized the diference between continually adding head - to do work, and simply raising the water level (where the head already exists).
Larry has taken a big jump in the right direction.
When you add a weight to a spring, the weight compresses the spring to a point of equalibrium, then the work to lift the spring is related directly to the weight of both the spring and weight -
The point is energy - is not added to compress the spring any more - as you travel.
On the reverse - when you take the load off the weight - at the end of travel - the spring will expand - which direction it expanded depends on the capture device.
Our system has a Hydro pnuematic spring.
Quote from: johnny874 on June 13, 2012, 02:15:44 AM
Wayne,
Jim
Jim, I just wanted to point out (again) that if Mr. Wayne's device is proven to work and that it is harnessing the Conservitive Field of Force known as Gravity, it gives validity to Bessler's wheel like never before and there may be many times more individuals interested in that. Me included.
You believe that Bessler also used buoyancy, but others (like myself) do not. So I would be looking for what fundamental underlying principle could be used without a fluid that could be derived without buoyancy to cause a Conserative Field of Force to be used to do work. The guys playing with magnetic fields would also be searching feverishly for this underlying principle.
So asking Mr. Wayne not to try might be the least of your concerns if your goal is to be "first" to replicate a Bessler type wheel.
M.
@Mondrasek, a very perceptive post. I always sat on the fence regarding Bessler`s wheel. But I believe that the first OU device to make it to market, will have an effect greater than the sum of its parts. Not only will it provide affordable energy, it will change the whole human perception of energy and indeed physics. In short it will be the first white crow that proves that not all crows are black. Suddenly , there will be fever of white crow hunting like never before. In the initial hysteria, white crows will be seen everywhere . But as things settle down, we will be able to separate the Magic from the Tragic. Then, who know, we may find a breeding pair...
@Mrwayne. I have re read all your posts over again and will do so several times, because to fully understand everything you have said, it helps me. Regarding models , you built a machine to show input and output, which I believe was the first machine seen by Mark Dansie . You refer to this as a "Table Top Simple System" which might be a good starting point for the home builder/experimenter. Table top implies fairly small . Could you give a rough idea of the size of the ZED please, and if possible the number of layers. was it three?
Suggestion. The ultimate teaching tool in understanding this phenomenon would be an Animation, with commentary on what is happening at each stage. Perhaps someone with the necessary skills and soft ware could consider this ? Every picture tells a story .
Thought I'd show what could be done using the 1/8" thick acrylic tubes available from McMaster-Carr. Since they have every size covered in 1/8" increments from 6" OD on down to 1.5" OD I think a fairly small model could be made, though it would take some expense, expertise, and equipment. This drawing shows a three layer ZED only, but more inner layers could be produced. The tops and bottoms of members are 1/4" thick sheet to allow for vents and fill tubes to be more easily fitted. But this gives the idea of the scale and possibilities with commercially available acrylic.
M.
Quote from: Seamus101 on June 13, 2012, 05:43:32 PM
I would argue that your system IS a Hydro pnuematic spring, and is not any more than that.
As springs do not provide overunity energy where does the claimed excess come from? No explanation given so far holds any water.
A spring can be used to move a certain amount of a fluid at certain (decreasing) PSI if it is allowed to act on a fluid reservoir such as a cylinder filled with said fluid.
Can the volume of pressurized fluid that the spring can move create a combined buoyancy force on several nested risers (a la the Zed arrangement) such that the energy that is produced by the resultant buoyant force is more than the energy that was initially stored in the spring?
I'd apprecite more than just talk. Please show some diagrams and equations to explain if you can. I know this is a very demanding request, but it is hard to follow just your rhetoric. Some graphical and calculational examples of why you state it cannot work would be most helpfull.
Thanks in advance.
M.
Suppose you build a table top model using the nested acrylic tubes, the patent, and MrWayne's helpful explanations.... and it works, and you can show it self-powering for hours on end, turning a little generator and lighting some LEDs. What then? I know exactly what I'd do. I'd grab MrWayne, the model, and we'd all go together to see some friends of ours, and the world will begin changing immediately.
But what if the model doesn't work? Did you get the clearance between parts A and B a thousandth of an inch too large? Did you use the wrong kind of glue? Is there a tiny leak somewhere? Need different water?
My point is, the model building is an interesting exercise. What is it for? A null result (failure to operate or no overunity operation) proves nothing at all. You could have been holding your mouth wrong, or a million other reasons why it won't work. (Of course... there is one real reason but we don't need to go there right now.)
And if there is a positive result.... won't that just be repeating work already done by MrWayne's engineers and builders? The device in the video is not "kludged" together: it is clearly the end result of a process of development. Somewhere along the way the engineers will have built a small version for testing the principle.
Where is this small version now, and how was it constructed, exactly?
TK,
I completely agree. The model building will not be a validation of anything so far presented. I only thought it would be neat as a visual aid for teaching, if it is a working device. I'm not trying to push it on anyone. But since Mr. Wayne has offered to pay for the expense of the materials if we do a group build, I thought, "Why not?"
I think the maths are simple enough (so far) that we could either witness or not the OU without resorting to debating dimensional discrepancies.
But (again) you are correct. If it didn't work, it would be easy to look for some minuscule difference in the replication that possibly changed the outcome.
I do not think that a replication in table top form is necessary. I just think it would be fun (if not costing anyone too much capital).
I ask again (earnestly), would you build? If you didn't have to pay for materials?
I'd be happy to CAD (know you don't need it) if you want. Just in case proportions are more important than I think and we can't receive better dimensional advice.
M.
Quote from: mondrasek on June 13, 2012, 09:31:44 PM
TK,
But (again) you are correct. If it didn't work, it would be easy to look for some minuscule difference in the replication that posibbly changed the outcome.
I do not think that a replication in table top form is necessary. I just think it would be fun (if not costing anyone to much capital).
M.
Hi guys,
for your information, there is a Russian website which actually explains in details operation of the O/U hydraulic engine:
http://ut27972.narod.ru/Book_2/70_Book_2_part_70.htm
http://ut27972.narod.ru/Book_2/71_Book_2_part_71.htm
http://ut27972.narod.ru/Book_2/71_Book_2_part_73.htm
http://ut27972.narod.ru/Book_2/71_Book_2_part_74.htm
Alex
You would argue if I said you were smart.
Well, I don't read Russian as well as I should but I can see already that there is a problem between Figs 1 and 2 in the first link. The water height "h" is shown to be the same, but if the figures are showing what happens when the ovoid shape is pushed into the water, that's wrong. As the shape is pushed under the water from the floating position in Fig. 1, the level of the water "h" will rise... and it is the lifting of this water which provides the buoyant force.
TK,
M.
A working replication from an outside source is awesome -
@Mondrasek: I might be tempted to build something if there was an actual verified design, but right now I don't have my machine shop set up and the nearest one I can use involves a couple hours drive, so I'm not really too interested. Plus, two thousand dollars might buy some basic materials and pay for some expenses, but anyone can tell you... and I'm sure you yourself know.... that this won't buy very much of a skilled machinist's time, much less the time of skilled design engineers. It would have to be a labor of love, and I don't love this particular labor.
There is a _lot_ of time and money spent on the machine we saw in the video. This is one reason why I cannot understand what is going on here, nor do I understand why MrWayne is making the two thousand dollar offer. If it already works, then it seems that this effort would only be useful to convince a few hobbyists and forum posters. But this effort _does_ make a sort of sense if it is looked at as sort of a "Steornish" effort at distributed development of an idea.
It would seem to me that CLaNZeR is much more in a position to perform this work than I am, but he doesn't seem to be interested either, for reasons of his own.
Hello All,
You may Reach me at mr.wayne@hydroenergyrevolution.com
I will ask my Web designer to add a blog to my site which will be a safe zone for positive discussion.
Thank you and Good Bye.
Wayne Travis
I agree with Tk, I had the same thought, at some point wayne must have had a smaller demo version built and running before spending the money on a larger version.
So, just show the demo running on a live feed, why not?
Or, invite Tk to inspect the current machine (under NDA), if he says its works, watch the investors queue up and make wayne a very, very rich man...
Clanzer would ideal for building a demo unit, but I think all his time is being used to set up his CNC manufacturing factory.
Quote from: Lakes on June 14, 2012, 06:07:21 AM
i doubt that venture capital investors hinge their decisions upon the opinions of some anonymous flamboyant marsupial internet personality from a fringe science forum... ;)
Again this guy is not going to fully Open Source his machine.
History will once again repeat itself and this “break through†will be lost just like many others.
Our current corrupt Government will NEVER let a self-sustaining free energy machine be commercialized. Remember Tesla? Government will lose control of the people if it happens…
So far there is NO concrete Open Source evidence how this machine works.
Yeah go hide in you safe room where you belong, you will be doing us (most of us anyway) a favor!
Now who really wants to save the world? Open Source it! Or fuck off!
Quote from: TinselKoala on June 13, 2012, 10:45:34 PM
I will try to explain briefly what I have understood, but first the name of the author is Mr. G.P. Perveev, ut27972@yandex.ru , ut27972@narod.ru (no disrespect for
mrwayne)
According to him, the principle is very simple.
First of all, the submerged body doesn't have to exit the water, so the water level doesn't change.
The body's volume is such, that it takes a very small amount of an additional water to have it to sink when it is close to the surface, or a very small amount of air to rise, when it is at the bottom.
Think of a submarine!!!
Basically we may have a body with a fairly large displacement, say, 10 tons, but because it is balanced in this way, it takes a very little energy to make it to go up or down.
So, if we have a 10 ton body at the bottom of 1 m vessel, and it takes it 1 second to rise, the power produced will be 100 kw!
Needless to say, that the body doesn't have to weight 10 tons, but it can be connected to the load with the weight of 10 tons by the mechanical means.
Alex
Quote from: microcontroller on June 14, 2012, 07:23:09 AM
Offcource this isn't correct.
It will only be 10 ton when you empty it completly and it will sink, or when you put in enough air to make it rise at 10 ton.
In the little water little air example you will only get the differential force you create so this would be the same for a 1 gram piece and a 10 ton piece it all depends on how much water/air you pump in and out not on the weight of the actual container.
So is this now claimed to be the new travis effect or what?
The work is done by the displacement according to Archimedes.
Little air/water just to make it to move.
Like in here:
Hello,
I am unimpressed with you limited interpretation - of my decision to leave this forum.
Some of you have offered continual interuption, disrupted disc cussion.
And the most intelligent thing you had to offer was - "I see nothing".
The only thing you have succeeded at - was to keep those who actually "See"
from learning how the system works.
Once Again - what I offered freely - you wasted your time trying to stop, you wasted the forums time, and the time others gave to follow.
One day, you will see the futility of your desires.
We have finished what you are afraid of, the world is welcoming our discovery - as we speak.
You assumption that your actions interfere with the success of our
Certified Over Unity device - they are like the rest of your comments.
You jump to conclusions without listening, understanding, it is fear, pride, envy, ego, I have no commitment or promise to you.
I do thank the others, and appreciate all of the letters, intelligent questions and respectful correspondences - we have more than words, we have the the real deal ;-)
"Roasting" - only works if at least part of what you say is true - claiming that which you do not know - is something else. It won't work, I don't believe, I see nothing here....is not roasting - it is opinion.
Good day.
Quote from: TinselKoala on June 13, 2012, 10:52:38 PM
@TK, I understand. If this was only 10 years ago when I was still doing design and project engineering and constantly "in the trenches" with my own machinists who would let me use their equipment without a second thought. But times and employees have changed and our shop is now locked up or under guard and I am no longer known to the new guys.
Here I sit in the tooling capital of the US, surrounded by machine shops. But no one I know would produce the pieces for a model for free. It would deffinitely require someone who has the equipment, time, and the "love."
@all, I doubt Mr. Wayne would have made any of his test models out of acrylic. He would more likely have been working with metals, and just like with the videos, ended up with devices where you cannot "see" what is going on. Even looking at one in person would not help anyone to understand. Many would not understand the operation even if they were allowed to witness it being taken apart, re-assembled, charged, and started back up.
Even in acrylic it may not be possible to see clearly through the multi layer design, even if different color tints were used on the different moving parts and fluids. But it would be more convincing than an annimation IMHO. The ultimate teaching device would probably require a model *and* an annimation.
M.
God I hope and wish what you have is real and true wayne, we need something to get us out of the hole we are in.
You have to understand those of us who have been here for a while have had our hopes dashed too many times, so we tend to skeptics when we see something new.
Quote "Certified Over Unity device" unquote, certified by who?, have you had a university look at this?
Quote from: telecom on June 14, 2012, 08:16:44 AM
Like in here:
AB Hammer had an idea using weighted floats, he wasn't willing to try and work wtih the design.
With even a submarine, it is the density of the mass relative to water which determines it's bouyancy.
All this means is that if you have a cylinder expand with empty space (not a vacuum, inert gas?) inside of it, it's density will become less.
Would have to wonder if this would allow enough lift to allow for the work being done, expanding the cylinder. It might be possible.
Quote from: mrwayne on June 14, 2012, 09:04:33 AM
Hello,
thanks stefan... for not moderating your forum... AGAIN. ::)
Hi Microcontroller,
I see your point - basically it will take the same amt of energy to bring load down as up.
will keep browsing through his website looking for an answer.
Alex
Quote from: WilbyInebriated on June 14, 2012, 06:22:15 AM
I'll have you know, Wilby you meatball-challenged pasta chef you, that I had my pouch surgically removed as a child and no longer associate at all with my marsupial relatives. Besides, where I come from, a person's marsupiality-- or lack of it--- is not considered a topic for polite discussion.
But then nobody has ever accused you of being polite, have they, you flesh-colored crayon-scribbler you.
Now... do you have an on-topic comment to make about the veracity, or lack of it, of a buoyancy drive that runs of itself? No? Then stuff this in your pouch and incubate it.
You know, some days I think I have selected the wrong forum . I was under the impression that this was an OVERUNITY FORUM. All I have to go on is the title. If I am right , then this is not the "Overunity is impossible" forum.
I make no secret of the fact that I am an Atheist. No big deal. But I do not waste my time interrupting church services, and being rude to the local priest. I respect him. He has his ideas, and I have mine.
Back around the year 1890, the then chairman of the Royal Society, proposed a motion. His motion was that the Royal Society should be disbanded, on the grounds that all the scientific discoveries had now been made, and everything was now known. That guy is no doubt dead now . But I seem to recall that we have discovered one or two things since then. Dead he may be, but his spirit and philosophy is alive and well.
Mark Dansie is a well respected sceptic investigator who has seen this device with his own eyes . But we have people here so gifted that they are better qualified to judge, even from several hundred miles away. At least in their own eyes.
Does it work? I do not know yet, because I have not yet learned all there is to know about it. But I intend to go on learning. The evidence so far looks promising .
The laws of physics are the summation of what we have learned up to now. Assuming there are no "holes" in them takes us back to the arrogance of the 1890s.
"Give instruction to a wise man, and he will become yet wiser"
Hi Mr. Wayne,
Thank you for sharing your idea here.
TinselKoala and Neptune bring up some valid points on the difficulty of fabricating a small model. If there are no takers to build maybe you could have your engineers develop a small working 3D model of it and put it up on Shapeways (www.shapeways.com). A 3D printed model would allow for some tight tolerances.
Lakes,
it's possible he might have built it before doing any testing. The lack of gauges showing pressure, volume of flow, etc. are missing.
it's that type of information that would dictate the development of an idea such as this. Wayne did mention that he was adding data collection devices to obtain this information as someone he knows suggested it to him.
I think if he would have done so that he would have found out that by compressing hydraulic fluid, it slows it's flow rate which diminishes the work it can do in the way he is trying to use it. With hydraulic theory, it's potential is increased by low pressure acting on one side of a piston and the opposing piston acting on the hydraulic fluid has a smaller surface area (edit) but has no extra travel. Volume is being exchanged for pressure. (end edit). His device uses compressed air to act as a piston. I think what he might not have understood is this information. For me, I think if he spent more money without doing actual testing that the costs he incurs might cause him more problems which he wouldn't need. And not all those costs would be financial.
If he really wants to try something that might work, he might consider a weighted float. As the Russian guy mentioned, it could be quite heavy which would have a lot of potential. Any way, Wayne can think about it. But as some have mentioned, this is supposed to be a Research Forum.
And as for Stefan's moderation ? His being patient might be seen as a good thing by some. It allows idea's and discussions that might not other wise be allowed.
Quote from: telecom on June 14, 2012, 10:54:03 AM
Hi Microcontroller,
Alex
I found out how he does it - its here:
Basically, he is using a variable displacement piston.(In yellow color, consisting of parts 1 and 2)
During the down stroke, piston is kept at the minimal displacement (part 2 goes inside of part 1). This allows for extra liquid to get in.
After reaching bottom the piston expands, and due to its increased displacement it rises up.
At the top position part 2 gets pushed in again.
The o/u is the excess liquid equal to the volume of the part 2 of the piston.
"Basically, he is using a variable displacement piston.(In yellow color, consisting of parts 1 and 2)
At the top position part 2 gets pushed in again."[/size]
[/size]
Ever heard of ELSA? Your description of the Russian device apparently uses the same mechanism that was presented by John Herring with his ELSA--albeit in a much less sophisticated fashion--9 years ago. I believe he has died since then. [/size]
The mechanics of part 2 getting pushed in again at the top position is where he lost me.[/size]
[/size]
http://www.icestuff.com/energy/elsa/
Quote from: Cisco on June 14, 2012, 12:46:19 PM
[/size]
[/size]
Hi,
will gladly look at Elsa.
According to the website, during the rise, while smaller part of the piston (2) reaches the top, bigger part (1) keeps moving up,
this is what causing part 2 to collapse into part 1 of the piston.
@johnny874. You said "If he wanted to try something that might work, he might consider a weighted float"
Can you please explain why he could possibly want to try something the "might work" when he already has something that does work?
Quote from: neptune on June 14, 2012, 03:22:31 PM
Neptune,
I did mention specific principles in engineering which I think he has not considered. it is merely a consideration of the facts. Compressing hydraulic fluid will only allow for a conversion of it's potential. This is one problem with a closed loop system.
If he made the mistake of building before doing testing to verify potential did exist, okay, so he reacted a bit more than he should have. But in research, sometimes it's best to start over at the beginning and do the basic tests. I think he'll find any increase in the height of the static head results in less work. This is because compression of the hydraulic fluid reduces the volume that can be pumped in a certain amount of time.
With a submarine or weighted float, having one weight drop on another would close the space between them increasing the density of the structure. When the device plunges deeper in water, the top weight can be caught and held while the lower weight continues it's plunge. This would open the device decreasing it's density and increasing it's buoyancy. Basically playing it like a yo-yo. It would need some mechanics or what ever to control it's function but might be a simple idea that could be tested with pvc pipe, weights, plastic and some plastic glue and a trip to the beach or lake and see how it responds ?
But then, something like that would have come from different peoples idea's. Scientists have even tried floats on top of the water to harness wave energy, but they never thought of sinking it.
Still, would be something for you guys to talk about if you want, and who knows, Wayne might like the idea. And since I have some things to take care of before I get to pursue my favorite hobby, will take that break I need and if you guys like the idea, it's all yours.
Jim
p.s. in this very basic concept, if one pvc tube goes over another, plastic can be used to seal it like an air shock so if the is a gap between tubes, it's okay. All it would be is a start if you guys think it's worth considering.
edited to add; with fluid systems, it is possible that increased pressure also increases adhesion and cohesion. With a collapseable weight, it is changing it's potential to a body of water or outside force.
basically, perpetual motion or overunity is considered impossible because a mass or an object can not change it's potential relative to iteslf or it's closed loop system.
@All,
PiR^2 H is the volume of a cylinder. There are 28.3^3" in a lb. of water. Basically, 3.14 times diameter times height equals volume.
By placing and end cap on both ends of a pvc pipe, you can see how volume changes
buoyancy. The pipe might leak a little without glue, but it would give you an idea.
A 2 1/2 lb.(dumbell) weight going by the numbers would need a tube that has a volume of
about 70 cubic inches to float. A simple test to understand buoyancy and mass. Cut the pipe in half
and see how it starts to sink, then you'll get it.
With a collapseable weight, the water it is in as well as gravity would be acting on
it, 2 other forces. This means it's not a closed looped system but would take advantage
of gravity and the density of water.
I guess in a way it's up to Wayne. Myself, I know there is a lot of pressure to prove
something yesterday, have experienced it myself.
With something like this, everyone would be in the loop from the beginning and would be able to test
different parts of it themself. research isn't free so if you need to spend 10 or 20 dollars to try something
yourself, why not ? Then you'll better understand what is being discussed.
as for myself, talked to my surgeon today. The best scenario is after he knows what it is specifically, I
would only miss 3 more weeks of work. Having a CT/PET scan next week. Not so good would be they
take my guts out again and give me lots of morphine, worst case, you don't need to know :(
So do think I'll take it easy. But maybe one of you will give this a try.
Jim
Quote from: Seamus101 on June 14, 2012, 08:33:09 PM
Here is my solution to improving the output energy of this device. Rather than use air in the cylinders, why not use a substance capable of undergoing a phase change during the expansion and compression cycle. Ammonia perhaps.?
As the Zed compresses the ammonia it will liquify, taking up far less space than it did before. That contraction could be used to displace FAR MORE water than merely compressing the air could achieve. More displacement = more lift !
I'd imagine such a machine might be able to apparently produce 3 times as much energy as it does now. It would achieve this energy gain at the expense of cooling the water and heating the ambient air, but there are plentiful supplies of those two things, right?
I'll order one from the first person to build such a device, I need to keep some champagne cool for the launch party.
Another way of doing this would be to increase the density of the fluid, for example,
dissolve lots of salt into it.
Quote from: Seamus101 on June 14, 2012, 10:10:01 PM
But then you'd need a supply of salt and a means of drying it out.. This only needs air water and a smallish amount of ammonia.
It's ok though, don't need go investigating the idea too closely as I've already managed to find people selling them. It has a COP > 4.
just meant that by increasing the density. it would be possible to increase buoyancy forces = there is no need to dry anything.
There is nothing wrong with your idea, but under what pressure it liquefies?
I am a bit confused about what has happened on this thread. OK there are some interesting ideas and theories being discussed but discussion on the original subject seems to have disappeared. Perhaps these ideas and theories would be better discussed on their own threads. Hopefully those who still wish to learn will be able to do so elsewhere, and I have got my name down.
Why do I think this idea merits study? I am also very interested in stuff like Quentron, and Rossi`s ecat. but You are never going to be able to build either of these, even in model form, in your garage. That is what makes Wayne Travis`s idea special. "Boiler Plate Technology" he calls it.
My biggest difficulty in understanding this, was that I could not see the connection between the basic Travis Effect concept and the ZED. As a result of some things said by LarryC, I am starting to understand that connection.When I really "get it" I will share with anyone who is interested.
Do not lose sight of the fact that Mark Dansie has endorsed this, and is impressed enough to arrange to go back in the future for further tests.
There is a bit of confusion, in that Wayne says he will not open source. And yet there is the patent , and Wayne`s answers to questions. I think there is enough info to build a model that will prove OU. It will not power your house, but will show that the theory of thermodynamics is not without "holes".
Quote from: neptune on June 15, 2012, 08:25:28 AM
Hi Neptune,
I think we were able to discover original ideas which were used for ZED.
The main idea is the variable geometry buoyuncy piston, which was described in ELSA and in a Russian website.
I want to come up with some formulas to confirm everything (this should't be hard), and than we could build a demo version.
Nothing to worry about.
Alex
After digesting Mr. Wayne's One+Zed+through+complete+cycle.jpg I realized that finding the starting configuration of water and air in the collapzed ZED would be problematic (for me at least). So I decided to try and start with an ideal case where the ZED model I showed earlier was already stroked upwards the maximum of 2 inches. Hopefully I can figure out how to work backwards from here.
M.
Here is an attempt to remove 5 in^3 of water from the center section of the ZED (as if transferring the water from this ZED to a second unit). Some interesting things happened:
1) The Pod and Outer Riser are still buoyant enough to overcome their own weight and want to float.
2) The Inner Riser is no longer buoyant enough to overcome it's own weight and wants to sink. It is almost now heavier than what the Pod can support with it's buoyancy, so both of those members may sink a bit more than shown in the diagram until the resultant increase in buoyancy of both members equals out their weight.
3) The pressure of the air inside each riser dropped due to the dropping water column height and would therefor allow for some expansion which is also not shown properly in the diagram. Truth be told, I do not know how to calculate the balance point for all the air expansions and resultant water level changes. I could get close by doing this iteratively but can't fathom putting in that much effort. Proper parametric equations would be the way to go.
4) The Equivalent Water Column Height dropped dramatically for only removing 5 in^3 of water. This is mainly because each water head is not just dropping, but is rising into the next inner air chamber and thus decreasing head pressure at twice the rate of drop. I believe this is significant.
Interesting exercise.
M.
Travis has kindly helped me to understand how the Total lift force is calculated in the system.
The relationships are not exact, but fairly accurate and can be analyzed to help the model builders.
The PSI in Riser 2 seems wrong, but it not incremented to account for the downward force that Riser 1 adds to the system. The total head in the system is actually 14.4.
The Pod is Archimedes's.
The xls file is right above the picture.
Enjoy, Larry
@LarryC,
Interesting. I seem to have missed that the buoyant force in each enclosed Pod or Riser also needs to overcome the downward force from the pressure of the air in the chamber in which it is rising. I'll have to redo my calcs.
Thanks for that!
M.
Mondrasek,
In your Extended ZED Model, you "decided to try and start with an ideal case where the ZED model I showed earlier was already stroked upwards the maximum of 2 inches."
Back in Post 321, Travis had written "Diameter of the inner chamber will dictate volume needed - keep your stroke length short - no more than one inch - (trust me) - will explain later."
OMG. Positive discussion is back, great . Can I just ask, Is 5in^3, just a way of writing 5 cubic inches?
@mondrasek. In item [4] in your last post, you mention "decreasing head pressure at twice the rate of drop" and say that you think it is significant. Indeed Wayne mentioned this earlier in a sort of obscure way .
It is probably a bit early, but has anyone considered the problem of interwall gaps. Does anyone agree that the volume of water needs to be the same in each section , in spite of circumferance increasing as we move from the centre towards the outer wall. Ultimately we need a formula to work this out , taking wall thickness into account .
@Cisco,
Thanks for pointing that out. But I don't think it matters right now, since I am just trying to figure out the dimentional relationships of the members. I think you can start at any level, but then (in my case) you need to lower to the point where the ZED members becomes neutraly buoyant. The volume of water needed to do this should be 1/2 the volume that needs to be exchanged bertween ZEDs for operation. This will define the actual stroke needed and the outside wall and rings attached to the bottom member can then be shortened to elliminate wasted material and uneeded water volume. At least that is how I was seeing it before realizing I need to adjust my Buoyancy forces by subtracting the down force of the increased air pressure. BTW, an initial look at that makes me think that my proportions are not correct. I think all of the members are too tall, but I need to do some more checking.
M.
Quote from: neptune on June 15, 2012, 11:57:00 AM
Yes sir.
I have not yet committed to needing the same volume in each annular section yet. But you may be right. I believe I have another mistake in my diagrams and calcs on the -5 in^3 due to only ajusting fluid level heights when they do have different volumes which makes that wrong. If they had the same volumes then that would have been okay. But I will have to check if just calculating the volumes properly is okay or if the same volumes are a necessity.
M.
Quote from: mondrasek on June 15, 2012, 11:38:31 AM
Thanks for that!
Hi M,
Nice work. But think Wayne, he's the genius, I'm just hanging on for the ride and loving it.
The pod is not effected as it is Archimedes's, so the volume or pressure differentials can be used for the calculation.
For those that don't have a spreadsheet and want to understand the calculations in the spreedsheet file, OpenOffice can be downloaded for free and it has most of the Microsoft Office applications.
The total force is without the system losses. But think of it this way to help understand the great potential, allow that force to lift the external load 1 MM, then the water inlet refills that 1 MM and it only sees the water head.
Regards, Larry
@LarryC, after thinking about it some more I think what I had done originally is fine, since all my Bouyany Force calculation were based off of the head pressure differentials, so the internal air pressures are already accounted for. So now I'm having trouble understanding the spread sheet you have. Could you draw up a diagram to explain where the dimensions and especially the "Next layer" are refering?
M.
Corrections to my previous diagrams and calcs when removing 5 in^3 of water from the full ZED model. Everything is still buoyant, so I may try and see what happens if a few more in^3 are removed.
The air expansion due to lessened pressure is still not being accounted for accurately.
M.
Quote from: mondrasek on June 15, 2012, 02:36:54 PM
This is faster, but let me know if you need more.
The Next layer at 10A is the top outside surface of Riser 3. The Next layer at 13A is the top outside surface of Riser 4.
The Height of all water channel are generalized at 100 inches, same as the pod. The miner clearance between risers and pod are not considered as they would not make a significant difference in the force calculation.
Riser 4 is 2 inches in diameter larger than the pod. Riser 3 is .9 of 2, and so on.
Regards, Larry
Quote from: LarryC on June 15, 2012, 12:44:33 PM
Hi M,
The total force is without the system losses. But think of it this way to help understand the great potential, allow that force to lift the external load 1 MM, then the water inlet refills that 1 MM and it is only sees the water head.
Regards, Larry
That last paragraph says it all. I am not 100% sure what system losses are involved. In a working machine there would be lots of losses, but if we are just talking about a ZED on its own those losses are going to be small. We need a pump to inject water into a ZED, which might consist of say a large syringe pushed down by a weight. That would involve some friction in the syringe. Or we could use a vertical pipe full of water with a valve at the bottom and a suitable head of water . Less losses . The losses within the Zed itself would be very small.I think what I am trying to say is that this device, on paper at least looks very promising indeed .
I make no claims to be a mathematician, but I understand basic maths. I am just Gobsmacked by the amount of info that you guys have derived from next to nothing. One can not help but be impressed by the large forces in a model so small. Well done lads .
It seems to me that there are two main problems in building an efficient model of a ZED.
1. Knowing what the water levels are in the various parts of the ZED , especially during set up.
2. The smaller the model, the closer tolerances it will be necessary to work to. This will be mitigated by the fact that initially we are not trying to build the most efficient ZED ever. One would probably need to compromise between tight clearances and ease of building . Since we are not talking of a tiny amount of OU, there would seem to be some room for compromise .
Quote from: neptune on June 15, 2012, 04:05:10 PM
Hi Neptune,
can you or somebody else describe the operation of ZED, the cycle itself. I can easily now understand it for a variable geometry piston machine, but not for this particular machine.
Alex
@telecom. I have yet to study the variable geometry piston. There are still parts of the actual cycle that I am struggling to grasp. I suggest you read reply 525 on page 35, as this is one of the best aids to understanding , as it takes us step by step from the basic Travis Effect to the working of a ZED. Having understood this, then the original sequence of diagrams by mrwayne will start to make more sense.
The most telling thing about this device is that the resistance to the water injected is only the head of water it has to resist. And when that water is sucked out again as the load falls, it still has half of its energy recoverable. Mathematically, it seems to stack up perfectly. No one can say specifically where the excess energy is coming from . At this stage , that seems to me unimportant.
To sum up, I have spent ages studying this, and for me there is no Eureka moment , just continuing small steps in understanding .
@Neptune
Reply 525 on page 35?
Just a quick update on what happens if I take 6 in^3 of water out of the model I've been studying. The Inner Riser looses so much buoyancy that it will begin to sink. It is now heavier than even the Pod can overcome at the fully extended level that the analysis started from. BUT, lowering the Pod and Inner Ring only .05 inch back into the water made them buoyant again.
So here is where this method of analysis ends, I think. I would have to do several iterations to see just where between dropping only .05 inch and not dropping at all that the balance point for floatation of the Pod and Inner Riser exists after removing 6 in^3 of water.
BTW, at this point the Outer Riser is still buoyant. So everything is not sinking yet and I have not found the half way amount of water volume that needs to be exchanged between two ZEDs of the geometry I am studying.
Just a reminder: I am studying this geometry because it is made out of commercially available shapes and sizes of acrylic. It is not designed from any optimization point of view. But many devices begin with being limited to the materials that can be purchased easily. Only once they are a marketable device will custom shapes and sizes become economically justifiable.
M.
@Mondrasek> Have you meditated properly upon the Cartesian Diver?
Buoyancy depends on volume displaced; the same "quantity" of air has a variable volume, depending on the pressure; a container containing an air chamber will be buoyant or not, with the same "amount" of air in it, depending on the volume that the air displaces, which depends on the pressure.
The Cartesian Diver's variable buoyancy depends on the pressure transmitted to it by the water it is diving in. If the external container is pressurised somehow, the pressure is transmitted to the volume of air in the Diver, which compresses.... that is, it shrinks.... displacing less volume, so the diver sinks. When the external pressure is relieved, the fluid pressure relieves also, which allows the air in the diver to expand, displacing more water, so the diver rises.
Quote from: TinselKoala on June 15, 2012, 07:52:39 PM
Hi TK!
Your assumptions are correct. I have not meditated properly on the e Cartesian Diver. I have had experience with that device since a child (some 35 or so year ago), but that does not mean I have given it the merit it deserves. I will try and find the time to examine the physics there ASAP. I am sure that it teaches more than I "think" I know now.
Doesn't everything?
Thanks again for "hovering". Sage advice is just that: Sage advice.
M.
An example of a 4 riser system with exaggerated water/air channel for clarity.
The PRECHARGE shows the lift as 16,065 as shown in the spreadsheet.
The 7% RISE show the lift now as ~ 11,000 due to the loss of head.
The last stage shows the force of ~ 15,000 after the head has been restored by the water inlet.
Of course, this is not how the system works, as it wouldn't wait for a 7% rise to start forcing water, it would be instantaneous.
Regards, Larry
@Cisco.Sorry that should have been Reply 523 on page 35.
@Seamus101. I can see what you are getting at, but to be honest, calculus is beyond me. I am sure that there are members here who are far better qualified to comment.
@TK re: Cartesian Diver. That was a cool video! I'd never thought to use the effect to amaze my kid. This should be a hoot!
Thanks again,
M.
Quote from: Seamus101 on June 16, 2012, 03:22:20 AM
if only this were so, but it is absolutely not true. Injecting any water would begin to increase the head thus it would become more and more difficult to push the water in as the resistance rises. The forces increases but the distance over which those forces can act are decreased. One needs to integrate the force and displacement over the stroke (basic calulus). When you do that you'll find the energy remains constant, (minus any losses due to heat but we needn't complicate it with that.
Hi Seamus,
Please note in the example drawing in reply 537. The head is the same in PRECHARGE and after the water is FORCED IN.
Regards, Larry
Quote from: neptune on June 15, 2012, 05:03:07 PM
Sorry to say this, but variable geometry piston is not going to work out - all the O/U is being spent into retracting piston2 into the piston1 at the top, plus some.
As the last resort, will study post 523.
Generally speaking, it is close to impossible to get O/U in a closed system - it has to be open.
Examples of the open system: wind, waterfall, sunlight, gravity, electrostatics, magnetism.
Alex
@Telecom. As far as I can see the maths seem to stack up in favour of this system. We have some pretty good anecdotal evidence, and the opinion of Mark Dansie. Until and unless someone replicates this, then we are not going to know anything for certain. Simple at first glance, as ever the devil is in the detail. We have been told that we need close gaps between risers and the walls containing the rings of water , so one of the main problems is we need custom made cylinders .
I was interested to see that you include gravity in your list of open systems. As someone said earlier, buoyancy is just gravity misspelt.
Quote from: neptune on June 16, 2012, 01:52:29 PM
Hi Neptune & everybody,
can someone please provide a clear diagram with explanations?
So far what I see in a post 528 looks like a normal air over oil system with multiple pistons. Used in car lifts, for example...
To control gravity, it has to be shielded. There is a website dedicated to this:
www.blazelabs.com
Quote from: telecom on June 16, 2012, 01:59:55 PM
www.blazelabs.com (http://www.blazelabs.com)
Hi telecom.
I think if we could explain this with just a clear diagram we would. But, then again, this unique construction would have been found years ago. That is always the argument, right?
This device is extremely interesting so far, at least to me. The "simple maths" support it. At least the simple maths that I have performed.
If you start with the taught "rule" that a "Conservative Field of Force" like gravity cannot do Work, then you must dismiss this idea outright. That is exactly what I would have done prior to running some calcs.
My Father taught me his understanding of buoyancy when I was a child (maybe 40 years ago?): The weight of the water displaced by any buoyant body is equal to the amount of weight it can support from sinking.
I believe my Father's interpretation of Archimedes is correct. But now I am seeing a new construction that shows what I believe to be an "addendum" to that explanation.
One of the reasons I never considered buoyancy to be a possible method for doing work was just because my Father, and several year of Engineering school, all taught that this was the case. So far with Mr. Wayne's construction, I am pleasantly amused to find that we may have been wrong. Maybe if we had not been taught that "it was not possible" more individuals would have looked for a way and maybe found this way earlier?
I still look forward to more info and demonstrations from Mr. Wayne.
I am sorry I cannot provide a way for you to understand this system. I was hoping that a physical model and maybe some animations would help, but I (personally) cannot provide those. I believe they will appear soon, however.
M.
Model buiding hopefully made easier.
Cylinders are the idea containers for high pressure, but since the model will not have high pressures, it seems it could be made square or rectangular shaped. So cut acrylic pieces and glue.
The pressure should still keep the side surfaces centered, but if it is a problem, spacers could be added.
Anybody, see any problems?
Regards, Larry
Double post. Sorry.
@LarryC,
I see no problem with making everything from acrylic sheet. But unless you have perfect machining capabilities, a box is the hardest thing to make.
How do you recommend we bond the pieces? If it is with something "glue like" such as silicone, that may disrupt an individual's ability to see clearly all the operations through multiple layers of acrylic and water.
I had hoped to see something made more like this: http://www.youtube.com/watch?v=hT6Ow_cBTps (http://www.youtube.com/watch?v=hT6Ow_cBTps)
But that is just me. I would welcome anything that helped others to understand. I mean, I'm definitely not a teacher, so those who teach should explain what would be the best teaching aid.
Thanks,
M.
Quote from: mondrasek on June 16, 2012, 03:46:07 PM
The following pretty much covered the issue:
http://www.bit-tech.net/modding/2008/03/14/a_modders_guide_to_acrylic/1 (http://www.bit-tech.net/modding/2008/03/14/a_modders_guide_to_acrylic/1)
It is easy to get accurate cuts using a compound miter saw or table saw.
Regards, Larry
Quote from: LarryC on June 16, 2012, 04:03:29 PM
Yep. It appears that easy.
M.
@Tom Webb
If the interim risers would not be offering any lift value, what other kind of value would they offer, spacers?
Also, could you provide a diagram of the arrangement you describe in Reply 523?
It is good seeing some ideas on the practicality of model building. The square idea is certainly a radical approach."Thinking inside the box?" It somehow seems a shame that everyday cylinders are being thrown away in the form of empty tin cans. If we could arrive at the ideal proportions and dimensions, either mathematically or with info from mrtravis, then transparency might be less of an issue. We could predict what is happening inside at least in theory. I still think that an animation would be the most cost effective teaching aid. I keep trying to think of an alternative geometry method of making this that is simpler to fabricate.
I have this sort of half baked idea in my head that most probably wont work but won`t go away . I keep thinking of a fat hose arranged in a sine wave shape and partly filled with water as mrwayne described . At each "positive peak"of the sine wave , where the air is , there is a vent pipe connected to a piston and cylinder [syringe] that lifts a load. Most likely rubbish, but the subconscious is still working on it. A sort of "equivalent circuit" of a ZED...
Quote from: Cisco on June 16, 2012, 04:17:34 PM
They increase the head for the large force provided by the most inner riser.
Regards, Larry
LarryC.- I was playing with your Travis Effect Calculator and saw that if you ran the four risers through the same volume calculations you used for the pod, and added all 5 together, it comes up with virtually the same number (16,082 vs. 16,065) as in in your original total.
Quote from: LarryC on June 16, 2012, 09:50:13 PM
The water head at any pod or riser is only due to the difference of the height of the water on the outside vs. the inside of that member. That is the only head that acts on each individual member. I believe the calculator spread sheet is missing a "Next layer" line under Riser 4 where a good portion of that "large force" needs to be subtracted. The majority of the total lift is actually coming from the Pod and Outermost Riser?
I think the way this spread sheet is laid out might be confusing. The buoyancy of each member is the Surface Area x Head on that member only. So the biggest member (Outermost Riser) always has the largest Surface Area and possibility of the largest head. Each inner member has less Surface Area and less possible head. So the possible force coming from each member must be:
Outer Riser > Inner Riser > Next Inner Riser > ... > Pod
Please correct me if I'm wrong.
M.
Quote from: GreenHiker on June 16, 2012, 09:59:17 PM
Good catch, very interesting observation. So a 4 Riser Travis system is basically equal to the lifting force of 5 separate Archimedes's systems, but with almost 5 times water inlet requirements on Archimedes's to move the system up the same height and almost 5 times the physical footprint.
Travis has stated several times, the more layers, the more efficiencies.
Thanks, Larry
Hello all,
I am heading out of town for a week, I want to congratulate you all.
First; any of the three methods you introduced will reflect the upward force properly - well done.
Second - stroke length is a decision you make on how much of the "Mechanical" ideal you wish to use.
In the model you are working with - overlapping walls (ring walls and Risers) are best when you are at the bottom of a stroke
The over lap is the most you can expect at anypoint in the stroke - it changes as you stroke.
Simply plan to utilize the overlap at the end of your stroke - set that as your combined load - force - or resistance
There is no loss - (other than utilization) because you can not create more head than the load anyway.
So - on your small model - I said short stroke - now you know why.
Next comment:
You are at the same point at which our Engineers (who where hired to disprove our system started to say omgosh).
Let me help you jump ahead a little - in our system the head -like Larry mentioned - travels up with the stroke - this results in a special condition at the end of stroke -
Namely - all the energy you put into the system is still there - the load is up - and removed - but the buoyancy - "head" - is still intact.
You limited the stroke - unlike other buoyancy systems we do not fill -then - float -then DRAIN and then sink - as you have discovered - moving the head creates a sink condition. The sink condition is directly related to the static load - as one of you mentioned - well done.
Now - we move the head - into the other Zed (equalization - free flow as we call it) the first one does not sink during equalization it sinks (during stroke of the other Zed).
We reserve a large portion of the head (neutralizing the weight of the system - we also do not expand the air in the system (Much) as one of you stated - well done.
Now in the equalized postion - we use the pressure in the lowering Zed to supplament the Stroking Zed -
Guess what this does for efficiency..........very exciting
We add weight to the riser and split the desired force - like this with our 6000 pound force model - 2000 pounds lifts weight - returned in the system (exhaust - lowering Zed transfer), 2000 to fuel the internal operations and 2000 pounds absolutely free.
In short - our three layer system has a total of 1/3 the Ideal - absolutely free.
Do not get trapped into thinking you have to exceed the Ideal of a system to achieve OU - that would be magic - our system is simple physics - seen in a new light.
When you wrap this together - you will see why - every engineer who comes - is so excited to join our work.
Well done men, ladies'
Now you know what I saw in the hot tub back in 2008 - in the Travis Effect - pretty cool, and why we dropped everything and persued this - against all odds.
Please e-mail me when your OMGosh moment hits - I am honored by your work, and will include you in our historical journals (with permission) and possibly work together in the future of Clean FREE Energy.
jwtravis5@peoplepc.com
Wayne Travis
First can I say a big thank you to mrwayne for dropping by. Although I am gobsmacked by the intellect and intuition of some of the members here, we are going to need all the help we can get. And who better to help us than the Main Man.
I had a little idea when I was out riding my electric bike today. As I was passing a farm, I was looking at a large tank used to store diesel fuel for tractors. On the side of this tank was a home made device used to check the fuel level in the tank. It consisted of an adapter fitted into the tank wall near the bottom. From this, a clear plastic pipe extended up to the tank top. where it was open to atmosphered. So the level of fuel in the tank was the same as the level of fuel in the pipe.
Suppose we built a ZED from non-transparent materials . We could use this idea to "see" the water level in each compartment, but the upper end of the pipe would have to return to the compartment through the top. This would be possible if all risers were fixed together at the top, as I believe they all rise and fall together anyway. Any comments ?
Quote from: neptune on June 17, 2012, 11:16:13 AM
Thank you.
Exactly as we did our first six models - long clear tubes - steel tanks. very simple only draw back - you can not be sure what the water level is - just the combined air pressure and head - why we eventually went to the effort to install sensors for both.
Wayne
Quote from: mondrasek on June 17, 2012, 08:52:24 AM
Hi M,
The pod calculation that was done, used the volume technique (2548), so let's use the Pressure Difference technique which is also valid.
PSI DIA SI PRESSURE
Pod top 10.8 30 707 7633
Pod Bottom 14.4 30 707 10177
Total upward force = Pod Bottom - Pod Top = 2544
The pressure at the top of the pod is being considered in the calculation, just differently in the volume calculation.
'Each inner member has less Surface Area and less possible head.' I am confused by that statement. The water head is the length of the water column starting from the top of the outside water column to the bottom of the water column below the pod. Each surface from outside to in, sees an ever increasing water head and PSI.
Regards, Larry
Quote from: LarryC on June 17, 2012, 11:32:58 AM
Hi Larry,
The head that is able to produce buoyancy is only the portion of the entire head you describe that is the height of the water displaced by the Risers or Pod. So for example, the head creating buoyancy on the Pod is the length of the Pod (when full submerged). Water above or below the Pod does not cause any buoyancy.
Each inner member must be a bit shorter than the one surrounding it. Therefor each inner member has less potential head than any outer.
Thanks,
M.
@LarryC,
Here is how I would have done it. I'm for whatever way that works that anyone can understand, however!
Here you can see that each Riser and Pod are adding to the Buoyant Force in a straight forward fashion.
M.
MrWayne : Greetings from a fellow Okie! I would like to give you an idea for the use of your device. As you know each time you convert energy from one form to another you lose some. All around me sit thousands of oil pump jacks running 27 / 7. They each have a huge transmission and electric motor just so they can bob up and down. Your unit bobs up and down from the git go and should last for many years. No conversion needed and a ready market where you are at. They pay a high price for electricity and sometimes have to pay a fortune just to get lines put into the oil patch. The unit you sell to them could be very simple and easier to construct.
Another market would be 100 kw units for the local electrical co-ops to use in distributed generation. The Gov has shut down coal fired generator plant expansion. The co-ops are owned by the customers and are some pretty sharp cookies. Our co-op covers four counties and has been operating since the thirties.
Garry
@iflewmyown,
Here is the big picture: Free electricity from ZED stations power desalinization plants and pumps. We can now irrigate all the farm land we need. Free electricity from ZED stations electrolysize water into Hydrogen and Oxygen. Free electricity from ZED stations compress and cool that Hydrogen into liquid. The liquid Hydrogen replaces any need for oil as a fuel, though it will still be used for all those other chemical products it is now.
Pure electricity from ZED stations will be able to power many of today's devices that currently use gas and diesel from oil. This includes most cars. But the technology does not yet exist, and maybe never will, to provide enough electricity from batteries (or other storage devices) to power a tractor trailer. Or to power a jet plane. But Hydrogen can do that. Heck, you can put a man on the moon with Hydrogen. And the only byproduct is water, not Carbon Monoxide.
I'd not invest in any oil jacks long term if I were you.
M.
MrWayne: I know the pump jacks are on the way out. I have an old diesel Bobcat loader. It works great as long as you give it a shot of ether to start. The pump jack replacement was just a shot of ether for your operation. The New York Times refused to interview the Wright brothers for five years after they first flew. All their experts told the Times that it was impossible to fly. In the same way free energy will start very slow, no matter what the benefits, no matter how cheap energy becomes and the oilagarchy will be the last to know. Good Luck and God Speed.
Garry
@iflewmyown, just me here, not Mr. Wayne. Thanks for the analogies. Especially those about the Wright Bros. I actually live in the area of their research. Where I work is within viewing distance of the hanger with the model Wright B Flier that the local air club built and flies. It's pretty neat for me anyways, especially since as a kid I vacationed at Kitty Hawk and got to see the museum and their full sized model. The family and I are actually scheduled to head to the Outer Banks later this year for our vacation. It will be my first time in many, many years. But I want to see the Wright Bros. museum there again!
I think the differences between the situation with the Wright Bros. not being taken seriously and the ZED are paramount. At the time of the Wright Bros. flight the "technology" of a curved wing producing lift had not been established and taught in schools. With the ZED we are playing with known and taught phenomenon. It is just a clever construction that allows the known physics to do something previously thought/taught to be not possible.
Also, at the time of the Wright Bros. flights we did not have the media to cover such events that we have now. The editors at the New York Times could not watch a video on the internet, see the e-mail comments of scientist who have reviewed the patent and math, or "fly" (ha!) to go see it for themselves. All that is now reality. So I expect a faster uptake of this development. Hopefully.
Any production facility making anything is competing with others. Any advantage is extremely important. And every product has some associated "energy" cost included. Any way to lower that energy cost will be adopted fast. And only the fastest will survive, IMHO.
Here is the link to Mr. Wayne's last update to his web site before heading off to the 50th anniversary he is attending: http://hydroenergyrevolution.com/index.php/current-objectives (http://hydroenergyrevolution.com/index.php/current-objectives)
Cheers,
M.
@M,
Agree that we should use the spreadsheet that most helps each to understand, but since I still am using the original, here are some update.
@All,
The fields in yellow, at the top can be changed and is used in the calculations for the rest of the spreadsheet.
This will help in model design. There are two versions, one for the Square shape and one for the Cylinder shape.
This is still the 4 Riser version, Wayne recommended that we build the 6 Riser version. The efficiency of the 4 Riser is 183% and the 6 Riser is 316%. At this point, I find that would be very difficult, but if someone can handle it, please do. If you need, I'll be glad to make a 6 Riser spreadsheets.
I stopped at Lowes today, they will cut the acrylic pieces for you or you can buy their scoring tool.
It seems simple to use, just clamp down a straight edge on top of the acrylic, score, then move it to the edge of the table and snap off.
The 1/8 inch is cheaper, but 1/4 inch thickness acrylic would probably be required for the container to maintain the glue holding ability on the corners.
Regards, Larry
@LarryC,
Well done! And I agree totally that making a square version lends itself to changing the gaps between each outlying Riser and it's annulus walls much easier.
Hopefully we will see a model build soon.
BTW, are you going to build?
M.
Quote from: mondrasek on June 17, 2012, 07:00:24 PM
Hi M,
Thanks,
I may build, but with the 1/4 thickness walls with a small model, it will present challenges. Would you or anyone else be able to do a material take off with with autocad or other, with whatever specification the modeler wants to use? That would save a lot of manual calculations.
Regards, Larry
If there is a serious builder out there who understands the challenges and the concept... Yes, by all means I will CAD.
Just to let you know my "vision" of this project, I was hoping to do a complete miniature replication of the existing ZED test setup. But I can deviate from that idea to help others.
In my vision we would end up with the two ZEDs and the water transfer system. The transfer system could be made from bellows type vacuum cups like the below, once they were properly attached to a surface to turn them into a pressure type pump. How to actuate that pump system (ie. collect output from the system and reuse) is still a problem in miniature. And the controlls...
But others may have ideas?
M.
Just something that should help you understand what is going on (I have posted it on PESN as well):
@Seamus101. OK. Now can you please explain how this "oscillation " happened in the early models where mrtravis had only a single ZED, which showed him a sufficiently high degree of OU to inspire him to move on to the two ZED configuration?
Quote from: mondrasek on June 17, 2012, 09:15:09 PM
M.
Wow, that is an ambitious plan. Sweet, to much for me right now, need Clanzer.
I,m just hoping to build just one ZED and take measurement for proof. Probably need 6 layers, as Wayne observed that the bigger the system the less the losses.
I,ll let you know. At this time, I have other updates in mind.
Regards, Larry
But others may have ideas?Quote
Hi mondrasek,
I think we need to come with exact sequence of the operation of the machine first.
Perhaps you and Larry C. understand it - may be you could share your knowledge?
Alex
@telecom,
I'd be happy to try and explain the exact sequence of operation of the machine if I only knew what was unclear. The patent spells everything out very clearly to me, but I understand that is not the case for everyone. Playing with the drawings I have made and the calculations have also firmed up some things for me. Maybe if you had some specific questions?
Maybe the picture below is a good start. The ZED on the left has no lift. The ZED on the right has full lift and has stroked to it's mechanical limits. So from this starting point the pressurized water at the bottom of the center chambers would be allowed to flow from the right ZED to the left ZED freely through the pipe shown. Once half the water has been redistributed the system reaches a balance and both sides are at the same water pressure. Now the pump (circle in the drawing) would begin to pump the second half of the water from the right ZED to the left ZED. While this second half of the water transfer is happening, the left ZED will become buoyant and begin to rise. At the same time, the right ZED will have lost it's buoyancy and begin to sink. When all the water has been transferred, you have the mirror image of the picture below.
M.
Quote from: KanShi on June 18, 2012, 03:38:02 AM
Hello again Kanshi,
I will be glad when you understand the system.
Wayne
Quote from: Seamus101 on June 18, 2012, 07:51:25 AM
I hope people will now see this for the trick it is. Because the stored energy oscillates between the two Zeds it creates the illusion of energy being created because it will remain in motion for quite a long time. The internal flows are quite slow, so the internal losses will be too.
Seamus,
It is no trick, no fraud, no lie, no error, no mismeasurement.
We do not have a system that just "stays in motion" we have a system that Produces its own operating energy and supplies extra.
Even the first engineers wrote - enough to supply consumer end power.
Wayne
Quote from: mondrasek on June 18, 2012, 03:24:01 PM
@telecom,
M.
Stevin's Principle.
@telecom,
M.
I am stuck at the air port - nine hour wait.
The two Zed system is not connected as drawn above - the water in the pod section is always under pressure - the pressure is related to the direction of travel and stage of the process.
When Zed 1 is all the way up - it has the full charge in Head + the volume inside the pod added for stroke length- It is at the top because it has just finished its production stroke -
At this moment the Hydraulic assist is "on" but no movement or consumption of energy. - To be clear - the hydraulic assist is what adds to the head pressure from the lowering Zed in order to overcome the hydraulic resistance in the production cylinder - or the load.
Both Zeds are connected to opposite sides of one a piston (bags in our lastmodel) that piston is at the end of its travel or near empty at zed one.
Zed one
is at Its has the highest presssure (8 psi - example given last week)
Recap Zed one - top of stroke - high pressure connected to Mass exchanger --(bags - cylinder)
The other Zed (Zed Two) is at the bottom of the stroke It still has 4.6 psi (caused by the weight)
Now the first step is to let go of the hydraulic assist - The two Zed's eqaulize head pressure - so both heads are now at 6.7 psi --both zeds are still in the same position they were in - but the Mass exchanger has traveled half of its distance.
Zed two is ready to be precharged - this means going from 6.7 psi to 8.0 psi (over coming resistance pressure).
The precharge is nearly instant - when the first hydraulic assist is turned on - when the pressure drops to 4.6 psi - about 3/4 of the total travel - we kick on the second hydraulic assist cylnder.
And we finish the stroke (we are capturing the buoyancy during the Stroke.
Then we are half way through a cycle - Zed two is up (8psi) and Zed one is down (4.6 psi)
ready for free flow to begin - the other direction.
Let me be clear - we exchange 1/2 of the hydro transfer during free flow - no input - then we pay for 1/3 of the next quarter, and then less than half of the last 1/4 .
That is our total input - nothing else - very simple.
The layering system which Kanshi disregarded - makes the "Exhaust or water transfer" pay for nearly 70% of the total input cost for each Zeds production stroke (roughly - three layers - better with more layers).
When our third part engineers measured the up stroke - they were excited - but when they realized that alll the energy for the up stroke was available for the transfer - (minus standard losses)
The weight in the system reduces the ideal of the unit - but do not mistake ideal for effeciency, yet the weight makes the transfer more powerful - and the size of the weight (percentage of ideal) is based on th enmber of layers.
So when you see th ethree layer system has about 1/3 of its ideal lifting weight - now you know.
A point many critics make is to ignore that stored energy in the head - still complete and intact - at the end of every a stroke.
Wayne Travis
can't spell check on this cp - sorry
I've improved the spreadsheet to make it easier to understand. Also, got rid of the confusing PSI not being equal to the head. Anyone who understands Wayne's earlier post of the forces in holding a cup full of water underwater and a cup of air underwater should understand the spreadsheet.
This was just to make M happy. LOL
Good luck with your trip, Wayne.
Regards, Larry
PS: A Riser is a cup.
Quote from: LarryC on June 18, 2012, 04:53:36 PM
And you have achieved that (noble) goal!
BTW, you can use "PI()" to return a much more precise version of "pi" in your calculations rather than typing in the 3.14... figure. That would make me even happier.
Much thanks, Larry,
M.
Quote from: mondrasek on June 18, 2012, 05:55:41 PM
Much thanks, Larry,
M.
So, 4 decimal positions is not accurate enough, are all engineers such precision fanatics?
@All,
The Wayne example I referred to in my previous post is Reply 108 on page 8.
Regards, Larry
Quote from: LarryC on June 18, 2012, 07:05:58 PM
As my wife may tell you: Only the nerdiest.
(sigh)
M.
so when are you guys going to demonstrate overunity ?
The rest of us are waiting.
Wayne has already posted that it is a working overunity device.
Of course, my car starts when I want it to and it keeps runnimg.
Somethimg Waynes device cant do.
i owe you guyr an apology. if yott want to slobber over each other, thts okay.
@telecom,
M.
Thank you,
but were is the proverbial air bubble from the post 108?
If its in air gaps, is the air pressurized?
Also, to collapse quickly, is the air gap supposed to disappear?
Quote from: LarryC on June 18, 2012, 04:53:36 PMI've improved the spreadsheet to make it easier to understand.
You forgot a
very important fact: the air/water exerts pressure on the surface of the risers in
every direction, that means, also down on the riser
below it.
The correct formula is subtracting force from the riser above (Outer surface of Riser X). Also, the pod won't be fully submerged as described in the patent and several drawings...
I have attached the corrected spreadsheet.
Quote from: KanShi on June 19, 2012, 01:10:49 AM
You forgot a very important fact: the air/water exerts pressure on the surface of the risers in every direction, that means, also down on the riser below it.
That would be double dipping. The pod is Archimedes and is calculated using volume or pressure differential formulas, please see my reply in 563.
Regards, Larry
Quote from: LarryC on June 19, 2012, 08:35:45 AMThat would be double dipping. The pod is Archimedes and is calculated using volume or pressure differential formulas, please see my reply in 563.
Let's reiterate over facts:
Only the outermost riser is affected directly by the weights. All the other risers are affected by air pressure of the riser above them. Essentially the risers are "sitting on each other" on air cushions - which is described by the pressure.
The pod is lifted by displacement of water (not air) - if and only if it were submerged fully in air, would it be "double dipping" (if I understand that term correctly) - which is what you did in your former spreadsheet (adding forces with different directions, which is just wrong)
Buoyancy is the upwards force exerted on a submerged body and is equal to the weight of displaced water. In this case, you can simplify it just by using pressure over area. Since the pod is
not fully submerged in water, you need to account for the pressure exerted on the pod from above (from the weight of other risers).
Don't believe me? Grab 4 cups, manometer and a force meter and see for yourself (or you can just look at the drawings and remember simple physics).
The drawing I have attached to post #574 shows the
net forces acting on those risers and the pod.
Edit. Let me simplify:
The buoyancy volume calculations can only be used as the net force when the pod is
fully submerged.
When the pod's
top is above the water's surface, you need to subtract the pressure exerted on the pod's top to get the
net force exerted on the pod.
Also, regardless of the pod's height, only it's submerged volume counts and since it is supposed to do work and lift weights, the submerged volume will gradually decrease. As approximation, you can use the average submerged volume.
And as a last note, if you want to be precise, you can calculate riser pressures as
QuoteP2 = P1 + h·ϱ·g
where h is the height difference in the U-column of water in two neighbouring risers;
ϱ is water density (999.7026 kg/m^3 (at 10 °C));
g is gravity (9.80665 m/s^2);
(again, see the attached image in my post #574 )
Quote from: telecom on June 18, 2012, 09:14:27 PM
Thank you,
The air bubble from the simple cup experiments is now the air gaps in the charged ZED construction. And yes it is under pressure to equal the pressure of the water head created throughout the system.
Think about starting with the ZED on the right in the previous illustration but having only water, and no air in or around each riser. Then you pump air into the bottom center chamber. That air would have to be pressurized to overcome the water pressure. And as it is pumped in it would eventually fill all the air gaps just as shown in that illustration until bubbles would be rising in the outermost chamber. So the air gaps will naturally balance to the correct pressures to enable the configuration of air and water in the illustration. Of course, the risers need to be weighted or held from rising further up while this air pre-charge is being implemented.
The air gaps do not disappear. As water is allowed to leave the bottom of the right ZED, the water head pressure drops. So each column of water begins to drop and pushes the air through the serpentine channels between risers and the separating rings from the outside most towards the center.
M.
@KanShi, as the air pressure increases in each chamber, so does the WATER pressure. The air pressure at the surface of each water column is equal to the water pressure at that surface.
If that is not clear, please consider this: Actual atmospheric pressure is ~14.7 PSI. So any buoyant device place in water has that 14.7 PSI pushing down on it, right? Why doesn't everything sink? Because it has exactly 14.7 PSI pushing back up at the surface of the water.
You do not need to consider the pressure of the air on top of a body of water when determining the buoyancy of an object in that water. You need only consider the pressure differential from any vertical displacement of that water. This is known as the head pressure. It can be calculated as (Inches of Vertical Water Displacement)/27.71. At least at fairly minor depths like we are discussing here.
M.
Quote from: mondrasek on June 19, 2012, 10:27:02 AM
That is correct. I said the same thing - maybe in more complex terms, I am not used to express myself in simple terms as most of my colleagues and students usually understand.
Quote from: mondrasek on June 19, 2012, 10:27:02 AMYou do not need to consider the pressure of the air on top of a body of water when determining the buoyancy of an object in that water. You need only consider the pressure differential from any vertical displacement of that water.
Exactly. Please read my posts carefully,
every word counts. The pod is
NOT FULLY SUBMERGED - that is the whole point, if it were, you could simply calculate the net force as the volume of displaced fluid (which is what I've actually stated in my post). I have stated explicitly I am talking about the pressure exerted on the pod's top not on water surface.
@KanShi,
All that needs to be considered is the height of the water displaced by the portion of the Pod submerged in the water. That "height" / 27.71 = the water head. That times (x) the surface area of the Pod is your Buoyant Force. The air pressure above the Pod plays NO part in the calculation.
M.
Quote from: mondrasek on June 19, 2012, 10:42:22 AMAll that needs to be considered is the height of the water displaced by the portion of the Pod submerged in the water.
For buoyant force, YES. For net force, NO. Again, please read the whole posts. I am talking about the
net force (the total force acting on an object).
When you have a body that is
partially submerged and it's total density is lower than water's, it would (by your thinking) float up and end up above surface. It does not happen in reality. The body ends up partially submerged because it's weight (Fg) pushing down is equal to the buoyant force (Fb) pushing up.
Now, consider this: the body is partially submerged (eg. on surface of a lake) and a hovercraft runs over it. The air pressure (which is higher than atmospheric pressure) of the hovercraft's air cushion will push the body down.
Quote from: KanShi on June 19, 2012, 10:57:35 AM
When you have a body that is partially submerged and it's total density is lower than water's, it would (by your thinking) float up and end up above surface. It does not happen in reality. The body ends up partially submerged because it's weight (Fg) pushing down is equal to the buoyant force (Fb) pushing up.
You are correct, the total force is the Buoyant Force - the Weight. However, Weight also has NOTHING to do with the air pressure above the object.
This is incorrect. The hovercraft is increasing the surface pressure of the water just as much as it is increasing the pressure of the air. The partially submerged body will NOT be pushed down.
M.
@KanShi,
Maybe this will help. The spreadsheet shows that 1 Travis 4 Riser system has the lifting force of 5 separate Archimedes system. Thanks again GreenHiker.
Your 'more efficient design' is only approximately equal to the lift force of the Riser 1 pod.
'P2 = P1 + h·ϱ·g'
We could, but the goal is for all to understand.
I too, will be glad when you understand the system, as Wayne previously stated.
@M
Good Luck. It is to much like spitting into the wind for me.
Regards, Larry
Quote from: mondrasek on June 19, 2012, 11:10:16 AMHowever, Weight also has NOTHING to do with the air pressure above the object.
Yes, it doesn't.
Quote from: mondrasek on June 19, 2012, 11:10:16 AMThis is incorrect. The hovercraft is increasing the surface pressure of the water just as much as it is increasing the pressure of the air. The partially submerged body will NOT be pushed down.
Don't be hasty :). This is actually true in the real world. And here is why:
We are dealing with forces and a small area. The lake is really big, the hovercraft is really small. The hovercraft exerts force on the water, BUT it is insignificant in the scope of the lake. Also, most of the force is directly pushing on the partially submerged body. Force = pressure over area.
Let's have P = pressure of the air cushion 200 kPa.
Area of the body is 5 m^2, area of the hovercraft is 6 m^2. Which means the exerted force on water is only 200 kN, while the exerted force on the body is 1 MN (do you see the difference?). The buoyant force is actually the same (for the stated reasons).
Now, if the hovercraft was as big as the lake, things would be as you say (this was just an amusing experiment to test your skills).
@LarryC: sure, if in your example the pod is submerged, then your calculations are correct (except you forgot to subtract forces on the risers - you just added them all up - that was the main point of my post). If you look at the drawings, it is not submerged - unless the height is the submerged height, then it is also OK. Also, my "more efficient design" has, for the same amount of required energy, the same lift as the Travis system (eg. 5x more than regular buoyancy with the same amount of water displacement).
Quote from: KanShi on June 19, 2012, 11:37:49 AM
Now you are confusing apples and oranges, aren't you? In this example the water under the hovercraft is supporting 200kN of the hovercraft mass. The body is supporting 1 MN of the hovercraft mass. And as you state, the buoyant force is still the same. And the body will not be pushed down into the water. It has the same buoyant force in any case, regardless of the air pressure at the surface of the water and over the top of the body. No weight is applied to the body to make it sink. This is because that weight you are imagining is actually a pressure that is applied equally to the body and the water around it and buoyancy is not affected. Pressures are already accounted for in the spread sheet as written.
M.
For anyone who wants to understand the Travis Effect fully , or how Wayne and his team engineered the twin ZED machine to utilize the effect, I personally suggest:
Watch the videos 1-5 on the Travis Effect - Links are on this site, Wayne's site or search "Travis Effect" on YouTube.
Study post number #523 page 35 from Tom Webb (webby1) titled "Just my 2 cents worth". Nice write up. That moves you from the effect, to the machine. Do not give up on his write up and skip ahead. Understand each point before you go to the next.
When finished, you should now understand exactly what Larry just said. With the Travis effect and Wayne's concentric tanks, there is the equivalent buoyant force from several filled air tanks wanting to rise, in each ZED.
Whatever calculations you are using to verify the claims, double check that you come up with approximately the same buoyant force for each shell if it were by itself underwater, with air inside. Then sum the results for the total number of shells plus the buoyancy of the pod. See LarryC's Travis Calculator if you need help.
After that you can study the cycling of the machines and how the different stages of the stroke operate. Very cool.
You folks are tearing this up! Great work.
Thanks,
Tom (from the Videos)
@mondrasek:
As I said, it was an experiment to test your abilities (it does not directly apply to the travis effect device). In simpler terms, most of the weight of the hovercraft is transmitted to the partially submerged body through the air cushion, so yes, it will sink a bit. It's the same thing as putting 17% of weights on the water and 83% of weights on the body (you even said so yourself). Adding a few kilograms of weights to a huge area (let's say 1 square kilometer) will do nothing, the water pressure at any depth will (virtually) not change. As soon as the body sinks a bit, the buoyant force will increase as more water is displaced (that's what I haven't stated explicitly).
Do you finally understand?
As for the spreadsheet, LarryC added all the pressures up (in his first spreadsheet, it was correct) - even those, that should have been subtracted. That was what I was pointing out.
Quote from: KanShi on June 19, 2012, 12:38:05 PM
@KanShi, what I understand is you trying to back away from your original argument rather than just admit you were wrong. The only time the body will sink in an ideal system is if the "hovercraft" becomes so small that it is not supported by any of the water. Then the body will effectively see the weight of the hovercraft (ie. 100% of the pressure) and since no pressure is transferred to the water, buoyancy will change.
Since in the case of the ZEDs the air pressure IS equally distributed over the tops of Pod/Risers and their surrounding water columns there is no correlation with your hovercraft example.
The spreadsheet was and is correct I believe. That is the only point of this discussion. Failing to admit your mistake is disappointing, but just so the other members understand and do not follow that mistake is all that I hope to achieve.
M.
As a layman , I am amazed at the level of mathematics which is apparently needed to analyse this device, which is basically half a dozen empty bean tins and some water. There are some differences of opinion, and various theories.I have made my opinion clear and I will not repeat them here. I think that very soon this device will be replicated, and also we shall see what the results of Mark Dansies prolonged tests are . Four years after the Wright Brothers flew, the academics were still busy "proving" that it was impossible. At least we have not yet quite sunk to the level of name calling .
What is worth considering is this:
1) instead of 4 risers you can have 1 riser with the same pressure, same area and even larger pod.
In Larry's latest spreadsheet you see surface diameter of 36.9i, pod diameter of 30i and pressure of 14.4 psi creating a lift of 16075 pounds.
So, you can have 1 riser with the same parameters and a 34.9i pod with a lift of 18858 pounds and the same input requirements (see picture).
Any disagreements? ;)
2) Lifting force will gradually decrease as the riser rises (assuming no further input) - decrease in air pressure and lower water level.
3) Lift distance is limited.
4) Let's completely remove the pod and just use a riser with a solid insert. Now we are using almost no air for 15410 pounds of lift. See what you got? Yes, that is called a pneumatic lift.
5) Or simply use a pod inside a closed tower. See the picture. 34.9i diameter pod and 14.4 psi. Little air used.
Compare 1, 2 and 4... See the analogy? Seems to me like a pneumatic lift with added 2548 pounds of lift using buoyancy.
(what you need is calculating the distance of lift vs. the energy required to fill the tank up).
@mondrasek: no, I am not trying to back away. The hovercraft does NOT have to become small. Basically what that exercise was based on is that a small local displacement virtually does not affect total pressure at depth (this is a fact).
LarryC had an error in his spreadsheet (in the one using square shapes) - it is fixed now, though. He is now subtracting correctly and he wasn't before (at all).
@neptune: that is basic school mathematics and basic school physics (at least for europe).
@KanShi. Yes I understand basic mathematics and physics. What I would like you to do next is to draw two of the machines you illustrated in your last post, coupled together in such a way that the resulting machine would run itself and produce 500 Watts of surplus energy to power a load. Forget Physics and mathematics , there are only two possible scenarios here .
1 Mr Wayne Travis`s machine does what it says on the tin.
2 Mr Wayne Travis is either a conman, or is deluded, and has spent many years a half a million dollars developing one of the best conjuring tricks in the history of the world. So good in fact that it has fooled Mark Dansie, and scores of other professional engineers.
3 There is no third possibility.
In the fullness of time we shall know one way or the other.
@webby1: I have used the same formula as in the spreadsheet.
@neptune: My take is it's option 2 (it becomes obvious as soon as you simplify the device).
Although, if you want to build the device to see for yourself, go ahead. Building stuff is fun regardless of results.
@KanShi,
Now, I understand that your issue is with the concept of water head. The pressure in your drawing is not 14.4, it is 3.6. The actual water head is the short distance from the top of the water column outside the riser to the top of the water in the riser. It is gravity that create the force, it is pushing down on both columns, and it does not matter if the volumes are different.
Regards, Larry
The piston is static (it does not move). To every action there is always an equal and opposite reaction. So the air inside the pod exerts pressure on the piston and the piston exerts pressure on the air.
The result is that the pod displaces the same amount of water as if the piston wasn't there - although only using a fraction of air volume (and also limiting the lift distance - but the same is true for the ZED from the patent).
Lift of the pod (with the stated parameters) is 3448 pounds (pi*(34.9/2)^2*100*0.03606) and the riser's lift is 15410 pounds (pi*(34.9/2)^2*14.4) => the total lift is 18858 pounds.
I am just talking about the lift force. Not sure what you mean by hydraulic lift (since the risers are basically hydraulic/pneumatic lifts (or lifters?) and they are part of the spreadsheet).
Lets say we have a closed bottom tube, and an empty top and bottom closed tube containing just air, that when it is inserted into the open top tube, we have say 1/8 in gap between the inner tube wall and the outer tube wall.
We fill the larger tube say 1/3 water. We insert the floater in the tube containing the water.
By just the weight of the floater we should see some of the water forced up into the 1/8 in gap. Now we add weight/load. Say we add just enough to get the floater to just be hitting bottom. The 1/3 water may need adjustment as to not completely fill the 1/8 gap when the floater hits the floor. ;] lol floater.
Now we see there is more of the 1/8 in gap filled with water and the buoyant cylinder has just enough added weight to allow the cylinder to touch the bottom.
Now, if we add water to the gap, the loaded cylinder should rise. Of course as it rises, water needs to be taking up the displacement happening at the bottom at the inner cylinder rises.
So as we fill the gap, the loaded floater rises, and water added to the gap ends up filling space created by the rising loaded floater.
If we have 2 of these, exchanging the water levels from one floater set to the other, may be easier than lifting and lowering the loads manually.
Just my take on this so far. ;]
Mags
Thanks all, glad to see more understanding and passing examples. Each example may be hard to understand for some and easy for others. So each example has values and will add to the total understanding. Which is critically required for the mass acceptance of this system.
Regards, Larry
Maybe a better model would be described by two relatively incompressible fluids (like mercury and water or oil), so you can ignore compressibility of air in the calculations.
@webby1: Exactly. Without the pod it is a plain old telescopic pneumatic lift. And pneumatic lifts are not OU. The more air you pump into the pneumatic lift, the more upward force you get. With this out of the way, you can just concentrate on the pod that is lifted by buoyancy, which is also not overunity. So, where do you get the energy to pump air/water into the ZED? What you can do is use potential energy (for example from a pendulum) to move air or water between ZEDs, but that potential energy will deplete in a few hours (depending on energy losses and the amount of stored potential energy).
@LarryC: I haven't heard it called water head, just water column (that actually explains some things). Fact that water pressure is the same at depth is well known. Now, in my drawing, the pressure can be 3.6 psi, it can also be 14.4 psi and it can be any pressure you want - if you have a compressed air tank with pressure higher than whatever the water pressure is at the input depth, you will increse the internal pressure and, at the same time, compress the air. Or, you can simply make the water column taller, which will increase the pressure on the air - compressing it to whatever pressure you want. Also, you can open the water column to atmospheric pressure and have an instant "boost" in pressure (of over 100 kPA or 14.7 psi) at the top. In each case, the lift will be the same and proportional to the energy input.
@KanShi,
"Fact that water pressure is the same at depth is well known."
Like so many other things these days, the "facts" are getting really strange.
Ask anyone who's ever had the bends if water pressure is the same at depth.
@Cisco: DCS is caused by breathing in high pressure air (due to depth of water) and quickly rising to the surface (lower depth of water => lower pressure) which causes bubbles. What is your point? Do you not agree that water pressure at eg. 100m depth below surface is the same, regardless of the size of the body of water? Or do you disagree with my description of DCS?
Quote from: KanShi on June 20, 2012, 02:38:54 AM
LOL, what a load. I'll not waste time pointing out the obvious.
I do have one question. How many people do you know that actually fall for your 'make a error, don't admit it, change the story' technique?
I will be glad when you understand, you may be able to help.
Regards, Larry
@LarryC: What? I have made a partial error (with the pressure on the pod) with the corrected spreadsheet (you can read I was agreeing with mondrasek). But the point of my drawing is that I can have whatever pressure I want in my closed system. You are not limited to zero pressure at the top. Just pressurize the air more and you will get more pressure (eg. hydraulic lifts use that, you know?).
Quote from: LarryC on June 20, 2012, 10:23:14 AM
Regards, Larry
Wayne made an error and won't accept it. He thinks a higher static head creates more work. Unfortunately,
he is pumping water into a smaller channel. Because this slows down the flow of water, the hydraulic pressure it creates can't be converted into useful work by rotating something like his generator. He needs the increased work to happen in the same amount of time as if pressure were being apllied to a static head that has the same surface area as the orifice it passes through and the same surface area of the static head it is filling. Why they limit hydraulics to devices that are not dependent on the time factor to realize work.
edited to delete a part of one sentence to keep thought of the post properly expressed.
@johnny874. All I can say is that it is fortunate that nobody pointed that out to him until after he got it working then.
Quote from: neptune on June 20, 2012, 02:06:51 PM
Nobody has seen it work. It would have been fortunate for him if he would have listened to those that tried telling him that. According to what he has posted, he would have saved $70,000 is it ?
The reality is, I doubt he spent $40,000 patenting it as he claims.
edited to add; it's almost funny because I was harassed quite a bit for working openly on Bessler's wheel which can work. I tried finding people to work with, especially at besslerwheel dot com, but I don't think they want to see somethign that works. it seems to be all about who gets credit more than anything.
With static heads, what some people miss is that if you pump water up to a decent height, it will seem like there is extra potential. I mentioned it in one of my first posts, if water is pumped up to a height of 33 feet, then if 1/2 the volume/mass is released, it would have the potential for over unity. Basic math, 10 lbs. of water at that height woudl require 20 pounds of force in a mechanical pump. If 5 pounds drops 16.5 feet, it can use leverage to oeprate the pump and keep a cycle going. Unfortunately it's not as fancy as what wayne built but is something that could work.
That is what sucks about engineering, you can't do it your way. I don't think anybody ever really has, they were just willing to change their ways and be willing to work with what engineering doesn't allow. As things stand, because of wayne's continued insistance of having a working device, I'm thinking elaborate hoax any more.
But do have more serious things to be concerned with than what he and his friends don't understand.
OK we have only his word on how many people have seen it work. I look forward to Mark Dansie`s prolonged testing . I have no idea on costs, but where patent lawyers are involved I would think The sky is the limit . I would go and have a look myself, but like yourself I have health issues, and I am old and poor . Time will tell.
Hmm. I've been corresponding with others that have seen it. NDA's are still in place so they can't say much more than that. But they say that it works. Some of these individuals are new to me. Some are not.
I believe the subjective evidence is still in Mr. Wayne's court. Any evidence against comes from the "I've been taught that it is impossible" camp. Same as with flight. Same.
Rather than go on about how this is not possible because of (insert historical reference here), why not wait and see? Or run some numbers, simulations, etc., ON THE EXACT CONFIGURATION DESCRIBED!
Changing the unique construction in order to "simplify" or otherwise do analysis is not actually analyzing the same construction, is it?
M.
Quote from: mondrasek on June 20, 2012, 04:23:16 PM
M.
M.,
Have some very pressing personal business to take care of. After that, will be able to demonstrate where wayne went wrong or missed something. And it does come back to time.
If you try to pump 100in^3 from a cylinder into one with twice the height, it will probably take longer. This is because compression converts the energy in the static head from high volume low pressure to low volume high pressure. They use this principle on steam driven turbines. this what he won't consider.
Wayne is compressing a hydraulic piston to create a flow which converts the pressure into work. When the flow slows because compression reduces the flow rate, the enrgy can not be stored as in a traditional hydraulic device.
The odd part is that if 141.5^3 in. (5 lbs.) of water were pumped up to 16.5 feet from a cylinder that dropped 10 in., then with a 4:1 leverage ratio, it would take a weight dropping 40 in. to pump the water back up.
And since 40 in. is less than 16.5 feet, 5 lbs. dropping 10 feet could perform how much work ? The trick to this is that if a static head of 16.5 ft. is maintained, then when pumping water up, it would be the water in the static head that would be pumped into a reservoir so it can be made to work. In reality, the static head and reservoir would have 10 lbs. of water.
Since the reservoir would top out at 16.5 ft., it would not add any extra resistance to pumping water upwards.
It would take something like that to use the potential of a static head. But then, I figured that out from going to school, studying (it does take some time ;) ), working with it and a willing ness to consider someone else's work. After all, I am not Bessler but have learned from him and his work.
It will probably disappoint a lot of people to consider that someone already came up with a vaery good idea hundreds of years ago. Of course, a 12 ft. wheel with 20 lbs. of over balance would only generate about 400 watts @ 20 rpm. But that's math and anyone can go over the numbers and show me where I wrong. Of course, I am not the only person to say that Wayne's "Travis Effect" has no extra energy in it. Maybe he can show where my math is wrong ? That is if he really understands this type of behavior.
Johnny
edited to change the thought on converting the potential of a static head to more realistically represent their behavior according to accepted principles of engineering.
edited to add. @All, anyway, a static head that is 8 ft. high could be made to work and be a simple perpetual motion machine. Floats could control the release of the water or something similar like flapper valves. And if you want to go smaller, that's up to you. 8)
edited to add; the shorter the pump, the less movement needed to pump. would require greater amount of leverage to pump quickly. The diagram is fairly basic and is hopefully something everyone can understand.
A float opens the drain on the top reservoir filling a bucket on the lever. When the lever drops, it pumps up the reservoir again. When it is finished pumping (while it is moving downward), a flapper valve could be lifted allowing it to drain into the bottom reservoir which feeds the pump.
And to lift it back up ? Water in the reservoir could float it back up, might take a little playing with it to get this worked out. Maybe have a gate open when the flapper valve opens so a "pond" could be filled with water lifting it back up then feeding (priming) the pump itself.
It would almost be like building a better mouse trap. Not sure if any of you ever played the game but it used basic mechanics to get a lot of things to happen.
Hello all,
My offer still stands - 2k for replication -
I am very impressed with the ones of you that have moved forward.
I am surprised at others - they have seen their own stated "absolutes crumbled" and still call our honor into question - several of the negative contributors have posted outright errors - proven mistakes - incorrect physics and drawings and they still claim the the authority to call us wrong?
And bravo to those of you who see thru the attempt to call this a pneumatic pump - it is a diversion to avoid discussing the other absolute statement where "Mass was the limitation of buoyancy" - Larry's calculator blows that away.
I suggest you move on to Webby's lead - how much energy is available to transfer - and what does that do to input cost.
Two more misleading contributions - the weight effects all layers - not just the outside - increasing the atmosphere in any layer effects all the layers.
Second - the Pods water level is key to the system - the pods water level is directly related to the nuetrality of the weights and risers weights.
one inch change in the Pod can mean float or sink - when that point is matched to the system - you can control the direction of the Zed's travel by simply raising above that point - or below that point.
To produce power from the system add 12 inches of head to the pod - that translates into 24 inches in each of the layers after that.
SO 12 inch change in the pod (water level) equates to a 7 foot head change in a three layer system.
Now - where our increased efficiency from layering - (this is another "absolute" claim against us - which is wrong)
In a six layer system - increasing the pod 12 inches - increases the head 13 foot head -
8 layer = 12inches = 17 feet of head - hope you see the pattern merging.
I will pay up to $500 for the flight of the model - representative - to visit for clear teaching and the check.
Wayne Travis
disconnect your battery then,
attacking math with words is weak,
Quote from: johnny874 on June 20, 2012, 10:50:24 PM
I did not see anywhere where Wayne's offer to pay for a replication required a battery in the replicated machine. The machine requires no battery to demonstrate the principle of operation. You should encourage someone here to replicate it. After all that would be the strongest evidence for or against the theory of operation.
see3d,
he has one, the replicate would also have one.
Of course, my car has a battery.
Coincidence ?
Johnny
edit. will someone put that 2 thousand to work please ?
give it up wayne
I've been thinking about how to best demonstrate the relative lift of the ZED and realized, the best would be visual, mathematical and physical comparison with regular lifts:
You can see the visual comparison in the attached image (the pod is of course full of air - it is drawn as full for visibility reasons).
As you are going to see, in all compared devices, the pressure exerted on the pod is the same (those with the pod +h2·ϱ·g) => every device has the same input requirements: fluid at the same pressure. What is also demonstrated is that multiple risers just increase complexity and that just one tall water column is needed to generate the ~same pressure and lift (with the ~same input).
To precharge the devices, we pump-in air at the required pressure and thus displacing water; or, in other words, increasing the potential energy of the device and storing it in the water column(s).
ϱ(water) = 999,7026 kg/m^3 (at 10 °C);
g = 9,80665 m/s^2;
h1 = 2m;
h2 = 1.5m;
A = 1 m^2;
hydrostatic pressure: p = ϱ·g·h = h·9803.73350229;
ZED:
p1 = 2·9803.73350229 = 19607.46700458 Pa (19.61 kPa);
p2 = p1 + 1.5·9803.73350229 = 34313.067258015 Pa (34.31 kPa);
Lift from pressure: Fp = p1·A + p2·0.9·A - p1·0.9·A = p1·0.1·A + p2·0.9·A = 32842.5072326715 N (32.84 kN);
Lift from pod: Fb = ϱ·g·V = 9803,73350229·0.8·A·h2 = 11764.480202748 N (11.76 kN);
F = 44606,9874354195 N (44.61 kN);
Hydraulic lift / hydro-pneumatic lift:
p = (1.5 + 2)·9803.73350229 = 34313.067258015 Pa (34.31 kPa);
F = p·A = p = 34.31 kN;
Hydro-pneumatic lift with a pod:
p = 34.31 kPa;
Fp = 34.31 kN;
Fb = ϱ·g·V = 9803.73350229·0.9·A·h2 = 13235.0402280915 N (13.24 kN);
F = 46077.547460763 N (46.08 kN);
The weight of air is ignored - as it is also ignored with ZED. It is only approx. 8.28N anyway.
If you guxs want to do a simpldd test, get a garden hose. All yott need to do is adjust the nozzle. The pressure in the hose does not change, how dver it,s flow rate does whem
you adjust the nozzle.
@micro, it,s old wayne and friends saying it,s a working over unty device.
such claims put the burden of proof on those saying they have done it.
Quote from: johnny874 on June 20, 2012, 11:22:17 PM
see3d,
Coincidence ?
Johnny
As has been stated, a simple model to demonstrate OU [not a self runner] would not need a battery .
CHECK LIST
JOHNNY`S CAR WAYNE`S MACHINE
Battery fitted? Yes Yes
Is battery charged by the machine ? Yes Yes
Is the battery the actual main power source? No No
If you removed the battery, and made no modifications,
would the machine still function? No No
What a coincidence, as you said. Give it up, Johnny.
None of us live forever. Concentrate on your Bessler work.
Had some time with my laptop waiting between meetings at a customer yesterday and was able to doodle the attached. I have changed the wall thickness of the outside tank on the little 6 in dia. model from 1/8 " to 3/16" since it was the next size available. This shrinks the outermost water gap and gives a better balanced operation IMO.
You can see that the system goes from Buoyant to Non-Buoyant when somewhere between 5.5 and 6 in^3 of water is removed from the "Full" condition that I used to start analyzing.
Thinking about a demo set up with just one of these ZEDs (to eliminate controls and energy capture systems). I was thinking to plumb a hose from the bottom of the center of the ZED and run it into the bottom of a sealed bellows type vacuum cup with the proper dimension to dispense exactly the correct amount of water needed to take the ZED from a lowered condition of -1 inch, back up to the "Full" condition where it is still producing 12.3569 lbs of lift. The bellows is completely filled with water and must dispence the correct amount of water (per the design) when being collapsed exactly 1 inch.
Now place a 12.3269 lb weight on top of the ZED to full collapse it 1 inch. This will also force water into the bellows to make it expand 1 inch. Now a weight of less than 12.3269 lbs is place on top of the bellows. If it causes the bellows to collapse 1 inch while driving the ZED and it's 12.3269 lb (heavier) weight up 1 inch, OU is proved, right?
I think this simpler test setup is a nice balance point between complexity and necessity to demonstrate the principles of the system.
Thanks,
M.
That would seem to have been a wise investment of your time. Can I make a couple of practical suggestions? It is unlikely that you would find a set of bellows off the shelf, which when depressed one inch, would give exactly the amount of water that needs to be injected into the ZED to raise it one inch. What I would do, is this. [and by the way although you refer to the bellows as a "vacuum cup" it is not used to create a vacuum in this application.] Buy the approximate size needed, but err on the large size rather than the small. Instead of placing the bellows weight direct on to the bellows , Have lightweight beam pivoted at one end [half a see saw] touching the top of the bellows and place the weight on the beam above the bellows. Arrange an adjustable mechanical stop to limit travel of the beam, to inject the correct amount of fluid. As the bellows weight`s fall will not be exactly an inch, we now use Force X distance to measure input .
Does anyone have an opinion as to whether bellows would be a better choice than a large hypodermic syringe, taking into account friction losses.
Quote from: neptune on June 21, 2012, 10:19:40 AM
CHECK LIST
actually will probably be quitting Bessler. It's like AB Hammer told me once, he either gets the credit or will do everything he could to prevent it from happening. I think between him and my doctors, it's a waste of time.
And if it worked, there would be nothing to talk about, you know, a lever drops and the wheel rotates. BORING.. Can just build that little self repeating water pump I posted and make millions. That would be the smart thing to do. Don't need a shop to build it and since I have published it, I have one year to patent my invention.
I think what you guys are missing among other things is that air is compresable. This means it acts as a shock absorbing energy but not really able to put much back into the system. It's why they use them on cars and tractor trailer rigs to control ride height.
I've set up a Material take off spreadsheet based on this video:
http://www.youtube.com/watch?v=FNPNiIeAi5g (http://www.youtube.com/watch?v=FNPNiIeAi5g)
I used the relationships in Fig 14 and Fig 15 of the patent for the calculations in the B and C columns.
I'm tired of looking at this, so there probably is errors. All, please take a look and point out any errors, not piecemeal, but all your noted errors at once.
@M, Please Autocad, so we can see if there are any intersections and what the build would look like.
Thanks, Larry
Quote from: mondrasek on June 21, 2012, 10:44:49 AM
I believe you are taking the right approach to come up with a simple setup to demonstrate the essential heart of the system. I have giving this some thought for a while. Why not just have your input hose go up to a raised bucket of water with the height providing the exact pressure and the volume of water measured out to be exactly what you need? It only provides the upstroke energy part of the demonstration. For the down stroke, water has to be extracted. The key is to show that you can remove more energy to get it back down that was used to raise it up. That would be the most direct proof of operational validity. Closing the loop would use the gain in energy to raise the volume of water back up to the bucket.
@neptune, Have you learned nothing from the "Travis Effect?" We use a bigger bellows and then put a block inside to limit the stroke and volume to exactly what is needed!
@LarryC, I'll draw it up. Guess I can take my laptop home and maybe work on it some there. I am off work tomorrow to celebrate my birthday (today actually) and have half a dozen projects already in mind. But it shouldn't take too long if just drawing geometry. Might squeeze it in today if nothing work related is too pressing.
@see3d, the reason I was looking at the bellows is that I am trying to show a relationship that a child can understand. Two different weights traveling through the same distance. But the smaller weight lifts the bigger. You could have a simple balance next to it to show how it is the opposite of what a balance would show. No equations. No other physics involved.
M.
Quote from: mondrasek on June 21, 2012, 12:42:27 PM
Yes, that would be conclusive, but you need to use a 6 layer system to get enough gain to realize that in a human perceptible way.
@LarryC,
It builds.
Two comments:
1) The Pod needs a top and bottom. The height there needs to be 23.50. I made that change in the .dwg.
2) The gap between the Outside Retainer and Riser 1 is too big, I believe. Driving water into it from the thin gap inside Riser 1 will not raise the water level there by much at all. It needs to be the thinnest gap of all.
Thanks,
M.
@Mondrasek. Yes, I like the idea of the block inside the bellows. It is doable, but it might be a bit fiddly to calibrate. In an earlier post, you said that you had corresponded with people who had seen the machine in action, and that it worked . Do you know, or can you say, if what was seen was the self runner, or just a simple model to show proof of OU . I would choose to see the latter given a free choice, especially if it could be stripped down before and after use. The problem of seeing the self runner , for a sceptic, is that you are looking at 2 large tanks that could contain anything. Given that the purpose of a model is to convince sceptics, this is important.
There are probably a number of questions we need answers to before building a model . I have asked the first one before.
1.Is it necessary that the separate bodies of water inside the ZED [with the exception of the central chamber] are all equal in volume. If so this prevents the use of off-the-shelf riser sizes, and necessitates that each riser be custom made .
2 It would be a great help if we had a step by step procedure to fill and precharge the machine .
The more help we have before we start, the greater the chances of a successful build.
The person who will gain the greatest benefit from a successful build will be mrwayne. Replication will give him more credence and publicity. So I hope that he will give us all the help he can.
@neptune, I have not heard anyone I have cooresponded with talk of any models like we are discussing. It was always about the larger units Mr. Wayne has built. Explanations of the workings had to be done with diagrams and animation since you cannot see into those like you mentioned.
It is interesting to me that Tom from the videos has posted here and no one has directed any questions to him. At least not openly. I PMed him and we exchange a couple messages. It was not on topic with this thread so I did not ask openly.
M.
Quote from: mondrasek on June 21, 2012, 01:52:26 PM
@LarryC,
It builds.
Two comments:
Thanks,
M.
Thanks M,
I intended for the Pod not to have a bottom, would be less of a problem to fix, if a leak developed.
In Fig 1 in the Patent it shows a larger diameter at the top of container. To handle overflow better or more water to keep the head higher on Riser1 without water coming in from water inlet, not sure, but it was just my way of compensating, without having the arkward build.
Would you add the spacers on my next version and shade the acrylic.
I'm more concerned about the narrowing in each air, water column. I will figure out how to correct.
Thanks, Larry
@Webby1. So if I understand your last post correctly. You are proposing two separate models.
1. A relatively simple model based on an inverted vessel and a concrete block, and an air pup.[bellows,syringe, etc] Or possibly two or more such vessel/block assemblies.machine to be self running,
2 A more complex machine with multiple layers, more along the lines of Mondraseks design.
The success of [1] depends on such a basic "single riser" design having OU. I am torn two ways here.\Wayne says that 3 layers are "only just OU" so you might be struggling with just one layer . On the other hand I have no doubt that Wayne`s first attempts were with a single layer set up. My guess is that he must have seen a degree of OU in the early single layer experiments to inspire him to develop the multilayer concept.
I would say that any self running machine needs a minimum COP of 1.5 to work and overcome losses.
However a COP as low as 1.1 might be sufficient to prove OU by causing a given weight falling one inch to raise a heavier weight one inch.[Not self running .]
I would appreciate your views on all this .
Quote from: LarryC on June 21, 2012, 03:25:58 PM
I understand. Do keep in mind that the Pod chamber has the most air volume, and without a bottom, some water will enter the bottom of an open Pod as the air there is compressed. This reduces buoyant lift from the Pod.
That may be true. And an overflow may be a good idea. But you will get very little lift from the Riser 1 if the outer gap is so large.
I could add spacers if you need. What do you mean by "shade the acrylic?" If you mean to add "hatching" to show that this is a cut away view (and make easier to see the walls vs. voids) that is no problem. If you mean adding color or tinting, I can do different color lines and hatching. But no "transparent color tinting". You'd need a Solids program for that and I don't have a key to use our package (nor am I anywhere qualified to use it anymore!).
M.
Quote from: neptune on June 21, 2012, 04:04:23 PM
@neptune, I do not believe there is any OU in a single layer design. I believe Mr. Wayne only saw the "Travis Effect" as the way to nest Risers inside Risers. It is the layering of the "nested" risers that leads to OU.
The purpose of the "Travis Effect" is only to show that you do not need the Risers (or cups) to be completely filled with air to maximize their buoyancy. Instead you can replace a portion of that air with other items. And if those other items are rings of water with other Risers, you end up with a unique arrangement where the buoyant forces of the Risers sum together and produce a larger total buoyant force in the same space of the one Outer Riser.
M.
Quote from: mondrasek on June 21, 2012, 04:13:05 PM
If it is an issue, styrofoam can be added, but we'd need to remove after the test to show no battery. ;D
I don't understand why the lift would be less.
Edit: Any color but blue hatching would be great.
Regards, Larry
@M,
New version, the biggest problem is the large walls with such a small model. Needs to be thinner, but I don't think the 1/8 would work very well.
Regards, Larry
Quote from: LarryC on June 21, 2012, 04:28:01 PM
Let me think on this. It may not matter, like you say. Could be just my mistake!
M.
Quote from: webby1 on June 21, 2012, 05:02:30 PM
may I remind politely.
Hi Tom. Thanks for the reminder.
I can see how that reply from Mr. Wayne can be interpreted as saying a one layer system can produce OU. But that was not clear to me.
In the second sentence where he says "if you build your system..." I was unclear if he was still talking about a single layer "system" or talking about a multi layer ZED "system".
So I guess I would need a clarifying statement from Mr. Wayne.
Just a "yes" or "no." Can the "Travis Effect" be used to show OU in a single layer system (just a cup over a cement block)?
Thanks again,
M.
Quote from: webby1 on June 21, 2012, 03:14:44 PM
IMHO there are 2 effects that need to be demonstrated in a self run mode.
First is the simple "Travis effect", the one demonstrated in the videos but in a self run mode, if this part is not understood then the next effect will make no sense and appear as "magic".
Second is the nesting of the risers to decrease the input needed and conserve some of the input itself for re-use.
Then when you explain that each riser is the concrete block, from the first demonstration, for the riser above it, it makes more sense, and is easier to understand.
For Travis effect to work you need to have enough space on the sides of a central piece, I think you call it a pod, to accommodate the compressed air. At the same time , in the initial position there shouldn't be any space on top of the pod.
Once there is a bit of lift from the incoming water, air will rise up from the sides to the area between the top of the pod
and the bottom of a riser and lift it.
An observation. If we look again at the videos of the basic Travis effect, we notice that the cup used is tapered, it does not have a uniform diameter all the way up. It appears that the cement block was made by using the cup as a mould. While this is convenient, it does create a problem. As the cup and block are both tapered, as the cup rises, the air gap between the cup walls and the block increases in width.
In my opinion, the net result off this is that the lift distance of the Travis effect is reduced. I am not saying that the total energy of the lift is reduced. It may be that we get a more powerful lift over a shorter distance .Or not.
It is interesting to note that the multilayer systems are based on cylinders of uniform diameter, not tapered cylinders.So if you are building a single layer model, it may be best to use a cylinder of uniform diameter . Any comments ?
Good Morning,
I will of course lend any support Technique, set up, clearances design - etc - what ever you need.
The benefit of the negative detractors is more proof that I am the established inventor - in a sad way they help us.
I would appreciate if the questions were sent to my e-mail - one question per e-mail - please - I only get a second to sit and jot down answers, so a multi question - does not get the proper attention.
Clear plastic does offer a whole new set of issues - to replicate - steel was pretty easy - our system has pressure sensors in ever upper and lower layer - and our program gives us a visual of the water and air levels through the whole cylce.
Set up is simple - Hold the system down (locked) down - fill slowly with both air and water into the inner most layer - until the water level reaches the top of the outside layer.
You have full ideal at that point -
When you remove the lock - the system will extend to the distance matching the head/surface area/and load.
At that point - removing water from the pod results in sink mode- adding water results in stroke.
When you hook up two systems - you just adjust the water level between the two Z.E.D.'s so that you match the stroke lengths - to pressure to height - actually a simple process - we will cover later.
Wayne
@M,
The latest Material Take off is attached, now with Gap Clearance calculations. To solve the Gap Clearance I removed the reduction of gap as the model went from Pod to Riser 1. It is just not practical with a large wall small model.
After we check your latest drawing and everything seems correct, I will be building a Hobby model out of Elemer's foam board. It is just 3/16 thick, but that should be close enough. It will also give us a good idea of how much material is needed, so we can cost out the acrylic. I picked up a freeware version of a Sheet Layout program, so it should be pretty accurate.
Regards, Larry
Cheers.
Quote from: mondrasek on June 22, 2012, 12:26:51 PM
Cheers.
Hi Mondrasek,
these spacers on top - I thought all the air should be squeezed out from the top to bring the expansion force to 0?
I'm not by any means an expert in these kind of devices - just asking...
Alex
Cheers.
Thanks, M.
But, It's not hanging right at the bottom, should look like Fig 14. I'll check my specifications.
Regards, Larry
Quote from: LarryC on June 22, 2012, 12:53:59 PM
Thanks, M.
Regards, Larry
Okay. Please note that I levitated the Pod so that the gap between it's top surface and the next Riser was the same gap (.31) as all the other gaps. Just FYI.
M.
Quote from: telecom on June 22, 2012, 12:36:47 PM
Hi Mondrasek,
Alex
Hi Alex,
To be honest, I am also not sure. The buoyancy is the product of the "water head" and the "surface area" of the water displacing Riser's top surface. So the need for air in the gap due to the spacers does not seem to be necessary. But I have not tested and really don't know more than that. Maybe TK or someone else with higher physics understanding can elaborate. Or possibly someone can do an experiment?
Then again, Mr. Wayne might also answer?
Thanks,
M.
Quote from: neptune on June 22, 2012, 09:48:18 AM
With the buoyancy force being the "water head pressure" x "surface area" of the top of a cylindrical "riser", I would think that having tapered walls would change this simple equation into a calculus function. With a tapered riser, the effective "surface area" would be changing at the different heights of the "water head?" Just my "swag" at your question.
M.
Not 100% certain, but I think these spacers are shown in the patent.
Quote from: mondrasek on June 21, 2012, 04:47:21 PM
@LarryC, I believe you are correct that the outer ring of water can be as big as you want without any negative effects on performance. In fact, having a bigger ring might change how much pressure difference there needs to be between the ZEDs in a two ZED system in your favor. But I will need to get back to my own little model and analysis to figure out if that second part is true or not. And that is not on my schedule for this weekend (which has already started for me!).
Sorry for confusing anyone with my mistake.
M.
Quote from: neptune on June 22, 2012, 01:27:42 PM
Definitely shown. But described in legalease as "may or may not" be used in a given embodiment of said device.
Man that is painful to try and type... Need to stop reading legalease.
M.
They are certainly shown in the "how it works" diagrams posted by mrwayne of the ZED. That tells me that it would work with them. Will it work without them ? Dont know.
Quote from: mondrasek on June 22, 2012, 12:57:42 PM
M.
Yes, that may be it, it does look like Fig 16, 17 and 18. Fig 15 should be the same, not sure, because the latest picture from Travis with 8 systems is like 15.
@Travis,
Please clarify this issue?
Regards, Larry
"But, It's not hanging right at the bottom, should look like Fig 14. I'll check my specifications.
Regards, Larry"
[/size]
Fig. 14 does hang different at the bottom. It also shows spacers and vents to be used during assembly. But there is a minor mistake where the vents are shown. According to the (argh!) patent description of assembly at [0095] and [0096], Vent 162 should be located not on the pod--the pod needs no vent--but instead on the inner riser where vent 188 is shown; and vent 188 should be shown at the top of the outer riser. They are depicted correctly in Fig. 15.[/size]
Quote from: LarryC on June 22, 2012, 01:49:42 PM
@Travis,
Might have the logic. At rest, with low or no water, each Riser sits on a retainer wall, enough that would allows them to separate from the spacers. So each retainer wall from inner to outer is higher by spacer plus separation gap. Thus, when lifted and the separation gap is lost, the longer Riser walls would be the outer most. So it seems 14, 15 and the 'One Zed through complete cycle' is more likely.
Regards, Larry
Quote from: LarryC on June 22, 2012, 03:26:27 PM
I did some manual drawing and the logic appears correct. The slope of the riser walls at bottom will end up being a function of the combined lost separation gap and it will slope downward from the inside riser to the outside.
@M,
Sorry, but the latest MTO is attached. There is a couple of retainer wall calculation correction. One to adjust for the fact that the inside of the riser is reduced by the thick top plate, while the retainer does not have that issue, and the other is a compounding error on my original calculations.
The gaps between retainer, riser, etc should be the same size as the material thickness. They appear a lot smaller, could you look into that issue.
Regards, Larry
Quote from: LarryC on June 22, 2012, 05:25:01 PM
@LarryC, right now you have all the gaps at .125". The material thickness is .25".
If I can ask, what is driving all the dimension changes? Is there something in the design you are trying to optimize?
If you are trying to replicate the patent drawing proportions, please first find out if they are from production model drawings. Patent drawing do not need to be correct to scale. They only need to be representative for the purpose of explaining the device. They may not be the correct proportions to create a working device at all.
M.
Quote from: mondrasek on June 22, 2012, 06:56:47 PM
You're right, I forgot to split the difference for the two sides. The new attachment gets it to .25 gap.
Agree in part, but I keep in mind Travis's honesty policy. So I think of the issues as drafting issues. Your drawing led me to look at the drafting issue at the bottom riser height and then to logically figure out how the system should look after the initial lift.
Regards, Larry
Quote from: LarryC on June 22, 2012, 07:54:41 PM
Regards, Larry
Keep in mind that in a patent application, the drawings are cartoon drawings designed to help the patent examiner understand the claims. Scaling a patent drawing is not advised. Use the drawing to understand the words, which are designed to claim far more than the drawings show, even to things the inventor never tried out in a practical way, and may not even work. Pay attention to what Wayne says on his site and on the posts, and he said he would respond to a single question at a time in an email. Take him up on the offer.
Hello all,
A quick not on the spacers between layers - they are not necessary - We built our system large for a large range of testing - yard stick measurements instead of micrometers -
The spacers were to direct the lifting force - In our new patents - we show them attached together and as a solid.
Now - on that topic - we have four primary forces:
The last riser has full lift - like the Travis effect
Each layer increases the pressure into the "inner riser" (above the pod or under the pod if the pod is attached)
The Pod acts as its own float - Archimedes'
And the layering diameter "increase adds a Little lift" - in our three foot wide six foot tall model - about 250 pounds additional per layer.
The four of these combined - in relationship to the head of each layer - as Larry and others have calculated
I added that clarity - because of the question of surface areas "between layers" - they are not necessary.
They do help the system because the pressures in the system naturally center the layers and make assembly simple.
Just another note:
The thickness of our three foot wide and six foot tall model - is .20 per wall, and per gap.
the pressure you have to prepare for is only the head of one layer.
Wayne
And to you, sir.
@mrwayne. That was a very useful post. From a first reading I have learned a couple of thimgs.
1. There is no disadvantage in bolting all the risers together as one unit. So that being the case, If the risers are being custom made, in a three layer system , we could fabricate the riser assembly from three concentric tubes and a single lid to which the 3 concentric tubes are welded/glued.
2.All the walls and the gaps are 0.2 inches . Therefore the volume of all the "pockets" of water in the system are not equal. This had been worrying me as I had this theory that they needed to be, and therefore gap widths would have to decrease as we moved from the inner layer to the outer. In a smaller model we could perhaps use gaps of less than 0.2, but precise construction would be essential. In this sense it is probably easier to build a large model than a small. But it costs more .
I keep thinking that model building would be much easier if we could find a supplier of plastic or thin wall metal tubing in a wide range of sizes.
Quote from: neptune on June 23, 2012, 10:25:12 AM
How about having the parts 3D printed?
I`ve no idea of the costs involved though.
@M,
Thanks, looks great. Hobby model building is a go.
@All,
The attached picture shows the forces with Wayne's latest sizes.
Regards, Larry
Wayne,
Mondrasek who is an adamant supporter of yours (praise the lord ! ) has just p.m.ed me that I am an egotist and I shouldn't ask for pity because of my medical problems. haven't asked for pity, but trying to build while on disability insurance is rather difficult.
I haven't been blessed by the Lord like you have to have all that money and to offer $2,000.00 to anyone willing to build your device to prove it works.
Yet while I like Bessler's work, you like the Travis effect. Not sure who Travis is, but your own website is http://mrwaynesbrain.com/ (http://mrwaynesbrain.com/). What exactly are you supporting ? That you're smarter than everybody else ? Why not The Travis Effect by Wayne Travis ?
Thane Heins promoted his own work and he had something that was accepted by a professor at MIT who saw it. That is independent varification.
If I understand this correctly, you are seperating you from yourself, like Jesus the Holy Ghost and God are one, you and Travis are 2 different people but are like the Trinity are 1.
And yet as a Christian you are thanking God, the Holy Father for what you will be doing in his Holy name, like telling everyone what a big brain you have and how we are blessed by your presence.
Amen Jesus, I myself am glad you are here. It has renewed my faith in God, Thank You.
A sinner among sinners
@M., sad to say, the surgery that messed me up was performed at a devoutly Christian hospital. I could easily spin this as my complications were easily avoidable.
I am a newcomer here, but I do have a sense of decency. I would like to request that nobody reply to offensive posts by Johnny874 publicly. If you find any of his posts offensive, then notify the moderator instead.
Hi Neptune,
I don't think a single lid would work as it would loose most of the Travis effect, each Riser would have a much smaller surface area and still seeing the same PSI. For instance, in my previous post of Wayne's latest size change, if it were one lid, Riser 2 SI needs to be subtracted from Riser 1 SI then multiply that by 2.6 and you can see the effect.
In the MTO the gap clearance can easily by adjusted by changing the 'Riser 4-Side Increase' variable.
Regards, Larry
Here you can see the effects of having a larger water gap around the Outer Riser. The comparison is made for the case where 5.85 in^3 of water has been removed from the center Pod section of the model as compared to when it is completely "Full" and at a restrained full stroke. The 5.85 value was used as this is right where the model with the smaller gap has lost enough buoyancy to overcome it's own weight and would begin to drop as the water level drops.
In the system with the bigger gap removing the same volume of water has a lesser effect on dropping the buoyancy on the Outer Riser. It is still well buoyant beyond it's weight. So only the inner two members will begin to drop as more water is removed.
Does this matter? Probably not, if the system is designed to account for this.
But in the case of the smaller gaps (all around) you get a much larger change in effective water head in the system for smaller water volume changes.
Thanks,
M.
Edited to add: Forgot to mention that the larger gap is achieved by replacing the 6 in OD x 3/16 in thick tube with a 7 in OD x 1/8 in thick tube that is also available through McMaster-Carr.
Quote from: mondrasek on June 23, 2012, 02:20:39 PM
Interesting observation. We may have to adjust the outer column to where the system would sink.
Regards, Larry
The outer column is a tradeoff depending on how you want to use the potential energy stored there. The amount of potential energy should be a constant based on how high the column of water is raised vs the volume of water. The potential energy stored would be an integral calculation. The question would be how to use it without unbalancing the total amount of water in the closed loop system?
@Wayne, can you ask Moondasek or what ever it is to quit preaching to me. he tells me all of my problems will go away when i put God first in my life as he says i have to follow you and him. If i wanted to hear a sermon on why people are special because of their relationship with god, I would go to church.
And I hope Wayne that one day faith will allow your machine to work.
Wayne@
I will quit posting in here.
Your machine is not gratuity powered, it is mechanical. sorry, it is powered by gratuity, not gravity. my mistake.
Quote from: see3d on June 23, 2012, 04:13:15 PM
The outer layer has a significant purpose at this stage of understanding the system -
The Last riser - the largest surface area - needs very little head to overcome the total weight of the risers - keeping that in mind -
The Pod is "also" used to keep the weight of the system neutral
The weight keeps the system in a precharge condition.
Now - in set up - you want the maximum usage of the pod,
a fully submerged pod at stroke is best -
SO to sink the system -you only want to lower the water (head) around the pod enough to sink.
So if you will add ten inches of head to the pod in order to stroke - reverse that ten inches to sink -
Now the last riser is you adjustment - you can add or subtract the head (water volume in this case) in this layer to balance the system.
Just an example - if you use 2500 pounds of weight to keep the free flow pressure at least 5.0 psi - the pod itself will not neutralize the weight - just increase the head in the last layer - a tiny bit of pressure goes a long way when you have a large surface.
In our set up procedure - we over charge every layer - then lower the pod water level to the lowest operating point - then lower the water level in the last layer -until the system begins to sink, - or 5.0 psi is reached.
Set up is complete and matched to the weighted system.
Wayne
The weight - which is used to keep the air compressed (and head) -
In our early model - we had the water connected between systems - this resulted in a bad scenerio - where when one side was set up better than the other - the better side would end up pushing more water into the other side -
our solution was two seperate bodies of water - seprated by a dual sided cylinder - the cylinder cost $19,800 each - and so we went to the convoluted bags by firestone - for $900 each.
My point is - We are closed looped by energy - but each Z.E.D has its own water - and its Own Air - they do not trade sides.
This is where some of our energy exchange losses come from - we take some water out from the pod into the bag - and transfer that pressure thru a lever to pressurize the other bag - and then we add what more is needed.
Wayne
We have fully modeled the gap - Or Volume equalitity - and the results were/are - that in a six layer system - equal gaps are just fine -
When you move to eight layers - then the fun begins - the expansion and compression rate to volume begins to mess with stroke length - so you adjust with the clearances.
Wayne
Wayne, is Mark still scheduled for the 28th?
Maybe a live video feed from Ustream?? :)
You People impress me,
My Patent attorney told me that few people could - or would wrap their heads around a system (like ours) that had so many naturally correlating effects within the system - you are doing well!
On that note: does it amaze you yet on how much is going on in basically a single moving part (when they are attached together).
Now for a big jump in your computations - I know some of you are working ahead - so.......
Consider the Weight - I told you it was to keep the air compressed - the heads in place (partially) and to control the sink rate of the system .... right -
Two More reasons for the weight:
First - as you have noticed - the effeciency of the system is best at "ideal" in most systems to get to ideal requires going from 0- ideal and back again = over and over -
The weights let us skip past the first 55% of the system and function only in the begining of the "super effecient range".
The weight would seem to some to be a waste of energy - or a simple teeter taughter effect - which it is (in that normal relm of physics - but to be able to cancel out the need to go from 0 - ideal - and instead operate at 55% of ideal too ideal only is good, very good.
We do not get to "eliminate" the need for the weight - but we do not pay for that part of the process over and over .
That was hard for my engineers - they wanted to squeeze everything out of the system - which means - you have to put it all back in - poor logic with a free energy machine - net Zero. They insisted on light weigting the risers - I argued - it cost us nothing if they are equal on both sides - they argued "Ideal usage" I argued - pay for everything - results in nothing.....
Part two:
The weight and mininum pressure effect:
As in our last model - we have enough weight to keep the pressure at 5.0 psi hydro - this means that if we had chosen to place our pump at the bottom of the system - we would have to overcome the 5.0 and then charge it to 8.0 in order to stroke - but we do not do that - we raised our pump to an elevation equal to that head/psi and so - when we push our water into the pod - the pump has a resistance of - well 0-3 psi - which is much better than 5-8 psi.
Three pounds is not three pounds - Some one will jump on me for that - but to let you all work it out - I will just say - that you can raise the water level in a column from any point - it is harder the lower you go - just in the friction of a seal ---
To be fair - the weight eliminates the input cost of 5.0psi - and reduces the ideal use of the system (please recall that fully utilizing the ideal results in under unity.
Raising the pump eliminates the stress of the exchange - that stress is what tore our model seven apart - during long runs.
- when you get done with this part - let me know - and I will explain the inverted pump system - 20% reduction in pumping cost -(real good).
Got to go
Again - very impressive teamwork.
Wayne Travis
Quote from: Lakes on June 24, 2012, 09:00:07 AM
I spoke to Mark two days ago - he is ready now - we worked out a game plan - now that we have our Debree clogging checkvalves open issue put to bed -(PLEASE OH PLEASE - paper towel pieces were introduced to the system in the plumbing upgrades - major pain).
We will run our pre test runs starting Monday - after we are sure we do not have new clogs - I call Mark and he will come - the 28 is still our goal.
He has been very patient, and our birthing issues only fuel negativty - fortunaltely The Z.E.D portion of the machine is very resiliant - continues to function without issue.
After his check - the next team gets scheduled.
Wayne
A question was asked about a weight selection calculator -
We do have that in our system - We are not releasing that work without NDA.
Our Model allow us to state the required output "Net" such as "50kw" and it will find all of the size hieght, width, layers, and weight that will match that output. Then we chose which to select - based on several factors - shipping manufacturing, location etcetera.
The model takes into considerations about 3000times (rough guess) - the information you have uncovered so far.
We have spent four years - not struggling - but in careful understanding.
Concerning your models at this stage, I suggested 1/3 of the ideal of the system - since you have discussed small systems - if your system calculates to lift 600 pounds (at the end of your stroke).
- add the weight of the risers and then add enough weight to reach about 200 pounds.
You will discover that the exhuast pressure created by 200 pounds is over half the energy required to lift 600 pounds.
Some of you may have noticed that we have 5.0 psi in our system from 2500 pounds of weight - and we only add 3psi to get to 8 psi to lift 5500 pounds (which is our operating lift).
So my suggestion - fill out the NDA meet our engineers that have busted it for years to come to a complete and predictive model....
Or, just add a weight to increase your exhuast above half the operting pressure.
We are fortuntate to have a large o/u operating range, this will get you in the good.
Thanks Wayne
@mrwayne.Many thanks for the new information that you have given us. It will take a while to digest, but I feel I am learning all the time.As always, what at first seems to be a very simple device gives us lots to think about. I would say that 80% of people who drive vehicles, do not understand how an engine works. An engine has far more moving parts than a ZED. And yet it is very easy to understand by comparison. As I have long suspected, the best efficiency is all about dimensions and proportions. I think it was Stevenson, a pioneer of railway locomotives, who said that any fool can design something complicated.But to make it simple needs a genius. Look at the long history of this forum. We have sought OU in electronics, in coils , capacitors, and pyramids, to name a few.How ironic for OU to show itself in a device that could probably have been built by the Ancient Romans.
Wayne talks about "raising the pump" or injecting water not at the base of a water column, but at a point higher up. In a ZED we cannot inject water into the side wall of the inner chamber, there are things in the way. So I assume Wayne means that water is injected via a pipe through the base of the chamber which projects upwards to the required point. More later when I have studied more .
Quote from: neptune on June 24, 2012, 11:00:33 AM
@neptune, I think you only need to plumb the water exchange pipe to the bottom of the center section of the ZED. But the physical pump is then raised to the correct height that the head pressure of the water column from the elevated pump system to the bottom of the ZED is equalizing an optimal amount of the ZED operating water pressures.
M.
@Mondrasec.What you say about the input pump makes perfect sense. We are likely to understand more about this at a later stage when Wayne explaines his inverted pump scenario.
Looks like things are still on schedule for the Mark Dansie tests. The results of these tests will be a vital milestone. Public awareness of this technology is going to be an exponential curve. I would go so far as to say that once it has been in widespread use for 4 or 5 years, it might even get a small mention in mainstream media. I have always said that the first OU device to hit the market will cause changes on a scale that we are not capable of imagining. It is going to make the Industrial Revolution seem like a vicarage tea party.
Quote from: mrwayne on June 24, 2012, 09:32:27 AM
Wow, spend half of the day preparing for the hurricane and we get a Wayne storm of post. Thanks.
At first it did, but then it seemed it would be no difference if they are attached or separated by spacers and rising in unison, as long as the same surfaces areas receive the same PSI.
I'd liked to point out that it would not be a good idea to permanently attach on the acrylic model, it will need to be broken apart to repair leaks if they occur.
Regards, Larry
One point on Mark's visit,
Mark is a good skeptic - his aye on nay opens or closes the door to the access to the highest critiuqe.
Do not be misled into thinking that Mark's or any skeptics word will end speculation - that is not his purpose -
Mark's job is to route out the phoneys - the mistaken, and the confused and direct the real technology to those that can and will help.
When Mark's work is done - the real tests begin - and then you wll start to hear public non "fringe" discussions.
Wayne Travis
@mrwayne.Thanks for the remarks about Mark`s visit. Let us assume the Mark makes a favourable report, as I personally think he will. This will be a first step in the proverbial thousand mile journey. In some ways you will be in a worse position than Wilbur and Orville Wright. Whilst their achievement was momentous, it only made necessary the rewriting of books on aerodynamics. You have made it clear that you are not really interested in re-writing physics books, but what you are about to achieve will necessitate just that. As a side effect of what you set out to achieve, you are striking a body blow at the very heart and soul of physics as we know it . Rock solid concepts like entropy , and the laws of thermodynamics , are about to receive a strike that will rock them to their foundations. A lot of ivy league professors on fat salaries are going to be left wondering just what has happened.
Do not expect an easy ride. Fasten your seatbelt. You do not strike me as being a quitter, so hang in there. I am with you all the way, and I am not the only one.You have a tool that Wilbur and Orville did not have, The Internet.
Thank you Neptune,
History has a way of repeating itself - unless we learn from it, and then we can plan to do things diffirently.
I am sure you heard Mark D say that we were doing everything right -
What he means is that we are paving the way so that we do not repeat the errors that many others have made in trying to introduce a new understanding in the realm of physics - not a denial of what is understood.
The truth is - the understanding of physics has leaped year after year - it is immaturity that thinks that everything is understood and nothing new can be discovered.
It is also true that billions of dollars have been spent looking - someone wrote recently -
Paraphrasing - "History does not favor the idea that those with the most education or the most money make the greatest discoveries".
Mature minds know that discoveries are made by the people who chase anomolies - that many people write off as noise, fringe technology.
If I have one single giftedness - it is persurverance - no worries on faulire or quiting.
Thanks again
Wayne
Physics laws cannot be broken. They are known as "laws" because experiments can be done that predict the outcome. So you can perform any experiment and the physics "law" will return the same answer as the experiment. Everytime. Both positive and negative.
In the case of Mr. Wayne's ZED we are not dealing with a physics law, AFAIK. We are dealing with the "assumption" that a Conservative Field of Force cannot do Work. This is not a "law." It is only what has been observed throughout history (and therefor taught to students). But there is a difference between this "assumption" and a "law". The law can be used to predict the outcome of an experiment. The assumption cannot. This is because there is no experiment that can prove that the assumption is incorrect. How do you "prove" that something is not possible?
Mr. Wayne may be rewriting the teachings about the "assumptions" that a Conservative Field of Force cannot do work. But he is in no way rewriting the "laws" of physics.
As I have been taught, and have repeated: The laws of physics are pretty good. They have been used to launch rockets from Earth and deposit their payloads on Mars. I mean, that is pretty good!
M.
Quote from: Seamus101 on June 24, 2012, 06:55:51 PM
He is doing no such thing. Apart from from unverified assertions that his device works as described, his explanations of how this occurs are nonsensical and demonstrably false.
Welcome back Seamus! Please demonstrate the falseness?
M.
Essentially he is making the assertion that water can be made to flow uphill, gaining gravitational potential energy without the input of work. It doesn't, not in nature , nor in this device.
It is my policy to be respectful, but do not confuse my respectful nature with giving you permission to be disrespectful.
Here are the facts for Seamus:
You have created a new user name - added 28 posts, all 28 on this thread, most assertions and misdirection of our claims.
You have failed at making one positive contribution to this thread - In defense or denial of this thread.
And in regards to your last comment:
You already know that water flows in which ever direction up / down / sideways - away from the higher pressure towards the lower pressure.
The direction of water can be controlled by controlling those pressure differences,
The effect of gravity within that flow can and has been used for work for centuries.
You don't have to post here humorously, we are trying work together.
I am not sure how we have injured you to warrant your tainted attention, but in case it was in my error - I am sorry.
Wayne
Seamus wrote,
"1. Post conclusive proof that a single layer system employing the travis effect could result in overunity energy, no matter how small.
2. Failing that, demonstrate what new mechanisms other than buoyancy and expansion/compression of air are in play and providing overunity energy in a layered system.
3. Failing that, provide a conclusive account of how you machine increases the *energy* (not just the forces) of a closed system,( ie without any external inputs no matter how small).
4. Failing that admit your machine is not OU.
Did you copy this list from Mark E and old Kanshi notes?"
You - just as Mark E,
Have mistakenly set yourself up as the expert - in which you understand nothing about our system by your list of questions.
Lets start with your largest flaw in your question - which is the base of your argument for all the questions.
You make the assumption that layering a system can not improve the efficiency.
Your point in simple terms - would be to say that hooking two 35% efficient motors together does not make a 70% efficient motor - your would be right if that is what we have stated. - It is not what we have shown.
Each layer of the Travis effect adds to the total lifting capability - just like hooking motors together would - the difference is in the input - adding layers does not increase the volume of our input - and the increase in pressure is not proportionate to the output.
I agree that hooking six 35% efficient 2hp Briggs ans stratton motors will net you 12hp - the increase in cost is proportionate to the output.
But you have ignored that stacking six layers of the ZED together increases the output at a disproportionate rate to the input -
which makes your questions - invalid.
Several forum members have offered calculators for weeks that you can use to verify the disproportionate aspect of our layering system.
To be clear, your list of questions is based on a fallacy in relationship to what has been shown..
If you are Mark E or speaking for him, do your homework as we have already discussed - if not - you can wait until the tests results are released.
You have not demonstrated the effort to understand.
Good night
Wayne
Hello All,
Pretests begin in the morning, so my time to post will be very limited.
Wayne
A good question was asked by a college student,
"It is guessed that the weight of the riser assembly (piston/float + top deadweight) is equaled by the default upward buoyancy force of 4.8psi. A 8psi would nearly double this force. "
The guess is wrong:
The function of lifting a weight using the layering system has a different set of principles than using the weight to increase the pressure in the same chamber.
The linear scale of (hydro) pressure to lift increases toward ideal - this means we get more bang for the buck, lift more for pound in the higher range than in the lower - this is extremely useful - taking advantage of this relationship is fundamental.
In simple terms - increasing the pressure in the pod from 7 psi to 8 psi (hydro) of pressure will lift an additional 687 pounds (for the cost of 1 pound of work)
In the lower scale - 3.8 psi to 4.8 psi (Hydro) 458 pounds creates 1 psi of hydro pressure -
So the input value depends on the point in the scale - the weight value - and the lift value is also controlled by that scale
If you put 5500 pounds of weight on both of the Zed - we would have 8psi at all points - same scale = no gain.
Currently - we uses the lower scale weight to increase the value of the sinking system - while benefiting from the higher range on the upstroke.
Wayne
@Mondrasek. We basically share the same opinion on the laws of physics, and on assumptions. Perhaps the terminology I used could have been better. My point is this. Science is indeed a wonderful tool. It is the summation of all mankind`s knowledge up to the present day. But the worst assumption we can make is that we now know everything. Science needs to be updated in the light of new discoveries, which may lead to past assumptions being cast aside. After all we used to "assume" that the earth was flat. It only takes one white crow to prove that not all crows are black.People often fall into the trap of saying things like "There is no evidence that we can harvest energy from a conservative force." In the words of James Randi, "Absence of evidence is not evidence of abscence.
Here is something I have been thinking about. Wayne himself has said that this technology is not one-size-fits-all type of solution to the worlds energy problem. He has said that his device is probably not a cost effective way to power one home, but is more appropriate for groups of homes, farms, and industrial applications. And you will not be driving a Zedmobile anytime soon.
Now think of first steam engines, used to pump water from mines . They were huge , cylinders of 6 feet diameter, and 30 foot flywheels . And boy, did they turn slow, maybe 20 RPM. A modern engine is much smaller, turns very much faster, and can have the same output power. So, within limits, the power of an engine is related to its speed. Wayne`s machine works slowly. There is probably an optimum speed of operation. We are pumping water through narrow gaps, that have to narrow. So the faster we force the water through, I suspect that the more energy we consume to do it. It seems logical that in a smaller demonstration model, that it could operate somewhat faster.
So what I am saying is this. Although the energy density of this device is relatively low, if used for the right scale of application it is a world changer. And remember that this is just the beginning. Further development is inevitable.And equally important is the encouragement this will give to the searchers in other fields of energy research.
@neptune. Yep, we are on the same page. I only chimed in to hopefully clarify if anyone might interpret your prior post to mean that physics laws are being broken. I do agree that the amendments and new information that would be a necessary part of acceptance of a ZED system would require a lot of texts to be changed.
Here is an idea that keeps coming to the forefront of my mind. I work for a Japanese company and have for over 20 years. So the plight of the Japanese people in the aftermath of their Tsunami/Earthquake disaster was watched by me any my coworkers quite intently. The fallout from those events affect our ability to provide product to our customers still today.
Japan had around 50 nuclear reactors in operation at the time of the disasters. Currently they have zero in operation. As each reactor has been taken offline for maintenance the people of Japan have successfully protested to keep them powered down. So now they are a highly industrialized country that is starved for power. Acceptance and licensing of the ZED technology in Japan could be a major kickstart to world change.
M.
I know nothing of the Japanese from personal experience, but as everyone knows they are very innovative people. When Japanese motorcycles first appeared in the UK, they were considered a joke. Within a few years, the joke was on us. Their machines were light years ahead of ours. Fukushima was headlines for a time, but now we hear nothing . The Japanese have to live with it, in some ways forever. They are not the only nation having a No More Nukes policy. What is the reaction in the UK? Oh haven`t you heard, we are having10 brand new ones. Hopefully they will get the sheds built just in time to install the ZEDs. Japan is an energy revolution just waiting to happen. She is not in a position to wait long.
What I would like to see is one customer running a factory on this, who can not only cope with the publicity and visitors, but who can turn these visits to their advantage. Guided tours anyone? Of course the best factory for the job would be a ZED factory.
UPDATE. I have just read the latest news on mrwayne`s website. Two items immediately caught my attention. Firstly, his team are working on an "Educational Model" I will be interested to find when that will be available, and under what circumstances.
Even more vital, it would seem that now, the actual source of the energy has been discovered. I very much look forward to finding out what that is. Might even silence a few nay-sayers, but I doubt it...
Hello Seamus,
I am glad you are doing your due dilligencse - good form.
I was going to ask you to explain this premise a little better, I am trying to follow your logic in your hypothetical example, but I realized you think our O/U comes from the precharge - no - It does not.
"To be 'overunity' the ONLY energy available to enable cycling between the two states is represented by the initial state shown with a body of water initally raised above a free surface. This equates to a 'pre-charge' of the Zed device. At the end of the cycle this precharge must be at least fully intact and for overunity, be raised by delta h."
You seem to be saying (assuming) that energy for overuntiy must be present in the precharged "state" in order to cycle....... your premise of our operation is wrong.
If this is true - I am begining to see why you offer opposition, well done.
Before I continue - let me say - I agree with your conclusion based on your premise.
Your premsie - A sum of what you know and the assumption you based on those physics are correct.
For a little clarity - the precharge of the system is merely to set the stage for the operation of the system - it is "not" the operational - or cycling energy of our system.
Since you base your premise on the assumption that our energy to operate comes from that source - you can not analyze our process.
Precharge is set up - it is a one time cost to put the water and air into the chambers - it is only counted as a cost to account for all the energy that goes into the system - it is akin to counting the energy used to bolt the tire onto a car, or putting water into the radiator.
Why the cost of precharge is mentioned - When our sketics reviewed our "Non" Hypothetical system - I graciously accepted the
"Exceptional Burden of proof" which included all input - including filling the tanks with water/air - as input energy.
The Sketics noted on the Video - that the Precharge values did not get consumed and continued to return to the same set up - each stroke - and even the next day - without any additional input.
Missing these points made by others is where you and I get seperated - those were key points to hear.
The level of sketisism - that we openly subitted to - was far beyound what you have realized - and we passed.
I will add another post repeating and expalining our operational process - and "energy in" and where it comes from.
Wayne
Operational input:
With both Zeds precharged (filled with water and air)
then equalized - (common Column equalization)
We have a state of being - where the resistance to lift (the weight of the risers and any added weight is counter balanced by the other Zed. Teeter taughter - is a good example of the static state.
That is very important - in the static state - nothing is moving - all things are equal
If the system were to be caused to move - the resistances change immediately.
The up going Zed will have the resistance of the hydraulic cylinder used to capture the buoyancy beyond the buoyancy used to float the riser and weight.
The lowering Zed has benefit of the weight of the riser and any additional weight.
To be clear - our teeter taughter - "when moving" is no longer equal
To start the "moving" - energy must be added to overcome the new resistance - the hydraulic cylinder.
Now follow closely - in the up direction - the added resistance 'increases" the required head pressure in order to overcome the "new resistance"
The energy added - become the new head - and the resistance is overcome - the system strokes and produces and stores the Hydraulic production - the energy added - continues until the end of the desired stroke.
Now - that head is still fully intact at the end of stroke - not just the value to overcome the resistance - but also the value to stroke.
The next step is to stop adding any energy - and equalization occurs again - everthing moves to center - naturally.
Note: the energy required to overcome the resistance - was converted during stroke into a second energy - while the original energy used is still intact - you see "head" and the resultant air pressure "is" our opposite and equal reaction.
Now we are half way through a cycle - and heading the other direction - one difference than the start - the first Zed is still all the way up - and the other zed is all the way down.
Equalization after the stroke - is not the same as precharge set up - where both are at equal distances.
We call this position post "Free flow" when the higher tank (risers are higher - with fully charged Head) is allowed to flow into the lower Zed.
Free flow can be easily calculated (for those following) as the average between the top of stroke head and the bottom of stroke head (In my examples offered on line 6.7 psi hydro)
From the post free flow position we have a balanced teeter taughter pressure wise - but not in travel.
When we now reverse the direction of the system - the same resistance to upward travel is realized -
The energy required to overcome that Resistance is now less than the initial stroke (due to the Free flow pressure - both the available and the amount required to overcome the resistance.
That energy is added - at the rate needed no extra is needed - the resistance balances the input.
At half way through the travel and production (if we were to stop) the system will now mirror the original configuration.
The energy required to evercome the resistance is stable, and once again stored in the for of hydraulic production and an equal volume of energy is stored in the head.
And the system repeats.
At this point - it should be clear - that the production of the system is supplamented by the latereal transfer of "Head" into the other Zed - More than 50% as I have stated in previous explanations.
{Most engineers have their own OM-Gosh moment about here when they realize that this adds up to - in total - one Zed operates evenly and the other is totally free - which is why we say is general - if you want 100kw net free energy - we build two tanks capable of producing 100kw each - and net 100kw}
back to the operation:
Just at this stage of the operation - we have reduced our total input cost by half.
For Seamus - your drawing show large tanks - the rise of water in your tanks during the process to overcome the resistance will hardly be recognized as a value - but it is well understood that when creating a displacement:
At least three things are occurring:
Head is generated (stored energy)
Air is compressed(stored energy)
Buoyancy is realized (stored energy)
In your system - you are adding and subtracting the value of one effect you will need to adjust when you add your next example.
We are utilizing all three, and few we have not yet discussed -
Wayne
Oh, I forgot to state where our input energy comes from? - from the production.
Just as our input cost is reduced by Over 50%, that results in our production being over 50% above our need - Like Mark Dansie noted in his November Video.
Wayne
Wayne, any more details on the "educational models"?
Will it be a physical desktop model like others are working on here?
Thanks for taking the time to post here.
Dennis is Hammering out the manufacturing details of the educational model.
At this point in Dennis's decision - it will be a simple input output system demonstrating the lifting of a larger weight the same time and Distance of a smaller weight.
A small version of what Mark Dansie witnessed back in May of last year.
Some of the members here are already involved with the project.
If you would like to get involved with it, just e-mail me and I will forward it to Dennis.
Let me be clear - Dennis is helping because he values open / honesty - our educational model is as something he looks forward to as well.
One of the mistakes inventors make is to claim to "endorsments by association" that is not my character.
I can quote Mark Dansie - because he has openly explained his position.
Dennis is Good and very intellegent man, whom I have chosen to trust, that is our relationship.
You are welcome for the posts, actually you all help me to put into words and view the operation of our system in clarity - I appreciate it.
Wayne
@mrwayne. Thanks for the detailed explanations. I am a bit unsure about your explanation about where the energy comes from. As I understand it , you are saying that we have an excess of energy because we have saved energy at the input, by using exhaust from the descending ZED. Sort of saying that there are two ways to increase your bank balance, one is by earning more, and one is by spending less.
However, I believe that you said it is possible to build an OU machine using a single ZED, and although it is less efficient than a two ZED machine, it is still OU. That being the case, there is something else happening here. I suppose that conventional physics would say that it must in some way extract energy from outside itself. Just what form that energy takes, is hard to say. It could be gravity, or something else. But this is the question that sceptics will ask. It is possible that at this stage, this is a question to which you do not know the answer. There is no shame in that. Ultimately, all that matters is that it can be shown to work.
Hello Neptune - it is time to test so i have to go,
But let me say - a single Zed system can demonstrate a gain over the operating cost - but it is not of much point -
Our Goal is to provide abundant excess energy - the two Zed system is better for that.
The "cannot beat" o/u comes from the simple travis effect as shown in Tom's Videos.
The whole operation is dependent on differential exchanges - namely caused by gravity.
The Physics of our system are simple - not magical as Seamus arrogantly alluded to in the naming of his drawing.
The cost of the entire operation is reduced by reusing the energy stored in the head - after the buoyancy has been captured.
The cost is less than the capture - before the resuse of the head (exhaust) because of the layering system.
You can check that with one of the calculatorslike Larry provided - compare to a common hydraulic cylinder - surface area x pressure = lift
we can lift more than a Hydraulic cylinder - which means if we were using a hydraulic cylinder to create the lift pressure and volume - we can capture more than used.
Remember - we use a 1"Si cylinder (input) to operate a 5"Si cylinder (Output) at the same pressure.
if you build a chart showing lift from 2 pounds to 9 pounds you will see a graph that climbs at a higher rate than a cylinder of matching surface pressure -
From an old note: 707 Si x 10psi would lift 7070 pounds - we lift 7700 with 9psi in our current three layer system.
BUT -on the low side 0-5 psi we are worse than a hydraulic cylinder 5 psi only lifts 2500 pounds.
We use that to our advantage - it only takes 2500 pounds to create 5 psi hydro, exhaust
psi - the weight puts us in the operating range of being "above the hydraulic cylinder" at no loss.
Do the math - I have to go - crew standing by..
No magic - simple mechanical and operational uniqueness - mind boggling simple.....very good for this our energy needs.
Wayne
@Neptune. Yes, if a single ZED shows OU, then, even though not as efficient as a dual, the loop can be closed to self run (by definition) -- as long as the loop closing mechanism does not lose all the excess in friction. It has to be a relatively simple and pretty much friction free feedback system. The dual setup has a nice straight forward symmetry for practical applications. If an educational model is created as a single ZED, there is no particular reason that two could not be connected together for a dual ZED educational model.
Hi Wayne,
You noted, "Free flow can be easily calculated (for those following) as the average between the top of stroke head and the bottom of stroke head (In my examples offered on line 6.7 psi hydro)"
I presume the examples you refer to are shown in your post #373, "ZED through complete cycle-1"?
In that illustration, you show the pressure at the bottom of the head stroke as 4.8 psi, and at the top, 8.0 psi. And just as you said above, the post equalization free flow pressures are shown there as 6.7 psi.
For the sake of clarification, isn't the average between 4.8 and 8.0 not 6.7 but 6.4--or have I misunderstood/miscalculated?
Hello Cisco,
Thanks for the clarity - most of the time when I am answering questions - I answer directly related to the operating pressures of that moment in time - it does not explain in detail all of the lessons learned and changes to the system - just the pressure.
6.7 was the free flow pressure when Mark was here - it was increased from the 6.4 by adding weight to the system.
So the range if ideal usage changes - which effects the value of the free flow - in pressure volume and speed of delivery.
The formula still works to each specific range of usage.
If you lowering pressure is 4.0 and your overcoming resistance pressure is 8.0 ----- 8 4 / 2 = 6 predictable Free flow pressure
Thank you for the correction.
Wayne
Update on design of the 6" OD clear acrylic ZED model:
Changed the outer tube back from 3/18" to 1/8" thick, since this works better once a preload weight is added. Added a 2.2 lb weight (in calcs only) to the Outer Riser to load to approximately 1/3 of the "ideal" buoyancy potential, as far as I understand it.
I removed water from a fully stroked ideal setup until the Pod and Inner Riser were about neutral buoyant. The volume of water removed was 5.748 in^3. At this point the Outer Riser was still slightly buoyant so I removed water from the outer ring until it too was neutral buoyant. I went back and drew the initial "Full" condition with this slightly reduced water volume and redid the calculations. Now my system is preloaded to just slightly more than 1/3 of it's full buoyant lift potential, but I believe we are well within tolerance limits.
If my understanding is correct, removing the 5.748 in^3 of water should put this single ZED model at it's equivalent "free flow pressure?" If so, removing 2 x 5.748 in^3 will define the amount of water that needs to be exchanged (with half a pump system) in order to define the system stroke? I'm still trying to decide whether I have convinced myself of this or not. Everyone's thoughts are appreciated.
M.
OK. It is Tuesday night. If everything goes according to plan, we can expect Mark Dansie to start his tests on Thursday. They say that patience is a virtue. But with a forthcoming event that is potentially much more important than the first man on the moon, waiting is not easy. I know that Mark is there to check that it works, and not to prove how it works. I seem to remember that Mark will spend a couple of days testing , but I am not certain. No doubt he will need time to get back home and write his report. I just hope that he will not make us wait too long before saying what he has to say. I know that Marks report is just the beginning, but it is a very important step. Personally I find it very exiting.
Neptune,
You are jokimg, right ?
edit wayne run it for two days, it is a simple test. just have faith,
Quote from: neptune on June 26, 2012, 04:31:49 PM
I am excited to - Mark will come as soon as I ask - he is ready too.
But I have not asked him to come yet, I might after tommorrows Run.
As Mark wisely says - it will be when it will be, do not rush this moment. - one of the mistakes inventors make - rush in and blow the one good chance (we will not blow it).
Now I send a Report each step of the way - and here is the one I just sent:
Hello Men, V
ery good day. After replacing the last suspect leaking check valve - and the pressure loss remained - we pulled the lid off the Zed and found the leak was from the fitting under the lid inside the top of the Zed. - repaired and are leak free at last! M
atthew reversed the operation of his water level adjustment calculator - and gave us the low position based on our end of stroke data (high position) This is where the water level should be at the start of a cycle / so now we have both. We set it up, ran it and verified the accuracy. We also verified the production strength :-) we are GOOD! In short - we gained 750 pounds lift per inch - above the internal input cost......... Everything is working great - In the morning we will be fine tuning the water level (minor changes) and running the system. I have one manageable set back - we only need 1.375 si cylinder for the lever arm assist - (the internal input) and we have the options of 1.0si and 2.0si Running 2.0si is a big waste - still over unity - but overkill the input - I used to be able to move the location of the cylinders - but not since we mounted it horizontally. Another option is lowering the output - by lowering the operating range - with less weight. - but that lowers our output too. T
he third option is to adjust the system to use all 2.0si - that puts us dangerously close to blowing skirts. I will have to make a decision, Thanks for your support. Wayne Travis
President
HydroEnergy Revolution LLC
mr.wayne@hydroenergyrevolution.com (http://www.overunity.com/mhtml:%7BBA0E7C10-7514-4EB9-8921-F3B89DA6F745%7Dmid://00001524/!x-usc:mailto:mr.wayne@hydroenergyrevolution.com)
Hi Seamus. Of course energy is added at every stroke. It comes from the output. This is called LOOPING.
Energy density increases as you scale up, in a non-linear fashion. How ever low the energy density is, it is still a WHITE CROW. The energy density of the present machine is higher than all the Hot Fusion devices ever built at a cost of Billions of dollars. It is indeed possible that white crows are the only type we will see, soon, as all the black ones will have been eaten by academics.
Quote from: Seamus101 on June 27, 2012, 04:05:06 AM
So,you admit that extra energy is being added at each stoke. How large is this input and what proportion of the net output is it? In this calculation do not include any energy that might be be recovered by exhausting the precharge energy.
Even if this device is overunity, and I am fairly certain it is not, it doesn't sound like the energy density of the output is large.
Seamus -
I tire of your immaturity, I have waited patiently - and you persist.
I am here sharing our world changing discovery - and you are busy eating "sour grapes" - what is up with you?
I would rather you chew your grapes here - and leave other inventors alone - I can take it.
One of the primary reasons I was able to find a system that produces Over Unity - was that I never tried to take a system and reduce all of the losses - instead I designed a system with Net energy - from the beginning.
I saw the Net energy possibilities in our Travis Effect - which I would not have seen if I was looking at reducing losses.
Your comments show "that methodology" as being lost in your dogma, I am sorry for you. I am merely humbled to be called the inventor - that's all - and I have the persistence and ability to see it through - I thank God for that.
We have never concerned ourselves with Over/Unity - My goal has been to provide Energy Independence -
And why you are such a turd about our long and hard efforts - must be pride.
We are very, and I mean very Over unity - and energy density - Our 50kw continuous model takes up the space of a full parking spot - and will power the average consumption of thirty homes (USA).
It operates with no Fuel, No emissions, Can run near Silently, and provides freedom.
p.s If it takes up too much room for you, have yours put in the basement - it does not need wind, the sun, nor any fossil fuel.
You might consider staying off all comments sites if you can't man up to your errors. I make them, make corrections and apologies, and then try not to repeat them.
On that same note: My engineers felt the same passion to protect the entropy idea of an "operating system" as well, yet they were professional about their original objections - and we are a good team now - you close doors, and very unprofessionally.
Wayne
My web Guru added a guest book to my web site:
http://hydroenergyrevolution.com/ (http://hydroenergyrevolution.com/)
If you would like to leave your mark - as witness to this work I would love for you to sign the book.
Also, I write weekly updates on the Current objectives page if you would like to keep track.
Wayne Travis
Quote from: neptune on June 27, 2012, 07:29:55 AM
Hello Netptune
Our system can be scaled and linked to replace the power of Nuclear - much cheaper and with a smaller foot print, so no worries here.
Just clean - safe energy.
We are currently Blue printing our Beta Models -
Our due diligence means we allow the inspectors to come, so I also spend time with the Demo model.
Yet, our understanding of the design capabilities are very advanced, very clear, and very scalable.
Currently - thru direct contact, and those Mark has made - we are offering the funding of the Beta systems in exchange for exclusive rights of sales, manufacturing, distribution, and maintains.
I heard comments about open sourcing - open sourcing has yet to provide the funds to see the project through - our goal is to make sure energy Independence becomes a reality - first.
We have had preemptive offers, which I respect - they are in the process of vetting.
Unfortunately - some people see the opportunity and try to become middle men - we need to deal with the people who can make it happen.
Somebody out here is in the right position, the right mindset, with the right contacts or capabilities - and have just been waiting for this discovery - I welcome them.
That is how all of our hard work has moved ahead - it has been a blessing.
If we have any trouble, or people wait too long to get involved - we will use the demo model to claim a few Prizes - ;-)
Wayne
@mrwayne. In a sense this project is already open source, in the sense that you are hiding nothing. Ok, there may be further stuff that you are not telling , until you are granted further patents. No problem with that . Before my health forced retirement, I was a business man, in the sense that I worked for myself, and made a good living. But I get the impression that you probably run a large and diverse business which is a whole different thing. However that puts you in a strong position to do research and development, and marketing. How many inventions have been lost because the inventor was not in a position to develop and market the idea.
In its present form your machine is more suited to groups of homes rather than individual houses. That means that to benefit from this, there will need to be cooperation between groups of people. That in itself is no bad thing.
You seem to have a step by step plan in place to bring this to the world. Although the need is urgent, it can be a case of more haste less speed. To build a Nuclear power plant takes 10 years. And here in the UK we are just starting to build 10 new ones . My hope is that by the time the buildings are complete, Nukes will be redundant. Here`s to the Future.
This is a bit OT, but I love the sentiment expressed. It is the same as I have expressed before about this device and others. This particular one is an excerpt from: A Student’s Guide to Cold Fusion -- Edmund Storms. It is his closing statement on page 40 that I think is great:
"Science has been successful because certain rules of evidence were adopted centuries ago, the so-called Scientific Method. These rules require that many people using different devices duplicate all novel observations. Such replications reduce the human tendency to deceive and to be deceived. In addition, the behavior observed in these various studies must show similar patterns, i.e. important variables must have the same effect in all studies, regardless of the equipment used. Having an explanation for a strange behavior is NOT initially necessary, although eventual discovery of an explanation is important. This is a good method and has served mankind well when it is faithfully applied. Science fails when these rules are ignored. They can be ignored several different ways, the most obvious being premature acceptance. Some scientists think premature acceptance is so damaging that they base their careers on protecting Science from such a violation. A less obvious problem occurs when evidence is ignored because a scientist does not WANT to believe results that conflict with a favorite theory. Initially, cold fusion was rejected for the former reason. Now rejection is based on the latter. The first rejection was valid and consistent with the Scientific Method. The present rejection is not."
"Skepticism, when carried to extreme, is as damaging as naive acceptance. At the present time, many people respect the skeptic for guarding the high ideals of science. Unfortunately, skeptics frequently cause much more harm by stopping progress, stifling originality, and turning creative people away from science altogether. Although many examples of this injury can be cited from many fields of science, the continued rejection of LENR is particularly egregious because of its vehement nature and the importance of the discovery..."
"Remember that new and strange claims do not have to be blindly accepted or blindly rejected, but only explored with an open mind. Important new ideas always conflict with conventional understanding. Such conflict should not be used as a basis for outright rejection before the possibilities have been carefully examined."
@Seamus101. If energy was added from an external source, such as an air compressor , a water pump , generator utc, I think Wayne would have pointed this out, or if he had not, Mark Dansie, or other independent examiners would have noticed . You say that all the output has to be used to reset the machine for the next stroke, and the output is nill. Wayne says about one third .
At the moment all you, or I have to go on is what Wayne, and Mark et al says. Not unnaturally you want more than this.There are only 3 ways to remedy this.
1.Sign the NDA and go and have a look.
2.Build your own
3. Wait for Mark Dansie`s report, and the reports of other independent inspectors.
The question is how many reports will it take.There are still people who believe in a flat earth.This is something new and radical. The answers will not be found in your textbooks.
If you would rather I did not comment on your posts, ask, and I will desist.
Hello All,
The Right question now should be asked - is where does the free energy come from?
I have shown where the exhaust from a lowering side is added to the input of a raising side and in doing so reduces the cost of the up stroke. Simple Water column equalization - on the surface a very common process.
Now let me teach you why Zed is so different than all the not Layered systems - why it produces a net excess energy.
Before you proceed - it takes understanding the full circle of the operating system - just a warning to those that look at one point in the system and make opinions.
Verify this with your own models - and calculators:
Record the stroking lift of your model. Divide that lift by the input pressure. - this will give you the lift per pound of input (Stroking lift is reduced from the ideal to allow for the stroke length desired)
Our stroking lift is 6000 pounds (the weight of the risers and the production). 6000/8.8=681
(Our Ideal is 7500)
Now take your ideal lift (not stroking lift), divide it by three. In our demo - ideal is 7500 pounds/3=2500
Now lower your input pressure in your model until it will only lift that amount (2500).
Take that input pressure and divide it by the reduced lift 2500/5.0 = 500
In recap so far at stroking pressure - or production pressure - we are lifting 6000 pounds total at a input cost of 8.8 psi, that results in a term we call (Effective Surface Area) this is not a real surface area - it is a calculated number that tells us how much lift we are getting per pound.
The 681 is the ESA and is also the value of lift per pound we cost to desired stroking lift.
The weighted risers - total 2500 pounds - this results in a pressure of 5.0 and has an ESA of 500 - this is also the value of one psi input -
At stroke pressure 1 psi = 681 Pounds lift
At sink pressure 1psi = 500 Pounds lift
Total pressure needed to stroke is 8.8
Of the at 8.8, 'At least" 5.0 is coming from the lowering Zed (more during the free flow and the third quarter of travel) .
So our operating cost - is 8.8 - 5.0 = 3.8
Our stroking Zed is lifting 6000 - 2500 weight and risers = 3500 pounds Production
Now take the production and calculate the ESA 3500/3.8=921
Our input value - is 1 psi = 921 pounds lift
(The combined value 6000/8.8 is ESA 681) - the lift per pound if we supplied the input without using the exhaust or weight.
(Note: Our pod chamber - which is the input volume - is 737surface inches)
Now the input we use - comes from that 921 per pound production - looped - its value is already increased - and when we use it
That increased value gets increased again - because we only have to use the portion of the production that equals the NON increased value.
In our small model 60% of each Production stroke - is enough to overcome all the losses in our system (all nine energy exchanges w/losses are over come - with less than 60% of the production.
40% is our Net - this is our worst case scenario.
In recap:
The up stroke cost portioned - 5.0 psi was provided at a cost of 500 pounds per psi
and the 3.8 psi was provided at a production value 921 pounds per psi ZED - in a cylinder (actual surface area) 737.
(the actual surface area is the physical input volume) The layering system makes our Zed lift more per volume and psi than a hydraulic cylinder in the upper range - and worse than a hydraulic cylinder in the lower range.
That means we can lift two weights at the same time and get the super effectiveness of the up stroke - and remove on of the weights (production) and the other weight requires a higher pressure to maintain its lift - or .... provides a higher value pressure to supplament another system.
Compare this system to a hydraulic cylinder if 5 psi lifted 2500 pounds, 8.8 psi would lift 4,400 Zeds 8.8 lifts 6000
Questions?
Wayne
p.s I would love to hear in your own words a description of this effect - I would love a simplified way to share this with others.
The Hobby Travis effect model was built using the Material Take Off spreadsheet and foam board. All front walls were left off for visibility, the front wall is the same size as the back wall, so no issue. It proves that the MTO is accurate. The model does expand a lot per riser, but this is due to using .25 material thickness and .25 gap and pod 2.00 X 6.75.
If you want to change the gap and material thickness to .20, change 'Riser 4-Side Increase' value to 1.60 and the 'Thickness' value to .20.
I do not intend to build the model, as I don't need convincing and am fortunate enough not to need the money. I will assist anybody who wishes to build. The latest MTO and calculator spreadsheet files are attached at the bottom. Lowes and Home depot will cut the acrylic, if needed.
This model has a predicted lift force of 54 pounds. But, if a model with a 18.00 X 6.00 pod was built then the lift would be 350, so it increases rapidly and can easily become too much to control.
@Wayne,
Please approve the MTO, or point out any modifications that should be made, as I'm sure no one will build without your approval.
An issue with building a 4 Riser acrylic model is that it will be difficult to see the air location, since it will be surrounded by layers of water.
Regards, Larry
Very Sweet,
Thank you Larry,
One big suggestion - The .20 clearnance is for our 6 and 12 foot tall models.
The pressures adds up inside - but the wall do not have to be stroneger than needed for the head of one layer.
The Pod is a big gain to the system - so look at the ratio from my perspective?
Does downsizing it make it impossible for this relationship?
Thank you again - could I add your work to my journal?
Wayne
@LarryC. Congratulations on your build. Obviously a lot of time, thought, and calculation went into that. One thing that springs to mind, is that it would be possible to do a hybrid build. By that I mean the use of two different materials, one of which is translucent [see through] and one of which is not. So only the front walls of each compartment are translucent. This would perhaps keep material costs down. It is impressive how the "power output" increases dramatically with a relatively modest size increase, and for a model, as you say it would not need to be very large before things got out of hand. Would it be possible to formulate a rule to show the relationship between size, and lift? Is the lift proportional to the volume of the machine, or combined area of all the risers X pressure, or something else?
Personally I still think that one of the problems of building a working model is assessing the water level in each compartment. In an earlier post, I suggested loops of translucent pipes running externally, and connected between the top and bottom of each body of water . Wayne says he has used this but it is problematic. It is not totally solved by a transparent machine due to multiple layers.
Wayne has said that a 4 layer machine is not much better than a 3 layer, so is it worth the extra work?
@mrwayne. In your last post you told us of the importance of the pod-to-riser diameter ratio.
Question. Please tell us if the ratio of diameter of outer tank to its hight is an important one.
@mrwayne,
I have found that trying to lower the ZED model from it's neutral buoyant condition is very time consuming to calculate. This is because the volume of the chamber that contains the air and water channels between the Riser layers is also collapsing as the entire Pod and Riser group descends. This causes the water head in these areas to rise again and buoyancy to rise above neutral for everything except the Pod.
These observations are with an unloaded ZED however; one loaded to 1/3 of ideal only by it's own material weight and additional weights to make it that value. So the entire system should still sink once loaded to 80% for "production."
All this leads me to believe that the actual working stroke is much less than what I had imagined. Can you give us an idea how much you are stroking your test set up?
Thanks,
M.
Quote from: mrwayne on June 28, 2012, 01:15:42 PM
More difficult to build, but yes it can be done.
The acrylic at Lowes are Optix - 20x, Duraplex - 50x, and Lexan-250x (x times glass strength). Each has an increase in price, but not as much as the strength. The easiest technique is to have the 1/4 inch Optix cut at the store and glue (actually plastic welding) them together. 1/8 would not hold up well with this technique. Another technique is the 'Hinge' method where V grooves are cut and they are then folded into a complete box. It requires a router table or a table saw with a V blade. This would work with the 1/8 as the glue surface area is increased. I would only use this to make a four sided box and the top of the riser should be cut separately, as this would not work well for deep boxes. Just google 'acrylic box construction' to see videos.
In the attached spreadsheet, the gap and material thickness is set to .125. The retainer 2 wall would be equal to your 2 riser system shown. Retainer 2 is 10.50 and 8.00 is Pod, or 1.25 to each side of the Pod. I used a computer ruler to take the width relationships off your system and it would be 1.76 to each side, so actually a little better. But if you want the same, a combinations of sizes could be used, like Riser 1/4 and Retainers 1/8. It would also require a thicker material on the top of outer Riser as the total lift force is 221 in a 4 Riser system.
Edit: Just ran another spreadsheet with .25 material thickness and .125 gap and it came out to 1.86 per side. A little over, but close. It seems that just starting with a much wider Pod reduces the relationship issue.
Yes, you or anybody, can add anything I post to whatever you wish.
Regards, Larry
Quote from: neptune on June 28, 2012, 01:26:51 PM
Thanks, actually it was tedious, but all the sizes were taken off the MTO spreadsheets.
Two different materials would not be advised, as the glue actually melts the two surfaces or acrylic welding. But two different size acrylics, 1/4 an 1/8 could be used on each box.
Just use the Travis Effect Calculator spreadsheet to find total force for any combination.
Regards, Larry
Quote from: Seamus101 on June 28, 2012, 03:41:30 PM
To me it sounds like you have invented the equivalent of a longer lever. No mention of the energy involved in this description at all. Force multiplication does not equal extra energy produced unless that force is maintained over an equivalent stroke length. Can we see analysis that integrates both the forces and the distance over which they act, and show that there is a net increase.
Also it is not important that the energy to reset the stroke comes partially from the other side. This simply represents the oscillation of the stored precharge energy, again with no net increase.
Thanks Seamus,
Study the non linear function of our "Lever" and you will see what you are missing.
Wayne
Quote from: mondrasek on June 28, 2012, 03:34:32 PM
@mrwayne,
Thanks,
M.
@M.
I have not explored the unloaded Zed - in our Demo model - with no additional load it takes 1.9 psi to lift 900 pounds worth of riser.
Or 4.4 feet of accumulated head.
This is the sinking Pressure - you can not get below this pressure unless you are setting on bottom.
The Risers and Pod will not begin to lower until after the 1.9 drops to 1.8and immediately - when the pod and riser drops the pressure returns to 1.9 - until bottom is hit.
With no load - you can float the system 2.0 and sink the system 1.8.
With our added weight 1600 pounds ( 900 =2500) - we have 5.0 pounds of pressure 4.9 sinks and 5.1 floats
When we add our Hydraulic load 3500 pounds ( 900 2500 =6000) - we have 8.8 pounds of pressure
So if you start at 4.9 (sunk) and you increase to 8.8 you are in production mode - How much production is based on stroke length.
The maximum pressure in our system is 10.4 - so you have the ability to stroke to the same place -if you were to stroke to 10.4.
As you stroke (loaded with 6000) - your head does change but a fraction you merely raise the water level below the Pod.
The load maintains the head - so the pod chamber diameter becomes you volume of stroke Per inch.
In our case 737 inched
On that note 737 x 3.8 =2800 That is what a hydraulic cylinder can lift
we add 3.8 to lift 3500....................... Seamus pay attention.
The 2500 gives us a pressure of 5.0
8.8 = total of 6000
1.9 lifts 900
To all - Build a linear chart comparing the hydraulic cylinder and our Zed - if you have not had your OM-Gosh moment - it is time.
I would like to hear from more of you who have, and Thank you.
Wayne
@M if I did not answer your question - I was not sure I understood the question?
Quote from: neptune on June 28, 2012, 02:14:56 PM
Well, Pod to riser "GAP" was the point specifially: that the pod is nearly a bonus to the lift - it is good to have it as large as you can, considering the smallest gap you can. Don't throw away its value with big gaps - is the point. and since the largest gain in the system comes from the riser above the Pod -make it priority in your models.
Next question: Ratio to Hieght to Diamter - depends on what you value
We have models that are 860% effeceint - and the prodcue less net than our 340% system.
So do you want to blow the minds of people - or supply more power.
SO - yes they matter, taller reduces the non lenier function -
The non lenier is awesome to reduce our input cost.
Wider incereases power very quickly.
Layers increase the non lenier - so our model selects the sweet spots for both.
Wayne
Quote from: mrwayne on June 29, 2012, 07:31:52 AM
You gave enough information for me to understand where I think I need to focus next on the cylindrical model analysis. So the actual question is not important for that, but still I would like to know: What is the production stroke that you use in your 6 foot tall ZED systems when they are in full automatic operation. If you can share that info...
M.
I have been giving some thought to mrwayne`s suggestion about making a linear chart. I will freely admit that mathematics is not my strong point. So I think by a linear chart he probably means a graph. Obviously we have to be careful to compare apples with apples and not oranges. It is usual to start with some assumptions. So we assume that for the purpose of this graph, we will use one zed. We know the size of this ZED, and we know how much water we need to inject into it to "stroke" it, and at what pressure. We know how much weight it is going to lift and what distance it will be lifted.
The equivalent hydraulic system we will use for comparison. It just consists of two interconnected cylinders, or if you like giant syringes. The input cylinder or pump will be designed to pump the same amount of water as is used to stroke the ZED. The diameter of the output cylinder will be chosen so that it has the same stroke length as the ZED . So both systems will have the same input volume and pressure.
So we have a two axis graph. Question is, what do the two axes show? Is one for the amount of weight lifted, and the other for input pressure? Would that show what we want to show?
So now we have two curves on the graph, one for the hydraulic system and one for the ZED. We may want to show a third curve for a two ZED system.
These are just the initial thoughts of a layman. Could be complete Bullshine. Come on guys , someone can do better than this?
Quote from: mondrasek on June 29, 2012, 11:52:36 AM
M.
Our available stroke length is 7.75 inches at 6000 pounds - we only stroke 3 inches (limited by Bag selection).
Even if we had a longer bag, or wider cylinder - we would not stroke 7.75 - for reliability - to close to ideal means risking blowing skirts (air or water to next layer).
Wayne
Quote from: neptune on June 29, 2012, 12:34:42 PM
I have been giving some thought to mrwayne`s suggestion about making a linear chart... So we have a two axis graph. Question is, what do the two axes show? Is one for the amount of weight lifted, and the other for input pressure? Would that show what we want to show?
I am actually working on this idea right now. I think the essence would be shown by stroke position vs force of the input compared to the stroke position vs force of the output. So one axis would be the stroke position for in and out. The other axis would be the force generated -- in two lines, one for in and one for out. Some scaling may be required to overlay the lines. A straight hydraulic piston can be also plotted in the same way. Integrating the force over the distance of input and output might also make an interesting curve.
Creating the formulas is step one. They can be plugged into the WolframAlpha dot com site to draw the graphs.
Hello All,
This graph shows our actual internal input cost (psi) on our demo model and the resultant lift in pounds.
This is after the weight and risers are lifted - so add 5.0 psi to see actual psi.
The weight of the risers weights = 2500 - and they create on the down stroke 5.0 psi.
Notice what the added input is to lift another 2500, and then what 5.0 more lifts....
This is what we mean by non linear.
p.s Ignore the first ten or so points - the cylinders had cross over pressure in them - start where the lift begins.
Wayne
The attached spreadsheet is intended to help in the understanding of Wayne's reply 746. In blue the nonlinear aspect and sweet spot is easy to see and it is mathematical proof of OU. Hope you get your OMG. The spreadsheet file is also included, just change the yellow fields for your model.
Edit: Some of the relationships are based on Wayne's 3 layer demo unit that he described in 746, it would need to be adjusted for higher layer models as they would be more efficient.
Regards, Larry
Quote from: Seamus101 on June 29, 2012, 09:25:27 PM
Can I ask where the energy comes from to 'merely' raise the water level of the pod? If it comes from the other Zed then there is no overunity present as you have simply depleted the potential of the other side. All that potential needs to be restored and the net effect is zero. If it comes from an external water supply then you have invented a generator powered by the head of the water supply. No OU there either.
This situation reminds me of a question once posed by my high school physics teacher who asked us to show why a float rising through a free surface was not a source of free energy. A naive analysis based around forces showed it to be so as it neglected to consider the change in height of the water surface as the float was sunk into it.
Sorry about your teacher.
He should have shown the energy potential in the height of the water raised, the value of the compressed air in the float, and the value of the down ward force caused by the buoyancy - and in a tiny degree - the humidity, temperature change, and the friction in the water.
The Force calculations should have raised the question "where is "all" the missing energy? Even using Energy instead of force - you can only find 67% of the energy in buoyancy - that means something was unknown, not observed, or not utilized.
That's what I was looking for when I discovered the Travis Effect - a volumetric based equation does not give the answer.
To your Question:
Two parts - we do not consume the energy from the other Zed - as I have shown before - the head is not consumed in the process - we transfer it laterally from side to side - your teacher did not ask you what the cost of moving a floating object side ways -
Until the Zed - no one had a use for that idea - the Zed does. (we move the raised water - as your example - in the form of head - side ways back and forth - and then when we do - the value of our float goes from float to sink - allowing us to operate the float in a cycle. This accounts for 5 psi worth of work, in our system - that we do not add or subtract during operation.
Second: the 3.8 pounds of input comes from part of the production - Which is produced at the high side of our ESA.
I hope this helps, Wayne
We began running pretrial tests - prior to Mark Dansie's return - I had very much hoped to be done by Wednesday.
Mark is on Standby - he is very graciously patient. As you already know - we update his group most every day.
Update on Mark's return:
We ran into a few minor technical problems - which have been resolved - so our Pretrial runs begin again Today.
Here is a copy of the last few update letters to Mark's Group:
June 26
Hello Men, Very good day.
Matthew reversed the operation of his water level adjustment calculator - and gave us the low position based on our end of stroke data (high position)
Another option is lowering the output - by lowering the operating range - with less weight. - but that drops our output too.
The third option is to adjust the system to use all 2.0si - that puts us dangerously close to blowing skirts.
Wayne Travis
President
June 27
Hello Men, Better day than our very good day yesterday.
Matthew built me a lever arm calculator (excel) so I could make the adjustment once - lol
Then took a cat nap and I slept on my Lever arm decision - and came up with a fourth alternative -
Step one - Drop one section from the three section production cylinder (leave it open it to the reservoir).
Step two - charge the accumulator from 550 psi (nitrogen) to 950 psi.(Chickasha Industrial will be here 9:00am)
Step three - remove the lever arm two from the staging program.
Step four - Adjust the gate valve to accommodate the speed increase.
Step five - set starting position and hit it!
In summary:
Using only one lever arm - at the higher pressure will give us the right force to create the same/better pressure at the production cylinder
This will result in a higher net production, and happens to be the pressure our Hydraulic {Motor not pump} pump is designed for - which means we will provide more torque, volume and rpm to the generator - and the Zed's run faster.......
p.s. We had one poppet valve for the cross over function fail - that is the section we will bypass.
Everything just fell perfectly into place ;-)
Wayne Travis
President
June 28
Hello Men, Made the changes mentioned yesterday - the poppet valves did not hold under the higher pressure - so I had them disabled. We do not have to have them to run. We began running at 3:30 pm.
The Data showed that one of our cylinder (sections) was not building pressure - probably an air bubble form pulling the Poppets.
I had meetings all day until about 9:00pm - We will vent the system and pull data in the morning.
Even with the one exception - the system is running well - and the set up (which we keep practicing and improving) - is going very well.
We are close, maybe a day away.
Wayne Travis
President
June 29
Hello Men,
I have to say I am disappointed (that we did not finish this week) - I really wanted to be done by the 28.
The Poppet valves that could not handle the pressure - yesterday we blocked the ports so we could run without them - the block - did not hold - so we went ahead and removed them completely and plumbed the sections.
We can later re-install a new better valve.
We have bled the lines, and after my 7:00 meeting in the morning - I run again.
Some good news - the set up worked perfectly again, and the new procedure allows us to set up on the low end - instead of the high end - which will help with the "measuring setup cost to".
I will be working through the weekend - and I hope you have a great weekend and a Fourth of July.
We will be doing a designed experiment on sloping the water levels - we have noticed that we can get better lift - from the same (total) pressure - by the way we set up the layers.
Wayne Travis
President
mr.wayne@hydroenergyrevolution.com (http://www.overunity.com/mhtml:%7BBA0E7C10-7514-4EB9-8921-F3B89DA6F745%7Dmid://00001539/!x-usc:mailto:mr.wayne@hydroenergyrevolution.com)
Our poppet valves have nothing to do with the Zed functions - it is a system I designed to turn a inefficient hydraulic system into Near zero loss system (hydraulics only)
They were very hard to locate (exactly what I needed) when I bought them -
Apparently I accepted a pressure rating less than the rest of the system - (3000 psi).
So We pulled those out Yesterday - until we, or somebody out here can help us find better ones.
We could not run with them leaking bye.
Now, We resume testing - when we finish mark will be here.
From Mark Dansie
June 26
"great news
Mark (from Mark)
Wish I was there this is exciting times
I will be soon as your ready only need a days notice."
[font=]
[/font]
Whilst we are waiting for Wayne`s tests and Mark`s tests, Here are some random thoughts about transmission. The transmission is a vital part of any machine but especially this one. In a recent post Wayne has said that his hydraulic system is a low loss system .I know little about hydraulics, but I would expect that the overall efficiency of that hydraulic system is probably about 80% .
The problem we face is that we like our energy in the form of electricity because it is so versatile. But efficient generators need to spin fast, and the ZED machine is slow moving. Any transmission that involves a wide gear ratio is going to have losses. Interestingly, Wayne talks about the use of a crankshaft in proposed larger machines. I am just wondering if a similar approach in a smaller machine would be more cost effective than hydraulics. No doubt Wayne has considered this.
In manufacturing any machine it is vital to keep costs low. Here is my rough guess as to how such costs would pan out .
ZEDs- 25% of total costs
Generator and electronics-25%
Hydraulics- 45%
Miscellaneous-5%
So that is just a guess, but it is obvious that the first place to look at saving money could be the transmission.
@neptune, well said.
I have to go cut up some trees that fell in my Mother-in-law's yard during some unexpected storms yesterday evening and night. So I can't look this up, but what is the transmission efficiency of a Muller type generator? (kind of ironic, eh?)
Just curious myself and hope someone else has the time to do the research.
M.
Stopped at Lowe's today and talked to the Acrylic cutter. The machine appeared to be very capable of good accuracy, but it depends on the cutter. I asked how accurate and was told it could be up to 1/8 off. Asked if I could use MM, was told only inches, then showed him on the machine that it had MM on the rulers, he said I guess we could. The other issue is that it is a scoring machine where they will score then snap off the piece, so the cut edges would need to be block sanded with 2000 grit wet sandpaper.
Called ACE and they didn't exactly understand my question, just said they could cut to any 1/16.
Checked online and this place http://www.eplastics.com/Plastic/Lexan_Clear_Polycarbonate_Sheet (http://www.eplastics.com/Plastic/Lexan_Clear_Polycarbonate_Sheet) will cut your MTO for a reasonable charge and with accuracy to .030".
Edit: Noticed they had 3/16 size online, this may be the best fit for the model, using 3/16 material and 3/16 gap. Compared to Wayne's drawing with 1.76 on each side, this would be 1.86 on each side. It is wide enough to glue and more stiffness than 1/8.
So the best would probably be Online.
But check with me first before using the MTO to order, as I may have some adjustments in mind.
Regards, Larry
Just a quick note - our re-usage of a portion of the production is relatively efficient
But transferring the excess to production is a very standard poor.
Thank Goodness, we have abundant excess.
We do not have the same problem facing LENR, we produce electricity in excess - even with the transmission cost.
Wayne
@Mondrasek. I am not sure that I fully understand your question. When you speak of a "Muller type" generator, are you talking of a permanent magnet alternator, or one using the alleged Lenz law cancelling principle, which is proving so elusive. Wayne is using a wind generator type alternator. These are permanent magnet alternators designed to work at a few hundred RPM, as opposed to say , a car alternator which typically need to spin at several thousand RPM. Wind generator alternators are relatively expensive, but can have efficiencies better than 90%, whereas a car alternator can have an efficiency as low as 27%! So untill and unless someone cracks the Lenz law thing, wind alternators are our best bet .
Looking at the video, the ZEDs seem to complete one cycle in roughly 10 seconds, so when connected to a crankshaft, that would give us a crankshaft speed of 6 RPM. So we would need a gear ratio of roughly 100 to 1. As a guess we could expect such a gear box to have at best an efficiency of 50%. Fortunately, as Wayne says, we have an abundance of energy to play with. It is possible that a better way will be found, but right now, Wayne has a cost effective working solution.
When it comes to electric generators, it is not RPM, but surface speed that counts. For instance, if a 6 RPM crankshaft was connected to a very large diameter flywheel with high performance magnets on the outer surface, It could be an efficient generator. The inertia of the flywheel would help when the load on the generator varies. However, the inertia of the flywheel would also force the ZEDs to run at a single natural frequency.
@see3d. Actually that is an interesting point. There might even be a cost effective compromise here. For instance, we could gear up from the crankshaft by a modest 3 to 1, which would then need a flywheel only one third the size, for instance. Somewhere in there is the best compromise of gearbox ratio, gearbox efficiency,flywheel diameter, surface speed and cost. To a professional mathematician, a problem like that is a dream come true.
@neptune, by "Muller type generator" I meant one that has and odd number of rotating magnets vs. an even number of coils (or vise versa) so that the "cogging" of the generator is minimized. I personally am not sure how efficient those types of generators are. But I believe they are used in modern wind turbines, so I assume they are the least loss conversion method we know of.
The last time we collaborated was on a "Muller" type system, IIRC. So I thought that fact was humorous.
Maybe it's just me? Either way, cheers!
M.
Hello Seamus,
I do not deal in "predictions" - nor opinion, nor guesses, nor dogma, nor feelings.
All of our testing has been physical testing, repeatability, consistency - hands on experimenting - real research.
Study the useage of a Non linear functioning system -
When you understand it - you will see that "the Load" improves our efficiency.
Wayne
Quote from: microcontroller on June 30, 2012, 11:27:02 PM
And that's another twenty pages of OU in words.
Seamus i'm still with you.
Wayne, Let's hope the world sees your discovery soon. (again)
Hello Again Micro controller -
"Twenty pages" to show - Our physics are good and verifiable, our design is good and verifiable, our process is good and verifiable - our concept is original and verifiable.
I have explained at a pace that most were willing to follow, slower than some, and too much for others - but enough.
All have been given more than enough to know that our system is completely O/U.
It works in the simple, it works in the complex, it works in the physical, it worked last year, it works today.
I have given of my time, willingly.
Times have changed:
For 2000 years, the O/U cynic has the best chances of being right - it is not much different than betting that people who purchase a lottery ticket are going to lose - history is in your favor.
This used to be an easy win for the cynic, times have changed.
I can not be responsible for you, the question now is of your own integrity;
How do you handle yourself when you make the bet against the winner.
Did you do your home work, on this bet?
If you did, show the integrity.
Wayne
For those considering or building a model and want to see the water/air levels in each layer, how about a small, colored, floating bead of some sort in each annulus?
M.
@Mondrasek. The bead idea is very clever. Such beads would have to be very small of course. Perhaps we could find beads of a retro-reflective material, so they would show up better.
@Microcontroller. In any machine of this size, there are bound to be teething troubles, and that includes leaking valves. This is not like buying a machine from a department store with a one year guarantee. Anyone who has built things from scratch, will have experience of this.
We have waited since the dawn of civilisation for something like this. What is another week, or another month. In the meantime, let us behave like mature adults, and treat each other with respect.
Not good form Micro.
@All
Here is a simple drawing showing our system -
P.s. don't get hung up on a 3 psi generator - this is just for example - we increase the presure - a pressure increaser - instead of gears.
It is really this simple.
Wayne
@ All,
The calcualtors such as Larry, and other have presented will confirm our "Word" claims.
Micro,
We have shown the world - and the skeptics - and do you know what they wanted next - the "words"
and the Data, and the understanding - you seem to value these the least.
At some point, you will realize you have been given a treasure - hard earned, and labored over for four years - right now - you see nothing, in time - I have faith in you.
Concerning our leaking valve:
In any Alpha testing stage - you run into these problems - I have deveolped working proto types before, it is part of the natural process.
We fired up again last night - and ran.
Do not confuse my "open and honest" policy with "excuses"
Thanks for your concern.
Wayne
Wow, Serendipity rears it beautiful head. ;D
The question is 'Why is the Travis effect machine nonlinear?' This tasked me, as I haven't seen an explanation, just the observed production results from Wayne.
I was playing around with a 3 Riser spreadsheet and thought it would be simple to leave all the input spec's the same and just change the force of gravity to see the total force at different PSI's. But as you can see in row 26 the differences indicate a linear rise. But after looking at the cycle drawing, it easy to see that it is due to the air being compressed, is the reason that it is nonlinear. My calculations were using fully aligned water column to get the results. That is not physically the case, because as the pressure increases, the air volume decreases to bring the water columns in alignment.
Excitedly, Larry
@Larry,
Row 27?
Quote from: LarryC on July 01, 2012, 06:01:39 PM
Excitedly, Larry
Great Job Larry,
You are exactly right - the compression ratio - reduces with pressure translating into greater head exchange as pressure increases.
Fantastic!
Wayne
Bye Bye Seamus,
We never claimed a technology that did not already exist - just a very clever design and way to use that which is already understood.
And Yes - we are very over unity.
Good night, and peace.
Wayne
Quote from: Seamus101 on July 01, 2012, 11:20:41 PM
At this point I'm going to have to call it as it is. Garbage... This device is not and never will be overunity.
Take care then,
Wayne
What arrogance's. Please explain why you would think that anyone would put stock in an opinion by someone in college like you. When there are many of us here with degrees, but tempered with wisdom, common sense and experience. Just look at Wayne's team here http://www.mrwaynesbrain.com/index.php/special-thanks (http://www.mrwaynesbrain.com/index.php/special-thanks). Do you really think you are smarter than all these people?
Larry
Quote from: microcontroller on July 02, 2012, 01:04:19 AM
Just what i was thinking more words.
Seamus buddy i'm still with you !
Garbage... !
You do make it clear that you did not understand.
Goodnight.
Wayne
I am an old guy who served his time at the University Of Hard Knocks. One of the things that life has taught me is this. If you are right, and you are absolutely used to being right, do not crow too loudly. Because nobody in the history of the world has ever been right 100% of the time. So it is absolutely inevitable that one day you will be wrong. When that day dawns, and it will, the louder you crowed, the smaller you are going to feel.
Arrogance has no place in a scientific discussion. It is merely a sign of selfish immaturity. A gentleman knows how to disagree without destroying his opponents dignity. If you want examples of really knowledgeable gentlemen who know how to conduct themselves in a debate, then look no further than Wayne Travis and LarryC.
@ All
Let Seamus and Micro have peace - please do not respond to their attacks on me.
Denial is only one stage in the process of adjusting ones own hard felt belief.
I do not knock others belief - I myself have unbreakable belief - belief that their is something greater than myself, and that the sum off all knowledge does not reside in my mind.
That gives me the patience and undersanding that I could be wrong, and that others can understand something that I can not.
What these two show - is only the beginning of the change that will follow, and why we have to be open and honest.
One Day - they will understand, they will be enlightened - Going through life bitter is a hard life, it is giving your mind over to others.
Adding Negativity "now" will only take that process longer.
Hopefully, the Moderator will recognize the personal attack - in the drawings and name calling and put an end correct the behaviour. I have been patient - but due time to act.
Thank you very much for the time to share - and the effort so many of you took to be enlightened just as I was, very good work.
Wayne
@All
Back to work:
Most of you have seen the patent - studied the natural physics of the design, and now see how we use the nonlinear attributes to our benefit.
Let me now affirm - what some of you have supposed - all of the information we have released - is just the beginning.
We have progressed far beyond what has been shown, which is sufficient to understand the validity, this discovery has led to many more.
As I shared with Mark Dansie - he stated (from memory)
"We have spent two years trying to take a 1 watt O/U (massive magnetic motor) and two million dollars later we have 1 watt - and the simple fact that you can continually find substantial improvements to your O/U device.........with no funding - lends credence to the viability of your discovery"
I can not share those improvements at this time, due diligence requires the attorneys have their go first.
But - those that join our effort, come and visit - they become part of the team and part of the history.
As Senator Justice stated "We have become the deciders of winners and losers, the hard part is ..when we pick a loser to win...(unsustainable alternatives) we (the government) can not hardly stop funding him - with the way things are set up - and the real winners are left out"
Do not expect Goverment to help.
This go round - we (HydroEnergy Revolution llc) are letting the people choose who is going to win or loose - not the trolls, nor governments, nor the funding.
The passion for Energy Independence, the years of hope for the discover - the beauty of the simplicity and complexity - as Nature is on its own.
Do not sit idol, do not sit bye, do not rely on the past to dictate the future - All Great discoveries had a first time of success, so those of you who seek, or sought, lived or followed - the dream of our world with ample energy to spare ----
It is time for the dream to become a reality, do not sit by and let the world try to gobble it up and spit it out - like Micro and Seamus try.
Let's get it done - Tell me where you can help, be a part of this truth, let no man step on your part of this destiny and the future of your families.
It is amazingly fitting that this is our Independance day in America - it can become the World's, join us now.
Wayne Travis
Quote from: Seamus101 on July 03, 2012, 01:34:55 AM
Sorry, but my enlightenment occurred a long time ago and it involved recognising the nature of conservative fields such as gravity cannot give rise to overunity energy. Recognising this doesn't give rise to any bitterness and it is not a personal attack on anyone.
My only qualification to that statement is that there is a small possibility that at nano scales the existence of the Casimir effect points to something that may allow gravity modification with a suitable technology. This technology does not include buoyancy.
You continue to mention gravity "modification". The thing does not modify gravity. I read the original post you appear to have latched onto as to that incorrect notion, and it's clear from the context that he meant something else...just modifying the amount of force needed to get the load lifted.
The gist of it all seems to be, in the main, that a ZED can lift the (Example) 2500+ pound load using leverage via concentric cascaded buoyant-pneumatic means...such that you can do it for less than the usual pressures (and thus work) that one might think are needed here.
Once that the load is lifted, you have the usual gravitational potential energy ready to work during the sink cycle..and yet because it uses an efficient lever so it seems, that work is not all used up to re-lift the other side, between that and the transferrals. Repeat...
I don't know how that leveraging works just that it is said to, but please stop mentioning "modification" of gravity. Such is not being claimed.
rc
Quote from: hartiberlin on May 23, 2012, 06:21:06 AM
I posted with permission from Wayne the 2 principle videos to my youtube account at:
http://www.youtube.com/watch?v=ZkxrLzcp0Z8 (http://www.youtube.com/watch?v=ZkxrLzcp0Z8)
http://www.youtube.com/watch?v=0JUj42h6j7Y (http://www.youtube.com/watch?v=0JUj42h6j7Y)
Also the hard skeptic Mark Dansie says that this device works.
The main effect is that only the height of the air in the plastic cup counts !
Not the volume ! So you only need to pump a very low amount of air under the plastic cups
which needs very low amount of energy. Then you can gain the massive lift energy by buoyancy which is much more than the used pump energy to get the air inside the platic cup.!
So you have a big energy gain there !
Hope this helps...
Also have a look at their website for more informations.
Regards, Stefan.
I made a comment on the two videos, but wants to repeat it here:
The concrete block is independent of the cup, and therfor assist in pushing the cup upwards with the same amount of force as the other cup. So the experiment is some how misleading us to believe that two different amount of air can lift the same weight. The right hand cup does not "see" the concrete block, but the block is displacing the water instead of the air doing it, and therfor act as it is filled with as much air as the left hand cup. Other than showing the experiment, it is practically useless.
That means if the concrete block is suppose to be a part of a machine, it would not be possible to work as a over balanced wheel.
Vidar
Quote from: Low-Q on July 03, 2012, 07:13:09 AM
Vidar
Hello Vidar,
I read your statement several times - because you both made our point and then concluded the opposite?
"The concrete block is independent of the cup, and therfor assist in pushing the cup upwards with the same amount of force as the other cup."
And then concluded with:
"Other than showing the experiment, it is practically useless."
You imply - Just As Tommy did - that the video shows that the volume is reduced by the non attached block to get the same for out of a system with much more air ----becasue the block takes up the space of the air - which makes it equal to the other cup---which results in less air need to lift the same amount-----
and then
"That means if the concrete block is suppose to be a part of a machine, it would not be possible to work as a over balanced wheel."
Vidar, to be clear;
We don't lift the concrete block - we do not have an overbalanced wheel?
Or anthing remotely related.
I hope this helps,
Wayne
The attached shows how the buoyancy of the different Pod and Riser sections changes at different rates as the system is allowed to raise and/or fall. This is the 6 in OD model system that has an ideal lift of about 15 lbs. It was weighted to 1/3 of that and balanced by adjusting the water level in the outer most ring. This is shown in the "FULL" condition where it would need to be restrained from stroking up further.
Additional weight was then added to increase the loading to 80% (12lbs). Water was then removed iteratively from the center Pod section until neutral buoyancy was achieved. This happend when 1.8156 in^3 of water was removed and is the second view shown. From there water was removed in additional increments of 1 in^3. This would cause the Pod and Risers to drop. The exact amount of the drop to return to neutral(ish) buoyancy was again found by iterations. In the middle view 2.8156 in^3 of water is removed and buoyancy achieved after the Pod and Risers have lowered .07373 in.
I drew some witness lines across the various water levels to help illustrate that the buoyancy ratio of the different members is changing. The Pod is loosing the most buoyancy. The Inner Riser is loosing a lesser amount. The Outer Riser is actually gaining buoyancy. All together, the buoyancy adds up to be the 12lbs of loading of course.
The reason for the changing buoyancy ratios appears to be the volume decrease of the air/water channels between the Pod, chamber walls, and Risers as the system collapses.
FWIW.
M.
The following vertical column example clearly shows why a layered Travis system has greater lift than a Hydraulic cylinder. It simply boils down to surface area. The Travis has diameters of 36.2, 35.1, 33.9, 32.5 and 31 all at psi of 2.2. The hydraulic cylinder of 31.75 at 11 psi. Each system has the same water volume input, but Travis win's on surface area.
This is only part of the OU, but if you understand this part your on your way.
Edit: You may need to download and blow up to see it better.
Regards, Larry
@webby1,
The following 5 riser calculator may help. The spreadsheet data set is below the picture.
Regards, Larry
Edit: Can you imagine having to put 5 100 pound weights on top to hold down this little model.
Thank you Seamus,
For your input.
Please consider the information that has been replicated and offered, your comments are unrelated to the Z.E.D system.
We have several fantastic discoveries - all of which can be measured with simple physics.
Wayne
Thanks to webby1 bringing up the 5 Riser, found this gem. Note the Light Blue at the bottom, which is the Travis Lift efficency over Hydraulic Lift.
Does anyone else hear a large cracking sound in the background? ;D
Sounds like something being broken.
Regards, Larry
Quote from: webby1 on July 03, 2012, 05:24:51 PM
Hate it when I do that :)
I appreciate the help in understanding but I am only trying to understand the "concept" and the "where" the forces are.
I know that in a real setup the numbers are not as simple as I am using, but simple numbers are easy to grasp and that is what I am trying to do, grasp the where and the what.
In the simple setup I gave, if the input tube to the pod chamber were also 10 ft tall then the 2 pressure values would be the same, 4.3 psi, so what I am asking is: Is it basically that the only force that is needed as an "extra" input is the force to take the input to the pod *from* the 4.3 psi up to the 6.45 psi, which is only 2.15 psi, meaning that I would only have to have a "pump" to "pump" the fluid down from the pod input tube that can make 2.15 psi. All this giving me back the lifting force equal to 6.45 psi.
Hi,
I posted the Riser 5 calculator with the 1 Foot Pod and Riser value to show that the Max PSI is 2.60. So your PSI figures are misleading as they don't correlate to 1 Foot. But, you are bascially right in your understanding of the additional pump force given the correct height Pod and Riser.
Edit: Webby1 or anybody please review my 808 post. Let me know if you understand or point out improvements to help the understanding.
Regards, Larry
@ All,
Here is the last update:
In recap: We are balancing the two sytems - one of thelast things needed.July 4, 2012 Hello Men, I hope you and your families celebrate Independence day!
Mark, Enjoy Denver - I pray you are not there long lol.
Thank you Rick for helping with the Poppet valve issue, The time you saved is very much appreciated, let Auggie - I put the data collection on hold until we work through these last issues.
Bullet recap - fixed leaks - repaired poppet's - isolated components - removing weights today - improved set up procedure - two repairs this morning then expected to be run ready - by this evening - will keep you informed.
Details:
Our Monday run - with the Poppet valves removed - we were able to extract an existing issue that (we were unaware of) - the low pressure valves were not tightened to the the same torque as the high pressure - and when we isolated two of the production cylinders - we were able to suck air into the system from those low pressure fittings (the fittings were not low pressure - just the way they were treated at install).
So - we also spent four hours tightening Stainless compression fittings. With the Hydraulics clean of air - we ran Tuesday morning and with all the noise out of the way - we were able to determine that Zed two had 80 pounds more weight than Zed one - that made a .4 (tenths) of a pound gain difference - which is significant since the two Z.E.D.'s are connected - and the value works both ways (an increased load one direction - and unequal free flow in the other. We determined which way to go (Add more on one or remove weight from the other) The Equalization of the system is the lateral transfer of the Head from side to side - over 50% is moved freely - when the system is not balanced at least roughly close - you have one direction working better than the other - this results in extra input having to be input on the heavy side and extra - uncaptured energy on the other side (we don't capture a different value per Z.E.D. at least on this model - and the staging program having to compensate - and the cycle time increased. We will be removing the weight from Zed 2 this morning. Yesterday -We replaced the Poppet valves and installed isolation valves (in case of trouble) and for future trouble shooting. We will bleed the system this morning while the lids and weight are removed. We have two last repairs to make to improve the set up and the extended run times - a simple air trap installation prior to the pump, and to unkink the air line to riser three (adds about 20 minutes to the set up) - while the lid is off today. I am looking for "equal" or balanced data out of our run tonight. The set up to run procedure continues to improve, requiring less time and more accurate - while Terry replumbed the Poppet valves - the rest of us worked on the setup with the assist operation engaged - we are very close - this will make the set up a 1,2,3, simple process.
Wayne Travis
President
HydroEnergy Revolution LLC
p.s.
We resolve our issues and refine and the process recording understanding to support others.
@Wayne. Sounds like you are still finding small problems, but it also sounds like your team is on the case and you are progressing by leaps and bounds. We share your frustration, but all we can do is wait, in the knowledge that victory is inevitable.
Larry asked if anyone heard a loud crack, like something breaking. I did not hear a crack. To me it was more of a thunderous roar! Even so it was but a tiny taste of the storm to come.
I too had thought, in my thought experiments, about using a column of water as an input pump. The only practical problem here, is that as soon as we start to draw water from the column, the pressure falls, making calculation difficult . If we wanted to use this idea for practical experiments, the problem could be reduced by using a wide column, or a wide tank on top of the vertical pipe.
Another obvious thing about model making. As soon as we try to make a model much larger than say 6" diameter, the weight of the weights quickly becomes too large to handle easily. So build it small unless you own a fork lift truck.
@LarryC. Re your post 808. In a sense, this is just a thought experiment, as in real life, all the water would sink to the bottom, and all the air move to the top. Unless the tube was quite narrow, or the air and water pockets were separated by frictionless pistons . So this is really an "equivalent circuit" of a ZED. You say that the ZED beats the hydraulic ram because it has greater surface area. If you tried to "improve" a hydraulic ram by increasing the piston surface area, what would happen? Well the lifting force would be greater but the stroke length , for a given input volume and pressure would be less. However, its output, as in force X distance would remain the same. So to be really honest, and I always try to be honest, I can not see how more surface area alone would cause the ZED to be more efficient then a hydraulic ram.
There is something subtle going on here. Someone [might be Webby1] described the ZED as " fed in series, discharged in parallel." Might this have a bearing on what is going on . Another hint dropped by Wayne might be relevant. He said[paraphrased] That the secret of the ZED lies not in its greater output, but in its lower input.
Quote from: Seamus101 on July 03, 2012, 03:25:26 PM
No, I won't stop mentioning gravity modification. Because buoyancy is a function of gravity and gravity is a conservative field this machine could not function as claimed unless it caused some modification of the nature of gravity. Obviously that is not the case, so we can only deduce that the machine does not work as claimed. To put it in simple terms water does not flow up hill.
@Seamus101, first let me apologize if the contents of this post are not 100% correct with regards to my description of logic. It's been a long time since I had to argue in philosophical terms and I am sure I am making mistakes.
Also, let me salute you for your tenacity.
I believe your argument goes as such: Buoyancy is a function of Gravity (true). AND Gravity is a Conservative Field of Force (true). AND a Conservative Field of Force cannot produce Work (ASSUMPTION). Therefore, the only explanation for the Zed to function would be that Gravity is being Modified.
There is absolutely no proof, Physics Law, or otherwise, that concludes that a Conservative Field of Force cannot produce Work. That ASSUMPTION is only what has been shown by historical evidence (so far) and therefore mostly taught to students. It is NOT, however, a known fact, and therefore cannot be used to prove any subsequent claims if used as part of a logical progression.
Thanks,
M.
Quote from: neptune on July 04, 2012, 01:12:06 PM
@LarryC. Re your post 808. You say that the ZED beats the hydraulic ram because it has greater surface area. If you tried to "improve" a hydraulic ram by increasing the piston surface area, what would happen? Well the lifting force would be greater but the stroke length , for a given input volume and pressure would be less. However, its output, as in force X distance would remain the same. So to be really honest, and I always try to be honest, I can not see how more surface area alone would cause the ZED to be more efficient then a hydraulic ram.
Hi Neptune,
Thanks, but the premise was to have the same input volume and PSI for both systems and show the lift force difference. So if the hydraulic ram had an increased surface area, than for a ZED to have the same input volume it's pod's retainer wall would have to be increased to the same surface area. Again, it would have greater lift.
Regards, Larry
Hi Larry. So if I am understanding you, in both cases we have the same input volume and pressure . But in the Zed we get more lift because that same input is acting on a larger area.
In your post no 813, the spreadsheet shows that a ZED is 146.43% as efficient as a hydraulic ram. Am I right in thinking that that is a single ZED and so does not have as high an efficiency as a twin ZED set-up , where we use the "exhaust" of one ZED to partly feed the input of the other ZED?
Hello Neptune,
That is correct - each layer divides the pressure 'as does Boyles law' -
Each Layer of the Z.E.D. acts to increase the surface area - because each diameter is larger.
In the Zed system the only volume is the "Pod chamber"
So when you use simple physics to calculate the lift - the extra surface area of the risers shows up.
(keep in mind that this is only one of the unique attributes - it is least of our gains).
Wayne
p.s. running good today ;-)
Quote from: mrwayne on July 04, 2012, 04:09:56 PM
Thanks for the mid-holiday update.
Godspeed.
M.
Hi All,
I found this amusing and encouraging to all builders, experimenters and tinkerers out there.
Hawking says he lost $100 bet over over Higgs discovery.
"But it is a pity in a way because the great advances in physics have come from experiments that gave results we didn't expect."
"For this reason I had a bet with Gordon Kane of Michigan University that the Higgs particle wouldn't be found. It seems I have just lost $100."
source:http://news.yahoo.com/hawking-says-lost-100-bet-over-higgs-discovery-151710271.htmlKeep building and experimenting.
Quote from: Seamus101 on July 04, 2012, 05:32:41 PM
The evidence given so far showing increased forces in a spreadsheet are laughably inaccurate. They conveniently ignore internal transfers of energy (forces AND displacements) and quote some of the force increase on one side as 'overunity'. This completely ignores that ALL of this 'force' (and displacement) needs to be transferred back to the other side for the system to continue to function. If we were to tap ANY part of that 'increase' the system would immediately stop. (as it will anyway due to friction losses in the fluid flow.)
Wayne asked that we do not respond to attacks for him, and yes, I can respect that, but this time it is a attack on me. The difference is that I don't believe you are here to learn, as shown in your first post to your last (just click on his name and press on show post to understand his agenda), but I know that you are here to deceive as I have witness several of your kind. So lets check out your current deceptions.
'The evidence given so far showing increased forces in a spreadsheet are laughably inaccurate'.
I included the spreadsheet dataset just to make sure that all can review that the math is clear, so Seamus101, please show where the math is inaccurate, laughing deceiver.
'They conveniently ignore internal transfers of energy (forces AND displacements) and quote some of the force increase on one side as 'overunity'.'
Seamus101, I have not stated they were created to show the internal transfers of energy. They only show the initial lift forces for a single zed and some show the increase over Hydraulic's initial lift force. So what what would you call 146% over Hydraulics, deceiver?
'This completely ignores that ALL of this 'force' (and displacement) needs to be transferred back to the other side for the system to continue to function.'
Again, Seamus101, this is only a single zed to show the initial lift force and not a full ZED transfer system.
'If we were to tap ANY part of that 'increase' the system would immediately stop. (as it will anyway due to friction losses in the fluid flow.)'
Ludicrous statement that it would immediately stop, Seamus101, but lets bring up your friction losses in the fluid flow. In a Hydraulic cylinder the losses in a cylinder is mainly due to the friction loss between the cylinder and the seals on the piston and the gland, they do not even considers the fluid loses as the seal and gland frictional loses are so much larger. Travis system has has no such seal losses, deceiver.
@All, Please see the attached picture to understand the large frictional loses of the hydraulic seals as opposed to the small fluid loses in the Travis system.
Regards, Larry
@DreamThinkBuild: That's the third bet Hawking lost recently - those experiments deal with forces and scales that a regular inventor does not have access to, though.
@LarryC: why don't you add input energy calculation to your spreadsheet (you can average the values between the start and the end state so you do not have to run a simulator, since the progress is linear)? It has been done over at PESN and the energy excess was 0 (and that's not counting energy transfer losses) - eg. not overunity.
Also, compare ZED to a telescopic hydraulic lift of the same size - for the same energy input you will get the same energy output (if you leave the buoyancy pod out, since buoyancy is known not to be overunity). ZED is a closed system that only lifts internal weights, unlike a lift that lifts external weights - that is why it does not need seals. Even if you could reduce energy losses to zero, you will still end up with only unity.
Again, see the attached image (detailed calculations are in my earlier post (http://www.overunity.com/10596/hydro-differential-pressure-exchange-over-unity-system/msg326477/#msg326477))
@KanShi. You suggested that we leave out the buoyancy pod as buoyancy is known not to be overunity. So presumably, when we compare a ZED to a standard hydraulic cylinder, we can leave out the cylinder`s piston.After all it is known that pistons are not overunity....
@neptune You can do that but then there is nothing left to compare. Anyway, while you mention it, ZED's hydraulic part (hydraulic lift) is not overunity and buoyancy is not overunity, so the device as a whole cannot be overunity (effeciencies of parts connected in series have to be multiplied).
Also, as you see from the calculations and the attached image. The lifting force of a ZED is less than a hydropneumatic lift with a buoyancy pod of the same volume (and the same volume of liquids used). Not that it matters, what you should be comparing is not force but energy and as soon as you do that, it will be clear as day that you won't achieve overunity (unless you are working for/are friends with Mr. Wayne, ofc, in that case, you will be claiming overunity regardless of reality).
Quote from: KanShi on July 05, 2012, 12:17:28 AM
Hello Kanshi,
I am suprised you chimed in here once again.
Please take note - that you, Mark E /Seamus / and Micro controller have made your opinons clear.
At the Same time, you state that the ZED is not O/U - a Dozen replications of our claim of over unity has been accurately calculated and shared with me.
Power/ Energy/ and Force - some replicators were satisfied with force - most followed through. Those same people had read your posts on Peswiki and Overunity.com.
I think we are all waiting to see if you follow through. Your repeated logic "that if one part is not overunity then all parts can not be over unity - is limiting your understanding.
The succesful replications took the whole process into acount - and the best took three of the seperate Overunity functions in the system.
First - Our input volume times pressure exceeds a hydraulic cylinder - you have not yet understood that - I had hoped when you reported a 33% to and the layering as 14% to then to 67% - you would look into the whole system - now you state a dead even 0 gain - keep going - there is much more.
Second - Our porcess is not Linear - you are incorrect - the volume in the internal layers changes at a disproportionate rate than each successive layer - this result in a a greater diffirential force applied in the internal layers during a stroke. Reducing the ratio to the downward force above each layer.
The result is that as we double our lifitng requirement - we do not have to double our input. (we are using energy - not just force)
We use the Non linear function to our advantage - in the next phase.
Third - our lateral transfer of energy - two system ZED which you have yet to include in your opinions - recieves over half the total operating cost from the other Zed each stroke - at the Non linear value linear value.
By itself - the Lateral transfer makes a two ZED system near a Zero cost process for one of the ZED - if you reduce in operation the input cost by 50% each - that is the same as 100% for one. SO if we only had that gain - one of our ZED's runs for free.
I pray you are just supplying incomplete data - as I said before - it is unprofessional to make, Opinions, and Incomplete assumptions.
As was shown before - all the head is still in the system after the load is removed -(do not let the system float up after tthe load is removed - and you have the complete head still available). You calcs only show the energy taken out - not the value left behind.
Let me be hopeful - that you and the others are not simply disinformationists.
Our proof and resolve is complete.
Wayne Travis
Quote from: mrwayne on July 03, 2012, 10:02:08 AM
Hello Vidar,
and then
Vidar, to be clear;
I hope this helps,
Wayne
it's hard to be clear in a non-native language ;)
Well, this experiment displays nothing unusual. The displaced water will cause the water level inside the cup to descend. The pressure between the walls of the block and the cup is the force which keeps the weight in place at the same level as the other cup filled with only air. So the pressure is the same in the two cases.
If the block is suppose to follow the cup in an over balanced wheel, the pressure against the block and the cup will cancel out, leaving the tiny volume of air inside the cup as the final cause of buoyancy. That means the cup with the block inside no longer can lift the same weight as the air filled cup.
Still not a good explanation, but I hope it helps :D
An over balance wheel made with this concept will therfor not work. The counterforce that balance the whole system is explained above. No rotation. No free energy from this - if that was the goal...
Vidar
Thank You Vidar,
I think I understand your reference.
When I first introduced the system to my engineer - he tried to relate it as well to the standard process of buoyancy - big mistake - those do not work over unity.
The comparison to an over balanced wheel - or like a float and sink operation - will mix you up.
My engineer originally tried to match stroke lengths to the standard process of buoyancy - Fill, float and sink cycles -
If you read my claims - we eliminate most of that process - or to say it another way - we do not use that process in the same manner. We have a near instant up or down - at any point of our process by changing direction of the flow of water in the inner chamber.
We can go from sinking to maximum lift - the example I use - real numbers - .2 cubic feet of displacement results in a change from sinking to lifting 6000 pounds using buoyancy - not other system in the world can do that. It does not relate to the standard usage and so the standard usage can not be the gauge.
In comparison to standard buoyancy - stroke length is your power out - Our power out is input cost to output.
With our three layer system - we are at over unity at 70% utilization - we have no need to go much below that. going below that 1% is sinking. Going higher - like to 88% is more gain.
We do use weight on the system - so that the ideal is at 68% by static load - and we will sink just below neutral - then only add energy to enter the over unity range - which means we have a direct conversion to excess -
We only have an 7.5 inch stroke range on our little system - but in our process - the other side is going up when this one is going down - we basically have a continual stroke - You look at both Zeds as one process.
Also - an 8 inch stroke continually over unity is much better than a six foot stroke that goes from Zero to full power and then back again - which is not over unity.
My main point in sharing - the process is unique - study it first - you will see where all other attempts at buoyancy are different.
Comparing to other systems will not lead to understanding ours unless you define why those systems did not work and then compare to ours.
Thanks for you input, and welcome.
Wayne
On this point the mathematics are clear. It is possible to derive an absolute mathematical proof that this is the case. I won't do that here but you'll be able to find many of these on the web.
Of course. And those mathematical proofs are taught at Universities.
Each and every one of the mathematical proofs is an analysis of a specific system or one that is meant to generalize all possible cases. Which leaves open the possibility that a specific system can be constructed that will not produce the same results for the same mathematical analysis. Therefore these proofs are not a "law."
Why do those who say Mr. Wayne's device is not possible keep changing the geometry of his unique construction before analyzing? Please analyze the unique construction. Show a mathematical "proof" for this specific case. Trying to "dumb it down" to some simplified equivalent system shows nothing but a lack of diligence.
Thanks,
M.
Quote from: Seamus101 on July 03, 2012, 03:41:08 PM
Herein lies the crux of the missdirection that is occurring. For this machine to be overunity you do need to be able to lift the block or some part of it as well. It is easy to see the extra 'lift' you claim is an anomaly of buoyancy actually comes from the compression of air against the block. This lift vanishes as soon as the weight rises and this compression is reduced.
Thanks, for the statement in bold above.
The videos had a concrete block. It could have been any kind of block, foam, balsa, empty container, and still worked the same, but the critics would have had a field day.
Wayne has stated that the POD's lift was a bonus, so what was it's real purpose?
It rises with the system to maintain the next inner air channel and keeps the water head aligned or a floating concrete block replacement. Now, please show us that you are a person of your word?
Regards, Larry
@LarryC. The pod acts as a floating concrete block replacement. A profound statement in a nutshell. This is the missing link between demonstration video`s and the ZED.
@Mrwayne. I was intrigued that there have been a dozen replications. I am assuming that these are replications built by others rather than your own team. Independent replication is an important milestone on the road to the acceptance of a new concept. I wonder if you are in a position to talk about any of these, or if there is a link we can follow.
@All. An idea has occurred to me. Suppose we have a machine that has just one ZED. So we have to allow a specific amount of water to exit the ZED, on the downstroke. We do not release all the pressure, just enough to cause a downstoke. In a 2 ZED system, this "exaust" would be used to partly charge the other ZED. So in a single ZED machine, we could feed the Exhaust into a low pressure hydraulic accumulator. In a model, this could take a number of forms, ranging from a balloon, a piston working against a weight or spring, or a vertical water column. This would improve the efficiency of a single ZED model. I have no doubt that mrwayne has tried this.
Quote from: neptune on July 05, 2012, 12:45:30 PM
Hello Neptune:
I have been helping (answering questions) for others who have been replicating the physics'
Some college students - some free energy buffs, and some curious engineers.
Some ask deep and important question which has taught me to answer better and better - some things I take for granted - like the floating Pod - instead of Brick.
Other force me to understand and to be able to communicate better - non of them are disrespectful.
So it has been a Joy.
Some have sent me there in progress and finished work - that is exciting.
Thanks Wayne
Quote from: Seamus101 on July 05, 2012, 03:54:37 PM
Consider finite element analysis for example. The basic equations are predicated on the conservation laws laws where each element has no specific form. To use it to solve specific situations you define a mesh of elements with specific forms and then solve the resulting system of equations.
Techniques such as computational fluid dynamics would not exist if it were not possible to do this. I'd doubt any one would doubt the accuracy of such simulations if they have ever flown in a modern jet aircraft which are designed with extensive use of such techniques.
Seamus101, thank you, but I am well versed in the capabilities of FEA and Computational Fluid Dynamics. Would you care to provide the output of either one of those methods for analyzing the particular configuration of a ZED system or will you just continue to reference non specific cases?
M.
Quote from: Seamus101 on July 05, 2012, 04:06:15 PM
The important part in the demonstration is that the block was connected to the bottom of the tank. Because of that he could have shown the arrangement producing any amount of 'lift'. Perhaps even an infinite amount if there was no air in the cup and then gone to claim the buoyancy did not require displacement of mass to occur...
My question is ..repeat the demonstration with a block that is not attached to the bottom and then see if this extra lift can appear. The answer is it cannot.
From my previous reply #836 to you.
'Now, please show us that you are a person of your word?'
You had 3 choices.
1. Admit that your stated requirements for the Travis effect to be OU have been met and start helping with this project.
2. Just leave.
3. Ignore your original statements and change the subject, in which case it shows that you have no integrity.
You have chosen number 3 and now all know that you have no integrity and just here to present misinformation. My next question is how much are you paid to be a deceiver?
'The important part in the demonstration is that the block was connected to the bottom of the tank.'
Even your new subject change is deceitful. None of GreenHiker videos shows the concrete block connected to the bottom, they were all on stands. Besides, you could easily do these simple test yourself and see the results.
Larry
Hello all,
My wife and I have just returned from Wayne Travis' shop in Oklahoma. I was very impressed with Wayne and his machine. I had visited with him for over two hours on the phone prior to the visit and what questions I had left were answered by Wayne in person. I am satisfied that he has an overunity machine currently and the capability to design any size needed. He is level headed and answered my questions and other's truthfully including saying he did not know when asked questions that he did not know the answer to. He is still teaching on this site in spite of being badgered by folks blinded by their faith in professors who have not seen this twist of physics and would not see it if these demo's took place in their own lecture hall. I have signed an NDA and will not respond to questions. Thank you Stephan for this site. Some day I will tell my grandson that I met Wayne Travis and his original team in person.
Quote from: webby1 on July 05, 2012, 07:51:45 PM
Just to pick nits :)
The better response is that the block only needs to provide enough force to counter the force of the cup. If the block were buoyant and that value was higher than the cup on top of it they both would lift, just as in the ZED.
Thanks, webby1,
I'd like to add some info to help clear up the ZED part, as I gave the simple version to seamus101 earlier. It is the retainer wall next to the Pod, and the water between the Pod and retainer wall, and the Pod, that would be considered the total concrete replacement. The moveable part that maintains the air column is only the Pod. This makes it more complex to understand, but since many more are starting to see, I'm sure most can handle it.
@iflewmyown,
Thank you for your witness, it was very inspiring. I wish more would post here, but there would be many attacks against those that just got an id to post it. In your case, you have an established history long before Wayne.
Regards, Larry
I was asked to leave this thread a long time ago and I did. I glanced in from time to time. I can see that you have been in ongoing discussions with Wayne and people are still arguing about buoyancy.
My suggestion is to understand the upcoming demo ahead of time. (I assume that there will be one)
What will be demoed, what is the input (if any), how is it measured? What will the output be and how will it be measured? How long will the demo run? Who will be there? What measuring instruments will be used? I am sure that you can butt your heads together and arrive at a consensus about what you want to know, and what the setup will be.
From the amount of interaction that you have had with Wayne, there is no reason that you should not be aware of this information.
Too often demos are done with zero information ahead of time. Some of you get star-struck and are awed by what you see. You often see people demoing systems with very little explained and no data. This is your opportunity to break that pattern.
Look at the example of the Bedini "Ferris Wheel." What did that thing actually do? I haven't a clue and the people at the show didn't have a clue either but people cheered. I doubt there was much discussion of input vs. output and how things were measured and what they were measured with. It was pretty awful.
You have talked spreadsheets and setups and have engaged a lot with Wayne? How many of you know what will be shown at the demo and how it will be measured?
For example, suppose the system is claimed to output 10 horsepower from a rotating mechanical shaft. How do you measure that horsepower? As an example, you could use some kind of prony brake setup. In addition you need a prony brake that can run continuously for hours connected to the machine. 10 horsepower is 7.45 kilowatts of power and that adds up to a lot of energy very quickly. So if the machine is going to output 10 horsepower of free energy for 24 hours, you should know ahead of time how the test setup is going to take care of dissipating 7.45 kilowatts of power continuously. It's a serious question that demands a serious answer. This is a suggested example for how you want to deal with the testing issue.
Remember, just seeing a running machine like in the first round of clips is not enough.
Quote from: Seamus101 on July 06, 2012, 12:26:46 AM
At this stage I'll just reference the non specific cases.
LOL! ::)
I already know that the basis of the calculations used depend on the laws of conservation. Using them to analyse a Zed system (or any system) cannot possibly lead to anything that shows an overunity result. That should be self evident to you or I'd predict you know a whole lot less about FEM than it being "very familiar"
more "predictions"? LMFAO ::)
Since MrWayne alludes to some magical 'non linear process' occurring somewhere in the machine, I'd say it it up to him or his engineers to model that it in a way that is consistent with the observed results.
However, being a software engineer and trained in mechanical engineering myself, I'd happily provide some code if I could be convinced the effect was real and able to be modelled. Nothing shown so far passes that test for me.
and does your modeling software include ALL the parameters that reality includes? will you provide the list of your parameters for peer review? ohh wait, that's all a moot point isn't it... because there is no way to convince you the effect is real. ::) so... why are you even bothering to blubber on about things you aren't going to do?
i see the troll milelow is back again... doing nothing but telling everyone else how it's done... ::)
Quote from: iflewmyown on July 05, 2012, 08:20:02 PM
Hello all,
My wife and I have just returned from Wayne Travis' shop in Oklahoma...
Thanks for your update!
Too bad about the NDA. Not the fact that you signed one (I would too), but just that you can't tell all! Good for you!
Now please add anything more you can reveal. Technical or not. It's all very interesting to those who live in "flyover States" that are much further away. And at least one from Queen's land is on the edge of his seat...
M.
@MileHigh, welcome back! I can't remember anyone asking you to leave but I, for one, am happy to see you return. Your type of critical thinking fills a gap here, I believe.
I've noticed a pattern in Mr. Wayne's responses that I thought I might address to you. It appears to me that he does not answer some questions purposely. At first I thought it was because he may have overlooked them in the thread posts. And that may still be true. But I wonder if he does not respond to questions that would involve disclosure of information that has not already been made public in the patent and videos? I believe he might not be addressing questions that may be considered IP that is not legally secured.
M.
Hello All,
When I was a young manager I was in charge of all the MIT's (Managers in Training).
One particular "Corporate" transferred MIT - was transferred to me - so that corporate could decide if his problem surrounding his last location were personal issues with his other trainer (no they did not tell me of his issues).
And since his issues were of his own doing - they arose very quickly - he made grievous errors continually - he put no effort in to changing his skill or efforts - because he had become a master of deceit - and he felt very safe in his ability to divert responsibility - lie - and to always have some counter charge - or teary eyed excuse about something.
He was not improving - and he was not trying to - and as the lead trainer for OKC this was a nightmare.
I was pretty frustrated - like many of you are - here on this web site - dealing with what you call "Trolls" they can say anything - and back up nothing - they don't try - they don't need to - they can switch at any point to a new position - as you futilely try to defend or hold them accountable to the last lie.
So, back to the MIT- I was livid with this MIT - my supervisor Danny Cruze - come by and asked me about the MIT's progress - boy did I have a load to get off my chest - after I vented - Danny said -
"Wayne, the MIT is not the problem - you are............. You are in charge and you have given your efforts and energy to a game of tennis........he said go look in the mirror and ask what you can do differently that will change the outcome - not what you can make others do."
It was not good advise to my ears at that age - I was PO'ed - dealing with a liar - cheat - and I was frustrated and tired with the effort I was extending proving the falsehood's - over and over.
Danny called and asked a week later - "Did you take that look in the mirror" .................I wanted to tell Danny something rude - but he was such a Good man and wise - I bit my tongue and then said - "OK Danny - I will"
So feeling like a fool - I stood at the mirror - and asked what could I change about me - to change the situation.
I really wanted to win the tennis match - really wanted to win - how could I change my behaviour - set up traps? cameras? detailed log books, duct tape and beatings --lol
Danny called again - "are you still playing tennis with the MIT?"
I said "No" ....not because I had solved the problem - but because it was the right answer at the time - and instantaneously - I realized that was the answer -
The only way to defeat a liar - a deceiver - an obstructionist - is to not give them the game.
Do not step on the court - the lies are just diversions - the truth is all that matters - if you chase the deceptions - you run back and forth expending much time and energy - and you gain nothing but a record of a new lie.
But when you step off the court - and hold your true position - you are in charge of yourself - and the liar.
So the Next Lie the MIT told - I stopped him mid sentence - and said - "fix it now" - he countered with "but I did it already".... "do it now" .... "I have witnesses" ....... Do it now.......I do not care what when how or who - your job is to do this work - do it now or quit.
I tell you all this story because it is happening again here.
All you have to do to let Seamus, Mark Euthanasia, Microcontroller --- waste your time --- is to give your time to them.
I think Kanshi is just confused - or has not done her due diligence and Micro controller just jumps the band wagon.
Milehigh had my respect that he left - a real troll will not leave - or just change his name to "Seamus"
My point:
Many of you have replicated the physics - and saw the attributes of the system and that it is Overuntiy
We can not hope that the moderator can keep up with trolling -
So instead of responding to the continual twisting and changing of statements and directions of attacks -
If you must respond to a diversion attack - just make a this statement:
We hear you, we will think about it, and if necessary we will change it.
Thank you for your input.
Lets get off of the tennis court where they control our time with "untruths, false assertions, misuse of logic and dogmatic entropy - and return to the discovery at hand.
In the end - any great leader knows - we are only in control of ourselves - we can not force lasting change in others - it comes from inside each of us to do our part - and not feed the "trolls".
Wayne Travis
The obstructionists know that they are not talking about the topic at hand - that is their point - we are better than that.
@Mondrasec. I can only second what you said about the report from Iflewmyown. Any kind of background information would be welcome and interesting. Living as I do in the UK, I am even further away, and totally unable to come and see for myself.
@Mr Wayne. I hear what you say about not feeding the trolls. Your experiences in Corporate Life are interesting although I can not relate to them directly as I have always worked for myself. Even so, I guess we have all met people like that.
I would like to think that at least some of the trolls will be silenced when we here what Mark Dansie has to say. Even that might be to much to hope. Any news or updates on the pre tests?
Quote from: mondrasek on July 06, 2012, 07:58:51 AM
M.
Hello M,
It is a combination -
Some peoples posts I hardly look at - I give everyone respect until they un- earn it.
Sometimes someone askes a question as a statement
Some people ask a bunch of questions in one post and I have a hard time matching those with my short visits.
Some people ask idea questions - such as to related but unrelated topics - they loose out to the schedule - unless I have anight were I can not sleep.
Sometimes the question is asked - in an unbelief manner - such as how do you defeat the law of such and such (I am not here to expalin system other than mine) those laws related to "previously studied designs" Study this one then ask if the law applies.
Many - and most times - the question has been asked and answered by both myself and others.
I do not avoid any question - I may not have an answer to some.
Only the Questions that pertain to our improvemnts from the patent are left out - as I said before - the lawyers do thier work first.
My NDA's are to protect the privacy of those who are involved - and then to make it clear we are not helping you to compete with us - join us - fine - use us - no.
Any of the people who have signed NDA's have my explicit permission to tell anything about the machine except - the improvements - who is helping us - and our business plans.
If chose to share - it is fine with me - so don't ask those questions.
I hope this helps.
Wayne Travis
Quote from: neptune on July 06, 2012, 10:21:23 AM
No,
The trolls will not stop - Mark has spoken five times publically about our project.
They respect no one - just demand attention - if this site was not being read - they would go elsewhere - for attention.
Rest assured - the real skeptics, the professionals, are helping us - the "troll's' will move on - no apologie - to someone else - until they can not get attention.
They have no effect on our work - just waste time.
Thanks Again
Wayne
Hello all,
Thank you very much,
You have been very kind, thank you for the visit, as I said before - I love to share our discovery.
The NDA is to protect your privacy - you may share anything you like - just not the things we discussed that are private.
Wayne
Please study what Wayne has shown on this site. The best way is to read only his posts in the order he wrote them ignoring All others. Then read the posts of the guys who are honestly studying what he teaches. Find and view each of his videos. Do the experiments he shows, as you will never find a cheaper experiment showing the basis of one form of free energy. I believe Wayne has exactly what he says he has and a lot more that he is not sharing publicly. That is the only answer that is needed by those with an open mind.
Garry
Well done, Garry.
So what do you fly? I'm very much a little plane enthusiast.
M.
Mondrasek:
QuoteI've noticed a pattern in Mr. Wayne's responses that I thought I might address to you. It appears to me that he does not answer some questions purposely. At first I thought it was because he may have overlooked them in the thread posts. And that may still be true. But I wonder if he does not respond to questions that would involve disclosure of information that has not already been made public in the patent and videos? I believe he might not be addressing questions that may be considered IP that is not legally secured.
i can't really comment on that. Once assumes that you can debate this issue with Wayne and eventually you will hit a wall. The wall is the "secret sauce," we see it all the time from people promoting free energy propositions.
Just a few more comments.
I saw some spreadsheets but they seemed to only be looking at increased force. As has already been said, you have to look at work-in and work-out in the spreadsheets. Without those calculations the spreadsheets are meaningless.
With respect to the "trolls" debate, don't let yourself get brainwashed and don't brainwash yourself. If you decide that "people that disagree with me are trolls" you are no better than a fascist. Trolls are
not people that want to argue the merits or lack of merits of the proposition. You start thinking like that and you are heading down a dangerous and ugly path. Go look up the Wikipedia definition for "troll" and you might agree with me that there is only one troll on this website.
The only thing that Wayne has to offer you is a story that there is a magic configuration that will fit inside a black box filled with water and valves and pipes that can produce an unlimited amount of free energy. Even though I have not been following, any of you that have been playing with buoyancy and making little setups only see unity. As far as I am concerned you are just wasting your time.
It's very likely that this thread as it gets longer and longer gets more and more Google attention and starts coming up higher and higher in various search results. Even a mixture of both good and bad publicity is better than no publicity. So this could all be part of a project to "set up your fishing" to get investors. Not such a nice thought, it would imply that Wayne is using you, and this ultimately the exercises you are all doing are BS. Don't shoot me, it's a real possibility. Following that train of thought, "Iflewmyown" could very well be a shill. If he has never been in this thread at all and just showed up the other day with a visit report I would be suspicions.
Because of all of the above, that's why I am suggesting that you focus on whatever Wayne claims he is going to do in his demo of his system to prove that his technology is real. Play hard ball with Wayne and push for getting all of the input and output measurement data like I already posted. After all of your back and forth talk in this thread, all that you guys know when push comes to shove is that Wayne is claiming that he has a magic black box that creates power out of nothingness using buoyancy. He can claim that he is "bending the rules" or that he has a "special trick that does not break the laws of Physics, bla bla bla" it doesn't matter. Wayne claims that he has a black box, and what you should do on this thread is get ALL of the information about the input and output measurements on the black box. You should demand this. Forget about trying to "understand how it works" because that's impossible. Wayne will always cite his "secret sauce" if needed.
Get the proof that Wayne delivers the goods when he does his demos. Don't just stand idly by like passive wallflowers and wait to be spoon-fed the results.
I just ready Milehighs latest attempt to insert the idea that we have magical free energy.
Well milehigh,
We heard what you said, we will think about it, and may make a change if we decide it has any merit.
Wayne
Wayne:
Quotelatest attempt to insert the idea that we have magical free energy
That's exactly what you are trying to claim, make no mistake. I don't care what phraseology you want to throw at me, in the final analysis that's what you are doing. Same thing for precisely how you are supposedly doing it, that's your "secret sauce."
So what follows from that is the only way to be credible is to tell the people on this forum all of the details pertaining to the measurements and apparatus that you will be using in your upcoming tests ahead of time. Then follow-through and deliver all the data. Your actual system can be put aside does not really need to be discussed. What your system actually does in terms of test setup and the provided data is the real way for you to show the people on this forum that you really have something.
Basic questions: What form will the power output be in and how will you measure it? What equipment will you be using for the measurements with manufacturers' names and part numbers?
Quote from: Seamus101 on July 07, 2012, 07:29:01 AM
As it happens I haven't been here to troll at all. I'd only represent the usual thinking of engineers on these matters.
I've re-read all the descriptions in this thread of how this machine works with a genunie desire to see a working principle that could explain your apparent success at achieving useful work output from it.
Now, I have a question, Is the working principle able to be deduced from the demonstration provided by the Travis effect video 5 http://www.youtube.com/watch?v=QHbP3QTncBY (http://www.youtube.com/watch?v=QHbP3QTncBY) A simple yes or no answer is all that is required.
I wish you were sincere;
Looking for the "Working principle" is why I believe this system has been over looked - You can not get free energy from buoyancy - alone.
We do provide free energy from a clever usage of several separate reactions that occur when dealing with Air, Water, design, and Gravity.
It is simple (one basic moving part inside) and a plethora of complex physics inside the process.
I did not need the complex understanding to see what was smack in front of me - had great potential.
One Very Good Engineer - Stephen Seymour - third party/grant committee - said Wayne - you need to measure more than force - you need to break the actions and reaction down into inf-antesable measurements of the reactions at every moment of the operation to fully understand it (why it can not possibly work).
I said - Oh, I am sorry - just the simple output was so clear - I forgot to offer those (the full spectrum of energy power and force) to you - here....... He looked and said - OMG - build it........now...... - do not tell anyone else until it is protected and build it now.
But what he said - was volumes - some people need the unendurable to believe the obvious - I believe our engineers are taught to look at the infinitesimal - for what other reason would they deny the simple - based on the complex.
Which is more powerful? If you are making your assumptionsoff of force - the details will tell you where you are wrong, but in power out - excess power out - then the details only explain how.
You can not gleam the details - the full operation from one Video - one working principle.
To your other question:
"Now, I have a question, Is the working principle able to be deduced from the demonstration provided by the Travis effect video 5"
Mondrask asked why I do not answer some questions -
Yours is an example of one I would not answer the way it was formed.
If you asked - as I have said - "is this the effect that you observed that led to your eventual design of your claimed working Z.E.D. system" - the answer is "yes".
But in context to our discussions and the charges you have already repeated - I must assume that you will again turn "A" answer to your question into a claim that we have claimed over unity in video #5 again.
Video 1 - 5 were the inception moments - a part of histoy to us - which I have stated every time you claimed against it.
Why I think you are not genuine - is this question has been hammered by you, Kanshi, Mark E, and second opinion's by Micro
and I have clearly answered it repeatedly - it is the same question you posed - that Larry C challenged you on - "to keep your word".
Now Answer me this question please:
How would you describe a machine the provided more energy than it required to operate - not more than the Ideal of the system - but a simple 5 hp Ideal motor that consumes 2 hp to operate and only has 3 hp to use?
In case you do not understand the question - If I claimed to get 6 HP from a 5 hp motor - or even 100% I would agree with the "magic claims" from the other. What you should ask is if it is impossible to reduce the input of a system to provide net energy.
It is not the same as taking one form of energy and claiming it grows into more.
Their is a difference - That is under under utilization - it is only 60% of the ability of the system - but it is free -
Because the Travis Effect showed a way to run faster and cheaper - that is all video five needed to show.
The "Laws" which you protect - we do not make claims again - we make Solid claims that we developed a system to capture multiple reactions to the same input - and then use those multiple reactions to supply the input - reducing the operating cost of the same system well leaving energy to supply to the consumer.
The middle school example of "opposite and equal reactions" and we discovered the combination of usage - of the compression nd expansion of Air and recapture - of head pressure and recapture - of buoyancy and recapture - and mixed that with the speed and cost reduction the Travis effect offered - and then layered the system to resuse the mechanical displaced mass multiple times at the same time - even speeding up the Travis effect - times each layer.
In short - each layer speeds the Travis effect at a greater rate with each layer - because the layering system decreases the compression and expansion with each layer - which is why we have a non - linear system - a polynomial.
I am just an inventor - but I clearly understand that power can be measured in time distance and mass -
Video 5 shows the Mass 2 pounds - lifted much much faster - at our controlled distance than the standard - Very good.
I can clearly understand that air volume compresses less within higher pressures.
We engineered a way to utilize that attribute - condensed it, and added the usefulness of the old column equalization - and some very cool attributes to develop the self powered system.
That should raise a flag of hope for all of us - it is just one world.
Even Larry C and other showed the upstroke potential - if you just used that and then added the equalization - you would intuitively know we blow the lid off Free energy.
In regards to your status:
Maybe you are - maybe your not - but coming on this link - the way you have presented yourself to this point - moves you to the other camp.
I hope it is just you are slow to realize that all possible combinations of physics - have not been completely explored - this system is an example - you can grow from it.
Wayne Travis
Quote from: MileHigh on July 07, 2012, 02:11:34 AM
Wayne:
You have dismissed everyone that has presented Data.
Which is the proof that you are in a philosophical debate with yourself.
I do physical testing - not philisophical.
Our physical system has been tested to confim to all physics - except the notion that it can not be done.
Multiple people have reported even here to the system - but a million people could present you with Data - and you will still struggle with your belief.
It is not my Job to make you a believer - it is my Job to share our advancement to physics - you are welcome to stay behind.
Again - Since our system conforms to basic and complex physics - which you can do yourself - make your own Data.
As I presented mine - you just say it is wrong - flawed or trickery.
You waste our time, and will until you decide which of your physics to believe.
Wayne Travis
Quote from: iflewmyown on July 06, 2012, 08:48:20 PM
Garry
Hello Garry,
You are a brave man, I have such respect for you.
You looked, you listened, you asked questions and understood.
The fact that you would risk the ignorant accusations that have now been dropped by the 'Trolls'
Lends credence to your courage, well done.
I apologize for them.
Wayne Travis
Quote from: MileHigh on July 07, 2012, 12:18:38 AM
Mondrasek:
With respect to the "trolls" debate, don't let yourself get brainwashed and don't brainwash yourself. If you decide that "people that disagree with me are trolls" you are no better than a fascist. Trolls are not people that want to argue the merits or lack of merits of the proposition. You start thinking like that and you are heading down a dangerous and ugly path. Go look up the Wikipedia definition for "troll" and you might agree with me that there is only one troll on this website.
First - what is that safety device in a steering wheel?
Second - We have working Demo models - which have been tested - the fact that you keep claiming otherwise is simple disinformation.
The NEXT Validation is a big step up - you do not move onto the NEXT level of Validation unless you passed the last - Three.
In validation recap - again:
Is our Physics good - PASSED
Is it original concept - PASSED
Do we have IP protection - PASSED
Is our group reptualable - PASSED
DO we have the ability to make Business decsions - PASSED
Does the input and out put math the physic model - PASSED
Can the system run closed looped - PASSED
What are the reactions within the system and can it be scaled - IN preparation
You are simply a disinformationist - you try to confuse people to our progress.
Third - Secret Sauce - it wasn't secret sauce for the replications.....That is your word for things hard for you to agree with.
Complain that it takes to much effort OK, but secret sauce - that points to you.
It is fine with me if you ignore the truth - you waste your time making bogus claims against us, and using your issues an an excuse is bad form.
As before - I asked - are you going to put as much effort in supporting us - that will be the test of your character.
If you already know you do not have it in you - quit insulting the good people that do.
I will take your banter - I can handle it.
Wayne Travis
Wayne:
QuoteYou have dismissed everyone that has presented Data.
Wayne Travis
QuoteFirst - what is that safety device in a steering wheel?
Wayne Travis
I asked you, "
What form will the power output be in and how will you measure it? What equipment will you be using for the measurements with manufacturers' names and part numbers?"
And you generate all of the text above but you don't answer my very basic questions. That says a lot about you and your hypothetical system.
Contributors to this thread: My advice is to push Wayne and keep on pushing him for basic answers to basic questions, focusing always on his demos and the energy input and output measurements with all of the details. That is supposedly what this whole thing is about. Don't let Wayne or anybody else sway you from this fact and try to deflect you away from this.
If Wayne does some demos in the future and you don't get all of the relevant data about the input and output and how it was measured and what was used to make the measurements, etc, etc, then I would walk away from this whole thing.
If you can't get a straight answer to a straight question then there is a serious problem.
Milehigh,
Who needs pushing? You divert and double down.
I have answered openly and honestly - you again assert the outright lie by calling our system hypothetical and dismiss everyone.
you dismiss that we have answered your question.
You are welcome to the results of our validation - you may ask the validators how they measured.
Be of character and stop making up poop - until it is over.
You continue to disrespect me and others claiming we have a grand conspiracy an agenda - theft - and such.
We have not injured anyone - nor have we asked for money or investors - nor have we made false claims - you now try to pretend to protect people from a future threat..... did you give up on proving our replicators wrong?
Since you persist with your accusations - let me repeat what I have already stated repeatedly
We have the help - from the right people - already.
I am here explaining my patent - and who knows - maybe some of the people who read this site might be in a position to join our team one day - after the validation.
If that is a problem with you - it is your problem.
Bad form
Wayne
I asked you some straight questions on behalf of all of the readers of this thread and I am requesting some straight answers.
Are we supposed to assume that you have a system that produces free energy and you won't tell us how you measure it?
Quote from: MileHigh on July 07, 2012, 01:52:48 PM
Actually, you presume too much. You are not asking questions on my behalf that I want answered right now. I am happy to wait for the on-site verification by Mark Dansie first, then I will ask Mark about his test details. Then if that passes, I will wait for the on-site engineering due diligence tests. Then I will ask about the details of those tests.
The sequence of due diligence tests have been repeatedly outlined by Wayne and Mark in the public forums. Each step to be designed and taken in sequence based on a passing grade for each along the way. A fail stops the follow-on test steps.
If you want to post concerns about the testing process or equipment, then I suggest you direct those to Mark.
Many posts have been presented in the "spirit" of an attack, rather than one of inquiry and constructive engagement. These types of posts do nothing but fill the thread with noise that makes it hard to navigate the information. Most want to pronounce the verdict before the trial is half over.
I don't have a problem with Wayne if he is wrong about the energy generation potential of his device. If he is wrong, it will come out through the tests and reviews by those qualified skeptics who are tasked with the on-site verification. I would not think the lesser of him for being wrong, because he has not tried to scam anyone by hiding what he has and knows. He has invited the skeptics to prove him right or wrong. All he has asked is that they respect his IP with an NDA if they want access to non-public information.
You made my day - that was funny.
Just be professional - thats all I expect from you.
Ask Questions that are sincere -
Do not insult those who disagree with you -
Keep your stero types about inventors to yourself -
Do not ask questions to support your belief system -
ask questions with respect to the whole system -
Read what was already answered -
Leave the Ego out of the conversation -
Do not assert in your questions that you behold all the attainable knowledge in the universe.
And the hardest Part - which I am sorry to have to say -
You are the student here - not me - (on this one subject only) listen, look, ask proper questions, and learn.
If you want to learn - don't jump to conclusions -
If you already understood what we have enough to make a "conclusion" - you would have built it long ago..
Ready if you are.
Wayne Travis
p.s. In referance to the Validation - I set no parameters - nor obstructions - you can follow their report in regards to input and output measureing methods.
Wayne:
I have avoided discussing your system and instead I am focusing on the test results. You have been talking in this thread about thousands of pounds of lifting force in the system, bla bla bla and then when someone comes along and asks you how you measure the energy out you croak.
You have tried to make me the issue and fired off your entire arsenal at me with everything under the sun in an attempt to put the spotlight on me and deflect it away from what really counts, the results.
Everybody knows that the spotlight is on the test results of your system. It has nothing to do with me.
Why can't you say what the power output from your system is and what form it's in? Why? How can you talk about it over almost 60 pages of this thread and discuss all sorts of aspects of it and you crumble when somebody asks you about the output measurements?
If I was in your shoes and someone asked me what the output of the setup was I would tell them. For Christ's sake, you have been working on it for months and months and months and you can't say what the output is? You should be able to answer that question without batting an eyelash and give the details. It's not even a question that asks about how your system works, it's just a question about the useful output and how you measured it. It's unbelievable that you can't answer that question.
I am NOT the issue and you can whine and pout and deflect all you want, and sound wounded and in need of sympathy and perhaps some of the readers will buy it, and others not.
The first issue is the measurements of the output from your system will all of the data and test apparatus documented for everyone to see.
There is a secondary issue, which is you Wayne. Watching you squirm and deflect and pout and try to make me out like the bad guy is not at all confidence inspiring for anyone. It's a pathetic joke that you are pitching that you have a free energy machine based on buoyancy and when someone asks you for data on the output from said free energy machine you can't answer and then you do your dance.
I am done with this thread for now and I will be glancing in from time to time to read about any demos of the system and the results and how they were measured.
QuoteAsk Questions that are sincere
How much power output will your system deliver? What form will the power output be in and how will you measure it? What equipment will you be using for the measurements with manufacturers' names and part numbers?
It can't get any more sincere than that.
First - as I have stated before - We are not doing the testing - and I am sure they will not use our equipment.
Second - we test our system by running closed looped - no fuel - no emissions, no inputs, and running a simple load.
(with the new cylinders bronze type bushings a little noise - but this is temporary).
A note you might have missed - we have nine energy conversions in our system - all with losses - we can not even capture all the lift from the Zed - and still we have ample to demonstrate our point - at some point - putting a gauge on it sinks a little deeper into the testing of the past systems - which might have been "barely" overunity.
Our system is basically a self running pump - one of our Beta model will be for agricultural pumping, the other three will be for electrical conversion and demonstrating scale ability.
What you do with it is based on demand -
How much you want - is based on scale.
If you are wanting to know the specifics of our demo - I will let you know when we have finished the runs - promise.
Thanks.
Wayne
Quote from: MileHigh on July 07, 2012, 06:19:08 PM
Wayne:
I answered before I read your rant ..
I think it is wise for you to leave.
Your tactic to start out attacking does not lend to someone caring to read - listen or answer.
I am sorry if you do not like me avoiding your laten and direct insults.
Have no fear, I do not crouch, nor fear, nor hide, nor get bothered by your insults - I just don't waste my time.
What you do not realize is that what I have shared here is real.
That won't go away.
Have a nice day.
Wayne
Wayne:
QuoteI am sorry if you do not like me avoiding your laten and direct insults.
Bullshit, all I am asking for is data on the output of your device and how it is measured. I am not going after you and insulting you. You are lying and using playing the victim as a tactic to avoid discussing the output from your system.
Stop playing the victim Wayne it's tedious. All that I know is that after 60 pages you still can't even state what the output from your device is. You just want to deflect attention away from the most important aspect of what you have been talking about for 60 pages - the output. Without any serious discussion about the output from your black box you lose all credibility as far as I am concerned.
For what it's worth, I have some comments this clip that was recently linked to: http://www.youtube.com/watch?v=QHbP3QTncBY
"Travis Effect Demo 5" shows nothing of significance. "The Travis effect has won the race and is the more efficient system." If any people reading this thread that watched that clip believe that you are seeing a "more efficient system" then you are wrong. Once you factor the vertical displacement of the cups into the picture then you should realize that there is nothing there.
If I have accomplished anything it is that some of the readers and contributors will be more focused when you announce the results of your testing. If you claim that the system produces seven horsepower continuously then they will want to see tangible proof of this. They will want to know precisely what load you put on the output and how you measured it. They are now aware than any load has to dissipate the energy output from your system and they will want to know how you are doing that.
We can all wait and see if you are going to deliver any results.
When I come back after you announce some results and ask you some questions about the results, don't you dare play the victim and try to deflect attention away from your results. i will ask you straight questions and if you start dancing your victim dance I will state that's exactly what you are doing.
MH
I watched some of the videos at the http://hydroenergyrevolution.com/ (http://hydroenergyrevolution.com/) website, and specifically the "TRAVIS EFFECT" videos, and if this machine is based on these principles it certainly does not produce extra energy, regardless if it is "closed looped" or not. The "travis effect" is just a static test and the force on the piston is down and is supported by the floor of the water tank. If this piston is attached to the cup, as some are thinking and designing, this force will than be supported by the cup and it will sink real fast.
So, let's talk about the proof offered: CLOSED LOOP
In the free energy "circles" most folks have the impression that "closed loop" operation automatically means proof of free energy, and that couldn't be farther from the truth. Take for example the simplest closed loop system, a spinning wheel! If it is on good bearings and friction with air is minimized, it can spin for quite a while if given some initial energy. Seeing the wheel spin does not mean it is producing extra energy.
The same concept can be applied to more complex system, where it is not clear what is inside and what forces and energy storage reservoirs are present. In such cases it is mandatory that the "initial conditions" of a system be specified. For example, what is the water level in the pistons or bellows, what is the center of gravity of the whole unit, how much pressure is in a cylinder, what springs are compressed, how much charge is in a battery, capacitor, etc.. Anybody who does not specify such things before or after a test might be a good inventor but proves he is not a good tester of a system.
So, looking at a system moving tells me nothing. The video of bellows moving is a worthless waste of bandwidth if it is meant to prove overunity.
EM
Quote from: EMdevices on July 07, 2012, 10:37:31 PM
MH
EM
You see nothing in the Travis Effect - OK..
Ok, - ya got me, I guess I am done here.....
Have a nice day.
Seriously - have a nice day.
Wayne
@Mrwayne. It would be a great shame if you really are done here. So the verdict has been reached even before the trial begins. Remember that the Flat Earth Society is still in existence and thriving. I dare say that there are people around who do not believe in Flying Machines. I think what would be helpful, is if you are in a position to tell us when the Mark Dansie tests are likely to take place. If for some reason you are still having problems, perhaps you could share that with us. For those of us who wish to see you succeed, it would cheer us up to see how things are progressing.
Regards Neptune.
To All,
To those of you who are sharing and asking for Data privately - please continue - and you may post what you like of what I share.
This Web site has turned into a loop of interuption - of our sharing and efforts.
We should be talking about the details of the Non - linear - the inverted pumps - the cross over hydraulic exchange system.
What Se3d said is exactly right - validation is a long and hard process - and if you do not understand the process of extraordinary proof - you will be confused for a long time.
For those of you who jump to conclusions - without understanding - I fear you may be on the "Edge of Jealousy"
I am sorry for that - I grew up with the notion that intelligent people helped eachother - for greater good - not of themself.
The professionals we are dealing with - hold their conclusions until the due diligence is done - I am so honored that they are professional.
And Se3d is exactly right - you do not move on to the next stage of validation until you pass the last - we have passed seven stages so far. No one - as I have been told has passed two stages before - in regards to free energy.
And for those of you Who have been professional - I commend you - it is hard to share your pearls of wisdom around split hooves.
And for you who are already typing your victory messages for running off an inventor- I will be back.
I will be back - to present the Conclusions of the Testing - Good or Bad - I am an honest man who keeps his word.
I suggest you get a BB gun and a cook book on how to roast Crow.
You are going to owe me an apology.
Don't bother claiming I did not give you enough information - you wasted your information gathering time - enough said.
To all who care,
Please keep us in your prayers, the preparation for the tests are going very well.
Wayne Travis
President
HydroEnergy Revolution.com
mr.wayne@hydroenergyrevolution.com
QuoteYou see nothing in the Travis Effect - OK..
Wayne, I did not realize it was you who invented the machine, but sadly yes, I don't see anything new in your "travis effect" setup, and calling it by your name really insults the great scientists that have explored the physics hundreds of years before you were even born! So have some respect.
but for discussions sake, here's why the "effect" is not special. I drew a diagram to illustrate.
Notice that the higher pressure inside the cup is also pushing down on the piston with force F2. It is true that a lesser volume of air is needed in such a configuration, but that's nothing new because the piston is displacing some of the volume. Your car breaks work on this principle. F=p A, and you can have a very large area 'A' and create quite a force with very little hydraulic fluid pressure or displaced, or have a small area and high pressure. But all this is just a STATIC configuration.
If we want a DYNAMIC cycle based on this "effect", we can perhaps let the cup move up, but it will quickly drop the pressure of the air inside as the air moves up top, since it depends on the water/air interface level. On the other hand, if we try and attach the piston to the cup, than the cup will be loaded down with force F2, and then the net force F1-F2 will be small, so nothing gained from this either.
Do you follow what I'm saying?
EM
I just posted the below to Sterling's site today because someone had made an incorrect assertion on how the Travis Effect was named.
"I (Tom Miller) coined the term "Travis Effect" and used it on the first video. The team liked it and the name stuck. Wayne called it "the Effect" back in April when I visited Chickasha.
Keith & Sterling's article on (PESWiki), talks about it accurately: "Tom Miller, in two videos (1 | 2) on the principle, has termed this the "Travis Effect." And though Mr. Travis may not necessarily approve of the nomenclature,...""
If there are issues with why the effect was named as it was, you may address that criticism to me.
I would suggest that the commenters in this thread read the material available before jumping to conclusions or making their own assumptions up. If you want to post snide comments or incorrect assumptions, they will be mostly ignored.
On the other hand if you want to ask a pertinent question in a nuetral, or a nice way, there are several people here that are happy to help others learn.
Thanks,
Tom
Quote from: webby1 on July 08, 2012, 05:06:41 PM
Hi EMdevices,
You are correct in your observation
How much input did it cost to bring the cup up to lift potential?
How much input does it take to bring an empty cup up to lift potential?
If the cup was to raise 20% the height of the cup how much energy is used?
This demonstration is being used to build the understanding of the functioning system, this is not the whole thing but the basic building block that is needed to understand how the system works.
If you could also raise the block at the same time you are raising the cup, that might be something novel, and this is what Wayne Travis has managed to do.
Another observation to this simple demo is that the input to the cup with block starts out at its highest value, and the lift is at its highest value.
To take this and find advantage would mean using a short up stroke, that is the area where the input is far less than a normal system, if you keep the stroke going then the costs rise up to the same value as conventional, so don't do that.
Nothing has been made, no extra forces nor energy BUT something has been conserved and that is where the gain comes from, after all, we all understand a penny saved is a penny earned. Take some of those savings and invest them into the system itself and continue with more savings :)
Outstanding, that was a great explanation.
Regards, Larry
To All,
I visited Wayne Travis last week. I found him and his machine very credible. He was very open with the priciple and the design of his machine. You can tell this is something he has put a lot of effort into and is very passionate. He has a small staff working with him and they are well beyond whether the machine works or not.
There are many reasons to be skeptical about the ideas and inventions out there, especially those promising overunity. So when I had a chance to check something out personally, I took it. I may actually be a believer.
Quote from: Seamus101 on July 09, 2012, 08:19:33 AM
I cannot agree with that statement.
no one cares... mint?
Is the Travis device, the big one, hooked up to the municipal water main supply (or to a local wellpump) while it's running?
Not for any flow, you understand, or perhaps allowing for just a small flow rate to replace leaked water... but perhaps seeing the _pressure_ of the municipal supply (or wellpump pressure)? And perhaps this connection could be valved on and off by the pneumatic control system ... again, not for any substantial _flow_ but for the pressure?
It's a question that's been nagging at the back of my mind for some time. I am believing all that MrWayne is sharing with us, but I still have the feeling we aren't quite asking the right questions yet.
MrWayne has told us that there's no exhaust, like excess water or air, and no input beyond the initial precharge of pressures. I believe him, benefit of doubt style, and that's what makes any "supplied external power" scheme break down, because if outside power were being supplied there would have to be an input and an exhaust of some kind. So either there is some well hidden or neglected input/exhaust happening, like an open pressure tap to the muni watermain, or the Travis Effect is really doing what MrWayne claims in a manner that defies rational analysis. (None of the positive analyses done so far have explained where any excess energy could be coming from).
@EM Devices. I find your post about closed looping a little strange. If we have a machine that will run closed looped, but produces no energy to external load, the conclusion we draw will depend on how long it will run. I would say that if the machine is purely mechanical, and runs for, say a month without slowing down, then something is happening that challenges the laws of physics. If it produces a tiny amount of excess energy, then it is overunity. If it makes any sound, that is excess energy. If it causes tiny air currents, that is OU. If the bearings run at one hundredth of a degree above ambient temperature, that is OU. Such a machine would be of no practical use, except to open peoples minds. That in itself is very useful.
@TinselKoala. For the first time , you have written a post I can agree with! Mr wayne has made it clear that there is no connection to the water mains, or well pump. If there was such a connection , then during 4 years of experiments, he would have tried the machine without it. If the machine then stopped, it would not be difficult to figure out where the energy was coming from. That would have been a pivotal moment at which time he would have realised that all he had was a water mains powered engine. Mark Dansie would have noticed. The other engineers would have noticed. It would be one of the first things you would look for.
That leaves only your second possibility. You express it as defying rational analysis. I would say it defies conventional analysis. I will admit that in a way, mrwayne has not said exactly where the energy comes from, in a direct sense. It is not impossible that he does not know. At this stage I am not by any means certain that it really matters. What does matter, is that there is excess energy. When mankind started to make articles from metal, he had to put away the tools he used to work with wood, and fashion some new tools. To understand this concept, perhaps we need some new tools.
Quote from: WilbyInebriated on July 09, 2012, 11:46:30 AM
Who cares?
But what you imply with your statement is that the Travis effect can some how be used to create a buoyancy effect that can deliver excess energy. That statement is BS. Because the Travis effect isn't displaying how much volume of air that is required to lift a weight, but the over all surface pressure that acts on the inside of the cup. It is a visually disturbing demonstration - specially for OU seekers.
Ofcourse, the same pressure is counter forced on the block inside the cup, pressing the block down as much as the cup is pressed upwards. If you put a scale under the block, you will see that the weight of the block increase with the same weight as the displaced water volume + the weight of the water above the cup that creates the pressure.
On the other hand you say " "a spontaneous increase in the energy state of a system" is not needed, it is only redistributing the energy that is already present"
What you say is that the system is trivial, and it cannot work.
I have had several sleepless nights because of a convincing idea, and it hurts when I realized I have done a mistake in my calculations.
You too have probably made too much effort in this to admit that you are wrong. It's painful to realize the facts, but you will recover soon ;) - I did after a week or so...
EDIT: That said, being unconcerned of the impossible is the reason behind most of the great inventions made in history.
Vidar
Quote from: Low-Q on July 10, 2012, 08:13:49 AM
Who cares?
bullshit. i didn't "imply" anything... ::) don't go putting words in my mouth that i didn't say.
me telling seamus that no one cares that he chooses to disagree with whatever he so chooses in no way implies anything about the travis effect... ::) don't be asinine.
what in the wide wide world of sports are you talking about son? i have said no such thing. again, stop putting words in my mouth that i haven't said!
Quote from: WilbyInebriated on July 10, 2012, 09:14:43 AM
OK. I'm sorry.
Vidar
UNBELIEVABLE visit with Wayne Travis, ZED, and team!
All,
Last week, I had the singular pleasure of getting to visit with Wayne Travis, his wife Sandy, and several members of his engineering team at his home and in the ZED workshop. In total, there was a group of about 7-8 "seekers" who signed NDA's and were treated to a tour of the ZED facilities and to a long question-and-answer session with Wayne.
Two initial observations:
1) WAYNE TRAVIS IS HIDING NOTHING! He is bending over backwards to get the word out to EVERYONE on the veracity of the ZED and its underlying principles. He gets the "big picture" and he understands the huge hurdle of gaining acceptance of this paradigm-shifting invention. There are improvements made to his machine that are not explicitly shown in the patent. That is the main reason for the NDA. But, there are no limitations for any individual to replicate this invention.
2) WAYNE TRAVIS IS NOT ATTEMPTING TO DUPE ANYONE! He spent NEARLY THREE HOURS in front of a white board, diagramming portions of the ZED, explaining some of the processes, explaining how things worked, and detailing some of the over-3-years history of the current rev. He is one of the most sincere, forthright, non-duplicitous individuals that I've ever met! He fielded every single question without hesitation.
Unfortunately, it appears that a few posters here have now successfully chased him off, and with him goes the wealth of understanding that he was sharing freely. So, we're trading the one true expert for a couple of individuals whose main expertise is obfuscation. (um, NOT a wise trade)
-Joel D. Sanders
@Webby1. Thanks for your detailed explanations. For the benefit of everyone, could I impose on you to ask something . In your last couple of posts, You refer to a set up with an external water column. I am pretty sure that you previously posted a diagram of the setup you are describing. Could you please post a reply number and page number for this diagram.
@All. We have problems on this thread with naysayers. No one objects to people who are trying to prove to themselves and others that this technology is impossible. But there are such things as respect and decorum. It is a shame to say the least that we have lost mrwayne`s contribution here, at I time when it would have been really valuable. As Forrest Gump said, "That is all I have to say about that."
To all the people who have witnessed Wayne`s machine under NDA. I believe we now have three such witnesses who have posted here. Whilst I find your reports fascinating, it is noticeable to me [and to the naysayers] that you are all new members. Whilst not doubting your integrity, it would be valuable to know how you first heard about this technology. I am assuming that you heard about it elsewhere, and were probably directed here by Wayne and his team. Would any of you care to enlighten us please?
@Neptune -- First let me say thanks to you (and LarryC, Webby1, etc) for helping to keep a sane discourse in the face of said "naysayers".
Heck no, I'm not a new member (2005) (check my profile). I'm just the type of individual who reads, thinks, and doesn't find it necessary to post my few (usually skeptical) opinions on most of the discussions. I rarely consider myself the expert, frequently have not made the effort to replicate, and realize that my two cents is worth about, well, two cents. My educational background is BS Computer Science. I minored in Mathematics and Physics, so I know more than the average non-degreed individual, but much less than the experts and genius-types.
Like many people here, I've been through many overunity highs and lows in the past (i.e. David Hamel, Newman, Searle, DePalma, Bedini, Marks, Bearden's MEG, Steorn/ORBO, etc, etc). I even got sucked in for a while on the Archer thing (God help us).
What struck me differently about the Travis device (ZED) were the videos of the Travis Effect. The effect itself is completely simple, yet completely counter-intuitive. It also is completely replicable by anyone who will take the few minutes to do it. Then, there's the machine that runs with NO INPUT. Does anyone here understand? -- NO INPUT! We're not chasing a fraction of a watt, there is not a string of batteries, there is not a magnet flipping back and forth, there is not some hazy measure of excess heat -- there is simply NO INPUT! How can one not be excited about that?
Then, after following/reading for a couple of days, I see that THE INVENTOR is answering ALL QUESTIONS and invites ALL COMERS to witness the machine. I live in Springfield, MO which is about five hours from Chickasaw. I reason that if the effect and machine are for real, then later generations will look on Wayne Travis the same way we do Newton, Maxwell, Edison, Bell, Tesla, etc, now. Would you not give your right arm to have visited any of those men in their experimenting prime? It was a no-brainer for me. I emailed, he re-invited, and the visit happened.
Neither Wayne Travis, nor any of his associates, asked, suggested, implied, cajoled, or any way influenced me to post about my visit. I simply did it as a way to help balance the sheer stupidity of some of the negative comments that were being posted. I was visiting this forum to gain additional information, but instead was spending my time wading through the ignorance of a negative few who were doing nothing to further my understanding, either favorably or unfavorably.
Any more questions? Please ask. I'm trying to increase what I know. Wayne Travis has given NDA-signers permission to discuss anything about the machine except for the specific improvements. It's in his (and the world's!) interest to get the word out.
Quote from: jdsanders on July 10, 2012, 03:57:13 PM
Could you do any conclusive measurements? Input versus output?
Is the machine working? If it is working, for how long does it run?
Greetings, Conrad
@All,
With much assist from Wayne, please consider the following:
The Travis effect device has four principles working at once to achieve over unity. If you look at just one principle, you will not be able to understand.
(1) The Nonlinear effect due to air compression/expansion requires less weight to make more pressure on the down stroke, and less pressure to make more lift on the up stroke.
(2)The Zed design is more efficient than a hydraulic cylinder as my previous calculations have shown. Partly due to the lack of friction robbing seals in the Zed as opposed to those in the hydraulic cylinder and mostly due to the increased surface area in the layered Zed. More layers, more efficiencies.
(3)The ZED system has production in both directions. First, on the up stroke, the buoyancy force is captured in a hydraulic fluid under pressure, some of which is used to move the water back and forth. Second, on the down stroke, the head production is captured and all of it is used to pay for most of the water transfer.
(Do not overlook the fact that the buoyancy captured, does not consume any of the head used to create the buoyancy)
(4) The inverted pumping system reduces 20% off the operating cost.
Regards, Larry
Username:iflewmyown
Posts:60 (0.042 per day)Age:N/ADate Registered:August 09, 2008, 06:44:26 AM
Have a nice day :)
Quote from: conradelektro on July 10, 2012, 05:35:24 PM
Greetings, Conrad
@conradelektro: No, my visit occurred the day AFTER they isolated the poppet valve leakage problem. During the visit, an engineer/technician was at the control panel working on the machine. I believe he was successively pressure-testing the different portions of the machine to check for additional leaks. So, I did not witness the machine running, nor was I able to request or observe any meaningful measurements. -Joel
To Neptune,
I learned of the ZED from PESN.com a few months ago, while checking out information on LENR, which I have only been seriously following since Rossi's announcement last Fall. I'm only 3 hours from Chickasha and Wayne was very open to receive visitors.
Yes I am new to this forum. The evening I got back from checking out the ZED I came across this forum from a link posted on a site discussing the Rossi's E-Cat. Coincidence? Probably, but browsing the posts, I thought an eye witness post would be helpful. Wayne Travis never asked anything of us. He barely even mentioned his detractors and I think only because someone brought it up. Like I said, I didn't even know this site existed until after I visited with Wayne.
My background is Computer Science, Math, Physics & Chemistry. I get the skepticism. It shouldn't work, but it sure looks like it does. I will probably spend the next few weeks playing with cups and lead weights in the sink.
Wayne Travis should be commended for his openness and willingness to share his discovery.
@Seamus101
It doesn't help to argue against believers - regardless of what they believe in (It doesn't have to be OU machines) ;-) I have tried. Believe me - it doesn't work... The only thing that works for changing peoples mind is a bullet, but it isn't allowed. The best thing is to look away, accept that other people thinks different, and have another view on things. Whish I had the patience to let people believe in what they want :)
However, being unconserned of the "impossible" (like many in here are - myself included) is important for learning, important for inventing something - even if the final product isn't what you first thought out. Maybe not OU, but at least something useful anyways. Remember that most of us, if not all, are still in our childhood in physics. We mostly do not see the whole picture, and cannot predict the real outcome other than what ones mind has made up - until one have had hands on experience with the invention. Then you scratch your head for a while, and ask yourself why it doesn't work as intended. Then learn something, and moves on :)
Vidar
Quote from: theotherguy on July 08, 2012, 08:58:37 PM
To All,
I visited Wayne Travis last week. I found him and his machine very credible. He was very open with the principle and the design of his machine. You can tell this is something he has put a lot of effort into and is very passionate. He has a small staff working with him and they are well beyond whether the machine works or not.
@ theotherguy
It is so trivial, that it is almost childish to ask it again. But it seems that the discussion always goes away from the essential.
The essential question in connection with any OU machine is how much energy is put in and how much energy comes out of the machine. And in order to answer this essential question one absolutely needs a working machine and one needs to do measurements to establish input and output. The measurements are best done by independent persons with the necessary technical knowledge.
So, did you see a working machine and did you do measurements?You claim a highly technical background (Computer Science, Math, Physics & Chemistry). Well, this background should enable you to answer technical questions like "how much energy was put in and how much energy came out of the machine"?
It is obvious that you did not see a working machine and that you could not do any measurements (a mentally sane person would have told in case this had happened).
So, what did you witness and why do you think it is a credible OU machine (without any measurements and without closely examining a working machine)?
I am not attacking you or Mr. Wayne, but we have to stay on the technical level in order to make any sense. OU is a very bold claim which needs clear and concise proof. And the burden of proof lays on the shoulders of the person who claims to have a OU machine.
So far, all self proclaimed witnesses in this forum have stated that Mr. Wayne is a nice person, but none has seen a working machine and most important none has witnessed or done any conclusive measurements. Therefore, on the technical level, no proof has materialised.
Greetings, Conrad
It should really come as no surprise to anyone, that most of the witnesses have come away with no scientific proof. The first step in real proof will come from Mark Dansie, who incidentally has seen the machine working .Wayne has said that Mark will not be called back until he can guarantee the reliability of the machine 100%. Mark is well known for his sceptical views, and remember that Mark was invited to see this machine. Had the other witnesses seen the machine working, it would have proved little. Incidentally it amuses me that people want to see measurements of input and output. How do you measure the input of a machine that uses no external input? Even exact measurement of the output is not that vital. With no input, if we can show an output, however small, then we have overunity. Like it or not, we are still in a waiting game.
I would say that Marks results will convince most rational people. And his tests are to be followed by still more rigorous tests. But even after these tests, there will still be people writing mathematical proofs of its impossibility. Exactly like the DDWFTTW machine.
@All,
Simple Non-Linear explanation attached. Enjoy the understanding. Bright green for free green energy. Keep in mind this is only one ZED, think of the possibilities with 2 and water transfer.
Thanks to Michel for a better looking presentation.
Edit: Changed descriptions for better clarity.
Regards, Larry
Quote from: neptune on July 11, 2012, 11:41:38 AM
@Neptune
May be I can add to your amusement by pointing out that
"setting up the machine" is an "input".
As far as I understand, the machine has to be pressurized. This clearly is an "input of energy" (equivalent to winding up a mechanical clock).
Even, if one only has to pump water a few meters up, it would be an "input". A great amount of water sitting in a container a few meters above ground has a lot of energy which can be released by having the water run through a turbine situated below the container. The energy is put in when filling the container.
The first thing to do is a rough estimate of the energy required "to set the machine up into a working state". The output should then of course be much higher than this "initial input".
If "setting the machine up" involves creating high pressure within the machine, the first thought coming to mind is that the machine slowly "winds down this pressure". Which could take a lot of time, e.g. days, in case only a small load is driven.
You will be even more amused, because
there clearly is continuous input: valves are switched, sensors are read and a controller (microprocessor) is running, which consumes electricity. This has to be taken into consideration, because the machine will not function without this input.
But besides the "initial input" and the continuous "control input",
there might still be further input which we do not know at the moment. The functioning of this machine would be better explained if this "unknown input" could be identified. Simply stating that there is no input is as bold as claiming OU and therefore equally controversial. It would need additional irrefutable proof (and can not serve as an explanation of the machine).
Greetings, Conrad
Hi Conrad. Firstly, I am not privileged to any more information than you are. I only know what has been disclosed, and pending information to the contrary, I am prepared , for the time being to take that on trust. I agree that setting up the machine requires an input in the form of an injection of compressed air or water. But that is a once only input, and after the machine has stopped, that input can be recovered. So that is , if you like , a "loan" rather than a debt.
Setting up the machine does not involve a "high pressure". I do not have the maximum pressure to hand, but I am certain that it never even reaches 10 pounds/sq inch. I believe that the output of this demonstration machine is 500 Watts, not that small in my opinion. Yes I am moderately amused to learn that all the valves, sensors etc , are provided with electrical input. I am of course less amused to learn that these are powered by the alternator driven by the hydraulic motor at the output .
You say, and I agree, that there may be a further input that we do not know about. If that is the case, then Mark Dansie will tell us all about it.No such input is shown on the patent, which we are told gives us all the info needed for replication.
So based on what we are told, there is no external input .
Yours, Well Amused, Ken.
All,
This thread started with an Inventor of a supposed OU device coming to OU.com (of all places) to explain the workings of his invention. The patent for his device was located, the contents of which were also being explained by the Inventor. For a while there was a mostly respectful dialog with the Inventor as he continued to openly answer questions and try to explain to several forum members who were trying to figure out how his device could work, why, where the energy could come from, etc.
This thread has been overtaken by several who continue to argue about the impossibility of the supposed OU device based on principles. And while that is fine in and of itself, it has become a constant detraction from the actual study of the patent and device, whether it was intended or not.
So I ask that those that want to argue why or why not a device based on the principles of buoyancy can be OU please start a thread for that purpose. Let those who wish to discuss the device disclosed by the Inventor at the beginning of this thread and in the later disclosed patent please continue to do so without your constant interuptions.
The interuptions have already driven off (for the moment) from the OU.com forum the best source for answering questions about the physical device described at the start of this thread and in the patent. That should be considered regretable to all.
If you would like to show how this device cannot work, please stay. But please show your analysis of the specific construction disclosed in the patent or the other models that are being analyzed.
Respectfully,
Mondrasek
@All,
My earlier statement:
'(1) The Nonlinear effect due to air compression/expansion requires less weight to make more pressure on the down stroke, and less pressure to make more lift on the up stroke.'
Understanding this concept is another important step in understanding the OU in the Travis system.
The first attachment shows the Zed at 4.8 PSI and at 8 PSI to help prove why the increase in lift is Non-linear.
The height values are all relative and the lift values are based on the height of water on the pod and the difference in height of water between two adjacent water columns.
They show that at 4.8 PSI there is 33.5 units of lift value, and at 8 PSI there is 130 units of lift value. So the lift value of 130 units is 3.88 times greater than 33.5. The PSI of 8 is only 1.67 times greater than the 4.8 PSI. This non-linear increase of 3.88 output at 1.67 input is due to the compression of air as the water head aligned. Note that there is also less air in the channels between PSI 4.8 and 8.
The second attachments is showing the 'Non Linear Zed advantage over Hydraulic cylinder' again.
I would appreciate a PM from anyone who is not understanding and where my explaination can be improved.
Regards, Larry
It should not be a suprise that energy cannot be created, or be destroyed. So if the machine has energy output, it must be a potential energy difference between input and output to do so. That would probably mean that the input energy is negative. To achieve negative energy one of the elements, force or distance, have to be negative. How do we measure negative distance, or negative force? Both distance and force has to be 0 or more. So basicly, the energy input cannot be measured, because it must be negative - or at least a source of energy that has no origin, and at the same time is constantly decreasing. - still not possible to measure.
Vidar
I finally finished the analysis of my ZED model design from a full lift of 80% capacity (12 of 15lbs) down exactly .5 inches which in my 12 inch tall system coorelates to the 3 inch stroke Mr. Wayne is using in his 6 foot systems. I was analyzing every 1 in^3 of water removed from the Pod chamber starting with a neutral buoyancy condition. This gave me 8 equally spaced data points (last one is a little less than evenly spaced). With this done I started really searching for the nonlinear relationships that have come up in discusions lately. And I think I found something very interesting.
I've posted the picture below before. At the time I thought the Changing Buoyancy Ratios were interesting. But take a closer look at the witness lines drawn on the top and bottom of the outermost water column. The ZED is lowering from left to right. But the water head of the Outer Riser is increasing from left to right. So the air pressure inside the Outer Riser is increasing from left to right.
So while the Pod chamber water pressure decreases, the air pressure in the Outer Pod is increasing. I believe this is very significant and may be the nonlinear relationship being discussed?
Actually I find the relationship pretty linear (since I am not adjusting air volume for changes in pressure). Its just that the slope of that graph is opposite what one would expect. Wow.
M.
@All,
New changes based on some comments PM'ed to me. First, I removed the extra hardware in the center of the POD. Wayne had said the POD can be solid, so this will reduce the confusion. Second the water wasn't balanced between the 4.8 and 8.0 cycle, so it is corrected on the right side only of 4.8. The good news is that someone else has understood why it is nonlinear.
The following is as posted earlier, with updates:
The first attachment shows the Zed at 4.8 PSI and at 8 PSI to help prove why the increase in lift is Nonlinear.
They show that at 4.8 PSI there is 42 units of lift value, and at 8 PSI there is 128 units of lift value. So the lift value of 128 units is 3.05 times greater than 42. The PSI of 8 is only 1.67 times greater than the 4.8 PSI. This nonlinear increase of 3.05 output at 1.67 input is due to the compression of air as the water head aligned. Note that there is also less air in the channels between PSI 4.8 and 8.
I would appreciate a PM from anyone who is not understanding and where my explanation can be improved.
Regards, Larry
Edit: Corrections to 8.0 numbers.
Post Deleted.
According to the information posted on his website, one of Mrwayne`s tasks in the current week, was to schedule the next stage of verification. I am assuming that he probably means arranging the next visit from Mark Dansie. Judging by the way things have been done in the past, his next website update will be on Monday, when he will probably tell us more. If Marks verdict is positive, and I believe it will be unless there are teething problems, the next stage will be verification by the Big Guns on behalf of potential investors.
There are several very promising technologies in the frame at the moment, and personally, I think that in the future as in the past we shall see several competing technologies running side by side. There will probably be no one-size-fits-all answer. Experience will tell what is the most cost-effective size for ZED machines. The answer could be a machine suitable to serve all the homes in one or two streets. This would be handy, as the sites of electricity substations could be reallocated as generator sites when the National Grid becomes redundant. When that happens, the scrap merchants are going to have a field day. We can recycle the pylons as a source of steel to build ZEDs. We live in exiting times, and things may move faster than you thought possible.
Quote from: neptune on July 14, 2012, 09:12:46 AM
Poignant ambiguity created by the mere (accidental or deliberate) omission of that little "c" in "exiting".
The following interesting nonlinear example came up in PM's with others trying to understand and help.
One nonlinear unit is a car air shock absorber, as its resistance to compression increases as applied force gets higher.
Now, if you had a small Travis model on your desk, that is set at a PSI (50% of max) which will lift 25 pounds and it has a 20 pound weight on top and had risen an inch to a stop. Now with your hand apply forces varying from >o to 10 pounds. It will respond similar to a spring as the internal air will be compressing/decompressing and the water column lowering/rising in response to the air volume changes due to the external pressure changes.
Then compare that to a hydraulic system doing the same test. No movement.
Correction: Thanks M.
Regards, Larry
Anybody up for a Beta test?
The below attachment is from my water height calculator and the spreadsheet is below.
Note how the New water levels have a increasing downward slope from outside to inside.
The logic used is to first lower the water level in the Outside Container by the entered value, then raise the water level in the adjacent channel. The new difference in water levels causes the PSI in the adjacent air channel to lower. The lowered pressure is used to calculate the expansion of the air. That expanded value is used to determine how much to lower the next water channel and raise the water in the adjacent channel. Then use the accumulated PSI to calculate the expansion of the air. So on and so on until the pod water level is lowered.
Basically, the outside water drop is forcing all the inner channel to respond accordingly.
This logic is much simpler, then changing the POD level and calculating outward. To do it correctly, it would require recursive iteration calculations forward and backward on the previous channels. As each channel change require changes to all previous channels which again changes the current channel, and round and round you go until it settles.
Regards, Larry
@LarryC. re your penultimate post .I see what you are saying regarding the loaded ZED having spring like qualities. Are you just drawing our attention to this as a sort of curiosity? It would have relevance in the complete machine. The ZED is used to compress a hydraulic ram which in turn is used to pump oil into a hydraulic accumulator. The amount of pressure needed to compress that ram increases from the start of the stroke to the end of the stroke, as pressure rises in the accumulator. The effort required is non linear. So if the water being forced into the zed is fed in at a constant rate, this "springiness" of the ZED might be of benefit. This springiness might be useful if two ZEDS were used to operate a crankshaft by connecting rods. It would help to get you through top and bottom dead centres.
If you had a hydraulic system consisting of a pump and a ram lifting a load, there would be no springiness in the system as you say. You could introduce springiness by having an air pocket inside the top of the ram. But it would be of no advantage, indeed, quite the opposite. So TBH I am not really sure why you are drawing our attention to this springiness.
Regards, Ken.
I'm following as closely as I can but not yet doing calcs of my own... I have no desire to reinvent the wheel. My position, as I've stated before, is that any overunity behaviour must defy conventional analysis in this system, and that IF calcs indicate OU behaviour there must be something wrong in the calcs. I am still taking MrWayne at his word that there is no input and no exhaust and the machine keeps running until it breaks or is deliberately stopped, producing useful power while running itself. That is, I am suspending disbelief for the moment, even though my training and education and experience tells me that it is impossible for it to be true.
So... at this point I have a question for larryc and mondrasek and the other spreadsheet modelers. I know that the mass of the water is in your calcs, else how could you compute the forces exerted by the water head heights. But is the mass of the cylinders themselves included in your calculations?
I just want to point out that many rotary PM designs would work, turning forever, if only just some single small factor were altered or removed, like bearing or seal friction or the mass of a swinging arm... or hydraulic cylinder. Or even viscous drag.
The "moral" being that if your calcs show OU behaviour, especially if it is small wrt the total energy flows in the system.... then the first thing you should suspect is that you have omitted something from your calcs somehow, not that you are about to save the world from the Tyranny of Big Oil.
Hi TK.
My analysis has started with a small, three layer model (6 in OD x 12 in tall) of a single ZED.
I began by calculating the entire lifting force due to bouyancy, ie. the "ideal." This was about 15 lbf. Initialy I was only looking at the counter force being the weight of the acrylic materials.
Based on info from Mr. Travis I then adjusted my calculations to add additional weight to the Outer Riser for the "floating members" of the model to have a mass of approximately 1/3 or that ideal, or ~5 lbs.
I then calculated what outer ring water level would be necessary for the above described set up to be only neutral bouyant. This required that the water level in the outer ring be lowered just a bit.
The next step was to load the system to ~80% of "ideal" lift capacity. So I added weight to the Outer Riser so that the entire Pod/Riser arrangement weighed about 12lbs.
Next began the removal of water from the "ideal" completely stroked up system until the neutral bouyancy condition for the now 12 lb weighted system was found.
Once neutral bouyancy was established I began an iteraitve search for how much the Pod/Risers would drop if 1in^3 of water was removed from the Pod chamber. I repeated this exercise for every -1in^3 until the Pod/Riser system had dropped .5 inches, as this cooresponds to what Wayne has said is currently the condition of his test system (though he acknowledges that the stroke of his current test system is limited by the volume capacity of the Firestone cylinders he has in use in his mass transfer pump system).
Please let me know if I can help with any other details.
M.
BTW, I used ACAD quite a bit to determine dimensions so the spread sheet does not have all those intermediate steps and calculations. I am happy to elaborate it it will help anyone.
Graphical representation attached.
M.
Quote from: neptune on July 14, 2012, 04:21:15 PM
Regards, Ken.
Just pointing out that a standalone ZED has similar non-linear characteristics to an auto air shock.
M's comment about air shock reaction: 'Push on the cylinder rod with one unit of force and it will collapse one unit of distance. But push on the cylinder rod with two units of force and it will NOT collapse two units of distance: it will collapse less. And considerably less for the third unit of force. So, nonlinear.'
Regards, Larry
Quote from: LarryC on July 14, 2012, 07:49:58 PM
Just to clarify, my comments about an air shock were that they ARE linear. So if you push on the cylinder rod of an air shock with one unit of force it will collapse one unit of distance. Push on the cylinder rod with two units of force and it will collapse two units of distance. And push on the cylinder rod with three units of force and it will collapse three units of distance.
With the ZED it is nonlinear so: 'Push on the cylinder rod with one unit of force and it will collapse one unit of distance. But push on the cylinder rod with two units of force and it will NOT collapse two units of distance: it will collapse less. And considerably less for the third unit of force. So, nonlinear.'
M.
I will admit I am not familiar with air shocks. In the past I worked on oil shocks, but that`s different. As I see it there are probably two types of air shocks. Type one would be like a bicycle pump with the outlet hole blocked up. So this would be non linear, you are simply compressing air progressively. A similar technology is used for the suspension of semi-trailers on tractor-trailer rigs. This consists of air bags, just like Wayn`s Firestone bellows. Here they act as just a spring, a separate oil type shock absorber being used.
The only type of air shock that I could envisage that would have a linear response, would work on the same principle to an oil shock . Here, air would be forced by a piston from one chamber to another through a small hole . A separate spring would be needed.
Actually, I have just remembered a type of linear air shock that I came across. These are used on some front loading washing machines. The drum assembly hangs on two springs, and has air shocks at the bottom. These are like a bicycle pump with a closed outlet. The piston [ which does not incorporate a valve like a bike pump] is deliberately made to be a leaky fit in the cylinder. So it is linear, and more effective at higher frequencies of vibration.
Quote from: mondrasek on July 14, 2012, 09:12:09 PM
The above is not correct. An air shock force vs. displacement is NOT linear. Sorry if I confused anyone.
M.
Please see the attached spreadsheet. It shows the main reason that the Travis system has less lift force than the Hydraulic Cylinder at 4.8 PSI.
On the right, note the Total force of the Travis system of 3777 (bright green) after the system in lowered to 4.8 PSI by lowering the water level. It is greater than the hydraulic cylinder of 3678.
On the left, it shows the Total force of the Travis system of 2630. This is due to the fact that the water around the pod has been lowered so that it cannot support it own weight and sinks to the bottom. Compressed air has been pumped in to maintain the original PSI on the layers. Only the risers are now applying the lift.
I hope this helps clear up as to why the Zed works as shown in the attached 'Non Linear ZED advantage over Hydraulic Cylinder'.
Thanks to Wayne for clearing this up.
Edit: 'Compressed air has been pumped in to maintain the original PSI on the
layers' missing statement was added.
Regards, Larry
@All who is downloading the Travis water height calculator. Sorry, but a save error has occurred and my changes wasn't saved. I'll correct and post later when I figure out what happen. Thanks for the patience.
Regards, Larry
Things have gone very quiet. The last I heard, on Wayne`s website, he planned to call in Mark Dansie. Anyone heard any news from anywhere?
they are planning to do long term running this week, will keep you informed.
Mark
Hi Mark, and many thanks for the update. At the risk of repeating myself, it is obvious that Wayne`s team have to have everything perfect before your tests begin.There is, after all so much at stake. This technology , in terms of the future of mankind, is of far greater importance than putting a man on the moon. Not only is there the prospect of cheaper , cleaner energy, but if this pans out, we can never look at physics in the same way again. I trust that, in as much as you are able, you will keep us up to date.
@mondrasek: thanks for the answer and the graphics. You are working hard on this, I can tell. I hope you are getting enough sleep!
I see then that you are considering the moving masses of the cylinders themselves, and your iterative process seems to be zeroing in on the maximum "break even" masses: if the cylinders are too heavy, the system won't work. And apparently also if they are too light it won't work, because the added lifted mass (A "bias" mass?) is just effectively making that cylinder heavier, since the mass itself is constant.
I still haven't had the time to go over the spreadsheets in detail. I am trusting the accuracy of the modellers and accepting the numbers provisionally but I still feel that somewhere there is something that's not getting into the accounting.
This last little RED statement worries me, pulls me up short. Have I missed something?
Compressed air must be pumped in? From where? What does the pumping, how much compression, etc. and is this pumped in compressed air accounted for when we have been told that, except for the precharge, nothing is added or exhausted during operation?
(Linear, nonlinear? These terms are used ambiguously. Sometimes it appears that "linear" is used in the sense of the order of the equation: linear, quadratic, cubic, quartic, etc. all of which have different shaped "lines" on a graph of the function. And anything that is not first-order (straight line) is considered non-linear, even if it is still a smooth, easily predicted graph like the second order, quadratic function. Stretchy springs or compressed air cylinders are examples that are smooth functions but not necessarily straight line functions... especially if the way the volume changes as the air is compressed is itself NONLINEAR....... imagine a tapered cylinder with a conforming piston..... hint hint....
Other times it seems to mean "non-differentiable", that is, the function cannot be described by a _smooth_ line, or it has holes or kinks in it.. discontinuities or cusps, places where the function's first derivative vanishes or is undefined. Bend a pencil and you get a linear stress-strain relationship right up until it breaks-- becomes non-linear, the derivative vanishes and the behaviour can't be described by a simple function whose solution is a smooth curve ( a straight line is the ultimate "smooth curve".))
@TK, lol yes I am able to sleep with this one! It's not my baby to birth.
Re: Compressed air. The addition of compressed air is part of the assembly process of the ZEDs. It is how you get the water and air into the proper locations within the system. To begin assembly you start with no Pod or Risers installed. You have only the main tank and it's internal walls that are all sealed and attached to the bottom. You need to fill that tank until the water covers all those internal walls. Then you install the Pod. Next you install the smallest riser. But to do so you must have a vent in the top to allow for the air inside to escape. Once this riser is full submerged you seal that vent. The next larger riser is then installed, also allowing the air inside to vent. Rinse and repeat until all risers are installed, all trapped air is vented, and all vents are sealed. Note that at this point the only air in the system is the air inside the sealed Pod. The Pod may also have been slightly pressurized to help neutralize the minimal water pressure it will face.
Of course, the Pod and Risers need to be held down in the water at this point as well as when the compressed air is introduced.
The compressed air is then added from below the Pod in the center chamber of the ZED. It is compressed only enough to overcome the pressure due to the weight of the water in the system, nothing more. This air will bubble up around the Pod and begin filling the gap between the Pod chamber wall and the inside of the inner most riser. It forces the water in this area down, thus increasing the water level in the outer most chamber and driving up the overall pressure in the system due to that water height. So the compressed air pressure to overcome is also increasing in order to continue pumping.
Once the air has driven all the water out of this gap between the Pod chamber wall and inner most riser it will begin bubbling up again through the water between the outside of the Inner Riser and the wall directly outside the Pod chamber wall (middle wall). Once again the air begins to fill and drive the water down and out of the gap between the middle wall and the inside of the Outer Riser. Again, this drives up the level of the water in the outer most chamber and increases the pressure in the entire system. So the compressed air pressure is still rising to over come the ever increasing water head pressure. However, the compressed air is still relatively low pressure. Wayne is saying it is only about 8 psi gage in his 6 foot tall system. In my little model it is only .917 psi gage.
The system is "full" of the correct amount of air when you see air bubbles start to rise in the outer most chamber. The ZED will now have water and air in the comfiguration shown in my illustrations as "Full."
As far as the nonlinear stuff goes, I am not 100% sure how Wayne means this and look forward to his explanation. I have found some relationships that might not graph as a straight line, but I'm not sure if it is exactly what he means. The most interesting is that when the water is allowed to flow out from the ZED Pod chamber in the "Full" condition, the water pressure begins to drop and therefore the air in the chambers begins to expand. So the Pod/Risers do not drop as much as I have shown in my illustrations so far (those ignored air volume increases). The expanding air increases the buoyancy and the pressure of the water flowing out of the Pod Chamber. Calculating for data points under these conditions is an iterative nightmare for me, so I cannot tell it yet if is nonlinear or simply linear with a different slope.
The way this thing moves and the air and water levels adjust is fascinating! I can only now begin to visualize what is going on inside after a LOT of calculations and illustrations. I can only imagine Wayne learned as much about his system as he experimented and tested. To think that anyone could come up with all this straight away is more than I can (yet) attribute to any person of less than savant status.
M.
Quote from: TinselKoala on July 19, 2012, 09:08:23 AM
I don't know how much you had in Red, but I'll try to answer this part for now as I am working on a new example now which will show more.
That is from an example of how to get the POD to sink at 4.8 to reduce the total lift to approx. 2500 LB. It could have been done at other PSI's (8.8,7.etc.) without blowing the skirt, but it is easier to understand at 4.8. The water is lowered, POD sinks, and the original PSI on the layers is now lower then what is was originally at the total 4.8 PSI. This also lowered the lift much below 2500. So compressed air is added from below the POD to bring up the PSI on the layers to the original value. It would only need to be
done once as part of setup, and remains during operations. Then to bring the system back to 8.8, on the layers, water is added under the pod to fill the small POD/Retainer Gap (~ 9.5 SI). The POD would have a similar lift as it had at the initial 4.8 before water drop, not a problem, as it is mainly used to rise with the system to maintain the Head levels on the layers.
I don't have an NDA, so my examples are based on a lot of shared facts from Wayne and part logically deduction on my part. So it is not how the actual system works, but it could work in a replication. My goal is to keep the examples simple for everybody to understand and anybody is wellcome to check my spreadsheets. I'll be glad to make corrections.
Regards, Larry
@Mondrasek. Thanks for that clear description of the "set up " procedure . Referring to your first paragraph, you talk about adding the risers one by one and venting the air. Here is a different way to do it that I think would work, and would eliminate the need for vents.
Just fit the pod and all the risers, and then mechanically restrain the risers from rising. Now pump water into the central chamber, until it pours out of the outer gap. I am not sure if this would totally purge all air from the system. If it would not , then in the case of a smallish model, we could pump water in at a high rate, and whilst holding the model over a sink , constantly invert it and return it to upright . Would this work? If any air remains in the upper part of the chambers, as long as its a small amount it would not matter, as we are going to add air anyway. What do you think?
@neptune, I believe your method of starting with a dry assembly and then adding water from the bottom of the Pod section would work fine. And there is no need to try and purge all the air out of the system at all. Any air that remains is exactly where you want the air to be. I think some additional air would still need to be added after the water, but just not as much now.
M.
I am pleased to hear that my simplified set up stands a good chance of working . This is really good news for model builders. Elimination of riser vents is no trivial thing, as it saves building time and gets rid of hidden leak points that would be hard to detect .
I just had an idea. Think of Wayne`s original hose pipe analogy. Take a length of clear plastic pipe. Attach it to a back board that has horizontal lines marked on it, say at 1 or 2 mm intervals. Arrange the pipe in a sine wave shape having an amplitude of say 250 mm, and a wavelength as short as possible. Mount it on the wall. If we use a syringe, and a long thin pipe pushed into the main pipe we can fill all the lower parts of the sine waves with water and the upper parts with air. As we pressurise the main pipe with air [or water?] from one end . we can see exactly how the water columns react with the air pockets, and how the air contracts and expands under pressure. This would be a useful teaching and self teaching aid, and would enable us to get a glimpse of what happens inside a ZED. The one thing it won`t do is simulate the rise and fall of the risers.
The first attached picture is showing just part of the spreadsheet, to see the entire spreadsheet you need to download the Travis Effect System Setup.xls below. Anyone that doesn't have Microsoft Office can download the free OpenOffice program from the internet to view the spreadsheets.
The second attached picture is of the spreadsheet that was used to generate most of the data for the first attachment. It is also included below.
Repeat of my previous statement: I don't have an NDA, so my examples are based on a lot of shared facts from Wayne and part logically deduction on my part. So it is not how the actual system works, but it could work in a replication. My goal is to keep the examples simple for everybody to understand and anybody is wellcome to check my spreadsheets. I'll be glad to make corrections.
Regards, Larry
Wayne has stated that a 1" rise in the Pod water results in a 2" increase in the water head of each layer.
The attached picture shows how the height changes in each water channel. First, water is added to the Pod retainer, then air pressure causes the water in the next channel to lower, which causes the water in the next channel to rise. So the difference between the last two water channel in now twice what was added to the Pod area.
I'm sure some allready understand, but it important that most understand, as my next example is based on this concept. The next example will show the great difference in Input volume and obvious time of input as the number of Layers increase.
Regards Larry
I'm very late to this thread.
I will be very surprised if Mr Wayne can can make a self sustaining engine, with no additional input of energy once it is started - I do wish him luck in proving his hypothesis - if he can do that it would be game changing - like others I will watch with interest the final analysis of all data.
I read the first 20 or so pages of this thread & then the last few to be current - I watched the Travis 1 & 2 video's.
What I saw I thought was not inconsistent with Archimedes principle.
Archimedes says that the upthrust force of buoyancy of an object is equal to the weight force of water displaced less the weight force of the mass doing the displacement, IINM.
The Work Energy Equivalence Principle says Work in Joules [ force x distance] is interchangeable with energy [PE + KE].
It says that if PE is raised then the PE gained is equal to the Work Done to achieve that gain, not adjusted for system losses - this applies equally to forcibly sinking a floatation device.
So what was different about the Travis effect ?
Well, buoyancy is well known - if the displacement volume doesn't change then the buoyancy force will raise an object a distance vertically - it takes the same energy [Work Done] to sink the object to a release height as the Work Done capability of the buoyancy force can do on an object rising the same height - zero sum energy game.
In the Travis video's the upthrust force is the same 'initially' as the ordinary buoyancy control - there is no doubt that this takes considerably less volume or air that the standard control - the difference IMO is that the Travis effect example cannot do as much Work i.e. f x d, IINM.
IOW's, & has already be identified, the control buoyancy test has an upthrust force that doesn't change as the object rises in the fluid - this is because the pressure differential top & bottom is maintained & is proportional to the height of the air gap [volume] - since water pressure is linear then that upthrust force remains constant as it moves up thru pressure levels - this is a constant force x distance = WD.
In the case of the Travis effect experiments, although the same upthrust force is created initially [because the effective air gap distance & pressure differential is the same], as the object rises it leaves behind the concrete block & the air gap depth reduces dramatically - this reduces the pressure differential between top & bottom of water & the upthrust force reduces rapidly accordingly - this lesser buoyancy force has less capability to do Work i.e. variable force x distance.
In many ways, this is a variation [the reverse application] of the "hydrostatic paradox" IMO.
I would be surprised if there is enough energy to cyclically transfer the required volume of water from cylinder to cylinder & have excess energy left to do external work.
Then I guess that's why competent people like Mr Wayne appears to be do experiments & have them independently validated.
If it can self sustain & do any measure of external work then the hunt will be on for the energy source - good luck to him.
Quote from: fletcher on July 20, 2012, 06:43:28 PM
Very late indeed! Welcome @fletcher. Did New Zealand just get the Internet? Or are you somewhere else now?
What if the object never "leaves behind" the concrete block as you mention? What if the concrete block is replaced by the Pod member that is also allowed to rise as it is also buoyant in a separate annulus of water?
M.
Quote from: LarryC on July 20, 2012, 06:24:48 PM
Regards Larry
Hello Larry,
That quote was a general statement - not intended as a control number - Please let me be a little more clear, and forgive me of the statement.
The exact movement of each layer in relationship to the pod is related to both the clearance and pressure between each additional layer
So you must consider if you matched the volumetric clearances - or if you adjusted the volume metric clearances for the pressure.
(This example is of equal clearnaces - not matched volumes - not the best method - but what is in our data model)
Now since we push down - to cause an upward movement of the next layer - the differential pressure is increased at twice the rate as the volume - directly in the first inner layer and while the next layer is (under lower pressure) is pushed down - and the differential changes twice the downward movement, and so on.
In our Little model (5.0 to 8psi) - a 1 inch push in the pod is against all three layers - this results in a .68 downward push - or 1.36 inch differential in the first (inner) layer.
The Next layer pushes down .40 with a .80 differential and the next layer pushes down with .28 with a differential of .56 (corrected)
SO - 1 Inch in the pod results in a differential change of:
Pod - 1 (this movement is direct)
Layer 1.36
Layer .80
Layer .56 (Corrected)
Total 3.72 inch differential (corrected)
This value changes with layers - higher pressure means more differential between layers. (Partially -where the Non Linear comes from).
p.s. We have our Data collection Model are up and running - free energy.
Mark says to ignore the Baiters -
Mark has now given our crew some homework and a few simplafiying steps to take and changes to make - I will let you know how things go.
Wayne
Quote from: Seamus101 on July 21, 2012, 09:27:56 AM
I remember getting an acceptable internet connection in NZ back in 1996, so more than enough time to become familiar with the medium. I don't think being in NZ is a significant disadvantage for ferreting out bullshit when it is presented as fact actually...
What if the object never 'leaves behind the block' you ask. It's a fair enough question. What you need to answer though is what provides the energy to 'raise the block' so that the pod can continue to push upwards. Perhaps the fairies that would provide the necessary impetus just haven't made it this far south yet
@Seamus101
1) I was addressing Fletcher.
2) My comments about Internet access in NZ were intended as a joke. Fletcher would get that.
3) The Pod is in a separate annulus of water and rises for the same reason that the Riser does: Buoyancy. No fairies need be involved.
4) We understand that you do not believe the ZED system can operate as explained. Repeatedly stating that fact adds nothing towards understanding the Invention that was presented at the beginning of this thread. It only aids in interupting. You have been asked to take discussions that do not pertain to understanding the Invention that was presented at the beginning of this thread elsewhere. Regretfully, I ask again.
M.
Quote3) The Pod is in a separate annulus of water and rises for the same reason that the Riser does: Buoyancy. No fairies need be involved.
Indeed. But then you need the fairies to push the pod back down for the next cycle, don't you?
Quote from: mondrasek on July 21, 2012, 10:37:52 AM
@Seamus101
M.
Hello Monderask, and Stefan,
In the Z.E.D. Lab - We have overcome the troubles that delayed us and are moving forward.
To that point:
As you know - several people "posing as intelligent, protectors of their belief" continue to interupt with uniformed opinions, statements and slander -
Since they demonstrate the inability to do their due diligence and lack the ability to self moderate - I ask that you address this as moderator.
I have been very generous here on your site.
I will not waste this precious time "watching or participate" as those Baiters try to suppress the discussion.
As you have noticed - when the attack on me failed - they started attacking the rest of the group.
To the final point -
There are several very good forums currently discussing the Zed Technology intellectually and the impact - I am not participating in those forums - yet.
They do not tolerate "Baiters" seeking attention.
Baiters never show proof - and never apologize for bad behaviour, mistakes, or ignorance -and they have to have the last word even it is just an insult.
Several of the Baiter created new user names - you can look into the histroy and see that they only post here - on this one link. Others are known as loud mouths in your community forums - not adding to the discussion - just proping themself up - until they are taken down and resurface.
The Baiters only serve themself at your "Stefans" expense - you are loosing me.
Stefan, please decide if you want the Inventor of our FE device to answer questions and share - or not.
Wayne Travis
Quote from: mrwayne on July 21, 2012, 07:46:37 AM
Hello Larry,
The Next layer pushes down .40 with a .80 differential and the next layer pushes down with .28 with a differential of .52
Layer 1.36
Layer .80
Layer .40
Total 3.56 differential
Wayne
Thanks Wayne,
Additional information from you always helps. In my next example, I was going to add air compression and how it has a combined effect the more layers you have. With my previous example I just wanted to make sure everyone understood the basics, before my next example to show the difference in Input volume and obvious time of input as the number of Layers increase.
In your little model, what is the Pod Height, Pod Diameter, Material thickness, Clearance?
The attached water height calculator based on Outside retainer water drop used 71,30,.25,.20. It used .28 for the drop as I was confused about your .28 diff is .52, not .56, then the .40 on the total differential.
The water input is set to ideal, so that would be part of the small difference if you are starting from Initial Pre-charge. In playing with this calculator, I noted that it can get the same total differential with different water layer values as long as you balance it properly. The calculator used volumes based on each air/water gap square inches and calculates from outer water to inner, which forces the water/air column's to align based on the previous channel air expansion/compression.
I wasn't sure about releasing this one again , since I corrected it, as it is quite confusing. It shows a lot of extra calculations that could have been part of the formula's, but it helped me to better understand the parts that make up the whole.
The calculator xls is attached last.
Edit: Added new fields to calculator and changes to the xls file.
Regards, Larry
Wayne:
Mondrasek gave an answer, but it was only half an answer. Hence the comment. I asked you a while back what the output from your device was and how you measured it and you were unable to answer that question. How is that possible?
And yet again you play the "wounded butterfly" and pout. People have legitimate concerns about your whole proposition and that's life for you. Be a man and don't call 911 like somebody took your parking spot. You know nowadays they arrest people for making bogus 911 calls.
I won't be surprised if you implode and disappear after your "real demo."
Quote from: MileHigh on July 21, 2012, 10:47:00 AM
MH, if you would simply READ and TRY to understand this concept instead of coming back time and again with your own preconceptions of what is going on, you might realize that no further explanation was necessary.
It has be explained in the patent and discussed time and time again in this thread that the water that is used to create the buoyancy in the Pod and Riser in one ZED is then EXHAUSTED to the other ZED. Allowing the water to freeflow from the "high" pressure ZED to the "low" pressure ZED requires no additional input energy. And this is how the elevated ZED Pod begins to attain it's neutral buoyancy and then negative buoyancy condition where it will again drop.
And YES, additional energy is necessary to accumulate the rest of the water from that "high" pressure ZED and introduce additional water to the "low" pressure ZED in order to complete a full cycle. And that additional energy is a fraction of the energy produced by the lift of one ZED.
MH, I really wish you would read and try to understand rather than standing on "principals." Or go have your "principals" discussion in a thread intended for that purpose. If you refuse to read and try to understand, then please don't bother posting. It is like the sighted trying to tell the blind how to see. Or vice versa.
M.
Mondrasek:
I admit that I am not following the thread but your answer is still insufficient. You are apparently claiming an "energy gain" from the lift of one ZED can take care of moving the water over to the other side of the system? Know what it sounds to me like? It sounds like you are just moving the fairies further up the chain of events. No fairies needed to move the water back and forth between the two cylinders because the two ZEDs take care of that. So who takes care of the ZEDs? Even if you have an explanation for that it just means that you are moving the fairies along yet again. Eventually you will hit a wall and there will be no place for the fairies to go.
Here is my challenge to you and the other believers: Stop beating around the bush and ask Wayne what the output of the system is and exactly how he is measuring it. He won't answer me and always plays the "wounded and harassed inventor" card.
You believe in his system? Then again, I challenge you to ask Wayne what the output of the system is and how he measures it.
Put aside the spreadsheets and the buoyancy calculations for a week and ask about the output. Supposedly Wayne is on the verge of doing a demo so why not ask him?
It's too easy to just "play free energy calculations" and pretend that the over unity power output is a given. You "know" that it's there so you don't have to ask about it. You would prefer to focus on the "science" of the calculations.
Shift your focus on the power output of the device for a while and ask about the tangible real-world results. Are any of you believers willing to step up to the plate and ask Wayne?
Quote from: LarryC on July 21, 2012, 11:48:32 AM
Thanks Wayne,
Regards, Larry
That was an internall adding error, thanks for catching it.
I will go back and fix it.
Wayne
Just visited the local zoo with my kids.
Most visitors are respectful. They go to the zoo, see the animals, read and watch the presentations, and they learn.
Others go to the zoo and end up throwing rocks & sticks at the animals for their own cruel entertainment.
The internet is the same way…
Tom
Good work Larry,
You have shown how the "concentration" of the "Travis Effect" works.
I might suggest that we move on to the next portion of the system.
The next phase is to understand how much Head is transferred to the second Z.E.D
Things to consider - The weight of the risers and added weight - they allow the system to sink when partially charged (head)
When You calculate how much (minimum) head it requires to float - amount of weight - you have the minimum exhaust pressure.
Next - you need to Know what your stroking pressure is - so your weight plus your production load - maximum head needed.
Take the average of the two pressures - and this gives you the post free flow pressure.
The value of the free flow is the head at max (end of stroke) to the post free flow pressure.
The value of the remaining exhaust is the post free flow pressure to the Minimum head pressure (sinking pressure)
The head less than the sinking pressure always remains in the Z.E.D and never needs replaced.
This is a good start.
Our pressure is:
Minimum 5.0, 8.4 max, and 6.7 post free flow.
Since the true input cost to each side it the diffirence between these pressures and the Max - this is very important.
Wayne
Larry,
Some where read and lost track of - You asked about our system:
The Pod is 707 si or 30 inch diameter 6 feet tall
All our walls are .198 thick and clearances are .25 inch
This system is three layers.
And Yes the arangement of the diffirentials within layers - very much effects the lift.
(Wise observation) - More diffirential in the outer layers increases the lift - think about how that effects our exhuast pressure (when the inner laers have dropped the diffirential)
Remember - very little movement happens in the outside layers...............
Well done.
Wayne
Quote from: MileHigh on July 21, 2012, 12:52:28 PM
Here is my challenge to you and the other believers: Stop beating around the bush and ask Wayne what the output of the system is and exactly how he is measuring it. He won't answer me ...
MH, I've tried several times to help you to understand what is happening right in front of you. I really wanted that for you. I believe you deserve it.
It is very clear to me: Your statement that, "He won't answer me..." is just false. He has answered the question you ask in the patent and in multiple posts. He has not addressed those answers to you because you ask AGAIN after he has explained that portion of his presentation several times before. Therefore answers to your questions only cause our progress to backtrack significantly. If you would only read and digest the entirety of this thread you would be "up to speed" and able to stop asking insulting questions.
I have hoped time and time again that you would get on board by at LEAST reading the patent and the rest of the thread. That is the LEAST you should do before commenting? But I doubt that you are going to do so and will again proclaim "Bullshit!"
I do not wish to leave you behind on this. I really hope you would do us (and yourself) the courtesy of reading the entire presentation.
The presentation was interesting enough for me to start running the numbers. The numbers is what solidified my interest.
Please stop harping about Mr. Wayne owing anyone the "MileHigh" required explanation of anything. That is just your Ego. It is not a requirement for anything else than satisfying your Id.
You will not even read Mr. Wayne's methods of explanation. Yet you mock him for not conforming to yours? Really?
Be a "baiter" and be ignored or join our genuine search for understanding and truth, wherever that may lead?
M.
Mondrasek:
Asking about the power output of the device is not an "insulting" question. Nor am I going to read through the entire thread and the patent.
Just pretend I am a newcomer to this thread for the sake of argument.
I come into the thread and I have the following three questions:
How much power is output by the device?
In what form is the output power?
How is the output power measured?
I honestly doubt those three questions have been answered in this thread. Now, in saying that, you put your ego in check and please do me the courtesy of answering those three questions. If you can't answer them then just be honest and state that you can't answer them. If that's the case, you personally should direct those three questions to Wayne yourself.
So, I am asking to forget about all of the attitude issues and all of the ego issues. Saying, "You're not nice so I won't answer your questions" is something that you should hear in an elementary school schoolyard and not in this forum where we are supposed to be adults exchanging ideas and information.
So can you do me the courtesy of answering those three questions?
Just take the position that the device is a "black box" and I, as an imaginary newcomer to the thread would like for my three questions to be answered. I don't want to be directed to "read the whole thread and read the patent" to find the answers. I am just asking about the output from the device.
Quote from: MileHigh on July 21, 2012, 04:02:47 PM
Asking it repeatedly when it has been disclosed repeatedly and you REFUSE to read those replies is not "insulting," I agree. Maybe embarrassing is a better term?
Thank you for making my point! You are willfully ignorant on this subject. WILLFULLY.
MH, I'm done. You win. I give up. Sorry I tried.
M.
Mondrasek:
There is nothing wrong with being ignorant about the operation of the device. I am not WILLFULLY ignorant either. You can't force me to learn about this stuff and I never expressed a desire to learn about this stuff. You are putting forth a false proposition.
You go shopping for a car and you ask the car salesman what the power output of the car is... Does the salesman tell you to go learn about combustion engines and transmissions and differentials and different fuel mixtures? Get real.
My conclusion is that you can't answer those three simple questions. So you have to do a song and dance routine and try to make me look like the "bad guy" again.
I will ask you one last time to answer my three simple questions and to respect the fact that I don't have to understand exactly how the device works just like I don't have to understand exactly how a car works.
I just want my three simple questions answered with no ego, no attitude, no preconditions, and no requirement to learn about the technology.
Mondrasek .. lol, I live on another small pacific island now [no, not Australia] & yes we do have internet - however, I regularly spend long periods away from my computer as I will be doing again soon.
Whilst I sympathize with MileHigh's requirements to have clear Output answers I also trust in the abilities & cool head of people such as yourself & Larry C - so, in short, I too as a newcomer to this thread don't have to wade thru the detail that you have already assessed but can rely on your summary facts.
I believe in the process - that is, that Mr Wayne is confident that he has found something extra-ordinary - that you & others will winnow out the detail by an exchange with Mr Wayne until all relevant data is in - that process may or may not reveal weaknesses in the argument presented [for which Mr Wayne may already have 'work arounds'], or you may find a "show stopper" - I believe that MileHigh is simply trying to get to the end game where we all will eventually end up.
As I said before if all pans out as Mr Wayne predicts then your time will not be taken up in understanding design & crunching numbers, but in identifying where the extra energy is coming from - and that may be a far harder task.
In the mean time I read with interest Mr Wayne's comments & appreciate his sharing of his research & hope he continues to do so - Mark D has asked some searching questions no doubt [this might be uncomfortable], so we wait for further information to substantiate claims of an extra-ordinary nature.
With this device I'd definitely like there to be no "show stopper" in waiting, so it's not surprising that emotions can run high at times, because not all information is available to all parties at the same time, as yet - Mr Wayne is doing a good job in keeping his cool head & character & not emotionally imploding with a few harder questions.
Quote from: MileHigh on July 21, 2012, 04:45:24 PM
MH, you are not "shopping for a car." You are in a forum thread discussing a new "engine" technology.
Yes, you are supposed to try and understand that technology.
M.
Mondrasek:
QuoteMH, you are not "shopping for a car." You are in a forum thread discussing a new "engine" technology.
I told you I was asking my simple basic questions without any preconditions. There is no rational reason to have any preconditions. I am not "supposed" to do anything.
I will take that as an admission that you can't answer my three simple questions about the output because you simply don't know the answers yourself. Why can't you just admit it? You should try to build up some character.
It's up to you or any other contributors to this thread to work up the courage to ask Wayne yourselves. Without doing that you are just sheep being led around by Wayne.
So the three simple questions remain unanswered and for all of your discussions with spreadsheets, none of you can answer them.
MH, have you stopped beating your wife yet?
M.
Quote from: mrwayne on July 21, 2012, 01:34:14 PM
Good work Larry,
Our pressure is:
Wayne
At the risk of arousing the further wrath of mondrasek and the other workers, I have to say that what is described here sure sounds to me like something material, not "just" energy, is being "produced" from nothing ... You can't have air pressure that increases or that is exhausted to some other place, without increasing the amount of air... the number of molecules, the mass of the air.
You are removing mechanical energy from the system to keep it moving against friction etc. But you are also exhausting something from one Zed to the other. How is what is exhausted, replenished, so that the mechanical losses are made up, with extra left over? I know, I know.... from the exhaust of the other Zed.
How embarrassing! Sorry if I have been emoting. I truly didn't mean to be wrathful. I'll take a break.
Sorry again,
M.
Mondrasek:
You have this big honking groaning behemoth of pistons and valves and compressed air and displacing water and a programmable logic controller with a digital display but nobody can state what the power output is! There is something wrong with that picture!
P.S.: Here is a link for you to contemplate: http://www.choicepaintballguns.com/bulk-co2-hpa-tanks
Wow! 100 cubic feet @3000 PSI and it's only $289 USD! :)
Quote from: TinselKoala on July 21, 2012, 05:58:15 PM
Hi TK,
Thanks for reminding me, with the many inputs from Wayne today, I haven't shown the difference in Input volume and obvious time of input as the number of Layers increase. Please see attached. Do you see how the Travis effect layers have a big advantage over regular buoyancy?
Both Archimedes's pod and Archimedes's + 3 Layers have the same starting and ending PSI. The Archimedes's + 3 Layers have a clear advantage in reduced volume input and time.
The figures shown in the first attachment are from the second attachment xls spreadsheet.
Regards, Larry
Milehigh. Whilst I am thoroughly disappointed that you will not study this device, For the sake of keeping the peace, I will try to answer your three questions. The answers I will give are purely my own opinion based entirely on information gleaned from the thread.
1. This is a small proof of concept model, and is designed to output up to 500 watts. The relationship between size and power output and size is not linear, and I believe that Wayne said that a 25Kw model would occupy a space the size of a parking space. In the present model, a high percentage of the output is being used to run monitoring equipment. I believe that leaves about 40 watts running a lamp load. Even if that figure was 5 watts, we still have overunity.
2. The output device appears to be a permanent magnet alternator, of the wind turbine type.
So the ouput, after rectification, will be DC.
3 No idea how Wayne measures the output. Much more relevant is how Mark Dansie measures the output. I have little doubt he will tell us in due course. Those are my opinions.
Neptune:
It's almost like you guys are out of the movie The Manchurian Candidate. You are so uncomfortable when someone asks some very basic questions when in fact you should freely answer them without turning things into a psychodrama. It's a form of peer pressure bordering on self-brainwashing. It's right out of the Twilight Zone.
I really don't have to know all of the specifics to ask my questions. Alleging that I am "beating my wife" as some sort of quasi comical segue to avoid answering the question yet again is ridiculous and it's playing into the "bad guy" angle yet again. What the hell?
I can feel the discomfort here, why? You need to do some searching to try to answer that question. Not even being able to admit that you can't answer the questions shows how deeply ingrained the peer pressure and discomfort level is. You should work on deprogramming yourselves, seriously.
Thank you nonetheless for trying to answer my questions. I will "reformat" your answers if you don't mind into what I am really asking:
QuoteHow much power is output by the device?
A: Between 40 and 500 watts.
QuoteIn what form is the output power?
You did not answer or misunderstood my question. You said, "The output device appears to be a permanent magnet alternator, of the wind turbine type. So the ouput, after rectification, will be DC."
Based on your response, my preliminary conclusion is that he output power is in the form of a rotating shaft. My confidence would be increased if there are any references to this in the thread. Strictly speaking, the question has not been answered.
QuoteHow is the output power measured?
You indicated that you don't know the answer to this question. Based on what you say above, it's possible that it may be measured by having a generator drive a load and then measuring the electrical power dissipation in the load. Again, I am speculating, and you haven't answered the question.
So you could only answer one of my three questions. I am not singling you out by stating that and my assumption is that it's the same story for most of the other participants in this thread.
Finally, look at your quote, "No idea how Wayne measures the output. Much more relevant is how Mark Dansie measures the output. I have little doubt he will tell us in due course. Those are my opinions."
This is an example of the discomfort and the peer pressure bordering on collective brainwashing. I am assuming that you have been an active participant in this thread from the beginning and yet you have no idea how the output power from the device is measured and apparently you don't even want to know how the output power is measured. How is that even possible? I can also infer from your responses that you are not sure what form the output power takes.
Again, I am not the "bad guy" and I refuse to be made to feel like asking about the output from this device is somehow a bad thing to do. There are a lot of issues for you guys to think about.
1.The output power is between 40 and 500Watts
2.The intermediate output is in the form of a rotating shaft, being the output shaft of a hydraulic motor. This motor is then used to drive the aforementioned alternator .
3. We have not been told how Wayne measures this output . If you wanted to measure the output at the hydraulic motor, a Prony brake would do the job.
I do not speak for anyone but myself, hence my pointing out that these are my opinions. It is of no concern to me whether you beat your wife or not. There you go. three plain answers to three plain questions.
Neptune:
QuoteIt is of no concern to me whether you beat your wife or not.
That is a gross and gratuitous statement and you should be ashamed of yourself for stating that. And if I did beat my wife you should be concerned with it because if not then you might be a misogynist and beat your own wife. In fact I am hypersensitive to the issue of conjugal violence.
You are just taking a gratuitous and malicious pot-shot at me because of my response to your posting. Shame on you.
I would never beat my wife and I never said that I would beat my wife. That was just a nonsensical statement made by Mondrasek that came out of nowhere. I never made any reference whatsoever to anything like that EVER.Retract your statement.
@Milehigh. Now you are just being childish. I am against violence in any form, and that it includes violence inflicted on women. It is not my concern if you beat your wife, in that you live half a world away from me, so, concerned or not, I could not stop you. I answered your three questions when no one else would. This is an overunity forum. Not really the place to discuss domestic violence.At no time did I state that you were guilty of beating your wife, merely that if you did, I would not concern myself with it.
Neptune:
Quote@Milehigh. Now you are just being childish. I am against violence in any form, and that it includes violence inflicted on women. It is not my concern if you beat your wife, in that you live half a world away from me, so, concerned or not, I could not stop you. I answered your three questions when no one else would. This is an overunity forum. Not really the place to discuss domestic violence.
Any inference that I would beat my wife is totally unacceptable. By repeating Mondrasek's ridiculous and unfounded statement you are casting aspersions on me by reenforcing an unfounded point.
You take your statement back and then it will be over. Don't you dare repeat a lie about me in some subtle attempt to impugn my character.
MileHigh, I bawl down to you Sir!
Your last 3 replies was just killer! Very true, very true Sir!
Right on target! Let the truth be told!
LoL! Nice job!
Keep it up!
I've always enjoyed reading your posts!
Good day Sir! :)
@Milehigh. Dont you dare use your dont you dare card with me. I do not do subtle character assassinations. I am straight John Bull and if I have anything to say , I say it . You have made it clear that your purpose here is to disrupt the forum . I no longer wish to converse with you and will ignore all subsequent posts from you.
Neptune:
Quote@Milehigh. Dont you dare use your dont you dare card with me. I do not do subtle character assassinations. I am straight John Bull and if I have anything to say , I say it . You have made it clear that your purpose here is to disrupt the forum . I no longer wish to converse with you and will ignore all subsequent posts from you.
Well then you are pathetic excuse for a man because you are attempting to do a subtle character assassination. You don't even have the guts to acknowledge your wrongdoing and retract your statement.
So you are not being straight right now and you won't make the retraction. It's just to be belligerent because you are uncomfortable with the things about this device that I have pointed out to you. So you lash out and make an attempt to impugn my character.
That leaves you with two problems, your attempt to impugn my character by repeating a lie and and your general ignorance about the output of this device that you have been talking about for months.
My purpose here is to inquire about the output of this device to understand what it is. It goes to the credibility of this free energy proposition. If the question was answered freely without any psychodrama then it would add to the credibility of the proposition. When anybody tells you that they have a free energy device and you ask them about the output from said device and they refuse to answer you then attempt to make you feel like you are doing something wrong then you should beware.
Go hide your head in the sand, I don't care.
I never intended to imply that anyone beats their wife. I meant only to give the classic example of a loaded question: http://en.wikipedia.org/wiki/Loaded_question (http://en.wikipedia.org/wiki/Loaded_question)
I was intending to point out that there is usually no correct answer for MileHigh. He takes given answers or lack there of and then "reinterprets" their meaning to suit his own needs, preconceptions, whatever. This is usually in his posts directly after anyone gives answers. Take a look and see.
Sorry if I offended anyone, especially MH, with that reference. It is, like I said, just a classic example. I didn't expect that it was not common knowledge.
M.
How can asking what the power output from the device is be a loaded question or not have a correct answer? Think about what I have stated in my previous postings.
@Mondrasek. Yes, this "loaded question" is of course common knowledge, as would be apparrent to anyone with a basic education.
You are trying again Neptune, I never said that I did not understand what a loaded question is. Now you have three problems.
To All,
It is clear through all of our postings and answers to the questions regarding our system that we us Buoyancy In a very unique way to generate excess power - and that the system is self looped - requiring no input.
As I said before - I have allowed the skeptics and the validation teams to decide how they chose to measure the input and output.
It is elementary to understand that a system such as ours - that requires no input to produce work - "of any kind" requires proper and due dilligense before making claims of any sort.
It has also been explained in regards to comparisons to other systems - Mark Dansie - 99.9% of all claims of FE are - measurement error - poor theory, and a few scams.
Mark has also said publically and on other forums repeatedly - this Oklahoma device is the .1% we have been looking for.
It is a waste of my time to tell you how good our system is - that is why I have helped others to discover for themself.
You can get as complicated as you want - you can get even more sophisticated equipment - you can claim you see nothing - but you can not make the simple math go away.
The truth of the .1% success is right before your eyes - if you just are honerable enough to look.
As I said to MH before - I will not waste my time with the dishonerable - do your home work.
I do not expect anyone to take my word for it - and I have been open and honest.
All the claims to the contrary do not float like the Z.E.D.
P.s. I have asked nothing from any of you - I have offered to share.
I am thankful for the sucess our team has had - and the now 13 replication (modeling) successes that have been reported to me.
Wayne Travis
@mrwayne. Thanks for that information. Could you please make it clear for us what you mean by modelling. Are you speaking of an actual device, made from sheet metal, plastic or some other substance, or are you speaking of a "Mathematical Model", a computer simulation, or indeed something else entirely. It is important for us to know.
Respectfully Neptune.
To all members . I have made a big mistake , and I will now apologise. I am very sorry for feeding the Trolls. I promise it is a mistake that I will never repeat. Sorry.
Quote from: neptune on July 22, 2012, 10:46:36 AM
Hello Neptune,
I now remember you asking this before - I am sorry for the delay - lots of interuptions.
As far as I know - Mathematical modeling - simple and complex physics.
You do not need an new form of physics to understand our process - just the ability to see that we have an anomaly in the area of physics that does an 'endaround' to belief that mechanical FE is impossible.
Wayne
QuoteYou do not need an new form of physics to understand our process - just the ability to see that we have an anomaly in the area of physics that does an 'endaround' to belief that mechanical FE is impossible.
I passed Grade 11 physics and because of that I have no desire to "learn" how the system allegedly works. They only thing that counts are results.
Neptune you should look up the definition of "troll" and educate yourself.
The only thing of interest is to see how this story will end. Will it take the form of one of the classic free energy exit strategies? I am willing to bet that it will.
@mrwayne. Many thanks for your reply.
Quote from: MileHigh on July 22, 2012, 11:31:20 AM
Correct, i wouldn't be surprised either.
@true open source people.
Jesus fucking Christ! People must think we're re-fucking-tarted or something, my God!
This is why I have NO patience anymore. People don't know what OPEN SOURCE is and pretend it's all out in the open! When it's NOT!
And I have said this before and I'll say it again...You CAN NOT commercialize Free Energy/Over Unity (NO I'M NOT TALKING ABOUT WIND, SOLAR, ETC!), period. You may be able to patent it but not commercialize it. Look at Tesla, and many others who have tried to commercialize FEE ENERGY! THEY DID NOT GET VERY FAR!. What makes you think you'll bypass our current corrupt government to make it happen?! If the people get a hold of real true free energy devices/machines they will break loose from the government and that is something they DO NOT want people to have access to, because then they will lose control of us slaves. Oh wait you think the government is for the people by the people? lol not really, its for the private banks by the privates banks who enslaves us through debt, monopoly, energy, media, drugs, and agriculture! wake the fuck up people, Jesus!
The two pictures show the water heights at 5 PSI and 8.4 PSI using the water height calculator with a "Out Ret Water Drop" value of 12 and 4.38. These were the latest PSI's stated by Wayne. In the 5 it is easy to see how the outer columns have moved much less than the inner. The percentages also change.
Regards, Larry
That is very good Larry,
You may notice that the outer layers - with less movement - account for the higher pressure for lower weight.
The outer layers have a larger diameter - and the last layer pushes against the atmosphere.
Wayne
Quote from: mrwayne on July 22, 2012, 10:16:26 AM
To All, It is clear through all of our postings and answers to the questions regarding our system that we us Buoyancy In a very unique way to generate excess power - and that the system is self looped - requiring no input.
It is elementary to understand that a system such as ours - that requires no input to produce work - "of any kind" requires proper and due dilligense before making claims of any sort. It has also been explained in regards to comparisons to other systems - Mark Dansie - 99.9% of all claims of FE are - measurement error - poor theory, and a few scams. Mark has also said publically and on other forums repeatedly - this Oklahoma device is the .1% we have been looking for.
It is a waste of my time to tell you how good our system is - that is why I have helped others to discover for themself. You can get as complicated as you want - you can get even more sophisticated equipment - you can claim you see nothing - but you can not make the simple math go away.
The truth of the .1% success is right before your eyes - if you just are honerable enough to look. As I said to MH before - I will not waste my time with the dishonerable - do your home work.
I do not expect anyone to take my word for it - and I have been open and honest. All the claims to the contrary do not float like the Z.E.D.
P.s. I have asked nothing from any of you - I have offered to share. I am thankful for the sucess our team has had - and the now 13 replication (modeling) successes that have been reported to me.
Wayne Travis
Hi Wayne .. please tell me if I have this wrong & my apologies in advance if I have - I think you said your ZED's are pressurised ?
If so, what is the purpose of pressurising the system ?
Would it not work without pressurisation or does it only work this way ?
I assume, if it is so, that it helps to shunt water back & forth efficiently but you might be using a hydraulic pump for that ?
Sorry if I've missed relevant detail that answers this query that you've already given elsewhere - just trying to mind map the system accurately.
Quote from: Ghost on July 22, 2012, 12:24:54 PM
Thats not quite true
If everyone wants one, or 2, more?, then who is going to make them? A device may not be able to be recreated in the garage or back yard or on the kitchen table easily. And those that can do it, are they going to be the ones that make them for everyone? And after doing soo many and demand increases, will those that can want to industrialize it, because the garage isnt going to work out any longer?
Sombody has to make it. And if it works, there is always the chance that the idea can be improved upon and research and development would be intense, or not. And there would be a job market open all over the world. But money will be needed to make them. When making them in very large volumes, cost goes down.
Meanwhile, everyone is saving money on energy and has more to spend in the economy.
And, all things should become cheaper, once the cost of energy is factored into the equation.
The key is to get everyone or at least a good majority, to understand that free energy exists. Otherwise, fugidaboudit. Until then the earth will be continually punctured and damaged because of our reliance on fossil fuels.
If free energy does exist, imagine the dry lands that could be watered, without energy cost. Meanwhile when a Nuclear power plant gets its power cables broken by a tornado in Alabama, it requires 40,000, thats right, 40,000 gallons of diesel an HOUR, thats right, an HOUR to power the cooling pumps till the power lines are repaired, over a period of 2 weeks. These plants are not prepared for many things. And many are being re licensed beyond the original licensing periods.
Tesla said, there is no better time than now. That was a long time ago.
Mags
Quote from: neptune on July 22, 2012, 10:49:59 AM
No problem, all Trolls, Flamers, Baiters, haul ass, get the hell outta here!
Hi
i am sure Mr Wayne is ok me updating.
The unit is initially pressurized, but these pressures are maintained without any other external inputs once running
Latest update is to go into long term running this week self sustaining then add the generator (its already connected)
Mark
Thanks Mark,
Today is my Birthday - so I left to go see the Dark Knight in an I Max theater - that was fun.
And you have my permission to answer - as you feel - anytime.
Wayne Travis
Quote from: fletcher on July 22, 2012, 09:29:17 PM
Hello Fletcher,
We do not have a hydraulic pump - we do spin a hydraulic motor - from our excess - to spin a generator.
And Mark is correct - part of the initial set up is to push the heads into the minimum position (with Air) - and that's it - no new air is used.
The pressure increases and decreases repeatedly in a cycle.
Wayne
Quote from: mrwayne on July 23, 2012, 12:04:51 AM
Hello Fletcher, We do not have a hydraulic pump - we do spin a hydraulic motor - from our excess - to spin a generator.
Wayne
Thanks Wayne & Mark.
Well, that adds to the intrigue as it appears a totally closed system except for load as output energy - all I can say is very best of luck & I look forward to Mark's analysis after the long run test.
If excess energy to do work is being produced, & pressure isn't dropping over time to provide that, then I wonder if the ideal gas laws are coming into play with a twist i.e. where there is are adiabatic & isothermal cooling & warming legs in the process that brings ambient heat energy into the system from the air to replenish mechanical energy losses ? - that of course would mean a machine that converts heat directly into mechanical motion & that would be very interesting from the Laws of Thermodynamics perspective - I could be totally wrong there & you no doubt have a theory Wayne.
Temperature differences might be something for Mark to consider in his investigation of the closed system ?
Once again, thanks for being forthright & sharing.
Quote from: mrwayne on July 23, 2012, 12:00:14 AM
Thanks Mark,
Wayne Travis
Happy Birthday Wayne, and please have many more. I envy you seeing Batman in the Imax, God rest the people in Colorado.
That's why people do experiments - that's also why long run tests are important - that's why long run tests under load are even more important - the energy to do work in a seemingly closed system must come from somewhere - especially if buoyancy is the prime mover & we correctly assume that it is an artifact of conservative gravity.
So, I look forward to Mark D's investigation & analysis to see if an energy anomaly exists & if so where might it come from in his or Wayne's opinion.
@MarkD:
When you go and look, please remember the story of the Redheffer machine. What is driving, what is driven; upon which side of elements does wear appear, etc.
I'm not accusing; like I've said before I have suspended disbelief and am still taking MrWayne at his word, but at the same time I'm as sure as I can be that something is missing. Happy Birthday, by the way, and many more to you!
13 replications all in simulation models, right? Nobody has yet built a working, self-running model?
@TK. I understand that some guy out in Oaklahoma, name of Wayne Travis has built one. :)
Yes, Of course respect to the families of Colorado and their loved ones - they are our brothers and sisters.... enough said.
Thank You for the Birthday wishes - 45 half way there.
Replications are expensive - who among would replicate a $30,000 to $500,000 system in your garage?
Dennis is building the replications - and has completed his Physics model - his plan is to explain and educate in simple terms.
I am sorry for those I am not able to communicate clearly too - what seems simple to some - can appear complex to others - and in my experience with engineers - complexity is often added where it is not needed - this can becomes a personal stumbling block to others.
I understand that we each have our own unique perspective - I have also observed where sometimes education works the uniqueness out of us.
I was a bit of a rebel (secretly in school) I held onto my uniqueness - others tried to fit in - while I refused to join the crowd -
I did not hold it against them - I did step in when the crowd attacked someone for "being Smaller" -
Thank you to those who try to stop the character attack - but please refrain - my character is solid - and not based on what others say.
I value Freedom:
True freedom is partly the right to choose to fit in or not - nobody has the right to step on others for personal gain or ego.
Text books:
The idea that all discovery and understanding was to be found in text books was counter intuitive to the process that put the knowledge in the books in the first place - the inventors - the researchers - the observant - and the creative - did not get their understanding from text books - but from thinking people.
Error is and was introduced to the field of science - when science became its own Law maker - rather than the observable, repeatable fact..... Newton warned of that - we should all understand that to use science as a "limiter" of observation is counterintuitive.
I had a good science teacher - when I was very young - in one instance - I argued that water did not always seek a level position - I referenced the round ocean - the wick effect - and evaporation - that in perspective - it could be seen differently.
I was very young - But my teacher respected my curiosity - he was the kind of teacher who stood on glass plates and ran electricity through his arms to lite a lite bulb with his finger tips - super cool....he died of an enlarged heart - happy to have inspired the minds of others.
He explained -
"The questions you are asked in this school are merely to teach and to share what others have learned and observed - the instruction will be based on those things previously discovered, you will be graded on your understanding of what they observed.......but you must keep asking questions, new discoveries are made that way."
This same teacher then suggested I try to make use of the wick effect - that was the start of my move from observation to experimenting.
Fully functioning Z.E.D. models:
I did - I built 8 of them - reused parts from older models of course to save money - but that is what it took to discover the secrets of buoyancy - it took quite some doing to design the mechanics to take advantage of the "Travis Effect"
Our Market:
We are not in the FE machine to "run a refrigerator" market- like the "Imagine FE commercial" on Peswiki.
One of our Machines will power between 60 and 70 homes - average annual consumption - not peak of course - but averaged power consumption.
The Z.E.D system is very robust - we have not had the issue of unrepeatability - we have modified - changed configurations - disassembled - reassembled and the Z.E.D. portion of the machine - and they Z.E.D. portion functions repeatedly just as the Physics show it does - very much FE.
The hardest learning curve was the use of the Non linear - since the system uses two Z.E.D.s the linear functions had to be matched - which meant they had to be understood - that took hard and long work.
Now - the Energy capture system - which can be of any complexity - has given me trouble in my Garage - I am not an engineer - but people want to see electricity - so our lateral stroke had to be turned efficiently into electricity - that is hard with a small model. Hence the hydraulic conversion system.
Thermal:
We do not exchange heat - or do any form of exchange in that manner - When it is hot outside - or cold - the system does respond as expected - the accumulators nitrogen does expand a bit - but since the system is self regulating - it compensates automatically.
The speed and pressure we deal with are barely enough to measure that exchange - Our engineer said - it is less than one 90 degree elbow (in the plumbing) adds in resistance and loss to the system.
Partial Theory:
It takes understanding the full operation to grasp our system - which is why I direct those who make predictive emotional comments to do the due dillignese. in my experiance - those people never do - "learning" becomes a distant memory in some minds.
The Operation of our system is Mechanical FE - we Mechanically manipulate the pressure differences between three separate mediums - because they are each effected by gravity in a measurable and predictable manner - differently - we can control the effect.
Our exchange system is a huge cost reduction and is simple equalization - captured and controlled.
The Unique portion - the pressure diffirential section - is a key.
Our water in our layers is like a liquid but act as both a solid lever and a pressure increaser - taking advantage of both the incopressability and the effect gravity has on the density of the fluid.
Our Lever has enabled us to design a system which is bent up and down many times (shortening the length of the lever - reducing the stroke length of the long end of the handle) - while still applying the force and output on the short end - like any understood lever. (how we take the work out is why this portion works --and a bent steel lever does not).
Larry has shown this effect in many of his spread sheets.
The force applied to the levers "folded long end" is gravity induced pressure from mechanically controlled pressure differentials.
Level of disclosure:
This group, had only been shown the inception and the basic process - and when you are ready - I will show how we turned our 160% (three layers) efficient model into 340% (six layers), then 840% (eight layers) and then reduces the "input cost"
We have one unreleaesed portion of the deisgn that takes any of those internal input costs and reduceds them another 88%.
Yes - we have discovered how to take our Original FE system and using the theory of operation to expand the process well beyound what - at this point in time - is even believable - for now.
Today some people treat us like crack pots - tomorrow - (figuratively) as we move forward - those people will realize thier error.
We are ready for the World, and most of the world is ready for us, let me repeat - We are ready for the World.
Don't wait too long - and thank you for the value you offer by at least being part of the knowledge of this adventure.
Suppression:
No one has tried to interfear with the development, research, or production of this system - unless you call apathy and slander interference - as I have seen on this web site.
In my humble opinion - regarding the interference - the brilliant one ones have stopped - the smart have doubled down.
I understand that "Smart" comes in many forms - on this site it has been emotional disagreements - not based on understanding not based on the physics of our system or observation or witness of others.
Emotions are not good scientific proof for or against a fact.
All I offer here is the truth and share in our discovery, I am not here to boost any egos, play games, or to be rude to others.
Thank you sincerely to those who have asked questions and spent the effort to understand.
True Freedom, Independance, the systems will cost to be deployed - but the continued benifit will be seen in a few years - for genrations - which is a rare occurance in this world - that is why I named my company HydroEnergy Revolution llc - ( H.E.R)
Wayne Travis
Quote of the week.
"all reasonable men change themselves to fit in with their environment. Unreasonable men change the environment to suit themselves. Therefore, all progress is made by unreasonable men."
This was the original quote. I would substitute "unconventional" for "unreasonable".
Nice quote Neptune.
One of my favorites that I believe also applies:
Nothing in this world can take the place of persistence.
Talent will not; nothing is more common than unsuccessful men with talent.
Genius will not; unrewarded genius is almost a proverb.
Education will not; the world is full of educated derelicts.
Persistence and determination alone are omnipotent.
â€"- Calvin Coolidge
PS - My change would be "Persistence and faith alone are omnipotent"
Quote from: neptune on July 23, 2012, 08:02:01 AM
Uh huh... and I understand he's trying to get somebody else to build another one, a tabletop demonstrator. Has anyone succeeded in this, yet? ;)
I was asking, in my post, if the thirteen model replications were spreadsheet models or actual model models that you ... meaning mostly me ... could build and set to running and watch running.... and running.......... and running........... right there in my own kitchen. I think I've gotten my answer.
Hi TK. That was just me trying to be humerous. I do know there are people working on a table top model, but as far as I know no one has yet completed the work. Wayne has said that the thirteen models are mathematical models, not table top models. Although a ZED is basically a simple device, making one in your garage is not a five minute job. I have no doubt someone will do it.
My own experience with trying to design a model made it very clear that it is very difficult to accurately calculate the changing water heights and air volumes as the Pod and Risers begin to move. And accurate calculations are necessary when trying to made a ZED device small enough to have as a desk top demonstrator. As has been shown, the lift forces become too large to manage once the device becomes larger than about 6 inches in diameter. More layers also increases the forces, but would more easily show the "OU" effects.
One of the critical design parameters has to do with thin walls and gaps for all the members. My own attempts to use commercially available acrylic tube of 1/8 inch wall thickness and gaps might be workable, but the amount of water that must transfer between ZEDs is proportionally larger than what Wayne is doing with his large units. This is because the wall thicknesses and gaps of a model with those material limitations are much larger proportionally than Wayne's device.
The gentleman who has been "authorized' by Wayne to build teaching models plans to make tooling for the model pieces. So he needs a very precise design first. To that end he has been working on a parametric software simulator where every dimension can be adjusted. Including air and water density. It is very cool, IMO. Unfortunately he is using a commercial software package now so you would have to purchase that to run his code. But he has told me that it should be easy enough for someone to transfer into VB, Java, etc.
FWIW.
M.
Developed a new Water Height Calculator for a 4 Riser system. With that information I updated the Water Input for Different Layers spreadsheet. Attached picture shows the volume of water input for different layers when raising water around the pod. It considered the cost of input with just the Pod, Pod plus 3 layers and Pod plus 4 layers.
The most significant values are in red and green.
Red is what the cost was for the many failed buoyancy machines, part losses, but mainly due to the volume of water input and obvious time of input to get to the Pod rise force required and the volume of water output and time of output to lower the Pod after rise.
Green is what the cost is for a 3 layer and 4 layer Travis system. Any of those failed buoyancy machines would have worked with that advantage. Remember the simple formula 'Power = Force X Distance / Time'.
One of the advantages of the Layering system is that
The Layer system reduces the volume of water and time required to load and unload a system.
The spreadsheets are attached. The 'Volume of Water Input for Different Layers' spreadsheet has simple calculations as it is using data from the more complex Water Height calculators.
Regards, Larry
I'm new to this forum as a registered user but not so new to the discussion or the development of this device.
I've read the patent, watch the HER site for updates and have had a couple of direct questions for mrwayne.
If I'm reading the current developments correctly the pod needs to be neutrally buoyant but no-longer needs the sealed chamber to accomplish that. (?) And in the patent drawings, air is the fluid medium being passed between the ZED devices.
Larry's calculators seem to be focused on water levels in the outer risers.
I'm just trying to keep up with the developments and understand the principles involved.
Is air still being transferred between pods or is the water level in the outer risers the connection between them?
Sorry if I'm a little slow to keep up
Dale
Quote from: wildew on July 23, 2012, 09:31:28 PM
Dale
Hello Dale,
The patent covers moving both water and air or separately - as well as moving separate bodies of both - in and out. All will work - but water is better - pumping a non compressable is easier than a compressable.
Having two separate by related bodies makes controlling the system much easier.
We have built systems and tested those three and a couple more methods that are being covered in our new patent.
Currently - we move two separate bodies of water related by pressure through the pumping system.
The Pod adds to the lift, but that is its least effective use.
The pod is the internal mass discplacement that chases the riser to keep the differentials in place during stroke.
We do match the desired stroke length, clearances and weights of the risers and added weight to take the best advantage of the Pod.
The Pod can act to neutralize the weight of the system.
Larry wisely noticed that the outer layers add more lift to the system than the Pod - utilizing the outer layers requires less pressure to create more lift - because it is outer layers that have the larger diameter.
Our Pod has a si of 707 and the outer riser has a si of 1100 1 psi in the outer layer adds 1100 pounds of lift - and one psi in the pod lifts 707 - using the outer layer "more" is better.
Understanding this - and how the pressure changes between each layer during a stroke - explains the non linear function.
Larry is on the ball.
p.s.
The pod was sealed during the air movng and the water moving - I am not sure what you meant.
Thanks Dale,
Wayne
Larry hit on a very important note - Time, distance and mass.
I thought one could not escape the confines of "work"
By comparing "work" - you must consider those three.
I first studied these as Horse power -
If in 1 minute, you move 330 pounds 100 feet that was 1 hp
if you moved 660 pounds the same time and distance = 2hp
Or if you move 330 pounds 200 feet in 1 minute = 2hp
and if you moves 330 pounds, 100 feet in 30 seconds = 2hp
I studied many designs, and watched many inventors overjoyed about a system - only to later realize - the trap that time distance and mass had on "Creating Energy".
Free energy seemed impossible, impossibility made sense.
When I saw the "Travis effect" I did not see a "creation even" nor was I looking for one -
I saw a system that had a "lift" proportional to the whole mass, moved faster, a short distance - utilizing a very small mass of input.
I saw the ability to do work - cheaper and faster and with less input than any other buoyancy system in the world.
Thru hard work and testing, measurement and observation - I finally understood the "Why" the "How" and the later the "Where"
The "Where" was the hardest - because a false label had been given to the idea of Free Energy - that label "Energy Creation.........."
We are not allowed to create or destroy energy...................................
One of the lessons I learned in my critical thinking studies - does the argument apply......?
The Argument - If you claim Free Energy - you must also be claiming to be a "Creator of Energy".......
The obvious comparison - solar and wind - are they energy creators?
No, of course not - are they free Energy - Yes.
But we understand where thier energy comes form.
So do we just apply the label of "Energy Creation" to everything we do not understand?
Some Do, they are mistaken - I do not - and that makes some people uncomfortable, I understand - I used to feel the same way.
As I have said before - We have a mechanical marvel - our system of interacting layers and the unique attributes residing in liquids and in discplacements - each effected by gravity and has giving rise to a system - a robust system - that has an internal operating cost - less than the total production.
We have "left over" Energy - which is free - just not "created from nothing".
We continue to find ways to save even more for the customer, but we will never be able to provide more than the system is capable. Reduce costs - we have - amazingly reduced - Energy creation - you can find it on another link - not this one.
Larry has been very keen in his investigation, the data he provides is very usefull in understanding our system.
If you get misled by biters into chasing a "creation system" that is not what we have or have ever described - the baiter misleads - that is his purpose - we have been very clear.
Wayne Travis
Quote from: Seamus101 on July 24, 2012, 02:30:17 AM
This describes leverage. NOT The production of usable work.
Please show how this cycle can continue to liberate energy without the injection of additional mass into the system. If the additional mass comes from the other side then the net output of the combined system is zero.
As I see it...this works as claimed via:
2 masses on top of a see-saw balance beam in effect (or connected like so via hydraulics) You have the kinetic energy potential when one is lifted, to take work from on the way down. However, you also have a unique leverage system,where buoyancy gives you 'free' lift each time, so lifting up the other side during the downstroke takes not 100 percent of that mass X distance coming down, but only some percentage. That leaves a left over amount for 'work'. Yet you shift the mediums around...alter the balance.
Now the other side is raised up, transfers are initiated allowing it to return, and it repeats. Gravity (the equivalent of the wind, or sun in windmill or solar energy here) is the 'free'.
Consider two masses on a see saw. Both being blown down by the wind from above (metaphor for gravity)...One side is released to rise, the other to fall, one rising because the other is used to leverage water and air mediums to make it rise.
Yes each mass is getting the same wind blown at it, but one, mechanically, is on a side 2x longer than the other, so the wind, blowing the same, raises the other side.
What now if transfer this leverage, making the other side the longer one...now it raises the original back. Same wind a blowing (gravity). Except you have a weird buoyancy going on , which means you don't need all the gravity on one side to life that other side up.
You repeat. You get extra each cycle, because you can lift up the mass each time using less than you get when it falls? You do that using buoyant leverage, and any mechanical advantage therein from compression of air and water. Then you shift the air and water on a timely basis, and transfer the process about.
Imagine a donut weight on top of a telephone pole. If it falls 25 feet, that's a set amount of energy to extract. And then if by utilizing other forms of energy, pressure, buoyancy and what not to raise it back up, cheaper, (the other side of a ZED is that) then the extra from the fall is your 'free' mechanical energy. Yet you have raised up the other side during the fall of the first, and now you have more mass x distance energy to enjoy again. But it only took you some lesser percentage of the stored (it is pressurized initially) and newly gained to raise it.
That's how I understand the thing.
Consider in this case, that gravity is a wind blowing constantly, linear direction, down a tunnel and there is a hole to inject something into the stream When you lift one side, it enters the tunnel, gets blown back down...and in doing, raises the other via leverage and buoyancy, overcoming that side's desire to fall as well, effectively in the tunnel it is smaller then the other due to the leverage. Then you transfer the leverage and buoyancy using the same compression from the mass, and now the other is 'in the tunnel' and full size again, getting blown harder in a way, gravity now ready to bring it back down.
You will say, takes same energy to lift it up as came down. Buoyancy provides extra lift, repeatedly, not just one time because if you are shuffling it around during the strokes or at the end...game changes doesn't it?
Since it's pressurized you can use that to initiate the transfers. At some point, gravity and buoyancy take over, and cycle repeats.
I don't understand things as to that leverage, I am an artist, kind of stricken by a 2D visualization more than I wish, and this is a 3D system of concentric leverage so I cannot explain it much better.
But here's your quandary, Seamus. If the thing does repeat on its own, and does run on its own (and I have no independent verification of this) then all your complaining about this and that about energy creation and such does not matter, you are looking at a gravity-buoyancy 'wind' machine.
Nobody questions that a windmill works. What if somehow, this thing does work, and it's a metaphorical gravity 'wind' machine, deriving work from gravity, by making each mass continually fall in a way...via that leverage allowing a return to full potential KE, for less than the full return. It would be as is you have made gravity work a circle using tricks of displacement, and buoyancy and how the conversion works among mediums.
I am long winded, pun intended, but there's the same thing said 3 or 4 ways.
rc
Quote from: Seamus101 on July 24, 2012, 07:41:39 AM
No, buoyancy cannot give you "free lift", here is why. It takes the same or more *energy* to move an object downwards into a fluid as can be recovered when it rises.
Not necessarily true, if you are draining the air or adding water to re-sink or re-float depending on the cycle at hand, but I don't know the particulars. Something's being shifted to and fro, that's been made clear. First I thought it was air and water, but recently, seemed to be said to just be water?
Gravity as wind was just a metaphor for visualizing a streaming of the downward force in a linear way instead of left and right. I am not really thrilled with Einstein's summation and metaphor of it, but there are not many other presented alternatives thus far.
It's a really annoying force or manifestation of whatever , to be sure. And one wonders if the answer to it will be found this century, or 10 more from now.
Hello Artist,
I enjoyed your explanations.
Yes, Gravity is in effect - the pull gravity has on an object is closely related to the density -
Air (atmospheric pressure)
Water (Head pressure)
Steel (our weight)
The same gravity affects densities differently.
Objects do not really float - they are pushed up by the denser object.
It is a very elusive concept - many patented inventors designed their systems as though Buoyancy somehow defeated Gravity - all while gravity causes it.
When I understood that Gravity caused both - I began looking into the effect - long before noticing the "Travis Effect".
When I learned that water pressure (head pressure) changed according to altitude - a very simple thing - I realized that it was not the distance from the center of the earth that caused a change in gravity's effect on water - but the change in gravity's effect on the atmosphere - which in turn affected the water pressure.
Water being incompressible
And air being compressible
Meant that the two could be combined to create a pressure differential system where the differential values could be changed.
Very much like your example - we use the gravity, water, and air in our layer system to increase the effect of gravity on the water.
A simple example:
I studied a 20 foot tube filled mostly with water - horizontal - basically no head pressure - a tiny bit of weight - the tube turns vertical and now 10 psi of head pressure.
Then I added pressure inside the tube - ten pounds - the result - horizontal - 10 psi - vertical 20 psi.
Simple enough - to understand - increasing the controlled atmosphere - increases the pressure at depth.
We use the risers weight to increase the "atmosphere" pressure between layers - it is additive -
A horizontal tube and volume of air - completely changed its value of pressure when turned vertical.
Not more energy - just a compression - turning vertical reduced the surface area - so pressure increased on the lower end.
So the effect - as you rotate - concentrated si - and then expanded - a piston with a changing diameter.......
I built that system - and like many of my attempts - it was only a stepping stone.
When I designed the Z.E.D. I used that understanding - each of our layers - the water hose example is that pipe - connected together - so the head pressure increase in each (tube) layer increases the pressure in the next.
Now - Our baiter is full of can't do's - he can't - that is all he can really say.
You see - our twenty foot pole example - has a rotational radius of 10 feet - it is a fixed value.
Our system has the same effect - "our radius" stays the same (input volume) - as we add layers - yet we have the combined surface areas - and the combined pressures and the combined buoyancy.
If it could be done with the tubes - and you hooked four together - to get two with water - two with atmosphere - you would have the head of 40 feet at vertical and still have a radius of 10. Six tubes would get you the head of 60 feet and still the radius of 10 feet.
In short - your tube example is clever - very cool - very close.
That tube - lever action - increases the pressure at the cost of rotating a mass - the mass is constant and the pressure depends on postion in the rotation - you can exceed the value of the pressure over the value of the mass. To consume it all you would have to do is drain the system - and replenish the water - but to use a portion of the pressure - and then let it return by gravity during the rotation - there is no consumption of the air or water. It is a sealed closed system.
Now - add a buoyancy system inside the tubes - you have both pressure increases and Free Buoyancy - the buoyancy turns off and on with the pressure changes as well - but does not add to the cost of the tubes.
Our system - uses three energy sources - the pressure increases, the buoyancy and the equalization to another Z.E.D. Instead of letting the system go back to zero by dumping (venting) - we reuse it.
We recycle the pressures - and capture the buoyancy - works very, very well.
The "Travis Effect" showed me how to do the same thing - without the rotation - faster and larger surface areas.
Instead of rotating the incredible masses - just the input to one "tube".
Wayne Travis
hey seamus troll... all of your 65 posts... all in this thread alone.
troll much? or is this some personal vendetta similar to that nutjob tinselkoala/alsetalokin?
"Nice metaphor but it isn't how gravity works."
that was funny as shit... i'm going to print that and frame it! and then you admit to not knowing how gravity 'works'... but you 'know' that that's not the way.... ::) idiot.
Nice metaphor but it isn't how gravity works. (If the truth be known the mechanism by which gravity occurs is not fully known by current physics but we can characterise its effects accurately using newtownian mechanics at normal scales).
The pictures show the 4 layer, and 3 layer system at Stroke PSI. The 4 layer has a higher PSI, but has the same safe outer skirt level as the 3 layer. Some important fields are the 'Water Head Change % over Pod water Level Change' and the Total Force field. This shows that the 4 Layer requires less Pod retainer input water then the 3 layer, while producting more lift force.
A 1 inch difference change in the Pod level can be shown by changing the 'Out Ret. Water Drop' by entering 4.5697 in the 4 Layer and 4.6887 in the 3 Layer from the original 4.38. The Pod force will change by 26 for each 1 inch difference, because it is linear. The Layers force will change 83 for the 4 layer and 75 for the 3 layer or 10.7% increase for the 4 layer at this PSI.
The attached spreadsheets xls files have updates to show the lifting force.
Regards, Larry
@LarryC,
Wow! Nice find. I mean, I could pretty much see that the added layer would increase the output force. But at a reduced water volume change? That I didn't imagine. But maybe this is why the numbers that Wayne is stating for the scaling of the system with layers is not linear and increases at a faster rate with added layers.
Keep it up!
M.
Hello Larry,
My engineers worked the layering system originally from the outside in - this will become problematic later - they had to start over.
Eventually your do not have room for you Pod and gaps.
It is better to start with the pod of choice and work your way out.
The main reason the efficiency increases so quickly is that the output power increases faster then the input costs.
Adding layers is increasing the total Surface area - "Diameter" - without increasing the input volume.
Things are going very well here - and your work is great.
Wayne Travis
Quote from: mrwayne on July 24, 2012, 11:15:10 PM
Hello Larry,
Wayne Travis
Hi Wayne,
Thanks, but there seems to be some confusion as to what my water height calculator is doing.
'It is better to start with the pod of choice and work your way out.' That is what it is doing. Please see the
'Channel SI Calculator' section at the bottom of the spreadsheet. It starts with the pod diameter and uses the entered
'Thickness' and
'Clearance' to build outward. These values are used thruout the calculations to ensure the channel volume's are correct.
'Eventually your do not have room for you Pod and gaps.' Cannot happen.
The main difference between my method and others is the water height calculation logic.
There is two ways to do this, increase the pod water height or decrease the water height in the outer layer, which can be backed into a increase in the pod water height.
If you choose to increase the water height in the pod, the calculations would take many recursive iterations to do it correctly, because as you change values in one layer all values forward and backward need to be recalculated over and over until it settles, or you could just do approximations which is not as accurate. I could have done this correctly with a excel VBA, but it would have been very confusing to most and that is not my goal.
By choosing to decrease the water height in the outer layer, it simplifies the calculations as it does not require recursive iterations and is more accurate than the approximation technique. The decrease in the water level of the first outer layer forces the adjacent column water level to increase. Due to a decrease in water head this causes the air in the next column to expand and forces the next water level down and so forth and so on until the pod water is forced down. Another words, it forces all inward columns to align. You have seen seen that effect with with the previous 5 PSI example, is it correct or not?
Regards, Larry
Just Confusion on my part,
When I read about the "Volume reduction" on the input - I though the pod area was shrinking -
SO I presumed you were trying to fit the four layers into the same space as three.
My mistake - well done.
Wayne
@Wayne,
No problem, it still confuses me at times. Many simple parts forming a complex whole. Which is why it is displaying a lot of unnecessary data, to help keep me straight.
I enjoyed the detailing of your learning quest. During my yesterday morning exercise, seen the last hour of the old Edison movie with Spencer Tracey. He had the same drive, determination and vision as you. When he was trying to complete his hardest vision to create the electric light, the learned naysayers came out in droves, some comparing it to the impossibility of perpetual motion. Sounds familiar. But the natural gas (main lighting source at the time) money baron didn't start abusing his power until his spy's informed him that it worked. Then he started paying off the politicans to fight him every inch of the way. As the same ones are buying off congress today to suppress renewable energy development.
@Artist,
Thanks, much enjoyed your examples.
Regards, Larry
Quote from: LarryC on July 25, 2012, 10:34:43 AM
@Wayne,
No problem, it still confuses me at time. Many simple parts forming a complex whole. Which is why it is displaying a lot of unnecessary data, to help keep me straight.
@Artist,
Regards, Larry
Thanks Larry,
I toured (the extensive tour) Edisons estate - I was amazed at how many of his devices still worked....
I also incorporated his Power naps - when trying to solve complex issues.
What I I think helped Edision - was his relationships with people who could not be "bought out".
Our Success can be directly contributed to our Grass roots support - no one is on Salary - everyone works for the Goal.
Kind of hard to stop a stampede...
Wayne
Quote from: webby1 on July 25, 2012, 11:50:34 AM
Just as an FYI,
I am building a build testbed, to see what I should and should not do and what I need to be careful of.
It is a very small build, 5 inches tall, an outside diameter of approx 2.4 inches and with a 1 inch diameter pod, approx. 1\16 space between things and I am using .008 thick plastic with the ends overlapped and glued. My spacing is not very good, but it is a practice build made out of scrap material,, Tennis ball tubes ;)
Now that I have the 5 risers not leaking I did something stupid but fun, I put them all inside themselves and filled them up with water and grabbed the inside riser and lifted it up and down. Watching this allowed me to see an interesting "gear" ratio occurring between the risers, so for a 1\4 inch lift on the 4th riser the inside riser moved up 1 inch.
I remember those days - that was/is the "New Frontier"
Call it a gear, a lever, a pump - what ever - it is so simple - yet wow.
I used five gallon buckets and PVC pipe with wood plugs in the pipe.
Have fun my friend.
Wayne
@Webby1. Could you please tell us what type of glue you are using?
For those that want to "roll your own," I've looked at some of the various plastic "films" available at McMaster Carr. It was very interesting. Several different types of clear plastics appear to be commercially available in various thicknesses. Some may be easier to bond into tubes (though clear packing tape should be an option?).
For example, go here: http://www.mcmaster.com/#standard-plastic-film/=ikassw (http://www.mcmaster.com/#standard-plastic-film/=ikassw) If you click on polycarbonate on the left you will see that it comes in various thicknesses up to .040" (~1mm). Unfortunately I don't know how small a bend radius you can expect before it "kinks" or shatters.
M.
This stuff would be beautiful to work with and the sizes available might work out, but you'd need to be willing to invest a bit.
The 8" x .250 is $70 per foot
http://www.eplastics.com/Plastic/Plexiglass-Cast-Acrylic-Tubing/Cast-Acrylic-Tubing-Cylinders-Size-Availability-List
Dale
Quote from: webby1 on July 25, 2012, 05:21:15 PM
Polycarbonate sheets have a forming temp of 275 F, so roll your own and put them in the oven to "set" the curve.
Good tip. I've use the same method to curve plastic that was then to be cut into aircraft model canopies. This should be a great way to make clear cylinders of thinner wall thickness which really improves the efficiency of a model.
What are you using for the end caps of the Pod/Risers? The same thickness? Same material?
M.
@webby1,
He he. Well done and a tip of my hat to you sir. Your resourcefulness is an inspiration.
So, one off topic question, purely for my own curiosity. You are French Canadian, no? Please do not respond or just PM me if that crosses any line.
So you are roughing up (sanding) the ends of the "tubes" so they adhere to the aluminum end caps with the RTV?
Also, I'm not sure what you mean by "ring wall spacers?" Please help me to understand.
M.
@webby1,
Any chance for some pictures?
M.
WOw - that looks good.
What is the metal for?
Wayne
Quote from: mrwayne on July 25, 2012, 08:52:13 PM
Wayne
If I may...
I believe that is a custom machined aluminum end cap shown on the end of a tube destined to be the Pod?
I'm impressed
But then, if it can't be built with a torch, grinder and welder.... it's generally outside the scope of my typical shop projects.
Nice simple creative work !
Dale
Thanks,
I thought I had read that you had machined it.
Mine is steel - but with a 30 inch diameter.
As long as it floats :)
The Pod chases the Inner riser during a stroke keeping the air from rushing to the top.
Have you decided how to attach the input?
Wayne
Great News:
Our PCT Examiner cited three other patents - yet determined they were of no particular relevance in analyzing the patentability of the present invention (ours). yes!!!
Also - My attorneys filed the 'three cited' in an Information Disclosure - listing the references.
We ran today - final tweeking - great Data!
Wayne
I used a tire valve stem - with the pin left out.
The Rubber has a nice slot and I glued it for good measure - it held.
Wayne
With the discussion turning to replication and potential materials selections:
A thought that lead to a question, if it doesn't probe too deep.
I haven't dug too deeply into Larry's calculator yet, maybe this answer is there; I'll throw it out anyway.
Selection of suitable tubing sizes for at least the risers ( demo units ) might be easier if... the thickness of the vertical walls of the base can be varied. That's what caused the question: Which is more critical to the successful implementation of the principles ( and maybe the relationship between these 2 is just as important as either independently )...
1. The volume of the air / water contained in the spaces between vessel walls and riser walls.
2. The increase in displacement of the adjacent risers themselves.
IE: Could riser 1 be 2"OD and riser 2 be 2.75"OD if the thickness of the partition separating them was managed to create the appropriate volumes of air and water? Or is that too large a step in displacement?
Dale
It is my understanding that best efficiency is obtained by using thin walls for all risers and lower retaining walls. Like wise the air gaps should be as small as practicable, although not small enough to cause capillary attraction. A cheap material is tinplate [tinplated steel]. It solders easily, but needs a bit of skill to work with. Someone will correct me if I am wrong abot dimensions.
Quote from: wildew on July 26, 2012, 09:59:41 AM
Dale
Dale, I have an older version of a 5 Riser force calculator picture and xls file attached. It uses the 'Riser 5 Diameter Increase' value to account for the clearance and material thickness between the Pod and the closes Riser. With the values set it shows webby1 specification going from 1" Pod to Riser 1 of 2.4", it does not have the retainer wall, so the Increase value would need to be adjusted lower to get webby1 actual Riser 1 size correct.
My newer versions use a 'Clearance' and 'Thickness' value instead, but I don't have any 5 Risers. I can change this one if requested, just PM me.
Regards, Larry
Dale
Hello Dale,
I can not answer definitively on the Small model.
In the large model - we originally built equal layers - thickness and gap, and then we modeled varying the gap - increasing the diameter of the wall thickness is a loss since as the risers move - the air gap above the wall is increased by the wall thickness and the water gap below the riser wall is increased as you stroke - those are minor with thin walls - but thick wall will make a difference.
Also - in our physical testing - you have to allow the air to expand in the system in order to lower the pressure -
If you have too much air in a gap -(by design) you may not be able to move enough to lower the pressure "enough to sink".
Weighting the system can give you a larger range - but you give up some Net to do it.
Here is my point - Sinking is as important as floating - if you plan a 0 to pressure system - and then to Zero again -
That is simple - but you give up efficiency - if you weight the system - you increase efficiency and give up some Net
That is why we suggest the six layer system - it is easy to build and has a nice balance between efficiency and Net.
Lastly - you do not have to match Volumes - equal gaps work almost as well - what you are looking for when matching volumes is to maximize your stroke length - and still Have differential at the last riser.
If you have equal gaps - you will shorten your stroke - in a two Z.E.D system - one side or the other is going up - so stroke length is good - but high Net with short strokes is good too.
I hope this helps
Wayne
Thanks Wayne
LOTS of good info there !
Now I need to go chew and digest a while....
Dale
Hi All,
has anybody done yet an animation, how the prociple works ?
As I did not have much time lately to studay the whole thread I would really like to see the principle
in an 3D animation.
Aynbody out there that can do this and show this in a short movie ?
I guess it would become then also much more clear.,..
Many thanks.
Regards, Stefan.
Hello folks.
Reading up on the later posts, good to see more replications developing.
Congratulations to all who have figured out how the basic principle works, not only as a force advantage but also as an energy advantage. It takes a bit of due diligence and time to grasp.
If you examine the patent closely, and read all that has been presented in the forums, a simple model can be constructed (0ne pod one riser) that can demonstrate the force effect and the gain.
The pre-charge portion of it, maybe not easily understood at first. But then think of it as “priming the pumpâ€. It is required once and stays there for the remainder of the cycles or up until the system is drained. This initial charge is not used to drive the system, only to initiate the cycle. Elastic -air compression- energy storage, kept in the system.
For one pod one riser, make them neutral buoyancy as a system, fully submerged. Compress (pre-charge) to get to the load force needed, move up, (force on the pod is less than force on the riser, diff areas same pressure) end of stroke remove the load, let it expand, move down (sink) to the original level.
For a 2 zed system, let the portion of the pre-charge move to the other side, and use portion of the gain to get to full pressure and so on.
The Sequence shown in post 373 is quite helpful
http://www.overunity.com/10596/hydro-differential-pressure-exchange-over-unity-system/360/
I hope this helps.
Quote from: mrwayne on July 26, 2012, 11:11:58 AM
The clearance issue interested me, because the increased clearance always showed more lift in my original force spreadsheet. So I ran test on the 3 and 4 riser water height calculators using clearance of .25, .50, 1, and 5. It showed that as the clearance increased the compression/expansion lowered as would be expected.
The 4 Riser did not work well showing low lift increase up to 1 and 5 was a disaster, blowing out the Pod water. So 6 would be much worse.
However, the 3 Riser system results were impressive as shown in the attached picture.
Didn't consider the input cost change, but the results are interesting.
Regards, Larry
Quote from: Seamus101 on July 26, 2012, 07:22:42 PM
For this one pod one riser system that demonstrates the principle, the sequence as shown in 373 requires that the volume of water contained by the device increases. I'm assuming then that this cycle can't explain the effect in a one pod system. Can you give an equivalent diagram for the one riser system that clearly shows the effect?
Ok, I’ll try to break this down to the most basic steps - there are few of them for this model construct-, but it'll make it easier to avoid misunderstandings for all the readers who may also follow this.
But lets agree on a very basic conservation of energy for e.g. a frictionless piston/cylinder.
If we compress the gas inside and then release, the piston will go back to it’s original position, no net thermal energy exchange with the soundings due to compression decompression for the cycle etc So basically we compress a gas from Volume 1 to Volume 2 with V2<V1 and then let it go back to V1. So for this full cycle V1 to V2 to V1 everything we put in we got out. Agreed?
Let me know yes or no and I’ll continue.
Good work - and very good to see understanding of the process.
Just a small warning on Gaps - increasing Gaps takes away from the prinicple of operation - it is alluring because of the force gains.
The gap increasing may "putout' more because of the Diameter increase - and that increases your input volume and time of operation.
And be very careful into the expansion volume of large gaps and see if you can handle the expansion and not blow the skirts.
Also - Our engineers' modeling results did not not show much gain from 3-4 layers on up - until they understood the effect the layers and on considering both speed and volume of the reused "head". The value changes with layers and pressure - the higher pressure results in more of the head transferring in free flow mode - which means less work or more stroke.
@ ALL
Be careful not to nail down comments from a year ago - that was when we were testing the closed looped system - extensive testing - since our Data collection model - our understanding has soared.
Current answers are more accurate and so is the understanding - as it is with hands on research.
You can use our long history here as a map of the progress we have made.
One more thing:
Play with the water levels - you can reduce the input pressure without giving up much lift by having the greater differential in the outer (larger diameters).
Stefan - I have 2D running models - but they include some of the improvements - not yet released.
I have put a call into my Animator.
Thank you all,
Wayne Travis
Quote from: mrwayne on July 26, 2012, 09:46:45 PM
...Also - Our engineers modeling results did not not show much gain from 3-4 layers on up - until they understood the effect the layers and on considering both speed and volume of the reused "head" The value changes with layers and pressure...
There must be a tradeoff, the more layers the more water to move inside those thin columns. Total flow ability is reduced plus more water mass to move back and forth. True, more force out (lifting) capability measured at equilibrium states. However; cycle time may have to increase, lowering the overall power out. (in that part of the equation) There should be an optimum mathematical solution for each configuration. (It could be more than one local maxima depending how complex the math gets)
Good stuff.
Quote from: webby1 on July 26, 2012, 10:48:16 PM
Not so sure on that.
If a model could be built, it would of been built.
Rube G. buddy is your friend,,, follow his teachings and BUILD something and stop TALKING,, it makes a huge difference to understanding.
Wow webby1, thank you for the warm welcome mate. But it seems the sneak peek you took into by lab, must have been when the lights were off… I guess no-one should talk, exchange ideas or comment unless she/he has a build to show? ;)
Anyway... nice creative build you have going there, thank you for posting the pics/info.
@All
I very much appreciate the intelligent approach and respectable behaviour being shown by most.
Those that took the time to Replicate the Physics, or the simple math - well done.
Those that experimented in the sink, tub, pool, fishtank - well done.
Those that built replications - Very well done.
Those who came and visited - took pictures - in history -well done.
Those of you who privately discussed the technology in your peer groups - well done.
It has been a joy to share our discovery with you - I hope you have enjoyed and will continue.
Let me tell you the exciting news - first - we are up and running.
Those of you who might want to be part of this - at any level;
Be it getting your picture with the Current machine (show to your grand kids one day) or To joining our Team - Welcome.
It is an honor to have you involved, and as a friend.
Second; We have taken this breakthrough model and have improved it to the point that this model is the "tricycle"
Compared to the Beta Test Models - our improvements are with less parts, fewer conversions and smaller foot prints.
In short - much less complicated and massively more Net Power to serve to the consumer.
As I told Stefan in the beginning - I am not here to claim any prize - but to include those people passionate about the future of clean energy production - we are certainly going to need friends and team members around the world.
Our system is solid as a rock, our IP can not be stronger than it is. The demand for our product ...... it can not be expressed (the demand) - and its Scaleable.
We could be the only viable clean energy system that has a Return on the Investment - in a few years - less in some areas.
Mark Dansie and his personal associates have aligned us with a group of partners for after the validation, and have prepared an awesome validation team. Well Done.
The Adventurers have been aligning with us - in preparation - very quickly, it will not be long before the waves begin.
After this Validation testing and presentation - we will be setting down to a coalition of teams world wide to bring this technology to the world - this could include you - Let Mark or I know - we will include you in the team - if you can join our vision, manage or support the same goals, have a quality character, and ability to followthrough - you will be welcomed.
This Machine is big - big enough for the world. Big enough to include you.
Yes, I do presume we will be validated - and so do those who have replicated the system - again well done.
Z.E.D or Zydro Energy Device
Wayne Travis
HydroEnergyRevolution.com
mr.wayne@hydroenergyrevolution.com
Quote from: webby1 on July 27, 2012, 09:48:23 AM
My bad, I was thinking of a post about simulating and I hit quote instead of reply.
No problem.
Quote from: Seamus101 on July 27, 2012, 01:42:37 AM
Yes, I would agree with that.
Great.
Next we take this frictionless piston/cylinder, and we fully submerge it in water.
We position the cylinder vertically with the piston/rod assembly extending downwards and the cylinder on top. We keep some air in the cylinder (air pocket), and we make the whole thing buoyancy neutral. We can do it as a whole unit or we can make the piston rod with an effective density equal to water, so it is buoyancy neutral and we have enough air inside the cylinder so it exactly counterbalances its own weight. (cylinder also buoyancy neutral)
Furthermore we make the rod same diameter as the piston, and now it looks like a medical syringe (like the old all glass ones â€" keep it still frictionless)
So the whole assembly as it stands now is buoyancy neutral, and has some air in it. And lets say is at level1 inside the water.
Do we agree on the following?
a. If we compress the assembly at that level1 and let go, there is zero net energy for the cycle same as per previous post.
b. If we move the assembly from level1 to level2 and back to level1 there is no energy gain or loss. The assembly is weightless inside the water. And actually even moving from level1 to level2 requires no net energy (weightless-buoyancy neutral)
c. Now, lets do both. Compress at level 1 move (translate) to level 2 decompress at level2 and move back to level 1. Net energy is zero, the translation contributes/subtracts nothing, the compression/decompression cycle is also net zero.
Agreed?
Let me know yes or no, so we’ll continue next with the simplified pod/riser model as you asked.
Quote from: phwest on July 27, 2012, 10:16:57 AM
Great.
Please don't rush through this step so fast. Compress at level 1 --performing work -- this means your formerly neutrally buoyant assembly will now sink, if you are doing it like a syringe or Cartesian diver, since the total water volume displaced by the assembly decreases but its mass is still the same. The external pressure rises as the assembly sinks. Decompress back to neutral buoyancy at level 2 -- that is, back to the same volume it had at level 1 before compression --- against a higher external pressure -- using only the stored energy in the compressed air? Please explain.
Agreed?
Quote from: TinselKoala on July 27, 2012, 11:28:53 AM
Ok for clarity, none of the scenarios a,b,c show any net energy gain or loss after one cycle. Agreed?
Are you are talking about a?
The cylinder can be held in place at level1 and the piston is compressed and let go as previous post net gain/loss is zero. Same situation at level 2 and so on. I’m only describing compression/decompression after submersion at some depth, (level1) for scenario a.
Scenario b?
We can lock the piston/cylinder relative to each other in place, move from level1 to level2, the air pocket is the same (locked no relative movement) so no net energy gain or loss there either.
The piston/cylinder remains neutrally buoyant throughout the motion. Translation of a buoyancy neutral body within the medium requires no net energy. Agreed?
When the piston is allowed to move freely relative to the cylinder, then I take it you are talking about c?
Glad you brought it up. It equals out at the end of the cycle. As it moves up the outside pressure to the piston/cylinder is also reduced, so when it expands at the level 2 the expansion is more than level 1. Any added energy during raise up (or sink) is given back by the “extra†expansion at the top. I left that aspect out to keep it simple. The end result is the same, net gain/loss from level1 to level 2 and back to level1 is zero.
Cartesian diver side note,
True, the Cartesian diver, we can take it down to a certain depth and as the “bubble†collapses it will sink to the bottom. (friction excluded it will keep on accelerating as the buoyancy becomes less and less.)It woluld take an ever increasing force as it sinks lower to stop the fall and reverse up Then unless the liquid is decompressed (air removed vacuum etc) to allow re-expansion of the “bubble†and ascension of the diver. Again just a side note here.
Now we can also take the Cartesian diver at level 1. Let’s say neutrally buoyant. Nudge it up and let it move to level 2. As it moves up it can increasingly lift more weight until we stop it at lets say level2.
To move it back down to 1 is the reverse process (weight substation to stabilize it back to level1) and from 1 to 2 to 1 the net gain/loss is zero,(integral dw*dx for each path and so on) right?
Ok back to the scenarios a,b,c, no net energy gain/loss for the cycle.
Agreed?
Quote from: phwest on July 27, 2012, 12:48:48 PM
For clarity? You are kidding me now, I know.
Scenario b?
I am talking about the same cases that you are talking about. Since you started at Level 1 and compressed, in your first setup, then your level 2 must be lower than level 1. Let's stick with that convention please, since we are trying to be clear. Now... is the piston FREE, or is it LOCKED? In case A the piston must be free and frictionless. Right? The work you put in is returned instantly when you stop compressing the piston. In case C..... you first have the piston FREE, to compress at level 1 (call this C1). Then you must LOCK the piston otherwise it will expand back out to neutral buoyancy. Then you sink to level 2, with the piston LOCKED (C2). This sinking comes "for free" since it is a result of reduced buoyancy; in fact you will have to do work to make it stop sinking at level 2. At level 2, you unlock the piston (C3). What happens? The piston expands until the pressures on both sides are equal.... that is, to lesser volume than it was at level 1 because the external pressure is greater, and you haven't changed the mass of air, just its volume. Now you lock the piston again, but your apparatus is still just a little negatively buoyant, since it is not expanded back to the same volume as it had at level 1 but still masses the same (C4). Hence it will require work to get it back up to level 1. Now, at level 1 again, you can unlock the piston, let the chamber expand, reestablish the correct volume for neutral buoyancy (C1) and NOW get that work back.
But where did the work come from, that raised the negatively buoyant apparatus from C4 to C1?
Did you not just reverse the order of level 1 and level 2? In your first setup and in my discussion, level 1 is above level 2, is it not? Let's please remain clear about this point.
Let's point out that the Cartesian diver is a case where the "piston" is free to move, that is, unlocked, so that it is the water pressure only that changes the diver's volume. There is no "Mr. Hand" doing the initial compression of the internal volume, then locking it against expansion regardless of the external water pressure, as there must be in your a-b-c scenario. In your "b" case, the piston could be locked, as you postulate, or free to move, as in the Cartesian diver. But not both, one on the way up and the other on the way down.
Agreed?
Are we agreed? Where did the work come from that raises your negatively buoyant apparatus from C4, piston locked, back up to C1? In order for things to equal out, for you to get this work back at the top, you first have to put it in from the bottom.
Are you going to tell me that this work comes from the other Zed, at the top of its cycle?
Nice job keeping this focused and detailed TK.
I think he's saying that the external input from gravity that is causing the compressed device to sink is countered by another external input ( maybe a wind powered sail... ) bringing it back up.
OR maybe that IF the energy from gravity were to be returned into this perfect model and applied to lift the device that at the end of the cycle all forces would be equal, energy expended = energy captured.
At any rate, again, great detail. Next?
Dale
I took it that @phwest always meant level2 was ABOVE level1. It was my mistake also at first to assume it was below.
At no point in the examples is the piston assembly moving up or down on its own due to a change in buoyancy I think. I believe he is stating that it must be transferred between levels 1 and 2 by an applied force (work) and that the net gain once returned to the start condition, again by an applied force (work), is zero.
M.
Quote from: TinselKoala on July 27, 2012, 03:21:28 PM
For clarity? You are kidding me now, I know. I am talking about the same cases that you are talking about. Since you started at Level 1 and compressed, in your first setup, then your level 2 must be lower than level 1. Let's stick with that convention please, since we are trying to be clear. Now... is the piston FREE, or is it LOCKED? In case A the piston must be free and frictionless. Right? The work you put in is returned instantly when you stop compressing the piston. In case C..... you first have the piston FREE, to compress at level 1 (call this C1). Then you must LOCK the piston otherwise it will expand back out to neutral buoyancy. Then you sink to level 2, with the piston LOCKED (C2). This sinking comes "for free" since it is a result of reduced buoyancy; in fact you will have to do work to make it stop sinking at level 2. At level 2, you unlock the piston (C3). What happens? The piston expands until the pressures on both sides are equal.... that is, to lesser volume than it was at level 1 because the external pressure is greater, and you haven't changed the mass of air, just its volume. Now you lock the piston again, but your apparatus is still just a little negatively buoyant, since it is not expanded back to the same volume as it had at level 1 but still masses the same (C4). Hence it will require work to get it back up to level 1. Now, at level 1 again, you can unlock the piston, let the chamber expand, reestablish the correct volume for neutral buoyancy (C1) and NOW get that work back.
But where did the work come from, that raised the negatively buoyant apparatus from C4 to C1? Did you not just reverse the order of level 1 and level 2? In your first setup and in my discussion, level 1 is above level 2, is it not? Let's please remain clear about this point. Let's point out that the Cartesian diver is a case where the "piston" is free to move, that is, unlocked, so that it is the water pressure only that changes the diver's volume. There is no "Mr. Hand" doing the initial compression of the internal volume, then locking it against expansion regardless of the external water pressure, as there must be in your a-b-c scenario. In your "b" case, the piston could be locked, as you postulate, or free to move, as in the Cartesian diver. But not both, one on the way up and the other on the way down.
I see where a mixup might be coming from.
Level2 is higher than level 1.
I also stated:
“â€â€Now we can also take the Cartesian diver at level 1. Let’s say neutrally buoyant. Nudge it up and let it move to level 2.â€â€
I ‘d think that the readers follow the movement from level1 to a higher level2, but you assumed Level 2 was lower. I apologize for the confusion if it wasn’t fully clear. (also to remotely refer diagram post 373 level1 is lower level and move up to higher and then back down etc)
Ok,
For case a it is irrelevant if level1 is lower than 2.
For case b where the piston/cylinder is locked still irrelevant. You can move it anywhere there is not net energy gain/loss. Are you stating differently?
“Translation of a buoyancy neutral body within the medium requires no net energy. Agreed?â€
So for case a and b there is no net energy for one full cycle correct?
Case a, no movement between levels, cylinder is held fixed, buoyancy neutral,l piston compressed and released, expanded, everything we put in we get out.
Case b piston locked with cylinder, with enough air inside to make the whole thing buoyancy neutral.
Move it anywhere from anywhere, but for this case from level1 up to level2 and back to 1.
No energy net gain/loss right? I’m only looking at translation of a neutrally buoyant body inside water fully submerged.
Ok back to case c.
Your statement:
“In case C..... you first have the piston FREE, to compress at level 1 (call this C1). Then you must LOCK the piston otherwise it will expand back out to neutral buoyancy. Then you sink to level 2, with the piston LOCKED (C2). This sinking comes "for free" since it is a result of reduced buoyancy; in fact you will have to do work to make it stop sinking at level 2..â€
“….But where did the work come from, that raised the negatively buoyant apparatus from C4 to C1?
Again, the model presented is based from level1 (c1) to higher level2 (your c4?),
But no problem with moving lower, actually we can extract work while it is sinking, and that work can be used to bring it back up again. No net gain/loss. It is sinking so there is a net force on it, moving for some distance, then it can produce work. Integral of df*dx. As I said earlier that work equals to the amount needed to bring it back up. No free lunch there either.
For case c, all I’m saying is, there is no net energy gain/loss moving from level1 to level 2 and back to level 1. I cannot see why we do not agree on this.
Conservation of energy holds.
Nowhere so far I’ve stated or shown any net gain or net loss for one full cycle.I’m only attempting to establish the basics, and simplify as much as possible.
From level1 to higher level2:
At level1 we have a piston/cylinder with enough air to make it buoyancy neutral. Net forces on the system are zero. This is where we start.
1..We can lock the cylinder/piston relative to each other, move it up to level 2 (zero energy in or out) unlock the piston at level2 and it will expand to a volume greater than the one at level1
Of course, after the unlock and piston is free to move, it will no longer be buoyancy neutral.
The translation gave nothing, but the expansion gave something more than the original at level1.
That’s not free energy, we moved up to a lesser outside pressure.
Now to move it back down to level1 it will require some work. That work equals to what we got from the extra expansion up at level 2. Right?
Or 2.. we can just nudge it up (piston unlocked) and it will start and move up to level2 where we stop the movement.
Now as per previous post - last paragraph Cartesian diver-
“As it moves up it can increasingly lift more weight until we stop it at lets say level2.
To move it back down to 1 is the reverse process (weight substation to stabilize it back to level1) and from 1 to 2 to 1 the net gain/loss is zero,(integral dw*dx for each path and so on) right?â€
Your statement:
“â€Are you going to tell me that this work comes from the other Zed, at the top of its cycle?â€â€
I haven’t involved any ZED or a two systems interconnected anywhere so far
I think we are making this unnecessarily complex…
Bottom line is for cases a,b,c and for each full cycle there is no net gain/loss yes or no?
In your first post of a-b-c, you said this:
Quotec. Now, lets do both. Compress at level 1 move (translate) to level 2 decompress at level2 and move back to level 1. Net energy is zero, the translation contributes/subtracts nothing, the compression/decompression cycle is also net zero.
Does this not imply that level 1 is higher than level 2? You are compressing the volume, reducing the buoyancy, then going to a lower level, are you not? So I still think you have flipped your level definitions on me. But no matter, let's use your redefinitions, where you are now using Level 1 to be lower than Level 2.
You start at Level 2, neutrally buoyant. You perform work C1 pushing in the piston to reduce the volume. If your piston is FREE it pops right back out. If your piston is LOCKED, it is not a Cartesian diver. So now you have a locked piston, that is, a FIXED volume. Now your apparatus sinks to Level 1 and you must do work--- or rather oppose the effective unbuoyed weight -- to prevent it from sinking further, since it has been negatively buoyant since you compressed the air and it will continue to try to sink as long as this is true. Now you release the piston and we have a Cartesian diver again: the air expands until the pressure on both sides of the piston is equal. But this now happens at a smaller volume than before. You still have negative buoyancy, and you are not yet back to the Cartesian diver neutral equilibrium, in fact you are in the position where the diver wants to sink, not rise. So where does the work come from to get you back up from Level 1 to the higher Level 2? You are not yet at the end of the cycle so there hasn't been any work returned yet.
One of us is missing something. I am perfectly willing for it to be me, but so far you haven't convinced me.
In the Cartesian diver, where the piston is always free and the compression and diver volume change happens naturally from without, as the outer water pressure is changed, then yes, I agree with your conservative scenario. I do not think this is equivalent to the situation you have described, though, where you are compressing the apparatus without compressing the external water, and where you are locking and unlocking pistons.
(Sorry, edited some confusion about level one and two.)
Instead of starting with a neutrally buoyant syringe of air... let's just use vacuum. After all it is the volume that controls buoyancy, and the mass of a bit of air is negligible, it might as well be vacuum from a weight/mass standpoint in these small volumes.
So we have our "diver" with neutral buoyancy and a locked piston, at the higher Level 2. We now unlock the piston, and the vacuum "sucks" the piston in, reducing the volume. We lock the piston, fixing the volume. Now obviously the diver sinks, and we catch it at the lower Level 1. Now we can lock or unlock the piston..... but how do we now return up to Level 2?
Quote from: TinselKoala on July 27, 2012, 06:09:23 PM
No. You start at Level 1.
You start at Level 1 and then you RISE (not sink) to Level 2. The rise is not due to a change in buoyancy. It is caused by an outside force being applied.
M.
Sorry, weird forum thingy...
I was going by the before your edit, I just refreshed and saw the edit note the original is lost but here is the reply:
True, hat statement in itself does not explicitly state level1 higher or lower than 2 but others as I note in the previous post do and/or refer so.
It always started at Level1 for the full cycle. I cannot see where I posted starting at level two for cases a,b,c.
The model presented, always uses level2 higher than level 1. (it works the other way too but let’s stick with level2 higher than level1 for consistency)
Level1, we start at buoyancy neutral and then we compress the piston then lock it and then move up. The move up requires energy since some buoyancy is lost due to compression. (loss of neutrality as we both agree)
At level 2 since the outside pressure is less, if we unlock it, It will give all the compression energy put in at level1 plus some due to the lower outside pressure, more expansion etc.
So we had to provide energy to move it up, but we got out some extra due to the higher volume expansion, the extra equals the energy we used to move it up. That extra expansion energy we can use to move it up. Nothing gained or lost
Similar in reverse if we move it back down from 2 to 1 so the full cycle is completed. Net energy is zero from level1 to level2 to level1.
All I’m saying is either locking it first and moving it from level1 to level2, or starting uncompressed (some air but buoyancy neutral) and then nudge up, after the full cycle nothing is gain or lost (friction and rest excluded)
Ok so we agree as you stated on the energy conservation scenario, but the issue is with technical description of what is happening. As I said I left that out earlier so it will be simple.
Then we are in agreement for a,b,c scenarios in one full cycle net energy gain or lost is zero.
I’ll wait to hear from seamus1 also before going to the single riser single pod next.
Maybe we can pick up the Cartesian diver analysis if we have time in another thread.
All right, I misunderstood you at first, then, since I could not imagine why you might want to compress, thus doing work to reduce buoyancy, then RAISE the volume, doing extra work. I still can't, off the cuff, but I don't have time to rethink it now, so please excuse my earlier misunderstanding and carry on.
(We have all this time considered adiabatic compression and expansion, with no heat loss to the surrounding cylinder walls or water, right? These losses will of course mean that, even if I do agree with your conservative ideal a-b-c scenario so far (reserving judgement here) in the real world this heat loss will require outside energy to replace.)
OK, so you start at lower level, with free piston, neutral buoyancy B0, and internal pressure P0 = external pressure E0. You compress the piston and lock it, performing work on the system by reducing the volume, raising the internal pressure to P1 > P0, and decreasing the buoyancy to B1 < B0. Then you perform further work to raise the syringe to higher level. The external pressure is now lower than E0, so when you unlock the piston it will go out further than it was at the lower height. Then you lock the piston. You now are displacing more volume than you were at the lower level, so you are more buoyant than neutral, that is, B > B0. How do you get back down to the lower level?
Quote from: TinselKoala on July 27, 2012, 08:00:51 PM
No problem. Misunderstandings are usually part of these exchanges. It’s all in good fun.
Yes, on frictionless, adiabatic vs isothermal, ideal gas approximation etc. I think I noted these conditions in the very early posts. Agreed, for the purposes of the model constructed, heat losses, transfers in out, would be set aside, but in the real world they are part of the package even if they can be very small.
Quote from: Seamus101 on July 27, 2012, 08:00:56 PM
I think see where you are going with this and initially I'd considered it a candiate for a 'wow' this is the working principle that explains this. Alas, I think you have missed something that does not allow it but however...
I'd agree that translation of a neutrally buoyant object in a frictionless environment is energy neutral. That in itself is no use to us, but I'd predict you are about to introduce the concept of somehow 'capturing' buoyancy at a one level, using this energy neutral translation to transfer this 'capture' to another level and thus this 'captured' buoyancy could then be used to exert a force between level one and level 2. If that could be made to happen then that would be the working principle and this device would work.
Correct?
No wow moment shown so far. I understand where you are coming from , I was there also on this, but that is for another discussion alltogether.
All I’ve been attempting to do is to establish base lines using simple physics, understood by all who would follow, so we can build on them for the next steps. Your prediction, yes in the ball park I think. But you can be a better judge of what you exactly describe when we continue later on. So far no laws have been “broken†as we know them, physics hold well
So you do agree with a,b,c scenarios in one full cycle, net energy gain or lost is zero?
Quote from: TinselKoala on July 27, 2012, 08:14:31 PM
I know, I was looking similar questions among the many, when I got into analyzing this.
Actually we don’t have to exceed the -more than neutrally buoyant level of expansion- at level 2. At level2 even at that amount of expansion, it has expanded more giving some extra energy. So at levl2 we got out what we put in as compression at level 1 plus some extra. The extra can be used for raising it… So now at level 2 it is neutral buoyancy, it only needs an nudge to fall back down, and it can also produce some work as it is doing so. ( the more it lowers the more it weighs and so on), up until it arrives back down let’s say to a support or stop at level 1, end of cycle.
We can compress it just enough at level1 so when it reaches level2 is at exactly buoyancy neutral state..
Bottom line is: what we put in at level 1 as added compression we get out at level2 plus some, and the -plus some- helps/pays for the lifting cost of the less than buoyancy neutral body (after compression at level1)
Next cycle same as the first, we recompress ( using the “what we got out is what we put in†at level2) and repeat. Again no net gain or loss out of the full cycle. Conservation of energy holds. Keeping it simple that’s all.
Side note on scenario c :
There are many ways but all result in the same bottom line.
For example,
We can compress, lock, lift, expand, push if needed back down(depending on expansion amount at level2, and repeat.
We can start buoyancy neutral at leve1, no lock, nudge it, it lifts by it self to level2. Producing some work as it ascends, we use that work to compress it (at level2 back to the volume of level1) and lock it. Then it can sink with no added energy, (locked in buoyancy neutral now), back to level1 release the lock, it goes nowhere, nudge it up and so on. Ok maybe have we talked enough on this.
Bottom line is still the same, no net gain or loss, what ever is put in it is taken out during a full cycle.
Quote from: Seamus101 on July 28, 2012, 02:53:50 AM
I agree that all three a,b,c scenarios are energy neutral. No gain or loss in a fictionless cylinder during a cycle.
The' bottom line' comment is bordering on not being true though. There is no 'plus some' that could ever be extracted as usable work. It can only ever be exactly the the same effort input or extracted. I'm not sure if you meant that or not.
So far we have described a system that could move about with no energy input but without the ability to extract energy from it. What happens next?
Correct, that’s what I meant.
That -plus some- stays inside the system, is not extracted, it is not over unity, it is part of the cycle. Again as I noted earlier, that was the reason it was left out in the beginning so we can keep it simple. The initial pressurization at level1 stays in the system and just gets recycled. All we did for the cycle is, compress, move up, decompress, move down.
So far no net energy extraction has taken place, no external weights lifted, no external mechanisms are driven. It is obvious, no debating should have been be required.
Great, we are in agreement on a, b, c
Ok let’s move next the one pod one riser model.
Now to one pod one riser. Use as ref the patent with one riser only, also refer to video 5 but there use straight walls, the inverted cup is the riser, the cement is the pod, its top area Ap is smaller than the cup area (riser) Ar, Ap<Ar.
(the riser is the cylinder and the pod is similar to the piston/rod but with Ap<Ar)
At Level1
Everything is fully submerged, there is some air under the riser (air pocket) to counter balance the riser’s weight. The riser is buoyancy neutral. Let’s immobilize the riser at this level.
The pod is designed to also be buoyancy neutral. Next insert the pod under the riser so the pod’s top surface is at the same level as the water level under the riser (cup). The pod has not broken that surface, no added pressure there, the riser is still buoyancy neutral and has not moved. The pod is also buoyancy neutral inside the water. No energy need moving it inside the water.
The riser is immobilized so it cannot move vertically. It stays at level1 for now.
Next push up the pod, lets say half way up for simplicity into that air pocket.
What is going to happen?
We compress the air (precharge) and also create a head differential that equals to air compression at pressure P greater than what was there before.
The head differential is at the gap between the pod wall and inner riser wall. (remember Ap<Ar)The riser, (cylinder) has not moved yet. We are holding it in place, immobilized with e.g. a pair of large pliers from its outside sidewalls etc.
At this state, let’s do a simple free body diagram on the pod and then on the riser:
The pod, we are pushing up with a force Fp and that force is P*Ap where Ap is the surface area on top of the pod. Fp=P*Ap plus some exposed pod weight above that water surface.
The riser sees a force Fr=P*Ar where Ar is riser area and Ar is greater than Ap and Fp<Fr
The riser is held in place by pliers so the reaction at the plier contacts is also Fr, the riser has not moved yet.
Now lets drop/place a weight W equal to Fr , W=Fr on top of the riser, then release the pliers. Nothing moves.
The riser as it stands now is again buoyancy neutral inside the water. It is still weightless inside the water.
So if we push up the pod with just an infinitesimal additional force the whole thing will move up lets say to level2 .
Now what just happened? With Fp<Fr we moved W (Fr) from level1 to level2 (distance x)
For the move we have EnergyIn = Fp*x and EnergyOut = Fr*x=W*x
But Fp<Fr then EnergyIn<Energy out.
At level 2 we clamp the weight W, and we clamp the riser. The riser is now at level 2 and cannot move anywhere.
Then we release the Fp so it expands to the same position relative to the riser similar to before precharge at level1. (top of pod moves back down to water surface inside the pocket, head moves up to its original position and so on)
Now we are back to the same state as level1, unclamp the riser, next we move the riser/pod back to level1 ( they are buoyancy neutral similar to scenario c) (yes the added expansion due to x comes in place but adds or subtracts nothing, as we discussed before, the exposed pod weight is also returned no net there so we leave all these out)
With every cycle we are gaining (Fr-Fp)*x
(If we run actual numbers the net gain is small with one riser, but can be increased with more risers, Ar total becomes greater for the same Ap, and so on) The assistance comes from the head differential which moves along throughout the x movement without any additional outside help. In this model, the head is created by precharge at level1 and given back at level2. That whole move along is cost free energywise but the travel is limited. The head differential is max at level1 and smaller at level2. Look also at diagrams post373 and patent. The change is not linear, we could let it go higher than levl2 but at earlier portion of the travel we get the higher advantage.
The precharge itself is intact energy wise, whatever we put in it was given back and so on.
The pre-charge is not used as an energy source during the cycle. Whatever is compressed at the lower level is given back when it expands at the higher level. Same as the piston/cylinder example earlier posts.
If a simple theoretical model/math does not work, then physical models built should not work either.
On the other hand, and to keep it simple, if a simple theoretical model/math does work so should the physical models built.
Ok over and out for now.
Quote from: webby1 on July 28, 2012, 12:39:04 PM
small sidetrack from the current discussion :)
I am still working on my test build testbed, I am mounting it onto a base and all that stuff and will be attaching the head extenders after that is done and checked for leaks.
One thing I have done to make it easier to distinguish between risers is to color the bottoms of the risers, hopefully that will also allow me to see the difference between air and water.
Would be nice to some pics or even video when its done. :)
I am sorry, but I keep choking on some points. Please help me to understand before rushing on.
Quote from: phwest on July 27, 2012, 11:10:22 PM
Wait a minute. So you are stopping the piston before it reaches its full travel, then, leaving the pressure on the inside greater than the outside.If the device was neutrally buoyant at a certain volume at the lower level, you cannot let it expand to a greater volume at the higher level without also making it positively buoyant. Therefore you must stop the piston before the pressures inside and out are equal. You no longer have a Cartesian diver if the piston is locked, so you don't get your dynamically unstable "hover". The CD's behaviour depends on its "piston" being free and all volume change a result of applied external pressure from the surrounding water.
QuoteAt level2 even at that amount of expansion, it has expanded more giving some extra energy. So at levl2 we got out what we put in as compression at level 1 plus some extra. The extra can be used for raising it… So now at level 2 it is neutral buoyancy, it only needs an nudge to fall back down, and it can also produce some work as it is doing so. ( the more it lowers the more it weighs and so on), up until it arrives back down let’s say to a support or stop at level 1, end of cycle.
Not if the piston is locked, which it must be for your first condition to hold.
When, in the limit of zero difference between levels? If it's neutrally buoyant at volume V0... it will not be neutrally buoyant at any other volume. The amount of water displaced, hence the buoyancy, depends on the volume doing the displacing. Change the volume by moving the piston in any direction.... which is required to compress or decompress the gas... and you are no longer neutrally buoyant. And if you lock the piston so the outer water pressure does not equalize the inner air pressure by moving the piston and changing the buoyancy, you don't have the dynamically unstable CD and your height changes don't come for free.
For example,
Bottom line for me is that there are still some equivocal points in your analysis that I'd like cleared up before charging ahead. I've tried to keep it simple by sticking to your original description (once I got it straight) but now you are playing around with stopping pistons before they've fully expanded, and other things that seem non-physical to me.
How do you change the pressure inside the syringe without changing its volume hence its buoyancy? It seems that your above explanation requires this, in addition to requiring CD behaviour even though the piston must be locked.
If you want to specify clearly that the initial compression is part of your full cycle, and that ALL components, water levels, volumes, diver levels and internal and external pressures arrive back at the starting point of your full cycle, then I'll happily stipulate that you are correct even if your details are a bit muddled ... so far. But I'd really like to see you put that statement out there, explicitly, listing all conditions that have to repeat exactly to count as a full cycle.
In other words... how do I tell if a cycle, or tens of cycles, have occurred, between observation T1 and the later observation T2, both taken at the same point in a cycle?
Quote from: webby1 on July 28, 2012, 03:16:58 PM
But of course!
One thing I think I should mention about this device I am playing with,, it is very sensitive to the way it is setup.
I have found,,by accident so far,, that there are sweet spots in the setup. When you find one of these the lift value is much higher and the water pressure on return seems to be more for a longer return value.
Also, there is a difference in the lift compared to just letting the system lift right away and holding the system still until full lift pressure is met.
Yes, good for you. May I suggest that you also make yourself a simple Cartesian Diver and meditate upon its workings, if you haven't? It's a simple situation where the buoyancy depends on the pressure from the water, changing the volume of the air that's inside of the "lifting" element. Sound familiar?
Quote from: microcontroller on July 29, 2012, 08:11:34 AM
Too bad people are wasting their time and money on this while they can save it for real projects.
Anyway, My previous prediction was dead on, and came true yesterday.
So it is time for my new prediction.
I predict that this clow.. i mean man is going to ow us all an apology, but he won't apologize, not to us...
I predict he will leave with a silent drum to be heard of never again, once he finds out the error in his measurements.
I also predict once more that in the upcomming 20 pages we will not see any proof of the Travis effect producing any OU nor will we see Mr. Wayne answer the critical questions he is avoiding.
I will be back in 20 i will see you there.
I'm with Seamus !
oh my gawd! you're a prophet! the world has been waiting for you! ::) where can i send you my money? ::)
i'm sure you'll be counting the pages... just like last time. ::)
Quote from: Seamus101 on July 29, 2012, 06:02:45 AM
Learning how to measure things properly and understanding the working principles are equally important.
but not necessary to make something work...
I have a mechanic that could fix my car but also believed in the whole HHO lie, primarily due to a lack of diligence in measuring the result. I also have plumber that could fix my pipes but who also believed I'd get increased pressure by constricting the flow with a nozzle. Getting my hands wet is no use if I approach it without understanding.
so your mechanic could fix your car... and your plumber could fix your pipes... regardless of their 'beliefs'. did you have a point here? cause the point you're making isn't the one you want to make...
I have been away a couple of days, and just catching up on developments. Congratulations to Webby1 on that build. It looks as if you are the first one with a real world model replication. I am not in a position to build anything at present owing to very poor eyesight. I am still trying to decide whether to risk having surgery on my one remaining working eye, or be satisfied with the limited sight I have. Either way I shall follow you progress with great interest.
I added a VBA macro to the water height calculation to simulate an animation of going from Initial Pre-Charge to Full Pre-Charge as the Start value is reduced by .01 increments. The chart now shows the Water and the Retainer/Riser heights.
First position the spreadsheet as shown in the attached picture. Then by pressing Alt plus F8 the Macro box will come up. Press Run and the system will show the water level changes as it goes from Initial Pre-Charge to Full Pre-Charge. After 10 seconds, it will reset back to the start position. The speed can be slowed down or increased by changing the 'Increase to Slow down' value. It will run in the free Open Office Calculator, but it requires a few extra steps after Alt plus F8.
When opening the spreadsheet a screen will be displayed about the Macros. Press Enable Macros. After it opens you can check the Macro by going to Tools - Macros - Visual Basic Editor to review the code, before you run.
Enjoy, Larry
PS: I am working on another version which will show the 3" production rise changes.
Pretty amazing work:
Our end is going well:
I took off for the weekend to be with the family - they had to drag me out of the lab - then put me in a ski jacket.
The room is still rocking - slowly.
I am very humbled by the value of the contributions - the excellent logic, the physics, the modeling -
With the effort you have taken - you are at least on the verge of understanding how we attain O/U - most likely far beyond it.
Nothing beats physical testing - I guarantee to you Webby is having fun!
I see the thugs, bugs, and baiters visited while I was gone - thank you for not spending too much time on them. No, I do not really expect an "apology" - they just owe it. I will be very impressed if they have it in them to apologize - I do hope for the sake of their own character.
Remember - Our "Day" is when we start providing Energy Independence to the World - That Day is approaching with great speed.
Wayne Travis
You all are a part of history - in the making.
Clean Energy - finally.
We are having a fine day with our system running today - and lots of challenges - it is like climbing a mountain.
I am looking forward to the next two weeks!
I just re-read through the Logic Process by PH - very good.
Wayne
@Webby1. Congratulations. Heroic work indeed. It is very encouraging that you have already shown OU to your own satisfaction, albeit not yet repeatably. I do not doubt that you will need to spend a lot of time tuning to find the sweet spot. You have already achieved an incredible amount in a very short time. I would be very interested in what you are using as an input pump, and how you are measuring input energy. It seems to me that you will be the first person to show OU in a real world replication, which to me will prove more than all the mathematical analysis in the world.
@Mrwayne. Your website does not appear to have been updated this week. I am sure we
are all anxious to hear what progress you are making towards the Mark Dansie tests.
Well Done Webby,
I am sure you have just inspired many more replications.
You are now - In the Know - lol.
Our system is a lot more friendly - adjustable in most every way - lends to more discovery. I will be glad when the variables are fixed.
Hello Neptune:
Honestly - SUPER BUSY,
Right now I am packing to leave for a funeral - and will be out three days.
We will resume when I get back.
Don't worry - the world will know of Mark's report - "It will be...... when it will be" - that is the only exact time table.
Great Job - Great people
Wayne
@Mrwayne. So sorry to hear that you have a funeral to attend. Can I express my condolences.
I have a tendency to be impatient sometimes.
Thank you Very Much.
Wayne
@Webby1.Looks as if you have been busy. I like your use of a water column as an input pump. It looks like you are still at the tuning stage. There are a few questions I would like to ask, if you wish to answer them .
1. You talk about adjustments to the pod. Apart from the water level in the pod chamber, which you mention, are there any other pod adjustments that one can make?
2. Is your apparatus fitted with any air vent valves for use during the initial filling process? In an earlier post, I suggested a filling method that required no vents.The method was to clamp down the risers, and then force water into the inlet until it overflowed from the outer vessel. Then force air into the inlet until it bubbles from the outer vessel.
I am impressed that, as a result of your mathematical analysis, you were confident enough to invest time, energy and money into a build. As regards the tuning process, I would have thought that apart from the water level and stroke length, and ballast weight, there are only a limited number of adjustments you can make. So sooner or later, you will derive "rules of thumb" to enable you to do an optimum set up, whereby you will be able to virtually guarantee best performance every time. I am certain that I don`t need to tell you how important your work is, because in my opinion, once we have the first independent replication with unquestionable proof of OU, then the Genie is well and truly out of the bottle.
Should anything happen to prevent Wayne continuing with his work[heaven forbid], there will be no turning back.
Hi Webby1
Nice work.
Based on all of the information presented prior I would focus on only about a half inch of travel, even that might be a bit much for a system of that height. It looks like you are trying different weights, that is probably significant. Wayne even stated once that the system works better when it's working harder and I think I might be starting to understand why.
Dale
I just had a thought that might be useful or it might not. If we run the device through a complete cycle, we need to input water under pressure to cause the lift. Then , to lower the risers, we need to let some water out of the device, and release some pressure, but not all the pressure. Here is a low tech way to achieve this. Webbby1 is using a vertical tube full of water to inject water into the system. To extract water and pressure for the downstroke, that vertical tube, which appears to be connected to the device by a flexible pipe, simply needs to be tilted over to a predetermined angle, to reduce its head pressure. The vertical tube needs to be long enough to contain all the ejected water. Not certain how you would then measure input energy. Just a thought...
On a personal note...
I spent about 3 man hours opening the casing of a refrigerator compressor that I had to have replaced. My goal was to find the "mechanical" lockup since all the (pre replacement) electrical tests seemed fine, except for current draw.
Found no problem. Everything moved nicely. So I tried to disassemble for my own learning, but also because I think little pistons and connecting rods are cool.
I was disappointed that the unit had obviously been manufactured only for assembly, and not disassembly or maintenance (Why would it not be? Its in a sealed steel pod!). But I did the best I could to take it apart with the tools in my garage. And I succeeded! But with a piston that broke its skirt when I had to punch out the piston pin after not being able to remove the roll pin that secured it.
Either way, I learned a lot.
A question: I found no permanent magnetic properties in the stator or rotor. Anyone know why?
I've heard from Dennis and Larry and they are both hard at work and about ready to reveal new information.
Oh, and webby has got some great updates coming.
Just thought I'd offer this info up.
M.
Quote from: mondrasek on August 04, 2012, 06:54:48 PM
M.
No PMs? The stator and rotor must be field wound EMs that are powered by the main supply.
Curiosity costs nothing if it is already broke ;) ......
I am back from Atlanta Georgia, it was only 88 degrees there - 108 here in Oklahoma.
Status on the ZED, we have been running - but with a loop of irritating small issues (mountain climbing - little mountains).
Our Mechanical team met and we have decided to put each of the issues to bed.
Since last Thursday - while I was gone - two of the five were put to rest.
The parts to fix two more were ordered - over nited and will be here Monday.
The last step is to pull the system and weigh the parts to see if they are equal.
We are also replacing any plumbing we had repeat leaks on - and using the new installation tools and torque settings.
We over torqued and caused leaks....drat....
The Great News
Both Sides of the Zed are over unity - just one side is a lot better than the other.
I can't wait to see what Larry and Dennis have? ??? ??
I have had three more Mathematical Replicators write me while I was gone - Well Done!
Wayne
Quote from: Xaverius on August 04, 2012, 07:25:01 PM
X, the stator is EM for sure. And the stator circuit is switched from first including a start up capacitor and charging all stator poles (several dozen) with the AC input power to (my guess) only every other pole once the compressor motor is up to speed and that start up cap is removed from the circuit. But the rotor appears to be just laminates of silicon steel. The outside of the laminates are perfectly cylindrical. How would this rotor be attracted by a rotating magnetic field from the stator?
If someone has a quick answer, great. If not, pls PM me so as not to clutter this thread.
M.
Quote from: mondrasek on August 04, 2012, 10:10:10 PM
M.
http://www.globalspec.com/reference/10791/179909/chapter-3-ac-and-dc-motors-ac-motors-ac-induction-motor (http://www.globalspec.com/reference/10791/179909/chapter-3-ac-and-dc-motors-ac-motors-ac-induction-motor)
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indmot.html (http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/indmot.html)
The aluminum bars are sometimes hard to see without removing the aluminum end ring, but they are there. You usually can see the small bright slanted edges along the laminate.
Regards, Larry
Hello All,
I am calling "Webby" - the winner of the replication challenge, and I sent him the $2000
Nothing like getting your hands "Wet" I have already heard from several people who copied his work - and or improved upon the Tennis Ball container Z.E.D. or the "TBZED" construction experiment.
PhWest found a plastic bottle company that sold plastic bottles incrementally sized.
Time, Distance and Mass - does not lie - We are very Overunity - Great Job Team.
It is your work - being the good skeptic - doing your due diligence, searching - discovering - that is helping to bring freedom - in many forms to the World.
Excessive heat - has caused transmission failures - Extreme load on the Grid, Grid failure has caused massive outages - during the heat.
Many fables have been wisely written warning against putting all your eggs in one basket - when whole communities can be shut down - that is a bad thing - it gives too much control over free people.
Recent Nuclear power and even past events - give clear rise to the need for safe and clean energy -
We have been blessed with a solution - together we can make this happen, individually and together.
Never underestimate how important your single contribution will be to the future.
Never expect support from everyone - just do what is right - do it now.
Thank you Webby, and others that have helped.
To Webby, if you would like that flight down - to visit our lab and team - get your picture for our book, price it and let me know.
Thanks Again, you who seek the truth - have humbled and honored me - but lets keep this about our future - a future that is changing before your eyes.
I look forward to the next level - from Dennis and Larry.
Thank you Neptune for carrying the torch!
Wayne Travis
Each Freedom in its time..... Thank God.
Let me be among the first to congratulate Webby. If ever a guy deserved a reward for a replication, he is that guy. As I have said before, he was already sure that this would work, based on his own meticulous mathematical analysis.But he did not stop there. He was prepared to get his hands wet and dirty, gather some recycled materials, and spend some time working with tools.Methinks we shall here more from this man.
phwest has already made a great contribution in his previous "thesis" on how this technology works. It would benefit the community immensely if he could provide a link to the source of these incrementally sized plastic bottles. That on its own would facilitate more replications.
I know I have said this before, but the thing that blows my mind is the essential simplicity of the basis of this technology. It is still to me a staggering thought, that the Ancient Romans could probably have built a pair of Zeds, to power, say, a water pump.
That of course does not detract from the brilliance, and originality of this system.I am proud to have played some small part in the discussion even if it has been mainly in the role of "cheerleader". Here`s to many more successful replications.
Quote from: neptune on August 05, 2012, 10:34:27 AM
Way to go Webby1, you're an inspiration to us all. We need all the encouragement we can get, keep up the good work!
Congratulations Webby !!
History in the making.....
What an honor and opportunity to be such a part of it.
Dale
Webby Well done ;D looking forward to seeing a self-runner
Congratulations Webby. Its been fun watching your progress.
Congrats Webby. My motto: 90% of winning is showing up!
Good job, Webby.
Keep building.
Sometimes we all need to get out from behind the keyboard and take action.
Excellent job and congratulations!
Tom
Hello Weeby, my English is not good. Could make a video or a simulation or a drawing explaining the procedure to have a better understanding? thanks and regards.
Nice work Webby. ;] And on the cheap! Good idea with the color codes on the tubes. ;]
So the individual tubes, do they have caps on top of each? And it looks like each tube is independent, floating within spacers between the tubes?
Using the thin plastic, are there pressures on the walls of the tubes that might crush them or cause them to bend in? I have a roll of this fairly stiff peal and stick plastic, that seems like it would work as you show.
Thanks for sticking with it and actually doing it. Also, thanks to Mr Wayne, for sticking around and just brushing off the fly's. ;] Good Show. ;]
MaGs :o ;)
Hang on! Are we really saying that Webby has just built an overunity device using nothing but some plastic tubes, water and super glue? Well, I'm truly gobsmacked! Are you going to use Wayne's 2 grand to build a bigger one? I dont mean to poke fun but- really?
I'm no over unity whizz kid and there are clearly a few here but, if you can draw off energy from a zed machine in the form of some kind of force. What happen's to the machine when you're not drawing off your "free energy". Does it a. get faster and faster until it shakes itself apart or b. build pressure until it explodes.
Blanco
Quote from: webby1 on August 07, 2012, 09:46:11 AM
Not sure what I will do with the money but I do have plans to build a slightly larger and better built unit, one that is more uniform in clearances.
Will the larger unit be a self-runer ? I am keen to make one that operates continuously,
but so far there hasn't been enough information to make me feel confident at an attempt.
What are your thoughts on a self-running device ?
Can I be permitted here to add my own thoughts about a self runner? Whilst I think it is possible that a self runner will be built in a home workshop, It is fairly lengthy and involved task. If we look at Wayne`s machine, we can subdivide it into several separate systems.
1. A pair of Zeds. Two is best, because we can recycle the "Exhaust" of one Zed to partly recharge the other, and vice versa.
2. A transmission system to convert the reciprocating output of the Zed into rotary motion. Whilst Wayne uses a hydraulic transmission, I think
for a small demonstration model, we could use a modified crankshaft type set up. Even if we do not wish to drive a generator, I favour a rotating shaft as output, as we can then have a camshaft to control the sequence of events.
3. A feedback system, [mechanical] to feedback some of the output to help in pumping water into the Zed.
4. In Wayne`s case, an alternator supplying energy to the load. If you just want a self runner without output, this is not needed.
A complex challenge, but not insurmountable, especially if people work together.
Just my opinion.
A System Rise Calculator data set and picture are attached.
The first is the basic system rise logic used by the calculator.
The second shows the force results and compares the the original stroke water level from the outside retainer water drop and the water height level after a 3". Note that the pod retainer (Retainer 3) gap water level his risen and the next inside water level (Riser 3) has dropped. More explanation later.
The third shows the 'Adjustment' button that must be pressed after the 'System Rise' or 'Start Out Ret. Water Drop' value is changed. After pressing the values will start rolling like a slot machine. If your machine is slow reduce the System Rise value and it will speed up.
The fourth is the calculator file.
Further explanation of Pod Retainer gap water rise:
To go from Initial Precharge to Stroke, water is added which raises the water in the gap between the pod and the retainer to increase the water head. The gap is ~ 12 (D155 cell) SI. Then the system is allowed to rise under pressure, while water is being added to fill in the 719 SI (C155 cell) area below the pod inside the pod retainer.
During the system rise a dynamic balancing of water/air levels occur. As the system rises the physical air space will increase lowering the pressure and water head and slowing the lift. The input water still coming in at the same rate, now reacts to this by overflowing into the 12 SI pod retainer gap increasing the pressure, water head and increasing the lift. There is no stopping it as the ratio is 61 times (719/12), so the 12 is insignificant.
That is why the water level at riser 3 was forced down from 8.488 to 4.255. This was due to the retainer 3 level rising form 52.226 to 62.726, but reduced by the new air expansion volume.
So it is an important step for physical replicator on initial setup, after bringing the system down from idea to stroke level, is to lower the water level in the pod retainer gap and add air pressure to return the water alignment in the outer layers. This is only a one time event.
Wayne had told me before that for initial system setup after the system was at stroke or initial prechage the water could be lowered and replaced by air pressure to realign the water head. At the time I though this was just being used to have the pod sink away and the layers would be the only part lifting for the 2500 LB. But, it's other purpose is to reduce the chance of the pod retainer gap water going over the pod retainer wall into the next riser gap and the additional air in the pod retainer gap being compressible reduces the chance of blowing outer skirts.
For those that don't have Microsoft Office, you can download a free version from http://download.openoffice.fm/free/?pk=26976 (http://download.openoffice.fm/free/?pk=26976)
It has a Calc module which is the same as Excel.
Regards, Larry
Webby thanks for your reply and your pictures, I begin to understand the parts of the ZED. Anyway, if you can, make a video with the procedure of imput and output of the system.
@All,
Sorry, but my latest spreadsheet is not responding under OpenOffice???, when pressing the 'Adjustment' button.
I will try to find a solution, but if anybody else comes up with a solution please post.
Thanks, Larry
Total force 6181
Minus pod 4582
Hydraulic 5799
Travis-Hyd 382
These are force figures?
Do we have the distances through which these forces are expected, or measured, to act?
Force is not a conserved quantity. Work is. Do your figures indicate a gain in _work_, or just in force?
Quote from: webby1 on August 07, 2012, 11:48:29 PM
Hey TK,
The TB you play with inspired you to build, why not this.
What is an ampere.
What is the electric force.
The first one can not be answered without the second, not to your standards.
If you can not answer these then why ask others to answer the same style of question.
Build and you will understand.
You are not dumb, you are not stupid, you ARE capable, you MAY answer questions we all have,,, but not if you don't try.
In short to your questions,
When lift pressure is met the lift distance is made by a constant value of input, this is a no brainer, what YOU are not addressing is the conservation of that constant input. Tar Baby,,
I don't detect an answer to my question. (It was referring to the spreadsheet's numbers anyway.) If there was one, it would look like this: the hydraulic force of xxx Newtons can be exerted over a distance of xxx centimeters. And the Travis Effect force of yyy Newtons can be exerted over a distance of yyy centimeters.
Two simple sentences, four numbers.
Yet you say this:
QuoteWhen lift pressure is met the lift distance is made by a constant value of input, this is a no brainer, what YOU are not addressing is the conservation of that constant input. Tar Baby,,
and I find this difficult to interpret. Can you explain more clearly please? I really don't think I have to "address" anything, since I'm not making any claims. All I am doing is asking if you've made the proper measurements to draw correct conclusions.
Or do you wish to insult me instead?
Just on casual inspection of the projects I see involving electricity, electric fields and forces, and electronics on this forum... I suspect I understand the Ampere and the electric field and electric forces better than many. Better than you? I don't know.... I haven't seen any electrical projects of yours. But there are plenty of my electrical projects available for inspection and criticism.
If you want to understand why and what I'm doing with Tar Baby, you are welcome to ask questions in that thread, and I assure you that MY answers to you will be informative. I don't see a real question in your latest post there, though.
Funny is it not, that you make this claim.
Things are not what Heavisides made it out to be.
The claim referred to , of course, is that Tar Baby performs just like NERD in all significant respects.... and three hundred pages later, that claim has been profoundly confirmed many times over in many different ways. I don't know what that has to do with Oliver Heaviside -- I have simply found that the claims of Rosemary Ainslie are not supported by her own data, much less that of replications like mine. Heaviside wasn't consulted and didn't need to be--- the independent laboratory that she sent her device off to, confirmed that her batteries DO discharge... .just as I did with Tar Baby months ago.
Now, let me ask you again, in a different way: are you claiming that the total work output of your nested cylinders is greater than the total work input, when all input sources are considered, including lifting masses during setup?
(I'm using "work" in its precise technical meaning here: force x distance)
Hello Webby,
Yes - the ability to access each layer air and water separately - moved our control of the process in such a positive direction.
Then when we added Pressure transducers to each - and are able to display water and air levels - it reduced our effort to set up - from a four hour ordeal - to minutes.
We also have prediction modeling - a "what happens if" any change is made to any one point - and warnings if a system capability is exceeded.
We do not blow skirts anymore - unless we forget to open a production valve and run the system.
To All: It has always been my position to be open and honest - this means sharing lessons learned - troubles - and successes.
Let me be clear about where we are in our process - Leaks and all:
We currently have a two Z.E.D. system - with both sides overunity by themselves- barely - 750 pounds extra Net - same time and distance - in our three layer set up.
The Recycle of the Exhaust adds to the other side or reduces the input cost another 55% - each side.
Our current problem is a good one - Both sides are overunity - and one side is much better than the other.
The better working Z.E.D. needs less input - this means less exhaust - the other Z.E.D. needs more input - so the 55% is less from the better working Z.E.D - and having the Z.E.Ds tied together - meant a common output pressure. Not anymore - this is the problem we have been working on - and have now solved.
The actual issue "The separate performance of the two Z.E.D.s" has been painstakingly solved and traced to our shop construction - basically our construction - welding the layers so that they did not match - actually a small amount one tenth of one percent in the outer riser resulted in a 90 psi production difference.
(Or you could look at it as less input to reach the same output value as the other Z.E.D.)
We have solved this problem - we have installed two separate production capture systems...
Having a problem is just an opportunity for some - it is something else for a prognosticator "baiter".
We do not have leaks in our water and air portion of the Z.E.D.s - we did have a drip of production fluid - which was annoying.
@ Webby,
We built ours large enough to be robust - we have a very large range of testing - resolution was important at this stage - actually our 2-5 models were 6 foot diameter and 12 feet tall -
That is a two layer system - laying in the Yard - for sale if someone wants to buy it lol - I will donate the money to JCCA (a small private school). Have a part of History ;-)
Be warned - you need three layers to have robust over unity - 5 and 6 layers are the best numbers of layers.
The two layer model was only 104% efficient upstroke - a simple capture method to use the exhaust will boost that.
Wayne
@Webby1 Just a couple of points. It might be worthwhile to experiment with having all the risers stuck together to asses if there is any advantage/disadvantage. You could also include the pod [or not] in this stuck-together group. Double sided sticky tape would serve the purpose on a temporary basis.
The size/length of the pod is an issue that Wayne might help with if you ask him, assuming that he has investigated models of this small size.
It might be better, rather than limiting the speed of rise with finger pressure, to have a "ballast weight" on top of the risers consisting of, say, a small container of sand. The weight is then easily adjusted.
You have probably thought of all these things, but then again...
Carry on, and thanks for sharing your great work.
@webby: thank you for this answer. It is close to an answer to my questions. I'm still not quite clear though. Are you saying that the lifting force is increased, but the travel distance is decreased, like a compound gear reduction?
QuoteIf I look at the distance traveled of each riser and pod compared to the distance traveled for the lift, I see, in essence, a compound gear reduction. I have almost 2 inches of pod travel and only 1 inch of lift plus the added distance for 4 of the risers.
Quote from: webby1 on August 08, 2012, 08:08:48 PM
I thought of ways to break the thing before I built it :)
Hmmm. Sounds similar to TK's methodology for testing.
Well, thorough testing that is.
M.
Hello All,
And thank you for the personal e-mails - yes some people ignore the truth, attack and slander - it is poor form.
I have shared and others have confirmed with their own physics - more to come - and the replication of our massively overunity system.
When considering only one aspect of our Z.E.D technology - one portion of the process - one specific number of layers - in particular the discussion concerning the current three layered model:
The Up stroke - by itself - no transfer of energy from the other Z.E.D. - just a stand alone observation - is only better than a standard hydraulic cylinder - input to output by about 700 pounds of lift.
In this three layered model - that is only about 10% more than a hydraulic cylinder - which is not a bad thing - but not where our massive overunity comes from - just part of it (Our Baiter knows this).
Once again - our baiter has twisted out of context my statements.
Seamus101 and Seamus102 - who pays you to disinform people? - you have tipped your hand again.
To All,
To show that I have covered the topic of where our "massive input reduction comes from" - well on this thread -
Would someone else please explain how the Two Z.E.D process works to massively reduce our input costs.
This will help protect the new visitors from the intentional dis-information.
Yes, it is a shame we have to deal with this.
My appreciation in advance, many of you have proven your abilities.
Wayne Travis
Change in ( current ) topic:
A few weeks ago there was considerable discussion about building a square ZED.
Did anyone ever try ?
I've been a little surprised no one took up the challenge then.
I happen to have a half-sheet of .060 acrylite and have ordered a piece of .470 for the base and top riser, and another piece of .250 for the "tank".
I've done a couple of tests and both PVC cement and 2-part epoxy seem to make acceptable bonds and are more tolerant of irregularities than the solvent weld shown in the posted video links.
I've laid out a mock up for a 4" square x 12" tall, 3 riser test using .060 air gaps for a 5.800 outer dimension. If anyone would care to provide feedback in the thread or PM please do so. One question; would it be better to use a 4" or 6" "extension" for an overall height of 16" or 24"?
At the moment I'm planning on starting from the outside and working inward, I want to see and attempt to measure changes as the layering is increased.
Dale
... bad math, that would be 16" or 18" tall
Dale
Not bad Webby,
You describe the lateral transfer of the Head pressure well. And you are right the input cost would be about 1/2
(starts making that 700 on the upstroke extra). The cost seems small when we pay 1/2 for the other 7000 pounds we lift.
Now - who will explain how we take advantage of the Non - linear aspect of our Z.E.D? (how much did the weight cost to lift versus the pressure it returned)
Wayne
@ Seamus101 and 102 - to borrow a line from a good show (modified) for you.
"I don't think that word you used 'Ludicrous' means what you think it means."
Please take the time to research - or keep your unintended "condescending" comments until you do your due diligence.
Good day.
Quote from: microcontroller on August 09, 2012, 01:49:58 PM
This is a discussion board.
Nobody needs to keep their comments.
If you are not happy with what people post feel free to leave but do not tell them what to do, you are not in that position.
This is an open source board anybody can join the discussion.
So don't tell people to keep their comments Wayne.
Bye Bye
Dear MicroController,
I am very respectful of others ability to share - be included, and to listen.
I am sure you did not mean to leave out the "Condescending" portion of my comment.
If you have something of value to share - welcome.
This site is not for the purpose of interuption, disruption, insults, misinformation, and otherwise inappropriate behavior.
If that is all you have offer the discussion - then keep it to yourself.
We are doing good work here, showing what this web forum is meant for - showing and discussing free energy, over unity, and a new technology - that many of us here are enjoying the discussion.
Wayne
@microcontroller. The evidence of OU is there for those who are prepared to put in the time and effort to learn about this technology. Why are you so anxious that Wayne should leave? If he does, then that prevent those of us who wish to learn from doing so. If you believe that there is no OU here, then why not move on and leave us to it?
Simple as it can get proof. Apples to Apples.
The attached shows a Archimedes Pod of 30" diameter with retainer and a Travis Pod of 30" diameter with retainer. The Archimedes Pod is the height that it would take for it to have the same lift forces as a 4 Riser Travis System. The Riser are not shown as the water is only input into the Pod retainer.
Note that the Sink to Stroke water difference for Archimedes is 164, while only 37 for 4 Riser. Also note that the PSI levels are higher for Arch. than 4 Riser, this advantage is due to larger SI areas on the Risers.
Archimedes has to input 164" of water pushing against PSI from 5.43 to 11.33.
4 Riser has to input 37" of water pushing against PSI from 5.07 to 9.99 PSI.
Or Archimedes has to input 4.43 times as much water at the SI as 4 Riser for the same lift with a much increase load and unload time going from Sink to Stroke and Stroke to Sink.
I have more for later. Just want to give some time to digest, before I confuse with my new spreadsheet on this drawing.
Regards, Larry
Quote from: microcontroller on August 09, 2012, 04:23:10 PM
No Sir,
There is no evidence.
I post about twice every 20 pages do you think that's too much?
Maybe i should make it 40 pages then.
Yeah Neptune, i will see you in another 40 pages of empty words, claims, spreadsheets, images, and road trip reports!
I hope to see you there !
MC
Micro controller you are an...... something else.....
My only road trip was to our Aunts funeral, she was 59.
Very rude indeed.
Wayne
Larry:
QuoteSimple as it can get proof. Apples to Apples.
This is a comment for you and all others that have shown data or spreadsheets.
Can you please convert your analysis to the proper units for evaluation?
It takes a certain number of
Joules,
foot-pounds_force,
Newton-meters,
kilogram_force-meters, etc, to push the pod down. The pod will produce useful
work when it moves up and your calculations must result in a
work calculation.
How much
work can you extract from the pod and what is the vertical displacement?
How much
work does it take to push the pod back down and what is the vertical displacement?
Without showing work calculations I just don't see the point. It's all about how much work you can extract from a rising pod and comparing how much work it takes to push the pod back in place for the next cycle.
Without looking at the work and just looking a "pounds of lifting force" or whatever, you are completely missing the point. I have looked at half a dozen spreadsheets by multiple contributors to this thread and I just don't get it.
You must not take your eye off the ball, it's all about work-in and work-out, everything else is secondary.
Bye Bye
But thats just it. You are not discussing anything. You are just dropping paper bags of dog crap. And it stinks.
Guys, at the top of each post, there is a 'Report to moderator' link. If a few of us post a complaint, Micro can be dropped like a bad habbit. ;]
My trigger finger is itchy. ;]
MaGs
Webby1:
It's not force that is the issue, it's work: force x displacement. You talk about the pod providing a lifting force and you talk about a displacement, so you should already have the tools in place to make a work computation. Same thing for the "negative work" computation, where the pod has to go back down.
I will just repeat what I said: Please show all of your work-in and work-out calculations. That is what it's all about.
I agree Milehigh et al, that these are the relevant facts needed to be ascertained to establish the potential for OU or free energy.
Ordinary buoyancy produces a constant force over vertical distance due to linear pressure gradients in a virtually non compressible liquid - this means you can find the Joules [Nm] & find the Power in Watts [Nm/sec] - this can be compared to the Joules expended to either depress a buoyancy piston or conversely pump liquid into the chamber to create the head.
Note: The "Work Energy Equivalence Principle" says that Work [f x d] in Joules is directly comparable to the Energy in Joules to depress the piston or pump the fluid - ordinary system mechanical losses bring an inequality to this relationship, especially if electric pumps are used etc due to heat losses & overall inefficiency.
The pod configuration has a variable force effect IINM so is more problematic to determine how much Work [in Joules] it can do - IMO a method to determine this would be to use the pod to raise a known mass to its maximum height achievable - then compare the Joules of PE it is given to the Work Done to set the system, or some such variation.
IOW's, the ZED pod should produce more PE Joules in a raised mass [= Work Done] than Joules of Energy to set the system, to be potentially either OU or free energy before system losses are accounted for in the energy budget.
Just my opinions to keep this discussion grounded, practical & non personality driven, in the interests of establishing credible rigorous fact from fiction, whilst we wait for MD's analysis to confirm the actual long run test results & setup detail in support of Mr Wayne's claims.
I have no particular axe to grind if Mr Wayne's device is OU or not [ I hope it is], however I have learned to examine & trust actual empirical data that can be replicated, above exuberance & spreadsheets - first establish that the Work Output is empirically greater than the Work Input.
Quote from: MileHigh on August 09, 2012, 07:22:54 PM
Webby1:
Give it a lil time M. Webby has just put the very simple 'test' tubes to some various tests the other day, just to see if there is something to see. And actually, it was done well enough for MrWayne to delve out 2Gs, cashitos, to Webby for listening closely and accomplishing what he has done so far. A a paid trip to Mr Waynes facility to meet.
Im sure that Webby will do and show more as the work progresses. So far, he is the only one that did the deed, and it isnt done yet. ;]
Lets see what happens. Im involved elsewhere, but following closely.
He might not have the data you require at the moment. And also might have his own time schedule in doing more. At least he has come this far, so far. ;]
MaGs
Deleted:
Sorry Larry but you are not correct. Work over a given amount of time, equates to power. Work/Time = Power
So you can evaluate the total work that you put into the system over a certain period of time and get an average input power value.
You can also evaluate the total work that you put into the system over a certain period of time and get the total input work.
Likewise, you can evaluate the total work that you get out of the system over a certain period of time and get an average output power value.
You can also evaluate the total work that you get out of the system over a certain period of time and get the total output work.
Average input power vs. average output power or total input work vs. total output work are virtually the same thing.
One factors in a time period to create an average power level and they other simply factors that same time period but only counts the total work.
So it's a phony issue and there is nothing to discuss. Which brings us back to the beginning: What are the input vs. output measurements or calculations done in your spreadsheets? You can use work or average power, it doesn't matter, the same relevant data is conveyed in either measurement method.
Quote from: MileHigh on August 09, 2012, 10:56:54 PM
I had just deleted my post, because I didn't like parts of it, when I seen yours.
'Sorry Larry but you are not correct. Work over a given amount of time, equates to power. Work/Time = Power'. What a liar, I had just stated that Work without Time was useless as Power is equal to Work/Time.
First you stated '
it's work: force x displacement' in reply 1206, and fletcher stated '
Work [f x d]' in reply 1207. Now you are claiming new definitions that you did not state. All of your new definitions contained
'certain period of time'. I did not know, but you are obviously a deceiver and this will be my last response to you.
LarryC:
I won't argue this with you. I suggest that you go to an educational web page and read up on energy and work and power and all that stuff.
http://www.edinformatics.com/math_science/work_energy_power.htm
One of the best sites is the hyperphysics web site - it is down for me at the moment.
Search on google .... Hyperphysics Work Energy Power
Bye Bye
can you apply this to your own comments ?
QuoteMy lift load or force input on these basic test was 2.5 fl o over 6.5 inches to lift 1.5 lbs with .5 of those left on the risers.
I am fairly good at puzzles but I am having trouble figuring this out.
2.5 fl o Does this mean "fluidounces"? The fluidounce is a VOLUME measurement, not a force.
2.5 fl o over 6.5 inches to lift 1.5 lbs with .5 of those left on the risers Huh? .5 of those What? Inches, pounds? Left on the risers?
Webby, you are better at building than you are at explaining!!
Here's an example of what I'd consider a good answer:
"I press down with a steady force of 2.5 ounces, measured by the compression of a calibrated spring. I exert this force for 6.5 inches. The riser lifts a weight of 5 ounces sitting on top of it a distance of twelve inches in response."
I think that Seamus10n and MH and me and some others would like to see answers in that kind of form.
To All,
It is easy to loose track with all the 'Stink bags" being thrown - please just use your Moderator Report button.
Wayne
@TK.I am sure we would all like to see Data expressed in that form. There are two ways in which we can see that data .
1. Build your own test rig and measure it in your own way.
2. Wait until Webby has perfected his test rig to the point where he can make those measurements.
My own build can not start yet until I have had eye surgery so I can see what I am doing.
Hello Tinsikoala,
I think that is a good question you ask.
I will give this to you in steps, you do your part - I will do mine.
Currently we are stroking 6 total inches in a stroke - and capturing 30 cubic inches of pressurized hydraulic fluid @ 640 psi
We stroke 3.7 times a minute.
Tin - Please place a Energy value of your preference to that and then I will step you through the input costs.
Thanks Wayne
Quote from: mrwayne on August 10, 2012, 06:11:36 AM
Hello Tinsikoala,
Thanks Wayne
Thanks for your response... but... no.
You are the one making a claim, I think, of overunity performance. It is actually up to YOU to put numbers on your claim, numbers that are standard and interpretable. Work, or equivalently energy, that is, Force x Distance, is the conserved quantity. You have not, as far as I can see, ever answered with numbers that would allow us to know the ratio of work input to work output. Yet, for a claim of overunity performance to be credible, this information must be known, in those terms, by "somebody" along the chain of analysis. Surely your engineers know the answer and can put it into the form required for others, classically trained and straitjacketed by our educations, to understand it.
How much energy, or equivalently, how much work must you do to produce your six inches of stroke at 3.7 times per minute? And how much energy, or equivalently, how much work do you recover from your 30 cu in of hydraulic fluid at 640 psi?
You have left out something critical: with what force must you push, over what distance, to obtain a flow of 30 cu in at 640 psi?
It's not up to your skeptics to provide you with information. Rather, if you really want to convince people that you've got what you claim, then you should be ready and willing to meet all their reasonable objections and questions with solid answers that are interpretable and make sense. I agree that the people who simply drop "stink bombs" and run away are not necessarily useful. But people like microcontroller, Seamus 10n, and myself are asking you to support your claim with real data... that's all. And we are telling you that, so far, your data are not providing that support. You should actually be thankful for that.... because at the very least we are making, or asking, you to firm up your argument, like a rehearsal for the "big time" exposure you'll be getting "when" your system is fully proven.
Wayne,
Would you be willing to host a visit by TK?
TK,
Would you be willing to visit Wayne and examine him and the device face to face? What would you need to make that a reality?
Just a thought.
M.
Quote from: TinselKoala on August 10, 2012, 05:34:51 PM
I am sorry for your position,
The Skeptics I have meet did their own analysis.
You asked the question - and the answer requires the same language be used.
It is as simple as that - I have given the answer over and over in my "nomenclature", So has Webby, So has Larry, So has Phwest and others.
All of us have just tried to make it simple for you and the others.
How much education does someone need to determine how much work can be done with a known volume, known pressure, and a known time. Highschool - I am sure you are taking a stand - you may be busy.
Yet I watch as some argue that using 15 cubic inches @ 640psi to generate 30 cubic inches @ 640psi in the same time frame - is not overunity - or not using the right words to describe - that we have 15 cubic inches extra - every stroke - 3.7 times a minute.
The patent is online - and has been discussed in great detail here - and I have submitted myself to answer questions -respectfully.
I have Very Good PE's (engineers) Brilliant in fact - and many others have visited from around the world - here in Chickasha Oklahoma - They have prepared a brilliant presentation.
You were offered an inside peak.
If what I share - is too much trouble...not worth your effort... I understand - if you think you are teaching me to present to a Critically educated Crowd - We have good people for that.
I am just the inventor of the Z.E.D. who tried to share with those that would listen, get their hands wet, crunch a few simple numbers.
Good Day.
Wayne Travis
@Mond:
It's a thought all right, and since I'm in San Antonio it wouldn't be a huge trip. Unfortunately... or maybe fortunately... for us all I'm not able to travel right now.
I am waiting to hear about MD's visit and evaluation.
I'm also kind of bemused at the 2000 dollars. Although I wasn't ever in the running.... and I'm not knocking Webby's efforts at all, I think they are great.... I'm really not sure just what was produced that was worth that much money. It's not quite a pushbutton demonstrator of overunity yet, is it? And I thought that was what was required for the reward.
We've got a bit of history, mondrasek and I, don't we? We had some fun back in the day, and I still think that Mondrasek magnet-assisted gravity motor you designed and I built is the closest thing to a "working" gravmag motor I've seen yet, especially with the JK "latch" wires. All it needs is some negative-friction lube for the magnetweights and it would go like gangbusters.
Quote from: mondrasek on August 10, 2012, 06:54:33 PM
Wayne,
TK,
Just a thought.
M.
Hello M,
I do not recall TK ever being a Disinformationist, baiter, overly arrogant, or attacking. Welcome - if it is not too much trouble.
Most anyone who is of the spirit to actually discover what we have is welcome.
Let me answer broadly....
On my list of Not Welcome:
Mark Euthanasia - another forum - Lied repeatedly about us and our members and refused to apologize after he was repeatedly caught in them.
Milehigh - Microcontroller, Seamus101 and 102, Never offered a contributing word - and mocked the truth at every page.
Nor the guy who made the video of lies, slander and insults - what ever his name was.
On my list of welcome - people who really want to know the truth, I very much respect those that take the time from their busy schedule to see.
Who I don't care for - only had one so far - who refuse to believe what is backed up by the simple math, the complex math, and the physical proof - Who needs a dogmatic denial? Seen enough here.
What I will not share - our business plans, our improvements, who is helping us and our new patents.
Other than that - fair game - several who have visited reported here on this site to that effect.
Wayne Travis
Well, MrWayne, you sound a bit "tetchy" today.
QuoteYet I watch as some argue that using 15 cubic inches @ 640psi to generate 30 cubic inches @ 640psi in the same time frame - is not overunity - or not using the right words to describe - that we have 15 cubic inches extra - every stroke - 3.7 times a minute.
As far as I am aware this is the first time that you have come close to stating work in / work out in actual measurable numbers. Has anyone _actually_ argued that those numbers you cite would not be overunity performance?
I think that what has actually been argued is that an input stroke of, say, 10 pounds of force over 15 inches of stroke, output producing a 20 pound lift force over 7 inches of stroke, is not overunity performance. But this is a different form of argument from what you are stating.
But even here you are stating it as a hypothetical. Is this really your claim? If someone were to take a single one of your Zeds at a resting state, and inject 15 cubic inches of hydraulic fluid or water at 640 psi, will you really get 30 cubic inches at 640 psi back out?
ETA: I'm not hostile or rabid. I have said before that I've suspended disbelief and I'm taking MrWayne at his word... but I'm still trying to find out to my satisfaction just what the "word" really is. Are we dealing with a force multiplication system or a work amplifier? Very different beasties.
And I don't know anybody who has ever been able to figure out how to build a complex apparatus from a patent. What's needed for builders are engineering drawings with measurements, and dynamical analyses, and all that there stuff.
@Tk. You ask the question "If someone were to take a single one of your Zeds at resting state, and inject 15 cubic inches of hydraulic fluid or water at 640 PSI , will you really get 30 cubic inches at 640 PSI back out."
The fact that you asked this question demonstrates very clearly that you have not invested the effort to understand even the basics of this system.
1. Hydraulic fluid is never injected into a ZED, only water, and during set up, air.
2.Whatever is injected into a Zed, the input pressure
is in the region of 10 PSI max. Any more will result in blown skirts.
3.The only place in the system we find hydraulic fluid at 640 PSI , is in the transmission system between the ZEDs and the generator. The transmission uses conventional hydraulic components.
Please do your homework.
I just want to clarify what Wayne has said and has continued to do here on OU.com. It is not to PROVE he has an OU device. He knows he has one. He has built it and can watch it run every day. His plan for "proving" it to the world involved coming on this board over a year ago to ask for advise and assistance. To that end he ended up in contact with Mark Dansie and has been working under his advisement to prepare for the testing required to "prove" his system. It is Mark Dansie and his team that is to "prove" the system to the rest of us.
Wayne came here to OU to teach those who want to learn how his system works. He has helped those who try to model and simulate a system every step of the way. He is helping those individuals to prove it to themselves, even in advance of the "proof" from MD and team.
I appreciate those who want to see the "proof" of the OU of Wayne's actual machine(s). I want that too. But he has never said that is what he is here to do. And barring some change of direction from Wayne, we all have been told to wait on MD for that. If you want to pester someone for the proof, maybe you should pester MD?
But if you want to take Wayne up on his offer to learn how his set up works, to better understand the patent, or to build an analysis tool or even a device, please ask him any questions to that end. He has so far answered with assistance on anything that is already public domain and even a bit more (when we have discovered more along the way).
Also, an opening statement like, "Sir, you are a liar," is just rude and bad form all around. It is a classic example of what some individuals think is acceptable behavior while they are completely hidden behind the safety of the Internet. If such "etiquette" were used in a face to face conversation, it would not be tolerated. Especially when there is no evidence presented of any lie having been told by the accused? So this is just name calling?
M.
Excellent use of the language @M !!
Amen
And Thank You Mr Wayne for doing all of the above.
Dale
Quote from: TinselKoala on August 11, 2012, 12:15:37 AM
I will look that word up, but if it means tired of misdirection and misrepresentation - it is true.
It is in my weakness that I find strength - thank you for the concern.
At the end of the Day - We have the cure for the world's Energy needs, clean and reliable - we can deal with junk talk - it just sets my heart back a moment when the pearls are trampled upon - and then I realize - some will - the strength comes from the truth - it will prevail.
Wayne Travis
Quote from: microcontroller on August 11, 2012, 01:11:48 AM
Sir, You are a Liar.
Seamus and Milehigh offered some very good arguments.
Just because they do not fit your overunity claim does not mean they are not contributing nor does it mean they are telling lies.
Untill you deliver undeniable proof that your invention works it does not matter who sais what because there is nothing to start with.
And encouraging people to use the report to moderator button because you feel someone is throwing non existent stink bag's at you just shows your weakness and that fact that you want to play out the good guy's against the bad guy's.
But for that to happen you are on the wrong board buddy.
You want our moderator to get rid of the skeptics well let me tell you this: it ain't gonna happen...
We are not here to attack anyone or to cause trouble, so stop acting like we do, we just want the truth and you know it.
You speak of the skeptics as being liars, but don't forget you still didn't supply any proof that your invention actually works and untill you do so, everybody is contributing, and nobody is telling lies.
You can put an end to this by proving your claim!
It seems you have a problem making up your own truth and you have a tendency to see criticism as being 'stink bags' while they are not.
It is just a means to an end which is the solution for both party's so once again:
IT'S UP TO YOU.
Please no more words just prove your claim.
@ ALL
Micro and his team have been trying to twist this conversation all year to deviate from the clear and stated purpose of my visit here.
It is up to me to stay on topic and on focus - to share our discovery and to explain the patent and to answer questions.
We have a team secured for the "Extraordinary proof" it is impossible to show that level of proof here - that is not our purpose.
As far as Micro's rant above:
It is a simple task to click on someone's name and read just their posts - the truth is presented - who is doing "what" is clear.
And as has been suggested by several members here -
When Micro, Seamus, MH try to twist our conversation from explaining our system into their own purpose with insults, slander, and disinformation - whatever that might be - use the moderator button.
Everytime they try to change the conversation and state that I have to prove something to them - such as O/U - they are not trying to learn - they are trying to redirect the conversation.
Thank You.
@Micro your insults to our discussions are cataloged - as I said before - you will owe us an apology, I hope you have the character when MD's Team is done.
I have called liars.... liars - and Skeptics..... Skeptics there is a big difference - throwing insults does not make you a Skeptic.
Splitting and dividing - it is you who have said repeatedly - "I am with you seamus" - followed by slander of the group actually contributing.
It will be a refreshing surprise, for your sake, I hope for you, and I pray you find the character.
Finally: I have stated my position - You will not lead this thread away from the topic - listen - do the due diligence - get your hands wet - add to the topic - or move on.
To those that have - Very well done indeed - and you are only on the surface "the tricycle stage" of what we have going on here - much more fun to come!
Wayne
Quote from: wildew on August 11, 2012, 08:41:59 AM
Amen
Dale
Thank you Dale,
I know that truly interested people are here - I appreciate you and the others very much.
I have nothing to gain from this - but sharing is its own reward.
Thank you and M. and the others with such a heart -Very Much.
Wayne
Quote from: mondrasek on August 11, 2012, 07:35:49 AM
M.
You have restated this very clearly, thank you M. for all that you do and have done.
When you are ready to come - let me know.
Wayne Travis
Hello Tk,
I agree with your logic - and experience.
I have not been here to use my machine to prove anything - and yes - it is very Overunity
MD made a video and in it explained where our output was basically twice the input - and that though the pressures changed during the stroke - they always returned to the starting point - with no additional input.
Here is a link to that video http://www.youtube.com/watch?v=q-0TITC4Wrc (http://www.youtube.com/watch?v=q-0TITC4Wrc)
Listen closely to his words - he is right in what he observed.
That was back in Nov - his second visit - We were bleeding off the extra in that video - and since then - we took that rough model and converted it to a self runner with Data collection and electrical generation.
Now when answering questions for the team here - I have referred to that model and the data we pull - when questions about their personal modeling have risen - just to compare real world - physical comparison to the replications or modeling results.
Our physical model is a great indicator if someone is off track - usually overstating the actual - until they find where they left a cost of function out of their own model.
As one of our Very wise Advisers (who knows our system and its physics) explained to me - third party replication/duplication is more valuable than any other form of proof.
When M, and others decided to replicate - I know it only takes a couple hundred at most to build a set up - not to put on the shelf at wal mart - but to scrutinize study and to test certain physics - such as input and output so i offered the funding to those that were willing.
Several started - I saw a real cool square mock up - but Webby followed thru and had a simple system that proved that the input was far less than the output -
I did not design his input and output - so I can not be for sure - but as he described it to me - he added a much lesser weight and lifted a much greater load - in the same time and the same distance - his details he sent to me privately - so I called him the winner.
The fact that he followed thru and then had the bravery to announce his findings - is a notch in my respect for his character.
I have countless numbers of people who replicate but are afraid of peer pressure.
The system is preloaded and that confuses people... but as others say - it is hard to jump into the conversation and expect to follow what is being discussed. Especially if you do not have a clear grasp of the function of the machine.
The desire for many - is to focus on one Zed - its in put and out put - this is a mistake - it is like calculating the work of a teeter totter with only the physics of "one side" and then trying to claim the system "balances".
More later - My beautiful wife has breakfast ;-)
Wayne
Quote from: microcontroller on August 11, 2012, 10:21:42 AM
WELL I SUGGEST YOU GET 'R DONE THEN.
WHAT ARE YOU WAITING FOR?
Are you going to keep repeating yourself? over and over ??
Like i said, at this point, i do not owe you anything.
I certainly hope this will change, but i doubt it.
I agree that i can be a little direct but there is nothing wrong with that.
We have seen so many fakers that we want to separate the fake from the real quickly, and you are not very helpfull, doing a terrible job at that.
It is almost as if you want your 'game' to continue in this fashion..
So once more, prove your claim or expect resistance from the skeptics and stop whining.
MC,
Each time you say this - I wonder how all the others were able to replicate from the patent and my help?
Did all your fakers have engineers posting their own physical and mathematical models?
You are dealing with the real thing my eager person - you will have to broaden your self determined limitations a bit.
"Get er done" don't you worry about that - our team is doing an excellent job.
Wayne
MC,
Please substitute the pronoun "I" where you used "we" above. You do not speak for the group. The "me" of your "we" is in no such hurry, finds Wayne very helpful, and thinks he is doing a fine job at offering information that he does not need to provide for any reason at all.
Cheers,
M.
Quote from: microcontroller on August 11, 2012, 11:09:31 AM
Well Mr. mondrasek let me clear that out for you.
We is me and my team so, not you and me.
I wonder how long it takes for a person to examine if a device is overunity or not.
Maybe one day? or one week? one month? maybe one year??
Whoever needs that long must be either stupid or does not know anything about the subject.
At this point we have 80 pages of nonsense and make belief.
A good examiner should be able to tell within minutes if not seconds whether a device is 'massively overunity' or not.
Given that there is no external supply feeding any logic or in this case, air pressure.
So i have decided to rest my case since this is an endless discussion between a guy making claims without the courage to properly back them up and some people interested in REAL new technology.
Time will tell.
Well MC,
I understand you have never had to succeed thru multiple layers of Validation in a Free energy machine, I do not brag - I am humbled at the willingness and diligence afforded this invention.
Now - we have covered this topic before it is not a one step process. - unless you fail a step - in which case you go no further.
I know you already know this - you have made this insult before.
To All,
We have been through 7 levels of validation and passed all to date - only two more to go.
On that Note: it has been explained to me - that no one has passed - with a mechanical free energy device - even 2 stages before.
As I have also stated - I do not set the parameters of the test - I just work to meet them - each step was and is exponentially harder than last - but it is a fair process.
A silly statement like how many seconds - it would take to prove .... simply no experience with a real device.
First - a redirection again to prove our system instead of help and guide others....
Second;
It is not about "does it work" - that was level 2, - it is about "How", "Scalability", "NewTechnology", "Market", "ROI", "sustainability ", "reliability engineering", "Weibell passed modeling", "manufacturing", scientific proof, and "good partnerships and business planning".
@ MC -You have "rested your case" from the beginning - no change, no learning, only insults and trash.
The only thing I have seen from you - was your negativity and attempt to change this forum so that it is about your thoughts - not the invention covered in this thread.
Bad form on this forum.
Good luck with you and your work.
Wayne
Meanwhile, the legitimate and fair question about work in vs. work out or average power in vs. average power out remains unanswered. Some in "the flock" are clearly confused by these fundamental concepts. Ironically, that is what this machine is supposed to be all about.
TK, if you ever were to visit Wayne, be sure to bring along a mechanic's stethoscope and listen in on the guts of this thing. If you could record and run FFTs so much the better.
QuoteBut even here you are stating it as a hypothetical. Is this really your claim? If someone were to take a single one of your Zeds at a resting state, and inject 15 cubic inches of hydraulic fluid or water at 640 psi, will you really get 30 cubic inches at 640 psi back out
TK, it looks like you made a slip-up unless I am misunderstanding you. "X cubic inches of an incompressible fluid at Y PSI" is actually a meaningless statement. There is no energy stored in an incompressible fluid at a given pressure. No comment from Mr. Wayne either.
MH,
In case you forgot - until you show respect to others - as we discussed the last time you were here - don't expect me to engage.
Second - everytime you try to mislead people - one of us will set the record straight.
If you want to engage - respectfully, and with a question regarding your attempt to replicate, duplicate, or understand the function of our system.
Otherwise - Do not expect a "comment" from me.
If you want to twist the conversation to your topic of "proving our system to you" once again - as I have repeated time after time
- We have an excellent team for that. Not why I am here - and you have been told that repeatedly.
Stick to the work we are doing here -show a mite of respect to others, or do not expect engagement.
Good day.
@All, I try very hard to answer questions - I asked before - but I need to say it again - please ask single questions - I have very little time to sit and answer - multi quizzical questions get partial answers which give MH twists into accusations against me.
p.s. as I told MH last time he made these charges - if he throws a stink bag in the front, middle, or end of a question - it is just a stink bag.
Thank You
Wayne Travis
Quote from: MileHigh on August 11, 2012, 12:33:55 PM
A
hydraulic accumulator is a pressure (http://en.wikipedia.org/wiki/Pressure) storage reservoir in which a non-compressible (http://en.wikipedia.org/wiki/Incompressible) hydraulic fluid (http://en.wikipedia.org/wiki/Hydraulic_fluid) is held under pressure by an external source. The external source can be a spring (http://en.wikipedia.org/wiki/Spring_(device)), a raised weight (http://en.wikipedia.org/wiki/Weight), or a compressed gas (http://en.wikipedia.org/wiki/Gas). An accumulator enables a hydraulic system to cope with extremes of demand using a less powerful pump, to respond more quickly to a temporary demand, and to smooth out pulsations. It is a type of energy storage (http://en.wikipedia.org/wiki/Energy_storage) device.
Compressed gas accumulators, also called hydro-pneumatic accumulators, are by far the most common type.
Spectacular! From both sides.
Seriously, well done all.
I recommend everyone take a short time out. Maybe an hour or two?
I'm gonna go line trim my yard.
M.
To all,
I took the time to respond to the mass of accusations and disinformation,
The pattern is clear - Each time you make progress, the barrage of four or five pages of misdirection. And when those do not work, personal attack (I am not referring to TK).
It is clear to those who truly follow this thread - we are about getting to the bottom of questions.
M was right, and to add to his statement - the world deserves to know what we have.
I profit nothing from sharing - and I give up valuable time - but I respect your time - those who diligently seek the answers - so let's move on.
I understand a few of you have some really great work to share - I look forward to it!
I challenged this group with a 2K challenge Webby won -
I also offer Se3d 5K to build an education model with his molding and extrusion experience - I think he is about to collect ;-)
We have great things ahead of us - as M. said - this is not about us - I agree and add - we need to avoid those that try to make it so.
Again - as we succeed - your lives will be improved for the better in many ways!
Wayne Travis.
LarryC:
A hydraulic accumulator is a pressure (http://en.wikipedia.org/wiki/Pressure) storage reservoir in which a non-compressible (http://en.wikipedia.org/wiki/Incompressible) hydraulic fluid (http://en.wikipedia.org/wiki/Hydraulic_fluid) is held under pressure by an external source. The external source can be a spring (http://en.wikipedia.org/wiki/Spring_%28device%29), a raised weight (http://en.wikipedia.org/wiki/Weight), or a compressed gas (http://en.wikipedia.org/wiki/Gas). An accumulator enables a hydraulic system to cope with extremes of demand using a less powerful pump, to respond more quickly to a temporary demand, and to smooth out pulsations. It is a type of energy storage (http://en.wikipedia.org/wiki/Energy_storage) device.
Yes I fully agree. A hydraulic accumulator is a form of mechanical energy storage, sometimes it can look exactly like a mechanical capacitor. The problem remains as I stated it, "X cubic inches of a non-compressible fluid at Y PSI" tells you nothing at all about how much energy is stored in the hydraulic accumulator. There is no energy stored in the non-compressible fluid itself, none.
The non-compressible fluid is just a passive component that makes up part of the hydraulic accumulator. So the TK phrase I quoted where he compared two different volumes of non-compressible fluid does not tell you anything. What is not known is the "path" that gets the fluid up to that pressure. Without knowing the path you can't perform the integration and so you have nothing to go on.
Wayne: You can try to demonize me all you want but my questions posted a few days ago did not attack anybody and were legitimate questions. There was no "disinformation" or "misdirection" inherent in them. In my opinion all that you are doing is demasking yourself when you do that so others can see you more clearly.
Quote from: mondrasek on August 11, 2012, 01:47:04 PM
Just to clarify for the majority of the world:
One to two hours of my US time is about 60 to 120 minutes of metric time.
Thanks,
M.
MH,
I do agree that this time round - I noticed improvement.
You referenced the lack of responses in the past to your questions - which were not respectful - I made it clear why I did not answer those questions:
And - I will not respond to questions laced with insinuations etc. - and that will still be my position to all.
You also referenced that "lack of response" to those "laden questions" as proof I was evading answering - you were very clear.
It was a clear misrepresentation of the facts.
Thank you for your efforts. I did notice you were not as rude as last time.
Are we ready to move on, to questions pertaining to the discussion? I am.
Wayne
So, here in the US you can buy soda (Pepsi, Coke, etc.) in 2-liter containers made of PETE. They appear to be about 4 inches (~101.6 mm) in diameter. The vertical height of the straight walled section appears to be about 6 inches (~152.4 mm).
I think these can be as easy to find and work with as the tennis ball tubes that @neptune used.
They have the same problems though... How to bond them into smaller cylinders? What end cap materials to use and how to bond those? Et cetera.
But they are (like @neptune's solution) very thin walled and easily available (at least here in the US).
M.
Last Sunday in Post #1148, Wayne reported, "PhWest found a plastic bottle company that sold plastic bottles incrementally sized."
Neptune followed up with a request to PhWest for a ". . .link to the source of these incrementally sized plastic bottles. That on its own would facilitate more replications." No response has been forthcoming.
PhWest, are you out there?
@Mondrasek. Can I respectfully point out that the tennis ball tubes were in fact Webby1`s idea. My suggestion , as yet untried was tinplate , soldered together. The problem with tinplate is that it is not of course transparent.
Quote from: neptune on August 11, 2012, 03:37:24 PM
Most definitely! Full credit for the tennis ball tube material solution goes to Webby!
M.
Quote from: neptune on August 11, 2012, 07:07:59 AM
Really? Did you not see MrWayne's answers to my question? Here they are again:
QuoteCurrently we are stroking 6 total inches in a stroke - and capturing 30 cubic inches of pressurized hydraulic fluid @ 640 psi
And in another post:
So what part of my homework am I not doing? You seem to be contradicting what MrWayne is saying in those two quotes. Please "educate" me. What am I missing? The claim seems to be very clear: you put in 15 cubic inches of hydraulic fluid at 640 psi and you "generate" 30 cubic inches at 640 psi. Is that NOT what MrWayne is saying in the quotes?
Please tell me then what he IS saying. Where can these pressure and flow readings be obtained in the system?
And perhaps more importantly.... what happens to all that generated hydraulic fluid, and why doesn't the machine tear itself apart?
If I am misunderstanding something it is because the explanations given have been inadequate, and include statements like those I have quoted above.
You are misunderstanding me, evidently... because those pressures and volumes in my question came directly from MrWayne.
And
So I noted that the second statement seems like a hypothetical, and I asked if it was really the claim. How is that a slip-up?
My solution is to look on the Internet for suppliers of clear plastic tubes in nesting sizes. For this work I would prefer polycarbonate to acrylic.
http://www.jcdanczak.com/our_products/subcat_16.html (http://www.jcdanczak.com/our_products/subcat_16.html)
http://www.k-mac-plastics.net/polycarbonate-tubes.htm (http://www.k-mac-plastics.net/polycarbonate-tubes.htm)
http://www.usplastic.com/catalog/item.aspx?itemid=23791 (http://www.usplastic.com/catalog/item.aspx?itemid=23791)
http://www.carrierplastics.com/polycarbonate_tubes.html (http://www.carrierplastics.com/polycarbonate_tubes.html)
http://www.interstateplastics.com/Clear-Polycarbonate-Tube-POLCE.php (http://www.interstateplastics.com/Clear-Polycarbonate-Tube-POLCE.php)
I think that 2 thousand dollars would certainly be enough to buy a set of nesting polycarbonate tubes of the required length, wall thickness and intertube clearances. With quite a bit left over for machine shop expenses.
Somehow I still feel that my own credibility as a builder and a cooperative correspondent is still being questioned. Here is a build that I did entirely on my own dime in an effort to help Mondrasek out a couple of years ago.
https://www.youtube.com/watch?v=WcPuKv9Z-XE
@TK.My post to you about doing your homework was not intended to be disrespectful. If I am honest, and I always try to be honest, I did not fully understand wayne`s post where he speaks of 15and 30 cubic inches of fluid at 640 PSI. It is just that you spoke about injecting hydraulic fluid or water into a ZED at 640 PSI. Wayne did not say that.
The machine consists of a number of separate systems.
1.The ZEDs, which work at pressure of up to about 10PSI. These are mechanically linked to
2. A high pressure hydraulic system . So the ZEDs pump hydraulic fluid at high pressure into the accumulator. It does not tear itself apart, because from the accumulator, fluid is bled off to drive a hydraulic motor to drive an alternator. Also some fluid is used to drive rams which help to activate the transfer of water from one ZED to the other.
3. The only place we would find 640 PSI is in the hydraulic transmission system.
I stand by the points I made in my previous reply to you.
TK,
Yeah, that is funny. But OUCH man!
You had a great French phrase I believe for it? My "Epiphany" that is. You used it over on the "Village of the Banned?" Do you remember the one I am describing? I had to look it up and I thought it was spot on.
Seriously... Your build skills are excellent.
I'll pay for the WD40 and maybe some of the acrylic (I'm not rich) if you have a machine shop to work in. And if you are willing to give us all a new TK build (seriously, RA is soooooo 15 seconds ago).
Cheers.
Mike Ondrasek
PS. My original "gravity latches" negated any issues with the magnets making contact and maintaining attraction to the "JK" wires. Plus they allowed for the magnets to travel TWICE as far down the drilled holes (in your build) once past 3 o'clock!
All of which means nothing if you do the math... So once again, I apologize to anyone who believed in that idea.
The one thing I learned from that experience is that TK can build. And test properly.
TK:
Please look at my posting #1247 to LarryC.
I realize that the root for your statement comes from Wayne's comment: "using 15 cubic inches @ 640psi to generate 30 cubic inches @ 640psi in the same time frame."
It's just not right. We can't assume anything. We can make a reasonable assumption that whatever the non-compressible fluid is pushing against is not returning a constant pressure. So what is the force x displacement "pressure path" to end up with 15 cubic inches @ 640 psi? We don't know. Without knowing that we can't perform the P(x)dx integration where dx represents the infinitesimal displacement as we compress the fluid. What is the effective area we are pushing with? What is the effective area we are pushing against?
There is no energy content in 15 cubic inches of non-compressible fluid at 640 psi. There are no valid units. We are back to the same question. How many joules of energy did it take to arrive at 15 cubic inches of non-compressible fluid at 640 psi? We simply don't know.
Thought experiment: You fill up a solid steel box with one-inch-thick walls with an interior that is 10 x 10 x 10 inches. You close up the box with a one-inch-thick steel top that has a gasket and eliminate all the air and bolt it into place. On one of the the walls of the box there is a tapped fine-pitched thread with a bolt inserted that terminates with a thumb wheel.
At the start the pressure of the non-compressible fluid is zero PSI. Then you give the thumb wheel five clockwise turns and the end of the bolt slowly pushes it's way into the non-compressible fluid.
You end up with 1000 cubic inches of non-compressible fluid at 1000 psi.
Big deal, it means nothing. It took very little energy to bring the non-compressible fluid up to 1000 psi.
ATEOTD we are all interested in whether Mr Wayne has found a mechanical OU system that has the ability to self sustain itself [without loosing PE] & do external Work [Joules] - this is the same as saying that the Output Energy is greater than the Input energy in layman terms - off course all energy must be accounted for somehow.
Mr Wayne says he has competent engineers & advisers on his team - I have no doubt that most if not all of them are classically trained in physics & would have been scratching their collective heads to identify the apparent energy conundrum - they do have more information than the average thread follower & have probably narrowed down the 'suspect list'.
My initial thoughts still hold true to me - that if taken on face value that the dual ZED's work as described & that the system is OU, then I expect that a likely candidate for energy entering the system to balance the energy budget is from an ambient source.
I suspect that we would be looking at a type of heat pump or refrigerator analogue i.e. the air is compressed in the pods & due to compression the temp of the air increases - the liquid acts as a heat sink & the thermal energy is drawn away from the compressed air into the medium & ultimately into the surrounding ambient air around the machine - then when the pods are allowed to do work the compressed air expands & cools as per the ideal gas laws etc - thermal energy re-enters the system [heat flows from hot to cold regions] & the air coming off compression expands further giving augmented force amplification.
It seems like a classic heat pump scenario with adiabatic & isothermal phases where thermal energy does mechanical Work to my way of thoughts - ultimately a heat engine where the machine draws thermal energy from the environment & this is used to do Work.
Disclaimer: this is a hypothesis of operation to explain an anomalous energy gain in a self sustaining machine cited by others as factual.
Hi fletcher,
A great classical physics analysis and theory. Glad to have your head in the scrum.
Just a side note question: Are you in "town" for awhile or heading back out (away from the computer) soon?
M.
Thank you Larry,
All of our production goes into an accumulator -
And then we power the water moving system with a portion of that production.
Our input cylinder (lever arm) - is fed from the accumulator has a surface area of .998 inches - it travels 12 inches - yet we only supply pressure during the last 6 inches.
Our output cylinder is 4.995
It is not an inch for inch system - the lever arm travels (during the last six inches) 2 inches to produce a 1 inch stroke in the production cylinder.
and then the process repeats.
And we have some losses in the process so at the end of the day - 2 inches (consumption) at the lever arm gets us 5 inches production and after losses we end up with just about 2.5 inches gain - per half stroke.
Or a full cycle - we consume 12 inches of fluid - and produce 30 - loose 3 in the process - netting 15 at best.
Now we currently run 3.7 strokes a minute - net just 55 cubic inches a minute
This was supposed to be a 40 watt demo and data collection system.
It is close - about 36watts.
Have a meeting
Later,.
Wayne - typing in a hurry - so forgive me.
Updates to simple as it gets proof 'Archimedes Pod versus Travis 4 Riser System' picture.
I'll take the green horse colors(4 Riser) for a race, as nobody with common sense would take the red horse colors(Archimedes)?
Wayne has previously stated that the number of Risers effect efficiencies. This should now be obvious that more riser would increase the 37" to 164" advantage and less Risers would decrease the 37" to 164" advantage.
Regards, Larry
PS: How long will it take for the deceivers to bury this one, with their babbling BS, just observes who tries and the fact that not one of them wants the Red colors?
Quote from: mondrasek on August 11, 2012, 05:40:01 PM
Hi fletcher,
M.
Hi M .. just in town for a short stopover & away again.
As you can see I am more interested in the energy budgeting approach than the actual mechanics because the Laws of Thermodynamics are over arching above Newtonian physics & mechanics - interestingly Bernoulli fluid dynamics is predicated on COE & makes no allowance for adiabatic cooling followed by isothermal warming, as I propose as a potential way for thermal energy to enter the "apparent" closed system.
I do find it curious that Mr Wayne & other insiders so far [unless I missed it] have not offered up any coherent theories about balancing the energy budget - I do not believe this is an oversight & it would be the main target of my inquiries if the mechanics demonstrated "apparent" OU & I was one of those convinced of what I was seeing - those same resident engineers & advisers [& Mr Wayne] must have formed some theories by now that could be shared here without compromising any patents etc so I don't know why that is not forthcoming, if it is so ?
On that note, & in the interests of resolving and/or replicating these claims, I would trust yourself & TK's build & analysis, if either of you were willing to put some time & effort into an independent build(s) - it would be appreciated by me especially, to help get to the bottom of this.
P.S. to test the ambient thermal energy input hypothesis the uninsulated control system could be tested against a thermally insulated system to see if the results varied significantly - the results, either way, would be a good clue to ruling something in or out.
Excellent!
Thanks fletcher and seamus10n!
Sounds like the MOAC is needed? TK, what say you?
I am assuming this test will require a miniature ZED system build since the MOAC would be very, very, very difficult to construct on the scale of the current ZED system?
About the "set up" question...
I go into auto manufacturing plants a couple times a week. I see automobiles being assembled. About 400 per shift per line, or 800 per day, per line. Some assembly plants have three lines, so, about 2400 cars per day...
If you do not believe this please use Google Earth to look at the US state of Kentucky. Before you even zoom in further than the borders of the state you will be able to see a dot just North of Lexington that is known as Toyota Motor Manufacturing, Kentucky (TMMK). They have more acerage under roof than any other company in KY IIRC.
So, an automobile requires how many parts to be assembled? And each of those parts requires how much energy to manufacture? And so when I purchase that vehicle it is declared on the MPG (or KPL) rating that the "set up", or manufacturing costs, of the vehicle must be considered?
Well then my Toyota Camry costs -.025 MPG when I buy it, no? (Edited to add, I really drive a Chrysler.)
Seamus102, I know this is not an "apples to apples" comparison, so please don't take it as such. It is only meant as a thinking point.
Sorry.
Back on topic.
So, where were we?
M.
A question for you Mr Wayne.. Have you or your engineers accounted for this energy source in your calculations?
I wish I had read this earlier, I just had a meeting with the Engineers to review the Presentation they have prepared for Mark and his groups.
When we were reviewing the little 160% model 36watt model - and its design in comparison to the 10kw model which is over 800% efficient - I paused to think - if people can not grasp the 160% what are they going to do with the 800%? ???
So I asked them ....How does it feel to be so confident in a system that you were well educated to "know" was impossible? (as you remember I dealt with negativity all day on the forum - and to see those brilliant men in complete and utter confidence in the Physics was curious) - they said "It feels pretty good!'
A little misunderstanding about our system - we have reduced the input cost - we do not get more out of the system than it could generate - The wrong question is "where does the energy come from" - the right question is "how did you reduce the input".
Larry has been doing an excellent Job showing how our layered system reduces the input. If you are looking for missing energy - you might not see it.
In our system - reducing the input while still producing within the capability of the system.
I know this is hard to swallow - that is why we have the big dogs working to prepare the world - as Mark explained - "it is a paradigm shift in the understanding of physics"
When Mark asked that same question last year in May - that was hard to explain - until you could wrap you head around these
Four things:
Our system is like a hydro pneumatic piston - we only supply input into the smallest diameter - yet we produce force from additive layers which continue to increase in diameter.
Second - we push down and gravity pulls down to generate an upward force - The upward force has no real weight value. (when you understand this point - you will understand why I say it is like we have a long lever we only have to move a short distance (Larry's Chart shows this today as well).
Third, the layering system increases the speed and along with point number one - increases the effectiveness of the Travis effect 11.1 times better than Archimedes' in time distance and mass.
Fourth - None of the energy used to push down is consumed - it is recycled every stroke - over and over.
So - it is design, gravity and system.
I hope this helps.
Wayne
almost 100 pages of pure garbage.
so far, no solid proof to prove the workings of this machine.
all of this could of been a lot easier and direct but now it's piling up into a mountain of shit.
a simple HD video showing ALL parts inside and out of this machine in operation could of saved us tons of time.
also a video showing the machine being put together one part at a time describing each part.
and having someone replicate your "over unity machine" by some dude and sending him 2,000 dollars doesn't prove anything either.
funny because many of us have seen this kind of mountain before and wont be the last either.
good day sir!
@Mr Wayne. I am asking you personally to help clarify a statement you made earlier, which seems to have caused a misunderstanding between myself and others. Here is what you stated.
"I watch as some argue that using 15 cubic inches @640 PSI to generate 30 cubic inches @640 PSI in the same time frame is not overunity-or not using the right words to describe- is that we have is 15 cubic inches every stroke-3.7 times a minute."
I venture to suggest that you may have made a mistake when you wrote that. "Using 15 cubic inches to generate." Is that 15 cubic inches of water being injected into the ZED ? If it is, then it will surely not be at 640 PSI. If it is not the input to the ZED, what is it? I assume it must be the ZED input because it is the ZEDs that are OU, not the high pressure hydraulic transmission system.
So for the sake of clarity, could you please help us here?
Respect, neptune.
Quote from: seamus102 on August 12, 2012, 02:24:41 AM
No, it doesn't help and your engineers should be ashamed of themselves for believing it. I shall leave the argument at that and await proof that you have a working system.
Well, Enjoy yourself, lol.
Opposite and equal reaction - we just use what we push one way - and then let it push back - we pay for the loss in the travel.
Wayne
Quote from: microcontroller on August 12, 2012, 03:27:03 AM
This is in conflict with this:
Overunity is a clear statement and it is something else then reducing input cost.
Reducing input cost means you improve the overall efficiency of a system but this is not the same as overunity.
Overunity means you get more energy out of a system then you put in.
The correct question then is: where does the extra energy come from.
If there is extra energy it has to come from somewhere.
Your words are in conflict.
To make things clear a system is overunity or it is not.
THere is no in between.
It cannot be overunity in 7 steps, it is OU or it is NOT.
Also, talking about 10 Kilowatt systems removes every doubt i have about this system being a fake.
You clearly have no understanding of how much 10Kw actually is.
That is about 10 water boilers ! are you INSANE?
The claims you make cannot be true, if you were to look at a system like your's producing 10 Kilowatts of power it would destroy itself within seconds, and the water will boil continuously, it will be vaporized in a few minutes and your unit would explode.
Here we go again.......lol
We have no input Zero, nada, none - we use our internal operating costs to calculate our efficiency - now - you can stand on your idea that overunity must be magical energy - but ours is not that kind of Overunity.
I am sure you know that if you do not have an input - and you produce extra net - massively in our case - well that is a good thing - tough to swallow - I grant you - but has it not made you pause for just a second that ours has been reported and verified multiple times by credible people as the .1% in contrast to the 99.9% failures at Overunity?
Our system has a super efficient input cost - I have been clear on this many many times - you forgot to quote all those statements - I wonder why?.....
No I don't lol - you are just out to confuse people - I wish you used that energy to help mankind - and not try to rip them off from the Independence this machine is bringing.
Once again, ROFL.....
How could anyone ever discover anything with your limited mind....
I repeat - We do not use thermal energy - please read the patent - read the posts, get your hands wet - omg
Our Z.E.D. internal operating pressure is max 40psi, the capture method changes by output -
Our 100kw system uses a crankshaft..... our systems are quite, no emission, no fuel, independent and simple - maybe not to understand - but to build.
Why would you try to scare people?
We have talked about this all before several times?
Wayne
Quote from: Ghost on August 12, 2012, 05:05:27 AM
good day sir!
Thanks for checking in,
I see you never got your hands wet... that does make it hard for you..... I can see where you are coming from. wrong of course - but if you make your decision by the effort you have put into this - counting pages.... well --- Good luck.
Also - You may have been misled - I am sorry for that - I volunteered to help those who wanted to learn about the system.
Not to prove our system to you - would you seriously believe anything your read on the net as fact?
(I try very hard to stick to the facts because of people like MC, ME, who try to twist every word into wasted pages of garbage)
No of course not - I do not expect anyone to believe either - but if you are one of the people who do decide to get your hands wet - and then have questions - take a look at the patent - do a simple test of your own - or read on the replications of those you might trust.
If you trust no one - how could I help you?
You are correct about the garbage - I am glad it stays so that everytime you and others check in with a stink bag - it is recorded - it makes up about one third of the garbage on this thread.
I do not know about other threads - on this thread - garbage thrown by people who do not take the time to look for themselves.
Look for yourself - and you have a qualified argument - other wise you just toss a stink bag ...If you base your argument on the pile.... bad form....maybe you will see something that 44 other engineers missed.. it could happen.
@Ghost - have you seen one single reason posted here on why the physics of our design can not work? No - but you have seen a Dozen that have replicated the physics from the patent and agree.............
I see you have experience with failures. That is the way with ALL inventions - it is not proof of the future - but it is proof of the need and desire for a certain goal.
This invention is not about me - but I do have to lead the charge - this is the contribution I have to the world.
Vocal people like yourself could add very valuable contribution to the world if you took the time to research yourself.
Good Day,
Wayne
Quote from: neptune on August 12, 2012, 05:51:48 AM
Respect, neptune.
Hello Netptune,
I am sorry, thought I did - reply 1262
In the model at our house - we use a hydraulic system to capture the buoyancy first - and then we use some of that captured and stored energy to increase the transfer of water between the Zeds -
On our system we only have to pay for the loss of the water's head during transfer - and whatever portion we leave in the Z.E.D
With loss in transfer and counting what we left behind - we consume (in this model) about half our hydraulic production.
Our hydraulic production is about 30cubic inches a full stroke / cycle.
Now - before MC posts another bag of stink - we have - like all systems, losses in every exchange - except the Z.E.D portion -
nine losses as I have stated before - with these losses - a third of our production is up and gone.
That leaves us with about a third of the excess to NET.
The good news is this - I built the Z.E.D. from the theory of operations I gleaned when I saw the Travis Effect, my engineers have optimized the design - our 10K system is not much bigger than my 36watt model.
Yet the losses do not increase at the same rate of production increases!
Once they understood how the system functions "OverUnity" they hit the floor running to optimize.
@Neptune, I keep seeing you try to encourage people to come and see - that is great, I love to share - Validation is coming - do not worry about that or the stink nags - how silly, and natural this will all seem in near future -
Resistance to change is as hard on some people as losing a loved one. Even my engineers went through stages of disbelief.
They were wise enough to make their decisions - in time - on the physical evidence.
The truth will prevail - it is just birthing pains we go thru now, some will come see the baby, some will wait for graduation.
Wayne Travis
Hi Wayne, and many thanks for your reply. So let me summarise what you said, as I understand it.
1.We are talking about the 36 Watt model that you have at your house
2.Let us define a cycle. We have 2 ZEDS, A and B , so at the start of the cycle A is down and B is up. A rises and B falls. Then A falls and B rises. This cycle repeats 3.7 times a minute.
3. During a cycle as defined above, a total of 30 cubic inches of hydraulic fluid is forced into the hydraulic accumulator by the rams [acting as pumps Wayne calls these 5 inch diameter rams"Production Rams"] which are activated by the Zeds as they rise. The pressure in the accumulator is 640 PSI.
4 The pressurised fluid in the accumulator represents stored energy. This is then used in 2 ways. Part of it powers the hydraulic ram which help to power the water transfer between ZEDs.This ram is called the input ram or transfer assist ram, and has a diameter of one inch. That accounts for about 15 cubic inches, taking into account system losses.
5. The remaining 15 cubic inches of fluid is used to power a hydraulic pump, which in turn, drives an alternator connected to a load. The power dissapated in the load is approximately 36 Watts.
@Mrwayne. Could you please tell me if I got it right.
Quote from: neptune on August 12, 2012, 09:45:51 AM
3. During a cycle as defined above, a total of 30 cubic inches of hydraulic fluid is forced into the hydraulic accumulator by the rams [acting as pumps] which are activated by the Zeds as they rise. The pressure in the accumulator is 640 PSI.
4 The pressurised fluid in the accumulator represents stored energy. This is then used in 2 ways. Part of it powers the hydraulic ram which help to power the water transfer between ZEDs. That accounts for about 15 cubic inches, taking into account system losses.
5. The remaining 15 cubic inches of fluid is used to power a hydraulic pump, which in turn, drives an alternator connected to a load. The power dissipated in the load is approximately 36 Watts.
Hello M.
Yes your recap is correct -
Except Number four needs to clarify that the input ram and the production ram are not the same unit.
The production rams (one per Z.E.D) is 5 inches in diameter, and the transfer assist ram is 1 inch.
I am afraid some might get that confused the way it was worded.
The input is used to increase the pressure flowing from the lowering Zed, to reach the stroking pressure of the producing Zed -
and then the process reverses.
Thanks,
Wayne
Quote from: mrwayne on July 23, 2012, 09:51:20 AM
Thermal:
We do not exchange heat - or do any form of exchange in that manner - When it is hot outside - or cold - the system does respond as expected - the accumulators nitrogen does expand a bit - but since the system is self regulating - it compensates automatically.
The speed and pressure we deal with are barely enough to measure that exchange - Our engineer said - it is less than one 90 degree elbow (in the plumbing) adds in resistance and loss to the system.
Wayne Travis
Misinformation deterrence.
Larry
Here is an idea: TK will go see Wayne, and Wayne will host (tolerate) his visit.
But it requires that TK get from SA TX up to OK. He could drive, but it would be better if he was driven. Anyone willing to help out with this part? Oh, BTW, there will be a dog (mostly) that must accompany him as well.
Next, TK states that he needs to be paid. I, personally, think he should just suck it up. But I do believe we could get together as a group to meet that requirement if, well, required. I seem to remember about $500 on the table for a trip that Webby has not accepted (yet)... And there are others who would consider his fees much less than the report he would provide.
But we can still wait on MD also. So, any thoughts?
M.
I have now modified my last post [1276] to take account of Wayne`s constructive criticism. Thanks.
Quote from: mondrasek on August 12, 2012, 10:31:18 AM
M.
Sounds like a good plan,
Thinking outside the Box.
Can he fly?
But I would not "Tolerate" as a host - I would consider it an honor.
TK - if you can come - the only thing I have to hold back is our Optimizations, our contacts, and Business model.
The machine and its system is fair game.
@All,
I am a respectful man - it is Mark Dansie that went the full distance to check this out - so he will be given credit at the end of the day. For his bravery, his discovery - as the First Skeptic.
Thank you all,
Wayne
Quote from: mrwayne on August 12, 2012, 08:35:12 AM
You are correct about the garbage - I am glad it stays so that everytime you and other check in with a stink bag - it is recorded - it makes up about one third of the garbage on this thread.
I do not know about other threads - on this thread - garbage thrown by people who do not take the time to look for themself.
Good Day,
Wayne
Maybe I'm not smart enough to understand, maybe I don't have the funds to get my hands "wet".
But one thing for sure is I hope you do have something here that actually works and is Over Unity.
Too many people have come and gone, only to leave us with nothing but a false claim, and even worst robbed us for what little we have left.
I hope you are real and not just another rerun of the same old story.
By the way your reply shows you know a little about our frustration, and this gives me a bit of hope of what is left.
good day sir!
I would also be willing to contribute to TKs travelling costs, though I think it likely that at the end of the day
TK would have to build the unit for himself to be totally convinced of over unity performance.
Hope he does build such a unit and proves that the Technology Works, at least then we might all know
how best to make a selfrunning one.
Quote from: mrwayne on August 12, 2012, 10:52:50 AM
Can he fly?
I believe he can soar. Or at least did at one time. So that might be an option.
Now the Chowyote is another question.
I doubt TK would want to put Maggie through the stress of such a short flight. But I assume too much if I try to speculate what Al might want to do. So I'll wait and listen.
M.
It is always difficult to prove that a OU system works and is indeed OU because people will be extremely sceptical.
In my opinion it is also impossible to calculate or to describe the "essential OU power generating part" using conventional formulas (conventional physics) because the OU part will violate conventional understanding. To describe the "essential OU power generating part" new formulas and a new theory will be needed.
But it is absolutely necessary that the inventor shows a machine that works over a long period (let's say at least a day) and puts out a considerable amount of net energy during that period continuously (let's say at least about 50 Watt for 24 hours).
I will believe in Mr. Wayne's hydro system once a credible witness reports that she/he has seen the machine work for at least a day and that she/he measured the output during this period. (Since there seems to be no input, output measurement will be sufficient and of course it should be checked whether there really is no input).
This said, I do not understand why we have no reports of this kind so far. The witnesses who came forward in this thread only reported about the character of Mr. Wayne, but did not see the machine in a working state and could not do measurements.
It is also very difficult to digest why the web site of Mr. Wayne does not disclose such a trivial test (together with comprehensible measurements, e.g. net output of a machine over 24 hours, may be also a video).
Why should any one travel to Mr. Wayne's location as long as there is no machine running consistently with a measurable net output?
Why should any one try to replicate Mr. Wayne's machine as long as there is no machine running consistently with a measurable net output?
Greetings, Conrad
Conrad,
First, thanks for the input.
Second, here is just one (my) idea for a response to your well stated post:
What if RIGHT NOW is the time when the ZED system is first being publicly displayed for our scrutiny?
What if all previous testing, builds, etc., were not documented and posted on the 'net?
What if the described and patented system was developed, tested, and scrutinized for several years before even the "inventor" was convinced enough that it was not a "pipe dream" and was ready to face the pubic?
Please do not take anything I posted as an attack, Conrad. I deffinitely did not mean it as so and only want to hear your response to these "counter thoughts."
M.
Conrad:
I think that you make a lot of good points. To add to your thoughts let me share a few ideas.
There is no point visiting Wayne without knowing ahead of time what the power production will be and what form it will be in. For example, supposing the claim is that system drives a generator continuously, and the generator output is 100 watts. If that is the claim then fine, you now can ask what the output voltage and frequency is for the generator under load, and what the load resistor is.
Supposing the generator outputs a sine wave at 25 Hz, and with the load resistor connected to the generator output, the RMS output voltage is 50 volts. So P = V^2/R, therefore R = V^2/P = (50 x 50)/100 = 25 ohms.
So, you need a 100-watt 25-ohm resistor to connect to the generator. Let's assume you can go onto the DigiKey web site and find 5-ohm 20-watt white ceramic resistors. They might be the size of a small chocolate bar. So Wayne orders five of these resistors and solders all five in series and connects the resistor array to the generator output. The string of resistors is suspended in mid air to allow for measurements and for convection currents for cooling. Without proper cooling they will burn up.
When you arrive at the site you have a true-RMS multimeter. You measure the resistance of the load resistor to confirm that it is 25 ohms and you connect it to the generator output and then start up the machine.
Once everything is running you can check things. You measure the RMS voltage across the load resistor with your true-RMS multimeter and verify that you are measuring 50 volts RMS. You touch each one of the resistors and verify that they are toasty hot. You can hear the generator RPM and that gives you auditory feedback that the system is maintaining proper rotational speed and output voltage.
Then you camp out in front of the device for a while. The best-case scenario would be for two people to camp out in front of the device and take turns sleeping. We are not going to have a repeat of the fiasco where Sterling went to South Africa and saw a running device for 45 minutes and was "convinced" that it was real. Then Mark Dansie visited with a full team and within a few hours it was found out that it was not real, it was all a fake. Talk about a waste of time and serious money, all for nothing.
Note that in the past on this thread I asked about the form of the power output and how it was measured but that was never acknowledged or answered by Wayne. It would be preferable if two people were to visit Wayne and camp out in front of the device (with tents - no kidding) where they could periodically spot check the load resistor. That would be approaching the "real thing." After a while you would not even need to use your meter. Most of the time you could spot check the power output just by touching one of the 5-ohm resistors and feeling the heat production.
If I was going to cheat I would put some very large commercial compressed air tanks inside the device to power the system. They are cheap and can store enormous amounts of energy. So in my personal opinion, one day would not be enough time. I think that two people would have to camp out in front of the device for a week or more. You should also have a mechanic's stethoscope and use it periodically to listen in on the operation of the device. Any anomalous sounds of air hissing outside of the normal operation of the device could be a valve opening and recharging the system with compressed air from a hidden cylinder. Don't forget that this system is run by a microcontroller for all of the valve timings, and it would be trivial for the programmer to make a program that recharges the system every four hours from one of the compressed air tanks.
This is a proposed real way to test this system. And if you are going to go visit Wayne to see "proof" that it works, proper due diligence would require something as comprehensive as I outlined above.
Well said Conrad ..
M .. the 'plot thins' ;7)
It seems after reading todays comments that there is a subtle difference in interpretation of what OU actually means - in the traditional sense [perhaps that which we are used to thinking about] a certain Input energy produces a larger Output energy, after accounting for ordinary system losses & perhaps a load/work done by the engine - & an engine it is that Mr Wayne describes.
All engines either use a replenishable fuel source to convert to joules or they make use of a naturally occurring differential that the mechanism can exploit to self sustain itself & do Work [sometimes environmental in origin] - so far, AFAIK, there are no known exceptions.
In this case Mr Wayne describes a process of reduced Input energy which gives rise to a larger Output energy - this may appear as semantics - in effect what he describes is a process that restores ALL Potential Energy & meets ordinary system energy losses [i.e. is self sustaining] AND has capacity to do external Work each cycle.
My interpretation of Mr Wayne's responses & those of his engineers ['that they are comfortable with'] is that they have found a demonstrable way to disprove a fundamental physics principle - that is, the Work-Energy Equivalence Principle.
IOW's, that by pure mechanical means it can be proven that the Work in joules the system does to restore itself is less than the energy in joules [i.e. capacity to do Work] it produces - this indeed would be a paradigm shift in understanding of physics !
Before I would take that plunge I would isolate any & every potential input of energy source from the environment I could think of to make sure it is not a contributing factor - it is a given that there is no fuel source or augmented energy input from the pressurizing system that depletes over time [I think the engineers would be capable of determining that].
Lastly, we would be left with a major conundrum - what "fuels" this engine - AND where did main stream go so wrong in assuming that the Work-Energy Equivalence Principle was inviolate - AND are there any naturally occurring examples now that we know what to look for - ALSO, does this mean the Laws of Thermodynamics are also now tossed out ?
If Mr Wayne & his team are on the level all of those questions will need answering by some big brains.
P.S. also well put Milehigh - couldn't agree more for a true test !
Fletcher:
Very interesting comments, but perhaps they are better left for a second-stage analysis to determine where the energy is apparently coming from. According to Wayne it's a "workaround."
You stated Wayne's proposition correctly, "Mr Wayne describes a process of reduced Input energy which gives rise to a larger Output energy."
However, there is a problem. I asked about the measurement of the reduced input energy and the measurement of the larger output energy corresponding to the cycles of the ZED. Unfortunately all of the participants in the thread working with spreadsheets and Wayne himself apparently don't want to answer this question. So we are stymied where a "free energy device" that is ostensibly based on a measurement of "reduced input energy" and a measurement of "larger output energy" per cycle is some sort of an obstacle that the participants in the thread can't seem to come to terms with.
So perhaps the best way to go forward is to avoid these issues and just do proper due diligence and measure the output power of the device over an extended period of time.
I agree MH ..
That's why I have been patient in awaiting MD's response - he is nobody's fool - he will probably also be reading this thread as it develops & so all the skeptics comments may prompt him to look closely in certain areas he might not otherwise pay close attention to - I think he is very thorough though.
I also point out, as has been said before, that this exchange & response format here may not always be comfortable for either the skeptics nor My Wayne, but it will be a 'dry run' for what is yet to come for him - it also firms up descriptions & analysis into a logical & robust presentation that adds clarity to the arguments of both sides - therefore it has value to all.
In the mean time, if Mond or TK can build something to compare to the information given, or be free to report on a long run load test etc, it would also be valuable in looking behind the curtain for those answers - personally I don't want to rewrite the Laws of physics but if they need rewriting then so be it & more power to Mr Wayne's elbow & bring it on.
Before anyone starts to make fun of my (obvious) lack of photographic skills: Please note that this is from my cell phone. Mommy has the good digicams with her and the "littles" on a trip at the moment.
M.
Quote from: microcontroller on August 12, 2012, 01:56:13 PM
I'm sure it does and i am sure you have a couple of those running as we speak.
I'm also sure you and your team are currently working on a 50 Megawatt unit.
That's comparable to a very high and very large windmill.
I have seen some powerful gasoline generators that run at 3000 rpm producing 2 kilowatt max.
I'm sure your Boyuancy machine runs faster then a turbine far exceeding 30.000 rpm to produce your 10 kilowatt output.
Keep talking like that Wayne, it certainly eases things up.
@ MC,
Please recall Our machine is for mass energy production.
3kw is too expensive per watt to build, sorry.
Keep doing what you do best -
So will I.
Wayne
Whoooah there, big fellas!
Thank you for volunteering me..... but I would like to have a little input in the matter!
First, I want to thank MrWayne for the invitation, and for not lumping me in with the "stinkbaggers".... I try to be skeptical in a reasonable manner, and generally won't start slinging stink until I'm quite certain of my "pitcher's mound" or I have to field stink that gets thrown at me.
Oklahoma hospitality is second to none... except maybe Texas hospitality!!
Second, thanks to Mondrasek for being the "instigator" of my involvement. I can tell that if I lived in his neighborhood, I'd have to keep my lawn mowed, for sure!!
Third, for a preliminary visit, I think that MileHigh's approach is a bit too radically doubtful. In a perfect world with perfectly compliant personalities it might be the way to go, but my take is this: If you are gonna try to fool me, I want to be fooled, first. Let me see your very best dog-and-pony, smoke and mirrors show. Then..... after you fool me, I'll tear it up, bring the tent and the xray machine and the colored dyes and transparent tube sections and so on and so forth, because I will then have some idea what to look for.
However I don't believe that MrWayne is trying to fool anyone---- I've suspended disbelief, remember?
So for a first visit by me, I'd want to see the normal demonstration, and be allowed to poke around non-destructively a little bit, just an investor's agent doing some due diligence, looking mostly at "face validity": does it do what it says on the box, not necessarily _how_ it does it. Some basic measurements of electrical parameters, some basic mechanical investigations, etc. just to get an idea what is up, what needs to be measured more formally, and where a "wedge" could be driven in to see how a perturbation is handled by the system.
The full-on skeptical teardown campout, BYOB would not be a polite first approach I don't think, but should be held in reserve. But, since the performance _as stated_ so far appears to be contrary to standard physics, and would, if true, imply that a lot of other stuff we think we know is wrong..... then, if it does do what it says on the box and the preliminary inspection sees no obvious mistake... or fake..... only then would the more "hostile" approach be appropriate or necessary. And of course if it _was_ fake, it's unlikely that such an approach would actually be permitted. That "other" TK, Sterling's South African genset, the Popper John story, etc etc .... all fakers resist real inspections and just do "demonstrations".
Fourth: some practicalities.
4a) I do have access, with some finagling, to the world's most precise civilian bulk calorimeter, MOAC.
However it is definitely NOT portable or easy to use (it takes about a week for it to "warm up" and stabilize before any accurate testing can be done) and it has an active test volume of about a cubic foot. It's really designed for cold fusion cells that have perhaps only a milliWatt excess power... yes, with care it can measure that precisely and accurately. But clearly it's not going to be applicable here, and building a huge one would not be possible.
4b) I don't fly commercially, I know too much about aviation for that. (google PPRUNE)
It's only around 400 miles from San Antonio to Chickasha, a straight shot up US 281, a pleasant day's drive. I do have some physical issues that make driving problematic at times, but I could probably do it OK. I certainly would NOT want someone else to drive me up there. Taking a bus or train is possible but less desirable than driving, because I really don't want to leave Maggie the feral chowyote behind. I hope MrWayne wouldn't mind having Maggie around; she can be tied up to my car and is perfectly happy that way as long as there's shade and water.
4c) Money. The love of money is the root of all evil. But the lack of money means inability to operate.
I'm told that my services come too cheaply, even some of my staunchest detractors tell me this. And in the past I've spent a lot of my own money and other resources on projects like this one. But unfortunately those days are gone, along with the money. I've calculated out an approximate cost if someone were actually to hire me at my daily consulting rate, plus expenses of course, for a visit like this. Two days travel, two days on site, lodging (Motel6, they allow dogs; no, sorry, professional ethics preclude me staying under MrWayne's roof as nice as that might be) meals expenses etc.... comes to right around 2 grand. This is reasonable for a potential investor, thinking about cutting a big check to MrWayne, as an attempt at doing due diligence, caveat emptor, and so on. But how to justify that kind of expense for a report to an internet forum? It's just silly, much as I need the work and the money... it's just silly.
Now... a much better idea:
MrWayne has a small working model, does he not? At least that's what I thought. And even a single Zed is overunity... right?
I have connections at a very professional laboratory that looks for new physics, that evaluates devices like this without charge to the submitter _IF_ the thing looks to have "face validity"... it appears to do what it says on the box. And this lab gives ironclad IP protection to the inventor. So.... take the small device and ship it down to them and I will "walk it through" the inspection, testing, and validation process, and let _them_ pay my fees, which they will do without difficulty (I hope). And maybe I'll even get more than four days out of it.
Another alternative, if the small Zed isn't available for some reason, is to send Webby some more money so he can purchase some nesting polycarbonate tubes from one of the plastic suppliers I linked earlier, and some machine shop expense money, and have him and a local machinist make up a "proper" (no offense Webby!) demonstrator with ruled reference marks and instrument fittings and so on. If the tennis ball tube model demonstrates the Travis Effect overunity... and it must, right, else why did he get the 2 large in the first place?... then the better constructed polycarbonate model will too, and it can be sent off to the folks I know with full confidence.
Ok.... there's my two bits.
Carry on.....
Now.... some test protocol questions for Webby and the spreadsheeters working on single Zeds.
The device is precharged with whatever necessary, a known test mass is placed on the output riser or pod or whatever it's called: the output, and it's now sitting there motionless and ready to go, all cylinders and risers etc. sitting at some reference marks "A".
Right?
Now we take a spring scale rigged to read compression force. We push down on the input thingy using this spring scale to allow us to maintain some constant pressure (force) downward, and we press for a travel distance of some known value, say 5 units, on our scribed scales on the sides of the tubes. We have now done X amount of work (the spring scale force reading x the pushdown units).
Right?
We see the output thingy rising, lifting the known mass. We now have an output value for the work: the downward weight of the known mass (a force) x the lift distance.
Right?
Now we relax the applied force to the input and allow the system to return to its equilibrium state.... which should be identical to the initial state.
Right?
Now we can find the ratio of the input work to the output work easily enough.
Right?
Quote from: mrwayne on August 12, 2012, 12:51:05 AM
Wayne
The question is 'how do you reduce the input' and that is shown in the drawing, but most recent posters completely ignore it. What is your real reason? You don't even ask how I calculated these values. I do have a spreadsheet ready, but that would just be more proof and I suspect you don't want to see the proof.
It is so simple, there is 4 phases, Sink to Ready to Stroke, 3" Rise, 3" Fall, Ready to Stroke to Sink. The only phase that Archimedes accomplishes at the same speed is the 3" Rise. It is all about time. 4 Riser requires much less time in all other phases. So back to the simple formula, Power = (Force X Distance) / Time.
Regards, Larry
PS: At all with common sense and values the truth, it will be interesting to see how long it takes them to bury this one in their useless blabbering.
Hello folks,
I have been lurking for many weeks while working on my simulator for a single layer single ZED demonstrator. I must say that I have been a bit amused by the members thinking that they must somehow prove O/U or not for his existing machine. I do not believe that Wayne needs or desires this kind of "help". MD is in charge of that type of effort with much expense and preparation for each stage of verification. There would be plenty of investors based on MD's approval of the technology, and follow-on testing would reveal the physics involved.
Duplication and testing of duplicates is more valuable than one more tear down of his machine. What Wayne needs is independent replications that show O/U. That will add more credibility to his device than anything else. End of story.
Wayne has made himself available on this site to provide enough information for experimenters to build their own small models. He even offered a bounty to keep the cost of the construction materials from being an obstacle. He has been most gracious in inviting and hosting those who desire a visit to his shop.
I must also say that I have been very disappointed by the very poor manners displayed by some here. Being a skeptic is good. It keeps one from falling for scams, delusions, and bad math. However, being disruptive and obnoxious and thinking the inventor owes more than his stated purpose of sharing is a hinderance for those who do want to proceed with experiments. Enough said.
I will be releasing my document to this site in the next few days. The document is an analysis of the principles and formulas that I am using in my simulation for this simplest of cases. Successful verification of the simple case by competent skeptics will be followed by a more complex multi-layered case. My approach stresses successful simulation to pave the way for robust replications.
LarryC:
Quote4 Riser requires much less time in all other phases. So back to the simple formula, Power = (Force X Distance) / Time.
You seem to be implying that for one of the steps of the 4-riser it happens much faster so there is "more power." What I believe that you are not getting is that then there is a "dead time" were nothing happens. Am I correct?
To factor in the "dead time" you look at the entire cycle time, and then you get (Force X Distance)/Total_Cycle_Time to get the
average power per cycle.
But if you want, you can simply factor out the total cycle time and just talk about the energy expended per cycle. Each one of the four steps (I assume) either inputs or outputs a certain amount of energy during the entire cycle. So discussing the energy required per step is sufficient.
Am I making sense to you? To me you seem to be saying that if the 4-riser requires two seconds to do a cycle but the Archimedes requires five seconds to do the equivalent cycle then the 4-riser is "more powerful." But if the total cycle time for the two methods is ten seconds and they both do the same lifting job then the average power for the whole cycle is the same for the two versions and nothing remarkable is taking place.
Can you do me a favour? Pretend that someone starts reading the thread at this point and they will not read the previous 80 pages. Can you explain what your diagram is post #1296 means in simple plain English? Can you list the steps one by one and explain what happens in each step? Can you calculate the energy required to do each step?
Honestly, I look at your diagram and I can't make head or tail of it. Also just to repeat for emphasis, you talk about lifting a weight a certain distance for a given step. Surely you can indicate the energy required per step? If we assume that you are going to discuss one complete cycle, then we don't have to look at power at all. Just the energy calculation for each individual step.
I am just going to share a few thoughts based on one of LarryC's earlier postings:
QuoteSimple as it can get proof. Apples to Apples.
The attached shows a Archimedes Pod of 30" diameter with retainer and a Travis Pod of 30" diameter with retainer. The Archimedes Pod is the height that it would take for it to have the same lift forces as a 4 Riser Travis System. The Riser are not shown as the water is only input into the Pod retainer.
Note that the Sink to Stroke water difference for Archimedes is 164, while only 37 for 4 Riser. Also note that the PSI levels are higher for Arch. than 4 Riser, this advantage is due to larger SI areas on the Risers.
Archimedes has to input 164" of water pushing against PSI from 5.43 to 11.33.
4 Riser has to input 37" of water pushing against PSI from 5.07 to 9.99 PSI.
Or Archimedes has to input 4.43 times as much water at the SI as 4 Riser for the same lift with a much increase load and unload time going from Sink to Stroke and Stroke to Sink.
If I understand correctly, the 4-Riser system will only have to input roughly one-quarter the water as a regular Archimedes system to do the same lifting job. I am pretty sure that I am correct here but by all means please correct me if I am wrong.
Would it be fair to say that the 4-Riser is sort of like a four-segment telescoping antenna as it expands?
Assuming this is the case what the 4-Riser does for you is give you four times the lifting distance for every unit of water put into the 4-Riser as compared to the Archimedes system. So LarryC crunches the start water pressure and the end water pressure and the water volume in his spreadsheet and it all looks really positive.
So if I am following this correctly, it's like the 4-Riser is kind of like a mechanical lever, but in this case the "lever" is giving you four times the lifting distance as compared to the normal Archimedes system.
If what I am saying is true, then I believe that there may be a problem with the calculations.
He is the gist of the problem: If you are getting four times the lifting distance, then there is a price to pay for this "advantage." Where you have to pay the price is in the "back pressure" coming from the weight you are lifting. In the 4-Riser system the "back pressure" coming from the weight that you are lifting will be
four times higher.
In other words:
Let's assume that we are going to lift one pound by one foot, and we are only going to discuss the "back pressure" that the one pound weight induces on the water inlet point of the system. We are going to use simplified units.
To do the same lifting job of a one pound weight by one foot:
Archimedes: 1 unit of back pressure x 4 units of water = 4 "pressure-water-units."4-Riser: 4 units of back pressure x 1 unit of water = 4 "pressure-water-units."Note that the two calculations above represent the
energy required to do the lifting. You are pumping some water into the device which creates a
displacement. As you pump you are exerting a pressure which is a
force. So the two simplified calculations above represent
force x displacement = energy.
In other words, with the regular Archimedes system or with the telescoping 4-Riser system, it takes the
same amount of energy to lift the one pound weight up by one foot.
In other words, a telescoping 4-Riser is just a lever, and the fact that you get four times the lifting distance per unit of water means that you have to supply four times the water pressure to do the actual lifting.
If I am on the right track, I am suspecting that you are making a mistake in the estimates for your "start pressure" and "end pressure" for the 4-Riser system. You are not accounting for the "lever effect" associated with the telescoping segments of the 4-Riser as they give you increased lifting distance,
and increased back pressure from the weight.
@Larry: along with what MH said.... Power is NOT a conserved quantity, like work and energy.
(Too bad too..... or my TinselKoils would be so massively overunity that we could all go home and relax. I have input power of less than a kilowatt, and I have peak output currents of 8 amps... at well over 30 kV. Go ahead and calculate the COP of that one... using Power alone.)
Average power is better, as MH said, but "many is the slip between the cup and the lip" even using average power.
Work is the conserved quantity. (Same thing as Energy: force x distance, even the same units: Joules)
Was there something objectionable or wrong about my question set above? Did I misunderstand the nature of a "cycle"?
We start with a motionless precharged Zed, not counting the work necessary to set this up. We apply a known quantity of WORK, force times distance, both easy to measure, by depressing the input piston (or cylinder, same difference I think). We get out a known quantity of WORK at the peak of the cycle... again, force times distance, easy to measure. And we let the system relax back to the beginning of the cycle which is identical to the start of the cycle, all pressures and displacements the same.... otherwise it's not a cycle, right? Maybe we have to put in more WORK to get it back to the start: this counts as INPUT.
So.... what is this ratio in your spreadsheet simulation? Output WORK/Input WORK. That is the question (whether I suffer the slings and arrows of outrageous fortune....)
Just a little side observation...
The skeptics like me and MH and Seamus10n are asking simple questions that require simple answers, from simple measurements made in simple ways. If I had a Zed or a set-up spreadsheet sim... I really think I could answer the questions, simply and clearly.
But we are getting complicated answers that are nearly uninterpretable, answers that don't include simple measurements, with units attached, combined in simple ways.
Maybe this is caused by the difference in training, education and experience of the people in the conversation, and is just a matter of "talking past" each other and we will eventually settle on a language and a methodology that we can all understand.
Or maybe it's not.
Quote from: seamus102 on August 12, 2012, 10:19:23 PM
We can discount any such analysis based on the knowledge of currently accepted physics if it shows that the system would break the laws of conservation of mass, energy or momentum.
These laws are mathematically provable as being correct and have been experimentally validated in every single case. (until now if this claim is to be believed).
If you are getting an overunity result by using any mathematical model that violates these laws then one thing is certain, your analysis is WRONG.
You'd better be prepared to bring to the table a theory that demonstates how and why current physics knowledge
is incorrect. It would necessarily show how gravity (perhaps just in Oklahoma) is not a conservative field.
As such, this claim can only be verified experimentally. There is absolutely no valid mathematical model that can be constructed using known physics that would support it.
Sir, It is quite poor form on your part to cast dispersions on my work with a preemptive strike before you have even seen it. How do you know what I have simulated? Please hold your comments until there is something to comment on. Then, if you are capable of analyzing my work properly according to the laws of physics, I will welcome your considered analysis.
LarryC:
More for you about your start and end pressure calculations. It looks to me like you are factoring in the water head pressure but I am not sure if you have the back pressure from the weight factored in properly, like I said before.
Let's split the pressure into two parts.
There is the back pressure associated with the weight itself. We can treat that as a constant. I am going to assume that you can calculate the back pressure associated with the Archimedes system. And of course the back pressure associated with the 4-Riser system is four times higher.
So you know the water volumes in cubic inches, and you know the PSIs for the two cases. We can do something to make life really easy for you. We can use energy units that are "CI-PSI." Cubic inches times pounds per square inch. Those are the units you are working with if I am correct. So if you multiply that out you get (Cubic inches x pounds / square inch) = inch-pounds. You notice that is a unit of energy, it's just a variation on foot-pounds.
Let's say for the sake of argument you use inch-pounds for all of your calculations. It's perfectly valid.
If you are following me, you should be able to calculate the energy required to lift the weight in both cases, Archimedes and the 4-Riser, and they should be the approximately the same. You just have to work out the back pressure associated with the weight in each case.
Let's call that your "Lift_Energy" - the amount of energy it takes to lift the weight a certain height.
Now, the other amount of work that has to be done is to push the water into the two types of cylinder and overcome the head pressure. Be very careful and carefully examine the head pressure in the Archimedes vs. 4-Riser case. Does the "lever factor" come into play here? I am sure that you can figure it out.
For the work required in inch-pounds to fill the cylinder with water, don't be intimidated by the fact that the head changes as you add water. You know the head rises linearly as you add cubic inches of water. You know the start pressure in PSI, and you know the end pressure in PSI. You have all of the information that you need. This is a very simple integration of a ramp function.
The energy that you have to add to overcome the head is the ((End_PSI-squared x Total_Cubic_Inches)/2) - ((Start_PSI-squared x Total_Cubic_Inches)/2)
If the Start_PSI is zero then it simplifies to ((End_PSI-squared x Total_Cubic_Inches)/2).
Lets call that your "Head_Energy" - the energy it takes to pump the water into the cylinder as the head rises.
So, the total energy it takes to lift the weight is simply = Lift_Energy + Head_Energy.
This will apply for both the Archimedes and the 4-Riser setups. You just have to carefully work out the calculations and you are done. I think you have enough information on your end to boot-strap yourself and solve for the energy in both cases.
OK, so if a single (or dual) Zed has no real "input" cylinder or piston, and instead must be supplied with an injection of liquid to initiate a cycle... that is even easier. You simply arrange a "syringe" to inject your fluid. You monitor fluid pressure in the syringe, and you know the surface area of the syringe's piston. The pressure in the fluid and the piston area give you the force, the piston travel is your distance. Work in is thus again easy to measure. Work out is the lifted weight times the lift distance, again easy.
Please correct me here if I'm wrong.
And once again... for there to be a "cycle" the end state must be the same as the start state... so syringe again full, with its piston out, and the lifted weight back down. If it takes more work to reestablish this initial state, that counts as input.
Will see3d condescend to put his results in this form so that they may be interpreted by those of us who are straitjacketed by our educations?
Quote from: MileHigh on August 12, 2012, 09:13:00 PM
Am I making sense to you? LOL
Let's see, if the 4-riser is 2 seconds for a half cycle and Archimedes is 5 seconds for a half cycle, so the total cycle for the 4-Riser is 4 seconds and the total cycle for the Archimedes is 10 seconds. Where did you come up with the both being 10 seconds, liar? .
LarryC:
You have got to be kidding calling me a liar. If you got what I said it really doesn't matter if the cycle time for the Archimedes system is different from the 4-Riser system. To make your life simple you can look at the energy per cycle in both cases.
If one system does a full cycle faster than the other system you can address that issue later. The thing to do is focus on the energy per cycle for each system.
I don't even know what the cycle times are for the two systems.
To the flock:
I am going to go out on a limb and make some "forward looking statements."
My gut feel is that I discovered the root explanation behind "a process of reduced Input energy which gives rise to a larger Output energy." It's all explained in my previous postings. You are looking at start pressure and end pressure for regular Archimedes and "Travis Effect" setups. You are looking at how much water you need to use for each setup.
What you see is that the numbers are apparently showing you that you can do the lifting cycle with less energy with the "Travis effect" because you use less water and the start and end pressures are comparable to the standard Archimedes setup.
What you now know is that there is an error in the start and ending pressure calculations. They are much higher for the "Travis effect" than you thought and when you calculate the energy needed to lift a weight for the Archimedes and the "Travis effect" setups they are approximately the same.
I think the other thing that you learned is that it's not really difficult to make energy calculations. If you know the number of cubic inches of water that you are using and the required PSI you have all the tools that you need to calculate energy in inch-pounds. The only "trick" is that when you are lifting a weight you can split the energy calculation into two separate parts and then add them together. One part is the energy to lift the weight itself, and that's almost trivial. And the other part is to overcome the head pressure, and if that goes up like a linear ramp as you pump cubic inches of water in, then that's trivial also.
Note that for those of you that have done spreadsheets, they are just a few simple steps away from becoming energy-based and in the "proper language." The language that you have been using over the past 88 pages to evaluate these systems is frankly nonsensical.
So the message here is that if I am on track and this is resonating with some of you, then it's time to start thinking outside of the "Travis box" and speak up for yourselves. I know that there is a peer-pressure phenomenon and it's very strong. It can be stifling. Just think for yourselves and you will be fine. This is a place where you are supposed to be open-minded to all ideas.
Mondrasek ..
Has anyone made an animation of one ZED in operation thru one cycle ? If they have perhaps they could share it again ?
See3d mentioned using a sim of some sort to support his case, to be presented in a few days.
Quote from: microcontroller on August 13, 2012, 12:31:09 AM
Please go.
I will too pay you.
Shipping doesn't seem right.
We need somebody on the spot.
Thanks... but.....
Work in, versus work out.
I would really like to see the answers to some of the simple questions that are being asked, before I make any travel plans.
I'm not much of a "people" person. I get along much better with dogs and machines than I do with people, as you can probably tell. I've been known to get up and walk out of meetings when I feel that I'm being snowed or talked down to or being subjected to inordinate obfuscation. I don't want to make anyone look bad, least of all me, and I don't want to embarrass myself or anyone else who is acting in good faith. So let's see if we can get any answers in the form of work in versus work out, before we pack me up in a box and ship me off to Oklahoma with a pressure gauge, a tape measure, and a DMM.
Time is money, and none of us have all that much of either one to be tossing them about in the wind.
Plus, isn't there a report from Mark Dansie coming soon? I have some confidence in him (not 100 percent... the only reason I even know who my daddy is, was that my momma told me so....)
I have seen Se3d's single layer,
He is brilliant and methodical - so if he says he will release - count on it.
His uses the physics to run the model - my terms.
I should in the next couple days - If my animator can get it done quickly - release mine.
I have a wonderful 2D model cut away - really helps - I am having the optimizations and improvements taken out so I can release it legally (proper timing - patent attorneys...).
Se3d's is better for brains - mine is better for a general grasp of the whole system.
@ Larry,
Please don't argue with Seamus, he has made his stand - any physics that agrees with our claims is "WRONG"
I am not here to push my understanding on others' beliefs....Change is hard to deal with.
TK, my only argument with anything you have said - was calling Seamus a "Skeptic" - he proves he is not - by his predetermination. - Mark Dansie started out that way - He told me it would take less than two hours to determine where I was wrong, by theory or measurement - he determined I was not a fraud before he came.
But he took the time to look - and then made a hard decision - that is a "Skeptic."
Seamus - by his own admission - Antagonist at best.
To All,
I am not ignoring the question of energy - I know why that is pushed as the question - I have never stated and do not believe we are "creating" energy - the purpose of that attempt is not to understand - but to turn this thread to the topic of "energy creation" that is not the stated purpose of my interactions.
I am not here to help someone win their own argument - when I do not disagree with it. Pushing the argument into a corner is a standard tactic.
I could care less about the Energy - if it has Net at the end of the day.
To be clear:
It has been repeated here over and over my purpose is to help others replicate our system.
We capture a natural force - once believed "conservative" gravity - it is a tricky process - and it confuses many.
Probably why it is not in the text books already.
Yet - Our physics are solid as a rock - and yes they come from those text books - and every replication proves it -
It is true that the "Infinity error" is also taught in text books - I never claimed Gravity would last forever - I expect it to in my lifetime. If you can not see past the error of the "error" - lol oh well.
One last note on incorrect assumptions - Our engineers had the most trouble with the down stroke - it is Nonlinear as we have shown here before. Don't be mislead - by others stating it is.
Replications:
I will let Webby answer why he decided to build - but the fact remains - he did - no matter how convoluted and confusing the arguments get here - it can be done and has.
I have never limited my instruction to those "friendly" but I will not sponsor - mud Slinger's.
I loved the simple input output apparatus Webby built, I wish I had thought of it, very clever - I suggest you look into his design for yours.
I build a huge apparatus because I did not trust my fine measurement skills - and I did not want other people to have to question their own. It works - or it doesn't -build it and you will know.
I am not selling kits - Yet - lol we do have working models being built - so don't beat me up on that later - the universities are going to need the models to explain the shift in physics. The instructional has been under preparation by a third party for a few months.
Third party is how we let others come to their own conclusions - replication is the best way to understand.
Good luck to you all! This is a grand puzzle for O/U students old and new - with a twist - you can win.
Update on Mark's return:
We finished the modification to our energy capture system Friday - ten thousand dollars and a lot of work - but we are done. I have not been this excited in months!
We will resume testing long runs on our system - and if the "fix" to our manufacturing variance works as planned - Mark has set his return for the week of the 20th.
So wish us luck, and / or drop a prayer - extraordinary proof on its way!
Energy Independence - not energy creation lol
Wayne Travis
Tk,
I was not referring to your question of input and output - on the Energy push.
Honestly - i do not yet understand your question.
If you were asking Larry - please remember he is comparing Standard buoyancy to ours.
Personal note:
History is filled with attempts to defeat the conservative field of gravity - no success.
It is an illusion - that gravity is overcome by buoyancy
Where our system is different:
Gravity is predictable - or has a measurable effect on mass - in that use - Archimedes is right on the money.
Air and water have different mass / density.
Our Zed - in its simplest form - reuses the same mass over and over simultaneously - in an additive fashion.
Larry is showing that we can get the same effect of Archimedes in a much, much smaller mass - yet the field of gravity did not change - pressure differentials can result in movement - and ours combined.
Recap:
We do not just increase the buoyancy - we concentrate the measurable effect of gravity in a smaller space -
Larry's data is just showing the effect of that concentration.
It has some pretty cool side effects - such as reduced input - increased speed,
in my opinion - it is as if we have concentrated the force of gravity - by concentrating its effect over the same mass against the light mass (air).
With that under our control - we unwrap the Conservative field of energy (referring to gravity and buoyancy).
Every single part of our process is measurable- understandable - and repeatable.
Please forgive me of my layman nomenclature - i am not an engineer - just a blessed mechanical person.
If you are able to ask your question in layman's terms - I will definitely answer.
Thank you for your patience
Wayne Travis
@mrwayne. Thanks for that update. I am sure we are all hoping you get "all your ducks in a row" in time for MD`s visit later this month. It is very interesting that, for the first time I believe, you state that the machine draws energy from Gravity. I always thought that this was more likely than the theory proposed by some, that is was ambient heat.
I am sure that we all look forward to seeing your animation, another tool to help us understand how it all works.
Regarding Webby`s build. You seem to know a bit more about this than the rest of us, which is as it should be as you awarded the prize. I believe that few, if any , details have been published here as to just how his water injection apparatus works. He seems to use a vertical pipe full of water to provide the input pressure, but we have no details on how he allows water to exit the ZED for the downstroke. Perhaps he, or you, could tell us more. No doubt when he is ready, Weby will show his how he operates his ZED, and if he has got to that stage, how he measures input/output.
More and more information is becoming available, and I am hoping that when I am in a position to do some building, after my eye surgery, things will fall into place.
Quote from: fletcher on August 13, 2012, 05:35:39 AM
Mondrasek ..
None that are public that I am aware of. Hopefully what see3d and Wayne are preparing now will be accurate and complete through an entire cycle.
I am sorry M,
This is my opinion - my engineers argue..
Gravity causes buoyancy, and in a combination of ways - causes head pressure.
Our system just works out the relationship and maximizes the relationship difference and gravity's effect on two separate densities.
Our system would work with water and Mercury - no air as well (actually Better).
I try to let people make up their own minds - but sometimes they get way off track.
Wayne
I posted last week that a square build was in progress and I did have some sheet stock and made a few practice glue joints. Testing those joints proved they wouldn't hold up long and I received a few PMs with concern for binding in the square config. Back to the board... I also checked all the links for acrylic sources and could not come up with the right sizes to build consistent .125 spacing and wall thickness; until I found eplastics.
I did a mill test yesterday to see how well I could cut consistent grooves in plastic and the results were quite good for a first attempt so... This morning I ordered material for a 4.25 x 12 ( 16" to 24" with the extensions ), 3 layer model. ( no where near $2000 )
Wish I'd started sooner, by the time I'm finished the official demonstrator and documentation will probably be out but I just couldn't wait...
Quote from: wildew on August 13, 2012, 10:48:26 AM
Great news, must have missed your original post. PM me if you need any improvement in the 'Travis Effect Material Take off Square Shape-4 Riser', like more than 4 Risers.
@Wayne,
Thanks, good explanations. And you're right, I should stick to my goal of helping those who want to learn to understand and not waste time with the deceivers. Unfortunately, I don't have your Christ like patience.
Regards, Larry
Quote from: LarryC on August 13, 2012, 11:18:48 AM
@Wayne,
Regards, Larry
Patience yes, but not that much, all I can say is that when I accepted the responsibility of bringing the machine to the world - I would not waiver or be mislead - by those who would wish I did not.
I also witnessed the mistakes made by Rossi and Kwok - anger might fuel a few people - but to keep your ground and character - patience is better - and the truth is the best.
I appreciate a good argument, when one really exists.
Wayne
I'm glad to hear that there are coming some better explanations of the effect.
Last weekend I modeled for myself a complete cycle of 1 riser based on INVERSE Travis Effect which could lift 1kg over 1cm after addition of 100grams of water BUT I needed all the energy produced to return back to the original state. I did not modeled n-riser yet.
One question to Mr. Wayne,
Is the Inverse TE considered full equivalent of normal TE. I'm asking as the Inverse TE does not use air.
with kind regards,
Marcel
Quote from: MT on August 13, 2012, 01:30:21 PM
with kind regards,
Marcel
Hello MT,
As you have observed - the system pushes as hard down as it does up in the single set up - a single layer has a reduced input as compared to Archimedes' - and you measure the equivalent of one full mass.
That mass is equal to Both the water you input and the hanging (fixed load) Just like Toms video did.
Adding layers without the separating walls and air gaps - does not equal to reusing the mass (which is critically important).
p.s. You should re post your picture it is right for a one layer system -
Now:
In the system just as mine multi layers - the force is both up and down - it might seem to be pushing down harder because the weight of the system is pushing down with the heads - but you pay for that on the way back up.
Operational note - we do not add air to the system after starting - only the initial set up - and we transfer water instead of air.
Cool thinking! I hope this helps - but always check for yourself - I could be wrong - I test eveything....
Wayne
@MT. I am pleased to see that you are experimenting. Can I just point out a common cause of confusion. People often use the word MODEL. And they, themselves know exactly what they mean. Unfortunately this word is ambiguous, in that it has multiple meanings. At least three are applicable here.
1. A mathematical model, where mathematics is used to describe the action.
2.A computer simulation
3. A real world replication of a real world machine often smaller than the original, but mimicking some or all of its actions.
Some people talk of a physical model, but this could be the same as 3 above , or could be a theoretical proof base on Physics. So may I suggest that we use the term "Real World Model" when we mean 3 above. So tell us please exactly what type of model you are describing.
None of the tube suppliers I listed a few days ago would suit? Sorry.
http://www.jcdanczak.com/our_products/subcat_16.html (http://www.jcdanczak.com/our_products/subcat_16.html)
http://www.k-mac-plastics.net/polycarbonate-tubes.htm (http://www.k-mac-plastics.net/polycarbonate-tubes.htm)
http://www.usplastic.com/catalog/item.aspx?itemid=23791 (http://www.usplastic.com/catalog/item.aspx?itemid=23791)
http://www.carrierplastics.com/polycarbonate_tubes.html (http://www.carrierplastics.com/polycarbonate_tubes.html)
http://www.interstateplastics.com/Clear-Polycarbonate-Tube-POLCE.php (http://www.interstateplastics.com/Clear-Polycarbonate-Tube-POLCE.php)
You don't say whether you are working in acrylic or polycarbonate. Proper tool speeds and feeds, cutting angles, and lubrication/cooling are critical for success with plastics.
Normal twist drills will usually crack acrylics when coming out the back side. Special drills with steeper point angles are available for drilling plastics. A set in the usual fractional sizes is well worth the investment and can usually be obtained from the plastic supply houses or tool speciality shops.
I buy WD-40 by the gallon and use it for coolant-lube when cutting acrylic (plexiglas, acrylite, other brand names.) Kerosene is also recommended but I don't like the smell. Water works fine for polycarbonate.
The worst thing you can do is to use too fast speeds and feeds, overheating the tool. You won't know you've ruined a workpiece until... you've ruined it.
Make sure your tools are _sharp_, especially your thread-cutting taps, and with the proper angles.
Good luck with your build.. I'm sure we'd all like to see some "work in progress" pix !!
(ETA: I see that you did mention acrylic. This would not have been my choice, because of its brittleness and shatterability. It is a slight bit easier to machine than polycarbonate, but in the long run the polycarbonate would be more durable, I think. But carry on.... do get some sharp-point drill bits if you are going to be drilling holes in the acrylic.)
Quote from: mrwayne on August 13, 2012, 09:24:53 AM
Tk,
(snip)
Wayne Travis
Well... that's fair enough, because honestly, I don't yet understand your explanations, either.
So...let's try it like this.
Do you have a single Zed, that shows the effect, the gain, the overunity, by lifting a known weight a certain distance, or providing a known volume output of liquid at a known pressure?
(This can be answered YES, or NO.)
If NO... then stop, because we have hit a contradiction: I think that earlier you (or someone) said that you did.
If the answer is YES.... then, does it start out, motionless, at a position with pressures and volumes known, and wind back up at that same position, with the same pressures and volumes?
(Another YES or NO answer can be given.)
If NO... then stop, because we have hit a contradiction: we have not yet completed a CYCLE.
If the answer is YES.... then, what does it take to start it up and make it lift that known weight that certain distance, to the top of the cycle?
The answer to this last one I expect to be something like "We need to push down (or in) on a hydraulic ram" or "We inject a volume of liquid at a pressure" or something like that. Very simple.
OK, I have tried to make it easy for you to understand my questions so far. Will you please try to make it easy for me to understand your answers?
Once I understand the answers to this part, I might be able to understand the rest. You have to cut me a little slack, though... I am straitjacketed by my education and it takes me a little while to wriggle out of what I "think" I already know.
Quote from: mrwayne on August 13, 2012, 08:55:02 AM
To be clear:
It has been repeated here over and over, my purpose is to help others replicate our system.
Yet - Our physics are solid as a rock - and yes they come from those text books - and every replication proves it.
Wayne Travis
Thanks Wayne for the additional information.
Also to be clear - you & your team have taken the position that gravity is not conservative which allows for net work/load output capacity ?
My question is a rather obvious one I'm afraid.
Can the Single or Dual ZED configuration operate as you propose outside a gravity field ?
For example, by creating an artificial ersatz gravity differential thru the use of a rotational environment & inertia i.e. centrifugal forces ?
This is the constant angular velocity spinning space station analogy.
The implications being, if the answer is yes, that if an artificial gravity can be substituted for real gravity differential/field then Cf's/Cp's will also be viewed by you as non conservative forces by deduction.
This would mean IINM that the Travis Effect is NOT a gravity/buoyancy effect but a differential-field/buoyancy effect that can be used to create an engine to do Work because the TE mechanics allow for non conservative force generation ?
If the answer is no, then an engine based on the TE will not work in space or horizontally & only in a gravity field ?
I hope that makes sense.
P.S. I'm interested to hear if your engineers have the same explanation as you or a different one, & if so, what is theirs ?
@TK - Thanks for the comments on lubricants for the acrylic, well noted. I'm hoping my machining needs will be limited to some milling , a few holes in thicker stock, and one tapped hole in each of the plates. The mill test I did yesterday was in a piece of ABS ( I think, a softer, colored piece ) so I will do a practice cut or 2 in the sample set I ordered for testing.
A note on the sizes: A few sites offer .128 wall tubing in .250 steps up to 4.5 inch but if I'm figuring it right those sizes won't work in all all places. With a +- .005 tolerance it's even likely that a 4.250 piece will not slip over a 4.000 piece.
Here are the OD sizes I did order, all in .125 wall. They should be close to .125 spacing ( which is more than I'd like ).
4.375 - 4.000 - 3.875 - 3.500 - 3.125 - 2.750. I'm sure I didn't think it through well enough, we'll see if I'm up to it...
Dale
Quote from: neptune on August 13, 2012, 03:24:08 PM
Hi neptune,
I'm afraid I'm not fitting any. Before weekend I felt like I need to internalize the effect using concepts I can understand. For me is inverse TE more intuitive to think about. I see it as a weight amplification system. Smaller amount of water results in a bigger increase of weight. I tried to model complete cycle how 1 riser could work. Attached are 4 drawings.
1. initial step - lever is in balance. Left side 2kg weight, on right side is 3l bucket (30cm high, 10cm for each liter). Pod hanging from top take 90% of bucket volume. I abstracted from whether it is cylinder or square, water can take max 0.3l volume around pod. I think it is clear 0.2l makes right side weighting 2kg.
2. charging step - Lever is locked. Adding 100g(0.1liter) of water on right side at the top level of the pod! This is our input. Charged right side gets weight 3kg.
3. stroke step - unlock the lever. Allow lowering right side by 1cm. This movement does work. I do not dare to calculate it but it is clear that there is disbalance of 1kg at 0cm distance on right side and this disbalance decreases to 0kg at exactly 1 cm distance. Water level decreases to the level in step 1.
4. closing loop step - now to get back to the charged step we need to apply force on left side over 1cm. Starting at 0kg and linearly increasing it to 1kg over distance 1cm. Producing step 3 makes force going from 1kg to 0kg, this step needs force going from 0kg to 1kg over 1cm, so inverse. I think it is clear that work done in step 3 equals work needed to be done in step4.
kind regards,
Marcel
Dear Mr.Waynes, allow me to adress this question to everybody involved in this discussion.
Guys, I watched a quite interesting video demonstrating an oddment in regard to Archimedes principle, if not an open violation.
Unfortunately I cannot find the youtube link, but I recall quite clearly the parameters involved in the demonstration.
Is this what it is all about, is this the differential employed by Mr.Wayne? :
regards,
Gwandau
The significance with this experiment becomes obvious when the minimum weight needed to keep the right cylinder down, still keeps the cylinder with greater air volume inside the left cylinder from rising. If anyone has an explanation for this oddity, please respond.
QuoteQuote from: LarryC on August 13, 2012, 05:18:48 PM (http://www.overunity.com/10596/hydro-differential-pressure-exchange-over-unity-system/msg331945/#msg331945)
@Wayne,
Regards, Larry
Wayne
Well, I am no deceiver, that's for sure. And I made a really sound argument. I think that it's too strong to deal with so pretending it doesn't exist keeps the buzz going.
Who is the real deceiver will all come out in the wash eventually. I can predict with great confidence that not a single erg of excess or free energy or whatever you want to call it will be produced by one of these systems by December 31, 2012.
Neptune,
Cisco I think you meant 1149.
No problem, I would think that by now some basic research would’ve be done on the net and coupled with creativity, would have led most attempting replicators to the following sites among the many.
So these maybe of interest if you haven’t found them yet:
http://www.specialtybottle.com/amberpetbostonroundplasticbottlesmi.aspx
http://www.specialtybottle.com/naturalplasticbottlesmi.aspx
http://www.sks-bottle.com/340c/fin19.html
http://www.freundcontainer.com/kautex-textron-plastic-containers-kautex-wide-mouth-leak-proof-plastic-jars-hdpe/p/v3977B01/
http://www.visipak.com/clear-plastic-tubing.shtml
Note the varying available diameters and types. Look around mix and match from different suppliers to get more options. It may shave you time making your own cylinders. You can still use the standard soda bottles to supplement sizes and the final external container 2L bottles and so on.
They go from less than a buck to couple a piece. You may try a request for a free samples when they are sold by the case.
The last link has the tennis ball tubes and associated products
If you dig deeper, wall thicknesses are in the .015â€to .025’ area some maybe more.
Blow molding process. Most made of LDPE HDPE and PET, and if you really want to get into the nitty gritty, pressure stress/strain calculations, use the matl properties, hoop stresses, deformations etc,
The “pod†can also by made by the smaller ones Instead of machining a piece of metal. Use the smaller bottles, fill it with sand, and styrofoam grinds or whatever, to provide extra strength against collapse (highly doubtful) to get at your desired buoyancy level your setup requires for the pod.
Tubing, can be from aquarium, or your local hardware store would have a variety of diameters and types. Sold by the foot for pennies. For tube fittings, just go to your local party store, get for 0.15$ the tube, about ¼†diameter 16†long thin wall with a movable flange on it, that they use for those helium balloons. Cut the tube to length use the flange or make your own for added handling strength and gluing surface, drill hole(s) on the bottle where you need access, or the bottle cup for the external water reservoirs some silicone, rubber glue…
The setup is small, so for accurate measuring of differential weights, visit your local pharmacy, ask for the graduated plastic syringes. You can get them for free one or two samples etc. You can measure and dispense water fairly accurately for increments down to tenths of a cc.
Stay creative, have fun.
I hope this helps
Gwandau:
QuoteGuys, I watched a quite interesting video demonstrating an oddment in regard to Archimedes principle, if not an open violation.
The setup on the right will have much more buoyancy and there is no violation.
MileHigh,
thanks for the response.
So even if the amount of water displaced by the right cylinder is less than the left cylinder, there will no difference in lift?
Excuse me for my ignorance, I always thought the Archimedes principle was depending on the displaced amount of fluid in relation to the weight
of the displacing object.
Gwandau
Gwandau:
In your example the fixed inner cylinder on the right could just as easily have been air and it would be the same thing and act the same way.
The real cause of the buoyancy is the air pressure pushing against the inside of the outer cylinder. All of the air pressure pushing on the vertical walls of the outer cylinder provides no buoyancy because the air pressure is in a horizontal direction and it all cancels itself out. The only thing that counts is the air pressure that pushes on the top of the inside of the outer cylinder. That air pressure comes from the water pressure at the bottom of the tank.
You just have to look at the individual surfaces and the forces on those surfaces from the air pressure or the water pressure. In the case of the setup on the right, the water pressure at the bottom of the tank becomes the air pressure inside the outer cylinder.
QuoteI always thought the Archimedes principle was depending on the displaced amount of fluid in relation to the weight
This is a specific example that is simplified. If you were to look at it in terms of surfaces and the water pressures and air pressures on each surface you will arrive at the same conclusion as the simplified example.
MileHigh and seamus102,
thank you for enlightening me, your descriptions were clear and elucidating.
regards,
Gwandau
Quote from: TinselKoala on August 13, 2012, 04:02:24 PM
TK, I have a great deal of respect for you and the effort you have given to help and protect others
I said I will answer your questions about energy -
Be clear - I do not share on this site to try to convince anyone or to replace the "team in place" for our validation.
Your format is inappropriate for my stated and intended purpose here.
I will repeat what I have said - our current single unit is barely better than a hydraulic cylinder - you can measure the input and output - we do not use weight - but volume and pressure. Yes - our three layer system is clearly overunity by itself.
In this small model - hooking the system together bumps us up by reducing the input further.
Oops dinner - more later.
Wayne
TK,
Please send me a personal e-mail to mr.wayne@hydroenergyrevolution.com
I believe you are trustworthy - I do not have the time to bring you up to speed in this forum fashion - I will send you some info
to leap you ahead.
Your questions will be more to the point. You need to know and remove the hearsay.
Wayne Travis
Quote from: fletcher on August 13, 2012, 04:12:43 PM
Our system relies on the effect gravity has on separate density - a rotation system would increase the system on earth and work in space.
We have a rotational model - I not allowed to discuss it yet.
Wayne
Quote from: mrwayne on August 13, 2012, 09:18:37 PM
TK,
to leap you ahead.
The your questions will be more to the point you need to know and remove the here -say.
Wayne Travis
I'll be happy to do this... but only on the condition that I can share whatever you send me with the other forum participants if I think it's appropriate. Would that be OK with you?
I have no desire to know about your intellectual property at all, at this point, so please don't expect me to sign an NDA yet, and please don't tell me anything you consider proprietary. And I definitely do not need, at this stage, to understand _how_ it works, or to read long convoluted explanations of how it works ... I just want to know _at this point_ if it does what it says "on the box"... the title of this thread. I simply want to know what goes in (energy, aka work) and what comes out (energy, aka work), averaged over a reasonable time period, like one full and complete cycle or a multiple of full and complete cycles, so that a claim of overunity-- what it says on the box-- can be supported with data. That much, I think, you could show or tell anyone without revealing your secrets. And I'm pretty sure that, were I in your position, I could do this in a reasonable time period... like a few minutes.
Well Wayne - I am most definitely looking forward to MD's analysis or any competent detailed analysis for that matter - it will be interesting to hear TK's updated thoughts after an exchange of emails & information with you.
A rotary mode engine based on 'formerly conservative forces' of either gravity or inertia, or both, would indeed be game changing in all ways & a natural progression of the idea for you.
I also appreciate that you are trying here to foster independent replications of the basic setups, which I don't have the time for, rather than enter theory debates - it's however part of the process from going from science theory to science fact when new paradigms are proposed.
ATEOTD a working physical model, validated & replicated, foreshortens all arguments & distills all essence - so no matter to which side any of us currently lean in this discussion we all have a common ground of wanting science truth, & that is what we all look forward to.
Well, you made me do it. I got my hands wet, doing a simple experiment that led me to an interesting conclusion and discovery.
I have discovered virtual water! And it has virtual weight, too.
https://www.youtube.com/watch?v=qFjqBaH_NWU
Quote from: TinselKoala on August 13, 2012, 10:38:54 PM
I have discovered virtual water! And it has virtual weight, too. ;)
I am still laughing -- you made my day!
We all live in a virtual submarine...
Bah!
http://www.youtube.com/watch?v=aPfTqrmnQuw
https://www.youtube.com/watch?v=qFjqBaH_NWU (https://www.youtube.com/watch?v=qFjqBaH_NWU)
Strange isnt it? ;] Now, if you second, displacement, glass had no weight, and was affixed to the first cup, just as it is in the vid, what would we see on the scale?
Mind boggling
MaGs
Quote from: MileHigh on August 13, 2012, 10:48:21 PM
Bah!
http://www.youtube.com/watch?v=aPfTqrmnQuw (http://www.youtube.com/watch?v=aPfTqrmnQuw)
But that is just a magic trick M. TK is showing something real. ;]
MaGs
Well not so mind boggling. The weight of the stand with the glass holder is applied to the scale by displacing the water. But displacing the water with a second empty glass fixed to the first glass, should only add the weight of the second empty glass. Right?
Like if you set it up the way you have with the stand, and have a way to bond the 2 glasses together while held in place and then removed the stand......
One might think that if the glasses were bonded together and the stand removed that the scale might show no difference, stand or no stand.
But I can see that even at the time of bonding of the glasses, that the stand is applying pressure to the scale, even if it is not the weight of the stand that is displacing the water after the glasses are bonded. After bonding, the weight of the stand is applied to the scale directly through the glass and the water is just additional weight.
Ah, so this is the why of the separate free floating chambers in the risers. Im getting an inkling of what is going on here. Ill see what I can make of it.
Thanks for the vid T. ;]
MaGs
Mags
QuoteStrange isnt it? ;] Now, if you second, displacement, glass had no weight, and was affixed to the first cup, just as it is in the vid, what would we see on the scale?
It's all about giving head.
If thats the way you want to look at it. :o
MaGs
Quote from: TinselKoala on August 13, 2012, 09:46:05 PM
Thanks, I have covered the input and output - very short on our current Data model -
IN -PUT = Each full cycle - 12-15 cubic inches of compressed fluid from the accumulator.
OUT - PUT = Same cycle - 28 -30 cubic inches of (same type) compressed fluid - pushed into accumulator.
The pressure depends on our desire no less than 500psi, no higher than 900psi.
Please remember the input comes from with in the loop of our system.
Wayne
@ TK,
Thanks for the laughs, excellent experiment.
But, I'm disappointed in your statement 'And I definitely do not need, at this stage, to understand _how_ it works'. It is a shame that you don't want to understand, because once you did, you would not have to travel anywhere as you would know how it works and could easily design your own system.
Regards, Larry
Quote from: LarryC on August 13, 2012, 11:25:55 PM
@ TK,
Regards, Larry
Ah, you forgot the emphasis on AT THIS STAGE, and NEED. Where, exactly, did I ever say that I did not want to understand anything? I generally say WHAT I MEAN, not what others want me to mean. Look carefully at what I said: I said that, AT THIS STAGE, I do not NEED to understand.
Why should I be made to listen to an obscure explanation of something that can't show me that it does what it says, first?
If I had never seen a bicycle, what would help me to understand it more: an explanation of how it worked, given in non-standard, non-engineering speak, or a video showing someone actually riding one? Once it's proven to me that bikes exist and can be ridden stably.... THEN tell me how, if I still need to know how.
But you will never convince me that a silly contraption like that can be ridden at 60km/h with a bunch of words.
Now... you and MrWayne aren't trying to convince me that there are bicycles... you are trying to convince me that there are _flying_ bicycles. (so to speak). So... right, I don't care how it flys and I don't need to know. First... convince me that it DOES FLY. And not by showing me tables of power-to-weight ratios, discussions of the Wright Bros, bumblbee flight, etc. SHOW ME THE SAUSAGES.
So far, no flying bikes, no sausages, and no energy input/energy output figures have been forthcoming.
Quote from: Magluvin on August 13, 2012, 10:55:44 PM
Mind boggling
MaGs
Try it for real - perhaps TK will oblige if you are unable - we are talking about the "hydrostatic paradox".
Here is a variation.
Place two identical bowls half filled with liquid on separate scales [or do experiments in series with one scale] - both bowls & liquid have the same weight force on the scales.
Now lower the reverse riser into one bowl of liquid by hand or mechanically - read the scale measure of total force as the water level rises in the bowl [pressure is increasing] - note that you have to apply quite a force to depress the reverse riser - naturally, because the riser is not fixed to the bowl the forces will try to reach equilibrium & separate the riser & bowl & this is the force you feel.
Repeat with a fixed displacer/reverse riser.
P.S. I actually did this many years ago using a balance beam, pivot, & two identical buckets - I half filled the buckets so the system was balanced - then I lowered into one a object that displaced fluid & thus the water level rose in that bucket creating a greater water pressure on the bottom of the bucket than its opposite - my displacer & the bucket moved apart [bucket rotated downwards] to find equilibrium - the energy cost of forcing the displacer into the water was the same as the rotational energy gained IINM.
Quote from: mrwayne on August 13, 2012, 11:23:24 PM
Wayne
So from this description you are not making a cycle, back to the starting volumes and positions yet, are you? It seems that you have pumped out 30 cubic inches of fluid from the Zed but pumped in 15 cubic inches of fluid. Thus... there are 15 cubic inches LESS fluid in the Zed and 15 cu in MORE fluid in the accumulator than you started with. Right? If this is a full cycle... so this means you could now start at THIS POINT, and do it again, right? Aren't you going to run out of fluid in the Zed after a certain number of these "cycles"? Or do you have to put in some more energy -- fluid under pressure -- somehow to reset the system back to the point where you started from?
If the first... you would seem to have a hydraulic fluid manufacturing plant, starting from nothing, making 15 cu in per squirt, filling up your accumulator. If the second... then you have not yet accounted for all the input work, have you?
(Conservation of Energy might be problematic... but surely everybody here believes in Conservation of Hydraulic Fluid... the stuff just does not come from nowhere and vanish back into nowhere, as much as we might like it to.)
"the input comes from within the loop"... sorry, this doesn't make sense to me. INPUT is something coming in from the outside. If your device has NO INPUT, yet makes an extra 15 cu in of hydraulic fluid per cycle... well I think Mark Dansie could confirm that pretty easily; the accumulator will be overflowing pretty soon. Or if it's just moving 15 cu inch from one Zed to the other and back again, with no input, and producing useful power output, that too can be measured in terms of energy. (In what form? electrical? How about just torque on that hydraulic motor., something that can be measured unequivocally with a simple Prony brake or fancy electronic torque shaft sensors for example.)
You sure are making it hard for me to stay out of the "stink pitcher's bullpen" here, Mr Wayne. It looks like determining work in and work out in your system is not going to be a casual affair and it's pretty clear that continued questions about it are just frustrating you. I'm sorry for that.
@fletcher: Nice.... and logical. All forces have "two ends" after all.... the displacer is pushing down, and the bucket is pushing up, with the same force. Not just the same numerical value in opposite directions... but the _same_ force, actually pushing on them both from "both ends" trying to separate them. Which one actually moves -- accelerates, F=mA -- depends on what's pushing back against it, with what force. Motionless objects are not "forceless", rather they are in force equilibrium.
(The bold letters indicate vector quantities: they have direction as well as magnitude).
TK:
You know the comedian Steven Wright. One of his lines was, "You know that feeling when you are leaning back in a chair and all of a sudden you feel like you might fall over backwards? - Well I feel like that all the time."
You have
ninety pages worth of Wayne describing the system but nobody truly knows how it works. Wayne is here to "teach" people to replicate and learn how it works, but at the same time he has stated many times that he is going to protect his intellectual property and he won't tell you how it works.
I bet you if you were to ask Wayne for a schematic diagram that shows how this system is supposed to work he will refuse, it's his IP after all. Even better ask him for a series of schematic diagrams, each one documenting where all the prancing fluids and swooshing gasses are for each step in the cycle. I have to assume that he will refuse. Yet at the same time he is more than happy to describe the cycles over and over in vague undefined terms, for ninety pages! So what is he doing here "teaching" people how to replicate if he won't tell you how to replicate? What is this business of endless streams of verbage demanding top-notch 3D visualization in your head, when it could just be diagrammed on paper? How many people reading this thread can visualize what Wayne is describing in terms of all of the cycles and transfers of fluids and pressures in their heads?
What is all this talk of the fact that the system does not produce any energy juxtaposed with all of this talk that the system can output continuous power and change the world? Those two conflicting statements have ping-ponged back and forth from Wayne about 20 times over the course of this thread. It doesn't produce "free energy," it just uses less on the charge cycle and puts out more on the discharge cycle, and it's going to revolutionize the world and he can quote you the continuous power output from the device, harnessing buoyancy with a "workaround" - but it's not a "free energy" machine.
What is this business with discussions about cubic inches of a non-compressible fluid when nearly every single other person with an energy proposition or a free energy proposition works in joules and watts and work and power - the universally accepted scientific terms that are the bread and butter and currency of this web site - except for Wayne?
So what is
really going on here?
Can you figure it out TK? Because to me it feels like ninety pages worth of balancing on a chair about to fall over - or not about to fall over. It's a self-balancing unbalanced chair.
It's all so simple, just read what Wayne posts in all its complexity and it will be as clear as night in the daytime.
QuoteWell, the sword swallower, he comes up to you
And then he kneels
He crosses himself
And then he clicks his high heels
And without further notice
He asks you how it feels
And he says, “Here is your throat back
Thanks for the loanâ€
Can you figure it out? Can I sell you some cheese?
MH .. we all have our own experiences - I was never able to find a 'workaround' to enable less Input energy than Output - Mr Wayne says he has found a workaround to this & that makes gravity a non conservative force - this forms the basis of a gravity-hydro engine.
Obviously my experiences & failures are not everybody's & Mr Wayne has a support team including engineers, so I have to speculate that they may know something I don't - their view & assertions don't conform to my world view & understanding of physics but it is never to late to learn if there is something to learn - that has yet to be determined & only the validators & replicators can provide that feedback I suspect.
I do believe that Mr Wayne is completely sincere in his beliefs & that is the motivation for his sharing what he can now.
@MH: Maybe ... we should all be made to wear ear phones.......
Something is definitely happening here but I don't know what it is....... do I, Mr.... er.... Wayne.
From the web page http://hydroenergyrevolution.com/index.php/current-objectives (see entry from August 13, 2012) we learn:
Presentation - we have moved our presentation (trial run) to this Friday at 7:00
May be Mr. Wayne will tell us after the "trial run on Friday" how long the machine worked and how much power it put out during it's working period?
From the web page http://hydroenergyrevolution.com/index.php/current-objectives (see entry from August 13, 2012) we also learn:
a lot of very smart people are working hard for us and for their own curiosity
May be one of these smart people can tell us after the "trial run on Friday" two very simple numbers: continuous run time and approximate power output?
After so many pages of "guarded explanations" and "world saving promises" by Mr. Wayne it becomes frustrating and annoying. Yes, he has no obligation to disclose anything. But what is his message?
As far as I understand Mr. Wayne's message: "There is an OU machine, but I can not show you a working machine and I can not tell you how it works and I can not tell you how much net power it puts out, please replicate it."
Greetings, Conrad
P.S.: Yes, I am frustrated and annoyed and my post is not nice.
OK, enough for the musical interlude already.
Fletcher said,
QuoteI do believe that Mr Wayne is completely sincere in his beliefs & that is the motivation for his sharing what he can now.
And that is my provisional stance as well, even though I agree with pretty much all of what MH has been saying. I believe MrWayne to be sincere and willing to help us "straights" understand his system, if that is really his goal. I might not be convinced that he is _right_ about what he's sincere about, but lots of people aren't, and I don't generally hold that against them.
MrWayne said,
QuoteI will repeat what I have said - our current single unit is barely better than a hydraulic cylinder - you can measure the input and output - we do not use weight - but volume and pressure. Yes - our three layer system is clearly overunity by itself.
So OK, can we please just for a moment concentrate on a single Zed that shows overunity, and not get sidetracked into talking about the full system with high pressures and accumulators and all that? Let's be specific: let's only, for the moment, discuss the three layer system that is clearly overunity by itself.
When most of us on this site talk about overunity performance, we are talking about a system that outputs more energy than is input, averaged over a suitable time period. This is distinct from "power" or average power, which might seem like the same thing but really isn't.
Energy is measured, in the system most of us use, the SI, in Joules. The units of Joules are also equivalent to the units of Work, that is, force x distance.
Now... for your statement that "the three layer system is clearly overunity by itself" to be credible, that "overunity" part MUST involve some input-output comparison, a comparison of energies or work. Otherwise... how can you justify the "overunity" part of the claim? If you are defining it the same way most of us do, you have got to at least know the input and output energies. But... if you are defining it some other way, we need to know what that is and to agree that it is a valid definition for the purpose.
So... referring now ONLY to the three layer, clearly overunity by itself system....
Go ahead and set it up, you can have this for free. Now it's sitting there, precharged, waiting to be started up. Right?
And the various pressures, water heights, cylinder positions and so on are known, can be measured. Right?
Now, you start it up and run it through a _complete cycle_. OK? A complete cycle means just that: everything back where it started from, ready to lather rinse and repeat.
How did you start it? How can you tell it's running, what happens at the "peak" of the cycle? And what is required to bring it back to the _identical start position_, including all pressures, fluid quantities, cylinder positions, etc so that it can start over? Describe this please, in your own words that you understand, and please tell us how you arrived at the "overunity" conclusion based on a single cycle, complete, of the three layer clearly overunity system.
Once you have described this in your own words, let's then see if we can translate that into the language of engineering: simply work in, and work out, in Joules.
Please notice that I am NOT asking "how" it does anything. I am just still wanting to know _what_ it does.
Quote from: see3d on August 13, 2012, 10:48:20 PM
and our friends
are all aboard
many more of them
live next door.....
(cue gurgling sounds....)
If I may; Mrwayne will correct if I'm wrong but I think this statement means that fluid is entering and leaving the output stage, not the ZED.
Wayne
The ZEDs continue to contain the same volume of air / water. The "extra" 15 ci of compressed fluid is cycled through the hydraulic motor to generate electricity.
Dale
Quote from: TinselKoala on August 14, 2012, 01:16:21 AM
What???
Output does not mean we take it out of the system.... are you playing with me lol
I will try one more time.
OUR PRODUCTION - is 28-30
Our INTERNAL CONSUMPTION is 15-18
With A NET of 12-15
Specifically concerning our "little model" - A single Zed needs 6-7 inches and it is a half stroke - a double Zed s requires 15-18
and one Zed produces 14-15, and the double produces 28-30
A cycle is One zed at the bottom of the stroke - the other at the top starting - and then returning to the same spot.
all of the presures inside The Zed return to the starting posistion.
@All
I meet with my engineers and I played "Semous tennis" with them from 4:30 -10:40
They gave me the current optimized model and its spreadsheets - and I threw my hands up and dramatically said:
"This is all bunk - how can you tell me with physics - that you have 800percent efficiency when physics says it cannot be done!!!! "You can not prove with physics that which can not be done in physics!!!"
Then I ignored the answer as they moved to the input and output and said "Impossible!!! Can't be done and I stomped my foot!!!"
And they turned and pointed at the Zed ten feet away and started to say just look......I said "trickery - you have hidden some secret compartment that with electro magnets .....helium.. something...some-thin pumps inside the plumbing....."
I continued "What about the FIRST LAW!!!!" they started to explain that we were not thermal - and that we have excess - black box - I interrupted ..... "WHERE DOES THE ENERGY COME FROM? ??? ??"
They started back at the Physics - and I shouted "ALREADY DISCOUNTED!"
They turned to explain the rational mind needed to realize we had achieved what is impossible.. I shouted "WHERE DOES THE ENERGY COME FROM!!!!!!!!"
"You Are playing Games, Stonewalling, avoiding the fact - DO YOU CREATE ENERGY? ??? ??"
One engineer said.... Yes... I Said Calmly - "no we don't......" he turned to the black box - Zed, the models, the physics, ...but these say we do...
I said "We don't - you have not yet fully explained where the energy comes from - the question we have to answer is NOT does it work - no one really cares about that - they really want you to explain how you appear to create energy from nothing."
He said - we put nothing in and get power out - that is energy creation - I said "What are you not counting - that is inside the box even if you don't put it in..."
Another engineer said "Gravity - the system does not work without it, increasing the gravity would make it work better,"I interrupted "But gravity is a conservative field.... "
He said, "Our system turns up the effect of gravity" - another engineer said "you can't turn gravity off and on" he responded - "we don't we increase the effect of gravity with the reuse of the same displacement thru each layer - and then we relax... it is a ten to three exchange."
I said - "then account for it - show it, We have to educate the people - they do not want to know it works - they won't believe it, they won't listen until you can explain where the energy comes from" - one engineer chimed in - isn't that what Mark and Jim's team are going to do?
I said "Yes - but you need to have a working plausible - verifiable theory before they get here....The machine is good, the physics are good, the energy is real - now is the time to educate the world on what is missing in our texts."
Then I drew the system separated - and I gave a value to each separate mass (displacement) and then I combined them - and said - the only thing that changed - is the mass was reduced by the number of layers - and we predict in the single layer based off that mass - you should be able to explain how recounting the same mass - at the same time - is pulling from the same field multiple times - our output increases directly proportional to the "presumed" mass repeatedly - even though it is only one mass for all layers.
I have excellent engineers:
Please remember - I never told them how it works or how to model, or how to optimize - that is their job - I gave them the working model and asked them to make it optimized and reliable - on that same note.......
They had all the same skepticism as the rest of you - and the same excitement and joy once they understood..
They are excellent at their Job.
A point on our current model - it is barely overunity - I call it the little model - not due to its size our its output - but from its optimization - it barely works - We overcome 9 real losses to operate.
I built it - the minimum size I knew how. It cost a lot of money - I was under the idea that seeing was believing - that does not work - for the "Educated" they must know how.
It is too important to stand on a box and insist that people believe... they have to see the relationship.
Yes it does work - it is Overunity - unless you account for the gravity - and then you understand that it is not energy creation - even though we get energy from the Black Box.
At some point the "minds" will understand that we have a 10-3 system - our layering turns up the effect of gravity and then we relax to normal gravity - that is where our differential .....which does work.... and supplies our energy - comes from.
TK, we are not trying to teach you that bicycles can fly - but we are trying to teach you to "see" energy - that you can not "see"............I understand how difficult that is...Your term "virtual" was very clever.
The virtual water - in your wet hands - is compounded in the same space over and over as we add layers - our four layer system has virtually four cups of water in nearly the same space as your one cup demonstration...
I am glad you looked... I hope you begin to see.. I would love for you to know - your own search and hope was not in vain.
This is not about Wayne Travis - but about the future and our generations - it is very important you do not throw the baby away with the bath water because the virtual is hard to "See".
Thank you.
Wayne Travis
Take some time to look at these:
The Patent has been available since May - and links have been posted here.
I hope this helps with the confusion.
And
Also
Internal of Zed left blank for focus on l hydraulic loop.
p.s. this was the original location of the Lever arm - we turned it horizontal because of air trapping in the cyclinder.
But the function is the same.
Once again
I posted these to help clear up the redundancy that the thread has to the input and output question.
We have nothing external coming in - as I have said before Normal calculations of input versus out put have to be re thought -
Internal input and external output can be measured.
Maybe this will help.
thanks Wayne
MrWayne said,
Quote from: TinselKoala on August 14, 2012, 04:04:22 AM
You are just simply not going to answer my questions here, are you.
I will ask you just one more time.
HOW DO YOU KNOW THAT YOUR THREE LAYER SYSTEM IS OVERUNITY?
What is the ratio of input ENERGY to output ENERGY , or equivalently WORK, in your
three layer system that is clearly overunity BY ITSELF, and how did you determine this? If you cannot, or will not explain this simple claim of yours in unambiguous, simple terms.... then there is really no point in my continuing, because you are NOT being sincere, however much you pretend to be.
There, put me in with the stink slingers... and I'll put you in the "oddstuff, OUidiot" file.
Now, perhaps people are beginning to understand why I'm not just leaping up to drive up to Oklahoma. It is far too hot for snowjobs.
Quote from: TinselKoala on August 14, 2012, 01:36:59 PM
MrWayne said,
What is the ratio of input ENERGY to output ENERGY , or equivalently WORK, in your three layer system that is clearly overunity BY ITSELF, and how did you determine this? If you cannot, or will not explain this simple claim of yours in unambiguous, simple terms.... then there is really no point in my continuing, because you are NOT being sincere, however much you pretend to be.
OK - your decision has been made.
As I said before - I have been wrong before - and against my wishes, I am again.
Good day.
Wayne
Quote from: microcontroller on August 14, 2012, 01:58:52 PM
TK you don't understand?
First he triples the force of gravity and the thing sinks until it hit's rock bottom, and then he turns the force of gravity back to normal and the thing rises again.
There is no energy needed to do this and you are always left with a +one force of gravity which is why the triple layer configuration is overunity by itself !
That part's clear enough.
The part I don't understand is what he does with all the extra hydraulic fluid he's generating. You inject 15 units to one Zed and get 30 back. He's said that many times, and that is supposed to be a full cycle for that Zed, right?
QuoteThanks, I have covered the input and output - very short on our current Data model -
So you take 15 volume units of that hydraulic fluid and inject it to the other Zed and it returns 30 back. Now you have 30 cu in extra hydraulic fluid in your accumulator. Pretty soon you are going to have to start selling that off, or the barrels are going to be all over the back yard.
Or perhaps the ratio of 30/15 is for the two Zeds together. But if each full cycle takes 15 out of the accumulator and puts 30 back in... you still have the same problem: too much hydraulic fluid.
Quote from: mrwayne on August 14, 2012, 10:16:27 AM
thanks Wayne
Sorry, Mr. Wayne, it does not help. You say that "internal input and external output can be measured", so please tell us
how long the machine can run (by itself without human intervention)
and how much external output there is? (I understand that there is no input, so only the output has to be measured.)
Greetings, Conrad
Simple explanation of energy advantage.
Shown is 3 systems, each create a 7 Foot Water Head. Each system uses a 100# weight as force, but each applies that weight over different distances.
Half filled U shaped column reduces the distance to apply force. Each additional U shaped columns further reduces the distance to apply the same force.
It doesn't account for air compression, but a water, mercury wouldn't have compression and mercury weight advantage over water is 13.534 to 1.0. Thinking Travismobile.
Also, if the piston was removed after stroke, the 3 U version would re-balance first, the 2 U second and the 1 U last.
Regards, Larry
What are these items? Do they appear on any of the patent drawings or the other illustrations we have been given?
In order to clarify my question about the output of the Wayne-Machine I indicated on the drawing (supplied by Mr. Wayne) which output I would like to know.
As a bonus, Mr. Wayne could also tell us how long the machine can run without human intervention.
In simpler terms: is it running by itself? And when it is running by itself, how much energy is put out by the "Gen"?
Greetings, Conrad
Quote from: conradelektro on August 14, 2012, 02:16:57 PM
Greetings, Conrad
Hello Again Conrad - I still appreciate the wisdom you added last year - rough - but wise.
Short answer - it ran until we broke it back in November - we bled off the excess.
Short answer - the system was designed for 500watts - total - it took 300watts to keep running - we only have 36 watts after conversion to electricity.
More:
We bleed the excess off through a hydraulic motor - which we use to turn a generator - which we then use to burn a light bulb.
This system was never built to be a continuous runner - but we try to satisfy that curiosity. I made the mistake of believing the engineers would believe the enginners........
Mark was here when we were running (November)
Before we added all of the data collection and systems to it - we ran well - just bleeding the excess off - until we broke several parts due to the layman building and the pressures we were dealing with.
After Mark left - we moved it inside and worked to convert the self runner into a Data collection model.
Its sole purpose has been to compare the actual to the model - for our benefit. I regret this when someone want to come measure the input and output - it is harder now.
And - The change has been problematic - two reasons.
We added a hydraulic motor and generator instead of wasting the production - this added new losses - big losses (for a simple system).
And we learned that the accumulator nearly refused - to receive production and supply it at the same time - since the input and output were simultaneous - the production would divert to the lever arm and not to the accumulator - or the generator would speed up instead of pushing into the accumulator.
This has been the big delay - we think we have solved it - Good side - it has given our team more time - they have used it wisely.
Right now we are ramping back up to run - if possible - I am not convinced I can make the original system handle all of the additions that have been added to it.
It will serve to verify the Engineers data - it is perfect for that.
Lastly - If I had known the loop I have been thru - lessons learned so far - I would have had the system optimized first - from our original input output test model.
The delays would have been over long ago.
Wayne
@LarryC:
In the left-hand drawing in your image..... is the tube on the right open at the top? If it's not.... how is it possible to achieve the final state with all the water in the right tube and the weight fully down? Especially if you are using mercury and water, instead of water and air?
If it is open at the top... then what about the other two systems? Are they open at the top, of the last tube, as well?
You say each system makes a "7 foot water head". That, to me, means that the final pressure, measured at the bottom of the weight where it contacts the water it's pressing on, is the same in all three cases. Am I interpreting this correctly?
Quote from: TinselKoala on August 14, 2012, 02:39:04 PM
Simple - the Initialization system.
Not in the patent - for the Validation team only.
I will recap since this has been covered and gets tossed up again:
When we moved the system inside - from Mark's visit we spent $26,000 adding a set up system so that RIchard could program the initializations system.
We have - Separate from the Zed - except the program which controls the separate operation -
Water pump attached to every layer in the system
An Air compressor attached to every layer
and a Hydraulic pump attached to the accumulator - you will see that in the hydraulic drawing.
You see, when Mark was here I had to disassemble, drain and vent every component.
Then I used a standby generator, waterhose, and Log splitter pump to set the system up to the precharge condition - covered well in the patent.
Mark was a patient man, it took all day and into the night to perform this task.
p.s. So I had the team design an automation system so that the validation team could use it to measure the set up energy.
So now - we push a button and the system drains itself - vents itself - measures and displays every aspect within the system and then steps you thru a set up procedure to refill everything to the beginning run state.
Glad you asked - I meant to restate this again when a liar claimed that we pumped air and water and hydraulics in the system to fool everyone.
TK- you said you put me in the idiot file -
I respected you to answer ...
It was a lot of work and changes to install air and water pressure lines to every layer, chamber - there is a pressure transducer on every line - we do use those during run to monitor the process.
I think the Engineers have the Initialization mapped - here is mine.
Quote from: TinselKoala on August 14, 2012, 03:10:20 PM
@LarryC:
The last tube on the right of each system is open, and you're right a water mercury would require a different design.
You say each system makes a "7 foot water head". That, to me, means that the final pressure, measured at the bottom of the weight where it contacts the water it's pressing on, is the same in all three cases. Am I interpreting this correctly?Yes.
Regards, Larry
All right, since you did me the courtesy of answering about the air compressor and the pump --- I'll ask you politely and directly one more time.
How is the ratio of input work or energy, to the output work or energy, determined for the three layer system that is clearly overunity itself?
Please tell me what the total input energy is to initiate and sustain a cycle, and what the total output energy is for a complete cycle.
What _numbers_ do you compare, to determine the clearly overunity performance of this system itself?
If you again say you put in 15 units of fluid and get 30 units back... I say again that it sounds like you are creating fluid from nothing, or that the cycle is not complete at this point, or that pretty soon the system will be empty and all the fluid will be somewhere else.
Quote from: LarryC on August 14, 2012, 03:41:45 PM
Yes.
Regards, Larry
OK, thanks. Now I have something I can test.
ETA: Before I do, though, let me ask another question.
If I put an outlet valve at the crossconnection between the first (piston) tube and the second tube, and pipe that into another, identical tube.... then open this valve when the piston is in the final fully depressed state, the water will run from the full tube through this valve into the new, empty tube. Right?
How high will the water rise in this new tube?
In the diagram on the left it would rise up until the two columns of water were at equal heights, I think.... but I can't quite picture what would happen in the third, righthand case.
Thank you Mr. Travis for answering my question about the "Gen".
I think I understand now what is going on and I describe it in very loose terms:
1) When the " three riser system" is measured with pressure sensors at various points one observes higher pressures than in a conventional "Archimedes type system".
2) One also observes that the "three risers" rise higher than a simple riser in a conventional "Archimedes type system".
3) And finally more fluid is displaced in the "three riser system" than in a conventional "Archimedes type system".
From these three observation Mr. Travis concludes that there is OU.
And now comes the not so nice part:
If one wants to take advantage of these observations (of the alleged OU Travis effect) and one tries to build a machine, problems start to appear. The biggest problem is to get a useful net output. And this is to be expected, because the so called OU Travis effect is a misinterpretation of situations (pressure, height of movement, amount of fluid displacement) which appear at certain stages of the operation of the machine. But this alleged OU situations are cancelled out at other stages during the operation of the machine.
In simple words: at some stages of the operation one can measure "high values", but at other stages there will be "negative values"; resulting over all in the conventional values as observed in simple "Archimedes type systems".
Because the system is mind boggling and difficult to describe with rigorous mathematics an endless discussing ensues, specially when laymen are involved.
Therefore I always want to see a self running system which puts out considerable net energy for a longer time:
This would put aside all "theoretical discussions" and would force "scientists" (the establishment) to have a closer look. But exactly this "self runner with a considerable net output" eludes Mr. Travis since years.
Whenever a Travis-system is built the alleged "OU demonstrating measurements" can be done, but the machine does not self run and does not put out a considerable amount of net energy.
Because a Travis-system is rather complicated (and needs a many electric valves, sensors and electronics for self running), one suspects that the problems are caused by not enough sophisticated engineering. But in fact, the concept is the problem.
The misunderstanding:
Mr. Travis talks about measurements which for him demonstrate OU.
Observers (like me and other sceptics) want to see a self running machine which puts out a considerable net energy over a longer time (because that would put aside all speculation and all interpretations whether true or false).
Mr. Travis wants people to believe in his OU measurements (the Travis effect).
People want to see free energy pouring out of a working machine.
Greetings, Conrad
Quote from: TinselKoala on August 14, 2012, 03:55:43 PM
Right about equal heights, and would be the same on the other two if you crossconnected between the fist and second on each. You would be removing the pressure created by the piston, so everything will slide back around.
Regards, Larry
Quote from: conradelektro on August 14, 2012, 04:08:58 PM
Dear Conrad??
I can not believe you got all three of these wrong?
First - our system has the same Pressures as the Archimedes' in each layer respectfully to the additive head and to lift.
Several people have shown that here - is this just a misquote?
Second - Our system uses a short and fast stroke - over a long one. 11.1 times faster than a Archimedes' same lift and distance.
Larry has been banging the drum on this for a week.
Third- we use a microscopic amount of input volume to Archimedes' ?This is the key point of the Travis Effect......
You have been getting some bad info, or I have done a terrible job.
Sorry Conrad - you need a clean sheet.
All 100 of us are not just wishing it were so...
Good day.
Quote from: LarryC on August 14, 2012, 04:30:19 PM
Regards, Larry
So in the one on the left, the water columns would equalize in the new tube and the receiver tube of the 2-tube system. So the water columns would both be at the height equal to the piston travel, just like at the beginning but in different tubes. Right? (corrected the "half", sorry)
And in the one on the right, the water columns would also equalize between the new tube and the second tube of the 4 tube system?
At the same height of the piston travel? Or would it rise to the same height as in the 2-tube system on the left?
No quick response to that last question of mine?
Quote from: TinselKoala on August 14, 2012, 04:51:40 PM
So in the one on the left, the water columns would equalize in the new tube and the receiver tube of the 2-tube system. So the water columns would both be at the height equal to the piston travel, just like at the beginning but in different tubes. Right? (corrected the "half", sorry) Right.
And in the one on the right, the water columns would also equalize between the new tube and the second tube of the 4 tube system? Yes.
At the same height of the piston travel? Yes.
Or would it rise to the same height as in the 2-tube system on the left? No.
Regards, Larry
PS: Thanks for taking an interest.
Thank you for explaining, Larry. Sorry about that crossed post above.
So... work, or energy, is force x distance. In LarryC's example, in the first case on the left, we are applying a certain force (the pressure of the 100 lb weight) and we are using that force to move a column of water the length of the piston stroke. Right?
And in the third case on the right, we are applying that same force, and we are using it to move the (essentially) same column of water..... the length of the piston stroke.
We have attained the same pressures in each case... and the work input / work output _in each case_ balances.
But the work input in the case on the left is greater than the work input in the case on the right.
The system on the right neither takes in... NOR RETURNS... the same amount of work as the system on the left in LarryC's illustration, even though both systems are operating at the same "head" pressure. And it will feel different "by hand" because the system on the right only needs a small displacement to get to the full pressure, while the one on the left needs a "softer, longer" push to get to the full pressure.
Congratulations, you have just invented the lever.
I congratulate everyone on a spirited debate, but unfortunately I think the fog remains as thick as ever.
However, I take issue with Wayne's posting #1364.
This one:
QuoteWhat???
With A NET of 12-15
@All
I continued "What about the FIRST LAW!!!!" they started to explain that we were not thermal - and that we have excess - black box - I interrupted ..... "WHERE DOES THE ENERGY COME FROM? (http://www.overunity.com/Smileys/default/huh.gif (http://www.overunity.com/Smileys/default/huh.gif)) ??"
"You Are playing Games, Stonewalling, avoiding the fact - DO YOU CREATE ENERGY? (http://www.overunity.com/Smileys/default/huh.gif (http://www.overunity.com/Smileys/default/huh.gif)) ??"
Thank you.
Wayne Travis
I was going to abbreviate the quote but decided to leave the whole thing in to emphasize the point. What is is? Some imaginary dialog with engineers plucked from an Ironman script? These fantasy scenes with "stumped engineers on a mission to save the world driven by their leader" do not advance the discussion by a singe iota.
I have been involved in engineering in one way or the the other for 25 years and what Wayne is describing in his fantasy scene is as far removed from the reality of working with engineers as it can get. That posting is just pablum mixed with Soma to make the hard core believers comfortably numb again. It's an attempt at social engineering.
We have to stick with reality.
While we digest the 'laws of levers' TK has so aptly drawn attention to, which incidentally are used in hydraulic presses !
BTW, the air gaps in the systems Larry showed could be replaced with plain water - we are only interested in the net mass of water lifted a certain height - how much Work that took to raise its PE - a larger mass depressing the piston will do the Work quicker in all cases - IOW's the power Input is greater but the Work Done joules of energy doesn't change.
As a matter of interest, here is a 'Hyperphysics' page I found when MH was discussing a few pages back the projected output of the machine & comparing it to hot water cylinders.
In this case it shows the energy requirement [Work Done] to lift a mass of water giving it head & Energy of Position v's the energy requirement to raise the temperature of a mass of water.
http://hyperphysics.phy-astr.gsu.edu/hbase/egex2.html (http://hyperphysics.phy-astr.gsu.edu/hbase/egex2.html)
The next two are Pascals Principle [scroll down to use the calculator & see how a hydraulic press works] & Hydrostatic Pressure [also scroll down to use the calculator].
http://hyperphysics.phy-astr.gsu.edu/hbase/pasc.html (http://hyperphysics.phy-astr.gsu.edu/hbase/pasc.html)
http://hyperphysics.phy-astr.gsu.edu/hbase/pflu.html (http://hyperphysics.phy-astr.gsu.edu/hbase/pflu.html)
Sorry MH,
You waste so much of my time.............. you don't know what you are talking about - again.
Wayne
Quote from: TinselKoala on August 14, 2012, 05:12:14 PM
Congratulations, you have just invented the lever. Are you trying to mislead or just don't understand levers?
A level that would move 3.5' with a 100# effort force to create a 7 Foot head would have a longer distance from effort force to fulcrum than a second level that would only move 1.16' and would require a much larger weight to create the same 7 Foot head.
Also, you ignore the fact that after lift you would need to raise a 100# weight 3.5' with the 1 U and 1.16' with the 3 U. Why?
Regards, Larry
I have put users MileHigh, Seamus and Microcontroller on Moderation as they have trolling this
thread too much !
Regards, Stefan.
Quote from: Larry C .. Post #1776 Pg 92
Regards, Larry
Larry .. Perhaps I don't understand 'head' like you do ?!
Do you mind explaining to me why you say all 3 examples in your drawing have the same 7 foot head ? - & pressure ?
http://en.wikipedia.org/wiki/Hydraulic_head
Quote from: fletcher on August 14, 2012, 07:01:07 PM
http://en.wikipedia.org/wiki/Hydraulic_head (http://en.wikipedia.org/wiki/Hydraulic_head)
Hi Fletcher,
I just picked 7 Foot off the top of my head. Could have been better and I may change and re-post.
Anyway 7' = 84", 84" X .036127 (Cu In weight of water) = 3.034668 PSI.
The SI of the water columns is such that the weight of the 7' water column would be a little less than 100#. Not important to me, so I'll let you figure that one out. Height * PI() * Radius * Radius * .036127.
The reason they all have the same head is because in 2 U and 3 U, the last water column is pressing up on the next air column and the next air column is pressing down on the next water column, etc. etc. They appear to the piston as a single column of water pushing up.
Regards, Larry
PS: This is not the Travis system, but it is a piece of the system broken out in an attempt to help increase the understanding.
@Harti, Thanks.
Yes, Stefan, I must protest as well.
Sorry... but I don't see any trolls. I see some people with genuine legitimate doubts and questions that aren't being sufficiently answered.
Simple questions like.... What was the reason that Mark Dansie wasn't completely satisfied on his first visit? And my questions are the same as some of theirs too: what is the ratio of work out, to work in, and how is it known that the three layer system is clearly overunity itself?
Meanwhile.... I am once again operating completely without funding, scrounging stuff that I happen to have lying about.
In the LarryC case it's pretty clear that each individual system can only return the work that's put into it. The only question is whether or not the work in the third system on the right is the same as the work in the first system on the left.
Since the input force--- the weight of the 100 pound weight pressing on the piston... is the same in both cases (RIGHT?) but the travel is less in the one on the right, we know at least that the INPUT WORK isn't the same.
RIGHT? The force is the same and is constant in both cases: 100 pounds downward. (More correctly measured in Newtons but we'll let that slide for the moment.)
And the distance travelled is different. Therefore the product Force x Distance = Work is different, with the first system on the left making the greater product, since the distance through which the force has acted is greater. RIGHT?
SO the only question is whether the output work is different or the same. Since the system on the RIGHT cannot push up a water column to the same height, when released, as the system on the LEFT.... it should be clear that the work output available from the system on the right is less.
We don't even need any assumptions about pressures. All we need is to note that the input FORCE is constant and equal in both cases, the input DISPLACEMENT is less for the one on the right, therefore the input WORK is less for the system on the right.
Since the OUTPUT-- the return height, or the height of an additional column as in my thought experiment, is clearly LESS for the system on the right.... well... DO THE MATH (tm RA).
Now, the issue of the pressures. Is it a confirmed fact that the "heads" are the same in both cases? I don't know the answer to this myself... but I am preparing to measure it.
https://www.youtube.com/watch?v=c8WYI7QCj0k
Now... Koalas really don't like to get their paws wet. We get all the moisture we need from the leaves we chew, or otherwise ingest, and the beers that we drink. Getting wet makes us cross and jumpy. Especially when there is no reward in the offing. However, even without funding enough to buy lunch, and working with garbage materials, we are still proud of our workmanship.
May I please have some suggestions as to how to measure the "head pressure" in this system? I could put a basic improvised manometer on the bottom of the first receiving cylinder... but this whole system is a manometer anyway, so I'm not sure of the probative value of that, although I myself would accept its indications. Bear in mind that I am not about to go out and buy a sensitive pressure gauge. I do have on hand a very precise and accurate electronic force gauge for mechanical linear force, a Mark 10 Series 5, model M5-05, that cost "somebody I know" about a thousand dollars.... but I dare not get it wet !!
LOL! Oh how I love this part of any good thread!
Thanks a million (peso?), TK!
M.
LarryC says:
QuoteThe reason they all have the same head is because in 2 U and 3 U, the last water column is pressing up on the next air column and the next air column is pressing down on the next water column, etc. etc. They appear to the piston as a single column of water pushing up.
Yes, I agree with that, at least until I can actually measure the pressures, but logically you are correct.
And how far did the piston push that single column of water up? The same distance the piston travelled down, right? Which, in the system on the right, is only 1/3 the distance of the system on the left. Right?
Work in = work out, minus losses, for each separate system.
Work for system on LEFT >> work for system on RIGHT.
RIGHT? Or not?
Quote from: TinselKoala on August 14, 2012, 09:17:34 PM
Sorry, but I can't help myself here...
Larry is only describing the work IN with this demonstration. And yes you are correct that Work for system on LEFT >> work for system on RIGHT.
M.
PS. Sorry again if I stepped in your way Larry. This is really a great discussion between you and TK and I'll try to butt out.
Quote from: hartiberlin on August 14, 2012, 06:47:38 PM
thread too much !
Regards, Stefan.
The only way I would agree to do so is if the members hammer against an idea that they themselves have not built themselves, like TK and the Tar Baibies, or Poynts diligence one the sims and come to accurate conclusions. But if they are just going to preach text book theories and laws against something as complicated as Waynes device, without having full knowledge of the device, nor ANY experience with it, then they should keep to themselves until they do have this knowledge and experience, in order to even make a case against the idea.
Otherwise it is just hounding, bickering, useless posts. Trolls.
TK, I have a feeling will delve deep into this. I see he is still on the 'HUH?' side, but as others here have spoken as to whom they want to see more posts from and who not, this should be a good indicator. And the Not's are agreeably not helping to figure things out, this is for certain. The Not's only post time/page wasting material. And animosity along with it. You can see it in the last few pages up to this one.
Wayne doesnt have to show anything. But he is and he has a nice, high, level of patience in doing so. Everyone deserves a fair chance to do their thing. But if their thing is to disrupt a thread with bias, and little knowledge of the device specifically in order to prove their case 'against' it, then most will agree that these posts are the least wanted.
With TK here, doing some serious questioning, while seriously trying to understand what is happening, there is no need for extra grumble and mumble about things that are well known or just insulting comments. They have know idea how this thing works exactly, and their posts show it. ;]
My local Plastics store (Plexi, etc) has lots of sizes of thin wall clear tubing(1/8 in). ;]
MaGs
Quote from: mondrasek on August 14, 2012, 09:22:53 PM
M.
Well, OK, then.... I guess we all agree that the Work, or equivalently the Energy... of the three systems LarryC presented are not the same and there isn't any magic happening. The fact that the "head pressures" are logically the same in all three cases is the Red Herring of the week. Pressure is not energy, it is not work, it is NOT a conserved quantity.
So I am afraid I don't get the point. Reduced work IN for the same pressure -- and reduced work OUT -- , with no other considerations deemed important?
https://www.youtube.com/watch?v=pTSMyKdKDR0
Quote from: Magluvin on August 14, 2012, 10:35:31 PM
MaGs
"Wayne doesn't have to show anything."
On the contrary, Mr. Wayne has to show everything if he is claiming over-unity and wants people here to accept his account and view of his device. He is the sole source of information, and therefore he must provide actual data and proof of his claim if he wants anyone to accept it. (He apparently desires this or he wouldn't be here on this site). It is reasonable to expect a clear and concise explanation with examples of drawings that explain the operation and input and output measurements of the device. It is reasonable for the people on this site to expect nothing less. Especially since the device in question already has patent protection, there should be nothing to hide. Those asking reasonable scientific questions have every right to do so, without being considered a "troll" and should not be silenced or moderated. If moderation wins, the truth may be lost.
Liberty
Quote from: TinselKoala on August 14, 2012, 09:03:18 PM
Misleading again, I have shown many time in different calculators and drawings. The Travis system Risers intersect and uses the pressures from each air column against each riser surface areas to produce lift. Please do your due dillegence and stop misleading.
Regards, Larry
Hello all,
This is the link to my public ZED distribution folder:
https://www.dropbox.com/sh/6vdnbk72ywyckns/zB501rT78P
A PDF document has just been uploaded. It is too late tonight to generate a set of animation files. That will have to wait until sometime tomorrow. Text that appears in red are numbers and formula terms that are changed from my previous version. They will only be red for a single significant version.
The purpose of this analysis is to present (for critical review), the theory and implementation I used for a simplified simulation of a single ZED machine. This is just a single layer version. A 2+ layer simulation model will follow after this one is verified for accuracy. No attempt was made to find the most efficient geometry for this. It is known that other geometries had better simulation results, but it would be wasted effort to try to optimize this model before verifying that it is accurate.
~Dennis
Quote from: LarryC on August 14, 2012, 11:42:06 PM
Regards, Larry
Are you claiming that I am wrong, that the work is not less in the system on the right? And when I say that there is no energy gain evident in any of the systems you have drawn? Are you disputing that? And when I point out that the work involved in the righthand system is far less than the work in the lefthand system... is that misleading or wrong?
I don't think it is I who am misleading, Larry. You set up your system and your illustration to make it look as if there was some kind of advantage to the system on the right. But there isn't. A naive person might look at the pressures, forgetting that you are only showing a half-cycle, and also might assume that you are saying you get the same benefit from the system on the right as you do from the system on the left, but with less cost. I think your entire drawing is misleading... that's why I had _you_ explain it first.
QuoteThe Travis system Risers intersect and uses the pressures from each air column against each riser surface areas to produce lift.
So? What exactly does that prove? You take two identical systems, neither of which is "overunity" itself, and "intersect" them and somehow... nobody has yet explained "what is measured to judge it"... overunity performance emerges? You are waving your hands, not explaining.
How is the ratio of input work or energy, to the output work or energy, determined for the three layer system that MrWayne tells us is clearly overunity itself?
Quote from: Liberty on August 14, 2012, 11:28:57 PM
Liberty
Show me the rule or the law that states MrWayne has to show anything at all, even though he has claimed OU? He is not claiming a prize here. he is just talkin, and goin with the flow. Who gives you the right to say how fast or slow that flow goes? Hmm?
Show me 10% of the 'moderated' members posts that shows that they have a good understanding of Waynes device that gives them the right to bash.
They dont. And until they do, they should pay attn, and if they want to know, they will do as Webby and Larry(and they agree so far) has and do some work, instead of insulting what the Not's know nothing about.
If you think its fare to let that crap go on, then open your own site, noholdsbarredposting.com
When they understand, what TK is trying to figure out, then yes, argue away. But before then is just trolling. Go ahead, ask one of those guys if they know exactly what is happening in Waynes device. If you get any 'real' answers, they would be interesting to hear, and compare. lol
Some people are of the understanding that there is nothing left to figure out in this world and that we are all just wasting our time here(just like you) and THEY NEED TO LET US KNOW HOW THEY FEEL ABOUT IT, EVERY SINGLE DAY. >:( Yea, that sounds reasonable. Gimme a break.
MaGs
And after TK's last post, I know these Not's know nothing.
Not insulting you T. Just showing an example of the difficulty of getting the drift of this machine. ;] Its not a 1 day ordeal. ;]
MaGs
Quote from: Magluvin on August 15, 2012, 12:29:24 AM
MaGs
All right then mags... perhaps you understand LarryC's system, and thus MrWayne's, better than I do. (I'll be the first to confess that I don't understand MrWayne's explanations, that is for sure.)
YOU explain to me how is the ratio of input work or energy, to the output work or energy, determined for the three layer system that is clearly overunity itself?
clearly overunity performance of that three-layer system itself?
Is it the 15 volume units in, and the 30 volume units out? And that is supposed to be one complete cycle back to a starting point so you can do it again.. and again... and again.... gaining 15 volume units each time, and putting it.......
Sigh.
So Mags, it appears that according to you, anyone can claim to have an overunity device, without providing evidence of the claim. I suppose that's true.
And of course, I have a pink invisible unicorn in my back yard, and he's hungry, so I had better go feed him.
What? You don't believe I have this unicorn? Why... because you can't see it? It's INVISIBLE, silly.
Quote from: seamus103 on August 14, 2012, 11:59:39 PM
I can understand why might think this is so, but one should not have quite so much disdain for the "textbooks"
If it were not for these very same "theories and laws" we would not have all the exceptionally powerful and accurate computer simulation code that allows us to analyse and design machines every bit as complex as a ZED is. Simulations that can provide a high degree of confidence that the actual performance will be very close to the predicted. This is proved in a multitude of fields of engineering.
'Theories' are just that, but it so happens these ones have been validated experimentally ad-infinitum and proved mathematically.
We don't need to get our "hands wet" if someone claims an effect that would break these laws unless they can provide conclusive experimental data that shows it does. No such data has been forthcoming yet so we can be justifiably cautious in believing them.
In addition the mathematical models provided so far are demonstrably incomplete. They do not provide the simple measurements that are required to demonstrate that the energy in vs energy out results in a net gain.
Until that occurs I won'd be wasting time on experiments. I'd rather rely on theory.
I know exactly what you are saying Sea. Exactly. And if you are well read, then you should know that there are things that we dont know about yet.
Think about it. You are here, for what? If an OU device can be made, then the books have to be rewritten or added to. 'Or even taken away', like Tesla, substituted with Marconi, Bell, Edison,etc.
Until experimenters figure things out that havnt been figured out yet, by 'experimenting', exploring, taking advantage of individual levels of 'creativity', then we are just stuck with what we got. Same old, same old. New things are figured out every day.
There just might be a few tricks out there that work if applied. Some ideas are already known by some Im sure. And the tricks that might work, may be complicated, such as Waynes device. So who is to say that anyone around here is going that extra distance into the unknown in order to achieve OU?
A reasonable person would not apply the pressures to claimants of OU devices. Saying that, what kind of persons would? Greedy? Suppression? Impatient? Atheist? What I say to them is piss off. What is your goal here other than to get the daily thrill of delivering some abuse. And for what? We are not on their lawn, or in their house. Make sense?
Trols are generally not nice people. They will try to degrade your intelligence, or make fun of people that are bad at spelling, and a lot of the time its the same 'worthless' balony every day taking up page after page of nothing to offer except the smell of a used baby wipe. ;]
So whats wrong with sayin "Be Nice or there is the door. Your choice" ?
MaGs
Quote from: TinselKoala on August 15, 2012, 12:48:51 AM
THERES NO UNICORNS YOU IDIOT. PROVE IT MR, NOW!!!!. ;)
Or, I could say, "sweet, got any pictures?"
I guess some people just dont get it.
Unicorn. How many watts in and out of the unicorn.? I dont care. lol ;]
MaGs
Quote from: TinselKoala on August 15, 2012, 12:42:10 AM
What _numbers_ do you compare, to determine the clearly overunity performance of that three-layer system itself?
Sigh.
"YOU explain to me how is the ratio of input work or energy, to the output work or energy, determined for the three layer system that is clearly overunity itself? "
Hey, Im just showing an example that if 'you', TK, have not got a grip on this in 24 hours, then these guys would need to spend as much time more or less as Webby or Larry to come to similar conclusions, and congratulations from Wayne to level 1. whats wrong with that?
And whats all this demand this and demand that? Why should I give the gold to just anybody that thinks that kind of talk will get them results? What is that? Am I Egor? ;]
I suppose if I say I know how it basically works, I am under some requirement to divulge? Now I should be trolled to death for stating such. lol
I think you and Larry have a tiny bit of tension. Maybe if things were nicer, you guys might be on the same level by now. Maybe, I dont really know.
I do know that larry is tired of Micro, and MH. So maybe some of that stuck, and you giving him the 4th degree is feeling much the same. So maybe the answers you get are all that anyone thinks you deserve, so far. Ya cant earn it with GIMME NOW!! this aint Goodfellas. ;]
I would like to see you figure it out. I think you know that you will have to build it to see if things are different than what you imagine. ;] Just like the SN device. Did you know it was going to be called a Super Nova and why, before you built it? ;] How could you? ;]
MaGs
I'll put my spoke in as well - I also protest at Stefan's actions against the three - if I want cheerleading disciples I go to a football match where I can appreciate them - a discussion is about challenge & response [kept civil] - Wayne has made the claims, others are attempting to clarify the theory & protocol in its simplest form - enough said from me about that.
Off the top of my head TK I would say you have two quick methods - you can probably think of others - the first the peizo as Mond said - I would suggest that a simple visual aid like a manometer tube for each section would give results to test the theory of all systems having the same or increasing head.
The idea is this - for each cylinder bore a hole near the bottom - insert a clear plastic tube & run it vertically to 7 feet - over the end of the tube that is inserted in the flow sections cover it with a water proof elastic membrane [like a balloon].
Set the system at rest then depress the plunger piston - if there is a substantial pressure increase in each progressive cylinder it will balloon out the membrane into the tubing interior [i.e. the membrane is a pressure transmitter but not a volume conduit].
When the piston is depressed fully [& the membranes are visually showing deformation, either the same, similar or vastly different for each section] then using a syringe add water to the manometer tubes until the membrane deformation reverses & goes back to normal - if this takes 7 foot of water at any time then the horizontal series system is analogous to a vertical column in pressure terms.
P.S. mark the water levels before allowing the membranes to move.
Larry C's comments were relating to showing "a simple explanation of energy advantage"
Air is compressible - the far right tube is open to the air - the air gaps will be compressed slightly by weight of water - the compression acts like a spring - the mid sections may show a slight increase in localized pressure for height - however the overall column length of water & air will be foreshortened by that slight compression - so the last column in the right cylinder will not rise the full height of restoration.
P.S. If the mediums were changed to virtually non compressibles such as mercury & water as Larry has suggested then how does this theory of same head pressure [i.e. height] pan out for mixed densities other than a gas ?
ATEOTD I believe you are dead on - this is leverage principles where the effort in equals the load out - IOW's Input equals Output for each system but more sections models require lesser input for lesser output.
I still don't see the "energy advantage" that these models were supposed to show ?
If your experiments show anything vastly different than what I suspect then I will be most surprised & interested - good for you for giving them a go.
Quote from: Magluvin on August 15, 2012, 01:40:25 AM
(snip)
MaGs
No, I didn't, and in fact I was astounded that it worked at all, really, or that my little "tweaks" would be so effective. But there are no principles broken, nothing that will get me a team of engineers and a bale of cash to help me develop the Inductive Wireless Power System that will Eliminate the Need for Heavy Batteries and Expensive and Dangerous Supercapacitors in Electric Cars...or that would even Supply Power for On-Board Electrolysis, plenty of it, to run your ancient ICE-car on H2 gas from the water-filled fuel tank. No.... nobody is interested in stuff like that... even though I can demonstrate and prove every single claim I've made for it, anywhere anytime on demand.... because it isn't "overunity." Or at least I'm not saying it is.
Quote from: seamus103 on August 15, 2012, 02:10:27 AM
It would be evident to many that you are becoming dangerously close to your own definition of a troll.
Just stick to debating the facts. There have been many valid questions asked that are still not answered in a satisfactory way.
Na, Im anti troll. ;] As for unanswered questions, the smart ones are finding those answers for themselves.
And the ones that are not trying to find out for themselves, from what is given so far, what can i say?
Seamus, where are your charts? Where are your risers that dont work according to plan? ;] Otherwise, what is to debate? You have no evidence thus far. Tell us what is being done wrong in Larry's charts. Rewrite them to show your side of the story. Make some risers and get out the bucket. ;] Unless you have seen or built one yourself, how can you say you fully understand what is going on as a whole? You cant. You make assumptions based on rules. Your not seeing the whole picture, yet. ;]
Be cool, thats all. Have a bit of patience. As you can see, pressure isnt working to get answers. Thats for sure.
MaGs
Quote from: TinselKoala on August 15, 2012, 02:41:37 AM
Your missing my point. What I meant was, you were not expecting Super Nova mode. I looked at several vids on Yt of those loop devices and none of them had shown the Super Nova mode that yours did, ou or not.
Im making a similarity that you believe your only going to get what you expect from the build. So maybe if you build it, you might find more than you expect. ;]
Heck, I wanna see what you come up with. I think that your the greatest. ;]
Ill end this here.
MaGs
@fletcher
I like the idea of the membranes, a strong visual indication is worth a dozen numbers in boxes, IMHO. But... ultimately, the numbers in the boxes are how we engineer our reality, the stuff around us we take for granted every day.
You said,
"Larry C's comments were relating to showing "a simple explanation of energy advantage""
Yes, that is what I thought too, but we found out that there is no energy advantage, just a leverage to increase pressure... not energy or work. So I still don't get it. If there is no increase or advantage in _work_ or _energy_.... and the pressure advantage is happening at the middle, not the end of the cycle.... so what? What is the relevance of that, to a big, groaning machine that is supposed to run itself (until something leaks or breaks or needs to be modified) and make 36 extra watts (measured how?) beyond what it needs for self running?
I'm not missing your point at all, Mags, I'm just making one of my own, on top of it.
Of course, serendipity favors the prepared mind. The only thing anybody will discover sitting in their figurative armchairs is how to get more comfortable. I learn something every day... whether I like it or not! However, there are far too many wild geese to chase, for me to spend time fishing after Red Herrings.
Peach, my friend. Er.... I mean peace.
thread too much !
Regards, Stefan.
Often I just would like to filter out posts of certain people from a thread to get faster to the point. Is it possible Stefan? It would be nice to have such setting then I can choose who is displayed and get a more concentrated page.
regards,
Marcel
Quote from: MT on August 15, 2012, 03:42:09 AM
regards,
Marcel
Profile>Summary>Modify Profile>Buddies/Ignore List
Quote from: TinselKoala on August 15, 2012, 03:03:17 AM
@fletcher : I like the idea of the membranes, a strong visual indication is worth a dozen numbers in boxes, IMHO. But... ultimately, the numbers in the boxes are how we engineer our reality, the stuff around us we take for granted every day.
You said,
Agreed !
What I find astounding is that these sorts of examples are put up as gospel of something relevant by a seeming acolyte - Wayne gave it the thumbs up of showing something important in principle.
But ... a physical model wasn't put up with supporting data of an energy advantage but a spread sheet was - you [the skeptic & not on team Travis] have to do the real world build & test, & explain the data & conclusions that show NO energy advantage - anyone would have thought you put up the spreadsheet.
Now I'll go back & find See3d's analysis of a ZED action & see if I can follow him.
Quote from: see3d on August 15, 2012, 12:11:54 AM
Hello all,
https://www.dropbox.com/sh/6vdnbk72ywyckns/zB501rT78P (https://www.dropbox.com/sh/6vdnbk72ywyckns/zB501rT78P)
~Dennis
Thanks Dennis !
EDIT:
What sim program did you use Dennis ?
I'm used to talking of force as Newton's rather than pounds - in fact, using SI units because they are a coherent system.
I use WM - if I have time I will replicate a similar system to what you have shown, in WM [time is limited] - I am fairly confident that I can mathematically create the pseudo/faux forces required that will act exactly the same as real buoyancy force so that the sim is an accurate predictive tool.
P.S. I for one appreciate & understand the enormous amount of thought, time & effort you have put into this sim & presentation.
Quote from: fletcher on August 15, 2012, 04:38:55 AM
Thanks Dennis !
EDIT:
Thanks Fletcher,
It can take more time and effort to build a good sim than a physical model. However. it is orders of magnitude less work to make a change and optimize it for a build.
I have been doing engineering work in pounds and inches since before there was any push to include metric in this country. Using units I am used to keeps me from making stupid errors. Also, since this is a mixed weight (gravity) and force system, I decided to do everything in the same weight measure for force to keep all units the same. Just my personal choice, and some non-engineers may be able to follow better this way.
This sim was written in AmiBroker. It is a stock market analysis program. It had the most useful characteristics for writing the UI stuff I needed of any program I was familiar with. The language is "C" like.
Quote from: TinselKoala on August 14, 2012, 11:27:56 PM
https://www.youtube.com/watch?v=pTSMyKdKDR0 (https://www.youtube.com/watch?v=pTSMyKdKDR0)
Well I guess I assume too much if I think that Larry's post made a clear point. It is clear to me probably only because of all the diagrams and calcs I've done on this system.
Let me try to explain a different way:
First, the diagrams that Larry showed are only a good explanation for the INPUT side of the ZED work analysis.
The OUTPUT side of a ZED is not drawn at all. But please consider that the analysis of the Output system needs for you to consider the amount of buoyant force that can be produced by a given Head of water. And then the distance that this buoyant force can work over (stroke) to create the Output work for comparison with the Input work.
It is agreed that the Input work of the single U system (left side) that Larry illustrated in post #1376 is greater (edited) than the Input work of the 3U system (right side). However, the water Head pressure created and therefore the buoyant force *potential* of the two systems are the same. Stroke height potential is not equal, just the buoyant force potential.
In the classical Archimedes float setup or the single U system it is known that the Input work only produces (at most) an equal and opposite Output buoyancy force potential. I believe this is the explanation why a buoyancy device cannot be OU. So Work In = Work Out.
But in the 3U system we have now reduced the Input work to achieve the *same* Output buoyancy force potential as the classical examples. So Work In < Work Out is a possibility. The next step would be to find a way to capture the Work Output while in this unbalanced condition?
M.
This was sent to me to post by someone who wishes to remain anonymous for the moment. FWIW:
This is nothing to do with how much force, just force flow.
If fluid under pressure is moved into the pod chamber the risers will rise.
If the risers are not allowed to rise then that fluid under pressure
will move the air and water columns within the risers and ring walls.
The changed air and water columns store that input value and can return
it at any time.
If fluid under pressure is continued to be moved into the pod chamber
and the resistance against the risers is maintained as such to just
allow the risers to lift but make no further change in the air and water
columns, then I can extract that resistance value.
If at the top of the lift the risers are held in place and the pressure
against the fluid in the pod chamber is reduced then the stored
potential in the air and water columns within the risers can be extracted.
The fluid under pressure can be manifested by raising a reservoir of
fluid a distance.
Hello all,
~Dennis
BRAVO!
Dennis - Your buoyancy simulation model is so well thought out and detailed! It is beautifully coded.
I like the way the split screen lets you compare water and air levels to the at-rest model at the same time.
The document has a good flow for all levels of readers. The engineers should be happy with all of the details in the formula pages yet the non-engineer can follow the detailed conceptual descriptions, graphs and animated models.
I agree with all of your conclusions on the last page.
LET'S GIVE DENNIS SOME FEEDBACK so we can move ahead to the multi-layered versions! ;)
@M, nice explanation.
It is coming.
@Dennis, very nice.
Regards, Larry
@M - Your anonymous contributor is quite a word-smith. He did a very clear job of expressing something Webby1 and Wayne have both mentioned a few times. I've been trying to design those same control elements into my test bed because I really think that is where a lot of the benefit of this technique comes from. Wayne's hydraulic cylinder and valves is perfect for that type of control but does suffer from friction losses that would probably kill a small model.
Great to have confirmation that I might be planning along some of the right lines.
Dale
Hi All,
I just finished uploading 5 short animations (about 35 seconds each), to my public ZED dropbox. They are about 3.8 MB each. A low resolution video can be seen in your browser, but to get a good look, you will have to download them to your machine.
One shows a zero layer system as a reference. The other four are for the 1 layer system. They go along with the simulator PDF description.
I have presented the animations that I thought would be helpful in understanding the simulation. However, my simulator program is built modular enough that I can change any dimension, add or remove views, do multiple simulations at once, show different internal parameters on the graph, or list different parameters in the table. I am open to requests for additional views that you think would improve the understanding of how this works.
I can also dial in a simulation for a physical model that someone else has built to compare simulation to real world. I currently only have 1 layer simulated until it is verified before adding additional layers. How do you eat an elephant? One bite at a time.
One private comment I had questioned if because I am not showing an over unity case on 1 layer, does that mean that the ZED can not work?
No, what have done so far does not rule out a working ZED because:
1. My simulation has not been verified to accurately reflect the real world
2. The test case geometry presented is far from an optimum configuration
3. I must include the middle layers to see the contribution for each added one to the overall efficiency.
I plan on making this a friendly and robust process. Skeptics are welcome to contribute to this effort.
One more thing regarding my simulated test case. There is no real setup involved. When in the down state, all air pressures start at zero PSI from atmosphere. I have the ability in the sim to preset the air PSI in each layer to a different value, but for the sake of a small model, I am running with the idea that the setup should be to add a fixed volume of water to the tank pockets, drop the riser into place, and put a rubber gasket screw into each layer vent hole while the riser is pushed down. That is all. All counterbalancing would be with external weights, like sand in a cup. No rocket science here.
Uh-oh. Looks like somebody has an even better buoyancy drive than MrWayne. Quieter, smaller, and already making lots of electrical energy. And his explanation is simple enough that even Koalas can understand it.
http://www.whec.com/news/stories/s2728359.shtml?cat=565
Quote from: TinselKoala on August 15, 2012, 05:28:11 PM
http://www.whec.com/news/stories/s2728359.shtml?cat=565 (http://www.whec.com/news/stories/s2728359.shtml?cat=565)
Are you serious? How many time does that concept have to fail, before it is put to rest.
Quote from: mondrasek on August 15, 2012, 09:18:27 AM
Quote from: TinselKoala on August 15, 2012, 05:27:56 AM
M.
Hi Mondrasek ..
Since TK hasn't specifically replied to your explanations I will take the liberty.
First, before I go there, TK had a problem to test the relative pressures in the multi-tubes experiment [re Larry's spreadsheet], to see if indeed you guys were or were not correct about the multi-tubes having the same head [i.e. pressure] as the standard much higher vertical water depth single U tube that demonstrated equal Input_Output energy.
I gave TK a few quick potential methods to test the pressures - since sleeping on it two more rather obvious methods have come to mind - the first is a small stand alone mechanical dial pressure gauge dropped into the bottom of each U set in series [these are just spring loaded dials that register pressure] - then you can read the pressures at each stage for comparison.
The second came to mind with a bit more lateral thinking [excuse the pun] - if a hole is pierced in a tank of water the water will exit horizontally under pressure - the velocity of the water exiting will be the same velocity as water falling vertically from the meniscus to the hole, at the hole - this relationship is due to Pascal's law - therefore this is a 'one_shot' method of testing your theory of same head & pressure for all 3 systems - it means attaching a stop that you turn on & off to test the relative horizontal distance each stream from each stage achieves compared to the 7 foot head single U tube.
Now, onto your post & I'll keep it brief.
I believe you are erroneous in your assumptions about the 3 systems having the same buoyancy force potential & this stems from a wrong belief that all 3 systems have the same pressure head - they don't, head is a function of height all else being equal.
1. the systems you cite are open to air systems on the right side.
2. air can be compressed - when it is done so it acts as a spring storing PE - is has the capability to give back energy in equal amounts of KE, less losses. EDIT: as per a toy pressurized pump water cannon.
3. clearly for air to be compressed & then give back KE to water Work must be done on the air - this work is equal to the stored PE in the compressed air.
General Comments & Observations:It occurred to me last night that after having viewed Dennis's excellent pdk drawings that the ZED system [when taken in context of Larry's & your's defence of the multi_tubes systems] that I was recognizing an underlying theme I'd seen before I thought.
That was that Wayne appears to have all the essential elements of a 'force pump' & that it is cobbled with a buoyancy system.
I attach a couple of pics from an old text book of mine that I scanned today - they show an ordinary lift pump & the compressed air augmented force pump - notes in margins etc are previous reminders to myself over something at the time.
Note that physics as we now understand it says that the Work done Input [the Effort] to raise the water [by lift or force method] equals the Output energy [the Load], less friction losses.
I think TK's continued call for good data for a complete single ZED cycle analysis of claims is even more important now than ever.
I think it important to test the Larry tube theory of equal head gives rise to equal buoyancy force potential [Output] for reduced Input with multi-tubes, because it is a first principle for understanding the basis & accuracy of the ZED claims.
I do hope we skeptics can be proved wrong because we'd all be winners in the end after the dust had settled & the jaws closed.
Best -fletcher
Quote from: see3d on August 15, 2012, 04:27:25 PM
Hi All,
As I see the situation:- We have a concept (the Travis effect) which seems to describe a OU machine.
- Theoretical considerations (repeatedly presented by Mr. Travis and followers) seem to support the OU claim.
- Some experiments, some simulations and some calculations seem to support the OU claim.
On the other hand:- The Travis effect is difficult to describe.
- The theoretical arguments may be flawed (because they do not take the whole energy flow into consideration).
- The experiments, the simulations and the calculations may be flawed (because they do not take the whole energy flow into consideration).
A way out of the endless discussion:
- Build a machine that works in the sense that it puts out "
useful net energy" over a longer period of time.
- This would prove the concept empirically and would encourage "real scientists" (who have a deep understanding of hydraulics and physics) to have a closer look.
What I suspect:- There is no working machine. (At least no proof of a working machine has been presented or reported by witnesses.)
- There seems to exist a machine (may be even several) but it is not self running and does not prove the concept in the trivial sense that "useful net energy" is put out for a longer period.
Greetings, Conrad
(Sorry, I repeat myself, but the discussion has become so convoluted, that I again wanted to present a "status check".)
@see3d
Thanks for your hard work. I appreciate it.
(But it is cruel torture that you chose Imperial units rather than SI. I had to look up and check that water has a density of 0.036 pounds per cubic inch.)
It is interesting that the riser displaces a variable amount of water without itself varying in volume, because you are able to raise the water level around it by keeping it locked as you press up the piston from below. This variable volume of displacement is what varies the riser's buoyancy of course; the pressure of the water... its "head"... only affects buoyancy because it raises the water level around the riser. This of course depends on the volume of the water being pushed up by the piston, not its pressure. The addition of the partially airfilled spaces between the walls allows some of the input work to be stored in compression of the air pockets as the water level is pushed up by the piston, before the riser is allowed to rise. It appears to me that the "buoyant force potential" depends on the water 'head' pressure, only in so far as this pressure changes the effective riser volume (the underwater volume) by raising the water between the walls by compressing the air pockets while the riser itself is locked. The water pressure raises the water around the riser; it's the increased water displacement that increases the buoyancy, not the water pressure per se.
The Inverted TE effect that I showed in my first video would then appear to obtain in the locked riser case. The total downward force that must be offset by the piston to push up includes the weight of the displaced water, so it increases as the water level rises around the locked riser.
The total work output is less than the total work input, when output work is considered to be the lifting of the weight on top of the riser. How could this be, if you are neglecting losses in your sim? It is because some of the input work is stored in the compression of the air pockets and/or the lifted water in the walls, and is still "stuck" in there at the top of the cycle; this stored work is returned during the second half of the cycle as a necessary part of bringing all levels back to their original state. In other words, some of the input work is done on internal parts of the system, raising and lowering them; this work balances (neglecting heat losses due to the compression and expansion of the air pockets). The remainder of the work goes into lifting the external weight, and this work too is returned as the system goes through the second half of the cycle.
It is as if you are pushing up on a mass through a compression spring. You push up with a certain force, the spring compresses but the load mass doesn't move so you press up harder. Finally it does but it goes up a distance less than you have pushed up, because the spring has taken up some of the distance travelled by your input force. If you look at the lifted weight x distance, it appears that the work out is less than the work in, by the amount stored in the spring's compression. So the total work still balances, as it should.
I think.... I'm sure I'll be corrected if I've gone wrong somewhere in my understanding.
I have to admit... that I see nothing particularly remarkable happening in your sim; if any of the work from either the external lift or internal compression/lift is taken away and used elsewhere, the system cannot reset to the initial state without more input to balance the work taken out. Certainly I see nothing that would indicate that there is a "three layer system that is clearly overunity itself' (as MrWayne has said exists somewhere) being modelled-- and I know that was not (quite) your intent.
But...
If you had the exact dimensions and masses of MrWayne's simple threelayer system that is clearly overunity itself, would you be able to put those values into your sim and show us exactly how it works out to be OU?
OK, tear me up.
--TK
Quote from: TinselKoala on August 16, 2012, 07:46:55 AM
@see3d
...The total work output is less than the total work input, when output work is considered to be the lifting of the weight on top of the riser. How could this be, if you are neglecting losses in your sim? It is because some of the input work is stored in the compression of the air pockets and/or the lifted water in the walls, and is still "stuck" in there at the top of the cycle; this stored work is returned during the second half of the cycle as a necessary part of bringing all levels back to their original state. In other words, some of the input work is done on internal parts of the system, raising and lowering them; this work balances (neglecting heat losses due to the compression and expansion of the air pockets). The remainder of the work goes into lifting the external weight, and this work too is returned as the system goes through the second half of the cycle.
...But...
TK,
Thank you for taking a close look at my partial sim model. Yes, you understand what it is showing for a single layer. I understood that all the input energy was conserved in the internal air and water head pressures. From a thermodynamic point of view (and I am no expert in this), even the heat of compressing the air is given back. If it is dispersed into the surroundings, it will be reclaimed from the surroundings. Since this is a static model, everything should be conserved except for static friction.
My intent is to understand the ZED from the ground up, not to prove anything one way or the other. To start with the idea that it does or does not work is to be biased. To be biased is to have cloudy vision. I have suspended belief and disbelief from the start of my investigation for this reason. Proof can only come from experiment, not theory. Theory guides the design of the best experiments.
However, what I need is a critical look at the conceptual model of forces on which I based my simulation program. This is not my area of expertise, and I am not sure I have it right in all the fine details. It is not the easiest thing for me to figure out.
To your question about modeling Wayne's machine -- Yes, that is my plan after verification that a one, two, and three layer model is mathematically consistent and conforms to known principles of physics. Comparing the simulated output to real machine measurements is critical for believability of the simulator. Wayne's three layer machine is the most instrumented machine to date and is the current gold standard. However, that does not preclude modeling and measuring other independent builds that can be translated into the geometry limitations of my simplified simulated model.
I am just now working on the mathematical relationships for the middle layers. I think I have a handle on that now. I plan on working closely with Wayne to model what he has now and proposes as the best configuration. I approach my work with respect for all the hard work done by Wayne and his engineers.
A critical review of my work as it is now and as it proceeds through a logical progression will be educational for me and everyone else who cares about discovery of scientific truth.
Quote from: conradelektro on August 16, 2012, 02:51:09 AM
What I suspect:
Greetings, Conrad
To All,
I have always enjoyed Conrad's wisdom, but I must respond to his disinformation again.
As has been reported here multiple times;
We had our PE certification of "concept" back in 2010.
Mark Dansie visited May/June 2011 and reviewed our input output model - and asked us to black box it.
November Mark returned and watched the system run and made his own video - that I posted last time our "friends claimed no one has seen it".
http://www.youtube.com/watch?v=q-0TITC4Wrc (http://www.youtube.com/watch?v=q-0TITC4Wrc)
After that visit - facing the same uninformed skepticism - Conrad presents -
Mark asked us for Data collection - which we took that same model and upgraded.
Mark has also publicly attested to the expectation of our success multiple times.
Mark has reported repeatedly and here on this site.
He has called us the .1 success out of the 99.9% Failures.
We are solving current issues for Mark and the rest of the team's next visit -
@Conrad, you have always been welcomed - but your pop In's with disinformation does not represent the content of this forum
and or the truth presented. I love your opinions negative or not - You ruin your credibility with the last three posts of
disinformation.
To All,
See3d has worked our physics from another direction than my own engineers - I look forward to his analysis with great anticipation.
I believe he has the ability to communicate in the Nomenclature needed for some in this group - please pay attention.
Thank you all for your help.
Wayne Travis
Quote from: fletcher on August 16, 2012, 02:19:03 AM
@fletcher, what you wrote above is all true, of course. For the "ideal" case that Larry illustrated he assumed that the air was a incompressible fluid. His reasoning for this is that we could replace air and water in this setup with water and mercury, or any two liquids of different densities so that compression could be ignored. In the ZED or Larry's illustrated case where any compressible gas is one of the two fluids used there would always be a decrease in the created buoyancy force potential due to compressibility.
M.
Quote from: mrwayne on August 16, 2012, 09:41:48 AM
To All,
I have always enjoyed Conrads wisdom, But I must respond to his disinformation again.
We had Our PE certification of "concept" back in 2010.
Mark has also publically and attested to the expectation of our success multiple times.
We are solving current issues for Mark and the rest of the teams next visit -
disinformation.
To All,
Se3d has worked our physics from another direction than my own engineers - I look forward to his analysis with great anticipation.
Wayne Travis
Mr. Travis,
I am curious why after having a patent on your device, that Mark Dansie felt it necessary to "Black Box" your device and only showed a very limited video. Isn't the purpose of a patent so that you have public protection so that you can freely show your device openly and the data of input and output to the public for marketing? Are there parts of your device that are still under development that do not have patent protection? Would your device (when stable) be suitable to power the electric motors on a locomotive in your opinion?
Liberty
For those who understand the 3 U examples from my previous post, please see the attached.
The first picture shows the same resting state Travis system as the 3 U with 0 Water Head. The second picture is 3 U at 0 and 7 for comparison. The third picture shows the same state Travis system as the 3 U with 7 Foot Water Head, except the Water Head is much larger for the Travis system as it has a pod of 72" X 30 Dia. as the Travis demo, but works basically the same as 3 U. All the Riser forces shown are due to the Travis system intersecting the air column pressures.
The piston force is replaced by the rise in the water level between the Pod and the Pod retainer to bring up the water head at a much decreased cost.
Those who want to learn, take your time, first compare Travis columns, right side of Pod to 3 U until you realize they are basically the same. Then try to understand how the separate forces are generated in the last picture. For those that don't know, the Riser forces are calculated as Si X Psi. All the needed information is there.
Notes:
1. The Force, Psi, Dia. and Si values are from my calculator.
2. The normal .198 for wall thickness and .25 for air/water gap are greatly increase in the drawings for visual clarity, but you should look at the Dia. text to understand the actual size.
3. This is not the normal Travis system way to setup, just an example to compare to 3 U to understand how the air pressure in each U can be used to generate force with lower cost.
4. Air compression is not considered, for my previous reason and it much easier to comprehend without it. It was a struggle to get some to understand 7 Foot Water Head on each without compression. I'll show actual compression on each channel later as all my calculators that show the water air channel levels account for air compression by SI of channel. But few have downloaded the calculators.
Regards, Larry
Wayne, I am sorry that you think I spread misinformation. I just say, that you will not be believed unless many people can see a working machine which puts out some net energy over a longer time. In fact this is the most trivial requirement of any OU machine and of course it is the most difficult thing to show.
On your web site you announced a test run for Friday 17th of August. May be you can report (after the event) accurately what one could see and the result of this test run, especially the net power output and the duration of the run.
"Verification" for most people simply means that an OU machine puts out "free power" (net power) for a longer time. One should be able to measure the net output and one should be able to see (by walking around the machine) that no power is put in which is not accounted for. A self runner would be helpful, because any human intervention will be suspect.
Once this "trivial verification" is possible for many people, you will be able to generate interest in the scientific establishment and in the serious business world. And if you want scientific recognition and recognition by serious investors you have to provide free machines for testing and verification.
I think that the "flying bicycle example" posted by TinselKoala was a very good way of putting it. If some one flies around me for some time with a "flying bicycle" I start to believe him, even without understanding how it works. If no one can be observed flying around in a bicycle, it will not be believed. One can never prove that a "flying bicycle does not exist", but one can prove that it does indeed exist by flying around people in this bicycle (even when its workings stay a secret).
In analogy, if you can provide a self running OU machine with a consistent net output, one will start to believe you. It would be even better if you could provide scientific institutions with free OU machines for inspection, you would be famous over night.
Greetings, Conrad
Quote from: Liberty on August 16, 2012, 11:02:51 AM
Mr. Travis,
Liberty
Black box is my term - it means having a machine you can verify has no external input. If it happens to mean something else - My apology.
We did that back in November - then the even harder examinations started.
There is more than enough information to build our overunity device - as many have replicated the physics of the system correctly - showing and affirming the fact.
Yes, we have improvements - those are under separate protection.
Our systems are big - but they do not have to be heavy - locomotion use would be down the road.
Thanks Wayne
Quote from: conradelektro on August 16, 2012, 02:39:20 PM
Greetings, Conrad
Thank You,
I did see where you wrote misinformation, I thought to myself - how could you not know that what you wrote was not true?
It is hard enough in this field of discovery just to "present my findings" and then that kind of stuff is added..... - I will appreciate, and respect that you mean what you say. Thank you.
I do understand that everyone assumes big checks come rollling in - they also believe that with a running system - all questions will stop - both are wrong.
I do understand your guidance - and certain people have had the "thorough walk around the machine" - and they are not the type that comment on Forums.
They are the type that join and help in a good fight, the fight we face - to explain the contradiction that we have presented physics - both being able to prove our system and argue against it.
A big error many here make - is assuming I am trying to convince someone of my machine's ability.
I am not trying to convince anyone - some will check it out - and some won't - those that do - come to the same conclusion -
Some thing is amiss in the Law of thermal dynamics - or it needs an amendment.
We are working very hard on the data converted model that is where we are now.
I understand that for people to believe in flying bicycles - ......... they need to see - but seeing is not believing - I have been there since last May - it gives hope - but the data and the answers to physics follow the sighting.
Then that is followed by a whole new list of questions.
This has been a great adventure - I do not mind sharing my story, and the story of the team working hard here - in its own way - sharing here has brought new team members - after they replicated the machine or the physics - it has been a blessing.
Thanks again
Wayne Travis
Hi All,
While going through the calculations for the 2 layer sim, I found an error in the formula used in the 1 layer sim. It was pretty glaring once I saw. it. Unfortunately that one error ripples through later formulas. I will post a new PDF version as soon as I work through the changes. It looks like the efficiency will be improved:
PAGE 9)
1. Calculate the AirPSI in the Riser air pocket:
AirPSI = (InputForce - PistonStopLoad) / H0Area
~Dennis
Good. I thought there was something funny about that one, but with all the hidden counterbalancing and the lack of computation of the internal work I wasn't really sure.
When you revise the sim, could you _please_ also account for the internal work, so that the total work "output" includes this internal work and its storage in the compression of the air and the lifted mass of the water? I can live with water density in pounds per cubic inch and hidden counterbalances and an unrealistically low-mass riser ... but not accounting for _all_ the work seems ... well, it seems like an omission.
At the top of the cycle when the lifted weight is as high as it is going to get, there is energy (work) stored in the system still, and this work isn't fully accounted for, and it is necessary to reset the system. If you released the internal pressure at this point... the weight would fall... and then if you resealed the system... it would have less air/water in it than you started the cycle with, showing that this stored internal work is indeed necessary to reset the system to the starting point of the cycle, and if it is bled off in any way... it will have to be replaced by additional outside work to bring the system back to the starting state.
Also, it would be nice if MrWayne would measure the "simple three layer system that is clearly overunity itself" that he has somewhere, and give you those exact parameters to enter into your sim, so we could see how this clear overunity manifests itself in a simple system.
Your sim has contributed greatly to my understanding of what is happening here. I do hope your revision, including the internal work and MrWayne's starting parameters, will teach us all even more.
Quote from: see3d on August 16, 2012, 05:59:32 PM
Hi All,
PAGE 9)
~Dennis
@Seamus10n:
Did you happen to watch Mark Dansie's video that MrWayne recently linked? It's very hard for me to reconcile the running of that system, as shown in the video, with any kind of mechanical resonance. The periods (measured by the interclunk timing) are not symmetrical nor are they exactly equal from cycle to cycle (assuming two clunks per cycle of course); nor does the amplitude of the "oscillation" increase. In fact the constant amplitude of the oscillations seems to be part of the control loop or is fixed by the geometry and is at maximum from the very first cycle. (I find this fact interesting on its own.) However, it seems to me that the f0 of the system varies a bit in a systematic manner over the 4 minutes of the video. What do you think?
ETA: mechanical or hydraulic resonance needn't be super fast of course; the "water hammer" is an example of (destructive) resonance in an hydraulic system, commonly found in poorly planned domestic plumbing and relatively easily corrected by hydraulic/pneumatic inductor-capacitor analogues that you can buy at Home Despot.
Referring to post 1376 on page 92 by LarryC. People have expressed doubts as to whether we can get the same head pressure from a number of layers in the diagram on the right as we would from a single tall column of water, and there has been talk of using submersible pressure gauges etc. Here is a very simple experiment to prove the point. Imagine we have the apparatus set up as in the right hand diagram. Now with the water levels as shown we extract the piston, and throw it away. The tube in which the piston fitted is now extended upwards to a hight of several feet. Now instead of depressing a piston with a weight, we pour water from a jug into the extended piston tube. We keep pouring until the water levels in the various U tubes move to the same position as happened when the piston was pushed down by the weight. At this stage, we find that the hight of the water column in the piston tube, is equal to the sum of the heights of the vertical columns in the U tubes. To me, this proves that the pressure of the column in the piston tube is equal to the pressure of the columns in the U tubes.
Quote from: neptune on August 17, 2012, 05:48:35 AM
Simple and brilliant, @neptune! Now, can anyone send TK one more polycarbonate fluorescent light tube protector tube?
M.
Quote from: TinselKoala on August 17, 2012, 03:24:38 AM
TK,
Thank you for your response.
I will try to make it more clear what the Riser counterbalance is about in a picture for the next release. Just imagine a rope up from the Riser up to and over a pulley with a counterbalance weight suspended from the other end. It can also be visualized as a lever in reverse of the water counterbalance weight that I did show. However, there is a buoyant force at the bottom of the Riser wall at the depth of the initial H1 and H2. If in the design, this is large enough, it could offset the weight of the Riser, but I doubt it would in a 1 layer design. Counterbalancing is is a practical problem with a simple solution.
The stored potential energy is shown in the graph when the WorkOut/WorkIn < 1. I also have another graph that I did not think would be interesting that shows the stored potential energy added to the WorkOut/WorkIn.
I considered it a practical waste to overdrive the input beyond lifting the weight to the limit stop. Just as it is a waste to have the Riser weight counterbalanced to more than zero. In a physical machine, I would try to keep these down to about 1% at each end of the stroke. I will will try to better show the balance of all the unused potential energy.
In my model, there is no provision for using any excess potential energy beyond lifting the load weight. It is all returned on the down stroke. Perhaps that is easier to understand if I explain how I envision a closed loop:
On a ZED in the down initialized state, add a 1 pound output load weight and a 1 pound input weight. After the output load weight is just raised to the top stop, remove it and the input load weight. The ZED will return to the initial down state. If the input weight has dropped less than the output load weight has risen, then the cycle can repeat forever.
Please keep the good questions coming.
Now, back to work fixing my calculations.
~Dennis
Quote from: TinselKoala on August 14, 2012, 02:16:28 PM
That part's clear enough.
The part I don't understand is what he does with all the extra hydraulic fluid he's generating. You inject 15 units to one Zed and get 30 back. He's said that many times, and that is supposed to be a full cycle for that Zed, right?So you take 15 volume units of that hydraulic fluid and inject it to the other Zed and it returns 30 back. Now you have 30 cu in extra hydraulic fluid in your accumulator. Pretty soon you are going to have to start selling that off, or the barrels are going to be all over the back yard.
Or perhaps the ratio of 30/15 is for the two Zeds together. But if each full cycle takes 15 out of the accumulator and puts 30 back in... you still have the same problem: too much hydraulic fluid.
Yes, you have too much hydraulic fluid. So the excess fluid is then used to drive a hydraulic motor, which , in turn drives an alternator, feeding a load. That is where the "free energy" comes from.
Attached is the third picture from my previous post with additional Psi pointer information.
This will be much harder to understand where the force and Psi are coming from than the 3 U water levels. If anybody has questions and they don't want to post here, please PM me.
Regards, Larry
And if it is demonstrated to be true, which I don't doubt, in this manner, what _then_ does it prove? Buoyancy does not depend on the pressure of the liquid, only on the mass displaced by the displacing object. In the system with a locked riser, increased "head pressure" causes the water rise and to wet more of the riser, effectively displacing more liquid. The pressure isn't affecting the buoyancy directly, and if the riser is free to float, it doesn't affect its buoyancy at all, as long as the riser's density (or equivalently the wetted volume) doesn't change.
It's an elegant demonstration, though, nothing wrong with that. If I had another tube I'd put it together in a minute. But I can't find any more of those polycarbonate light bulb protectors, they have been replaced by much weaker and flimsy tubes. Maybe one of those will work for this particular purpose but I wouldn't trust them for external pressure loads.
see3d said,
QuoteOn a ZED in the down initialized state, add a 1 pound output load weight and a 1 pound input weight. After the output load weight is just raised to the top stop, remove it and the input load weight. The ZED will return to the initial down state. If the input weight has dropped less than the output load weight has risen, then the cycle can repeat forever.
Really? If the input weight (that you have removed) has dropped less than the output load (that you have removed) has risen ... then the system is NOT reset to the beginning of a cycle with all levels and pressures the same as when started. Do you think that by bleeding off some pressure, doing work elsewhere, it will then be reset to the original state?
Quote from: neptune on August 17, 2012, 09:01:28 AM
Well, I've been told in no more clearer terms that my conception of operation like this is wrong. But... just in case it's not, you still aren't dealing with what becomes of the fluid... sorry, hydraulic oil.... after it goes through the motor. How and where does it get back into the Zeds, at what pressure, how is this pressure obtained etc etc.
And I believe that big thing with fins on it, being driven by the hydraulic pump/motor, is actually a generator, not an alternator, built for wind power systems. I don't know its exact specs... but I sure would like to.
ETA: Where, in the diagrams shown, does the extraction of 30 volume units happen, and the injection of 15 back in while diverting 15 thru the motor? After it goes through the motor it winds up in the reservoir. How does it then get back into the system?
Quote from: LarryC on August 17, 2012, 10:30:15 AM
Regards, Larry
Why are you showing this confusing diagram, when there exists a three layer system that is clearly overunity by itself?
Quote[cite]MrWayne[/cite]I will repeat what I have said - our current single unit is barely better than a hydraulic cylinder - you can measure the input and output - we do not use weight - but volume and pressure. Yes - our three layer system is clearly overunity by itself.
http://www.overunity.com/10596/hydro-differential-pressure-exchange-over-unity-system/msg332026/#msg332026 (http://www.overunity.com/10596/hydro-differential-pressure-exchange-over-unity-system/msg332026/#msg332026)
Why not diagram _that_ system, that is clearly overunity by itself, and let us know how the clear overunity was determined?
I've asked for this information once or twice before, in several ways. Is it an unreasonable request? I don't find it so at all.
Certainly, if I had made such a statement, I'd be prepared to back it up with real data, and I think everybody that knows me would agree that that is what I'd do. If you can't diagram it for some reason, then just tell me please how the clear overunity performance was determined for that three-layer (single?) system.
And while you are at it, I am also curious about the single system that is better than an hydraulic cylinder (barely).
Quote from: TinselKoala on August 17, 2012, 11:04:26 AM
TK, in the picture below all the red hydraulic lines are filled with high pressure hydraulic oil. All the blue hydraulic lines are filled with unpressurized hydraulic fluid that is also stored in a reservoir that is not represented pictorially. You can see where each blue hydraulic line from the cylinder on top of each ZED and after the motor ends is the labeled "Res" for "reservoir.
To each of the three sections of the multichamber hydraulic cylinders above the ZEDs are two lines, one the high pressure red and the other the low pressure blue. On each of these routes are also one way check valves. So when a ZED is going up it is pressurizing the Hydraulic oil inside these cylinders. That high pressure hydraulic oil can only flow through the red lines to the accumulator(s)(s). The one way check valves make this the only open passage. Then when the ZED is going down hydraulic fluid would be pulled back into those same hydraulic cylinder chambers above the ZED from the reservoir. Again, the one way check valves make this the only open passage.
M.
Quote from: TinselKoala on August 17, 2012, 10:58:13 AM
TK,
My simulation starts with the Riser at the bottom stop and no input or output weights applied, atmospheric air PSI everywhere, no Pod head, no exit head differentials. The riser has a NET weight of 0.01 pounds holding it against the bottom stop. Therefore, removing the input and output weights at any point will return it to the initial state. This initial state is very easy for me to analyze without a computer.
There is no provision for any fluid or pressure removal from the system as I have presented it. Excess energy production would be removed from any excess differential in the movement distance of the input and output weights. The potential excess output work would simply be a measure of the distance x weight. From a practical point of view, there would be other more direct ways of removal of any excess. For instance driving a crank from the linear motion of the Riser to spin a generator. In that case, it would be equivalent to the input weight moving the same distance as the output weight, but with a heaver output weight.
Please don't complicate it. It was reduced to this very simple form on purpose to aid in understanding. Wayne's machine has a lot of moving parts. It is beyond my ability to analyze it. I am trying to work with this simple cartoon version so I can analyze and understand it, building it up from the most simple to the more complex, one step at a time. If I am successful with this learning approach, you and others here will help me understand as I turn that understanding back around into an ever more complete simulation the will help others understand in an upward knowledge spiral.
Questions that you already know the answer to, but don't think I have explained well enough for others to understand are welcome.
~Dennis
@TK. I described the "thing with fins" as an alternator. You insist it is a generator. The term generator as I understand it is a term that includes alternators and Dynamos. So all alternators are generators, but not all generators are alternators. Modern wind turbines are usually permanent magnet alternators with rectification on the output to provide DC. But if you still want to call it a generator, that is fine by me.
Regarding your other question, well Mondrasek pretty well covered it . As the ZEDs rise, the hydaulic rams fitted to them act as pumps, one per ZED. They force 30 cubic inches of fluid into the accumulator. From there, half powers the hydraulic motor/generator, the other half powers the rams which push the convoluted bags to input water into the zeds. The low pressure "exhaust" from the hydraulic motor, and from the convoluted bag rams is returned to the reservoir.,
You ask how does the hydraulic oil get back into the system from the reservoir. As each Zed falls, oil is drawn into the hydraulic-ram-used-as-a-pump mounted on top of the ZED.
Quote from: neptune on August 17, 2012, 12:57:14 PM
I am not INSISTING it's a generator... I am REPEATING what was told to me, and what I've seen in units that are similar in appearance. You may note also that on MrWayne's diagram it is called a GENERATOR.
You can argue semantics if you like, distracting from the main issue. The important distinction between a GENERATOR and an ALTERNATOR is that the generator can be driven electrically in a simple manner and will turn... just like a motor. Alternators with field coils and no PMs... much more difficult to make them motor along. Also... generator/motors will work fairly well even at low RPMs and torques. Alternators, not so much.
Please provide the part number of the unit in question, so that we can get some specs and see if it's a generator with PMs, that can be reversed into a motor, or an alternator with field coils that are more difficult.
QuoteYou ask how does the hydraulic oil get back into the system from the reservoir. As each Zed falls, oil is drawn into the hydraulic-ram-used-as-a-pump mounted on top of the ZED.
But every body else who has answered this question is telling me that the oil is injected into the zeds -- or somewhere -- at high pressure. This does not jive with your description, which requires a NEGATIVE pressure, or suction. The reservoir is held at what pressure?
Oh... the first 15 units goes into the zed at high pressure and the rest which flowed thru the hydraulic motor/pump is returned at low pressure, from the suction of the rams ... a process that requires INPUT WORK?
The ZED tanks contain air and water only.
The hydraulic (oil) system is external to the ZED(s).
Nothing is injected into or taken out of the ZED system once set up and operating.
@see3d:
I am complicating the issue?
OK, fine. I suppose my continued request for real data on the simple three layer system that is clearly overunity by itself adds to the complications, doesn't it? Especially when the fact that we aren't being provided with this data or any other evidence that that _simple_ system is clearly overunity by itself, starts sticking out like a sore thumb. It's pretty complicated to try to interpret that set of facts, all right.
And LarryC's posting of his most recent diagram is simplifying the issue. Uh huh.
OK fine, carry on.
Quote from: wildew on August 17, 2012, 02:11:21 PM
So when MrWayne says "we take out 30 cubic inches at (some pressure I can't remember) and we return 15 cubic inches at (almost the same pressure)" he is referring to the hydraulic system only. And the 15 cubic inches that drive the motor and are returned to the reservoir at atmospheric pressure. Right?
How exactly does that oil get back into the active system of rams? It appears that the answer is that it is SUCKED UP by the rams and squirted into the pressure side of the hydraulic system. A process that does not come for free.
Am I still wrong?
mondrasek said,
QuoteThen when the ZED is going down hydraulic fluid would be pulled back into those same hydraulic cylinder chambers above the ZED from the reservoir.
Thank you. This is a process that requires work, does it not?
Quote from: TinselKoala on August 17, 2012, 02:12:56 PM
@see3d:
OK fine, carry on.
TK,
My comment about complicating the issue is only in regards to my simulation. I don't want to mix what I am doing with what anybody else is doing at this stage. AFTER the simulation is regarded as an accurate description of the statics, THEN we can apply what we have learned to the other efforts. To do so before that is a meaningless exercise bound to generate false conclusions.
@mondrasek, thank you for your explanations. Let me see if I've managed to get it down yet.
So 30 units are taken out of the pressure side of the hydraulic system, and 15 of that are immediately injected back in at almost the same pressure, and the other 15 are diverted thru the hydraulic motor and wind up in the reservoir ( at ambient pressure ?). Then the hydraulic suction rams draw fluid back up out of the reservoir... and then on the next stroke reinject it into the pressure side? So then these particular rams are just functioning as pumps, they are not putting power into the mechanics, they are driven on both strokes and not driving anything but the re-injection of the oil back into the pressure side of the hydraulic system?
@TK. All the information I have posted in reply to your questions is information I have gleaned from what mrwayne has already posted, and has been posted by me in a genuine attempt to help you understand the system. Re the alternator/generator, Wayne said something to the effect that it was designed for a wind turbine, and was chosen because it works at low RPM. Of course I do not have a part number/ specification. So from what I am told I naturally assumed it to be a permanent magnet alternator, as is the normal practice. Will it work as a motor? I do not know for sure but I expect that if it was fed with a 3 phase AC supply it would work as a synchronous motor, but that is not its purpose in this machine based on what we have been told.
You asked at what pressure is the reservoir. In the hydraulic systems that I have experience of, the answer is atmospheric pressure. The reservoir has a filler cap to top up the fluid, and this is usually vented to atmosphere. I am not sure if the
reservoir is above, level with, or below the rams on top of the zeds which act as pumps, hereinafter referred to as production rams, that is Waynes terms. Let us assume worst case scenario and say below. In that case, yes a small amount of work would be needed to return the fluid to the system.
Please bear in mind that I am engaged here in a genuine attempt to help you. If you would rather I desisted, just say so.
Quote from: see3d on August 17, 2012, 02:27:10 PM
TK,
Oh, no, I think I understand what you are doing with the sim. You want "us" meaning the skeptics, to approve your sim as being correct mathematically and structurally, and then you will bring out the input parameters -- which you probably already have waiting in the wings -- that show overunity performance.
But I would like you to take a _real_ system that is simple and already confirmed to be clearly overunity by itself, by MrWayne and his engineers, and put +those+ parameters into your sim. If you get the same overunity result as MrWayne using the parameters from a Known Real System that is clearly overunity by itself, then we'll know that your sim is working right.
Right?
Quote from: neptune on August 17, 2012, 02:39:52 PM
(snip) Let us assume worst case scenario and say below. In that case, yes a small amount of work would be needed to return the fluid to the system.
1) I believe the reservoir tank can be clearly seen in MrWayne's slideshow on the website. It's at the bottom of the system, underneath the electronic control box, isn't it? I don't have the photo in front of me right now, but isn't it the big rectangular box that has steel casters on the bottom but is slightly elevated off the floor by the framework of the apparatus?
2)Why should I rather you desisted? I need all the help I can get, to dig this hole deeper, and you are helping immensely.
3) Perhaps it is just a question of semantics, but in my hands-on experience, generators are DC devices and alternators are... well... AC devices.
MrWayne: may we please have the spec on the generator/alternator that appears in the photos?
@Tk.
1.Having looked at the photographs on Mr Wayne` site, It would appear that the object to which you refer is indeed the hydraulic reservoir. That would mean that a small amount of work is consumed in drawing oil back into the production rams.
2. I am here to help you understand what is being claimed. If you want help with hole digging, I am not your man. I am here to help you make an unbiased assessment of the technology.
3.Rather than get involved in semantics, I prefer to rely on what Wayne has already said, and if you want to call it a generator that is OK. Perhaps Wayne will enlighten us as to the exact type of machine, and its specification.
Quote from: TinselKoala on August 17, 2012, 02:49:28 PM
I am sorry for the delay - very busy testing.
Several Points --
For TK
The drawing Larry has shown is the dimensions of my unit - do with it what you like.
Second - It is called a wind generator - from Windynations - 500watt A/C three phase. We rectify it to DC - the voltage locks into the CPU batteries. I have no idea if you can run it backwards - I assume so.
Normally a hydraulic motor can function as both pump or motor - until you drop below certain sizes - at least with this supplier - this particular motor can not be a pump.
The Reservoir for the return fluid is at the highest point in the system to avoid air trapping and suction.
See3D is going about this the right way - step by step - because poor Skeptics throw the baby away - over minutiae - like the cost of the oil returning to the reservoir - or the ambient temperature change effect on the accumulator.
Again: I am not here to convince you of anything - quit trying to force the issue - if you are not interested in learning - or you already know everything or you consider it a trick to show you step by step the understanding of the process - - you are free to move on.
For Seamus (3),
I think I understood part of what you stated - about seeing the potential - your conclusion is a bit premature - as See3d warned it would be if you jumped to the end too early. I am glad you are following his demonstration.
To the rest of you who answer the repeat questions - Thank you - Thank you very Much - I will comment if I see a wrong turn.
To those of you who would like to be on our Z.E.D. update list - Email Sandy at jwtravis5@peoplepc.com and ask - she will add you.
Thank you again, and in our future - a breath of fresh air - might just become a forgotten phrase - this is good.
Back to the Lab!
Wayne
Quote from: TinselKoala on August 17, 2012, 02:43:08 PM
Right?
TK,
You are too funny. I am not trying to lead anyone into a "trap". How can I show a convincing O/U case when I don't even have the formulas right at this point by my own admission. I would not be a very clever adversary now would I? LOL
Besides, my ego is not big enough to care if I won. My nature is more collaborative than competitive.
I am offering a different approach to learning how the ZED operates, myself included. One that is based on math and scientific principles from the ground up. I am being open and inviting anyone who is capable of contributing to this opportunity to do something constructive towards learning the scientific truth along with me.
What I am doing with the single layer sim is what I had ask for from some skeptics on another site before I came here. A couple of skeptics told me that it was a trivial exercise. One said that he would generate the transfer curves for me. Weeks later he said he had them but would not show me the pictures. Do skeptics lie? I then started my own effort to create the simulation for my own enlightenment before I replicate. It is not a trivial matter as far as I can tell.
I am not accustomed to blind replication. I have been designing and building things for over 50 years (I started young with tin can robots and simple computers). I generally do a paper design (or a CAD design now days) and do a math model if required. I get to know what the tradeoffs are and get an intuitive grasp of them before materials are wasted. I optimize in simulations rather than build a hundred prototypes.
I am looking to the capable skeptics and believers to help me generate a sim that is scientifically accurate. That is my first goal. I am sharing the process. I have no hidden agenda other than the truth. I have stated before that I am taking a neutral attitude -- neither trying to prove O/U nor trying to disprove it. My goal is scientific accuracy in a simulation.
However, even if my sim is deemed accurate by consensus, and shows either O/U or not, it still does not constitute a proof of either. The simulator is an attempt at a visualization of a theory. A theory is not a proof. If an experiment does not agree with the theory, the theory is bogas and has to be revised.
You are right that the ultimate test of the sim will be how it matches up to experimental builds. If it does not match, then either the experiment had bad measurements, or the sim is wrong. Multiple experiments are best.
The sim needs to start out being consistent with math and science first. Then it needs to be compared to experiment. I could hardly put in numbers from Wayne's 3 layer ZED when I am still working on getting 1 layer accurate.
It would be good if you are able to help with the first objective of having a mathematically and scientifically consistent sim. I can't imagine that would not benefit everyone.
~Dennis
Quote from: TinselKoala on August 17, 2012, 02:20:30 PM
mondrasek said,
Well I believe that depends on the actual relative heights (and the assumed gravity field) of both the hydraulic cylinders and the hydraulic reservoir.
Seriously, professor, thanks for challenging us. I believe we are making great progress because of it.
I'd love to engage more right now but am in charge of the little one. But it looks like the rest of the class is in attendance.
Somebody wake up Hicks (er, um, I mean, Webby)!
M.
Quote from: mrwayne on August 17, 2012, 03:32:17 PM
Several Points --
For TK
A lot of members here have great respect for TK logic and due diligence when it comes to claims of over unity
So it is not just TK that your answering but the people like myself whos understanding of science is limited.
I say this now because I feel there is a slight resentment in your response, I do hope this is not the case
and you will continue to answer TK questions as best you can.
After all we're all looking for the same thing "Free energy that is self-running"
Quote from: neptune on August 17, 2012, 03:14:08 PM
@Tk.
Several Points --
For TK
(snip)
Well.... can you blame me for being confused? The reservoir is on the bottom, the reservoir is on the top. I only see a reservoir on the bottom, but I'll take your word for it that there are components that aren't being shown.
"The drawing Larry has shown is the dimensions of my unit - do with it what you like."
I am asking for the dimensions and pressures of the simple threelayer system that is clearly overunity by itself. Is that what Larry's drawing represents? How is the clearly overunity performance determined for this threelayer system that is clearly overunity by itself?
This must be an unreasonable question, because nobody is answering it. But as I said before, I don't think it is unreasonable at all, especially if one is attempting to explain a much more complex and apparently harder to measure system to a tree-dwelling leaf-eating bearlike animal.
Thank you for the name and rating of the generator you are using. I'll be looking up the actual specifications for the unit, like its preferred operating RPM and stuff like that there, just for my own reference purposes. It seems that there is sufficient flow of hot wind around here that I might be able to use a wind generator at home. If you would be so kind as to also specify the part number of the hydraulic motor, that would also be nice.
ETA: You've said, I think, that the system makes 36 Watts of electrical power over and above that which is needed for the operation of the machine itself. How much is that? I mean, how much of the generator's 500 Watts rated output at full RPM is actually being generated, and how much goes to running the machine?
Is this the PMA.... Permanent Magnet ALTERNATOR... that is being used?
http://www.youtube.com/watch?v=q1lC9eN0u60
I believe that a Wind Generator refers to the entire apparatus. The unit being turned by the wind power and used to produce electricity from it is an ALTERNATOR, using the manufacturer's nomenclature.
Sloppy language makes Koalas misunderstand what is happening. We are very literal critters.
@see3d: Touched a nerve, did I? Sorry. You are doing just fine, carry on. But I think that the simple three layer system that is clearly overunity by itself would be very interesting to analyze, don't you? I especially would like to know how the clear overunity is determined. Does it run itself indefinitely too?
@MrWayne: Is there some design reason that crossheads weren't used in your device? They would eliminate many of the side loads that are wasting power and making noise in your system, I think.
The Riser's don't float up, they work like a pneumatic cylinder. See the first Picture. The attached drawing show how pneumatic cylinders using the same Psi and dimension replicate the Outer Riser and the next Inner Riser lift force.
Regards, Larry
Quote from: TinselKoala on August 17, 2012, 05:58:50 PM
TK,
Yes, I think it would be interesting to analyze, but first I need to create the tool that makes it easy to understand and analyze it in the way that makes me comfortable. I make too many clerical errors in my hand calculations to trust any answer I get that way. I also understand the limitations of small shoestring operations -- having been there and done that several times in my life. I am looking to be a positive contributor to all this. It is my nature to be helpful.
Quote from: TinselKoala on August 17, 2012, 05:36:21 PM
The Hydraulic tank is in the upper right corner - barely see it in that shot.(top picture)
The lower Tank you are referring to has a green hose running into it - antifreeze - this is a reservoir but for the draining of the ZEDs during set up and testing. Antifreeze because it has a rust preventative in it - and to prevent the animals from drinking it.
TK, I have great deal of respect for you and others - when my communication does not satisfy the question - it is frustrating - to both of us - and then when you assert I am avoiding the question - we are both put out. I accepted the fact you placed me in your Idiot file ;-)
To all - my claim has been substantiated long before sharing here - first party second party third party - with simple physics, with complex, with Power, Energy, and Force - and yes - it will require an amendment to the Laws - or an exception will have to be made for "Virtual Mass Utilization" - I really like that virtual comment TK.
I am a very open person, and I do not mind helping someone build a replication.
I am not helping copy my current system- it would be silly anyway - it is the least effective model we have.
If you want that kind of detail - you need to join our engineers - on our side - thank you.
Thank You, and kind regards
Wayne
Quote from: TinselKoala on August 17, 2012, 06:06:16 PM
Because I do not know what a cross head is - the noise from our system is the bronze bushing in the Production cylinder - the last set had nylatron/plastic - no noise.
The clanking is both the two main valves clicking - and loose parts clanking.
I will ask my engineers what a cross head is, thanks.
Wayne
tk,
compression slows the flow.
Quote from: powercat on August 17, 2012, 05:14:15 PM
I respect all people - I have respect for both the strengths and the weakness of others.
I am certainly not in a position to cast dispersions on others.
I presumed from the beginning that the members of this group were here for that - a brighter future, clean air, freeenergy.
On that note - here on this site - I have had to deal with many very angry people, many arrogant, many rude, and many that lie - for a motive beyond my understanding.
Since I began sharing our discovery maybe 33 pages of people trying to force, beat or pry something out of me to further their claims of disbelief.
They lump me in with all the previous failures - the frustration, anger, ignorance, belongs to those of the past - blaming me - is wrong.
The problem is - and will be to those people - I am telling the truth - verified by many now.
The independent replications are awesome - they are more powerful than anything I could say.
If I have a frustration - and I hope I don't - it isn't that people here are not willing, intelligent, helpful, it is that some people demand and want things handed to them ..... hand outs don't work.
I have yet to have a person value the system I have - when it was handed to them.
I do understand that what I say seems like "claims" and that is presumed by some to think I am challenging them.
Well I have challenged some - check for yourself or have someone you trust help - those that do - win the challenge when they discover for themself.
Larry, Se3d and others are trying to help. TK is sharp - I admire that - I am not going to tell him how to do his work - nor will I allow him to direct mine. He is a good man, I have heard it from many.
p.s. I love TK logic as well - maybe he is already at the end - and is holding back - but until he represents to me an understanding of the basics - I am not interested spending the time on the external apparatus.
One thing should be clear to all -Hounding does not help me explain things better, and does not encourage me to help..... I am at a bit of a loss - so I forgive and move on.
Just as you say others are better at this than me too.
I am so glad, and feel blessed and honored that some of those that have replicated - have come and visited, and a few have
shared here.
Thank you for your comment - I will try to be more careful in my responses.
Remember - I answer more questions privately at mr.wayne@hydroenergyrevolution.com
Good night.
Wayne Travis
Quote from: LarryC on August 17, 2012, 06:11:16 PM
Regards, Larry
Why is the floating object in see3d's sim called a riser, and why is it shown floating up? It rises due to floating, not due to pneumatic pressure, unless I am greatly misinterpreting his sim.
Quote from: johnny874 on August 17, 2012, 06:35:14 PM
tk,
May I quote you on that?
It certainly seems that in my air compressor, for example, the higher the compression, the faster the flow out the nozzle or tool or spraygun. On the other hand, within the flow itself, an increased flow causes decreased pressure in the flow. These two Italian guys named Bernoulli and Venturi figured this stuff out a couple of years ago, I think.
Quote from: TinselKoala on August 17, 2012, 07:53:12 PM
I called it a Riser, because it moves and the Tank does not move. Since my initial state is sunk, it is also called a Riser, because the "power" stroke is rising up. I guess I could have called it a sinker, since it sinks with no inputs. I don't even remember if I picked up the term from someone else. I would not call it a floater though... LOL. What difference does it really make? A rose by any other name.
There are two ways of looking at it. Is it floating up, or a pneumatic cylinder? This is a hybrid device. It has aspects of both, and that is what makes it harder to understand. Looking at the transfer curves, depending on the state, it could look like either. That is part of my problem -- trying to make sure I have the theory correct much less getting rid of typos in my formulas.
MrWayne: thank you again for answering. No, you are not really in my "OUIdiots" file... you are still one level above that in the directory tree.
Crossheads are used whenever a straight push needs to have some out-of-line motion at the end of travel. Perhaps the most familiar place we see crossheads being used are in railway steam locomotives, where the straight push of the piston needs to be sent off-axis to the driving wheel. It is sort of like an external wrist pin; it acts to relieve the side loads on the piston and cylinder and conrod packings by moving them to easily lubricated sliding guides.
Another improvement in geometry I was thinking might be useful for approximately the same purpose would be to adopt the shape of an oil pumpjack's head, which serves to change the straightline travel of the pumpshaft going into the well, into the arc motion of the jack's rocker arm without putting side loads on the pump shaft. I know you have plenty of pumpjacks around so you know what I mean here.
OK, so the hydraulic reservoir that is at or near ambient pressure is the small white one at the top, and its rams that pump fluid from it back into the pressure side are the two rams at the very top, also seen in that same image?
And that big tank at the bottom is a water tank, and there are no other reservoirs (except the pressurized hydraulic accumulator)?
And how does the hydraulic fluid get from the motor's outlet back up to that reservoir? Is there enough pressure in what is being supplied to the motor to drive it back up there or is it assisted in some way to get back to the reservoir which is much higher than the motor?
On another issue... I have been looking for the patent. I see some drawings from it, but I've been back through this entire thread and over both your mrwaynesbrain website and the PESN page and I can't find a listing for the patent. I probably just missed it... I am literally half blind these days, my left eye is failing... so could you please link to it again? And it is an actual, fully granted patent, right? Not "just" an application, I hope.
Quote from: see3d on August 17, 2012, 08:16:32 PM
It doesn't have closefitting seals that don't allow fluids like air or water to pass, does it? It sure looks to me like it's floating and the pneumatic part is only raising the effective water level, and when the riser--your term-- is locked, the water rises up around it, effectively creating the same kind of "virtual water weight" that I showed in my first little video. Right? Therefore it is not a pneumatic cylinder, which requires sealing and does not allow water to come up past it. Nor is it some kind of hybrid. It is a floater; it rises because it displaces liquid, the amount of liquid displaced can be varied by locking it in place and pushing up on the bottom piston, and when it's unlocked it becomes a simple floater again, rising to the correct height , and with the correct buoyant force, for the amount of water its wetted volume displaces.
Right?
And I am afraid I don't understand how it is supposed to sink through water, since it has extended volume but only weighs, or is counterbalanced to weigh, 0.1 pounds in your sim.
Or was is only 0.01, I don't have it right in front of me.
There are roses that have thorns, and there are thornless roses. They might smell the same and be called the same... but you will find out just how different they are when you try to grasp one.
Quote from: TinselKoala on August 17, 2012, 08:25:14 PM
Right?
Well it does not matter to me which way it is approached, as long as it gives the right answer. I approached it from the point of view of forces rather than displacement. One can be translated it to the other in practice. I would like to see it calculated both ways, and both matching. Tried that once, but had trouble with the displacement version. If you show me the exact formula for your way, I will plug it into the sim program and see how it compares.
Sinking: In the down state, there is no H0, so no buoyancy force on the pod. There is some buoyancy force for the Riser wall that is sunk to the bottom of the H1-H2 water pocket. The Riser would in a practical sense have more than enough weight to sink, so it is counterbalanced to 0.01 pounds to just barely sinking (1% of the load weight). It takes an input force (even without an output load weight), to raise it up. Therefore, remove the input force, and it returns to the sunk state. Here is the new picture I am adding to the PDF:
tk,
the reason air has high velocity is it has low pressure once it leaves tne nozzle.
that is a principle they use in converting high pressure steam into tne rpm's of the steam turbine.
Here is the problem I am having with my reworking of my formula:
I start with a riser locked down and no input force. I apply an input force and the piston will move up until it encounters an opposite force equal to the input force. When the piston moves up, it forms head H0 which compresses the air. I first determine the air PSI that will exert the same force over the area of H0. I can see no way around this fundamental linear relationship, so this is where I start.
AirPSI = InputForce / H0Area.
0.125 = 1.00 / 7.987
I reason that the H2-H1 head differential must also support the same PSI calculating from the exit back.
H2 - H1 = InputForce * H1Area / (H0Area * H2Area * WaterWeight)
5.210 - 2.251 = 1.00 * 9.684 / (7.987 * 11.380 * 0.036)
2.959 = H2 - H1
The two formulas are linked by:
The constant water volume of the H1, H2 Tank pocket
The linear reduction in air volume with increased PSI
However, when I do an internal consistency check for the force at the bottom of the Riser wall, I get two different numbers depending if I calculate it from H2 or H1 + air PSI. I have not found where my reasoning is incorrect yet.
Calculated from the H1 side, I get 0.206 PSI at the bottom of the Tank.
From the H2 side, I get 0.188 PSI at the bottom of the tank.
I either have something messed up in my conceptual thinking, or I just have a typo in my formula that I have not found.
Here is the picture:
see3d,
not on a pc but am asking this based on your answers, does one side have 10% more surface area ? if so, that could equalize force.
you know, psi x surface area woulc show the potential force of h1 & h2.
Quote from: TinselKoala on August 17, 2012, 08:16:44 PM
...On another issue... I have been looking for the patent. I see some drawings from it, but I've been back through this entire thread and over both your mrwaynesbrain website and the PESN page and I can't find a listing for the patent. I probably just missed it... I am literally half blind these days, my left eye is failing... so could you please link to it again? And it is an actual, fully granted patent, right? Not "just" an application, I hope.
Found the patent, er, application:
http://www.google.com/patents?id=BfIPAgAAEBAJ&printsec=frontcover&dq=wayne+travis&source=bl&ots=klAmREbeB3&sig=A1L1SPYXJ-do-TsHrO-VPGu2xPw&hl=en&sa=X&ei=gQ0vULLoBITHrQG7nYHwBg&ved=0CEYQ6AEwBw
Just call me "document boy" from now on... ;D
P.S. Seeing as the other forum is down at the moment, how's the frequency counter troubleshooting going?
Hello TK,
This is the reservoir - above all the hydraulics - With the sticker on it - it is not square because it used to be mounted inside our 7 foot wide 12 foot tall test model.
You can see a little white oil filter just below.
If someone has not linked you to the patent - Search under Travis Wayne S, It was released under the PCT.
Thanks Wayne
p.s.
Thank you for the Crosshead info - That would help - I will bring it up when the design team meets.
Component comparison of pneumatic cylinder to Travis pneumatic risers in first picture.
Regards, Larry
Quote from: johnny874 on August 17, 2012, 11:48:14 PM
see3d,
Very good Johnny,
You are on the right track. By trial and error last night I found a factor I could use to make the internal PSI check consistent. It was Factor = H2Area / H1Area. Unfortunately, that violates my first assumption that the PSI must counter the input force: Air PSI = InputForce / H0Area. So, I must reject the answer of PSI = InputForce / ( H0Area * Factor ). However, with the clue that it is off by that ratio, I will look to the formula further down stream that uses that same ratio in finding H1 and H2.
Thanks for the suggestion.
Quote from: LarryC on August 18, 2012, 08:36:38 AM
Regards, Larry
Larry,
I stopped for a minute to rest/and/check progress on the forum.
I have to say- you are doing an excellent job giving visual representations.
The water surface is our hydro/pneumatic seal for our Z.E.D - a little less friction is not a bad thing :)
Thank you,
Wayne
Quote from: see3d on August 18, 2012, 08:40:10 AM
Very good Johnny,
your welcome :D
And now for something completely different...
Thanks, MrWayne. I am learning a lot from you. The big reservoir was not obvious to me... I guess it would have bit me if it was a snake or something. Thanks for pointing it out. The little filter that I at first thought you were talking about didn't look nearly big enough.
Using the search terms you gave me, I found this application:
United States Patent Application 20120117957
http://www.freepatentsonline.com/y2012/0117957.html (http://www.freepatentsonline.com/y2012/0117957.html)
All I can find is this application. Can you please give me a link to the actual granted patent at the USPTO?
Here is some more information I found to be very interesting, lots of stuff I didn't know about patents, the PCT system, and patent applications.
http://www.patentlens.net/daisy/patentlens/3037.html (http://www.patentlens.net/daisy/patentlens/3037.html)
http://en.wikipedia.org/wiki/Patent_application (http://en.wikipedia.org/wiki/Patent_application)
http://www.legalzoom.com/utility-patents-faq/what-difference-provisional-utility-patent.html (http://www.legalzoom.com/utility-patents-faq/what-difference-provisional-utility-patent.html)
http://en.wikipedia.org/wiki/Patent (http://en.wikipedia.org/wiki/Patent)
From the last reference:
QuoteA patent is requested by filing a written application (http://en.wikipedia.org/wiki/Patent_application) at the relevant patent office. The person or company filing the application is referred to as "the applicant". The applicant may be the inventor or its assignee. The application contains a description of how to make and use the invention that must provide sufficient detail (http://en.wikipedia.org/wiki/Sufficiency_of_disclosure) for a person skilled in the art (i.e., the relevant area of technology) to make and use the invention. In some countries there are requirements for providing specific information such as the usefulness of the invention, the best mode (http://en.wikipedia.org/wiki/Best_mode) of performing the invention known to the inventor, or the technical problem (http://en.wikipedia.org/wiki/Technical_problem) or problems solved by the invention. Drawings illustrating the invention may also be provided.
The application also includes one or more claims, although it is not always a requirement to submit these when first filing the application. The claims set out what the applicant is seeking to protect in that they define what the patent owner has a right to exclude others from making, using, or selling, as the case may be. In other words, the claims define what a patent covers or the "scope of protection".
After filing, an application is often referred to as "patent pending (http://en.wikipedia.org/wiki/Patent_pending)". While this term does not confer legal protection, and a patent cannot be enforced until granted, it serves to provide warning to potential infringers that if the patent is issued, they may be liable for damages.[23][24][25]
For a patent to be granted, that is to take legal effect in a particular country, the patent application must meet the patentability (http://en.wikipedia.org/wiki/Patentability) requirements of that country. Most patent offices examine the application for compliance with these requirements. If the application does not comply, objections are communicated to the applicant or their patent agent or attorney (http://en.wikipedia.org/wiki/Patent_attorney) and one or more opportunities to respond to the objections to bring the application into compliance are usually provided.
Once granted the patent is subject in most countries to renewal fees (http://en.wikipedia.org/wiki/Maintenance_fee_%28patent%29) to keep the patent in force. These fees are generally payable on a yearly basis, although the US is a notable exception. Some countries or regional patent offices (e.g. the European Patent Office (http://en.wikipedia.org/wiki/European_Patent_Office)) also require annual renewal fees to be paid for a patent application before it is granted.
Again, I want to thank you for being so forthcoming in your explanations to me. Sometimes I don't "get it" what people are telling me the first time, so I usually try to do a little research of my own, and I always learn a lot when I do.
EDIT: I also found this, that may be of some passing interest.
QuoteThe marking of an article as patented when it is not in fact patented is against the law and subjects the offender to a penalty. Some persons mark articles sold with the terms "Patent Applied For" or "Patent Pending". These phrases have no legal effect, but only give information that an application for patent has been filed in the Patent and Trademark Office. The protection afforded by a patent does not start until the actual grant of the patent. False use of these phrases or their equivalent is prohibited". [5]
@derricka: Thanks, I got it...
The HP8640B is fully operational now, thanks for asking.
Do you know anyone that needs one? I'll sell this one cheap, I just do not have room for it.
Quote from: mondrasek on August 18, 2012, 12:33:24 PM
OK M-
I'll bite.
Whatcha doing with the materials in the picture? Hmmmm.
Dunno yet. Just making something...
M.
Hello TK,
I understand it is not easy wading through all of these pages - The last time someone asked I shared the Progression of our patent "Application" it is a long process.
I have very good Patent attorneys taking care of it.
I do see your point in distinguishing between my patent - which is all the work our team and my attorneys put into it, and a "granted patent".
Rest assured - we are unique....recorded, filed and protected.
Our PCT has been granted, and we have sent those results to the US patent office as well.
Thanks Wayne
Webby!
Please tell us about your latest tests?
Please?
M.
for some more references on patent protection i've uploaded some documents from and old patent attorney friend of mine.
even older than me. probably one of the most experienced patent attorneys i've consulted for.
Patent Reform Act (2011).pdf (http://www.overunity.com/downloads/sa/view/down/509/#.UDBFSaO058E)
A Need To Protect (2011).pdf (http://www.overunity.com/downloads/sa/view/down/510/#.UDBF9KO058E)
paul and i have had many discussions on the use of patents. i tend to lean toward the use binding agrreements, nda/nca's, and contracts and it puts me at odds with him once in a while. but he is a good guy to know and a good guy to talk to, for lawyer that is.
take care.
nap
Quote from: mrwayne on August 18, 2012, 09:00:22 PM
Hello TK,
Thanks Wayne
It's funny that you put scare quotes around "application" and "granted patent" instead of around your patent.
But this Wiki says that only applications exist in the PCT, not "granted". The granting of the patent is the prerogative of the particular jurisdiction concerned.
http://en.wikipedia.org/wiki/Patent_Cooperation_Treaty
QuoteA PCT application does not itself result in the grant of a patent, since there is no such thing as an "international patent", and the grant of patent is a prerogative of each national or regional authority.[2] In other words, a PCT application, which establishes a filing date in all contracting states, must be followed up with the step of entering into national or regional phases in order to proceed towards grant of one or more patents. The PCT procedure essentially leads to a standard national or regional patent application, which may be granted or rejected according to applicable law, in each jurisdiction in which a patent is desired.
Darn those lawyers and their big words anyway. So confusing and so clear at the same time.
Now, Koalas don't always believe everything they read on the internet... but en.wikipedia.org is generally fairly reliable.
Please... .let us be completely clear. I am having a lot of trouble sorting all this out. I've been back through the entire thread and I see many references by you to a patent. I also see conradelectro and johnny874 talking about the same issues.
Do you have a granted US Patent or a granted Patent in any other country? I am talking about a granted patent, not an application, a provisional patent, an application that includes another provisional patent by reference, a PCT application, or anything like that.
Do you have a granted US Patent? Note: this is a simple question that can be answered by a single word.
It is actually illegal, I think, to claim that you have a patent when you do not -- especially when talking to investors or potential investors -- and "have a patent" means a granted patent, not an application for one or even a provisional one. In those cases you are supposed to say "patent pending" or "patent applied for" and both of these terms have restricted legal meanings as well and can't be used falsely. And if you are referring to the document containing all the hard work you and your patent attorneys did, that actual document is a Patent Application, not a Patent, until it is actually granted.
Now, LarryC in a post way back seems quite sure that you have something that is "approved". Is this the same thing as a granted patent by the USPTO?
QuoteFalse. The provisional application filed on Nov 9,2010 is under the Related S.S Application Date section of his standard Patent Application which was filed Nov. 9, 2011 and approved May 17, 2012.
http://www.overunity.com/10596/hydro-differential-pressure-exchange-over-unity-system/msg325025/#msg325025
But that latter date given by LarryC is the date of publication of the current application, as far as I can see. Can anyone give me, please, the actual link to the actual patent? LarryC's word "false" in the statement above is responding to johnny874's statement that there is only an application not a granted patent. SO you must have an actual patent, and surely the date listed is wrong? Since that's the date of your present application's publication, not an actual grant of a patent? Or is LarryC's "false" itself false?
Seriously, can you blame me for my confusion?
If you do have a granted US or other country's Patent, please give us a link, and please accept my profound apologies for being so stupid. Koalas in general are not known for our intelligence and I seem to be somewhat of a freak. But please don't hold it against me.... just give the link to the actual granted US Patent.
Tk,
Mind if I point out Mr. Travis' over sight ?
If a cylinder has 10 sq. in. (25.4 sq. cm.) and is connected to a cylynder that has 5 sq. in. (12.7 sq. cm.), what can happen is the cylinder with 1/2 the area would have twice the pressure.
If the pressure were equal, then it's static head would have twice the height.
What needs to be remembered is that we are discussing a closed system.
And this is where I say compression slows the flow, increases pressure and if discharged to the atmosphere would have a greater velocity which could perform work because of f = ma.
If it's pressure were limited to
Hi,
I've been keeping up with this thread over the last few weeks and is very interesting, even if I don't understand it all! However, Google is your friend, and a US patent looks unlikely (see attached image from link given below), certainly from that application. Wayne has mentioned improvements, so maybe there is (are) as yet further unpublished patent/patent applications (that one took 6 months).
http://portal.uspto.gov/external/portal/pair (http://portal.uspto.gov/external/portal/pair)
Application number: 13292954
Edit: Looking again though, that status is almost 6 months old... how long does it take the USPTO to get their a**e in gear!?
Just to let everyone know that I have fixed my formulas so that they are now consistent. It will take me another day to make all the corrections in the PDF and then I will republish it. Whew!
~Dennis
QuoteInput 65g lifted 6 1\2 inches
output 1 lb 1 inch
recovery,,,, 1\4 inch drop in reservoir to start and continued until bac kto start point
Centimeters, Grams, Seconds. Or, Meters, Kilograms, Seconds. Consistent, accurately measured units throughout.
How are you measuring your masses, or rather their equivalent downward forces due to gravity? To what degree of precision, to what accuracy. Are the reference marks on your tubes that you have shown, the reference marks you use for your lift? How and to what degree of precision, to what accuracy, are you measuring your heights?
I ask because INPUT WORK: 65 g lifted 6 1/2 inches... means to me that your "lift" measurement is accurate to the half-inch, or perhaps to the quarter-inch, and your mass measurement is accurate to the gram, or perhaps half a gram.
And your OUTPUT WORK: 1 pound one inch... means again that your weight is accurate to the ounce, or perhaps the half ounce, and your lift measurement is accurate to the half-inch, or perhaps quarter inch.
I am of course here talking about that mysterious topic called "significant digits" and trying to remind us all that our calculations cannot be more precise... or more accurate... than the _least accurate, least precise_ measurement that goes into them. What are the "error bars" on your four measurements that will be used in the work calculation?
Gaah. I can't use these weird mixed up units. Do you mind if I convert to SI, at least?
65 g of weight = 65g x .009807 Newtons/g = 0.638 Newton
6 1/2 inches =~ 6.5 inches x 2.54 cm/inch = 16.5 centimeters = 0.165 meter
so input work = 0.165 meter x 0.638 N = 0.105 Joule
1 pound of weight = 454 grams force = 4.45 Newton
1 inch = 2.54 cm = 0.0254 m
so output work = 0.0254m x 4.45 N = 0.113 Joule
and there is some "bouncing" or whatever, the 1/4 inch variation that you describe on the "recovery" but I don't understand your description.
So by these rough measurements and calcs, not including that last 1/4 inch of something, it appears that you are having an overunity result by about 0.113/0.105 = 1.08, about, when the expected value would be 1, or maybe just a bit less due to losses.
If I've done the math right, that is. Please.... please everybody, check my work, it's hard to punch a calculator with Koala paws, we are better at hanging onto treelimbs.
But if any of your input values, or our roundings, are in error by 8 or 10 percent ... then so can our result be. Note that if I were to respect sig digs and round according to convention the result reduces to about 0.110/0.108 = 1.02 or even less.
So, since you have this intriguing result, but your measurements may not be that precise or accurate, I'd like to see the measurement repeated if you don't mind, weighing everything in grams and to the tenth of a gram, and measuring everything to an accuracy of a millimeter. This will require some special care on your part, care that is entirely justified in an attempt to confirm your extraordinary result.
Aside: Precision and accuracy. Different things.
Precision is when all five of your shots go through the same slightly enlarged hole in the paper target.
Accuracy is when all five of those holes are actually on the center bullseye where you were aiming, not off in the corner somewhere.
They are separate things, separately controlled, corrected for, and measured. Using a millimeter ruler instead of one with markings every quarter inch will help with precision. Making sure you are starting your measurement from exactly the same place every time, and reading the markings consistently from the same viewing angle, and checking your numerical result by an independent measurement, all speak to attaining accuracy.
It should be clear that you can be precise as all get-out, but still not be hitting the side of the barn. And you can be very accurate... that is, every time you measure a foot, you get 12 inches... but you are not getting 12.000 inches by using that tape measure, are you.
So please, experimenters, strive for both accuracy and precision in your measurements, and don't try to overinflate the precision by using every digit that your calculator spits out. Your answer cannot possibly be more precise than your least precise measurement.
Also, when measurements yield results like Webby's that could be in the noise -- the imprecision/inaccuracy of measurement or apparatus vagaries, even temperature changes.... the experiment should be repeated multiple times, like at least 5 times, and the results from each trial averaged together to get arithmetic means and standard deviations. If the magnitude of the effect result is less than the standard deviation of the data, it is probably not reliable.
Finally.... sort of... .the issue of experimenter bias comes into effect. Is the measurement 0.51, or is it maybe 0.49, when the marking or needle is at 1/2? Ask two different observers, one whose theory depends on it being 0.49 and the other who likes 0.51, and you are likely to get different answers from the same trial. This is NOT a conscious process. It is called confirmation bias and is everywhere, we all suffer from it. The only way to control for it is first, to realize it exists and second, to take lots of measurements of different trials. Another way is to use a data-taker who has no stake or doesn't even understand the experiment but who can make the measurements accurately and precisely anyway.. and take lots of measurements of different trials. There are other experimenter biases as well, it's a fascinating subject and there are WIKI pages.
@AmoLago: that looks like the record from the first application which was incorporated by reference in the second one I think. It can take two or three years to get a patent granted, but if it's granted the protection goes back to the original date of filing.
Here is the USPTO official application for MrWayne's patent:
Hi TK,
That document and the one I linked to are one and the same. In fact if you click on the "Published Documents" tab, there is a link to the same page. You can tell, even from the images you and I posted...
Series Code / Serial Number = Application Number
File Date = Filing or 371 (c) Date
US Patent Application And Kind Code = Earliest Publication No.
May 17, 2012 = Earliest Publication date.
Also from the link I gave (currently under maintenance at time of writing, grrr), clicking on the "Continuity Data" tab will give you a link to the Provisional Patent filed back in 2010, from which this patent is based. Plus, if you click on the "Continuity Tab" from that Provisional Patent, it not only gives you the link back to the application we're looking at from USPTO, but alos give you a link to the PCT (WIPO) patent...
Application Number : PCT/US2011/060036
Publication Number: WO/2012/064877
None of it actually says granted though.
You'll also notice that it you search the Patent Full-Text Database (http://patft.uspto.gov/), "Travis Wayne S" returns with the above patent from the "AppFT: Applications" database search, but there is no mention of Wayne in the "PatFT: Patents" database.
Wayne, if you're reading this, and you're convinced you have an actual issued patent, I'd suggest you have a quiet word with your patent lawyers and just double check.
I have no idea at this time if Wayne has a full patent or not. It looks as if , as a minimum, he has applied for a patent. The nuts and bolts of his technology have been revealed. Frankly it is not important to me if a patent has been granted or not. Look at some of the ridiculous things that have been patented in the past. A patent is no guarantee that a thing works. I remember reading somewhere that there is a patent for a house without doors and windows. Entry and egress is by teleportation. "Beam me up Scotty." A granted patent is no guarantee that a thing works. Lack of a patent is no guarantee that a thing does not work.
TK has talked about accuracy and precision in measurement. I have to agree with everything he says. On the other hand, Webby has just returned from a vacation, and probably quoted the first figures that came into his head. He probably has more detailed measurements on record that he can quote. I believe that Wayne said Weby had achieved a cop of 148%, but I may be wrong. Also Webby said that he built this rough model to help him learn to build a better one, and it is already giving him problems, even though it is the best replication built so far. Having said all that, Webby is more than capable of speaking for himself.
Quote from: AmoLago on August 19, 2012, 05:21:44 AM
Hi TK,
You'll also notice that it you search the Patent Full-Text Database (http://patft.uspto.gov/ (http://patft.uspto.gov/)), "Travis Wayne S" returns with the above patent from the "AppFT: Applications" database search, but there is no mention of Wayne in the "PatFT: Patents" database.
Thank You,
No - I am very clear where our patent stands - this discussion has been someone else's misunderstanding of my statements.
Since this is not part of the discussion of understanding the system - I would normally ignore it - but since it also is a natural step in the process of "Realization" I will cover it further.
Now:
This was TK's concern and question. I am learning from his efforts and questions - that is a gift from him and this site.
We are doing all of our due diligence - all of it - rest assured.
The patent question was hammered a while back - the last time it was claimed that anyone could file for $500 means nothing to have filed.....(my position was well understood and clear) My response was the same as it is today - except I said our cost $38,000 - it is rising.
Then - an attack - not for clarity - I was attacked for only being in the application process as if that was nothing - it is true you can file a $500 patent for something that does not work, but when you have something that does - you better do it right.
I am sure most understand Patenting is a process and progression - as I said before - I will learn from this forum to be even more careful. I do not think TK was trying to assert anything just digging for clarity.
Observation:
I also understand and have seen this many times now - The move from "does it work" to questioning the Patent always comes after "one" realizes the validity of our design - It is of course the first question interested partnerships ask - to protect their own interests.
Who wants to deal with an inventor if he does not have control of his own invention. It is also followed by some who might be unscrupulous - Sadly - part of due diligence - we are prepared for that as well.
Another point - legalese - I have not offered to sell anything here - and when a private question is asked - I carefully review the control and ownership - in all aspects - this forum is not the place for said discussions.
What I will offer in the discussion of Ownership and control:
The inventorship has been clearly established: Travis, Wayne S.
The Proper and Due diligence has been properly processed in good faith and order. Time stamps - art work - and concept have been cataloged - as well as the rest.
This invention is unique - simple yet extremely complex - it is not an improvement - it is not a reapplication of an old technology - original concept.
Finally - it works - it is not a Application in vain.
We are on track - the patent application has been accepted - and it is a process - a very expensive and long process.
And yes, our improvements are being taken care of properly and legally.
As I have said before - we have very carefully protected and researched the IP,
I have stated our position here, We are well covered.
To All,
We have worked very hard to protect the invention so that we can make sure the Energy Device gets to the market.
Not to stop others from helping bring the technology to their respective areas - but to ensure we have legal grounds to partner
with Win - Win - Win organizations.
A win for the organization who manufactures, distributes - a win for the consumers - and a win for the investors.
We are also very well prepared to challenge anyone who tries to step on, or stop - our mission is to be the group you would love to do business with - to be supportive and to make it a poor business decision to try to side step us.
Some will anyway - so falls that part of the world.
Now worries - it is a world with plenty of energy needs.
We will bring this Clean Energy forward, you can see the lights and breath fresh air, soon.
Wayne Travis
Quote from: TinselKoala on August 18, 2012, 10:33:52 PM
http://www.overunity.com/10596/hydro-differential-pressure-exchange-over-unity-system/msg325025/#msg325025 (http://www.overunity.com/10596/hydro-differential-pressure-exchange-over-unity-system/msg325025/#msg325025)
But that latter date given by LarryC is the date of publication of the current application, as far as I can see. Can anyone give me, please, the actual link to the actual patent? SO you must have an actual patent, and surely the date listed is wrong? Since that's the date of your present application's publication, not an actual grant of a patent? Or is LarryC's "false" itself false?
Your are correct in that I was mistaken in saying approved May 17, 2012, should have been publication date May 17, 2012.
But lets check Johnny's statement and my response:
Wayne,
You have intentionally misrepresented yourself in this forum. That is plain wrong !!!
To wit, you have a provissional patent. This is not to be confused with an actual patent.
What are the differences ? Namely a provisional patent requires no examination which you claim to
have been subjected to. Seriously, lying like that is not good. Would you like me to show you the post ?
A provisional patent costs $110 and is given just for paying the application fee and submitting a 2 page form.
The purpose of a provisional patent is to help inventors who might wish to market their invention while having
the protection of a PROVISIONAL patent. It requires no patent search, examination or any demonstration of
being an actual invention. The inventor(s) is given 1 year from I believe the filing date to convert the provisional
patent to an actual patent which would require going through the complete patent application process which you
claim to have done. Shame on you !
Johnny,
You seem to be just looking to spin any point to attack Wayne.
I was correct in pointing out Johnny's false assertion that it was a provisional application.
Your statement:
LarryC's word "false" in the statement above is responding to johnny874's statement that there is only an application not a granted patent. You should have stated
'provisional application' and not just the misleading
'application'.
Larry
Quote from: LarryC on August 19, 2012, 09:08:28 AM
Wayne,
Johnny,
Your statement:
You should have stated 'provisional application' and not just the misleading 'application'.
Larry
Larry,
I do remember that conversation now: Who was that that made the fasle charges? The way you quoted it - I thought you were yelling at me lol.
I think the real question is:
If someone was interested in getting involved - to help Wayne and the ZED, are they helping the right inventor.
Asking TK is a hands off apporoach - yet they need to know what is the exact position of the protection - be it all forms of IP protection.
It is a business question: should not be covered "here" - in my opinion.
You are right - the last time this was brought up - it was an intentional misleading attack - and you corrected the attack then.
I believe TK is asking questions for others' sake - and brings clarity.
His drag-it-out-in-the-clear method - is dogmatic - just don't take it wrong.
Thank You
Wayne
mr. travis,
bottom line is that I believe you are claiming hydraulic theory allows for over unity. it doesn't.
even though you can generate a taller static head with more psi, psi times surface area would equal static heads that have the same potential to do work.
a sinkable float would generate energy without accepting someone's word that when they manipulate a static head that it's a new discovery. it's not.
Quote from: johnny874 on August 19, 2012, 09:36:16 AM
mr. travis,
Thank you for being civil this round.
You are welcome to 'believe' - for or against.
Good day.
@All,
a simple test anyone with 2 pressure gauges can do.
Connect a 3/4 & a 1/2 inch tube (the 1/2 in. tube wil fit inside the 3/4 in. tube) and put water in them then cap them with the pressure gauges,
Then pressurize th larger tube. You will see tbat the 1/2 in. tube will have more psi.
Then multiply the psi by surface area for both tubes and you'll see they have the same answer,
And as far as patents go, they're pretty much worthless if the invention doesn't work.
And if Mr. Travis invention does work then maybe he could give a simple demonstration like I just posted and then send it to Stefan since everyone would accept his word for varifying Mr. Travis' claims.
MrWayne, thanks for the reply, and I'm glad that you, at least, aren't misinterpreting my intentions like some others seem to be doing.
The patent discussion, from my part, isn't about the intellectual property protection, the filing dates, the difference between "provisional application" and "application" or any semantic argument like that. It is simply about getting straight answers to straight questions, and yes, drawn out not just for me but for everyone else whose vision might also be a bit cloudy when viewing the "fine print".
And I think Webby's work is fine, and certainly if I were doing it, I'd be reporting my best numbers, not a random set taken casually without controls, so I believe that he's doing the best he can do under the circumstances.
What my calculations show, IF THEY ARE CORRECT.... is that his gain is small, small enough so that minor imprecision in measurement and/or general experimental technique could account for the COP>1 finding.
And, since this is so very important..... the first demonstrated overunity work-producing device that doesn't need a battery or a big flywheel and can be made in an afternoon and demonstrated in anyone's lovely back yard garden -- no machining or fancy tools needed ..... and that would also overturn not just our ideas about buoyancy but also, like, the past 200 years of physics knowledge and require all the textbooks, from 10th grade on, to be rewritten.... sitting there on Webby's garden furniture, made out of tennis ball packaging tubes....
Well, we need to be absolutely certain that the measurements are precise, accurate, and properly obtained, as well as repeatable on demand, don't we?
And I myself would LOVE to be the principal or second author on the first scientific paper in a journal like Science or Nature or PhysRevB that brings the effect to the attention of real scientists around the world.
I should think that with 2 large to play around with, one could make a precise, rigid, easily measured, model that didn't leak and had some simple automated data collection capability. Certainly I could implement such a system.... I'd use a USDigital linear optical encoder setup to monitor heights to the half-millimeter, velocities and acceleration etc. of moving parts (3 or 4 hundred dollars), a good sensitive digital scale for weights (under 100 dollars), and something like an Arduino for automated data collection and recording (under 100 dollars), in addition to the basic apparatus made out of polycarbonate tubes from a plastic supply house (certainly less than 200 dollars). I'd borrow or rent a good force gauge like the Mark-10 M5-05 that I have sitting here gathering dust, get a couple of sensitive piezo pressure gauges ... And I'd have enough left over for a nice little vacation after I proved, repeatedly and well above noise floor, that I was making more work out than I was putting in. Did you know that Koalas are great bass fishermen? I'll bet you didn't.
But I realise that Koalas generally approach problems like this differently than most people on internet forums do.... it comes from living in a tree and eating eucalyptus leaves (which are a little hard to get in South Texas, believe you me).
any working perpetual motion machine or overunity device would be able to run contiuously under it's power.
@TK. I am probably one of those people who appeared to question your motives. However appearances can be deceptive. I have already said that I endorse your insistance on precise measuring methods. I would ask you to bear in mind that we are all different when it comes to abilities and resources. When I say that, I am not complaining, just stating a fact. You obviously have measuring equipment, and probably machine tools, and the abilities to use both. My hope is that you will , sooner or later, be sufficiently convinced of the reality of this technology, to do your own build. I realise that you are involved in other things as well.
Quote from: johnny874 on August 19, 2012, 12:56:16 PM
[/quote
Whilst this would be the ideal situation, a machine does not have to self run, to prove OU. If it can be proved to be OU by a sufficient margin, a feedback loop can be added later.
Quote from: webby1 on August 19, 2012, 12:46:19 AM
WHAT do you want me to talk about M.
Anything and everything you observe, measure, notice, etc., while poking your TBZED.
When you want to.
Sorry if I interupted any testing!
M.
Just saw this on a table upstairs and could not resist.
I hope everyone is having a wonderful weekend.
M.
Grandma!! We've found you!! Please write, we miss you.
--Tinsel
@neptune:
Thanks, and you are right. I don't mind tough and realistic challenges to my skeptical position and work; constructive criticism and real refutations of what I might say or believe or do are fully welcome and I +especially+ need others to check my maths... can you imagine working a calculator with claws like that?
You will eventually encounter my very own personal troll though, who manages to sully just about every thread I post in, yet is never able actually to refute anything with checkable facts, outside references or his own demonstrations.
I only lack one thing to be able to put my full skillset and resources onto this issue, and anyone who knows me will confirm that I do NOT need to be convinced of the reality of anything before I start building and investigating on my own. In fact, like Inspector Morse, I don't have theories... just questions.
-TK
(And.... like Inspector Gadget, another of my personal heroes ... I might have one or two tricks up my sleeve.)
@Webby, thanks for the description, it sounds like you are having fun.
But.... come on. You have on your table a device which has the potential to overturn hundreds of years of real scientific research and theorising, theories that have so far worked well enough to design sophisticated hydraulic systems and even submarines. But if MrWayne's device, and yours, actually make more work out than in, all that will have to be rethought, especially that fundamental law of thermodynamics that results in Conservation of Energy being taken as gospel all over the world and for many many years. Entire careers of scientists and educators will be rendered null and void, textbooks will have to be rewritten, and more. I don't think that a person who is not trained in the "hard" sciences like physics or engineering mechanics can fully realize what a truly revolutionary thing this is if it actually works.
So... it's pretty important, I think, to get good reliable and repeatable measurements from a known configuration of the apparatus, with good recordkeeping and so on. Any measurements must be as accurate and precise as the setup and our experience allows in order to know that we aren't fooling ourselves and so that this revolutionary system will be believed by others.
I wish I could tell you how to improve things to make them easier to measure. The very first thing I'd recommend is a good digital scale in the weight range you need. Even if it only measures accurately to a gram of precision, that will be better than what you are using. The scale I used in the "virtual water inverted TE" video cost about 20 bucks from Harbor Freight and is accurate to the gram, and I've got a mechanical Harvard trip balance with a calibrated precision weight set for comparison, so I do know the accuracy and precision of that cheapo scale are usable for this purpose. (The OHaus Harvard Trip Balance has a capacity of about 2 kilos and can weigh reliably down to the tens of milligrams if I hold my breath and use tweezers for the tiny weights. I found it at a Goodwill store, along with the precision weight set.... for twenty dollars. ) Next you might try the Dollar Stores looking for transparent plastic rulers with cm and mm scales in the school supplies section.
Thanks for doing the hard work and for your willingness to put yourself out there and sharing.
--TK
(Eta: a tenth of a pound is 45.4 grams, so a scale that's precise to the tenth of a pound still leaves a lot of room for error.)
Hi All,
While reworking my PDF today, I realized that I could combine some of the formulas and simplify the technical formula portion, so I am taking another day to make it easier to read, and also simplifying my sim in the process.
~Dennis
Quote from: see3d on August 19, 2012, 11:38:41 PM
Hi All,
~Dennis
You were reading my mind ;7) - I had a chance to have a closer read of your pdf this afternoon - I have some clarifications required if you don't mind.
First some housekeeping :
1. Neptune .. you were correct IINM - Mr Wayne did say 148% advantage in Webby's build - he said it was from private correspondence between the two.
2. There seems to be some disagreement about whether the ZED is a pneumatic device or a buoyancy device, or both - both Mondrasek & Larry said in the multi U tube analysis that the mediums could be different density fluids like water & lower density oil or water & higher density mercury, rather than water & air, & show the same buoyancy potential & energy advantage in the output.
My feeling is that if an internal air pocket is used then it will transfer pressure - at the same time it will compress its volume somewhat & store PE to be returned later as KE [the spring analogy] once the riser is released & as the head increases - this would be a partial pneumatic element - but we know the energy input to compress a gas & increase its density & pressure is equal at best to its output potential.
If different density fluids were used [virtually non compressible] then this pneumatic spring effect is eliminated & it is wholly a hydraulic/buoyancy device where pressure changes by an increase in head determined by volume transfer from piston water packet to riser cavity volume etc - this volume transfer determines the stroke length & variable power of the stroke, IINM.
It seems apparent that the current internal air packet can transfer pressure from the H2 height to the piston height & that the air packet pressure will be practically the same as the H2 head [this is the startup position of the cycle].
Generally in sim world it is convenient to know the mass of parts & the system CoM as a point mass equivalent - the work done joules to complete half a cycle [the drive portion] is the increase in PE of the CoM from the start datum - this is the input energy with no losses, viscosity etc, so it is optimal.
N.B. it appears in your sim diagrams that the H2 level is quite a way up the side of the riser wall indicating that the system is in equilibrium i.e. the riser is floating at this start position where upthrust equals apparent weight force.
The system should then reset itself back to datum levels & give back the joules of energy PE gained.
Further observations & comments needing clarification :
1. the work done to raise the piston is by providing a force N.B. pressure is force / area therefore force = pressure times area - so the input force could be provide by a hydraulic piston, for example, which is well known.
2. the H2 to piston head depth determines the pressure head.
3. as the piston is forced upwards the hydrostatic pressures internally change - not only are there upward pressures acting on the all the riser parts [some of these can be combined], but also as the H2 levels rises in height proportional to the volumes transferred, & the hydrostatic pressure acting downwards on the piston increases [this is the hydrostatic paradox] - this increase in hydrostatic pressure acting downwards must be overcome & included in the work done input [I didn't recognize it in your net force formula's & diagrams].
In conclusion FWIW I currently see this sim as fundamentally a hydraulic/buoyancy system because any air compression [i.e. reduction in air pocket volume] reduces the stroke height until that PE is given back & the air expands again.
I'll be looking into it more closely as time allows but these are my initial off the cuff comments.
@Webby... thanks for your kind offer, but please don't consider sending me anything you've built. I can't handle that kind of responsibility! Golly, what if the world's only portable OU device gets dropped by UPS or something...
I'll tell you this though: if you have an easily portable system that you can set up on a table and demonstrate more work out than in, reliably and repeatably, no matter how small the gain as long as there IS gain.... then I can "walk it through" at a laboratory that I know and trust, will full IP protection for you, MrWayne, me, and so on. And a positive word from these people will go a long way.
So my advice would be this: get to building. Build a better, more stable system just like the one you've got now -- not too many design changes, since this design works, right? -- but without leaks and wall friction/interference, and test it by making good precise and accurate measurements. When you see consistently more work out than in, and are confident that it will travel, I'll PM you the information about the lab and the personnel there and you, and MrWayne, can decide whether or not you want some official, hard-science types to confirm your discovery or not. My role will then only be that of the "arranger", all the testing and evaluation would be done by them. Am I talking about ETI? I could be. I could also be talking about SwRI: Southwest Research Institute, located in San Antonio.
https://www.google.com/search?q=southwest+research+institute (https://www.google.com/search?q=southwest+research+institute)
From the Wiki:
Southwest Research Institute (SwRI), headquartered in San Antonio (http://en.wikipedia.org/wiki/San_Antonio), Texas (http://en.wikipedia.org/wiki/Texas), is one of the oldest and largest independent, nonprofit, applied research and development (R&D) organizations in the United States (http://en.wikipedia.org/wiki/United_States). Founded in 1947 by oil businessman Thomas Slick Jr., SwRI provides contract research and development services to government and industrial clients.
The institute consists of 11 technical divisions that offer multidisciplinary, problem-solving services in a variety of areas in engineering and the physical sciences. More than 2,000 projects are active at the institute at any given time. These projects are funded almost equally between the government and commercial sectors. At the close of fiscal year 2011, the SwRI staff numbered 3,046 employees and total revenue was $581 million. The institute provided $6.1 million to fund innovative research through its internally sponsored R&D program.
A partial listing of research areas includes space science and engineering; automation, robotics, and intelligent systems; avionics and support systems; bioengineering; chemistry and chemical engineering; corrosion and electrochemistry; earth and planetary sciences; emissions research; engineering mechanics; fire technology; fluid systems and machinery dynamics; and fuels and lubricants. Additional areas include geochemistry and mining engineering; hydrology and geohydrology; materials sciences and fracture mechanics; modeling and simulation; nondestructive evaluation; oil and gas exploration; pipeline technology; surface modification and coatings; and vehicle, engine, and powertrain design, research, and development.
SwRI initiates contracts with clients based on consultations and prepares a formal proposal outlining the scope of work. Subject to client wishes, programs are kept confidential. As part of a long-held tradition, patent rights arising from sponsored research are often assigned to the client. SwRI generally retains the rights to institute-funded advancements.
The institute’s headquarters occupy more than two million square feet of office and laboratory space on more than 1,200 acres in San Antonio. SwRI has technical offices and laboratories in Boulder, Colorado; Ann Arbor, Michigan; Warner Robins, Georgia; Ogden, Utah; Oklahoma City, Oklahoma; Rockville, Maryland; Minneapolis, Minnesota; Beijing, China; and other locations. The institute also provides environmental monitoring expertise at munitions disposal sites at the Umatilla Army Depot at Hermiston, Oregon, and the Pine Bluff Chemical Depot at Pine Bluff, Arkansas.
SwRI’s mission statement is, "Benefiting government, industry and the public through innovative science and technology." Two of its core values are independence and impartiality.
@Webby... it sounds like what you are describing is a system where constants aren't, and variables don't !!
(old science joke, sorry)
--TK
Verge Archemedia Labs Llc
3708 Spicewood Springs Rd, Austin, Texas 78759
(512) 418-9988
and
Overunity Laboratories Inc 8905 Bluegrass Dr, Austin, Texas 78759
(512) 342-0522
Quote from: fletcher on August 20, 2012, 01:39:45 AM
My feeling is that if an internal air pocket is used then it will transfer pressure - at the same time it will compress its volume somewhat & store PE to be returned later as KE [the spring analogy] once the riser is released & as the head increases - this would be a partial pneumatic element - but we know the energy input to compress a gas & increase its density & pressure is equal at best to its output potential...
Fletcher,
Thanks for taking a look. I think your observations are along the same lines that I have been zeroing in on. I think it will be easier to follow in my revision PDF that I should have updated later today.
I see the Piston transferring PE through H0 to the compressed air and through H1 to H2. I think the net effect is that H0 and H1 heads are effectively stacked on top of each other as has been stated by others. I think my latest formulas will represent the various internal heads and pressures in the system.
However, I have struggled with exactly which elements to include as net lift for the output.
I can now see the PSI of the water at the bottom of the Pod area as one. The PSI of the water at the bottom of the Riser Wall area as another. However, that gives a lift force that is less than a straight Archimedes un-convoluted riser. The Riser air pocket area is not included, but somehow I think it needs to be. If I include the raw airPSI in that area as part of the Riser lift, the total lift number becomes unbelievably large.
So my dilemma has been which potential areas of lift are to be included. My current sim has every potential lift calculated and included on separarte lines so I can comment out each one to see the overall effect. I have not found any combination that feels right yet. Perhaps it is all in the stacking of the heads, and I will have to get into multiple internal layers before the ZED catches up and passes simple Archimedes.
You mentioned counteracting forces to the lift that you did not see me taking into consideration. That was the basis of my original force calculations where I did not include forces that were relative to the Piston, but did include forces that were relative to the Tank. This is the area that I think needs more conceptual work.
http://physics.kenyon.edu/EarlyApparatus/Fluids/Hydrostatic_Paradox/Hydrostatic_Paradox.html
It has nothing to do with overunity nor with surface instead of volume;
Buoyancy is still concerned by volume: one should take the right system into account:
1/ without insert
2/ with insert
in 1/ the glass with small volume of air will naturally have a weak buoyancy.
but in 2/ the glass and the insert are partially forming a global system: so you should consider the global volume of moved water: by air + partially by insert, since there is a direct contact inbetween, without water anymore.
Then it is said that global application point of buyancy is the centre of gravity of moved water. It's correct as a resultant force, but if you consider each differential bit of external surface, then you see that a big part of the surface submitted to the buoyancy force is ...the glass. So, the glass has partially "stolen" the buoyancy force of the insert.
There is no magics nor overunity ! ;)
Quote from: dgouttman on August 20, 2012, 11:13:57 AM
1/ without insert
2/ with insert
Hello DG,
No "magic" is right!
Thanks Wayne
First Picture: 3 U with water levels set to account for the air compression.
Second Picture: Calculated values for 3 U, with air compression calculated by SI of air channel.
Regards, Larry
Quote from: webby1 on August 20, 2012, 12:38:12 AM
I have intentions to build a better unit, more precise and all that BUT I am hoping that other builders out there, and you know there are more, will be willing to come forward with results in line with what I have.
Hello Webby,My team is currently planning the build for our desk top self running water pump.
I would love to see your teams creativity with the ZED technology!
How about a new challenge for you and your team..a $5K ZED challenge.Specifically designed by your team to ease measurements of input and output.
Two single five or six layer systems will do, or a combined system.
It does not need to be transparent.
Weight of the riser is not an issue works as a counterbalance - steel, aluminum may be used.
The risers may all be attached to one lid.
The system needs to be able to be measured and have access to each layer (tubing both air and water).
Part two: $10K ZED challenge ----5 layer, dual Z.E.D. water pump. If your design team connects the system together for a self runner - I will double the 5K Challenge to 10K.
and each member of your team will receive a HER ownership certificate - valued at the current valuation and equal to the prize.
Five members max - pick them wisely.
Suggestions:You do not have to beat our team - but time is important.
plan on 1/4 or 1/2 inch gaps between risers and ring walls - will work fine.
If you start with a pumping system and then size accordingly - a lot of time is saved.
The previous expectations apply - after a reasonable time of testing and reporting - you must send me the units, you are welcome to make an authorized extra set to keep for yourself.
Placard with your team members name and the name of the device Zydro Energy Device on all systems made.
What do you think? Up to it?
Wayne Travis
Quote from: see3d on August 20, 2012, 08:35:06 AM
Fletcher,
Quote from: see3d
Agreed - because of relative densities the H2 vertical height determines the pressure head in relation to depth to piston face.
If we assume that the starting configuration [when H1 = H2] is also when the
system is in equilibrium [all forces are equalized] then this sets a datum to launch & calculate from - we have to make some assumptions - one would be that the H1 H2 water levels are equal & that there is a communication channel between these two water towers that allows the water to find the same level both sides of the riser wall divide - from that we can assume that the internal air pocket was once of greater volume & at atmospheric pressure but now it has a slightly lesser volume & its pressure is at least the same as the bottom of the H1 H2 towers [which is above 14.7 PSI or 1 atmosphere] - in essence the air pocket can be thought of as a flexible rod that transfers the pressure at bottom of H2 to top of H0 - N.B. if the air pressure were greater then we would not see the Bottom of H1 H2 & top of H0 at the same levels.
Effectively the air pocket is a pressure communication medium & the head height is calculated from the top of H2, IMO.
The conclusion is that for the riser to be in this position in the equilibrium state [with effectively water climbing the sides] then although the riser may be hollow its density is such that it raises the H2 level to where the cycle starts from [in equilibrium] - also that the pressure at ANY vertical height measured will be the same at any horizontal line taken in the system.
Quote from: see3d
See above - I would say that because of relative densities of the two mediums that we are only concerned with the H2 level for calculating pressure head height.
Quote from: see3d
So my dilemma has been which potential areas of lift are to be included. My current sim has every potential lift calculated and included on separate lines so I can comment out each one to see the overall effect. I have not found any combination that feels right yet. Perhaps it is all in the stacking of the heads, and I will have to get into multiple internal layers before the ZED catches up and passes simple Archimedes.
See end comments below.
Quote from: see3d
Hydrostatic paradox examples
http://scubageek.com/articles/wwwparad.html - what it means is that there are no free lunches - so if I increase head height by increasing water level height by moving only a small volume so that the system center of mass [CoM] doesn't change much at all I do increase the force [i.e. pressure] on the bottom of the tank/piston face in your sim - the effect of this doesn't seem apparent until one considers a system where a piston is used - the relative pressure levels felt at every vertical level will try to force apart two objects, one of which one is moveable.
General Comments:
Sims are very useful tools, for predicting outcomes, if constructed accurately - as you know their usefulness is many fold - mainly that once a sim is relatively accurate dimensions & other inputs can be changed at will & the outputs will fall out the bottom - this is way less time consuming than building multiple real world builds.
The other main advantage is that they can then be compared & normalized to a real world build so that the sims behaviour mimics the real world build closely making the sim a reliable predictive tool - then improvements in one can be retro'ed to the other in a leap frog progression.
They have one great advantage over real world builds & that is as you work thru the components & formula's & insight grows they can be simplified dramatically - simple is good - when they are accurate & you have confidence in the sim then complexity can be added.
In your case I can't immediately see how to simplify the setup further because you must have an internal air/lower density fluid pocket - however, as a step in the right direction of simple analysis you can make the assumption the the air pocket is a non compressible fluid the same density as air - then see if the sim behaves as you think it should & you have accounted for all the relevant forces contained in the pressures etc - you can add complexity later by changing the non-compressible pocket fluid to compressible air [a fluid] & compare the sim outcomes for major differences - you can also add drag losses from vortices & eddy's & viscosity differences but they aren't that important just now.
The primary purpose here is to isolate the ingredient that allows for OU as Mr Wayne asserts is the case - to do that you have to test the systems integrity component by component - if it is the air pocket that makes all the difference then this will be self evident in the sim comparisons & you can delve deeper to find out why.
N.B. One of the easy ways to formulate buoyancy force is volume x density x - gravity acceleration - effectively this is a reverse approach where water volume displaced weight force is the upthrust force.
In more complex cases like you are looking at here this simple approach may not be adequate - buoyancy is actually a factor of sum of pressure forces on a submerged object less the effect gravity has on it downwards.
In the ZED sim the water pressure is artificially increased by moving only a small volume of fluid - so a different formula is required that calculates buoyancy force on pressure differential rather than the ubiquitous volume displacement usually used.
ATEOTD, Mr Wayne has said that the energy advantage comes for gravity not being a conservative force after all - we know that atmospheric pressure & air density is gravity dependent as is pressure of practically non-compressible fluids - so in essence they are both direct artifacts of gravity in traditional thought.
I know you have started from the position of having an open mind & you show that you are intelligent & capable to work this sim thru logically - I'm here to discuss that logic - perhaps there is such a thing as a free lunch after all ;7)
P.S. I'm not trying to teach anyone to suck eggs, just simplify, identify & follow logic paths - on that note, to Larry, I only have dial up speed internet so I haven't been able to view any pics for a few weeks - I have to rely on good & clear verbal descriptions of what pics show, what the calcs were based on, & what the conclusions were.
Good luck Dennis !
P.S. there may be out there someone who knows of or uses a good sim program that can handle hydraulics & changing volumes & pressures who could replicate against your sim for comparison.
Have vistors for several days. Today went to the new Infinity building at Nasa Stennis Space Center in southeast Mississippi right across the Louisiana border, and a tour of the Nasa testing facility. If you get a chance to go, it is well worth it. I've attached a picture of a statue at the entrance made of wood and metal parts from past missions and is 33 foot tall. It was very movating and inspiring. Enjoy.
Regards, Larry
Quote from: fletcher on August 20, 2012, 05:53:21 PM
You are missing a lot of understanding, if you cannot see the graphics. As the old saying goes, A picture
is worth a thousand words. Please go to a Library, University, coffee shop, friend, etc. to get access. Your knowledge can be helpful and there is no way that my words can clear up what I am showing.
Regards, Larry
Maybe you just need to try different liquids.
http://www.youtube.com/watch?v=OS1KXMsE2qk
Thanks for the advice.
I get what you are saying about the 3 U devices & that the last far right column of water is raised up - this 'leans' on the air pocket to the left [which was at 1 atmosphere & greater volume] & this ripples back to the piston face which has a comparable head pressure to the single U column.
The point that was being made at the time [by myself & TK in particular] was that this pressure head was useless in this format, that it didn't show an increase in buoyancy potential or energy advantage - that was because the piston was displaced downwards by a force [work done joules] & the net effect was that the far right column of water was raised - the WD Input not only had to equate to the raising of water mass but also to counter the change in PSI at the piston face - the actual Work Output that could be done by this system was exactly like a hydraulic jack [Pascal's Law re force multiplication, not energy/work multiplication] i.e. the pressure at the right side [not left] x distance of stroke.
Perhaps you could assist greatly in explaining how the forces & pressures should develop in see3d's sim so we could actually see how that energy advantage [OU] manifests into sim & real world reality by way of his force & pressure derived sim built with accuracy of formula's & logic.
Quote from: fletcher on August 20, 2012, 06:55:04 PM
@Fletcher, you are at a significant disadvantage if you have a slow internet that makes pictures difficult to download. I show my work and think almost exclusively in pictures. You must be a very intelligent person to be able to get as much as you have without the pictures. Were you able to download my whole PDF with pictures?
My sim baseline level sits at the bottom with zero H0, zero air pressure (atmospheric), and H1,H2 at the same level. The riser is counterbalanced mechanically as is the piston and water in the pod area. The system starts out in a "relaxed" state at the bottom with only a 1% of design output load weight sinking it. It is a very easy state to understand as a starting point for the sim. Then a design load weight of 1 pound is applied on top of the Riser. Then an input force is applied to the piston via a 1 pound weight applied to a mechanical lever. Life does not get much simpler than that for something to sim and physically measure accurately. I am really designing it as a science experiment for the purpose of easy accurate measurements. Making a single ZED free run takes a little more Rube Goldberg mechanical ingenuity.
@All, I would be very happy to get additional math-a-magic formulas for improving my sim. I believe I have the water heads and air pressures right now. I need to get the lift forces correct next.
I may have to do my own super simple 1 layer "tin can" build to check my sim against some real world measurements -- since nobody seems to have built a 1 layer test setup. I am keen to get the super simple 1 layer sim correct before extending it to multiple layers. The more layers, the harder it is to physically verify all the dimensions and pressures. A 1 layer system can literally be done with tin cans or plastic bottles or a combination of both.
I have my own independent build interests with Wayne, but I would be happy to use my "improved" sim to provide design optimization ideas for a build here. That was always my intent in sharing what I am doing here.
I am going to take a little more time before finishing my PDF for release again. There is a lot of work in regenerating all the pictures and animations which are no good if done with the wrong output force calculations. I am in search for a bit more understanding about the proper concept for this output calculation. Perhaps in another day I can feel more confident about what I have. I would like it to be in the ballpark before a tin can build, so I can make it able to differentiate the various forces unambiguously.
Quote from: webby1 on August 20, 2012, 07:34:21 PM
Some info from my risers.
dry weight sink mass
90g 270g outside
18g 294g
21g 196g
16g 143g
12g 85g inside
Totals
157g 988g
the sink mass was determined by placing each riser in an open container of water and filling a cup up, that was placed on top of the riser, until the riser just broke the surface of the water.
The max lift to date that I have had, and moved, is 1204g that was with 19 3\4 inches of "head" into the pod chamber.
Thank you for sticking to grams. I assume that your scale like mine reads to the nearest gram, that's fine with me. Can you also give a volume for the risers taken from measurements of their dimensions? This will be a crosscheck on the density information contained in your present data set.
Now, if I am understanding you correctly, you are pushing the risers into the water until they are just fully submerged, holding them down with the weighted cup, and then weighing the cup to see how much weight is needed to hold them there? Is that right? So you are getting a measurement of the upward force of a just fully submerged riser. Right?
And I think that your risers are open on the bottom, right ? So that there is air trapped inside of them, and also that the volume of this trapped air will be variable depending on the external pressure, right? Like a Cartesian diver and _not_ like a sealed and constant volume. Am I still on track?
Could you please test one thing, and see if the depth of submergence has any effect on the "sink mass"? I mean, push the riser further under the water-- try to use a deep barrel or something like that-- with a thin rod (little displacement or buoyancy of its own) and balance the weighted cup in air on top of the rod, and see if the cup needs to be heavier or lighter to "sink" the riser or hold it down at your test depth. Don't forget to include the weight of the rod and its submerged volume -- I think this should be added to the dry weight and volume of the risers.
Also... how far did the 1204 g weight move, and how far did the water head drop when the weight was at its full travel?
I'm trying to figure out a lowfriction lightweight way to keep risers and stationary walls concentric without adding drag and of course with allowing air and water to pass freely. I'm envisioning something like a Teflon "star" or "gear" with teeth pointing out and in, like a ring, that can slip over the inner tube and ride between it and the outer tube smoothly with loose clearance, preserving the interwall spacing and keeping everything concentric.
I know how I'd do it if I had my shop set up, but I'm looking for ideas for something cheap or free, easy to make, and adaptable to most any design that people are working with.
Hey See3d
Nice work. Does your simulation show the 'air' as compressible? Like when it is under pressure does it occupy less space, as compared to the water?
MaGs
Hydrostatic paradox examples http://scubageek.com/articles/wwwparad.html (http://scubageek.com/articles/wwwparad.html) - what it means is that there are no free lunches - so if I increase head height by increasing water level height by moving only a small volume so that the system center of mass [CoM] doesn't change much at all I do increase the force [i.e. pressure] on the bottom of the tank/piston face in your sim - the effect of this doesn't seem apparent until one considers a system where a piston is used - the relative pressure levels felt at every vertical level will try to force apart two objects, one of which one is moveable.
Fletcher,
Thanks for that link about the paradox. In fact, I missed this in the currently released sim PDF. It was the reason I had to rework the formulas. I got caught in the paradox and tried to ratio the difference in area of H1 and H2 in the PSI calculations. I fixed it without understanding this old paradox. I had to rediscover it on my own through the math... LOL
Quote from: TinselKoala on August 20, 2012, 08:48:51 PM
You might glue 3 or 4 thin triangle shaped vertical plastic strips to the outside of the riser or inside of the tank outer wall.
Quote from: Magluvin on August 20, 2012, 09:05:39 PM
Hey See3d
MaGs
Yes. I also make the air darker grey the more it is compressed to see it happening.
Quote from: see3d on August 20, 2012, 08:35:32 PM
@Fletcher, you are at a significant disadvantage if you have a slow internet that makes pictures difficult to download. I show my work and think almost exclusively in pictures. Were you able to download my whole PDF with pictures?
Yes, I was able to download the pdf [it took some time] - whether I can see pics posted on the forum or not depends on the day & hour sometimes, especially when demand is high - currently my service is throttled right back because my month plan was exceeded some weeks ago - nevertheless I can usually see some of a picture [or none at all] so a descriptive of how formula's are made & conclusions reached in clear terms are appreciated to aid understanding.
Quote from: see3dMy sim baseline level sits at the bottom with zero H0, zero air pressure (atmospheric), and H1,H2 at the same level. The riser is counterbalanced mechanically as is the piston and water in the pod area. The system starts out in a "relaxed" state at the bottom with only a 1% of design output load weight sinking it. It is a very easy state to understand as a starting point for the sim. Then a design load weight of 1 pound is applied on top of the Riser. Then an input force is applied to the piston via a 1 pound weight applied to a mechanical lever. Life does not get much simpler than that for something to sim and physically measure accurately. I am really designing it as a science experiment for the purpose of easy accurate measurements. Making a single ZED free run takes a little more Rube Goldberg mechanical ingenuity.
My purpose in labouring the point [sorry for that] about the system starting in equilibrium has everything to do with "previously understood to be" conservative gravity, the cornerstone of Mr Wayne's claims.
N.B. when a system where gravity is the prime mover is
In Equilibrium of forces it is ALSO in its position of
LOWEST Potential Energy - it can not get anymore 'relaxed' than that - if it can lower its system CoM even further it is not at equilibrium.
The only way that you can test whether your sim conforms to the real world is to build a model in that same position of lowest PE & check the water levels etc.
Then you can be confident that the system isn't 'loaded' in some way which would need energy to restore it to.
I don't think your sim needs counterbalancing of riser & piston water volume/mass - like I said any movement of the piston which lifts any portion above it will be given back later to achieve reset i.e. zero sum energy wise - however the WD to cause the piston & its load to rise can be quite easily found IINM.
TK .. a suggestion - ball bearings or bb's made of low density plastic in a vertical channel - or castor wheel analogues etc - basically something that allows both surfaces to slide past each other & maintain separation without much friction.
Quote from: fletcher on August 20, 2012, 10:29:59 PM
Fletcher,
Thanks for your continued inputs. I can balance the system by loading pressures and heads or other arrangements of shifting water mass, but that is difficult for the initial setup and can change with temp and barometric readings. My way to do the balancing externally, make it dead simple to adjust during the setup phase, and it also makes it possible to reduce the height of the ZED for the same output -- if my sim is giving me accurate results. With more layers, that tradeoff might change. I will have to wait and see.
It is true that setting it up my way is 1% more potential energy loss than the baseline needs to be and wastes 2% of the total potential work that could have been obtained in theory by overdriving it into the stops. However it is much easier to have consistent mechanical repeatability by giving up that 2%. That gives some mechanical tolerance and insensitivity to some variations in barometric pressure and temperature.
If 2% is all the O/U available, then that is not a design I would pursue for practical reasons. We are looking for something with dramatic O/U to produce a large number of KWH in a parking lot space. That should not be hard to measure even by eye.
I will try to get an updated version of the PDF out tomorrow, so you can see where I have taken the sim. I will hold off on new animations until I can do more verifications. I may do a tin can build first.
BTW, I did try a physics simulator program. It was not a very good one. Really more like a science educational toy, but it was free and easy to use. It included mass, acceleration, water turbulence, cavitation, etc. However, it lacked the ability to have the dimensional precision I needed, and the Piston leaked water drops, and the Riser did not self center... LOL That was the point when I decided to write my own to eliminate all the unwanted side effects.
~Dennis
Quote from: mrwayne on August 20, 2012, 05:47:07 PM
Hello Webby,
Suggestions:
Wayne Travis
Hi Mr Wayne,
Okay, love game time. I am not a member of Mr Webby's team, but have a question as I am a friend of Mr. Webby, will your team have access to your new improvements or will this be based on the current demo model specifications that we both understand? Just want to make sure we are on the same playing field.
Thanks, Larry
See3d .. LOL - soon you will be 100% percent confident of your sim, logic & the formula's, & that was your target IINM.
I've attempted to constructively cross reference your logic without seeing the actual volumes, masses & formula's you are using [I guess I could work them out from your data compilation but that would take valuable time].
The prize Mr Wayne & his team are so confident of having achieved is a paradigm changing one - one can never be to careful in checking for errors in formula's or logic, though this may seem redundant to some - a lot of credibility rides on it.
You are correct & the OU capability predicted is way above unity [large margin of error insurance] so a few minor aberrations or omissions isn't going to affect the results to much [the 80:20 rule] - if things were predicted to be much more close & marginal every detail would have to be accounted for accurately - this is why TK was questioning Webby's results when considering margin for error & scientific bias etc, because the results appeared to be possibly marginally significant at best & not demonstrably OU as was perhaps expected.
BTW - when your sim is complete to your standards I expect others to replicate your sim in other 'off the shelf purpose built' programs to compare results.
The new build challenges should also answer a lot of questions independent of Mr Wayne's own team building a desk top demonstration of a self sustaining pump well able to identify & measure input & output.
Quote from: LarryC on August 20, 2012, 11:50:09 PM
Hi Mr Wayne,
Thanks, Larry
Hello Larry,
Our team is restricted to what is currently released - you have gleemed much already - I will offer suggestions and lessons learned if asked.
Teaming with Webby is between you two. You both have demonstrated talent, and self motivation.
If it is to be seperate teams - I will give a certificates of ownership to the runner up if it happens that way.
Thanks!
Wayne
QuoteBTW - when your sim is complete to your standards I expect others to replicate your sim in other 'off the shelf purpose built' programs to compare results.
This is what I've been hoping to do and I've been Google'ing like mad to find something that doesn't cost the earth. I'm only just getting in to this so this is probably old news.
But anyway, from what I've found, there are clearly heaps of games and sims out there for educating yourself on specific setups/systems/forces etc. I thought Google's SketchUp might do it, with SketchyPhysics (Newton SDK) plugin, but I struggled with it last night.
However, I've now come across Algodoo (previously Phun), at http://www.algodoo.com/wiki/Home (http://www.algodoo.com/wiki/Home). At 3 Euros I thought I'd give it a try and let others know of it for anyone who doesn't have a sim or hadn't heard of this one.
Looks like it should be a fun night.
Algodoo/Phun is fun. I've got a couple perpetual motion machines that work in Phun. One is a gravity wheel and the other is powered by an overcentering spring. No tricks like hidden motors... they just work.
Meanwhile, back in the DeepBunker....
http://www.youtube.com/watch?v=BUlBqLM6Naw
@Mrwayne. On your website you say that there is to be a change of emphasis, and that you are now working on a simple basic table top model. I get the impression that you are still having problems with the data collection model, in that although it consistently demonstrates OU, it fails to meet some other criterion that you have set yourself, and for that reason you have not yet called in Mark Dansie. You may [or not ] wish to tell us more about that.
I did say months ago that IMO a simple basic model would be more convincing to a casual observer, so this change of policy definately has a positive side. The new challenge is exciting, and I am sure there will be people who will rise to that challenge.
One thing I found strange is this. Re the challenge model, I don`t think you gave any specification on the size of this model. And yet you say that gaps of a quarter or half an inch between ringwalls and risers will work OK. This is a bigger gap than in your Data collection model, yet I was envisaging a much smaller model would be built for the challenge. Could you please help to clarify this. I love the idea of a self acting water pump model, simpler than trying to generate electricity, and yet has a visible measurable output.
@See3d. I am intrigued by your idea of a one layer model. Please give more detail. Are we talking about a pod and one riser?
I tried AlgoDoo before I started my sim. It was fun, but frustrating to try to make a realistic ZED.
Quote from: neptune on August 21, 2012, 07:42:10 AM
Were you able to download my PDF? It has many details.
I am revising it today. I will announce when the new version is available.
Yes, Pod and 1 layer in the riser. Super simple.
|''''|___|''''| Riser
|__|_____|__| Tank
Oops. Looks like I forgot something...
http://www.youtube.com/watch?v=khZtoyjF4aA
Multi Question AHHHH my little brain.. just kidding.
The decision to do a parallel build - for a measureable system - is in case it takes much longer to wrap things up for Mark.
I have a lot the utmost respect for his teams bravery and efforts - and I am ready to wrap things up and move on to the next phase.
To be very clear - we are very overunity - it can be measured now - inputs and putputs - we are fighting external issues.
It started with fighting the check valves - remember when I said the capture system does not like to store and supply at the same time - well this is still and issue after the split of the accumulator - now we are bypassing the check valves to see if that is the issue.
We reduced the number of check valves - seemed to get better - we split the accumulators increased the pressure range - now we are bypassing the check valves - I will probably add pilot assisted spool valves - if it turns out to be the Check valve.
- we have 6750pounds of thrust and either the fluid does not go thru the check valve deign parameters - new blockage - sabotage lol - or we are bending the input shaft dead head - (cross beams needed) - the bypass today/tomorrow- will will tell us.
So - knowing we are having trouble with our hydraulic system - not the ZED - we entertained modification to the system - but decided since anew system might have as many issues - to split up - one team (and the challengers) to build the simple input out put desk top - to help our Presentations - or even better a self running system.
Bigger gap - we have done extensive work on the stroke and expansion capabilities of the layering system - it can handle larger gaps - which makes the system easier to build - and more output.
I personally would build the system a little larger than Webbys - if you are going for the $10K it is much more forgiving and has room to handle waste (losses) and better to control.
Wayne
Haven't read to the end of the thread yet this morning, so please excuse me if this has already been mentioned:
Once the ZED is set up (initialized) you always have greater pressure in each inner annulus. So the outermost annulus (water ring in this case) contains the lowest pressures. The next inner annulus contains a bit higher pressure at each height when compared to the pressure on the outer side of a given stationary or riser wall. So the system (once set up) is self centering. I believe Wayne called this hydrostatic centering or something like that in the patent app.
This effect also allows for thin walled members since the relative pressures inside any annulus wall are small due to only slightly lower pressures on the outside of that wall at the same heights.
The only problem comes with a sealed Pod that is in the highest pressure zone of the ZED: the center Pod chamber. So a material that can handle the pressures there is needed, or you need to pressurize the Pod internally to keep the maximum pressure differential on the Pod to a reasonable level.
If you keep the Pod bottom open the pressure differential issue is eliminated again, but you loose some lift due to air compression in the Pod.
M.
I've found that I can "right click" on just a picture and ask it to open in another window with great success when they fail to open in the actual forum page. FWIW.
M.
QuoteI'm trying to figure out a lowfriction lightweight way to keep risers and stationary walls concentric without adding drag and of course with allowing air and water to pass freely. I'm envisioning something like a Teflon "star" or "gear" with teeth pointing out and in, like a ring, that can slip over the inner tube and ride between it and the outer tube smoothly with loose clearance, preserving the interwall spacing and keeping everything concentric.
For a larger system and possibly even for what's being presented as model size I would consider an external alignment system like many industrial press applications use. With polished rods and recirculating bearings or Teflon sleeves friction could be quite low, and alignment accuracy very high.
A thought
Dale
QuoteI tried AlgoDoo before I started my sim. It was fun, but frustrating to try to make a realistic ZED.
Disappointingly, this is my conclusion too. It seems to do a lot really well, and it's certainly fun and easy to use. However, there doesn't appear to be a way to handle pressure properly.
Guess it's back to the drawing board.
@mrwayne. Thanks for that detailed report-fascinating and reassuring that things are still on track. Great news about wider gaps. That re-introduces the possibility of building from a wide range of "found materials" aka junk. Could well encourage more people to play around .
@See3d/Yes I managed to look at your material, but am only a bit basic when it comes to mathematics. Many thanks.
na
MrWayne or others,
I am new to this thread and off course did not go through all the posts but I have a general question;
I read that the ZED has between 104 and 300% overunity depending of the number of layers but read also that there is no external input whatsoever not even compressed air so how is calculated the overunity?
it should be output/input but input is zero, so to what correspond the 100% if one layer gives 103%
tks
Dennis
@Parisd. I will have a shot at answering this. In order to lift, a Zed does need input, usually the injection of some water into the pod chamber. When the limit of lift [stroke] is reached, the contents of the zed are still under pressure. So as we release this pressure , we can make use of this pressure to partially pressurise another Zed. What corresponds to 100%? That would be a simple Archimedes Buoyancy system.
A two Zed system uses no external input , as the pressure is shuttled back and forward between the 2 Zeds. A percentage of the output power has to be used to aid this process.
Quote from: TinselKoala on August 21, 2012, 08:12:47 AM
Interesting setup... difficult to tell what's going on through the dark green section. How does it work? And, hot glue's great for many things, but not so much for water-tightness (although, if you use enough it'll get you by ;)).
polln8r
It's a combination hydraulic-pneumatic system [like being mentioned on this thread except without buoyancy] - overall there's a net reduction in system PE i.e. the system CoM lowers over time - PE of water is converted to KE of water & height achieved [PE] for a portion of that water.
The system PE is restored when the water is added at the top of the bowl - a kind of hydraulic clock that needs rewinding.
Not OU but shows looks can be deceiving & a bit of fun by TK.
@webby, thanks, I thought the risers were sealed at the top, I just woke up and I don't quite understand yet what you mean by 'feed tube' in the context of the risers.
In my original mental picture I thought your risers are only open on the bottom, and I thought that increased depth would force more water up the bottom, compressing the air but also reducing the displaced volume and hence also the lift force, just like the Cartesian diver.
I'll have to have some coffee and think about your numbers.
Again, thanks for indulging a silly old Koala.
---TK
Quote from: wildew on August 21, 2012, 09:55:47 AM
A thought
Dale
I agree and that is the way I'd do it in a big, machined system... if it is necessary. But mondrasek reminded us that the patent application speaks of this automatic centering caused by the pressure distribution. I'm not quite able to wrap my mind around that one yet without some more experimentation, and I'm a little worried about capillary effects when wall spacing is small wrt wetted area. If you, say, float a 1-inch ID O-ring on the top of a tub of water, then put a 1/2-inch OD O-ring to float inside the first one, surface tension/capillary effect will cause the two to come together instead of centering concentrically, I think.
It may even be possible just to float some plastic spheres of the right diameter on the water surface "ring" around the annular walls. Like 5mm plastic bbs for airsoft guns. If they were, say, 0.5 mm smaller than the normal clearance they'd float in there like the balls in a bearing, and my intuition tells me that the water surfaces are going to remain near the centers of mass of the riser vertically, so just the single layer of spheres at the water surface won't make the riser "" or ride crooked, they should automagically be in just about the right place to provide clean and constant spacing separation between riser and fixed wall.
ETA: lol, the missing word in the "" quotes must be a forbidden forum word. What crows at dawn, is also what a rooster or male pea... bird is called, and means "run crooked" and is also what you do to a rifle before you can fire it.... heh.....
Dirty he who dirty thinks.. .this forum has a dirty mind, because "" is forbidden, so is "", but many other really foul words are allowed like the "f" bomb, British nasties like b****r, even the German slang version of our English "f" bomb are allowed, but you dare not speak of the pea-hen's husband, and if you are going to the range for some target practice, be sure to un.... er, un...... well, just don't pull back the hammer until you get there.
@webby:
That's interesting, I can't quite understand why that self centering would happen. Is there a difference in the area between two different sized circles, if they are concentric vs. wall-touching? If the area is different then I can understand the self centering effect, but I think the areas are the same, geometrically, and so for cylinders so would be the volume. I'm not confident of this though, I'll have to look in some geometry books or make some drawings, try to remember how to prove a Euclidian theorem... heh, with my ossified brain not likely. Maybe I'll just cut out some shapes and weigh them, that much I can still do.
When you were giving the riser dry weights and sink weights earlier I thought they were out of the system so the feed tube didn't come into play?
Quote from: TinselKoala on August 21, 2012, 07:29:49 PM
@webby:
Simple as it can get example of self centering.
Hi All,
I was preparing to release an updated version of my simulator PDF document tonight, but that is not going to happen. Just as I was finishing up, I realized that I had made a conceptual error in the sim. I have to rework the formulas one more time -- again.
The road to success is a series of learning experiences that some call failures. No, just "1000 ways not to build a lightbulb".
Back to the drawing board...
@LarryC: Thanks for your drawing. But please look down at the system from above, not at it sideways. As I understand it there are no balloons in there, but a cylindrical chamber filled with air and water. Will this still self-center? No balloons please unless they are in the actual device we are discussing.
ETA: I don't know, either way, I'd just like to understand how. It sure would be nice if it did self center, that would eliminate a bunch of design problems.
For your amusement:
http://www.youtube.com/watch?v=N2M05d8J8fU
http://www.youtube.com/watch?v=P8OVSPVKLBI
:P
Quote from: webby1 on August 21, 2012, 08:42:47 PM
You asked for a test and asked a question, the one where my max lift was 1204g was done with the system assembled and using the feed tube and displacement piston for the input, the weights I gave for the risers were with them out of the system.
Ah, Ok, I reread your post after a couple cups of coffee and now I get it, thanks. I understood you used the full setup for the big lift, I just needed to know the input, and you gave me that, I think, if I can remember the weight that pushed the piston down.
And earlier you said something about a full riser sinking... does that affect your earlier sink weight measurements?
@see3d: your attitude is admirable. The essence of the scientific method is the search for one's own errors, the attempt to refute one's own hypotheses, the unflinching examination of data no matter where it leads, even over the cliff of career destruction ( google HeLa Adam Curtis Documentary).
Keep it up and thank you for your hard work.... I know how difficult numerical modelling of physical systems can be.
Quote from: TinselKoala on August 21, 2012, 10:22:33 PM
Yes, especially systems I didn't understand before I started.
Thanks for the kind words.
I have a personal motto: Never give up! How can someone be called a failure if he is still trying to succeed. However, to give up is to admit failure. I am allowed to refine my goals as I learn more though... :-)
Thanks for the video on the fountain. Say, where did you find that human to do the grippy stuff for you on assembling it... LOL
Quote from: TinselKoala on August 21, 2012, 07:12:00 PM
Why not use some cheapie nylon rollers? A pair arranged vertically, repeated in a triangular or quad fashion (if viewed from top) should work, low friction, low weight.
Question: what is the desired mass target for actual risers themselves...weight wise...lighter is better, middling, or there some value they need to be optimally?
That is, should they be lighter than the water, or heavier, or neutrally buoyant...
Stated again, if sunk in the water sideways like a filled cup, assuming it is deep enough, they would a) float bigtime, b) float just under the surface, or c) sink fairly quickly d) sink like a filled Titanic.
rc
Quote from: TinselKoala on August 21, 2012, 10:10:46 PM
For your amusement:
:P
Excellent demo.
@LarryC, reference your diagram with the balloons. I can see what you are trying to show, but at this stage I remain unconvinced. IMO, for the diagram to represent reality, You would need to show a tube connecting the necks of the two balloons together. As shown , the balloons would cause centering, but in real life, as things go off centre, air is free to flow around the riser to the other side.
Regarding the centring issue generally,what is required depends on if we are using a stand alone Zed, or if it forms part of a more complex machine, for example a self runner. For a stand alone Zed just being used to lift weights, strips of plastic used as spacers could work.
For a self runner, I would build it like the old beam engines[steam]. By using two parallel beams, one above the other, [Desaguliers Beams], the risers, which Wayne said may all be fixed together, would be forced to move up and down without cocking. They would actually move in a slight arc, but remember the stroke is short, and the beam could be relatively long. By placing the beams fulcrum off centre, we could amplify the stroke length if desired. For a self runner I favour a crankshaft and flywheel setup.
The fact that the risers move in a slight arc is less important now that Wayne has said that gaps can be up to half an inch.
On the question of self centering.
I grasped the idea from our bearingless pond pump - it directs the water pumped around the free floating armature - best pump I ever had.
Also - I worked AT Anhueser Busch for 19 years (until I was funded for thisproject) - the most important bearings were Hydraulic - non - contact bearings - precise to .00001
Also - real world application our six foot Zeds - no guides - .20 gaps do not touch during operation.
The alignment with the output shaft and Final riser is important
Important to note - the inner pressure is always greater - so the alignment improves as you near the center.
Wayne
Quote from: webby1 on August 21, 2012, 07:20:19 PM
The feed tube is a long cylinder I attached at to the bottom of the unit and feeds the pod chamber, inside the feed tube is a close clearance piston so that when I push down on the piston the water is pushed up the sides of the piston raising the head, if you will and allowing it all to enter into the system through the pod chamber.
@Webby1.Can i ask you a few questions please.
1. I suppose you have thought of this, but is the piston in the feed tube neutrally buoyant? If not, and it tends to float, you are wasting energy sinking it.
2. Could you give your best rough estimate of how many cycles per minute are possible in a Zed of the size you built?
3. Wayne has said that in proposed very large machines he proposes to use a crankshaft. I, and no doubt others have thought of using a crankshaft in a small model.In using a crankshaft, a flywheel is desirable to carry the crank over the dead centres. If the crankshaft turns slowly, as it must, we need to gear up the flywheel to run at reasonable RPM, to preclude the need for a large heavy flywheel.
My question is this. From your observations, would you say that the pause at top dead centre and bottom dead centre can be short enough to avoid stopping the crankshaft at those points?
If I am thinking right, and we use a crankshaft, then it would be possible to operate the piston on your feed tube by a separate crank on the same crankshaft, having a larger "throw" than the crank connected to the ZED.
Quote from: Artist_Guy on August 22, 2012, 12:20:02 AM
a) float bigtime
rc
No one in the know seems to want to answer your question or it's been missed - I'll give some observations/comments for you to consider - I'm not sure whether you are talking about Webby's build or a single layer ZED build - I'll assume you mean a generic single layer ZED that see3d is simulating, & so I'll relate these comments to his simulation diagrams which you can find by downloading his pdf a few pages back.
If you start with the proposition that the ZED unit is at equilibrium [all forces are equalized] & that the riser is NOT latched, & that the system is not pressurized, then the volume density of the riser dictates where the water levels are up the side of the riser - incidentally, for an unpressurized system this will be the position of least Potential Energy.
Assuming that the riser is made of dense & strong material to reduce deformation then it is likely to be hollow with thin walls - the "Floatation Law" will decide how high the riser would be in relation to the surface [or apparent surface] of the water.
1. If the riser volume density is greater than the same volume of water then it will sink to the bottom.
N.B. there is still an buoyancy force so its apparent weight will still be significant - there will be no upthrust net force.
2. If the riser volume density is equal to the same volume of water then it will be neutrally buoyant [the same as having the same packet of water instead of the riser volume].
3. If the riser volume density is less that the same volume of water then it will rise in relation to the water surface level.
N.B.1. If the riser volume density is very low it would float above a water level with most of it visible above the water line - if its volume density is medium perhaps only 1/3 to a 1/2 etc would be visible - if its volume density is rather high but still less than water not much would be visible above the water line, like an iceberg.
N.B.2. The buoyancy force [using Archimedes examples] is the inverse of the gravitational force of the same volume of water - if the riser had no mass the upthrust force would be equal & opposite to the force of gravity acting on the same volume of water - then you subtract from the buoyancy force the gravity force acting on the actual mass of the riser [this is the apparent weight] - you are left with a NET upthrust force - this upthrust force is inverse & proportional to the riser density/mass, therefore more apparent weight means reduced upthrust force to use to do Work.
What this means in the single layer ZED is that we don't have contiguous water surface levels - there is water rising up the sides of the riser.
We can deduce that the riser is at equilibrium, not under pressure, & that it has a medium buoyancy & therefore a medium upthrust capability.
Change the materials of the riser to change the mass & all those relationship reach a new equilibrium & Work capability, including water levels.
Where it becomes important in the ZED is because it is purportedly not a true Archimedes buoyancy system - so what we see when the ZED is at the START of a cycle [i.e. in equilibrium & position of least PE] is water pressure levels & head developed - the head is from the meniscus of the outside water column adjacent the pod wall & open to ambient air.
The water pressure increases with depth from that datum [which moves upwards when the cycle is started & the piston does Work on the system] - the important bit is that water pressure has no shearing moment, IOW's, it acts at right angles to any & all surfaces.
So there will be an upward force [water pressure] on the underside of the riser [this pressure cum force is derived by apparent depth from head height] - there will be a greater water pressure cum force acting downwards vertically on the piston head, also derived from apparent water depth - N.B. there is no normal Archimedes water volume displacement to create this head depth but the pressures/force 'feel' & act as though there was.
EDIT: i.e. the pressures developed mean that the piston has to do Work
as though it were lifting an equivalent mass of water.
Remembering that as the piston does Work [expends energy] on the system the water head rises & since the riser is latched & released when the upthrust force is optimized, it will move upwards generating a useable force to do Work - then the system enters the second stage of the cycle & returns to equilibrium & position of least PE, to start over.
That's my take & hope it helps.
P.S. - the traditional science view says that the Work Done/Energy Input on the piston, which in turn pressurizes the air pocket & raisers the H2 water level, which creates the head [when the riser is in locked down mode], is the same Work Done/Energy as the riser upthrust capability in Work/Energy Output, less system losses of energy.
So we are trying to identify where the anomaly is that allows apparent OU if measurements are correct as reported by Mr Wayne - it would seem that it might be contained in the pneumatic portion of the system somehow, but then that fly's in the face of some contributors comments about different density fluids [non compressible] showing the same potentials which would seem to rule out pneumatic contribution as the cause.
The upshot being that more energy out than in, empirically proven, would prove that gravity [from which buoyancy is a considered a downstream effect] is not conservative & that the laws of thermodynamics would need amendment IF no environmental energy entered the system - this would be a game changer at so many levels that its importance couldn't be underestimated.
@fletcher: thanks for that walkthrough, it makes good sense to me. I hope mrwayne will tell us if he approves of the description too.
(I see that you also find that "virtual water" is important to the cycle ! ;) )
So.. I think I'm getting near a single-layer TinselZed here, what do you think?
The TinselZed looks good TK - actually I was hoping you'd do a test rig & report on its performance characteristics.
Then this will help the sim builders like see3d test the veracity of their sims & further check the logic.
P.S. BTW thanks Mondrasek for the tip a few pages back - you learn something every day :D - I was able to right click Larry's image & view it on a clip board immediately in full, even though the original had frozen 1/4 completed.
Unfortunately right clicking TK's photo's didn't have the same result for some reason so I'm having to guess some of what you are showing TK :( - can always wait for the vid later I suppose.
tk,
didn't you tell me the engineering books you know of say these things can't work ?
yep, have to believe your posts to me were personal.
What a day!
As you all know, my team has been trying to trouble shoot a system error for nearly six weeks now - OM gosh it was lot of work.
Our probelm was - in simple terms - when we turned up the production (and resistance) - the the system seemed to have hydraulic blockage meaning - we could not run for anything.....
Today , Robert suggested that one of the tie rods on our production cylinders was not torqued equally with the rest - so we loosened them and then torqued them as instructed - immediate next test "Blockage /stoppage" GONE - praise God, and thank you Robert...whew.
We are all pretty excited around here.
I have not been able to spend as much time - and have had a few distractions - but I will try to catch up and answer what "I see" that is not already answered by some of the group.
If I skip a question, please just ask it again.
Thanks Wayne
First question off the top of my head ...
Why the $5K and $10k Challenge?
I understand - good question - no .... it is not to overcome problems for us..No..... it is not to steal your improvements..
If you remember - the challenge was in using the current released information - I did not ask for improvements.
Final Answer:
We know it works - and we want you to know also.
The Money:
The Money, was donated to us by a good man - I want it put to good use. Please realize that no matter what i say - it is suspect - but third party replication - protects us all (that is very valuable).
The share certificates are from me - I very much value the 20% who actually do most of the work.
Many of you have expressed the desire to tests and mentioned funding - I am a probelm solver.
This challenge should take no more than a couple weeks.
If you build it five layers - it is hard to not get positive results.... A ton of variations work fine.
P.s. I keep my word.
I will re-post the challenge in the next day on my Web site.
Wayne Travis
Quote from: fletcher on August 22, 2012, 05:18:42 PM
So there will be an upward force [water pressure] on the underside of the riser [this pressure cum force is derived by apparent depth from head height] - there will be a greater water pressure cum force acting downwards vertically on the piston head, also derived from apparent water depth - N.B. there is no normal Archimedes water volume displacement to create this head depth but the pressures/force 'feel' & act as though there was. EDIT: i.e. the pressures developed mean that the piston has to do Work as though it were lifting an equivalent mass of water.
I am a little overwhelmed at the quality of this response -
So let me say a few things that popped in my head when trying to follow it.
The Neutral buoyancy question (for the riser) - normally - less weight means more output - that is in a traditional system - but our is Non- linear.
This means - a certain amount of weight - at the right range of the polynominal - is a great advantage - cheap to lift and valuable to sink - cost reduction in both directions. Loss of ideal output - but a great reduction in the cost of a less than ideal output.
The density of the water is also important - yet it is not the "expansion of the air" where we operate the piston - or pull power out of the system - this is a mistaken understanding of our operation. - at the end of the up stroke - all the air is still compressed to the highest point - which is the same as the precharge compressed value - only we raised the height of the water below the pod to stroke - inch for inch - after precharge.
(side note - the air does expand - but while we are lowering - not rising - and not all the way - just until the weight of the risers equalize with the head).
We use the heavy density "water" to pressurize the lighter density air - and when the equilibrium of the load is met - we maintain this equilibrium to stroke.
The lighter density is what pushes up - if you could measure the density of the air - you would see that the force applied to the riser is minus the value of that density - it would be easy to measure in a mercury water set up.
Mercury More density) could replace the water, and Water could replace the Air (less density) and the system would work much better - not thirteen times better - because water has more density than air (twelve times better would be a safe bet).
A mercury water system would not have expansion and allow for extreme control of the water levels during operation.
I hope this helps - it is important to understand that this system is a pressure diffirential system - casued by gravitys effect on density - the seperating walls redistribute where the diffirential is focused.
The mass "reuse" is what causes the ZED to be Over Unity ....TK's Virtual Mass is the begining of the real understanding.
It also answers where the Energy Comes from - hope to see you all their!
Wayne
Quote from: neptune on August 22, 2012, 12:55:31 PM
The rpm is pretty slow - 3.7 stroke per minute on our system.
One of my engineers wants to use a crankshaft -
I "flat top" my output - but with a crankshaft you can charge to ideal and capture.
The value - while the ideal decreases during stroke (this is how they get overunity out of a single ZED).
So the crankshaft is better use of the size of the machine - but making it a little bit bigger and flat topping is easy to capture.
Wayne
Hey TK,
My very first pod was a glass mason jar - -- it was heavy and since the pod floats due to direct discplacement - a lighter pod turned out to be the best.
But you can measure the additive characteristics - the pod and your first riser pretty simply.
The Pod will "virtually" be a mass displacement for each layer after that.
If you account for all the virtual mass - in each successive layer - all the buoyancy - compared to Archimedes' displacement -will be accounted for.
Have fun!
Wayne
Quote from: johnny874 on August 22, 2012, 08:05:29 PM
tk,
No, Jim, what I _suggested_ to you is that you take a look at one particular engineering textbook , the fundamental course in engineering mechanics, Beer and Johnston's "Statics and Dynamics" ... one that is used by many colleges of engineering, in its 9th edition, 2010, and I gave you the website for the Student Edition where you have access to just about the entire text. Did you look?
And I also think I reminded you and everyone else that violating the fundamental Laws of Thermodynamics is Big News, not some matter for internet forum chitchat and tinkering. If... that is... it is actually happening. Is that what you are referring to?
Yah, that's pretty personal, I guess.
Quote from: mrwayne on August 22, 2012, 09:59:14 PM
Hey TK,
Have fun!
Wayne
Thanks, it is already fun. I'm just looking at the geometry right now and making several variants. Drinking lots of instant coffee ! This that I showed above will just be a single layer, if I understand the term. Pod, riser 1, ringwall, outer chamber wall. I made it so that riser2 can go, I hope, over the inner parts and between the ringwall and the outer chamber wall, making a 2 layer system. I haven't been able to find the right jar for riser2 yet though.
You think I am just clowning around, but I think that your Zed system -- or rather my variant of it, with the permanently sunken pod -- might actually work, to increase the air pressure in the input reservoir of my PerPump and drive the head even higher.... than the 8 1/4 measured inches it can already pump above the base of the input cup. Maybe. In my dreams, anyway.
Some more irrelevant irreverent video for your amusement: measuring the pressure head of the Fountain of Heron perpetual self-powered water pump, with several variants tested. You can already see one effect of the precharged TinselZed variant: the "gulping" that is caused by the variation in the internal water levels when I provide some back pressure as I make the head height measurement on that system.
http://www.youtube.com/watch?v=Gx0P50ra2go (http://www.youtube.com/watch?v=Gx0P50ra2go)
Quote from: TinselKoala on August 23, 2012, 05:56:40 AM
No, not much .... :o
Attached picture is to help the model builders and was created due to a question I received from a model builder. After you study it, you should realize what would happen if you press down on your model after rise before water release.
I am not building and do not need to be part of any team. I am assisting a couple of builders with data, so to be fair, I will assist others that PM. But first come, first serve.
This is close to scale, to see the relative volume difference between the 3" of water below the pod and the water gap between the pod and the pod retainer wall. So you may need to expand to see clearly.
Regards, Larry
Quote from: LarryC on August 23, 2012, 08:57:28 AM
Regards, Larry
Thank you Larry,
You continue to show that you are a real team member!
Wayne Travis
Attention to those who are taking the TBZED $5k or $10K challenge,
Please e-mail me at mr.wayne@hydroenergyrevolution.com
I have something to send to you.
Wayne Travis
Quote from: fletcher on August 22, 2012, 08:00:37 PM
Hmm. If you have only tried copying to a clipboard I would still try "copy link in new tab" or "copy link in new window." Both of those should allow the internet to keep doing its "retry" for missing packets thingy I think. Not sure how many retries a single "copy/paste" cycle will get you.
Cheers!
M.
Nice control tests. So finally you route the "input" from the top of the fountain into the "Pod chamber" instead of into the outer annulus and you should have the now "corrected" TinselZED output to test by comparison. If the TinselZED has more output in the "corrected" configuration, your Heron fountain "output" head pressure should increase?
Interesting.
M.
As I said few days ago I am new to the ZED device, curious but not catching up rapidly and have no or little access to the available videos (in SA even a fast internet connection does not allow watching Youtube.com unless in the middle of the night)
I have seen one simple demonstration of the Travis effect which I do not understand, the Archimede principle is not function of the height it is function of the volume of water displaced (this statement is not from me!), if it was function of the height then a thin and tall man with heavy bones would sink in water when in horizontal position and would just have to stand-up in the water to return to the surface. Its not working like this. The archimede force will increase only if the volume of the mass inserted in the water increases; our guy would have to pull out his belly to have a slight chance to float !
Now in the Travis effect demonstration video I have seen, the reason why it takes a heavier weight to keep the second cup under water is because we are compressing the air inside this cup and it is compressed until the air almost escape from the sides (this is a simple piston effect). As soon as the cup move few mm up the effect disappears, unless all the system moves together which is probably how it works. In such case of compressed air, the air volume decreases so the Archimede force decreases too, not what we expect. In addition injecting compressed air required a bigger effort (energy).
I am not saying that it cannot work, I just dont catch it with the information I have. I believe the Archimede force is like a shielding to gravity, so I would not be surprised someone managed to shield then un-schield and recuperate potential energy this way. Just surprised this happen in 2012 !
To finish, I have seen mentioned large weight involved (thousands of pounds), but when one weight goes up an identical weight goes down so the global effort to move them can be close to zero.
Hope to catch up soon...
About the statements that buoyancy is dependent on the water height...
Officially, buoyancy is dependant on the weight of the water displaced. But the weight of the water is the Volume x Density of the water. And the Volume is (for a vertical cylinder like the Pod or Risers) Surface Area (of one end) x Height.
So if buoyancy is:
B = V x d (where B=buoyancy, V=Volume, and d=density of H2O)
and V = (pi x r^2) x H (where r = radius of the vertical cylinder, and H=height of the submerged portion of the cylinder)
then:
B = (pi x r^2) x H x d
Now for a given cylindrical Pod or Riser: pi, r, and d are constants.
So the buoyancy will change when the H (height of the submerged portion of the cylinder) changes.
In the ZED setup, we change the amount of water in the system below the Pod and Risers, and this effectively changes the H.
M.
PS. Sorry not to include units and the proper way to show something "squared." It is only because the former is too laborious at the moment and the later is something I do not know how!
@Parisd. You say " when one large weight goes up, the other goes down." This is not exactly what is being claimed. In the case of a single Zed, as I understand it, when the Zed reaches the top of its stroke, a large percentage of the weight being lifted can then be removed, leaving sufficient weight to sink the risers as water is released from the pod chamber.
Now consider Wayne`s large data collection machine. In stead of lifting weights, the effort of the Zes is used to compress hydraulic rams. These are used as pumps . They pump oil into a hydraulic accumulator. The pressurised oil represents stored energy. It is prevented from returning to the rams by one way valves. The stored energy in the accumulator is used for two purposes.
1 Part of the pressurised oil is used to help push water into the pod chambers of each Zed in turn.
2 Part is used to drive a hydraulic motor which turns an alternator to provide "free" output energy.
Hope this helps your understanding.
@mondrasek,
Sure, surface x height = volume of a cylinder, I read that height only was important (not volume)
@neptune,
I would need to see a complete drawing or a 2D animation to have a better idea of what is one Zed what is 2 Zed connected and to see the complexity of the whole system, is it disclosed and available without going to Youtube?
Why store energy in pressurized oil, oil is like water not compressible, it can be pressurized but does not store energy. oil is probably used to transmit energy.
Tks for your previous answers.
Quote from: parisd on August 23, 2012, 02:37:09 PM
@mondrasek,
@parsid, you may want to read my post again. I said a lot more than what you quoted.
M.
@parisd. You need to spend more time studying the system. One Zed consists of an outer tank with ring walls inside, and a central floating pod, and a number of concentric risers shaped like inverted cups.
Pressurised oil only stores energy if stored in a hydraulic accumulator. {google it} In its simplest form, think of a balloon inflated with pressurised oil. As you let the oil out, it emerges under pressure and could be made to do work . A practical accumulator consists, in one type, of a cylinder with a free piston inside . One end contains oil, and the other end contains pressurised nitrogen. Think of the nitrogen as acting like a spring.
Remember that the oil/hydraulic system is separate from the zeds, and just acts to convert the energy from the rising zeds into a rotary motion for the output alternator. There is no OU in the hydraulics, it is just a transmission system . The hydraulic rams-which-are-used-as-pumps, are pushed up by the zeds. They DO NOT push the zeds back down, that is done by gravity.
Hope you totally understand this reply. If not, please ask.
I understand that you can not access Youtube, but there are lots of diagrams in the thread[if you can access them] showing how the system works.
When a Zed is at the top of its stroke, the air and water inside are still under pressure. To lower the Zed we have to let out some water, which is under pressure, and can partly [50%] start to push water into the other Zed. The rest of the energy needed for this process is provided by a ram, fed from the hydraulic accumulator.
Yes, H height of submerged portion of cylinder. Agree with that.
quote author=mondrasek link=topic=10596.msg333365#msg333365 date=1345748635]
M.
Quote from: TinselKoala on August 23, 2012, 05:40:17 AM
you didn't suggest I read it, you said i had to REFUTE what you say. It applies as much to static heads which means you should be making the same refernce to mr. wayne which sounds like a Jim Crow log on.
tinself kkoala, I do believe you are some who plays with words to play mind games with people. Like you said, you might have been willing to try the pendulum set up but you didn't like my attitude. The videos you posted show no mechanical builds. wrong person for it. Besides, you don't know me yet assume I am stupid because I wasn't fortunate enough to go to college like you.
At least I am intelligent enough to realize in Mr. Travis' "invention" that the staic heads really have no value because the input air pressure detrmines their height. Since they are controlled by the in put energy, it's only the conversion of that into the second cylinder that matters. And as I mentioned, when trying to compress 20 cc of water into a cylinder of 10 cc, the staic head WILL be taller but the height can be reduced to increase pressure. Nothing new there but in this thread it's an invention worth putting considerable effort into. I would've done testing first.
But then, bessler's wheel is a much better idea so will elave you to your forum so you, Alan and Bill can get rid of people you don't like just as they do at besslerwheel dot com where they say engineering doesn't allow for it either.
By the way, check out the continuous flowing water thread, at the end of it is a design where water can keep a hydro machine running using static heads and gravity.
Funny how you ignored a potentially successful design to sqy I'm stupid because I need to read books you've probably have only heard of.
And btw, tell your friends to quit emssagibng me. it's funny how you say you don't pm other people when you want to go after someone.
bye
Quote from: mondrasek on August 23, 2012, 12:04:45 PM
Interesting.
M.
Yep, and now I've completely revamped the system to incorporate a linked pod-riser. So now the pod is free to float and also carries riser1 along with it, with the innermost ringwall between them and sealed to the chamber floor. I've plumbed in a fitting at bottom center of the chamber, so anything coming in here goes into the space surrounding the pod and defined by the inner ringwall, and I've made a "sub base" to provide ground clearance for this fitting. I've also put a vent fitting in the top of this riser assembly so it can be vented then sealed. I put all this stuff together with clear RTV so it needs to cure until tomorrow before I get it wet. So the stationary unit is the outer chamber with the one ringwall sealed to the bottom, with the central fitting in the bottom. The moving unit is the pod-riser combo that fits into and over the inner ringwall.
So in the original fountain, the down tube goes directly from the input cup to the bottom reservoir. Water coming in raises the air pressure in this chamber, which communicates with the very top of the green input reservoir, increasing the pressure there, which pushes water up the pipette opening which is near the bottom of the green input reservoir. So.... if there is some increase in pressure for a given amount of input water, caused by the geometry of the "tinselZed"... which may now be an actual Travis Zed by now.... it should show up as increased pumping head, and I believe the system is quite sensitive enough to be able to discriminate slight differences, if there are any. So the effect of even the single-layer Zed, if that's what I've got, could show up in the pressure head measurement at the top. I think. Maybe.
But even if it does, will this mean that the Zedated PerPump is now an overunity pump, in addition to being self-powered and perpetual ? ;)
Quote from: johnny874 on August 23, 2012, 03:39:51 PM
bye
Jim:
1) Please show where I ever said you were stupid.
2) There are plenty of mechanical and electromechanical constructions in my videos. The Mondrasek magnet-assisted gravity wheel is something I am particularly proud of, and my VanDeGraaff machines and Bonetti machines are truly... shocking. My electrostatic Tesla Turbine is something that nobody has ever seen before. The Steorn Orbo replications Orbette 1 and Orbette 2 show what I can do with found junk and what I can do with my machine tools, lathe and mill. Just like when you were criticising me for the textbook recommendation, you are simply wrong in your assertion that there are no mechanical builds in my videos. What there AREN'T is simple arrangements of levers and pulleys that do nothing. My machines work.... even the Mondrasek wheel would work..... with negative friction bearings. I have some on order, delivery expected sometime in 2053.
3) Going to college has nothing to do with being "fortunate". It has to do with motivation and hard work. Please show some respect-- as I said before, your world is designed and built by people who DID go to college and learned something there, and went on from that foundation to add to the sum total of human knowledge.
4) Those little squiggly red lines under your words are complaints from your spellchecker. Take a deep breath, slow down, and for goodness sake stop flaming me and blaming me for your inadequacies. If you think you've got something... shut up and build it, prove me wrong.
5)
QuoteFunny how you ignored a potentially successful design to sqy I'm stupid because I need to read books you've probably have only heard of.
Not only is that a lie, but I also resent it very much. I suggested to you that you look at the standard engineering mechanics textbook THAT I USED WHEN I WAS IN ENGINEERING SCHOOL at the University of Texas in Austin, working my way through school at my AIRCRAFT MECHANIC job, staying up late nights studying, and we used that text for two semesters; I worked many many problems and sat many many exams based on that text. For you to make the absurd statement that you do really makes me mad.
TK,
So you had tyour friend remove some of your posts. What was it Bill accused me of doing ?
Yep, deleting posts. But you don't know me and don't know engineering and on your youtube channel,
not one mechanical build. I wouldn't ask someone like you to help me on Bessler's wheel or anything else.
Of course, Milkovic's pendulum is his as he has patented it.
I do have better things to do. As you said, if I do what you say, then you'll consider aI know something college boy.
Guess my mistake was serving in the military protecting your freedom of speech while losing mine.
C'ya wouldn't wanna b ya.
uh, tk, once someone messaged me on your behalf, it did let me know there is a group of individuals who do work together
and if for no other reason than to cause someone problems. And I do believe it possible that you and Bill pm'd each other
before posting in my thread. That way you could cast me in a bad light for thinking about pursuing an idea while being willing to give the patent rights to charity.
I know AB Hammer pm'd people all the time because he wanted to take over my work. He knows opportunity when he smells it.
So yep, there are vindictive people in here and you are one of them.
Quote from: johnny874 on August 23, 2012, 06:17:58 PM
Okay, this is embarrassing to say the least...
But NOBODY torments my tormentor!
http://www.youtube.com/watch?v=WcPuKv9Z-XE&feature=plcp (http://www.youtube.com/watch?v=WcPuKv9Z-XE&feature=plcp)
I think you all will recognize the voice in the video.
Please take note of the Engineering that must have gone into this exquisite Mechanical Build.
For those of you who don't know, the wheel is turning on ceramic bearings. Just because TK had those laying around in his tool box. Or so he said at the time. You can't trust marsupials. Because they're fast!
Humbly yours,
M.
m.,
That's magnetic, didn't see any levers.
@tk, I am wrong and you are right. I know nothing of engineeringt.
After all, even AB Hammer told me he would teach my dad engineering if he had 4 years to learn from him. And those engineering books my dad gave to me to study are wrong. I consider the sourse. it is like oyu said, you know what you are talking abouty and that I have no education in engineering.
And liek AB Hammer, you are also the best builder and if someone can kiss your guy's butt, then you might say, I'd build that for you but it's not a good enough idea.
Did have a shop set up but that didn't stop my having to take a lot of crap. i think maybe when you can understand bessler's wheel which is hydraulic theory then we'd have something to talk about. But i am not like Mr. Travis who has a lot of money to spend trying soemthing that can't work.
You see no levers, Jim, because you do not know what a lever is, really.
There are arms and moments happening, Jim. Lever arms, lever moments, levers of varying lengths, torques, angular momentum. They are all over that machine.
Any overbalanced wheel moves --if it does--- by exactly the same way and principle that an unbalanced lever does.
johnny874.
You are paranoid. None of your accusations of people PMing each other to conspire against you are true. None of us are working for some evil cabal to suppress free energy either, that allegation is also a plain and simple lie, based on a delusion and promulgated by some people who have no idea what they are talking about.
No amount of proof will convince you either, not even Stefan's testimony about who pms whom with what... because you believe that our good and tolerant host is in on the conspiracy.
Yes... and he runs this website as a personal joke on people like you, Jim, doesn't he.
So... if I may be permitted to get back on topic for a moment....
The Zeds go through a cycle, right, a complete cycle, gaining something for each cycle in terms of work/energy. Right? So... there is no law, is there, that the cycle has to start at the bottom, I think... it just has to wind up exactly where it started from, but that starting position could just as well be the top of the lift as the bottom of it. Right? As long as a complete cycle is performed, winding back up at the top.
And also, or maybe the same thing, we could consider the "output" ... the great weight lifted a small distance... to be the "input" when running backwards. So you start at the top, use the great weight to push down the small distance which then causes the small weight to rise a great distance until you are back at the normal, bottom "start"position, then you continue through the second half of the cycle until the small weight (or piston) is down and the great weight is up again, an inverse cycle.
That destroys energy, or makes input work vanish... or something.
Ahhh... I think I need another cup of instant coffee.
Hmmm.
Okay, I'm in. You propose a very interesting thought experiment to which I have no immediate answer.
Good on you and thanks. I'll try to sleep on it and get back to you.
M.
@TK, Right. It does not matter where a cycle starts as long as it ends in the same place. I like your running in reverse analogy destroying energy. I have my head around the simulation again and cleared up my conceptual error. Making quick progress towards another PDF release soon...
Quote from: TinselKoala on August 23, 2012, 08:46:27 PM
In our double ZED system if we let go - they equalize - this does not mean that both ZEDS are in the middle - but the heads inside the ZEDs are equal - one can be on the way up and on the way down.
The "Bottom" is never seen - the set up process is designed to have the lowest point - above the bottom - or else the pressure from the weight will drop.
And Yes - on the way up the Hydraulic load is the output from the changing the head - and on the way down - the weight causes the output of water pressure - transfer of the head.
It is a dual inverse process - both sides are producing in both directions.
The non linear function is due to the distribution of head in varying diameters (layers) of the ZED, the head distribution on the down stroke favors the smaller diameter - making the weight production (down stroke) more productive than the cost of the weight on the upstroke.
Wayne
Quote from: mrwayne on August 23, 2012, 09:13:25 PM
Wayne
I realize your questions are mostly rhetorical TK - the cycle can start anywhere you like - like mapping a 4 stroke Otto cycle - it just makes more intuitive sense to start a cycle at equilibrium before fuel or forces are added to change the machine condition from static [equilibrium state] to dynamic.
Yes, what you propose is the norm - take a normal hydraulic jack/ram for example - a small force is applied to a small input piston area over a long stroke distance - this generates a pressure in the hydraulic fluid [pressure = force /area] - due to pascal's law the pressure is transmitted equally all thru the fluid - the pressure acts on a large piston area acting over a short stroke distance at the output end - since .. force = pressure x area .. the force is greatly magnified - it can be used to raise a masses PE like jacking a car.
BUT ... Work In [ f x d ] joules = Work Out of raising PE [ mgh ] joules - so you could just as easily reverse the system & apply a large weight force [with PE given to it by WD] to the Output end to reset the Input - zero sum energy game [not considering ordinary losses] in either 'cycle flow' direction as you propose in your thought experiment.
Where this becomes perhaps less obvious is when Potential Energy is raised by a system having Work/Energy done on it as described above - once the Output seen as increased system PE [e.g. raised mass or
increased pressure] then that PE could be given back again to set the system to equilibrium [& positions of least PE] - IOW's, no Work/Energy should be required to reverse the cycle direction to return PE gained [other than covering system losses of frictions etc] N.B. WD joules were expended to give initial the mass PE.
What Mr Wayne describes does not fit any world view I currently hold because he seems to say he can raise system PE [pressure] with no Input Energy, once the system is given one-off initialization pressurization - And extract some of the PE as Work/Energy Output, then use the remainder PE to reset system to lowest PE equilibrium conditions again, & maintain system initialization pressurization - all using gravity & initial energy to pressurize the system - this is not a description of an
engine as I know it, nor a zero sum energy game, obviously !
So ... I guess that's why I follow the discovery process of builds & sims - in the hope that new science & logical understanding will unfold of apparently paradoxical machines/engines which will educate me & alter my world view - OR ... that process reveals a logical error.
Hi all,
thanks for your posts, you are triggering new thoughts...
Yesterday I was looking again at picture of complete ZED cycle. I noticed two new things for me.
First: in fully prechared step is pressure in inner container 8psi. After full stroke step there is still 8psi. New for me is that water is being added also during stroke not only dyring precharge step! Precharge step is clear it has two phases, first is equalization to 6.7 with other ZED then in second phase hydraulics increase this to 8psi.
Second: Where is water added. I always though water is added only in inner cylinder under pod. But picture suggests watter added also in containers for second riser and third riser, see water level in 2nd and 3rd container after full stroke. I thought those 3 inner containers are completely isolated and only precharged to certain volume of water and air at certain pressure. Maybe just picture is not correct...
MrWayne can you please clarify this?
Marcel
@MT let me try to answer your questions. You are correct about the charging of the ZED having two phases.
Note that the waters in the two zeds are kept separate. Look at the pictures on Wayne`s website . You will see two convoluted rubber bags. They are linked mechanically so as one fills, it squeezes the other, causing it to emit water under pressure.So as one zed discharges, it is starting to inflate its rubber bag. This squeezes the second bag, causing it to inject water into the second Zed. This movement would stop when both Zeds are at the same pressure. But at this point a hydraulic ram, fed from the hydraulic accumulator, causes the process to continue.
Water is only ever fed into a Zed at one point, the bottom of the pod chamber. You may have been confused by what I think are drain taps in the bottom of other compartments. These would be for set-up and maintenance.
The rise in water levels in other water masses is due to the pressure of the water injected into the pod chamber causing air and water to move through the system towards the outside of the ZED.
Quote from: MT on August 24, 2012, 03:00:38 AM
Hi all,
Marcel
Hello Marcel,
First - good question -
You are correct that once 8 psi is hit - we continue to add water - only to the pod in this model.
Water added after precharge is stroke volume - at the same pressure.
The water levels change in response to the increased air pressure - caused by the input of water into the pod - they are all connected via the layering system.
p.s. this is a very very old drawing - so they are conceptual - and need to be understood in that manner.
We now control the water levels and the reaction in our optimizations.
Thanks Wayne
@mrwayne. A quick question, and sorry if it has already been answered. In building a table top model of a Zed. is there an ideal ratio of Diameter to height? In other words,, is tall and narrow best, or short and fat?
Many thanks.
Quote from: neptune on August 24, 2012, 09:27:07 AM
Many thanks.
Good question;
Capture method:Since the stroke length is determined by your flat topping the output - and the overlap of the ringwalls and Riser walls are reduced in this model during stroke - length is better.
If you are trying to capture the ideal and the lesser value during stroke - width is better.
Give and take:A short wide model has a shorter stroke and greater lifting capacity -
A tall model has a longer stroke and or has more wiggle room.
A short model needs less precharge volume (assuming the Pod is the same size)
Additional consideration:If I was doing short and fat - I would do larger gaps - reduce the pod size.
I recommend three times taller than the width of the average of the diameters - sounds funny - but it works pretty good as a starting point.
Mechanical function: - if you are using / stroking, or squeezing a pump - you can use a lever to increase stroke length (short and fat is fine) - as long as you designed the force to accommodate.
If you are pumping directly from the ZED, then you know the stroke length, and power needed
Close the loop: (assuming you have the power down)
You must have enough stroke length for precharge and stroke volume - my machine is limited by the pump selection - it could do much more if I had matched the system to its capability.
Wayne
@Mrwayne. Just what the doctor ordered as we say in the UK. That is great information that will benefit all who wish to replicate.
Attached is information on how to calculate water height using sensor Psi for the non-transparent model builders. Information was gleaned from one of Wayne's calculator. The sensors do not have to be directly connected as shown. Other methods, such as combinations of different types of tubing to the sensors could be used.
Edit: Tubing from the bottom with an air column extended upward would allow for the use of cheaper air sensors, instead of water sensors.
Regards, Larry
Quote from: webby1 on August 24, 2012, 02:38:08 PM
A test I did a while ago.
Using my 345g piston and a 680g lift mass.
Setup system so that the piston resting on the water holds the lift mass up just a little.
Place cup on top of piston and add 70g of water, piston sinks about 1\2 inch and the risers rise just shy of 1\8 inch, add another 70g of water to cup and piston sinks about another 1\2 inch and risers rise about another 1\8 inch, add another 70g of water and piston sinks to bottom and risers lift until blowout.
Reset the system but this time I hold the risers still and add about 120g of water to the cup on top of the piston, piston sinks about 3\4 inch, slowly allow risers to rise and the piston falls about another 1 inch and the risers lift over 1\2 inch but under 3\4 inch.
I tried adding more lift mass but the results were similar up to a point where I was not able to lift and any addition to the input just blew water out.
My conclusion is that the more potential stored under the risers the better the lift.
Well Done!
That effect become more dramatic with larger gaps ...
The idea of keeping energy in the system was counter intuitive to my Engineers - until they saw that test.
Keep it up!
Wayne
Quote from: mrwayne on August 24, 2012, 08:32:17 AM
Thank you MrWayne and Neptune for response. It is then as I expected.
Marcel
In the short video from Mark Dansie linked a few pages back, the system is started by operating an electronic control panel. This panel is clearly active before the system starts running. So... please correct me if I'm wrong... the electric control system is running off of batteries that are charged and kept charged by the output of the 500 watt PMA . Right?
I have been under the impression that the machine would run continuously until it was deliberately shut off. In other words, it could run unassisted by outside power for days, right?
Am I right about this?
Can we please know just what the maximum run time has been, so far, for the device that Mark D. shows in that last video? Minutes, hours, days? How long has it run for, maximum, from starting it up by pushing the button, adding nothing, subtracting nothing but the electrical power used to charge its batteries, until it stops or is stopped?
I like TinselKoala's replication of Heron's fountain.
Here you find a nice explanation of Heron's fountain: http://en.wikipedia.org/wiki/Heron%27s_fountain
The fountain in Tinselkoala's latest video http://www.youtube.com/watch?v=3fYltvNPU0U (his nice contraption) has one more "chamber" at the bottom and a "riser" in the chamber which would be the first (lowest, bottom) chamber in an original Heron fountain.
I would like to ask TK to explain a bit the differences between the original Heron fountain (e.g. as depicted in http://en.wikipedia.org/wiki/Heron%27s_fountain) and his set up. A drawing would be perfect. But I do not want to interfere with TK's ambitions to save the world and with possible future patent filings. I understand that TK has to safeguard his investment. It is much easier to save the world as a rich Koala. Koala's need a lot of Eucalyptus leaves every day. I wonder where he gets them from in the US?
Greetings, Conrad
P.S.: The Wiki-page http://en.wikipedia.org/wiki/Heron%27s_fountain contains a hint at increasing the output pressure: "The fountain can spout (almost) as high above the upper container as the water falls from the basin into the lower container. For maximum effect, place the upper container as closely beneath the basin as possible and place the lower container a long way beneath both."
Quote from: webby1 on August 25, 2012, 02:30:13 AM
Hiya TK,
Let me pair this question down to what it should be, without all of your inferences.
Wayne, can your system run without the battery. Could you replace the battery with capacitors to run your valves and control circuits.
Oh,, by the way this has been answered.
Due diligence may be required.
Did I touch a nerve? Sorry. I am "inferring" nothing, I am asking a simple question. The machine obviously had some power to the control system before it started running. This power came from its internal batteries I AM ASKING, or was it supplied by the wire we can see in the video coming over from the top of the building to the top of the apparatus?
And I am asking what is the longest time the machine has actually run? I've been assuming it has run for days, but lately I'm beginning to think it has only run for hours, before it stops or is stopped for some reason. I AM ASKING these things because I either don't believe that they have been answered adequately or that they have not even been asked yet.
Who said anything about capacitors? Capacitors? I don need no stinkin capacitors....
I'm just asking for another set of simple numbers.
And it's perfectly fine to me if it needs the battery to run properly. So does my car. I just want to know where the energy in the battery comes from. In my car, it comes from the alternator which is powered by the engine which is powered by the gasoline I put in.
@Conrad: Shh... pretty soon you are going to discover Heron's other invention.... the fire pump.... which sure looks a lot like a twin-zed system from the first century CE...
As the world will soon learn there are other ways than merely fiddling with spacing and heights to make a Fountain of Heron work better. A little. For a few minutes anyway.
Oh.... and I have them shipped in from northern California, by the bale. Almost out, too, got to re-order, thanks for reminding me. (One time they sent me some Tanna leaves by mistake.... too strong for me, I had to give them to Mummy....)
Good Morning - TK
I see we are back to sending questions sent to you by others.....
Webby is right, this has been answered and answered. - might be good to confuse a newcomer.
This time though - especially with the photo - I would call dredging - looking for a dead body - or hoping something will stick.
Guilty until proven innocent - even if we have to dig a body up - a crime must have been committed - that is what your Friends believe - let them due their due diligence's.
To ALL:
The ZED can run completely without electronics - remember the only thing needed is a way to change direction of the hydro assist.
Starting and stopping the system is as simple as blocking the the flow at any point - and opening it - you can do it with a manual valve or electronic. - this is not a momentum system.
That model - the closed looped model from last November - was not running a Generator - and the energy to turn the directional valve and power the five sensors is discussed in Mark's Video - and yes that energy was accounted for.
As I shared before - Mark and I spent the entire day (before the video that is being referenced) completely evacuating the system - and completely resetting it - counting for every scrap of energy - even filling the tank with water.
He spent the next entire day going over the engineering and design.
P.s Mark is really sharp - these people who are discrediting him by these claims of extension cords - not so much...
When you see us walk up and start the machine - it was the next day - early in the morning - (yes we had run it that same night) it is just the camera did not record well in the dark.
The primary purpose of our Unitronics Human machine interface - was to track pressures during a run cycle.
Back to "The picture...."
The clear plastic bleed hose (you were told extension cord) attached to the other hydraulic cylinder.. I used for venting/bleeding air out of the hydraulics is close looped to the reservoir.
Originally I climbed on top of the ZED - carried a bucket and drained the air out of the system - after several messes - eventually I hooked up series of clear hose in a loop returning to the tank.
When I built the next system - I lowered the hydraulics to make it easier to trap and vent air - currently we do not have any air trapping in the system (YEAH!)
If you look at the "Tree" when Mark points it out - laughingly, you can see the clear hoses better and the manual valves.
TK, Here is where I take offense to who ever is feeding you this clear and intentional lie - the photo you show is the only angle that makes the hose look like it is coming from the building - the same hose can be seen in several other shots as being connected to the other cylinder with more shut off valves between both ends. Please use your Koala brain to thinkabout that and the intention for a bit - you have defended these people several times - it is not good form.
My conclusion of this round - it is intentional misinformation being spread to you - and you shared it - thanks for clearing it up for others. I could be wrong - but it seems you are being used..... by an intentional liar.
The Laughable point - don't ya thing Mark would have Noticed a power cord running from the shop as your friend claimed?
p.s
The whole system was on a concrete pad - elevated about 24 inches off the pad with blocks to give access to the entire system.
@ ALL
I want you all to remember one thing:
I asked you to replicate and discover for yourself - I even offered to fund the experiments and have some, and will others.
At the same time three unprofessional men have vowed to try to take me down regardless... some call them skeptics even defend their attacks - I differ in that opinion.
A true "Skeptic" seeks the truth to protect all - these three men are spreading lies, you all know who they are. Currently they are trying to associate me with people of poor character.
I am praying for them, eventually they will learn that our system is real - in this world with a history of errors and scammers.
They will see the benefit our system has to the world, I hope they use the same energy to tell the truth.... I can hope for them.
@TK, I like skeptics, I was honored Mark came - when he told me that it would take him ..on average ..two hours to show me my error - I said - "I would rather know my error that to be misled - or to misled others". He did not - and he shared this with many others. We are still in testing - His final report will be out in due time.
I do understand that some men lie to support their vendetta.... I would appreciate you looking at them with the same eye... you do me.
Some men have done their due diligence - without due diligence - making conclusions is beneath the lowest position of a Skeptic.
Please help keep that important position - a true skeptic... one that can be trusted.
Wayne
Quote from: TinselKoala on August 25, 2012, 01:53:09 AM
No, - we did not run a generator back then.
No, that machine was not designed to run indefinatley - like Webby's model but bigger and then we close looped it - like the $10K challnge I have right now.
That system was to account for energy in and out - in all forms - since none of the forms of energy "out" was used to produce electriciy - the battery would have died.
Yes, If the system used mechanical valves to change directon - it could have run until it broke - which is what we did - three times.
No, I am not sharing run Data with aynone, until we have the system ready to be released - tested and scrutinized which will begin when Mark advises we are ready.
A point for clarity - I designed the system from my theory to be 500 watts - so that after all losses I could generate excess power.
Next, the video of that model was to show the system running under its own power - and more importantly - that the water and air put in the system during precharge - did not get consumed.
It was a hard thing for people to wrap thier minds around the idea that once the system was charged - no new energy needed to be put in to run continuously.
Wayne
What is the longest time that the system has run?
What is the power source for the electrical panel in the video?
Two simple questions, nothing implied or inferred. Two simple questions, answerable by two simple declarative sentences.
"The electrical power running the panel and the controls in that video came from ....... and the wire that you indicate in the picture is ......".
"The longest we have been able to run for is ...... hours, or ..... days.".
Yet you choose to provide another half page of innuendo about me and my motives-- which you don't understand at all --- and you choose AGAIN to dodge the questions.
You have said that you have a simple three layer system that is clearly overunity by itself -- your own exact words. I have asked you REPEATEDLY how this clear overunity is determined for this simple system and what is the input work and output work for this simple clearly overunity by itself system. I have asked you this question about nine times now, and you have not deigned to answer.
And now it is clear that you are not going to tell me the longest running time, or where the electrical power comes from or what that wire is in the picture.
So I feel very free to make my own INFERENCES, from your lack of straightforward responses to these simple questions.
Simple questions, which, in spite of all your protests, you have NEVER answered.
OK, then tell me this much: Are you refusing to answer me because you don't know the answers, or because the answers might be embarrassing, or reveal too much, or perhaps they are just too MUCH TROUBLE for you to answer, about the machine that overturns hundreds of years of WORK by many other people, destroys thousands of careers, sets thermodynamics on its head?
Every time I ask a simple straight question that I think you should be EAGER and WILLING to answer..... you dodge it and start your attacks on my motivations and character, coming perilously close to the paranoia that people like johnny874 exhibit when challenged on their claims.
You can BET YOUR CYNICAL TEN THOUSAND DOLLARS that if I claimed to have what you have I'd be able and willing to answer these simple questions IN SIMPLE DECLARATIVE SENTENCES. Not paragraphs and pages of character attacks.... which only indicate that you either DO NOT HAVE the answers I request or that you DO NOT WANT to answer them for some reason. In which case, a simple declarative sentence to that effect would have sufficed.
QuoteNo, I am not sharing run Data with aynone,
Ok, that was an honest answer, so I will stop asking you for the all-important run data.
How would everybody respond if I refused to tell you how long my Perpetual Water Pump runs for? It runs for a LONG time..... and the larger and taller the reservoirs the longer it will run. With NO electrical input power at all, not even to start it. But no.... I'll not give you the critical information you need to determine if it's worth overturning science or not..... just pay no attention to the man behind the curtain at all.
ETA: Your allegation that somebody is "feeding" me or telling me things to ask you about is a great insult to me. But I'm used to being insulted when I start asking the right questions. Just like Chief Inspector Morse.... when somebody doesn't want to discuss something, that makes me want to discuss it all the more.
QuoteThe Laughable point - don't ya thing Mark would have Noticed a power cord running from the shop as your friend claimed?
The laughable point right now is that you seem to be claiming that it _did_ have external power for the control system.... you say this one had no generator, no batteries charged by its own running.... but you are also saying that Mark would have noticed the power supply cord if there was one.
So where does the power for the control system come from? It's another simple question that you find hard to answer with a simple declarative sentence: "The power for the control system and sensors in that unit comes from the shop, it comes in by the yellow extension cord " or whatever "that can be seen here" pointing it out in a photo.
You KNOW I'd do this much for you, I hope.
And just because several people see the same holes in your story does not mean that they are working together in some big conspiracy against you. The only information about you and your system that I have been "fed" is that its longest run time so far has been a few hours.... and that information came from somebody you have had on-site -- NOT from one of my skeptical "friends", whoever they are. And I've asked you directly if this information is correct or not.... and your answer is that you will not share run data.
TK,
I must be tired - because your questions have been answered.
Wayne
@Conradelectro:
Koalas aren't very good at supplying drawings of our work. We prefer to show things more graphically using pictures and videos. Some people don't like the shaky camera but it's the best I can do.... all the other people in my grand conspiracy seem to be "virtual" in that I never see them and they are never around to help me to do anything useful like hold a camera. They only show up on payday.... wait.... there aren't even any paydays to worry about these days, so I don't even get to see them then, never mind.
The difference between my PerPump and the standard Fountain of Heron self-powered water pump is that I have incorporated a single-layer (I think) TinselZed in the lower chamber. I call it a TinselZed because the floating Pod displacer and the first Riser1 are locked together so that they lift simultaneously, and I think this is different from MrWayne's Zed which has a free pod separate from any riser, although it does push up on the innermost riser when it floats.
The only inlet to the lower chamber is to the bottom center, that is, to the pod chamber defined by the inner ringwall sealed to the bottom of the main chamber. When the pod/riser is in place there is a thin layer of water between the pod and the ringwall, and another fatter layer between the ringwall and the riser skirt, and then between the riser skirt and the chamber wall another fatter layer of water. All three layers have surfaces that vary in height with reponse to the pressures inside, in just the same manner as the Zeds do with unlocked floating pods in MrWayne's system, if I am understanding that system correctly.
I've found that with just the right amount of "precharge" water in the operating TinselZed chamber, the operation of the pump is somewhat enhanced over that found with no "working" parts in the TinselZed chamber.
So... I have made a table-top self-powered water pump that will pump an 8 inch or greater head, which uses a modified Zed to enhance its pumping ability. This pump will run indefinitely, as long as its input reservoir is kept filled and its output reservoir is emptied. There is a small amount of useful power that can be extracted from the fountain portion by running it past an overshot wheel, for example. This "excess" power could be extracted over the entire time that the pump runs, could be accumulated in batteries or capacitors, or used to lift a small weight.
A test of this pump, showing the action of the modified Zed working to enhance the output flow, can be seen in this irrelevant video on my YT channel here.
http://www.youtube.com/watch?v=AlLYD4CSJLU
No... I am not claiming any "prize" even though I think I've fulfilled the letter if not the intent of MrWayne's cynical challenge. I've spent no money at all on this project, unless you count the amortized cost of the instant coffee. My consumption has gone up since I've started this work !
What I have shown, I believe, is that there is some effect on internal pressures caused by the operation of the TinselZed and that this effect seems to enhance my PerPump's ability to pump. Take that or leave it, for whatever it is worth to whomever can use it. Me... I'm pretty well done with being insulted for my efforts to understand what is going on here.
TK,
I tire of your effort to ask questions outside of the bounds of my limitations and then asserting a nefarious motive. I have put up with it to allow you time to do your due dilligense.
Since you first came to this page - we have repeated I am not here for an armchair review of our equipment.
The offer was - If you want to participate - get your hands wet. I will not be in the business of telling you how to think or observe the repeatable characterstics of our ZED technology.
Each time you rant about how I avoid your questions - let me be clear - and respectful - you were told in advance - stay on topic - badgering and head gaming is not effective. Thank you.
Your questions and comments give me cause for concern.
What is your motive for coming to a discussion where I am sharing how to build a ZED and trying to turn the topic into a review of our Hard earned research and data collection?
From my poor memory:
You have asked about our input and out put
then Energy
then the patent
then the sensors
then the pumps
then the batteries
The run data
You show - two photo misidentifying a hose connect to the other ZED and assert it was a power cord from the lab.
You were shocked at our initialization system.
You also said you would keep nothing confidential.
you have thrown me away into the idiot file and picked me back out on to the rim.
And you have not persisted on diverting the subject to your personal desires - to find something "secret" within our system.
You have warned that you may file the scientific papers before others..
Now - Exactly what do I owe you?
Who told you that you have a right to hard earned work, discovery and effort - just because it is free energy?
Thank you and good day.
p.s.
And I do not need to know anything about your pump, it is cute. I hike to the top of the mountains to see natural springs - at the top of the mountain...pretty cool.
Have you all seen this?
http://www.youtube.com/watch?v=OS1KXMsE2qk&feature=plcp (http://www.youtube.com/watch?v=OS1KXMsE2qk&feature=plcp)
Does not work with water...but works with beer. Who knew?
Obviously it is temporary but.....pretty cool to see.
Bill
Quote from: mrwayne on August 25, 2012, 12:19:51 PM
TK,
Wayne
I have been completely through this thread several times and I have not been able to find your answer to this question here:
In your simple three layer system that is clearly overunity by itself-- your exact words -- how is the clear overunity determined, and what is the input work and output work for that simple system that is clearly overunity by itself?
If you've answered this question before PLEASE give me a link to the answer, if you don't want to write a short paragraph answering it again. You have here made a claim about a simpler system than your large, difficult to analyse one, and I am just asking you to support your rather amazing claim.
And those other questions I've been asking that you say you've answered before.... do you mind if I summarize what I understand to be the answers?
How long has it run for, maximum? Answer that I believe: A "few hours".
What supplies the power for the control system in the short video from Mark D. a few days ago? Answer that I believe: The same mains supply that supplies all your home's and shop's electrical power.
I don't know where this power comes into the system... you say Mark would have noticed an extension cord.... well, where DOES the power come in then, if not by the "thing" I indicated in the frame from the video? I'm sure Mark would have noticed if there was NO power cord but the thing still lit up anyway.....
Please correct me if I am wrong about these things. It's easy to do... simple declarative sentences of the form "The power cord for the controls is ..... " .
You have said that you aren't going to share the run time data.... OK, I'll stop asking about that, if you stop claiming that it runs for hours or days without giving the actual numbers.
At least we finally did get an answer to my earlier question that took you so long to come right out and answer .... you have a patent application filed with the USPTO, not a granted patent.... yet.
Quote from: TinselKoala on August 25, 2012, 12:10:36 PM
TK to date
All "Holes in the story" have been self imagined.
As I said before - We deal with the truth here - not imagination and speculation..
Wayne
Good day.
Quote from: mrwayne on August 25, 2012, 12:43:58 PM
TK,
Who exactly is ranting? Perhaps you need to check the definition of that term. I am asking questions that you have NOT answered adequately.
You are claiming something that is contrary to hundreds of years of scientific research and experimentation and that is inconsistent with the major system that is used to understand and engineer the world around us. You should be able to support that claim against any and all comers... IF IT IS TRUE.
then Energy
And you have not answered properly.
then the patent
The PATENT APPLICATION, you mean....
then the sensors
Please show where I have ever asked about your sensors.
then the pumps
then the batteries
I have asked you how the batteries get their charge, yes.
The run data
Two photos? And I misidentified something? I ONLY ASKED ABOUT IT, what it was, and I only showed one photo that I can recall. Please show where I ever asserted that it was a power cord from the lab. A question is not an assertion.... calling my question an assertion is... er... well, Mr Wayne, it is a statement that is untrue, and we have a name for those statements here south of the Red River.
Shocked? Did I say that? Really? Where? Please point it out where I said I was shocked by your initialization system. For the record, the only thing I find "shocking" about your entire system is the evident cost of it.
What I told you was that I would not carry on back-channel communications with you unless I could share the information you gave me publicly. I also said -- in a personal communication -- that if you engage me in an official manner I would be happy to sign and abide by an ironclad NDA. Thank you for not mentioning this in your present flame.
You owe me the straightforward and unvarnished TRUTH.... and you owe this to the world, and most of all to yourself. As far as scientific papers go... you have shown neither any science nor any respect or understanding of it. What I do with what I learn with my own apparatus and on my own time.... is my own business, and I'll share it with whomever I please and write whatever I like about it. You can rest assured of one thing, though: what I say and write and show will be the truth, and it will be testable by anyone with the ability to test it for themselves. I won't be claiming patents when I don't actually have any, for one thing.
You have not demonstrated any free energy to anyone's satisfaction who knows how to measure energy or work. You've had lots of opportunities to do so and you dodge them every time, with flames like this that simply attack your sincere questioners and divert attention from the real issues: How long has it run for, where does it get its electrical power, how is the clear overunity determined for the simple three layer system that is clearly overunity by itself.
More sincerity? You are welcome, and I hope you have a good day too. I intend to, myself.
p.s.
The natural springs at the top of the mountain ( in southern Oklahoma...) may or may not work by the same principle as Heron's Fountain. I doubt it, myself. But what about your large reservoirs, compressible bags, water flows, and air chambers? Does anyone really understand how they work? I doubt that too, especially since no one has yet shown just where any "free energy" enters the system, since all of the individual steps are underunity due to losses, and many of them are in fact quite lossy indeed.
@Pirate
... I knew ! ;)
Now the question is "which beer works the very best".
My current favorite is Shiner Wild Hare ale.
I am trying to understand the principle of the ZED but difficult especially with this wind of negativity, if the ZED is fake we will all discover it soon or later and leave one after the other one.
I just watched the MrWayne videos Travis effects videos 1, 2, 3 and 4 (yes I am far behind all of you...) and I can say from these videos that the Travis effect is nothing else than a piston effect on a gas (as clearly mentionned in one of those 4 videos), the larger mass compress the air in the cup (the right located cup has not reached the bottom of the aquarium), nothing new, as soon as the compression is removed the effect disappear. The air compression energy is provided by the mass itself. Only the latest (I believe Travis effect video 4) is interesting, but we dont know the energy spend by the air compressor to fill the cup on the right of the aquarium compared to the one on the left, this is essential information. Poor videos introduction to the ZED.
Hope to understand the ZED principle with better drawings or explanations. So many pages to read.
What is mainly missing in this thread is some physics (with no numerical values) to explain the phenomena, it seems to be all based on the Archimede force, with so many scientists and engineers having seen it, build it or think at it, something should have come up, all I find are numbers and values in mm, pounds, PSI or whatever, they are sometime difficult to measure precisely like the air pressure in the 2 cups.
Hello mrwayne, TinselKoala and all.
Like some others I too have been observing this discussion out of curiosity.
Some observations:
Trying to be unbiased; mrwayne did say the power source of his control panel on his device in the pics & video, is a battery. Charged by his machine. -which was said to put out a total of 36 watts. He also said: ..."our 10K system is not much bigger than my 36watt model."(post1275) don't know if that means he built one or just on paper
When Mark Dansie. was there, (with the machine that was outside) mrwayne alluding to that it ran over night, and pressure readings were the same the next morning. It doesn't appear that there was any charging devices run by that machine to charge the battery then. When it was rebuilt inside his building, it does show charging equipment there run by his machine.
Mrwayne said his machine will run (when in working condition) until he decides to stop it, consuming no other power than what it develops itself. I think this is what mrwayne means when he says he clearly has over unity.
Mrwayne said he has funded money, so he must have convinced someone. He's also dishing it out. Webby was given $2k on his claim of a 145% efficient experiment.
This is all very incredible!
Reasons why a rational person would still question:
The promise of Mark Dansie. to do a long run test investigation was delayed, (near the beginning of this tread), and now seems to be indefinitely delayed or dropped. Mrwayne's last long run test of last weekend must have failed, so Mark Dansie was again called off.
Mrwayne has now taken a different direction. He is going to build a demonstration machine to prove his over unity claims and has offered $10k to anyone who also can.
So clearly; right now, he does not have a machine to demonstrate his claims. -otherwise he wouldn't have to build one now, or pay others too.
My simple mind says this is what should have been built at the start, before you dump time and money into constructing a building size machine.
Webby didn't have clear measurements and results to prove overunity. If he did, it should be easy to copy by any scientist to prove it also.
I'm not attacking anyone; there are just common sense observations.
I wish the best to all!
Hi webby
The suitable item that occupy 90% of the volume inside the cup does not lift with the cup and this is why that cup losses rapidly its ability to lift the mass. is this correct up to now? So the travis effect work only on small distance like the 1" of your example. I start to understand, what still surprise me is that the air pressure is same in both cups.
Quote from: webby1 on June 12, 2012, 11:56:27 AM
I love it when people compare apples to hand grenades :)
Simple evaluation of the basic effect should be viewed more in this way:
2 identical cups 5 inches tall 4 inches in diameter with vertical walls, 1 cup has its interior space occupied by a suitable item so that it has 1\10 the open volume. Place a balance tube between the top of the 2 cups, this keeping the pressure values the same. Fill the 2 cups with air, with the pressure being the same between them the air pocket will progress down the water column inside the cups to the same level, this level will be the bottom of the cups.
One cup will use 1\10 the air at pressure to reach this point as compared to the other cup, conclusion: it has taken 1\10 the energy to fill one cup as compared to the other.
Both cups have the same ability at this point to "lift" the same mass, so now the cups are allowed to lift the mass. One cup losses it ability to do so rapidly and so for it to continue the lift more energy must be used to fill it with more air, if we limit the "lift" to 1 inch then the amount of relative energy I must add will be 1\5 more for that cup, so to move the same mass the same distance in the same time one cup requires 30% of the energy the other cup needs.
No energy has been created, it has been used more efficiently.
Can we all just settle down for a minute?
Wayne, I think TK said your system did in fact appear to increase the output of the PerPump for a portion of the cycle....
TK, please lay off the instant coffee so late in the day (I'm LIT on diet Pepsi again myself...). It creates an aggressive Koala when we know you are really soft and cuddly (and have very pointy dangerous claws and teeth!).
Personally, I want to see more TinselZed experiments.
It's the only way to be sure. (come ON! Somebody gets what movie my "lines" keep coming from!?!)
M.
@mond: I do get them .... "believe it or not".... ;)
@parisd: Are we sure that the air pressure is the same in both cups? I've suggested connecting them with a thin tube at the tops, to make sure that they are, and see if the Travis Effect persists. Has anyone done this little experiment?
@MIdone: So thank you for making it clear. Let me summarize so that we can be sure that I've got it straight. The machine in the video that we are talking about, outside there. The control panel and other electrical circuits were powered by internal batteries, but there wasn't any electrical generator or other "output" from the overall system on that unit, and the energy in the batteries came from some external charger. Right so far?
Please note -- everyone -- that I am not implying... or hoping that anyone else will _infer_ that I find anything wrong or suspicious about this. I am just trying to get the phenomenology straight... what it is that I am actually seeing as opposed to interpreting from descriptions and so on. What does the device actually _do_ as opposed to what the theory says or what the inventor expects will happen when it's fixed properly.
And the longest observed run, unpowered and unresupplied with anything, has been "overnight". Right?
I say my PerPump "will run (when in working condition) until I decide to stop it, consuming no other power than what it develops itself." (MIdone's words). Not only that, I've demonstrated that it will run, several times, at least until it breaks down, springs a leak or runs out of water. May I then claim that this is clear overunity performance? If not.... why not?
I don't even have a battery. Is that why not, since we already know that all overunity machines must have a battery?
Quote from: MIdone on August 25, 2012, 02:35:53 PM
Some observations:
Thank you for the clarity.
A couple of points:
The System we had running last Nov - Marks second visit - we ran it that night after the complet evacuation of the system and reset - no that system was not allowed to run all night - the battery was not being chargered back then and it would have stopped
What I did say - barring mechanical failure - and having mechanical (latching) valve to switch flow directions - it would run continuously.
I call it overunity - because it has no input - that one overcame six mechanical losses and we had to bleed off the production in order to keep the pressure regulated -(low).
Marks third return was delayed because our "new" system would not charge the accumulator - and it took us three months and $60,000 dollars to find out that our multisection Ram - hydraulic cylinder had improper tightened Tie rods - which resulted in the outer housing of the cylinder to bend during high pressure.
He and the rest of the validation team have been patiently waiting.
Next - The direction change and the small model build in house was in response to feed back from Our Engineers ZED presentation.
They decided they wanted more than pointing at the machine.
The $5k and $10k challenge is to end the BS that others are trying to make stick on our real machine.
Webby's work is great - he and his team are going to do better. I am glad to help.
Lastly - the size of the system - before we knew why it worked - we knew what worked and so we built to that understanding - now we know why and how to optimize - our 10K system is much smaller than if we used the original theory.
Much much improvements has been made since - even our Data collection model.
As I have stated here before - we do have many people replicating the physics - and visiting - and without any help from me - models they send - agree with what our engineers show.
I want to thank you for your research - well done, good thinking and good opinions.
I hope this clears the mud a little.
Wayne Travis
To All,
I am going to begin selecting ignore in our options tab to people who intentionally misdirect the conversation toward their own goals.
So if you see a question that is worth repeating - please restate it - if you like.
Thank you Very much -
@ZED Replication teams -
We have four official teams working on the desk top model - fantastic!
In consideration of the time and effort - All four will receive Share certificates - of HydroEnergy Revolution.
Please share your photo's of your process from time to time.
@All,
I will be focusing on our validation now that our blockage was repaired - but I will answer questions as the come - at least an hour a day.
Thank you all who have suffered thru this last round.
God willing, we will bring Clean Energy to the World - and the Independence it brings.
Wayne Travis
Quote from: TinselKoala on August 25, 2012, 04:35:25 PM
No cigar TK, sorry ;) .. you need to complete the cycle & lift ALL the water back to its original PE's [that's additional Work Done] i.e. it must be able to replenish system energy losses & replenish system PE & then this would be OU performance.
It would be showing indisputable OU if it could do external work [like turning a gen etc] on top of the work to cover losses & lift the water masses back to their original positions - that would be a free energy engine that proved gravity was not conservative.
So far you have captured some of the energy of falling water that was previously given PE when you lifted it into position to start the machine [kinda like a ram pump uses a percentage of the water & its KE] - but you need to refill the 'gas' tank as it stands now - somehow you need to close that loop to claim OU performance.
Mr Wayne's team should have their new model ready possibly before the 4 replication teams since they have the advantage of familiarity I would think.
This is a process that leads to a result & it is that result I am most interested in because it should bring forth independent information as no one is following a set of blue prints supplied by Mr Wayne & his engineers - I would expect all teams results/performance to eventually align & have repeatable consistency after some tweaking suggestions from Mr Wayne's engineers if initial results are significantly different.
Attached is the ‘Travis Water Height calculator based on Outer Retainer Water Drop 4 Riser’. It has been modified for better clarity and handles small models better. Data was added (top right of first picture) based on Wayne’s comment that the model should be 3 times taller than the width of average of diameter.
It does not have any VBA modules, so it should work well with any spreadsheet software.
If you don’t have sensors in your model, the calculator can be used to predict the water levels and Psi’s at Partial Pre-Charge and Full Pre-charge.
The Gap value is for all gaps, air/water channels and below Riser/above Retainer. Does anybody need it separate for below Riser/above Retainer as it would make the model less distorted if a large air/water channel was used?
Note that these smaller models with larger relative Gaps have several advantages. Has a much better force advantage over the Hydraulic (peach line) due to a higher Riser diameter increase ratio. The ‘% of Pod change’ values (top of second picture in blue) are improved due to lower compression. Between those two and the 4 U advantage in this case, the OU should be obvious.
I will next be working on a 5 Riser version.
Regards, Larry
PS: Wayne thanks, for the ignore suggestion, works great. The constant aggravation factor with very little or no value towards the goal, is not worth reading.
Quote from: LarryC on August 25, 2012, 06:35:23 PM
Regards, Larry
Very Nice Larry and thanks for helping everyone.
The best part is - you only show the upstroke :)
On the "ignore" I tried very patiently - at some point you have to make a decision.
Keep up the good work!
Wayne Travis
TK, it looks like mrwayne has answered those questions in his post, and corrected me saying that it did not run over night. So oher then what we see in the video, I don't know of any statements of observed run times.
I think if you are interested enough; and confident enough with the claims and what information there is in this discussion and patent application; you could be the first one to build a continuously self-running, working ZED demonstration model to stop the BS, -and when you send it to mrwayne for examination, he will give you a prize of $10,000 Or you could shoot for the $5,000 prize.
His challenge is in Reply #1552 on: August 20, 2012, 11:47:07 PM, and he says you don't even have to beat his team who are switching gears to build one.
or...
patiently wait and see if the movie comes out; produced by Mark Dansie.
Enjoy.
@fletcher: no probs, mate, I agree with you completely. ;)
Let's just make sure we hold... er... everybody to the same standard, OK?
I mean..... if my PerPump machine springs a leak or is stopped for some other reason than it ran out of water, before it ran out of water, then we still don't have a fully complete cycle, do we? I mean, imagine this. We are doing a run and after some time ... the machine stops, so we look at the precharge water and air pressure and we see it's decreased. What do we conclude... OH, yeah.... we conclude that it sprang a leak somewhere, and that if only it didn't leak the precharge would remain and it wouldn't stop.
Makes sense to me. My car is the same way. It stops.... so I look in the gas tank and see it's empty. Darn.... must have a leak.
@midone - welcome to the group - I'm a newbie too.
Great posts.
Careful how you feed the bears; cute, cuddly and VERY creative - but they bite :)
Quote from: MIdone on August 25, 2012, 09:48:25 PM
You can't be serious. What if what I build doesn't run? I could be holding my mouth wrong, I could be using the wrong color water.... I could have a 60 thousand dollar torque wrench problem.
Besides, my PerPump is already just as continuously running as anything we've seen. Do you not think I could make it run overnight, before it springs a leak or runs out of water, by giving it very large, elevated reservoirs that I am allowed to precharge?
I don't want MrWayne's money, at all, and at this point I wouldn't take it if he offered it to me. And there is no way that I'd take thousands of dollars for a bunch of glued together discarded plastic packaging, anyway. If he wants to give away money so badly, let him give it to his local no-kill animal shelter or spay-neuter program, in the name of Eureka Archimedes.
or...
Enjoy.
Yes, thank you, I have seen that. Pretty funny. Even if his team makes the first selfpowered water pump using zeds as specified, he will still award the money to another independent team that makes one later. Quite an incentive, isn't it? To me it means that his team doesn't have now and has never yet had a small working model of their operating principle, and they are hoping someone will help them develop it. I've noted that 10,000 dollars is very cheap for such a device. If I had one it would be worth a million, instantly, and a billion by the end of 2012, and onwards from there.
And as far as waiting for the movie... I note your use of the word "IF".
Let me ask YOU something, there, MIdone, since you seem to be a talker and MrWayne has probably put me on his ignore list.
If YOU had a device that really truly overturned physics, thermodynamics, and engineering principles and created energy out of "nothing", even at the low excess rate of 36 Watts..... how exactly would you handle getting it to market, getting it "validated" or confirmed?
Wouldn't you be worried about the people that go around blowing up laboratories and stealing notebooks and prototypes, the MIBs who assassinated Nikola Tesla and stole his notes, the Big Oil people who have a great stake in keeping things as they are, the Mossad, who are known to steal what they want that might be of military significance, the people who "rifle" computers at a distance to steal data and images...... the Agents of Suppression of Free Energy, in other words? Moray, Tesla, Meyers, Papp... there are literally hundreds of cases in the literature of suppression of free energy technologies, and many of them weren't nearly as good as what MrWayne's got. By discussing it here on this forum.... aren't you practically sending out invitations?
So I've just got to wonder.... why are we discussing this here at all? Why isn't Mr Wayne sequestered in his very own laboratory at Boeing or LLNL, working for our Government on this project that has clear national security implications?
I mean... I certainly got YOUR message: you want ME to stop discussing it here.
Quote from: wildew on August 25, 2012, 10:01:34 PM
Great posts.
Yes, welcome MIDone! Good to see more newbies!
Wild animals are unpredictable and may bite the hand that tries to feed them.
Tk, you seem to be taking this ZED discussion seriously.
I have been observing it, and kind of just testing the waters now by repeating things already stated in this discussion to see the reaction. My suggestion to you was not completely serious, because I knew by your logic displayed here you probably wouldn't start building one. It was a bit facetious.
At the same time, I tried to point out things mrwayne already had answered that you may not have read.
At the beginning of this discussion mrwayne said several times that he was not here to prove his machine was overunity, (in his own mind he just knows it is, because of whatever he and his team decided). I believe he said he was here just to show this effect he named, and how it is used in his machine. He has done that, but has not proved overunity with the information presented. He wants people to take his word that it's overunity, and build it.
What's makes a person decide to do that without mrwayne showing a working one, and wave that important aspect by???...he convinced them, maybe by just repeating that it's clearly overunity enough that some want to believe. Some are convinced, because he presents himself as being convinced. There's that mystery of 'what if?'
This is what rings the bell to a lot of us as being an illogical reason, because the reality of hard evidence has not been presented. There are extraordinary claims, but we have not be presented the proof.
I may be wrong; but technically, I don't recall mrwayne himself ever saying that he has a continuousely self-running, *WORKING* ZED that demonstrates overunity. To him, he is sure at times something has worked. He was working on getting it working; for Mark Dansie to really dig in and test. He said he could get it working because it was just mechanical problems. Assured people that he could get it working because it was just mechanical problems. Has plenty of money to get it working; but that wasn't working. Old ZED isn't doing what ZED's are suppose to do.
I also stated a serious common sense observation that should make a rational person still question this stuff, that no one has seemed to pick up on. Accept maybe you just now. -This change of gears because Old ZED has got some Gremlins.
What I stated in my first post that should be obvious and now very clear to people; is that right now mrwayne does not have a working machine that can demonstrate overunity. If he did, he would not be now shifting gears to build a working machine to demonstrate overunity, to end what he calls BS -in his post, (TK, I was just repeating what he thinks is BS). Or trying to get someone in this discussion to build one for him, to send him to demonstrate overunity, for a prize of $10k. This really shows a sign of reaching out, to get out of a mess.
In my mind, as an inventor, this is what you would do yourself. Before you spend tens of thousands on a building size machine. Before you file for a patent on it.
What happened here, is what is called 'jumping the gun'.
I don't want to aggravate people by stating these things anymore. If people want to experiment, it's no problem to me. Something will always be learned.
If someone builds something that actually works that Mark Dansie is waiting to really test, great. Something caught this professional skeptics attention.
So enjoy.
Thanks for the welcome guys, and as I said before I'm just making some observations.
TK: Never claimed that, you misread me. I beleive Travis effect is a piston effect so pressure should be higher. I read it was equal and was surprised of that.
@webby: You think you've got problems... I have to unscrew the jars and pour out the water, to start mine over !
But in your case, I thought that was what the second unit was supposed to do... as the first one reached top dead center, or maybe just before, the second one starts mashing back down on the first one to drive it back to the start state. So the second one's cycle starts halfway thru the first one's cycle. For my PerPump it's a matter of keeping the input and output flows constant so that the floater doesn't hit the stop but is dynamically stable halfway up. It's not a cycling system but more like balancing on a basketball.
@MIdone: Thanks for the explanation. I'm not sure, though, that MrWayne has avoided making the direct claims, though. Until yesterday I thought the thing had been observed to operate for days... that is the impression I got, somehow, from the statements that have been made by various people. The specific fly in the ointment that you've pointed out... yes, I've thought that too, from the instant the news was out. I am reminded very strongly of Steorn, Orbo and the SKDB cult-club trying to solve McCarthy's problem for him.
But in spite of all this I still believe that MrWayne himself is sincere..... but mistaken, perhaps a little self-deluded, or perhaps even himself the mark in a long con being played by someone else.
It's clear to me that they have excellent technical assistance.... the welding is great, the hydraulics and pneumatics all look great, all of that very professionally and expensively done by people who knew what they were doing. But some of the problems that have been reported, and the lumbering, groaning, uneven operation of the machines we have been shown indicate a certain lack of ... something, I don't know what.... at the design level just above the actual construction of the machine. This sixty thousand dollar overtorque issue is a case in point, although I don't have enough detail to be able to evaluate just what happened and how to prevent, say, an innocent replicator from having the same problem.
@seamus 10n: I do believe that the Wright brothers flew many kites and tethered gliders, even invented the wind tunnel to test models during the years that they were developing their silly invention. They even soared, in unpowered gliders, making sustained flights in the updrafts at Kill Devil Hill, and learned how to fly and how to control their airframes. Only after they had lots of success with kites, wind tunnel models, tethered gliders, and actual soaring gliders, did they finally hang a motor and some propellers on their best glider design and exhibit it to the world.
Exactly backwards from the present case, it seems.
na
@Parisd. The answer to your question is in the quote from MT. Pressure stays at 8psi, because water is being continuously injected into the pod chamber during the time that the riser is lifting.
Parisd and Neptune,
The 2 pdf attached might clarify and answer your query with regards to stroke displacement.
It is also the criteria on how to determine the distance of the stroke (at the design stage).
Michel
Good Morning,
Just read all of the recent analysis's of my methodology and some humorous theories.
Let me clear a few things up, my methodology is simple -my methods are of a teacher - blessed with the understanding, patience, and concern for others.
From my years it is clear - not many things handed to you are kept valuable - but things worth keeping are worth earning.
This Invention has value far beyond any pot of gold, and claim to fame, any one man (wrong motives have been asserted) - the most value this machine represents is the education that will follow - and the new field of discovery that will bloom from it.
That Frontier is the end to what we labored here - it is worth and the reason we accepted ridicule, and very unprofessional treatment.
It is understandable - there is not a two hour movie showing the history of the invention - it is not on NetFlix - and so speculation is normal at this overlapping time of times. Discussing what should of been and what shall be - when it is happening...
It took four and half years to develop this system - and it is getting better every day - it worked a long time ago.
Now with respect - If I had been handed this machine complete - I would have never understood it at all.
If you "who speculate" had been privy to those four years - you would not only be supportive - you would do like so many from around the world are doing - you would be flying down here to be a part of it.
The reason to be on this site - "Some here have shown a willingness to learn".
Giving and serving the minds of others is what true educators do, and when others dive in - thier effort expands my ability to see the complexity from another angle -to see what others see is a gift - and helps to sharpen my ability to teach others.
The difficulty I have had in this discussion - is some of other students - as brilliant as they might be - are not the teachers of this subject - namely the ZED technology.
They choose instead to be the self appointed fraud detectors - just one wish I had - they should have become students first. How can they play policeman if they do not know the system. Very frustrating from both sides I am sure.
A physcologist wrote me and asked if I minded him following the story --he suspects that the internet has created a new paradigm in discovery - it could be the reason for so few inventions - I suppose that if edison had to deal with "the trolls" would he have tried 1000 times?
Teaching /sharing - is not a waste of anyones time, and when it comes to Good Engineers - rarely does one grasp the ZED technology the first time thru. Entering this with patience is a must.
We waited until we were far enough along that others negativity did not matter - and that is what seperates us from a lot of the inventions that end in error.
As Se3d said - (paraphrased) If someone thinks this system is simple - they have no idea what they are talking about..
And I personally say - Teaching is very much worth the effort - when you care for others.
One last thing - I have never charged for any class I ever taught, never charged a speaking fee, never charged for a lecture - and I have almost always supplied the teaching tools - That is part of my methodology.
And the "Why" do I do it - What would you do if you held one of the most promising technologies to help the suffering of mankind - run to investors - hide it in a lab - if you are a man of character - you would suffer indignations in order to bring it to the world.
It is the example my Saviour has demonstrated to me.
Wayne Travis
p.s
To all, My many thanks for your efforts to learn the ZED technology, do not fear, or be misled, it is not a waste of time or effort.
Learning something "Truly New" is at least as hard to teach - as it is to learn - thank you for helping me.
Hi Wayne.My understanding of where you are at right now. You have resolved the big problem that has been bugging you with the issue of the bolts/tie rods. So now you are back on track with your test programme, and when you are satisfied with the results, you will schedule another visit by Mark Dansie.
Question. In view of the above, is your team still continuing with the desk top demonstration model?
You seem to be in the mood to talk philosophy today.So here is a philosophical question for you. Many of your team members are hard sceptics, and originally came to disprove the technology. Then they saw something that changed their minds, and stayed to become part of the team.
The big question is, what was it that they saw that changed their minds? The answer probably varies from one man to another. Perhaps you could give us one or two examples?
Respect, neptune.
Quote from: neptune on August 26, 2012, 08:57:50 AM
Respect, neptune.
Hello Neptune, yes we are back on track.
No, the Demo Challenge is "On" - it has nothing to do with our validation delay - that was an assumption - not from me.
Our engineers decided that a very simple model would be helpful for their demonstration to the validation team.
As I saw the usefulness of the model they wanted and I was gifted the prize money - same time - one plus one = the opportunity to fund the ZFC.
You guys and gals are in ZFC - (ZED First Class) - your work will help teach generations - do you see the value in that? It is well worth the effort and funding.
Little Philosophy I learned - A wise man plants a tree that he might never be able to climb, so that others might be able.
One gift of encouragment I have over everyone else - Good Men and Women from around the world are sharing their OM Gosh moments with me - those will be in book, or movie lol.
The common term I hear - is goose bumps suddenly ran up my arms..... when the gravity of the discovery hit...pun intended..
As far as why others follow - that is as big a questions as why people who are very educated and do not think Free energy is possible - spend time on an Overunity web site?
I will leave that to the Others for now.
Thanks, Wayne
Quote from: webby1 on August 26, 2012, 12:41:19 AM
I appreciate being included on the back Chanel conversations,, I would like to be included in ALL of them,, thank you.
TK,
What kind of coffee do you like?? I will send you some if you simply will take a moment before you post,, you like instant? Starbucks has there
Iced Via caramel that is fabulous. Send M your info and I will send you some.
NOW,, children stop with all this garbage.
I have seen an anomaly,, I am playing with it and I am trying to tie it out.
None of this stuff that you are putting up here is helping me in getting there,, so if you are Not BUILDING, please ask questions that those of us that are MAY be able to answer.
TK, I have not been able to come up with a test that allows me to back the system up,, I have to over compress the risers with mass to start the reverse lift process,, HOW can *I* get rid of that problem.
MH,, yes what is needed is all the final data,, but if that can not be given then what may I be able to give you to get past this issue?? or at least move on to the anomaly that is in the room.
So, HELP ME HELP YOU, quit with all this stuff and give ME guidance.
Hi Webby1. In the quote above you are addressing TK, but as you posted this publicly, I feel it is appropriate to comment. What exactly do you mean by "back the system up", and "the reverse lift process".Exactly what problem are you trying to get rid of ? Do please clarify.
Hello Webby,
You are discovering the production difference between the up stroke and the down stroke.
The up stroke is captured by lifting a weight - and the process was Precharge first and then lift volume added.
The down stroke is pre charge out first (free flow) - and then pressure and flow out from the remaining weight.
The process is not a complete reverse.
Also
If the input load is still on - you have full head even after your lift - pushing the other ways like pushing a spring from both directions - only their is only so much give.
Very cool mind bender - output removed - still full power in the spring....................this is important.
If you wanted to lift the original input weight .....lift that weight directly and measure how much it weighs as the heads retract - that is measureable hint hint.
Lots to observe and learn here I promise -
Wayne
@Webby1. Thanks for that clarification. That`s a start as now I understand what the problem is. Sadly at this stage I do not know the answer, but the more readers who fully understand the question, the greater the likelyhood of an answer.
One way to look at it is this. Use the "divide and conquer" technique. The problem has to be either in the Zed itself, or in your input pump. Is it possible to disconnect your input pump? Or build a copy of it? If it is replace the Zed with a balloon and use the pump to pump water into the balloon,. Put the balloon under one end of a small lever[half a see-saw], and put a weight on top of the lever. So the balloon and lever now takes the place of the Zed. Do you still have the same problem, or not ?
OK, its a crazy theory, but it is something else to try.
Maybe Wayne has a theory?
Sorry, Mrwayne beat me to it.
Quote from: mrwayne on August 26, 2012, 09:51:24 AM
As far as why others follow - that is as big a question as why people who are very educated and do not think Free energy is possible - spend time on an Overunity web site?
Thanks, Wayne
Skeptics who don't believe in 'something for nothing' in energy terms [like harnessing conservative gravity] can still believe in potential for free-energy technology & engines derived from this.
For a layman any free-energy technology's modus operandi might be generically thought of as OU, hense the legitimacy of spending time on an Overunity web site.
The subtle difference between OU & free-energy is sometimes missed - an engine that uses a differential or gradient derived & harnessed from nature to cause asymmetric torque would be free-energy but since the environment is providing the energy 'top up' it would not be OU.
The world is not a dearth of such devices, in fact they are very common - solar, wind, water & tide power, barometric pressure & temperature/thermal devices etc - each has a natural cycle where the energy is provided by the environment for the basis of a free-energy engine, but they are not 'closed system' OU as you would describe it, using conservative forces - they are 'open systems' that do not invalidate the Laws of Thermodynamics.
Hence there is a much greater statistical probability of finding free-energy thru harnessing an environmentally occurring force cobbled to a mechanical device to exploit it than finding OU from conservative forces in a closed mechanical system.
That's why skeptics of OU spend time at a free-energy web site.
I agree wholly,
If you have read my letter on my web site - you understand where I stand on that same issue.
I would say that our ZED is a possibly a hybrid - at least mentally until fully understood.
Yes it appear to be a Black box supplying power - but if you remove one key ingredient - it does not work.
Gravity.
And if you turn up Gravity - our system works better.
The hybrid part comes in when gravity effects what is inside the box - naturally.
Now, when I shared this last time - an argument was made that Gravity was a Conservative field.
This is the point of our ZED, we have found a work around - the conservative field.
A very effective "work around" Gravity is our wind - just a little more predictable.
Thanks for your input.
Wayne
@webby: Ah, I understand now. It's not that you can't push down, it's what happens when you do . Yes, this is a problem in my TinselZed in the PerPump too, but in my case it's caused by the restricted travel of the riser/pod I think. When it hits the top stop there is still plenty of pressure coming in so it "blows the skirt"... I think that's the right term. You can see this in my output stream as a periodic fluctuation as the wasted pressure bubbles out beneath the riser's wall.
Just like in a Stirling cycle engine, it appears that the volumes and pressures have to be matched carefully and a bit of "inertia" or flywheel effect is needed. And I think that what MrWayne is describing is a sort of "overcenter" effect, where the system has to be driven that last little bit to get it past some compression or resistance before it springs back to the start of the cycle. Maybe. I'm having trouble with my translator these days.
QuoteI have to over compress the risers with mass to start the reverse lift process,, HOW can *I* get rid of that problem.
@Webby1 - THANK YOU for that comment ! - It may have greatly improved my understanding of the system by making me think about a comment of ( I think yours ) and several of Wayne's.
"Control the POD and you control the system." - Was that you? Deserves much more consideration... When you mentioned pressing down on the risers it made me review Wayne's test bed and remember that his "down-stroke energy input" is applied to the.... POD! by applying hydraulic up force to the convoluted bag of the sinking ZED ( at the same time down force is applied to the convoluted bag of the rising ZED ) - forcibly transferring the "post free-flow" pressure from the falling ZED to the one being readied to rise.
In a latter post you did comment that the POD had sunk but that the risers were still up. Is it possible your whole rig is too light? That sounds like the air is decompressing too much and not allowing the differentials to realign to the down position.
Maybe this starting to really make sense, maybe I'm just nuts. It "feels" like it's coming together for me....
Dale
Quote from: webby1 on August 26, 2012, 02:34:34 PM
back the system up,, make it go in reverse, use the risers to lift my piston.
Simple thought would be that the system should be able to work in both directions, it does but only sort of.
When the lift stops and the piston is down and risers up I can push on the risers and move them down and that lifts the piston, but when I do that I get to a point very quickly where I am compressing the risers to the point of blowing air out from underneath them, if I try and balance the system nicely and push slowly I see the risers go down before the piston goes up.
So, in one direction of operation I can measure the masses, measure the distance of travel and all that, in the reverse condition the values so far are not the same and I am trying to get to a point where the numbers can be compared and viewed correctly.
Why am I needing to add force to the risers to lift the piston when the system is in a state of balance?? Why do the risers change a little when lift stops?? Why is the lift head higher than the holding head?? these are the things I am currently looking at.
@webby1, this is the most intersting observation that I've seen posted in quite a while. Please let us know what more you learn about this apparent anomaly.
M.
Might as well watch something entertaining, while we are waiting for more demonstrations from visitors or replicators or whomever.
PerPump v 2.2 pushes over 13 1/2 inches of water head.
http://www.youtube.com/watch?v=L3UGTyc36f4
I used top secret information leaked (no pun intended) to me by C...........o and incorporated it into the PongChamber, which nearly doubled the output power performance of the self-powered tabletop water pump.
"sorry about the light" and the shaky camera work... the silly thing wouldn't start at first, and then the down tube came unplugged, and then I had my marks on the wrong side of the measurement tube. But I finally did get a measured 13 1/2 inch head above the fountain outlet, and also showed the nicely increased internal pressure afterwards. This pressure could probably be used to push down on the TinselZed of another pump, resetting it, if you had somebody smart enough to figure out the valvulation required.
Koalas don't do valvulation, much, except electronically.
@webby, if I may...
QuoteWhy am I needing to add force to the risers to lift the piston when the system is in a state of balance??
Perhaps it's that "overcenter" thing, where you need to do what the hydraulic assist does in the big boy.
QuoteWhy do the risers change a little when lift stops??
Perhaps you have a small leak of gas or water. That's what caused it in my TinselZed.
QuoteWhy is the lift head higher than the holding head?? these are the things I am currently looking at.
Leaks, overcenter effect against an air pocket, or just timing: the system gets to settle a bit, walls expand or contract maybe.
TK,
Thank you for keeping on station.
M.
I've watched the youtube fish tank videos. Is it possible, that the Travis Effect, shows that 10% of the air will lift 10% of the distance?
Hi all
i have not visited here for a while so I am sorry I did not see your emails sooner.
I have respect for many of you (Milehigh and TK) and would never lock swords with you unless I have a death wish.
I still have not seen the two day demo yet , but I never put a time frame on this. However as with all things as time carries on the confidence level always diminishes.
My observations some time go on a visit was it could hold pressure and keep operating for a limited time. I believe the longest run is 4 hours.
I was impressed by many of the people working with Wayne and thought it has a chance. But I will not say its real until a two day run followed by a team of very qualified engineers and scientists.
Many of you have called for me to call it a scam or busted but to be honest I am not qualified to debate the physics or mechanics. History is saying it can not happen, the engineers and scientists I have spoken to are divided.
I had advised Wayne not to debate matters in forums like this, just get on with it and get it running long enough so all inputs could be accounted for. i see no use in long debates and endless rhetoric. I am not sure Wayne is fully qualified to answer the questions but he does have some bright engineers on his team.
So I am just going to sit back and see if the day comes when I get the phone call to come down.
My other reason for as some of you put it you have gone soft on this, is it is sometimes about the journey. There is a lot of people involved at all levels and the journey is sometimes more important than the destination. Is it folly? I do not know but in depressed times in a rural community where this is coming out from it has brought a lot of happiness and good will from all walks of the community. Sometimes it is important to believe in things and I think the benefits can be measured in many ways.
However have no fear, I am still on my game in all other areas, busting an average of 10 technologies a month lol. (I hate my job as I always just once one would work)
So all those who wrote to me, thank you and your views are noted and I agree in most cases. To Wayne, just get on with the demo.
As I stated before, I have no time frame but as time goes on confidence will diminish. I have not signed of but at this stage a think a little more breathing room is warranted.
Kind Regards
Mark Dansie
Mark, thanks for all your hard work.... keep an open mind, let it all hang out... ;)
http://www.youtube.com/watch?v=yF7YLcoRbFA
Quote from: wildew on August 26, 2012, 06:14:09 PM
Dale
One problem that seems to occur, is that I fail to understand, in laymens terms exactly what is being said in some posts. Maybe it is just me,and this is intended as a constructive criticism.
So if I understand the above correctly, once the Zed reaches the top of its upstroke, we need to actually "suck" some water out of the pod chamber, to initiate the downstroke., rather than just allow the water to exit under its own pressure. Or to say the least, until the downstroke is started, we can not expect the outgoing water to do any "work" as in lifting pistons, or helping to charge a second Zed. Anyone agree/disagree?
Understanding how it all works. Some people have a eureka moment. For me it is a series of smaller eureka moments. Last night, for the first time, I understood how the concentric risers form a greater area of lift in a small space. One step at a time...
One small step at a time is MrWayne's stated intent so I'd say you are on the right track :)
I still have a ways to go...
To attempt to answer your question: Take a look at the full cycle image again. This particular question deals with the case where one ZED is at full stroke and the other is "at rest". Neither is at 0 pressure but one is at a higher pressure than the other. I think at this stage the output hydraulics are locked so neither outer riser can move.
First, a valve opens allowing pressurized water from the higher pressure ZED to flow back into the CB ( convoluted bag ) forcing it up, this action starts to compress the CB of the lower pressure ZED "free flow". Neither of the outer risers is moving but the pressures in the POD chambers are equalizing and the differentials in both are starting to change some.
Once the pressures equalize as much as they can, additional down force is applied to the CB of the ( still lower ) pressure ZED. This doesn't "suck" water from the ( soon to be sinking ) ZED it just lowers the pressure more.
At some point ( not clear yet ) after the differentials in the ZED being "charged" go positive, the riser control releases and allows them to move. The weight remaining on the risers of the sinking ZED keeps the internal air compressed. I don't think the risers ever separate and if they do, not by much.
The down force on the CB of the ( now stroking ) ZED, combined with the load, keeps the internal differentials "ahead of the curve" until the end of the stroke.
Very elegant, but complex, cycle.
And again - I may be WAY off still and if I am maybe MrWayne will catch and correct - and I'll learn more....
Dale
Quote from: markdansie on August 26, 2012, 11:05:15 PM
.... I am not sure Wayne is fully qualified to answer the questions but he does have some bright engineers on his team.
Thanks Mark for giving an update and that info of maybe a 4 hour run time. Your opinion was why I have been following this discussion.
From what I understood from mrwayne, is that HE is ‘The Teacher’, -the master of the ZED. And the followers of the ZED are the pupils. So he should be able to answer a few questions regarding his invention if he wants people to help him resurrect the ZED.
If I run some current thoughts by, would mrwayne and friends consider something that I don’t think anyone has brought up yet?
What ran across my mind is the density of the water and/or antifreeze mix Old ZED is first pre-charged with; and that density changing as it ran.
From what I understand, ZED is emptied, and all his workings checked.
It is then charged up with air pressure and fluid levels.
Now maybe it runs for couple hours before it stops.
...but, the pressures readings and levels are still the same when it stops.
What if, when it is first charged up, the water is saturated with dissolved O2/air.
As it is run, the dissolve O2/air is slowly being separated out, which would be gradually change the density of the water, which in turn would be changing the buoyancy.
This changing bouyancy, because of changing density, is what is making it operate for a short time until the O2/air is all separated out.
Applying varying pressure, as in the workings of ZED, to a water saturated with dissolved O2/air, is going to squeeze the O2/air out at different rates. And density and bouyancy will also change.
When you are charging a tank or lines with rushing water, it can get it saturated with dissolved O2/air. It’s the work that the little pump in a fish tank does.
Just thought this might be something to consider.
-Life really is better when you have a sense of humor ;)
Quote from: wildew on August 27, 2012, 06:31:48 AM
Dale
Dale, you are right.
And we never go to vacuum or Zero -
We do not actually have a riser control during operation - we do for set up - but during operation - the total resistance - the weight of the system and the hydraulic resistance (the upstroke output) is the natural riser control.
When the head (differential) reaches the point to lift - the input to stroke becomes a process of maintaining the differential.
To all - on another portion - the point I was trying to make yesterday concerning Webby's reverse question :
In a single ZED set up with a weight as the input - the cost of the input weight needs to be calculated in the whole cycle.
I am sure this is forth coming - the end of the stroke would be with the input weight back in the raised position -
With that in mind - what was the cost to raise the weight?
It is not the full value of the weight - because as you went to return it - the differential in the head helps to lift it.
So the cost of lifting the weight is the true cost of the weight - now compare that to the out put - and you are under way to understanding the ability of a single ZED.
We use that effect in the dual ZED to have a nearly continuous output. Or faster cycle times.
Good questions and good work.
Thanks Wayne
QuoteWe do not actually have a riser control during operation - we do for set up - but during operation - the total resistance - the weight of the system and the hydraulic resistance (the upstroke output) is the natural riser control.
Thanks for clearing that up.
Dale
Hi all
Kind Regards
Mark Dansie
Thanks Mark, and I do respect your advice -
I have tried not to engage in the debate - but to share - it is difficult to separate the two.
This has been a valuable learning experience for me, so much so that I do suffer long.
It will not be long now - so all the time past will be forgotten - the effort and results will not be forgotten.
Thank You
Wayne
Just a thought, if I understand correctly, for those looking for build material. These are graduated plastic beakers that you can probably cut the upper pour spout section off with a razor blade by rotating on a turn table.
Plastic Beaker Set - 5 Sizes - 50, 100, 250, 500 and 1000ml
http://www.amazon.com/gp/product/B004OA1VY6/ref=ox_sc_sfl_title_1?ie=UTF8&smid=A37SSOMGWCKVU1
Attached is the 5 Riser and a updated 4 Riser version files. They both have a new 'Gap Above Ret. / Below Riser' value. I added this because the previous way of using the Gap for both air / water column and above ret. / below riser causes a distortion effect with the larger relative gaps on a smaller model.
The attached picture shows output from the Idea Section of the 5 Riser and below is a 4 Riser. Again, the hydraulic is increasingly losing the battle as the number of Risers go up. The Riser + Ret. Diff. values are very interesting. Note how 25.135 is the same for Riser 5, Retainer 4 and Riser 4, Retainer 3 even though the Accumulated PSI values are not the same. This is due to the fact that the SI's are the same, but the total difference in pressure below and above the Riser is the same. They are the same all across but at the end of the 5 Riser it has the additional 72.65 value being added. Layers Rule!
@Neptune, Congratulations.
Regards, Larry
Quote from: cyber19 on August 27, 2012, 12:59:11 PM
Cyber19 - Welcome!
Nice find but also look for a set where the height of all beakers are equal. I believe that would replicate the risers more accurately.
Quote from: GreenHiker on August 27, 2012, 01:13:31 PM
Cyber19 - Welcome!
You could vary the cut below the spout to make the height equal on all if that is the only issue.
A few thoughts on building materials. For experimentation, a Zed needs to be transparent. After some thought, I feel that the best chance is to build risers and ringwalls from scratch, as this gives a better chance of achieving the ideal hight to diameter ratio. Wayne said that the best compromise is that the average diameter of the risers should be about one third of the hight, so this is relatively tall and thin. A good material for models would be the type of plastic used to make large soft drink bottles, but preferably bought as a flat sheet. Anyone know a source?
Look on Ebay at "Compass cutters." less than $5. Then all you need is patience and a good glue.
Rideout Plastics sells sheets in .010 and .020 pretty reasonably.
I ordered 3 of my largest tubes from them.
Dale
Having a Zed machine running 2 days instead of 4 hours is not relevant to proves or not OU, then after 2 days someone will ask for 2 weeks.
What is important to know is the reason why it stoped after 4 hours, is it because of a known or suspected hidden source of energy depleted or is it due to a conception problem (like a leak, an equipment failure, an pressure drop, too much friction or whatever else which IS NOT jeoperdizing the perpetual movement of the ZED if adequately corrected even if too costly or to complexe to solve at mrwayne scale.
So, to whoever can answer with certitude, what made the ZED to stop after 4hours?
Quote from: parisd on August 27, 2012, 03:42:59 PM
Hello parisd. The importance of 48 hours under load is that Mark Dansie thought that amount of time would exhaust all possible sources of potential energy, which would prove that the ZED is a net energy producer.
Of course skeptics will want more right up to the point where they become a commercial reality. However, Mark Dansie has set this as the hurdle for his team of expert engineers and/or scientists to spend the time and expense to understand and certify its operation. This would lead to very large investments and commercialization.
Important note for model builders, attached is Wayne's Bag Plumbing picture. Note that the input is reduced by pipe size and gate valve allowing adjustment of the input flow and the larger pipe size outlet flow is unrestricted. Should help with piston return. Check valves are cheap see http://www.usplastic.com/catalog/default.aspx?catid=489&clickid=redirect (http://www.usplastic.com/catalog/default.aspx?catid=489&clickid=redirect)
Regards, Larry
Mr Wayne,
I would like to hear your opinion of the gravity harnessing invention depicted below, since it seems to be using quite similar parameters to extract energy from gravity, even if this device is based upon a rotating system and depicted in a quite simplified sketch. Unfortunately this sketch is all documentation there is left from this once fully working gravity engine.
(This invention by the late Arno Werner was generating a dokumented excess output compared to input, and the scientists visiting Mr. Werner were openly confounded. As I recall from the TV program about him here in Sweden, the COP was very small due to the limited size of his prototype, and I remember him mentioning a German company willing to get involved in the construct of a bigger one. But unfortunately he died before being able to develope a more efficient prototype.)
Gwandau
Quote from: Gwandau on August 27, 2012, 07:13:31 PM
Mr Wayne,
Gwandau
Hello Gwandau,
I do not feel qualified to make a statement about the device.
best wishes.
Wayne
Quote from: LarryC on August 27, 2012, 06:51:13 PM
Regards, Larry
The amount of flow out must equal the amount of flow in, over a complete cycle, right? The same quantity flows out during half the cycle, as flows in during the other half of the cycle, right?
Hi all !
Effect is real, Free energy and overunity capable but shere size and complexity is issue
Proof through the roof for sceptics and such that supress FE. well done !
keep up the good work or even better join something more powerfull, smaller, easier to build:
- FDM by Igor Knitel
Igor Knitel
Perihelion Labs
Regards, Larry
Hello Larry,
And very good point,
We gained a stability and control - by metering the inlet - You could sink as fast as you want - but you would give up exhaust pressure (if you move faster then the heads can keep up - as the other layers tried to catch up).
The input - or the up stroke - can be put in too fast and too powerfully - the load is hit to hard or the production moment can be overrun.
When we hit it too hard - you can see a pressure spike of 15 - 20 psi - in a system that has a max head pressure of 10.4. - kind of a dead head against a soft head...
And the water will shoot over the walls.
Restricting the "inlet only" - allows you to control the input speed - without metering restricting the exhaust - allowing you to dial in the speed to match your load.
Larry and All,
It may not be necessary depending on your input selection - We use hydraulic unrestricted fromthe production - when combined with the exhaust pressure - it can move pretty fast -
Any restriction is a loss - you have room for it - but I suggest being creative on your input - that can solve it also.
Now, Once you do have your "speed to load" set right - it is no longer an issue.
Good work.
p.s. - for the Challenge- the system does not have to be transparent - cool that way - but I did not require that.
Transparent does give you more to ponder.
Wayne
MrWayne, see3d or others:
- What made the ZED to stall after a 4 hours demonstration
and
- From where would come the potential energy that could last up to 2 days ?
Quote from: see3d on August 27, 2012, 03:58:13 PM
@Parisd. Why did the Zed stall after four hours. We have not been told, but it could be any number of things. Remember we are talking about an experimental prototype, so things can suddenly jam, work loose, spring a leak etc. Reliability comes with time, and alpha and beta testing. Having said that, I was not there of course.
Mark Dansie`s job is, among other things, to detect fraud. So by asking for a two day run, he is eliminating
some of the obvious ways that the thing could be faked, such as hidden storage batteries, hidden compressed air tanks and so on. Two days is a period chosen more or less at random, as a balance between a realistic time period, and spending the rest of his life there. Whatever time period is chosen, there will be those who say it is not long enough.
That is my attempt to answer your questions.
Quote from: parisd on August 28, 2012, 10:57:14 AM
and
To@,
I understand why these questions are important - but they do not reflect the topics that our advisory team is willing to discuss at this time.
Our immediate focus is to resolve the external issue we created during our last upgrade.
We will be providing clear and accurate information regarding the principle of our operation and design, and our ability to use
Gravity as a non conservative field - if this is the advice of our Validation team.
I am sorry, but the Questions that "assume entropy" of an energy source do not yet understand our system.
It is not in our best interest to engage in debates at this time.
Thank you for your interest.
Wayne Travis
Classic.
Let me translate into English:
"We are happy to tell you everything except what you actually need to know to evaluate our system. Right now we are still trying to figure out why it still won't work as predicted by my theory. If you still have questions involving thermodynamics and the fundamentals of physics as they relate to our apparatus, you are by definition too stupid to understand the answers, so please go away."
You know, I just thought of a great way MrWayne could improve his credibility, even to the point of convincing an ignorant Koala like me.
Get over to Norman, to the University of Oklahoma's College of Engineering's School of Aerospace and Mechanical Engineering, in Felgar Hall.
http://www.ou.edu/content/coe/ame/research.html
Find some grad students looking for a thesis project and offer THEM a ten thousand dollar grant, not to make a selfpowered pump, but rather to go over MrWayne's system with a fine tooth comb, and they get the money IF and ONLY IF they can _disprove_ MrWayne's claims.
Should a highly motivated group of bright engineering students at one of the best schools in the nation FAIL at this task.... that will do much more for MrWayne's credibility than anything else that might be accomplished here.
To All,
This is a very important discovery, it is very exhilarating and exciting to be in this field of research and development.
We feel very blessed, and look forward to sharing with the world.
Our Group has been very Glad to share with those of you who have and are taking the time to experiment with the design.
History will quickly forget the effort and resistance to what we have achieved - and so I let it pass in this time as well.
If any of you are convinced by "scrutiny" I understand - and we never asked you to "believe" but to seek for yourself.
The physics are very clear. It is awesome.
Do not fear, nor worry of our falter - we have the solution this and many generations have longed for - thank you for being a part of it.
Wayne Travis
It is clear that an impasse has been reached in information sharing & conclusions drawn.
For a few days now I have decided the only credible way forward is for the independent replicators to build their models & report in the performance & relevant data that the skeptics have been asking for.
Remember that IF the challenge participants are officially part of Mr Wayne's payment challenge then Mr Wayne owns the device which must be sent to him to collect the fee - I assume he doesn't own the information & intellectual property gathered from the process or that would be included in the 'contract' - I assume that if your device is not OU then you won't be sending it nor collecting the fee i.e. the fee is a 'success fee'.
Mr Wayne, in an earlier post, advised groups to also build a second parallel device to keep for themselves - this would be good advice IMO - I presume that all participants in the challenge are free to discuss their builds & performance findings without being muzzled - I also assume that they are free to discuss any theory about where extra energy comes from IF the devices are self sustaining.
@seamus10n: Look at it this way. Gravity is like a wind, everybody knows this, a wind of gravitons. Right? So you put your windmill into it and let the wind... the gravitons rushing past .... turn your mill. If gravity can provide power maybe it does it like the wind. After all, gravity seems to act like a wind in other ways, by pushing things around and into each other. And you can't see the wind, or gravity, you only know them by their effects on ordinary matter. Right?
So if MrWayne's machine was extracting power from gravity somehow, in analogy to the windmill.... wouldn't we expect gravity or the force of gravity to be reduced above, or maybe below, MrWayne's running machine? Or at least disturbed, and if we are taking a detectable amount of power out of gravity we should be able to detect the disturbance caused by this removal. Right?
So I think it's important to know if anyone has noticed balance problems, queasyness, or lightheadedness, especially when working directly above or below the major masses of the system when it's running. If you drop a wrench, does it fall more slowly?
It's a wonderful thing, being ignored. It allows one considerable creative freedom, not to mention lots of opportunity to sneak up on people.
Quote from: TinselKoala on August 28, 2012, 09:58:10 PM
Well that's simply ridiculous reasoning, and needless sarcasm. But since you mention wind, the following is likely more than anybody needs to endure. ;)
@PeopleOftTalkingAboutThemselvesAsKoalasInThirdPersonAreSomewhatDisturbing
Here's what I have observed. Long time back, you sure seemed outright happy to bring yourself forward to the situation as representative of some big money financial backers, or other scale-it-on-up type of money, that is, up until basically you were told "sorry, not interested."
Now lately, it sure seems you've decided to engage in an alternating friend of the court then enemy of the court passive aggressive skeptic-athon.
Should Wayne answer these simple questions with simple answers? Sure. Don't know why he does not. Milehigh and others have a good point about that. Should be simple. Why isn't it stated? Don't know. Sad to see it's like that, because it's not hard to articulate. Seems to me if one had a machine that worked, be easy enough to say.
Then again, if one has something working, they'd also not care what anyone else thought, and why should they?
Then again, why the heck not tell all about it down to the kilogram? Don't know.
History is on the side of the skeptics, so nobody should be upset at the skeptics.
However Wayne has this on his side as to the doubters... their thinking something doesn't work doesn't change that fact that a working something works, if it works.
Now either way, some of you keep on distorting the gravitational angle entirely, enjoy making mockery of the notion that something can provide extra energy on the way down at the same time it lifts a similar something else up. Maybe that's true and this thing is a big pump that's so balanced it seems to work otherwise. Maybe it's like a pre-charged bubble level and that pre-charge is the bubble and when you pop enough over to the other side, there goes that weight back up again...ready to come back down again once you reshuffle that level's bubble back over to the other side.
Don't know.
Seems the thing moves the mechanical advantage around hydraulically, and is basically a hydraulic fulcrum mover. And when you get things reset as to the topside gravity helper weight on one side, you still have extra left to use on the other side to enjoy some fun it seems. Then you restart the cycle...
No gravity lost. Just levers and fulcrums moving about in a smart way (I guess).
But nutty talk about gravity being "used up" is just that.
Assuming it works:Here is how you can use gravity like the wind,
metaphorically.
Imagine a cylindrical weight with a hole in it, and vertical axle through it. It has a ratchet like a hand clamp, otherwise it would fall forever, this axle is infinite. So imagine you can un-click its 'lock', and let it drop a set distance each time. You can use that drop for work. You have 'quantized' the gravitation acceleration a bit. But metaphorically speaking that wind is still blowing, because if you un-click the lock again, well it's going to drop again. Never going to stop, even if it has to crush a car underneath it to stop first, assuming the forces are large enough in comparison to the car.
Nobody would dispute this. Wayne has his weights set up in a similar manner. Not too light, not too heavy. Just right for the job, so it seems. Enough to provide the lift of the other via the mechanical/buoyant ZED advantage, and enough to provide a little extra oomph. Yet not too heavy to make it impossible given the forces available.
In the case of the ZED, these are two switchable, reversible "layered levers". Where people lose the mental picture is that what they think of lifting a weight back up, is relatively speaking from a point of view, just each side of the weights on each axle un-clicking a notch here and there.
Back and forth they would go, first one, then the other. On down those invisible axles, forever. you don't use up any wind, you are getting it back each time you "lift" the weight back up. You are able to lift the weight back up from the other weight due to mechanical buoyant advantage. You are able to do this because the ZED provides a fulcrum of sorts, and because that advantage is more than the lift needed to 'reset' the other, you can repeat.
So it seems.
Stated again, imagine you have two weights on a seesaw with a movable fulcrum. That movable fulcrum is the ZED buoyancy/displacement advantage and other transfers via the switching system.
Weight 1 can easily lift Weight 2 a certain amount, because the fulcrum is offset (multi-layer ZED). The system is 'pre-charged' so the other pressures and things are now pre loaded, adding a little help. This help is not lost, it can be re-shuffled to the side doing the work, as needed. Imagine a level with a bubble inside. You can tilt it to an fro. The bubble provides lift to some degree, but it not lost. Shuffle it about. There's something, no?
Now it sure would be easier if somebody just stated some facts and numbers so one doesn't have to guess so much, but alas, doesn't matter.
And I'm just a web person so none of this matters either. Wayne, please ignore the master debaters and get on with it as best you can.
I do hope The Colossus of Chickasha is real. :-\
PS thanks to Fletcher a while back for answering my question(s), and thanks for the thread for indulging a gravitational windbag. Sadly, this one never runs out of words.
[Edited for typos]
Well, Artist-Guy, if you want to criticise me you should at least get your facts right. I don't "represent" anybody here except myself. What is true is that if you convince me, and if I can convince some other people that I know.... not represent...... your little tabletop perpetual water pump based on a 5-layer Zed system will be worth a lot more than ten thousand dollars. But the fact that there is no granted patent...... just wound up making me look bad in the first instance, since I took the word of people that there WAS a patent and passed that.... now known to be bogus.... information down the line. Bad form for me, not checking facts thoroughly.
And now it seems that a lot of other stuff that I believed, initially, because I was told..... also isn't ...er.... ah..... exactly corresponding with reality.
No continuous runner. Not even overnight. Maybe not even four hours. No patent. No working scale model.
So, since I'm on the ignore list for asking the hard questions.... like how is the clear overunity determined for the simple three layer system that is clearly overunity by itself..... and how long precisely was the longest run time..... and what charged the batteries for the unit Mark Dansie showed in that last video..... and since my constructive suggestions aren't being taken seriously.... I feel a bit freer to point out that this Emperor's new clothes are rather ...er..... transparent, if not downright invisible.
Where are the teams of engineering grad students, promised a large reward if they DO find something wrong with the claimed overunity performance? Instead we have teams of overunity aficionados working with glue and scissors and old packing materials, trying to make a tabletop selfpowered water pump to prove that MrWayne is right and win that same reward... a pitifully small reward for something that would do what it is asked to do.
Come on.... please think for just a minute. You have cracked the nut, and sitting there on your kitchen table, nary a leak, is a water pump that runs itself,, and makes enough power to turn a little turbine or even power a Kelvin waterdrop ES HV generator. And it runs and runs and is clearly overunity by itself. So you phone up MrWayne and collect your plaque and your ten thousand dollars. Right?
Riiiight.
Me.... I'm phoning some "friends of ours" and getting a million bux for it right away, and a billion by the beginning of 2013. If the MIBs from Big Oil don't assassinate me first. Mr Wayne can sue my estate for infringement.
(BTW... this isn't "sarcasm". It is a variation on the reductio ad absurdum. )
Quote from: TinselKoala on August 29, 2012, 01:25:14 AM
Was that multi million dollar deal something that Wayne was interested in?
I must have missed it if there was a possible deal as you suggest. Unless its all just coming out now.
MaGs
Well why would your friends give you a million dollars if you dont have a patent? ;]
Would they just hand over the cash for the table top teeter totter without hesitation?
Maybe if they are that good of friends, they might just give you a million, just to be friendly. ;] Then step up to billions in 2013, because they simply love you. lol. ;]
No patent and your swingin by a thread just like anyone else.
And wouldnt this thread be sort of dated proof that you intended to steal the idea?
Cmon T, whats the big deal? The guy has a way that he wants to do things, and he has every right. Patent pending is a substantial thing to have. It means you were there first. Its got teeth. And patenting these days, its who comes first. And dats it. ;]
Wrote my own provisional. $75. Know a lil bit. ;]
MaGs
MaGs
Quote from: seamus103 on August 29, 2012, 01:17:18 AM
So, just what is it about the nature of gravity that you are missing?.. Objects with mass have gravitational potential energy related to their position relative to other masses. Move an object 'up' against gravity and it gains potential. Move it 'down' and it loses potential. The amount of work required to move the object 'up' is always the same or more than can be recovered by letting the object return to the original position.
There are no exceptions to this rule, no matter how smart a system of 'levers and fulcrums' you might devise.
Is that still true when you have a bubble of "preload" extra kick being shuffled about? And buoyancy helping the lift with weird displaced virtual mass going on (maybe?)? Probably. But nobody knows
. Maybe that we still don't is on purpose. Don't know. Maybe it's all been for the local 'journey' that Mark mentioned. Don't know.
As I said, history is on the side of the skeptics. By the time your screen name is Seamus105, I am sure it all will have been settled. ;D
You mentioned being the middleman and getting rich and that to me suggested, logically, that you are a broker representing some serious kind of somebodies.
#324 TinselKoala
" I can tell you this: if it is self powered, truly, and uses gravity and buoyancy to sustain operation.... I can set you up solid, my man, solid. I'll get rich from being the middleman, but you will get hugely so rich you cannot imagine it, and the world will be a better place very quickly."
I do understand the frustration of asking simple questions, and not being able to get simple
numerical answers. That's the lone big red flag I have personally. But I read all this for entertainment mostly, with a believe it when I see it attitude as befits all the hoaxes I see on these forums all the time.
QuoteWhere are the teams of engineering grad students, promised a large reward if they DO find something wrong with the claimed overunity performance?
I think that's a fine idea, using the local college to debug and prove or disprove it. However if somebody thinks they have the answer of all answers, I am not sure they'd be open to that for monetary, or other reasons of concern. Alas.
QuoteMe.... I'm phoning some "friends of ours" and getting a million bux for it right away, and a billion by the beginning of 2013. If the MIBs from Big Oil don't assassinate me first. Mr Wayne can sue my estate for infringement.
What's the input to output power on a reductio ad absurdum? ??? ;)
rc
Ah, I see the source of the confusion. No, if there's no "product", I can't be any kind of middle man, can I. But if there is a product and it's being bandied about on an internet forum, then there is no reason why I can't bring it to the attention of some friends of ours, and there's no reason why they wouldn't be grateful to me for doing so, in the only way that matters. This is quite a bit different from me "representing" anyone. And the protection offered by a patent _application_ only extends retroactively if the patent itself is finally granted.
Is this an announcement of my intent to rip off somebody's intellectual property? Really? REALLY? Well....then I have to ask, just what property are we talking about anyway? You had better keep your invisible flying pink unicorn tightly locked up because I just might rip that off too.
Since when has a patent protected anyone with a truly revolutionary invention with national security and world-changing implications anyway? Are you saying that the conspiracy theorists are wrong?!? No MIBs, no government sequestering of patents, no Big Oil assassins working to keep us enslaved?
There are circumstances where I would be officially representing someone in matters of this nature, but those circumstances are as likely to come about as an Oklahoma blizzard.... in August. And the fact that I once said to someone that there was a patent, when there really isn't..... well, that seems to reflect poorly on ME. Imagine that.... I, a bystander, get censured and scorned by my friends for saying that there is a patent when there isn't. But it's OK for the claimant to do it.
The input to a reductio ad absurdum is "the way things are". And the output is some contradiction that is so glaringly absurd that one can see that there is something badly wrong with "the way things are" or at least the way that they are represented. Like a working free energy machine sitting in a barnyard in southern Oklahoma, without attracting a lot of attention from, say.... DARPA, Mossad, the Chinese, or even those bright grad students over in Norman. And the power of the output is multiplied by each absurdity revealed.
Yep, let's hope that patent gets granted in a hurry, so MrWayne and his intellectual property will be safe.
The University of Oklahoma' s College of Engineering's School of Aerospace and Mechanical Engineering in Norman is the mere "local college"? Well, we grads of the University of Texas might think so but I'll bet a bunch of those students in Felgar Hall would disagree.
@Mags:
"No patent and your swingin by a thread just like anyone else."
Ah.... no. "No patent, but you've got a working model that does exactly what you say it does"..... I'll put that up against a "patent" with no working model behind it any day of the week. The first person to show up with a working model of a free energy device wins the big prize, patent or no patent and no matter whose name is on the patent application.
@TK
QuoteThe University of Oklahoma' s College of Engineering's School of Aerospace and Mechanical Engineering in Norman is the mere "local college"?
Why would you take the word local to mean 'mere' as in lesser, or incompetent or something? I meant local to the project. Local is same state, since I'm several away.
I was agreeing with you that it was a good idea to have a college look at it. Yet even when agreeing, that is made into something contentious. Hmm.
:o ???
Quote from: Artist_Guy on August 29, 2012, 04:12:03 AM
Is that still true when you have a bubble of "preload" extra kick being shuffled about? And buoyancy helping the lift with weird displaced virtual mass going on (maybe?)? Probably. But nobody knows. Maybe that we still don't is on purpose. Don't know. Maybe it's all been for the local 'journey' that Mark mentioned. Don't know.
Hello Artist,
Many have been taught that gravity and Mass are intrinsically linked - just as Archimedes' volume and buoyancy is misinterpreted to confirm - the misinterpretation is to transpose that observation and assume it holds true in all possible scenarios.
Our System proves they are not linked - Gravity is not limited or controlled by Mass - or density - instead Mass and density are controlled by gravity. Our system shows that Gravity can also be utilized in the absence of mass.
As long as the wrong understanding persists - that Volume/density - is the limitation of taking advantage of the gravity - one Will not understand our system - nor the impact of the discovery.
It time - I do believe that from the measurable physics of our system - it will be understood that we utilize Gravity "internally" at greater than external "mass" values - an awakening of understanding of how and why our system works - will be realized.
It can be said many ways - such as we utilize the force of gravity with less mass, or that we or we have virtual mass and utilize its effects.
But if you are limited in observation to the capture of gravity - and limit it to a single mass - you will not understand our system, or understand why our efficiency rises in an additive fashion within those layers..
I have said it is simple to see - but not simple to understand - one has to compare the lift forces of (Internal Mass usage) buoyancy - as Larry and Dennis have shown, and compared that to the External total mass of the ZED to see that either mass was missing to account for the buoyancy - Or that our current understanding of gravity has some loop wholes - or both - maybe a few more ideas ;) not authorized for release (and with People making threats - it is clear and proper due diligence).
The key point - Gravity utilized in our system is not dependent on actual Mass :)
Thanks for the clear comments.
Wayne
Quote from: webby1 on August 28, 2012, 12:57:48 PM
A quick note. I just tried using my pod and only the outside riser, I have played with different setups but did not bother to measure and since I did that yesterday for 4 risers and pod,, that was what I was using, leaving out my first riser to help with air blowing under the skirt,,
ANYWAY, my max lift like that was only 463g, compared to 730g with 4 risers.. this is the whole weight of the outside riser and added mass.
Edit:
Something struck me as odd, so I went outside and re-did some stuff.
outside risers can hold 324g
outside riser weighs 90g
lift was 462g
I will go measure displacement of pod and its weight.
Pod is partially full of water but it has a lift of 42g.
So should that not be 324g - 90g + 42g = 258g
and 463g - 90g = 373g
So 373g - 258g = 115g from where??
Maybe my math is wrong.
Hi Webby1.I have made no secret that I am not brilliant at mathematics. This is not surprising as I am only a retired truck driver, but I am not completely dumb. I have been struggling to understand the above post, and I suspect so were several others but were afraid to ask.
So as I understand it you are just using the outer riser and the pod.You say "outer risers can hold 324g. " I guess you meant to say "outer riser [singular] can hold 324g. So I assume that the outer riser if placed in a tank of water will require a weight of 324g to sink it. This riser itself weighs 90g
The pod can lift 42g
Then you say "So should that not be 324-90+42=258". My calculator gives 276
324 is the net upthrust of outer riser
90 is weight of outer riser
42 is the net upthrust of pod.
and 463-90=373
463 is the total lift [stated earlier as 462]
90 is the weight of the outer riser
so 373 - 276 =97
Therefore 97 grams unaccounted for.
Hi Webby. Yes I am quite sure that we are all interested in the why, rather than exactly how much. I just wanted to be quite sure on what you were saying , rather than criticising your calculations. As it looks like I will be waiting a while for surgery, I have started to make a model of my own, although it will be a slow process. All I have done so far is the pod.
MrWayne, Excuse me...
Asking why the ZED stalled in 4 hours does not reflect what you are willing to discuss.
This is an essential information, from now no one should waste his time or money trying to replicate your device without you giving this information. You are entertaining dozen of fans in this thread with hope of OU, they deserve an answer.
You probably have arrived to the point where yourself after years and lot of $ spent have realized that there is no OU in your machine, just something that last hours a bit like the long pendulum of the London science museum.
I read that the additional layers increase the global efficiency from 104% to 300% from where come the additional 196% from the outside layers?? I dont understand all of the ZED as you have figure.
You have top scientists and engineers (read one hundred) that advise you. What means "top", they must have figure long ago what is the physics behind the ZED, a ZED is not rocket science; Archimede force, some simple fluid mechanics, a first year university student in physics or engineering should be able in a 2 weeks project to put on the table the physics involved and say yes or no if there is OU in a ZED. I cannot imagine that after years and $ you dont have this physics formula in your hands, if you dont show us, it is easy to figure why ...
It was so simple to tell us what was the problem to keep credibility something like "look guys, it stall because water leaks at one valve and water pressure drop fast" then we have an explanation (true or wrong) for your first failed demonstration that does not comprise the claimed OU.
Desapointed
Quote from: mrwayne on August 28, 2012, 03:35:37 PM
To@,
Wayne Travis
Quote from: parisd on August 29, 2012, 12:03:25 PM
MrWayne, Excuse me... Asking why the ZED stalled in 4 hours does not reflect what you are willing to discuss.
Desapointed
Hello P.
I have only five minutes - so let me answer first questions, and then respond to the statements that are not accurate.
I am here to help those willing to put effort into understanding the system - not to have anyone validate our system.
We are very confident in the second Part, and convinced of the capability of those trying.
Second - We have brilliant people helping, visiting and checking us out on a regular basis - and to Date - only one - who refused to show ID and Refused to agree to certain respects - has been turned away.
Yes they number over 100 - yes many are very educated and skilled.
Yes we have extremely respected people for the Validation process.
Finally - I quote the very conservative efficiency - very conservative.
Actually, I have shown how and why - it was ignored after four pages of shirt ripping by some.
I am disappointed that the answers to your questions - such as we ran four hours tops till we broke the machine - three times and then rebuilt it stronger and now work to get the system up and running is translated by you into "stall" not OU, and disappointing - do you think we are not kicking but here to give you what you think you deserve - a fully functioning running machine.?
Lastly - over five minute rats - Our OU is not and has not been the question - simple phisics can show it over and over - turning it into a fully functioning system is a chore. We did not build thesystem originally to be anything more than a input output measurable system - it still is - but now we are adding fully functionability to the complete system - I hope you can see where your suppositions are disappointing.
Sincerely - excited and happy to share - just stay on focus.
Rome was not built in a day.
Wayne
Quote from: mrwayne on April 10, 2011, 04:07:24 AM
Well, I have not been to secret, and so I do not confuse myself, I need to explain a few things about my invention.
It uses multiple channels of water to transfer energy to the same number of air pockets, each air pocket is sandwiched between two pistons, the layered pistons apply a direct upward force on a hydraulic cylinder.
Each channel of water increases the "Head" and thus increases the pressure in the air pocket - to be clear each air pocket has a different amount of air pressure increasing in succession.
Since the greater pressure is in the lowest, each piston has a greater force than the one above it.
Now, this upward action of this set up is not much different than the same action you would get from a pneumatic cylinder.
10 psi on a 1000 inch (squared) piston will roughly lift 10,000 pounds - so will my design.
The main difference between my system and that cylinder is the down stroke, after the load is removed, the input is allowed to vent, my design keeps that exaust pressure at exactly half of the input.
In our photo's you will see two Z.E.D.s that is because we use the exhaust pressure from on side to supply half the fuel for the other.
You can guess the net gain...
More tommorrow, it is late.
mr.wayne@hydroenergyrevolution.com
www.mrwaynesbrain.com (http://www.mrwaynesbrain.com)
Mr. Wayne,
Thanks to pirate88719 and TinselKoala, now know that what you claim to be as The Travis Effect is nothing
more than Heron's Fountain.
http://en.wikipedia.org/wiki/Heron's_fountain (http://en.wikipedia.org/wiki/Heron's_fountain)
Bye
edited to add; the first chamber has 14 psi of air pressure acting on it. Simply means it uses hydraulic theory to increase the water's pressure with each successive chamber. Sound familiar ?
And to think, the biggest complaint people have against me is people like AB Hammer and his friends don't like me. But Alan always did say he should have any invention that comes out of this forum because he has a family to feed. I thought that's what his armoring was for but have found working openly only allows opportunity for clever people.
Think I will take my money, you know, patent my invention which will work but is not very interesting.
Well, anyway, I hope you have a nice day.
Quote from: johnny874 on August 29, 2012, 02:47:10 PM
Mr. Wayne,
Bye
Sure - thank you.
I will add you to the list.
Good bye.
Wayne
Quote from: mrwayne on August 29, 2012, 02:51:12 PM
Sure - thank you.
Good bye.
Wayne
came back so I could delete it. to late I guess. Still, for the crap I've taken for no reason, just have to wonder.....
Quote from: mrwayne on August 29, 2012, 01:14:45 PM
Wayne
But it burnt down in a night.LOL - sorry Wayne - couldn't resist the windfall moment to drop in a one liner ;D
Sincerely, good luck to you & the replicators with the build projects - I am looking forward to the results.
Final dignified acceptance of new physics understanding that would shake the foundation of the world is a series of often hard won, sometimes feral, skirmishes for intellectual real estate, fought for in every laboratory & garage, one at a time - until there is no more high ground to take & flags to teardown, & hearts & minds to defeat.
Quote from: fletcher on August 29, 2012, 04:18:21 PM
Perfectly funny!
Thank you!
Wayne
Mrwayne, it looks like you just updated your website.
http://hydroenergyrevolution.com/index.php/current-objectives
"...I talked to Mark - and he is like the rest of the world - "ready for the delays to be over" Remember that the model I have - was from my theory - before the engineers improved upon it - it is tough to get it to show what it was not designed for - full and continuous run - it works perfectly to show input and output - and the Free Energy.
I have promised that if our team does not meet our objective due to the original design and changes we made in this system - we will quickly divert our efforts to the optimized smaller model.;....."
If you are wise and still think you have free energy to show, why not go back to the extreme basics and try to do a simple demo model of what you paid webby to do. But with clear and exact measurments for all to see. Then go from there.
Johnny, please stop with the flame war posts here.
Thank you,
Bill
Hey Se3d,
How's things going with your new updated simulation?
I've a couple of questions for you on the vid's currently online. I don't really understand everything that's going on, so bare with me, these may seem a little dumb but I'm bold enough to ask in just case they aren't.
1. In video 3, it appears that as the piston rises, the riser is slowly sinking. Is that correct? If so, I can only assume this is because the buoyant force from H1/H2 is slowly reducing as the riser rises out of that chamber. But is that enough to cause the "sinking" that is apparent? What am I missing?
2. What is the density you are using for the riser. Does it matter? Would this make a difference to the overall output force in the simulation, i.e would something less dense make the system more efficient by producing more output force?
Quote from: seamus103 on August 30, 2012, 01:50:18 AM
And I think I might have challenged you to describe the effect clearly in a way that used standard physics terminology. This is absolute rubbish. How can anyone believe such illogical ranting?
Seamus, Seamus01, Seamus02, Seamus03 -
You have skirted moderation - You have proven you can sling mud and make insults.
Make a factual claim or try to learn the system.
I ask - How can you not see the capabilities of the ZED technology - it has been handed to you in at least four separate forms?
Wayne
Quote from: MIdone on August 29, 2012, 09:23:41 PM
http://hydroenergyrevolution.com/index.php/current-objectives (http://hydroenergyrevolution.com/index.php/current-objectives)
Wisdom.............
Here is some wisdom regarding the "Change" process
We started with the "Basics" - PE certification that our design would provide NET (Free Energy) -
The world would not believe - treated us like - dirt - threatened us for daring to challenge 1000 years of understood facts...
The next "Basics" - measurable input out put system that proved our system -
The world would not believe - called us con men for continuing to dare to challenge 1000 years of understood facts...
The next "Basic" - Closed loop system self running and sustaining system -
The world would not believe - called us delusional and mocked us for the gall to challenge 1000 years of understood facts...
The next "Basic" - Data collection of the entire system
Which we have been working on - and the world claims we have nothing, how dare we, how delusional - how illogical...
The future "Basic" - Scalability
Which will be an optimized system - smaller putting out more power than our large model (respectively).
Do you think then the world will believe..........
Here is the result of Wisdom of "Basics"...
A few have accepted our Free Energy claim because of the PE certification (and their own replication of the physics),
Some have been assured with the input and output measurement (and their own replication of the physics),
Many were excited to see the closelooped running system (after careful and certain inspection),
None of this has changed the worlds position - that we dare to challenge the Past -
The Delema we face here with this discovery is this -
The World is shouting at us - We just want the "Basics" and the "Basics" will NEVER be enough.
We push on and persevere because - the world cannot stop us - it is not "Our Energy" that keeps us climbing out of this pit of entropy worship - the energy comes from the pure "Will" for True Independence" it is the sound crying from the World and the Souls on it.
The Next "Basic" - We are welcoming the reviews and critiques from the respected and honored institutions and minds of the world.
My experience with the past make me question if they will be brave enough to face the world in its error -that it can't be done.
Challenging the past is the essence of progress in the world, I hope they will.
The final Basic - which we need no approval from the world for - which is the core of HER direction - to install our completed ZED's where Independence is already realized - where no one can stop us - with the people.
The world can catch up later, the science can adapt when it is ready, the science of our system will be Honored in time.
The only difference is how much longer it will take to reach and spread the technology - if science would do its Due diligence's - the world could have the Technology and Independence right away.
This is the "Basics"
with wisdom regarding our system - "Acceptance and then progress" - that is not the "way or history" of world changing innovation.
"Sooner or Later" is reality - (people will see receive the benefit of our technology - it will be faster if the world will accept the technology - yet we who know will carry it on our shoulders until the world does - steady and true - is the sure way way to win against a world that has taught every highschool-er on up - they will never see Independence.
Thanks for your encouragement - rest assured - we will not fail and we know what we are doing, and where we are going.
The entrenchment has lost its hold ;) Not by our strength but by the strength of the truth that supports our discovery.
In 119 pages - not one person has offered a single fact relating to our device to disprove it - other than entrenched dogma - "it can't be done"- which our "Basic" technology proves is "Old School" - we are just inviting them to learn - the "New School" is being built by those who have been brave enough to rise above the fray.
I hope they all join in - but that would not be the wisdom to expect.
Yes - they have picked on single parts - picked on the supporters - picked on he inventor - all of that means nothing - I forgive them - it is not as though it is working for them ;) , or against us.
No one has nor can disprove the simple physics - not with complex, not with anger - because ours are more accurate - they cover an anomaly - the old school did not know of.
Independence is coming, the lines are just being drawn - it is not "who still thinks the world is flat" but instead "who wants to sail around the world and make new and greater discoveries."
We are working hard - with God's help - to make sure you get to see it in your lifetime.
Thank You
Wayne Travis
Quote from: AmoLago on August 30, 2012, 01:46:28 AM
Hey See3d,
Hi AmoLago,
I have been working hard to make sure I have all the physics details on the updated simulation mathematically correct. There are a couple of twists that may have escaped many casual observers. I just have one last formula to iron out before I can release it. It is easier to know what it should be, than to translate that into a simulation formula.
1.) I just reviewed all my released videos. I could not see any case where the riser sank while the piston rose. Perhaps you should advance it frame by frame to make sure.
2.) The density of the riser material is not a factor, since it is counterbalanced.
All the videos will have to be redone with the new PDF release.
Mrwayne,
Yes, we all understand that you & team are working and spending time and money and effort on your device.
You explained well all of the frustrations you feel from doubts pointed at what you SAY.
But the remedy to that is very simple.
Take---the focus---off---of---YOURSELF.
Put the focus on measured facts.
Like webby is still trying to do.
Form a simple experiment like webby.
Two masses; one elevated (Mass #1) for input, one mass to be elevated (Mass #2).
At the start:
the elevated mass (Mass #1) has a potential energy according to the height, (PE= g x m x h)
the mass to be raised (Mass #2) has a potential energy of ‘0’, because it is bottomed out.
---then the elevated mass is released and energy is put through your system and comes to a stop.
At the end:
Mass #1 now has a potential energy of ‘0’, because it has now bottomed out at the end of it’s travel.
Mass #2 has been raised a certain distanced and now has potential energy. (PE= g x m x h)
Compare the input potential energy measurement to the resultant potential energy measurement.
Forget trying to tell people with talk and just point at the experiment and measurements. That's what people wanted at the start of this discussion.
That’s how simple this can be if you really have something. Just show this, just like webby is trying to do. He’s not afraid.
Once you did this and shows 145% efficiency, or whatever, the focus would not be on YOU and what you SAY. But on the experiment and shown measured facts.
You could get rich by just selling this experimental kit....
I have received pages 13-14 of ZED for dummies, I unfortunately don't have the rest of the ebook. From these 2 pages and help from 1 member I have tried to figure how the additional external layers could bring additional efficiency and quite a lot as I read from 104% to 300% increase from 1 layer to 5 layers.
Please guys correct me Asap if I misunderstood how work those layers and bring additional lifting force, here how I see it:
Initially all air spaces (from 1 to 5) are at same pressure, it could be above or below atmospheric pressure, I would say it is at atmospheric pressure. From layer 1 to layer 2, surface 2 separe air space 1 from air space 2 and the air pressure increase in air space 1 is faster than in air space 2 ( air space 2 is less pressurized because of the water column that form between the 2 layers). The pressure being lower on air space 2 than air space 1 this create a net force going up helping to lift the Zed. same applies from layer 2 to 3 and from 3 to 4 and finally from 4 to 5 (assuming we stop at 5), the 5th air space is at a lower pressure than the other but remain above its initial pressure that I assume to be atmospheric. I dont see anything else from all these layers to helping the lifting of the Zed.
Waiting for feedback (i.e did I get it all wrong) before to make my conclusion on the efficiency of those layers. Tomorrow probably. I prefer to have a kind of theoritical understanding first, instead of jumping blind in fabricating one Zed.
Quote from: MIdone on August 30, 2012, 12:23:33 PM
Mrwayne,
At the start:
At the end:
Webby is doing a great Job, thank you.
Any of you could do the same, good luck!
Wayne
Quote from: parisd on August 30, 2012, 12:39:49 PM
This is an old picture - but the head acts the same.
The Addative head is responsible for the pressure at each level.
I can send the whole book - if I have assureance you will not allow it to be distributed.
Wayne
Based on your attached drawing on previous post, we are supplying air (no color on drawing and at 122PSI) not water and what lift the green cylinder seems to be the compressed air. I was far away to imagine it like this. Tks.
Quote from: mrwayne on August 30, 2012, 01:04:26 PM
Wayne
Quote from: parisd on August 30, 2012, 01:36:19 PM
This was an old picture - we moved from moving air to moving water last year - the point of the picture was to show the additive head towards the center.
The pressure is 12.2 Psi not 122
We no longer move any air directly and this is only one side of the Zed - so If you do not consider both - and the relationship - as in a full cycle you will have incomplete Data.
Welcome,
Wayne
@MIdone. In your last post you describe a simple test where a falling weight causes a second weight to lift .
That in itself is not enough because you only described only half a cycle. After all we can lift a weight up, and recover energy as we lower it, so raising and lowering a load weight takes very little net energy.
We need to take into account how much of the load weight we need to leave on the lifting platform to return the machine to its starting position. Hope that makes sense.
Quote from: neptune on August 30, 2012, 02:15:34 PM
Neptune, I am talking about potential energy measured in joules before and after that one action. The way potential energy is measured PE=m x g x h.
If before the action one mass has the potential energy of 1 joule, and the other has 0, the total potential energy of the system =1 joule.
If after the action the first mass has now 0, and the second mass has now 1.5 joules, the total potential energy of the system now =1.5 joules
That would be enough to show access energy as know to the science formula.
Of course, no one has demonstrated this as fact, though webby is trying.
@MIdone. I have to politely disagree with what you are saying. I could build a "black box" to do exactly what you are asking. At the bottom would be a small platform and another platform at the top. I place a 100g weight on the platform at the top.Then I place a 10g weight on the bottom platform. The 10g weight and its platform drops half an inch. The top platform instantly rise 2 inches, and is prevented from falling by a ratchet.
Does this pass your test?
The bad news is , that hidden inside the black box is the mechanism from a childs toy gun. The lower platform operates the trigger, releasing the spring which raises the 100g weight 2 inches. The even worse news is that I now have to use a force of 250 g over a distance of 2 inches to recompress the spring,replace the energy lost to friction, and reset the machine to its starting point.
So you must analyse a machine over one complete cycle, and return it to its start position.
Do you agree or disagree?
I understand what you are saying neptune. I'm talking about everything being out in the open and about the total potential energy of the system before and after. Whatever moves would have to be considered; they would be part of the masses. Like water levels.
But you are right that in order to convince a person who cares less about formulas, that bringing everything back to the first state, plus spitting water up is what would matter to them.
Neptune .. MIdone is correct - in your example of the black box you would not have accounted in your energy budget for the PE of the spring & the work done joules to compress it [WD = f x d] - after system losses there would be a net loss of joules.
Parisd .. my 2 cents.
I believe this will probably turn out to be a measurement/interpretation error by Mr Wayne & his team - having said that this is the fun of doing experiments & garnering good data along the journey.
I will give you a clue where that measurement error might be occurring, IF there is one.
It has to do with Pascal's principles & enclosed hydraulic systems - pressure is transmitted undiminished in an enclosed system & Wayne's system is a mixture of buoyancy & hydraulics, all under pressure - often pressure & force are confused which is unfortunate - so IMO a force is generated & magnified [it has to do with area ratio's] due to Pascal's principles - because it is basically a hydraulic system the force is multiplied in the system which is seen/interpreted as buoyancy potential increase to lift mass - but if, as some might know, when you take that magnified force output & add it to the weight force of the system fluids & compressed air you get a high internal force figure - when this is converted back to pressure [pgh] & then you recalculate the height potential [h] by rearranging the formula to find hypothetical 'h' i.e. Static Pressure = F / A = pgh therefore h = P / pg you may find the calculated 'h' doesn't match the heights of fluid & air in the actual system - this is an anomaly.
In short the Pascal force multiplication is added to the weight force of the system & by some math is converted to a system pressure which deduces a different 'h' than actual.
The upshot is that there appears a potential to lift virtual mass because of the force multiplier effect & the pressurized system.
The trouble is in 'normal world' that for both hydraulics & buoyancy to do work [f x d] then the Effort to Load [work done] ratio is zero sum energy wise i.e. f1 x d2 joules = f2 x d1 joules, less losses.
JMO's at this time - I watch with interest.
See3d .. I don't know what formula's you are working thru but one comes to mind as a possibility.
That might be for a fluid drag formula to take account of viscosity - a simplified one I might build & use would be say ...
Coefficient of Drag 0.36 [change this factor as desired]
Viscosity Drag = Cd . 1/2 . density . velocity squared . area i.e. Vd = Cd.0.5.1000.v^2.A
Where 1000 is density of water, v is velocity of riser etc, A is area of riser etc.
You would need to include an IF statement in the formula in your sim to account for changing directions & velocities of fluids i.e. viscosity dampening works up & down.
Here is a simple formula I quickly built & would consider using.
Input[Cd]*0.5*1000*if(Output[velocity].y1<0,Output[velocity].y1^2,Output[velocity].y1^2*-1)*0.01
Considerably simplified for a generic sim could be this stripped down one i.e. adding a viscosity dampening effect to buoyancy fairly similar to above in behaviour.
Input[Cd]*if(Output[velocity].y1<0,Output[velocity].y1^2,Output[velocity].y1^2*-1)*100
P.S. viscosity represented as a force is a small system energy loss but probably should be included for sim accuracy & to dampen oscillations.
The density figure has to be adjusted to say 1.225 kg/m^3 for air at 1 atmosphere etc - Vd = 0.36.1/2.p.v^2.A where p = density
Quote from: see3d on August 30, 2012, 08:25:09 AM
Hi AmoLago,
Hi Se3d,
Thanks for the update, great to hear to the sim's coming along nicely.
With regards to my point 1., maybe it's only an image rendering thing as opposed to what's actually going on, but here's what I see.
At the start of the cycle, the riser is at it's natural floating point i.e. I'm thinking that if the piston didn't move it would just sit there as is. Throughout the whole cycle, the riser is never locked or stopped in any way to restrict movement. Also no weight is added or removed.
At the start, lowest point, I can see that the riser is partially submerged, looks like about 30%. However, by half way through the cycle, highest point, it is now about 60% submerged.
So to my eyes, the riser has sunk about 30% of it's height.
Or am I just confused!?
Amo
Quote from: AmoLago on August 30, 2012, 06:55:24 PM
Hi Se3d,
Amo
Hi AmoLago,
Yes, as the piston goes up, it raises the head around the pod, which increases the output force. When the riser hits the top stop, it can not rise any further. However, if the piston continues to rise, the water head around the pod continues to rise and increases the pressure against the top stop. The actual physical location of the riser should never go down as the piston is going up.
Quote from: fletcher on August 30, 2012, 04:28:19 PM
Hi fletcher,
I only wish I was smart enough to be doing fluid dynamics in my simulator.
My simulator is quite modest as are my capabilities in this type of math. I am only dealing with a static 2D model in my simulator. This will actually be a best case simulation of the ZED, as no frictional losses are included. The worst case senario would be 100% efficient.
The actual problem I am working on has to do with coming up with algorithms that do not require an overly large amount of iteration to find a solution to multiple interacting variables. I am also not an algebra or calculus genius. I feel like I am rediscovering all the math and physics principles from the ground up... LOL
I will give you a taste of what I am working on (and it is my last problem to solve). I start with a single layer, single ZED sunk to the bottom stop and at a low energy state. I place a too heavy to lift weight on top of the riser, then apply an input force to the piston. I have worked out pages of formulas that describe the relationships between the water heads, air pressures and volumes, and forces at every point of interest. I ended up finding it easier to solve the problem using a binary search technique for this first step where the ZED is pressurized, but the riser is not allowed to move. I increase the internal energy of the ZED until it is producing a back force in the piston equal to the input force applied to the piston. That puts the ZED into its fully energized state. It takes about 24 iterations to get an answer to the max precision of my simulator (IEEE 32 bit float). All the relationships can be reduced to Y = mX + b form. If I wanted to put more effort into it, I could probably figure out a quadratic form to make it a single pass. So much for the easy stuff.
Next, I want to allow the riser to move up a specified amount and rebalance all the internal relationships. This is the tricky part. When I move the riser up, it affects everything. There is no one thing that stays as a constant (except the input force which is non-linear to the rest once the riser moves). With no single known internal variable to work from to calculate the others from, I am stuck with iterating in a circle until the system is settled. Then after I am in a settled known state with the riser in a fixed position, I can then do a binary search like before to get the internal state to match the input force again.
So I am working on getting the kinks out of my math and doing many internal relationship calculations for internal consistency checks for verification. I understand what I want to do, it is only getting from the dynamic geometry I can see in my mind to a formula and algorithm in the simulator that is slow going for me.
Dennis .. I can't offer too many sage words of advice because every sim is built from the ground up & you have to know the package & the constraints intimately - sometimes I make quick & dirty force approximations of something i.e. sacrifice some accuracy for expediency or function, if its not a show stopper or has minimal influence on outcomes - later in the run testing stage I debug it if needed or upgrade the formula(s) for more realism etc.
In your case it sounds like you have accounted for the major constituents of Inputs & Outputs - it should be good enough to give a fair representation of what happens in a single ZED cycle - that's when any advantage in sim world should show thru or not - if it does then accuracy can be retro-ed into the sim etc.
I should add that I am mighty glad it is you building this sim from the ground up & not me, LOL.
I just get to sit back & puff on my wisdom pipe from time to time [all care & no responsibility] while you do all the hard work 8)
Quote from: see3d on August 30, 2012, 08:20:27 PM
Hi AmoLago,
Hi See3d,
Thanks for indulging me. I know this isn't a forum for beginners as such, but I'm just really interested and want to be involved (if I can!) :)
I can see that if the pod/riser is locked or hits the top, then any force applied by the piston will raise the head. This is why I looked mostly at video 3 (that's ZED_1_Layer_Spring1, just in case they're ever displayed in a a different order for some reason!?), which doesn't appear to have any locking or "topping out".
So from your explanation, was my original assertion correct then?
The ability of the piston to raise the Head around the pod/riser in the main chamber (or from another point of view, the apparent decreasing buoyancy force of the water applied to the pod/riser), must come from the decreasing buoyancy force / increasing gravitational force being applied to the "wings" of the pod/riser in the H1/H2 chamber as the "wings" are being lifted out of the water.
Because the "wings" are being lifted out of the water, the whole pod/riser no longer has the equilibrium of the gravitational and buoyancy forces applied to it and so slowly sinks to back that equilibrium, as is shown by the pod/riser sinking, or conversely as the piston raising the head.
Amo
Quote from: AmoLago on August 30, 2012, 11:49:14 PM
Hi See3d,
Amo
You might not understand what the "spring" video is showing. It starts with the ZED fully energized with an input force and up against the top stop. Then it shows what things look like if you put your hand on top of the ZED riser and force it down to the bottom stop. The input force is still applied all the time. So the transfer function is just showing how stiff and linear the "spring" force is.
I would not spend a lot of time with the old videos though. The will have to all be revised as I discovered some errors in the simulation that I have been working on correcting. Of course, the errors resulted in the entire system being one order higher function than I originally thought it was, so the formulas got much more complicated.
I think I have made some good progress tonight in getting it figured out -- just have to look for a few clerical errors in the formulas now. :-)
Quote from: see3d on August 31, 2012, 12:03:48 AM
Hi See3d,
Awesome, thanks.
Can't wait for the new stuff.
Amo
I think it is time to make my second post (to-date) to share my observations and findings in context with this tread and Wayne’s invention. It appears to me from what I see, that several members are totally inflexible, lockjaw, unmovable, a drama environment that would only wastes my time to participate in and the reason for no frequent postings.
Wayne as the tread owner and object inventor determines and controls the information flow. I do not want to expand on what MUST be released on this forum or for what purpose, Wayne has clearly stated his objective. It is sure your right to disagree and walk-on.
As the tread has been advancing it is clear that,
1.. The buoyancy device appears apart from a clever compact lift device quite ordinary at first sight
2.. There is no apparent over-unity visible apart from a large force which transforms into energy with a very short stroke.
3.. The video’s show certain aspects of the device but not the actual over-unity.
4.. The Zed device appears like a slow groaning mammoth and raises more questions than answers.
5.. The over-unity answer is quite ambiguous and unsatisfactory for all (lazy) skeptics.
6.. You will not be spoon-fed, even if you blatantly reject the invention.
The points you might have missed or did not register,
That the inventor discovered something monumental after years of hard work and logical reasoning and brain teasers that are all consuming (you might not know what I mean). It is clear that he is not going to release exact and complete detailed information to anyone without you showing some entitlement to this information.
1.. Notwithstanding the inventor’s desire to share his invention, he will protect his core discovery and improvement to maintain a business advantage.
2.. The information to the invention details and associated discoveries, including over-unity is within the compendium of piece meal information bits that have been shared in the forum. It is just a question for you to connect the dots.
3.. That to understand the invention and underlying principles, your effort will be required to connect these dots, by pondering, by discussion, by getting your hands dirty or wet and primarily getting your brain exercised. You need to earn it.
4...Wayne has been true to this word to handle more intimate detailed technical question off-line.
5.. And remember, you play with Wayne, he also plays with you in ways that are not directly apparent. Become serious rather than standing on the sidelines and throw fast and quick conclusions. A diligent and serious approach will change things on this tread. Effort must flow bi-directional.
What can I attest to,
The bulky and non-impressive looking Zed system is a Pandora treasure box, filled with gems. I have been steadily discovering many interesting and clever details.
Last night I unearthed the big over-unity diamond, I knew it was there for quite a while but I couldn’t see it due to the flawless properties that blended in with the water. Finding and understanding the exact process of over-unity in this system is a real eye-opener. It would be an insult to just tell you about it because of its simplicity. A Troyan Horse, you can not see it directly but need to discover
I can only commend you to do your open minded due diligence and you will be richly rewarded.
Regards, Michel
To @ll,
Michel is exactly right - in everything he stated. Well Done.
Michel's timing is good.
With some help from a Engineer traveled from Switzerland - we are beginning to see success out of our Data collection Model.
With my permission - the Switzerland Engineer is going to share his complete model with Larry C - that model has the complete process mapped.
This should give Se3d a comparison model and others help in understanding the process.
@ Replicators - I must close the entrant to the Replication Challenge - If you have not notified me of your intent - do so Immediately.
Please post as you will and your observations and discoveries - Good Hunting!
Email me privately when you are ready.
@All,
I have welcomed you all, to those who have visited, got your hands wet, wrestled through the mind teaser - you have joined in the process of discovery - you are a part of histroy - Well Done, well done indeed.
Yes, this is an Exit Letter, I must notch up the level of professionalism to move forward.
Enough of you have the understanding to continue without me - I will still be available for the private messages.
I also post weekly updates on:
hydroenergyrevolution.com (hydroenerg@yrevolution.com)
Those Getting their hands wet are discovering what I am able to share.
Wayne Travis
Quote from: seamus103 on August 31, 2012, 09:32:10 AM
There is no 'overunity diamond' to be unearthed here. All that is apparent is Mr Waynes increasingly desperate and illogical explanations as to why the machine is not in a fit state to pass validation, and those excuses are starting to wear thin.
It's time to admit you got it wrong and this (or for that matter any other gravity/buoyancy device) cannot ever lead to overunity energy production. All the math, thermodynamics and physics theories and experimentation for the last few centuries have said so.
Seamus,
Get your hands wet - or walk on.
Wayne
To All replicators.
I just had a meeting with the visiting Switzerland Engineer -
He asked that I direct your models in such a manner - so that you do not encounter issues our later models resolve.
Very Wise.
If you will be using Water and Air - please limit your models to four Risers - three will be enough to make your observations.
Equalized Gaps - or equalized volumes will both work just as well with-in 10% of each other.
Second - a dual ZED system is highly encouraged - it has a 50% efficiency advantage over a single system.
Good Building!
Wayne Travis
Anyone besides me thinking "Archer Quinn" at this point?
Quote from: TinselKoala on August 31, 2012, 10:14:56 AM
I do not want to go into character comparisons, but I am sure we have reached a crucial point in this thread.
High strangeness, high weirdness, little credibility.
Swiss engineers? I am a bit disappointed. Nowadays one goes to the Chinese when help is needed. Involving the Swiss or other ancient folks from Europe is so outdated.
It becomes interesting, but not in a technical sense. A hands on course in sociology and human psychology.
Greetings, Conrad
Yes, with bells on, how many times,
"I've done it, it works"
"oops technical issues"
same old story http://www.youtube.com/watch?v=qiU2V_gZvfE (http://www.youtube.com/watch?v=qiU2V_gZvfE)
Quote from: powercat on August 31, 2012, 12:17:25 PM
That is funny.
Wayne
The "Sword of God" roll on to the 20th of September, that's just what we need.
Ah, the old, old story. (quote from Tinker, tailor, soldier, spy)
Bill
Conrad, so much unjustified arrogance about nationalities !
Quote from: conradelektro on August 31, 2012, 10:37:08 AM
GoOod MoOorning, Isaac. Glad you're gone. May you now bless the drought areas with your abundant rainfall.
Been out of power since Tuesday night. Just wanted to pass on a few pictures of the hood during Isaac.
First Picture: Dunt dum, dunt dum.
Second Picture: Hum, where did that dog go.
Third Picture: From my rear deck. Looks bad, but no problem, everbody is up on pilings.
Will take some time to catch up. Got some new understanding with the time off, will be passing along later.
Regards, Larry
I was really hoping there was going to be a result here as Mark isn't easily fooled. This has become a case of no news is bad news, I fear.
Anyone know of what became of James Kwok? James's idea seemed very much along the same lines.
John.
Quote from: pminnie on September 01, 2012, 10:38:44 AM
John.
Hello John,
Don't be misled by the false assumptions made by some:
We are going strong -
We will be reporting here -
Mark has not been fooled - he is very good at smelling a rat, and recognizing success -
None of James' design have in common with this one but water and a tank -
Current Facts:
Teams are replicating the Zed's as we speak -
More PE's have certified our process as OU - they have traveled from around the globe - for their own desire to know - not that we asked - we just welcomed.
Our system will be evaluated by Mark and his team - and the results will be shown - at the time they are ready.
The Unprofessional environment made by a few -does not lend to protecting our integrity - so while the replications are under way - we will rest.
As I said before - The last Engineer left this morning - a member of our team and is sending his spreadsheets to Larry.
I expect Larry to share when he is ready.
Thanks - no news just means we are very excited and getting busy - no time to help others by being a mud target.
Thanks John.
Wayne
Quote from: LarryC on September 01, 2012, 08:08:16 AM
Regards, Larry
Good to know everyone is OK.
So what? Do you live on an alligator ranch!?! Did they escape their enclosures? I mean, that is the excuse for wild animals loose in Ohio.
'Gators don't want no trouble, right? Probably just as freaked out about the change in the environment as humans are...
M.
Larry -
Glad you made it through Isaac. I've seen a lot of gators, but none ever swimming around my yard!!
Good luck with the cleanup and getting the power back on.
Tom
To ALL,
This is the official closing of the TBZED challenge entry window.
If you have already messaged me, good building!
I answer question each morning Central time USA.
Good luck, and get wet!
Wayne Travis
Hi all,
I have one question see picture below.
Simplifications:
1. air is not compressible, always keeps volume
2. red riser have infinitely small weight
Step 1 is initial situation. Riser have no lift, there are 4 units of water in left and 4 in right side. Pressure inside of riser is the same as outside = 1atm.
Step 2. Adding 2 units of water. Since air is not compresible this action will push water in column 2 and 11 down by one unit and also raise columns 1 and 12 by one.
Question: what is the lifting force F after step 2? Equivalent weight of 4 units of water or 20units?
Marcel
Should that have read "4 units or 2 units" instead of 20 units?
Second question: Through what distance will that lifting force act? That is, how high will the riser rise before the water levels in and out are again equal?
(I like the simplification of incompressible air. It makes it a bit easier to see what's happening.)
But wait a minute.... you must have the riser locked down at first, otherwise it will simply rise up from the air pressure and the water columns will remain the same height. The only way the pressure from the input water can be transferred to the water columns is if the riser can't move, and if it's weightless then it must be restrained.
So in your experiment then, you are unlocking the riser after injecting the water... under pressure..... and then asking with what force it will try to float up, right?
And I'm asking how high it will float before the water levels are equal again.
So the water columns will be equal again once the weightless and free riser has risen, right? And since volume is conserved, the two units of volume added to the central column's eight units will raise the riser's 10 unit width by 1/5 unit, I think. So you will have essentially the lift buoyancy of 4 units of displaced water initially, but the riser only needs to rise 1/5 unit to equalise everything again.
Ok, tear me up, how am I going wrong?
(I think I see where the "20" came from now... but I don't think that's a right answer.)
Hello TK,
thank you, I forgot to say in step 2 is riser locked but you figured it out already. I was just curious to know what pressure it can produce by using compartements as in ZED. It seems to me also that only 4. I'm trying to understand how the lift pressure builds up by adding second riser to a one riser model. Have lunch now, I'll be back...
Marcel
Marcel,
You cannot start with the assumption that air is not compressible. Air
is compressible and if you want the air to be pressurised it need to be compressed, this is the equation of perfect gas P1V1=P2V2 valid at constant temperature, so to double air pressure in a closed system you need to reduce its volume by half.
Water is not compressible, if in a closed system (but with no air trapped in) it can easily be pressurized, in the Zed water has an atmosphere of air on top, so to pressurize that water you also need also to compress the air on top of it, this require a certain amount of water to be injected (all depending of the volume of air displaced by water). So the vertical force F on the horizontal surface doesnt come for free, it comes from the compression effect.
I have not yet figure how additional layers bring more efficiency.
Quote from: MT on September 02, 2012, 04:40:14 AM
Hi all,
Simplifications:
Marcel
That was exactly my point. I had not accounted for the energy budget of the whole cycle, AND NEITHER HAD MIdone.
@Fletcher. You totally failed to understand my post. I was totally aware that my black box example did not allow for the spring recompression in its energy budget. My purpose was to show MIone that he had only analysed half a cycle of the ZED, and thus made the same mistake as I deliberately made in the black box example.
MT .. Mr Wayne has categorically stated that the system would perform equally well using two incompressible fluids of different densities, so your example for analysis purposes of considering air as non compressible is valid.
He also said that a compressible gas is not the 'secret' ingredient for why it is OU in his view - as has been pointed out by Parisd gases follow the ideal gas laws [within reason] of a direct trade off of volume & pressure i.e. they are inverse in ideal conditions - this means that energy used to compress a gas is stored as PE in the gas, & after some internal losses where temperature/heat might enter or leave the system [minimal in a short time frame; search adiabatic & isothermal legs of a carnot cycle] - therefore the compressed gas will give back the PE as KE - this is the perfect spring analogy that many have talked about.
TK is correct IMO - the riser is locked & the fluid has to have more & more work done on it to enter the riser chamber as the pressure inside builds - but what is important is that the non compressible air will displace the fluid raising the head - to see the relationships clearly you have to work with volumes rather than 2d areas - the upshot is that any volume injected into the riser chamber has an energy cost - although the fluid head rises & does create more pressure the buoyancy/lift potential is 'short lived' & directly related to the volume injected which displaces an equal volume of fluid etc.
Some further thoughts to consider - pressure & force are two sides of the same coin but only one does Work - internally the thin wall of fluid is pushed upwards which raises the head - static pressure of a fluid = pgh in N/m^2 - if we assume the fluid has a density of 1000 kg/m^3 & g is 9.81 m/s^2 then it is easy to calculate the pressure in Newtons per meter squared [Pascals].
The buoyancy force is related to displacement volume - in your example you assume that the riser is virtually massless - this means that the buoyancy force = -mg N's of the volume displaced - in this case we have to use a 'virtual' volume [because the pressure is increased by the high thin head i.e pgh] - since the riser has next to no mass we can neglect weight force of the riser which would counter the buoyancy force.
So, we have a net upthrust force [buoyancy force less weight force] based on a virtual volume displacement due to high head [pgh = static pressure] - the penalty is that as soon as you release the riser to do Work [ f x d ] it has a very short stroke length - this is because everything is volume dependent [just like Archimedes].
N.B. Static Fluid Pressure = pgh in N/m^2 or Vpg / A i.e Ahpg / A = pgh & P = mg / A
P = F / A in N/m^2 ... F = P x A in N
So now Pressures can be converted to Forces & Forces converted to Pressures.
Note: Forces x Distances do Work - Pressures do not.
Edited to add units.
Now this *is* Pod racing! (Cheesy, eh? But the best I could come up with.)
TK? Please let me know what you think about the build. TRUST ME! I am not happy with it at all! Maybe build 7.0 or so will not be so embarassing.
But WE do what we can, because we can, and we should (or must?)...
M.
PS. @fletcher, Thank You for spending time on this thread. You are a Gentleman.
I have put a LOT of work into trying to simulate a single layer single ZED. I finally felt that I had all the equations worked out describing the relationships of volumes and forces between the different internal structures. I put everything into the sim yesterday and hit the go button. It spit out an answer that was self consistent, but it was not the answer I was expecting. I have spent a day going over it in my mind and can not find anything wrong with the result, so I am going to throw it out here for comment. I have attached a screenshot of my simulator input/output result.
The simulation is based on applying an input force to the piston at the bottom, then finding the riser position that balances the internal heads and pressures. The input force is stepped from 0 to 2 pounds in 108 steps to generate a transfer function curve.
The interesting thing is what happens to the air pressure as the Pod moves up.
1. Initially, the Pod head and air pressure increase linearly (increasing the lift), until the total lift is more than the 1 pound output load.
2. When the Pod starts to move up a little, it increases the air chamber volume. This drops the air pressure. The piston and Pod head have to move up to balance the input force. However, the increase of the Pod head, increases the buoyancy force. This places less importance on the air PSI as a lift force, so the air PSI decreases as the Pod head increases. This can be seen in the 10x Air PSI curve in the graph. If the stroke is long enough, the air PSI can actually reverse from being a lifting force, to being a sink force to keep everything in balance. This is also evident when the Exit Head is lower than the Middle Head.
3. Once the upper stop has been hit, then any increase in input force once again results in increasing the air pressure.
I never expected to have the internal air pressure in a situation where it was hurting rather than helping lift the output weight.
If anyone has a clear single layer ZED already built, it would be easy to check to see if this is what is actually happening. Slowly feed the water into the Pod chamber and observe if the outer head increases until the pod starts to move up, then decreases until it gets to the top.
If the outer head keeps going up the whole time, then I have some more head scratching on the simulation formulas.
Can anyone help with this, or do I have to cobble something together to make this observation?
Dennis .. debugging & checking suggestions.
You could try simplifying your sim to check to check basic hydraulic facts - then add back complexity later.
Make a copy of your sim & simplify it by making air non compressible & give the riser the same mass density as the fluid so there is no buoyancy force.
Check that the sim follows well known hydraulic rules based on Pascal's Laws - i.e. that pressure is transmitted undiminished in a fluid in an enclosed system - this means the head must not change & only the riser rises i.e. treating it as a hydraulic ram.
In your case your Input Force is applied to raising the piston - that Force will raise the riser with a force proportional to the areas.
i.e. hydraulic leverage is a force multiplier but Work Done In & Out energy remains the same - that is, hydraulics is a form of leverage of trading force & distance & pressure is linear.
N.B. the hydrostatic paradox will show internal pressures consistent with pgh from the top of the piston to fluid height - this does not effect the force multiplication effects of area ratio's.
Once this is working as it should then add back complexity to the sim - first by adding buoyancy force by making the riser less dense than the fluid - let the head rise again & become an open system.
Next make air compressible again.
Optional extras - adding viscosity drag to add some frictional loses.
Check against real build results & tweak as you are doing.
@All,
Wildew has pointed out an error in my spreadsheets that have the Channel SI Calculation section at the bottom, this was taken from part of a shop floor spreadsheet. Checked with Wayne and he passed me the Swiss Eng's spreadsheet and he had it corrected. The error correction will make hydraulic looks even worst, not happy news for the closed minded skeptics, so I'll just be correcting and sending updates later.
In my short review, I find the Swiss Eng's spreadsheet extremely impressive. Those who have made fun of his existence should be very careful. History will be recording what you are stating and I guarantee, that you will be the ones made fun of later.
Regards, Larry
@mondrasek: Looks good to me, man! ..... better than I expected, better than I could have done. I'd have a mess of fingerprints and tear-drop cross sections. I'm amazed that the lap joints came out so well. Could you detail for us, please, your gluing method and materials? (I know you told me already but maybe the rest of the readers might like to know too.)
Have you done any pressure testing? I'm worried that the open ends of the tubes won't hold their shapes without a reinforcing ring at the open end (a half-inch ring of the same material?, doubling the wall thickness and with the lap join 180 degrees opposite the tube's lap seam). Also, what is your inter-tube spacing, and have you been able to test for the self-centering phenomenon yet? I have a feeling this effect, if it happens, depends on capillary action and will happen mostly with small interwall spacings relative to the system's characteristic length. I am hoping to be surprised here, though, because it would make things a lot easier from a builder's standpoint.
@see3d: I think, if I am understanding you correctly, that I have actually experienced the effect you describe in the single-layer Zed I have in my PerPump v.2.2. The pumping pressure seems to me to behave like you have described, when I have the starting water levels in the Zed chamber just right (apparently just enough to allow the riser to make a gastight seal between the ringwall and the outer chamber, a 1/4 inch or so.) Even in my crude system, I think I'm seeing both the enhanced pressure and the negative pressure effects, due to the volume changes as things move around. I don't have a way to lock my riser/pod combo except by varying its weight (buoyancy at a given displacement) to make it heavier so it stays down longer, and my range of motion is limited to under an inch, but even so, I see the effects on the water output that correspond to what you are seeing in the sim, if I am understanding your description. I interpret this in my PerPump as a force multiplier, like a hydraulic lever, that trades off increased pressure for shorter pumping time... in other words, less volume pumped at a greater pressure. I reported this effect and demonstrated it in a couple of videos last week sometime, but nobody around here seems to pay much attention to Koalas any more -- even if one of them does have a self-powered table top waterpump demonstrating the active Zed principle in action by pumping 13 1/2 inches of water head above its outlet fountain.
Quote from: fletcher on September 02, 2012, 06:23:08 PM
You could try simplifying your sim to check to check basic hydraulic facts - then add back complexity later...
fletcher, Thanks for all your suggestions. That is the route I travelled to get to my current point. When redoing my sim, I went back to just a zero layer system. That gave me some new insights that I could carry forward one step at a time to the one layer system (although without the complexity of the friction). I don't ever expect to take the sim that far, because it is not needed for my purposes of defining an optimal static design. Building a working model would be easier... LOL
I added one formula at a time and substituted it for an alternate form to see that the sim gave identical results before moving on to the next relationship. I did the sim starting from the Pod Head going forward, then from the output head differential working backwards. I was not satisfied until things works the same with either set of formulas and that some other formulas just used as consistency checks were happy.
As far as the incompressible air, I did look at that. In other words, using light oil instead of air, and giving it zero weight, or alternatively upping the density of the water to compensate. I would just use the same formulas that describe the action of the water pockets again. However, it was not really needed for my model. As far as the final result goes, the air PSI changes so little and so does the corresponding volume, that it might as well be a liquid. THe PSI changes by +/- 2% and so does the volume. To me, it just means that Wayne is right, and a water/mercury ZED would be like a air/water ZED in a practical operation.
Quote from: TinselKoala on September 02, 2012, 07:38:33 PM
TK, Thanks for reporting that. Here is the thing that I missed in my first sim that I have included now, which makes it make sense to work this way:
The pod is not going to move up unless the "spring" force between the piston and riser is equal to the output load. Just like if you had a stick with a spring on the end of it and you had a bowling ball sitting on platform with a hole under it. When you first push the stick with a spring up under the ball, the ball will not move until your spring has compressed to the force of the weight of the ball. Then it will move up one-for-one with the stick movement. Of course, the stick "feels" the whole weight of the ball.
In my ZED sim model, there are two springs. One spring is the Pod Head as a normal buoyancy type force plus the air PSI, making the head seem higher (or lower if negative PSI). The other spring is the air PSI x the Pod Head area. The two interact, but do not have the same mx + b factors. The water head has more gain than the lift from the air PSI, because it has to move further to make up for the volume expansion of the air as the Pod moves up.
The net result is that for my sample model, I have a peak work transfer efficiency of about 65% at around 1/4 inch of riser movement -- which is well before the air PSI turns negative. So a short stroke is going to be better.
Playing around with the dimensions, I can see a taller and thinner gap and wall model getting up to 85% efficiency. Keep in mind that this is yet an unproven sim model, and only one layer.
So far, in my sim, everything is consistent with what Wayne said was the direction for a small table top system design point.
Quote from: webby1 on September 02, 2012, 08:05:02 PM
see3d, I do not have a locked pod to riser, but when I run with an oversized pod the risers will sit on it when in the down position, right now I am running the pod very lite and so it takes very little water into the chamber to make it lift, but even set up this way the pod does not stay stuck to the riser until enough water has been added to make it stay there, it will go up then settle for a moment while the risers are still moving and then lift up back into the riser.
Webby, that is interesting. It may be the same effect of a negative force, but uncoupled to the Pod in the middle of the operation. That bears watching carefully.
@see3d:
Hmm. OK, so you have a single layer Zed that can probably attain a transfer efficiency of 85 percent.... By transfer efficiency you mean the ratio of work output to work input? I'm assuming you do for the moment.
So ok... now can the single layer Zed then be treated as a "black box", like an internal pod, which then allows the second layer to be calculated in the same way as the first?
What I'm trying to understand is how a nested five layer system of 85 percent efficient modules can ever attain an efficiency greater than one.
(0.855 = about 0.44)
Quote from: TinselKoala on September 02, 2012, 09:48:43 PM
@see3d:
TK, a single layer is not the same transfer equation for the next layer. This is the overhead layer to get things rolling. If the single layer math pans out in the sim, then I bump it up to a 2 layer sim. I think 3+ layers will all use the same general function, but I am not sure if 2+ would be the same, so I will play it conservative and just add one more layer as a special case first.
I am not extrapolating my single layer result to a future result, and I don't advise anyone else to do that, because it isn not valid. I am following my painfully slow step-by-step method to understand the ZED from the ground up. I will leave it to others to judge the final performance from constructed models. I am so slow and methodical about my methods, that I am sure others will be way ahead of me by just taking the shortcut of building something first. When I build something, I want to know that my first model will work well before I start. The methods I use to build are dependent on the design criteria from a sim model. That is not to say that there is not real value in doing rapid prototypes to test certain theories -- because I do that too, when needed, but they are pretty ugly... LOL
@see3d:
TK .. I don't understand the 'work transfer terminology' either ? - And I also currently can't see why nesting risers will make any difference & should lead to well over OU ?
See3d .. I would have thought the obvious way to test efficiency in [& integrity of] the sim [assuming it has no losses] is to calculate PE start & top of cycle ? - Energy Input into the piston should equal the PE gain
at any vertical height cross section after start - no where should it exceed 100% ? - this applies to releasing the riser to do work as well.
N.B. In the single riser layer ZED sim PE + KE joules gained should never exceed joules of energy input [ f x d ] - if it does
at any position then OU is being indicated then & there IINM & gravity would not be conservative.
P.S. for those following the piston raising PE of fluid while riser is locked down is doing the same job of injecting fluid into the riser chamber under pressure I believe.
Unfortunately we all know that air is compressible and making such false assumption would make laugh a high school student, with false assumptions you will be able prove anything you wish to prove, lets be rigourous !
Quote from: fletcher on September 02, 2012, 03:49:18 PM
/quote]
Quote from: parisd on September 02, 2012, 11:55:06 PM
In my simulation, the compressibility is so slight that it makes little difference to the operation. First learn if you are talking about a first order issue or a second order issue in the particular application. If you want to prove a point, do it with numbers to show what difference it will make. If you are looking at 300% issues, then 3% issues can be ignored. I do not know the answer for a multiple layer system yet, so I would not make such a statement.
Quote from: fletcher on September 02, 2012, 11:30:39 PM
See3d .. I would have thought the obvious way to test efficiency in [& integrity of] the sim [assuming it has no losses] is to calculate PE start & top of cycle ? - Energy Input into the piston should equal the PE gain at any vertical height cross section after start - no where should it exceed 100% ? - this applies to releasing the riser to do work as well.
N.B. In the single riser layer ZED sim PE joules gained should never exceed joules of energy input [ f x d ] - if it does at any position then OU is being indicated then & there IINM & gravity would not be conservative.
Fletcher, I do calculate some of those things also, but they are meaningless at this point to me. I shared the parts I want to have verified by others experience. I will share more details when I am sure they are more true than false. No point in wasting time discussing things before their time -- it just invites fruitless speculations about things that have a high probability of being wrong anyway (due to my lack of mathematical skills). One step at a time. This is my learning experience, not my teaching others. Besides, I am really only interested in how high I can lift a 1 pound weight with a 1 pound input over the same travel -- work in, work out. Simple ideas for my simple brain! :-)
Yes, I can understand your approach of physical verification against model behaviour.
I was suggesting that cross sectional analysis of PE + KE v's Work Done is highly indicative that your formula's are indeed correct or near enough to not matter - if something is way out of kilter then it would be cause for concern & looking closer at the formula.
One thing you should be prepared for Dennis - that is, that criticism will rain down whether the sim [or sonsofsim] shows OU or does not - on one hand you will get comments about not capturing the true effect rigorously therefore not a reliable predictor of behaviour - And, on the other hand, that should it/they show OU that the formula's need work or that a sim that follows physics laws can never show OU.
That's why I admire your determination to accurately model a simple system first which matches real world behaviour & extrapolate the evolution thereafter with more sims from a solid first principles foundation.
Hi Seamus,
Home delivery...Piza hut does it...most take-outs do....why is the OVER-UNITY ZED not on the home delivery menu....
Do not despair!......here it is.....
Since you are hungry and have been repeating the same thing over and over. Let me fix you your favorite sandwich, I will prepare it for you and bring it to you on the couch. What I will not do is spoon feed it you. If you like some more cheese or mayo on the sandwich, you will need to get yourself from the fridge. Remember that you need to get off the couch for that.
There will be no further interaction from me beyond what is provided below, OK.
For more details, try to understand what is written and explained by Wayne in the previous 12x pages. Also an effort to understand an XLS worksheet, would help you. Especially for you, I laid it out in normal text format. I could have added some pictures but I think I should leave this for some other time (follow Barney's advice).
Example;We have a nested lifting device, 4 layers that share the same water displacement volume space but each have their own water column. We can control the total daisy chain water column from its bottom section 'which is the pod area'.
We have it setup that for the limited stroke length only. To stroke we inject water into the pod area to lift the head, that will also rise the heads in the above layers until we have 8psi, then we follow the stroke movement with displacement water for the pod area so it has a base to rise on. The risers have sufficient balanced water in the U-bend for the stroke length without impacting the head heights.
Sample Specs
Total lifting area (risers + pod)= 26031cm2
Control lift area (pod) = 4902
Lift efficiency ratio = Total Lift Area/Pod area
= 26031/4902
= 5.31
Pod efficiency ratio = Pod area / Total Lift area
= 4902/26031
= 18.8%
Virtual displacement water for stroke 3†or 7.5cm
Virtual volume = Displacement volume - Pod volume
= 195.23 â€" 36.78
= 158.5 Ltrs
** The virtual water is non existing water that plays a role as real water as per standard Archimedes
Pod volume ratio = pod volume/displacement volume
= 36.76 / 195.23
= 18.8%
** Pod volume and efficiency ratio’s match
Note: Do not be fooled that this makes this clever layered lifting device over-unity, all what is demonstrated in the figures above is how much less 'displacement' water we need than Archimedes. There is a penalty for the weightless non-existing water. Also do keep in mind that energy is calculated by nature in the 'displacement water weight' and not in the "water of the heads", the heads are a mediator and must be considered as a overhead.
TOTAL OUTPUT = (RiserWeight + Load) x 3â€
= (1000 + 2000) x .075mtr
= 75 + 150
= 225 KgMtr
NET OUPUT = Load
= 150 KgMtr
RECYCLED OUTPUT = Riserweight
= 75 KgMtr
GROSS INPUT = Recycled + Add-on costs (input referenced to zero level)
= 198 + 99
= 297 KgMtr
** Gross Input figures include adjustment for pressure down to zero level reference (8 psi = 5.62 Mtrs)
GROSS EFFICIENCY = Output/Input (absolute efficiency)
= 225 / 297
= 75.7 %
REAL EFFICIENCY = Load output/ Add-on costs (Effective operational efficiency)
= 150 / 97
= 155 %
** Real efficiency is the load output received minus the cost we need to pay
Please Note: Figures should be accurate within a 5-10% margin either way. The figures listed are rudimentary and intended to show the general operational energy flow of the Zed device. No overheads incurred by mechanical or other losses have been included.
Regards, Michel
What are all these numbers from Marcel? They seem almost deliberately designed to obfuscate what should be a simple and clear measurement and calculation.
Here are the facts and numbers we need:
Position of all moving parts at the start of one cycle.
Input work, or energy, from outside the system, over the complete cycle.
Output work, or energy, delivered to an outside load (or loads, see below), over the complete cycle.
Position of all moving parts and fluids at the end of the cycle: should be the same as at start.
Example:
Start: All risers and pod bottomed out, water levels even at height x, load mass of ML sitting on top of the output riser at height H0.
Something is injected into the system, a fluid. To aid calculation, this injection is done by depressing a piston of area AP through a stroke of SP with an average force of FP. This piston, cylinder and plumbing are considered external to the ZUT (zed under test), so the work done by depressing the piston is input work to the ZUT.
At the end of the injection, we pause and allow the system to settle, then we measure HL, the lifted height of the load mass. This gives us an output work value.
Then we go to the input piston and _pull it back out_, or allow it to come out "on its own", with some assist if necessary, until the same volume of fluid is withdrawn from the ZUT. This "assist" could be in the form of pushing down on the lifted output mass or by pulling out on the input piston. Any work that we do here to restore the initial state must also count as input work, though. Ideally the piston will come out on its own with the same force and stroke as the original input as the lifted mass sinks back to H0.
End: Everything is back where it started from: one complete cycle, nothing added nothing taken away.
With the numbers AP, SP, FP, ML, H0, and HL we would be in a position to calculate some actual efficiency numbers that meant something and that might allow us to discriminate between a simple hydraulic lever system, and the discovery of Water 2.0.
Where would excess energy be manifested in such a system? Well, hopefully we are not claiming the creation or destruction of matter, so "conservation of volume" applies: there won't be extra water or air beyond what we started with and the resultant pressures and positions will be the same. So excess energy must appear in some parameter of the lift or input piston stroke. It could be that the mass is lifted extra high, so that the simple output work is greater than the input work depressing the piston. It could be that the input piston is pushed back out with excess force for the same distance, as the lifted mass descends in the second half of the cycle, working against a different load. (I'm not sure if this wouldn't violate conservation of volume, though.)
@seamus10n: Hey, virtual water is no more -- or less -- ludicrous than centrifugal force. I've measured them both myself in various systems, and found them both very amusing, convenient sometimes, hilarious even, but certainly not ludicrous. ;)
Quote from: seamus103 on September 03, 2012, 01:04:38 AM
Garbage. Any engineer worthy of the title would take one look at this idea and dismiss it out of hand. There is absolutely no valid mathematical analysis based on known physics that could validate this device. This is because any such simulation would have the conservation of energy mass and momentum as the starting point. By definition this will not lead to an overunity result.
As such it is up to those claiming it works to present solid experimental evidence that it does. That is something that has not been forthcoming as yet.
Circular logic must prove itself, lest we accept the illogical as true, or that something has been left out of the ring.
Wayne
Seamus & TK,
You appear to be and live the USA and so is the inventor. This would mean that you would be more akin in understanding each other than I would. The inventor could help me quite fine and I could understand him fine, notwithstanding that I come from and reside on the other side of the world. I could understand his invention quite fine after doing some homework on his prompting that that would oil the wheel, why is he not able to do that with you two is my question?
* Here are the facts and numbers we need: ....give me...give me
I think the basic issue might lie with the understanding and expectation certain people have with the forum. Certain people just want blueprints so they can built/replicate, others want animations, video...ect.
The inventor was clear on what he wants to share on this forum, sure this did not match all our or your wants....He initiated the topic to share what he wanted to share to a defined extent, that is clear by now. The shared information is sufficient to draw further conclusions from with some effort from the reader side. Give me...give me..is too easy.
* Demonstrating where and when the energy arises out of no-where would.
I omitted this on purpose, since the inventor did not show it directly, I will not show it either (although it has been said where to find it. You know what to do,
From where I come from, we have saying that describes certain people, very much alike to a overcast sky.
Regards, Michel
Quote from: seamus103 on September 03, 2012, 04:37:19 AM
155 % efficient? So can I ask why this device does not appear to produce energy for more than 4 hours at 36 watts peak. (by my estimate about the same amount of energy in the 'pre -charge' based on the volumes , masses and initial displacements mentioned so far.)
Ludicrous appeals to the notion of "virtual water" won't help here. Demonstrating where and when the energy arises out of no-where would.
Seamus, I do not take it lightly that the Discovery of the ZED system counters much you believe and have been taught.
I felt the loss, eventually - like the many of us - you will be excited for the benifit this will bring to the world.
I think this Giraffe video does a good job of showing the stages of dealing with loss - pretty funny.
http://www.youtube.com/watch?v=G_Z3lmidmrY (http://www.youtube.com/watch?v=G_Z3lmidmrY)
Step 1. Acquire two liter diet Pepsi product.
Step 2. Save some of the diet Pepsi for lunch and pour the rest of that crap down the drain.
Step 3. DO NOT remove the label! It is the only chance you have to make one of the end cuts straight. Use it as a guide for scissor cuts while removing the ends.
The label glue and remnants comes off with mineral spirits and a lot of scrapping since the label material is a pretty good shield for the mineral spirits. PITA.
So the entire system OD will be one complete two liter section which is ~4.25" dia. The next smaller cylinder (Outer Riser) is made by cutting another two liter cylinder along it's length with a skill knife and straight edge. Once cut you will find that it wants to roll up even smaller, and usually not very round. So far NO two bottles have been the same. Again, PITA. But every once in a while the stresses in the material do make a fairly round shape. I scored a line at 1/2" from the cut and sanded where the lap joint will be. Then the glue...
I had told you of the Threebond plastic cement, but that was wrong. It is actually a Loctite product and NOT recommended for the primary joint! Instead, I now am using a product called GOOP. It is a clear and flexible contact type cement that you apply to both sides of the lap joint, wait a couple minutes, and then join. It drys by solvent evaporation, so I hold the assembly together with some little neo magnets that I seem to have EVERYWHERE in my garage now. I move the magnets around while it is drying to help even out the glue. The neos will squeeze it all out from directly underneath themselves and leave a void if they are not shifted during the set up time.
Excess GOOP peals off from the edges of the seam very nicely, but it take a lot of effort! I run a bead of the Loctite plastic cement along the edges of the seam inside and out to smooth and guarantee the seal. That stuff dries fairly hard and not as rubbery as the GOOP or silicon.
End caps are .10" lexan from LOWES. I score and snap close to round using a compass and skill knife. Final rounding is against an orbital sander that is held on it's side on the edge of my work bench. Again, a major PITA, but a fairly round disk can be made with some patience. These are roughed with sandpaper along the edges and bonded inside similarly roughed up cylinders with GOOP again to make the Pod and Risers. I've been running a bead of the Loctite on the inside to double the seal and stiffen the joint as it makes a good fillet.
The Pod bottom has a 1/4" hole in the center to allow for air to be circulated to dry the glue that holds it in place on the inside. I blew air inside with a ball inflator needle on my little air compressor a couple times during it's cure time until the vapors were no longer obvious. Then I sealed the air hole with silicon. And yes, I did do this by first chilling the Pod in the freezer and applying the silicon to it while it was cold (I let it cure in the freezer until it had skinned as well). So now at room temp it should have positive pressure inside to hopefully assist with keeping it air tight. It is currently at the bottom of a full 5 gallon bucket for testing.
The only other pressure testing has been to fill things with water and look for leaks. I've been overly generous with the sealing materials and hope for the best, but this is still a lousy choice of materials! But it is cheap!
Some day I'll break down any get a mini lathe...
Subsequent smaller cylinders were all made by removing 1/2" increments of material from the two liter PET before creating the lap joints. So they are all nesting with 1/2" differences in circumference. Except for the Pod, none are perfectly round on their open ends. So they touch in the dry fit testing, but still slide smoothly against each other, so I am hoping for no problems. I have no idea if any hydrostatic centering will occur and do NOT believe it would have enough force to round out the deformed cylinders anyway.
M.
If the air volume in space one is pressurized from 4 PSI to 8 PSI then its volume has to be reduced by half, so half is not negligable even if the volume of air in space 1 is probably quite small, this is the law of ideal (perfect) gas (PV=NRT ) or boyle's law (P1V1=P2V2) and air is much much closer to an ideal gas that to an incompressible fluid.
Now let see what would happen if we replace the air by an incompressible fluid (liquid) of a lower density than water, then the space 1 pressure can be increased immediately, (i.e no need to inject a certain volume of water to compress a gas by half its volume to go from 4 to 8 PSI). The pressure will be transfered from that lower density space 1 to water column between layer 1 and layer 2 then to lower density space 2 and then to next space (no 3) and having identical pressures in all spaces meaning same force on both sides of surface 1, both sides of surface 2, surface 3 being at 8PSI (or whatever pressure) minus atmospheric pressure, the multiple layers effects seems to be lost and we are not anymore in the conditions described in Wayne ZED. (the above is assuming a 3 layers only)
Note that even with a compressible gas like air, with the understanding I have of the ZED, there is no added value from the vertical forces on the multiple horizontal surfaces (S1, S2, S3), the reason is that S1(P1-P2) + S2(P2-P3) + S3(P3-Atm) is identical to S1(P1-Atm) (all surfaces being practically same or to be very accurate if only 1 layer then S1 can be = S3) so the improvement of efficiency comes from something else than the vertical forces and from what I dont know. Anyone? I asked Wayne but still don't get it.
Sorry if I used only few numbers.
Quote from: see3d on September 03, 2012, 12:06:11 AM
Quote from: parisd on September 03, 2012, 11:00:57 AM
The 4 and 8 PSI values are GAGE pressures. The equations you are stating all require ABSOLUTE pressures. So:
4 PSI (gage) = 4 + 14.7 = 18.7 PSI absolute
8 PSI (gage) = 8 + 14.7 = 22.7 PSI absolute
where 14.7 is an accepted value for atmospheric pressure.
The volume of air is not reduced by half as the pressure changes from 18.7 PSI to 22.7 PSI.
M.
You are correct I am not used to PSI and was thinking we used absolute pressures, but still air cannot be considered as incompressible. Does the rest of my post make sense ?
Quote from: mondrasek on September 03, 2012, 11:19:02 AM
M.
Quote from: parisd on September 03, 2012, 12:37:02 PM
I think the rest of your post makes sense. Sorry that I can't give you an answer to your questions though. I became stuck with my own analysis once the air compressibility and lift required an iterative or higher math solution. So I was never able to find the OU myself. Instead I look at the tools from LarryC and see3D and wait for more.
And I wait for glue to dry...
M.
@Mondrasek. Re your post 1853. This is without doubt a very practical and informative post for model makers.
People in different parts of the world may have to experiment with different glues and materials that are available locally. One thing I figured out is that the top caps of the risers do not need to be transparent. So alternative materials could be used here, including thin plywood if it is treated with a waterproof paint or varnish.
In the past, I have used a cheap bench grinder as a substitute lathe when making plywood discs. I cut the disk approximately to size using a fretsaw or band saw. I then drill a suitable hole at the centre and mount the disc in place of the grindstone. I then take a long rasp, and placing one end on the bench, bring the middle of the rasp against the revolving disc. Naturally. i wear goggles. For safety reasons, you do this at your own risk, but it works for me.
Hi,
thank you for responses and posts, I'm learning from it.
My previous model for inverse travis effect (1inverse riser) showed no OU. Advice was to go multi riser system similarly as ZED, reuse mass etc
So I created the following model and would still call it 2riser. I think see3d would name it one riser but name is not important now.
Model is 2D but it can be mapped on a 3D model with cylinders.
I used following simplifications:
- air in below text should be replaced by icompresible weightless fluid lighter than water. I agree with parisd that air IS compressible but it just makes calculations more complex and since we can use icompresible fluid why not make things simpler if it helps and simplification is valid.
- risers have negligible weight
- compartements have negligible thin walls
- no losses
1. picture shows starting situation, risers are locked. There is inner compartment with the pod(1th riser) and 2 units of water. In the outer compartement containing 9 units of water on each side is floating 2nd riser. Air pressure above 2-riser but also air pressure in inner compartement are the same = 1atm. Under 2riser left side are 6 units of air and 6 on right side.
Total lift force of risers is 6 units. 2riser contributes 0 and the pod 6.
2. Precharging, risers are still locked - injecting 2 units of water in the inner compartment (at its bottom) raises water in 1 and 12 column by one.
Total lift force 16. The pod contributes 12 units and 2nd riser 4.
3. Stroke - risers are allowed to lift up one unit distance. To keep internal pressure the same(real ZED keeps pressure in inner compartment also the same 8psi), 10 extra water units need to be injected. Most of this water (6 units) is needed to fill space under rising pod.
Total lift force after stroke is 22. Inner pod contributes 18 and 2riser 4.
So work that can be done using this model equals lifting force caused by 16 volume units of displaced water over one unit distance. In fact lifting force increases from 16 to 22 over one unit distance. Water injected at bottom = 12 units.
Now I'm trying to answer the question: is the work done enough to inject 12 units of water at bottom and by this close the loop? Webby1 said some posts ago we can use builded pressure of water from stroke step and lead it to another 2 riser. I assume equalization would fill first 6 units in another 2riser. Question (restated) is then: is the work done enough to inject only 6 (not 12 units) of water and close the loop?
I have a feeling that it can but think at the same time that feelings have no place here, just facts.
thanks,
Marcel
QuoteBut my own position is that I'd want to avoid people wasting their time on overunity concepts that don't work.
Until you can provide either solid experimental evidence or a plausible theory on why gravity acts in a non conservative way in this device then I think it is a reasonable stance to take.
Seamus & TK,
As watchdogs that qualify over-unity examples with a plausible theory that will waste no-body’s time, see below ONE of the MINOR Zed OVER-UNITY aspects that should have woken up the dog that was watching !
I re-arranged some of the measurement details somewhat to make it stand out more. Reduced the pod area to 50% of the outer lift layer area. The idea is to illustrate Wayne's strategy & logic towards over-unity, not by creating energy, but by reducing costs (governments could learn something here). The point here is not to explain where the energy is coming from and how this impacts the sacred laws and re-arranges what we new before. The point is that the logic flow is sound and it produces results.
Sample SpecsTotal lifting area (risers + pod)= 26031cm2
Outer Layer 4 area = 5500 cm2
Control lift area (pod) = 2750 cm2 (50% of outer layer area)
Layers = 4 + pod
= 26031/2750
= 9.46
= 2750/26031
= 10.5%
= 195.23 â€" 20.62
= 174.6 Ltrs (cm3 -> Ltr)
Real displacement water for stroke 3†or 7.5cm
Total Volume to rise 3†= Outer Lift area x stroke length
= 5500 x 7.5
= 41.2 Ltrs (cm3 -> Ltr)
** The real displacement water must be provided at the appropriate pressures for each layer. This is offset in the energy balance. The water is effectively shared in the same way the air spaces are shared by all layers. As a quick calculation, the balance of energies would be unity (if we ignore the heads)
Actual used volume for for stroke 3†or 7.5cm ( using pod only)
Total Volume to rise 3†= Pod Layer area x stroke length
= 2750 x 7.5
= 20.6 Ltrs (cm3 -> Ltr)
** Here we use the pod area for stroke displacement water injection. Supported by sufficient balanced water in the U-bend for the stroke length. The pod area is 50% of the largest lift outer area. This reduces our water and input costs by 50%
Energy used = 20.6 x 5.62 = 115.7 KgMtr (8psi = 5.62 mtrs)
Potential energy gained by lifting 3000Kg for 7.5cm @ 8psi = 225KgMtr
NET EFFICIENCY = 225/115.7 = 144.5 %
OVERUNITY by 44.5%Note: This is only one of the minor optimizations towards over-unity in the Travis Zed. The major optimization trump card is way more simple in its setup but because of it more ingenious and more beneficial
Do not be fooled by the first sight and your first impressions of this set of inverted cooking pots. There is way more cooking going on here than you think.
Regards, Michel
I've corrected the SI calculation sections on the attached spreadsheets and showing the results from each in the first picture.
The last two results are from the System Rise water height calculator to show the force before a rise and after a three inch rise, they are the same. It is accomplished by increasing the water level between the pod and the pod retainer wall during the rise. The total force is different from the 3 Riser at the top because the Pod water level was reduced and replaced with air pressure to maintain the water head in the Risers. This has been explained many times, but some just keep implying that there is no force over distance values.
For the real anal, use the System Rise water height calculator and start with a rise value of .00001 and press the Adjustment button, wait 10 seconds for the number to quit spinning. Record the force results. Continue incrementing by .00001 until you reach 3 inches. Please report back in a month with your results. I'm sure you will remember next time before implying again.
Regards, Larry
Why can you mathematicians not answer the simple questions, without all this obfuscation?
You start at the bottom, precharged however. DON'T TELL ME THE DETAILS of the precharge, I will take your word for it AS LONG AS IT REMAINS IN THE SYSTEM AND IS THE SAME AT THE END OF THE CYCLE. You have some "load mass" sitting at some initial height and this mass and this height you will tell me.
You use an external piston and cylinder and plumbing to apply A KNOWN AMOUNT OF INPUT WORK by injecting your desired quantity of water into the chamber surrounding the pod. All I need to know here is the surface area of the piston, the stroke length, and the average force exerted on the piston to push it in for the stroke length.
You then measure the HEIGHT of the LIFTED WEIGHT sitting on top.
You have now completed ONE HALF CYCLE. The input work can be compared to the output work at this point, without all the complications introduced by Marcel and Larry. But you aren't done, because perhaps your precharge has boosted the output, so for TOTAL work balance you need to return to the initial state EXACTLY. So now you compute the work in the second half of the cycle: Your lifted load mass becomes the "input" and your injection piston travel is now your "output". If the system returns to the initial state on its own, just from removing whatever force you are holding the piston in, you are done. If you have to put in extra work, either by pulling out the piston or pressing down on the lifted weight, this counts as input in the total work calculation. If the input piston pushes out with more force than you took to put it in initially, averaged over the full stroke, then this difference counts as output work in the total work calculation.
Please use measurements from an actual system. Made-up numbers and complex calculations only serve to muddy the waters.
So, will one of you numbers crunchers please just give the values that will allow actual calculations of work in and work out, total? This should be very easy to do, and the only time that it has actually been done, by webby some days ago, the calculation I performed on the given data indicated an "ou" value that was in the "noise floor" or the margin of error in the measurements.
The fact that there is so much reluctance to give the required numbers in an easily interpretable form indicates to me that there must be some reason for not doing so. Perhaps, using the measurements and calculations that I would like to see used, you don't get such big overunity numbers.
In fact Michel's given OU number is so embarrassingly great that he has to remind us, over and over, that losses aren't being included... as if losses in a wellconstructed system would prevent the OU from several layers from building up drastically.
So let's break it down again.
MrWayne has said that he has a simple, three layer system that is clearly overunity by itself. These are his own exact words. And I have asked over and over, how is this clear overunity measured IN THAT SYSTEM, and what is the ratio of input work to output work for this simple system that is clearly overunity by itself?
All that is needed to answer these questions properly is to set THAT SYSTEM up with an external piston and cylinder that can be used to apply a known input work, and do a few simple measurements of the work put in and the work gotten back out. Webby is nearly doing this with his system.... the two thousand dollar set of tennis ball tubes.... but not quite. In the only experiment he reported that is "almost" this simple, I got a numerical answer that was "positive" but not by much, in the noise floor of the measurements.
Quote from: Red_Sunset on September 03, 2012, 03:22:57 PM
= 2750 x 7.5
OVERUNITY by 44.5%
Note: This is only one of the minor optimizations towards over-unity in the Travis Zed. The major optimization trump card is way more simple in its setup but because of it more ingenious and more beneficial.
Regards, Michel
TK .. I agree with your objective approach to method, measurement & data collection
100%.
Just a side note about Mr Sunsets last contribution.
I get
194 % Net Efficiency based on his figures i.e. that's OverUnity by 94 % [give or take 5-10% margins of error & no losses] - re 144.5 %, but I don't want to seem trivial.
I also have a little problem in comprehension just near the end - he says, I think, that the systems input is 20.6 liters of fluid which raises the PSI from 0 to 8 PSI - then he uses a head justification of 5.62 m = 8 PSI.
AND ... 8 PSI is indeed 5.62 m thereabouts - so he seems to be saying, I think, that 20.6 liters [kg] of fluid is raised by a height of 5.62 m = 115.7 kgm = 1135.72 joules Input Cost ["Energy Used"].
Yep, that looks ok - the trouble I'm having is that 8 PSI at 5.62 m head means that 20.6 liters [kg] would only raise its PE by half that distance because Static Pressure = pgh = 1000 kg x 9.81 m/s^2 x 5.62 m = 55.132 KPas = 8 PSI [i.e. fluid depth 5.62 m], while an equivalent column of solid would have its CoG half that distance [i.e. 2.81 m] since density is uniform.
So was the potential raised 5.62 m or 2.81 m ? If 5.62 m is correct for the "Energy Used" calc the 20.6 liters would have to be raised 5.62 m to get 115.7 kgm or 1135.72 joules & this doesn't seem to match the head statement of 8 PSI at 5.62 m.
If the former even 194 % looks paltry.
Or maybe the hydrostatic paradox is coming home to roost - higher pressure means more work done to force a fluid into the system, especially if you want to force it in at a lower level & take it out again - I can only think that the major trump card lies in volume changes beneath the risers but then we all know pressure is scalar & pushes up & down & that's what the paradox is about ?
I hope you get straight answers this time, especially from the spreadsheet kings.
Yes, well, this part
225/115.7 = 144.5 %
is certainly wrong; my calculator agrees with fletcher's when I do the division 225/115.7 and gives me closer to 1.94, or 194 %. An embarrassment of riches, as I said before.
But garbage in, garbage out, anyway. Where do the numbers come from in the first place?
Now, when I was addressing see3d about nesting systems, perhaps I wasn't using the right image. You have a single layer Zed, analyzed to give ... what, now, 194 percent OU? So you take this system and call it a POD.... and use it as a pod in a second Zed constructed around it. So now you have a two layer Zed, the inner one analyzed to give 194 percent OU and the outer one, constructed just the same only bigger and with an active OU Zed inside it instead of an inert pod. So the outer one should also give an OU percent boost as well, right?
So by the time you've gotten to 5 layers, you have 1.945 = about 27 1/2. You've even beaten Rosemary Ainslie.... with a COP of over 27. It will take some mighty groaning huge losses... to what, heat?... to keep your usable output down to 36 watts.
No no no - the 194% was not a single riser & pod - it was a 4 or 5 layer model by the look of the picture that went with Mr Sunsets math ;)
Quote from: fletcher on September 03, 2012, 11:03:42 PM
Ah, I see... but so what? It can still be put into a "black box" or rather a black cylinder, and called a "superZed", can't it .... then it can be used as the riser in the center of an outer superZed...... etc. etc.
I mean, I can certainly stack levers, or water heads in a loopy hose, in this way. Why not Zeds? If a Zed layer is OU, and a nest of five Zed layers is even more OU, why can I not nest some nests of Zeds and get even _more_ OU?
That would be the Rushin Egg ZED.
Why not, yes, you can stack levers & loopy water heads - Pascal's hydraulics multiplies force doesn't it !
What we [& I mean that in terms of all not yet convinced] should understand is that we are not supposed to fully understand - the exception is see3d building his sim from the ground up & taking an impartial view & hopefully sharing his findings where the Inputs & Outputs can be questioned - he is prepared to let the chips fall where they may - we are supposed to build & make our mistakes along the way, & learn from those.
Your call for the obvious OU 3 layer single ZED with relevant empirical information & Input & Output data capable is the logical way forward - you may have to wait for the replicators or Mondrasek to finish first.
Quote from: fletcher on September 04, 2012, 12:33:37 AM
Why not, yes you can stack levers & loopy water heads - Pascal's hydraulics multiplies force doesn't it.
What we [& I mean that in terms of all not yet convinced] is that we are not supposed to fully understand - the exception is see3d building his sim from the ground up & taking an impartial view & hopefully sharing his findings where the Inputs & Outputs can be questioned - we are supposed to build & make our mistakes along the way, & learn from those.
Sure, you're right. But what if they don't find OU? That would just prove that they didn't understand the principle and didn't build correctly, wouldn't it? Building an overunity device on your tabletop is evidently sort of an "entrance exam": Only those who can do this, or simulate it with a complex chain of spreadsheet reasoning, are allowed into the inner sanctum.
There is more "back channel" communication happening on this project, between the various participants, than in any other thread I can think of. You've got all kinds of compartmentalized information being shared by pairs and triplets of people through PMs and emails, not necessarily overlapping.... nobody, not even MrWayne, knows the full extent of this hidden layer of Zedspeak happening behind the scenes of the open-source forum thread. It's veritably Steornish in its onion-like layering and pungent odor.
The closed circle of table-top waterpump contestants is a virtual clone of Steorn's SKDB cult-club. I wish them the best of luck.... and I'm sure that if one of them is actually successful they will sleep on it for a night or two, letting the real implications set in, before they decide to inform MrWayne and collect their measly ten thousand dollars and special trophy plaque for solving his problems for him.
One reason I am so skeptical of the spreadsheet modellers and the engineers who MrWayne says confirm his claims, is that "I have been here before" in a manner of speaking. I am talking about the work of P Graneau and his claim of overunity water arcs. He had a math model based on standard conservation of momentum, he had perhaps thousands of experimental trials, reams of data, years of research, papers published in physics journals and his model made sense. Only problem was that experiments never showed the actual 7-fold increase in energy his model showed should be there. Why not? Welllllll.... it was because of this: even though his _model_ was correctly executed, and consistent with conventional physics, and looked valid on its face, and returned internally consistent results..... it was the wrong model. In the final end, a more complex model based on underwater shock fronts turned out to describe the existing data and make predictions consistent with experimental results... and showed no overunity. Moral of the story: Your spreadsheets and drawings could be themselves correct and consistent, all ducks properly marching in line..... and they could still be wrong. Epicycles.
And the only way to tell the difference between epicycles and a more correct model is to refine the input data. Part of this is to gather the _correct_ data in the first place, to the proper degree of precision necessary. Another part is to analyze the data correctly... using the right model. Yet another part is to see if your model can predict future data gathered under different initial conditions.... this is a robust test of a model, and this is where Graneau's program -- along with many others -- broke down.
Just think for a moment, why do I take the trouble to post ?, Why did Wayne take all the trouble he did ?
Answer; To share something that could possibly help you, open a new horizon for you.
You guys are brilliant ! in showing your insolence. I agree you need to question scrutinize what is posted but you do it at the cost of understanding the intend of the communication.
The reason might lie in the fact , you ‘do not want to understand’ because ‘you are not looking for understanding’, I assume this might not be intentional
Your main purpose appears to be, how many holes you can shoot into any posting. Making for a pretty nice on-line gaming activity.
My applogies for the calc error "225/115.7 = should be 194% " (writing postings near midnight doesn’t improve accuracy). 144 or 194 doesn’t impact the core intend of the posting. The figures are merely illustrative to the underlying purpose of the posting, to show where and how some over-unity can be had. The values shown are only important in their relationship value, not in their absolute value. The other details like layers ect only have importance in the relative dimensioning on which the number are based.
I am describing a concept principle, not a model blueprint for building
What was the purpose of my posting ?
One of the many ways cost savings are used in the Zed to show how OVER-UNITY. The layered device that is in principle not over-unity can made over-unity by the manipulating the area ratio’s and the process used to initiate lift.
Limitation “Please Note†on the bottom of the post,
** “The figures listed are rudimentary and intended to show the general operational energy flow of the Zed device.â€
Let me allow you to consume my time, just for one more time only .
1.. Fletcher - Yep, that looks ok - the trouble I'm having is that 8 PSI at 5.62 m head means that 20.6 liters [kg] would only raise its PE by half that distance because Static Pressure = pgh = 1000 kg x 9.81 m/s^2 x 5.62 m = 55.132 KPas = 8 PSI [i.e. fluid depth 5.62 m], while an equivalent column of solid would have its CoG half that distance [i.e. 2.81 m] since density is uniform.
Answer: I though that I was clear enough in my posting. If it only lifted half the distance, there would be no point for me to make a posting. To understand how 20.6 ltrs does the job of raising 3000kg for 3â€, you will need to use your imagination & visualization and play it out bit by bit, this might take you some time.
The pivot lies in the ratio between the Outer Layer and the Pod area. A pod area as big as the outer layer surface would be “unity†if we ignore losses. As you make the pod area smaller than the outer layer, the outer to pod area ratio will becomes your advantage over ‘unity’.
There are pre-requisites we need to satisfy. That is stroke distance. Since we inject displacement water only into the pod area, the risers must be pre-provisioned sufficiently to support the stroke distance (so they do not run dry). The criteria will be lift force (pressure) and stroke distance.
2.. TinselKoala - But garbage in, garbage out, anyway. Where do the numbers come from in the first place?
Answer: The figures are merely illustrative to support the description and discussion of a concept principle. They are not intended to serve as a model blueprint for building. The values shown are only important in their relationship value, not in their absolute value.
I want you to see the point, not to tell you how much it is going to ..give me…give me..
PLEASE NOTE: This is not the main energy gain conundrum of the Zed, the ingenuity by Wayne to achieve the main caveat will blow your mind.
Finding it yourself is important to really appreciate and relate to the discovery. To get a taste what the inventor went through to arrive at this point and the feeling he must have had at the point of discovery. To discover the trick to fool nature.
If you think you have seen it all already, it may be best that you keep your silence.
The world needs people that reach beyond the limits to advance mankind.
Regards, Michel
Quote from: TinselKoala on September 04, 2012, 01:34:01 AM
I, at least, agree with you & have little faith in spreadsheets, in & off themselves - actually spreadsheet programs are fine & I use them, it's the modelers that can be the weak link.
I am much more impressed with robust simulations & real world POP experiments that can leave no room for doubt by the rigorous nature they are conducted & examined - it is a given that the modeling that follows should then be highly predictive but built around actual data.
I will trust the process underway to come to some sort of firm conclusions - either way it pans out will be a good result from my perspective.
Michel .. thanks for the reply - you won't be offended if I await actual data from the replicators & long run test before I'm swayed - I don't need to relive Mr Wayne's eureka moments for myself - I'd be too busy trying to rewrite the laws of physics to accommodate non conservative gravity loophole you speak about.
jesus fucking christ!
it should be obvious by now that this system will never work!
data shown is shit!
videos and images shown, shit!
no solid proof has been shown!
expecting us to have faith that this system works and going along with it is absolutely unacceptable!
this system will never go open source! and if it does I bet that will be the time we find out it doesn’t work!
this type of shit will not end here, there will be others so get use to it!
eventually someone (or group of people) will come along and will actually open source their over unity/free energy discovery.
but until then we will have to deal with shit like this!
and if i’m wrong in the end, well then I apologize in advance! seriously. ;)
QuoteQuote from fletcher
Fletcher, Thank you for a decent and meaningful response. No, I will not be offended, I understand your reservation and I appreciate your response that you understood my comms and that you require further investigation to make up your opinion.
To me this means that you are doing your due diligence on your part instead of dismissing it outright like some/most of the other members on this forum without producing any validation on their part why a certain logic is illogical or wrong, except for a few high flung statements pulled out of their back pocket or science manual.
Example post, how not to respond: (from ghost)
data shown is shit!
Seamus, No.. That statement makes no sense. Either some part of the cycle results in an energy gain or it doesn't . Your explanations show leverage is possible but leaves out how and where the actual energy gain occurs. Show where that happens or stop wasting our timeNo.. That statement makes no sense. ** Please expand your statement, why doesn’t it make sense. I though I explained it simple and well enough.
Either some part of the cycle results in an energy gain or it doesn't .** The energy gain was clearly demonstrated together with the source that created the gain in a logical fashion.
You may explain why this is so impossible in a progressive logical rebuttal. It is clear that you have difficulty to understand this but if you do not provided more details why you can not get your head around this. I can not help you.
Your explanations show leverage is possible but leaves out how and where the actual energy gain occurs. ** I showed a net energy output that was more than we put in. And I showed how we came to that point.
That is where a clever guy like you comes in. You can make a clear analysis why the example given in post #1861 can not work as stated. Or tell me what produces this magical energy, or better said how can it be possible to demand a discount from nature within the bounds of the known laws. I can only tell you, I do’ this and that’ and look, I get this for free.. Believe me it is still a puzzle for me too. I do not claim that I know all. I am on a discovery tour. A bit like Columbus, he should have been in India or China but he was somewhere else outside the boundaries of what was known. Seamus, you got the ball. This is what the forum should be all about to be of any value.
Show where that happens or stop wasting our time.** Yes, show us what happens, I did in earlier post, it is now your turn to make a meaningful contribution that will advance the train of logical reasoning, so we can ALL come out successful for the good of all of us and the world.
Lets be a team and stop hiding,
Regards, Michel
Quote from: Red_Sunset on September 04, 2012, 01:51:37 AM
Michel, Thanks for your little insight nugget.
Quote from: fletcher on September 03, 2012, 12:37:24 AM
fletcher, I may grumble a bit when it looks like you want me to do more work, but I appreciate you inputs on my sim. I take them all with due consideration.
Yesterday, I spent most of the day trying to make a plot for the energy in vs potential energy out, or captured inside. I broke down every individual change in pressure or head inside the ZED and all actual work done. I then tried to show every combination that could be taken together. I could not get anything that looked even close no matter how I played with the combinations. That is when it dawned on me. I was never going to be able to make it make sense using that approach.
My whole simulation is based on balancing the input force with an internal state that creates an equal and opposite force on the input. I was avoiding using the input forces and direct "push back" forces in all my formulas, because I knew that was going to show 100% by definition. Yet that was the only calculation that could be used. Either that or I am way off base in my relationships between the internal geometries. Otherwise, I would have to show that I am creating and destroying virtual water on demand. The real test will have to come from matching up the sim and actual build results
Lacking any further inputs from builders, I will push forward with completing my revised PDF with new animations.
@ ALL BUILDERS,
I am quite interested in having measurements from tests that I can duplicate in the sim by adjusting the sim dimensions to match your models. Please PM me with any details that you would not want to share publicly yet. I don't care if it shows O/U or not.
I have been thinking about how to take measurements of the heads in a clear ZED. The way I am leaning towards is to mount a LASER pointer on a right angle stick that can slide up and down on a fixed vertical post, wall, etc. A poor man's height gage! I happen to have a LASER pointer that puts out a line rather than a dot, which might make it easier to see. The other thing was to get some colored plastic floating beads to put into each head to make the level easier to see, or a cutout sheet plastic ring might be a better way.
The needed data other than the ZED dimensions is the water heads at the beginning (down), the heads when the pod starts to lift, the heads at about half stroke, and the heads at the top of the stroke (just at the top stop if you have one). The data would only be used to verify the accuracy of the sim, not to be shared by me.
My sim is currently limited to a single layer, but I will add more layers in time. So, even if the model has more layers in it today, The data would be useful to me to evaluate the next iteration of the sim.
TIA,
Dennis
Hi Dennis
If nobody else is that that point yet, I may be able to give you a hand by the end of the week.
I should have a single layer demo available to work with by then.
It will be 8" OD x 12" tall with clear .125 walls and .125 gaps.
Any assistance I can provide.
I'd already planned to work from the outside in, taking as many measurements as I can along the way.
It's set up to be 5 risers and a 2.5" pod fully assembled.
Clear, single top plate so it will be pretty simple to monitor what's going on inside - for better or worse :)
Dale
Red-Sunset said
The Pivot lies in the ratio between the outer layer and the pod area. A pod area as big as the outer layer surface would be unity, if we ignore losses. As you make the pod smaller than the outer layer, the outer to pod area ratio will become your advantage over unity.
1. The pod is a cylinder. By pod area , do we mean the area of one end of that cylinder?
2. As it would be physically impossible to have a pod with an area as big as the surface area of the top of the outer riser, and still fit the pod inside he riser , can we assume that this is a theoretical question?
3. So making the pod area smaller than the area of the top of the outer riser, is advantageous in terms of gaining OU. Is there, therefore an "ideal" pod to outer ratio, Or can we enlarge this ratio to an absurd extent, and still gain? Can Red_Sunset, or anyone please answer these questions?
Hi Dale, that would be great. I am actually interested in more than one set of inputs from different models, since the measurements from different people will vary in accuracy, and the sim might have an error that does not show up in all configurations. Having measurements from you as you add layers would be a real bonus. The more, the merrier. :-)
PS. I put in the rough measurement into my sim for 8 x 12 size with 0.125 walls and gaps. It spit out that to get a 1.28 inch stroke it would need about 10 pounds of input and output force to be at an efficient operating point. It would be a lot different if the pod was not as large as shown. I have not put the ability to vary the wall and gap sizes independently in the pod area or exit areas yet. I will do that soon -- as if anything I ever do can be considered "soon"... LOL. Here is a picture of my sim output. I am sure your setup will be somewhat different, but it is a data point for consideration.
Thanks,
Dennis
Quote from: neptune on September 04, 2012, 01:47:54 PM
Hi Neptune,
If I understand your question, it is possible to have an exit head area that is larger or smaller than the pod area or pod head area without doing anything absurd (I just put that into my sim both ways). If the whole last layer "air" area is used, then it is even an easier ratio to achieve. The geometry is not constrained. As far as the exact definition of terms by Red-Sunset, he will have to confirm that.
Seed3,
Your Zed drawing is interesting and a bit different to what I imagined. what is the dark blue, gray, light blue and what is the orange rectangle at bottom?
Neptune,
** By “area†we mean “lift areaâ€, on which pressure forces act to generate lift
** Quite an interesting interpretation, it definitely does mean that he pod must fit inside the outer riser otherwise the outer riser would become the inner riser. This also means that the Travis buoyancy device is by default over-unity.
** There are quite a few other design considerations that come into play that need to be looked at, changing the lift area ration affects the lift force. Smaller area, more OU but lower force. You will need to run this through xls to get a better feel. I have not done that
Regards, Michel
Quote from: parisd on September 04, 2012, 03:16:29 PM
Seed3,
parsid, you must have missed my posted link to my public ZED folder with a PDF description of the ZED drawings used in my sim. Here it is again. This is where I will post my updates to the PDF and animations. These are about to be updated, as the current ones are wrong in the details, but it will give you an idea of what it all means.
https://www.dropbox.com/sh/6vdnbk72ywyckns/zB501rT78P
Seed3,
The labeled diagram for the simulations is on page 2 of his original pdf document.
Quote from: see3d on September 04, 2012, 03:33:32 PM
https://www.dropbox.com/sh/6vdnbk72ywyckns/zB501rT78P (https://www.dropbox.com/sh/6vdnbk72ywyckns/zB501rT78P)
Parisd .. I believe you are viewing a split screen representation i.e. half images of a ZED in the before & after phases of half a cycle, for comparison.
The orange rectangle at the bottom is a Piston that an up force is applied to - the center orange Riser is locked down initially so it can't move - the Piston pushes up the water volume beneath the Riser [N.B. the dark blue shells are the Pod walls & never move] - water volume [calculated on circular areas x heights for volumes] is forced to rise up the inner side of the Riser - this displaces the grey area of air [the air gap] - the air in turn pushes the water columns [as seen in the sim] down & up on the outside - so the air gap is just a low density fluid that for the purposes of a sim transmits water pressure.
As the outside water column rises the head pressure rises - this is proportional to the volume of water in the Piston chamber that is forced to bypass the locked down Riser - this raising of head [measured from the outside water column height to the top of the Piston face] creates the Buoyancy force the Riser experiences - this buoyancy force is real & is proportional to the 'virtual' volume displacement of the Riser + Riser 'legs/rings'.
Note that :
1. the Piston must do Work to raise the mass of Piston + Piston chamber water + NET Pod & Riser columns water - this means there is an increase in system PE achieved by Work Done.
2. as the head increase is proportional to the volume exchanges the Static Pressure [i.e. pgh where p = density] increases on the Piston face - so in essence as the head increases rapidly for a small volume input the Static Pressure increases also - since Pressure is Force x Area & Force = P / A we can see that a larger & larger force opposing the Piston is generating - this 'counter' force is also 'virtual' volume dependent.
P.S. the Piston 'feels' like it has to lift the virtual volume equivalent in real mass, even though the actual volume real mass is considerably less.3. at some point the Riser is released [in the sweet spot] & net upthrust force [buoyancy less gravity force] causes the Riser to gain PE & also increase the PE of the Load mass - of course while moving they both have KE.
4. the displaced virtual volumes are now reduced [lowers the water PE somewhat] & the system is top of cycle & in equilibrium again, as before the Piston was forced to move upwards [the Piston in the sim is to represent water injected into the ZED proper] - the system returns to starting positions & Potentials when the load is allowed to move the Riser, Water & Piston back down to their original positions & volumes etc.
N.B. At this stage it looks like the opposite action of depressing an ordinary float into a tank of water - i.e. the force to depress the float is the same NET cycle force as raising the Piston & contents etc, IMO.
I'm sure see3d will correct any misconceptions I may have.
Quote from: fletcher on September 04, 2012, 04:22:52 PM
... this displaces the grey area of air [the air gap] - the air in turn pushes the water columns [as seen in the sim] down & up on the outside - so the air gap is just a low density fluid that for the purposes of a sim transmits water pressure...
...Note that :
1. the Piston must do Work to raise the mass of Piston + Piston chamber water + Pod & Riser columns water - this means there is an increase in system PE achieved by Work Done...
fletcher, thanks for providing parsid with that detailed description. A couple of points for the above quotes:
The sim does model the compression in the air. The grey color gets darker as the PSI increases. It is not an absolute scale though -- I adjust a parameter to match the particular sim max pressure. Also, if the air pressure becomes negative, the color takes on a red tint.
On point 1. above:
My sim model is based on counterbalancing the piston, water, and riser mass. That only leaves the output load weight in the equation, so it is much easier to model. This is not cheating though as a physical model can easily be set up this way. It should actually perform better for a single ZED.
Quote from: see3d on September 04, 2012, 05:18:51 PM
On point 1. above:
Yes, duly noted about the compressible gas variable - Mr Wayne & Mr Sunset have said that incompressible fluids of lesser density work just as well - for the purposes of understanding a single layer ZED as you have represented it it would make very little difference [hardly any air PSI/volume change I think you said] to think of it as a low density non compressible fluid.
It begs the question which I have thought about before & I'm sure others have also - why not just have water replace the air gap ? - the answer seems, it appears to me, that the same density water in place of the air gap might well act as a syphon as water wants to flow to lower areas by cohesive bonds i.e. reduce its PE - therefore it might try to pull water volume into the Piston Water Chamber - for some reason they don't want this effect so use a lesser density fluid.
On your second point Dennis - yes, I well remember that was your objective - which goes back to my comment about leaving the Pod & Piston stationary & applying a force to sink the Riser + Load [the reverse ZED sim
i.e. changing the reference frame] - measure that Work Done against the Work Output i.e. when the Riser/float is released it springs upwards with load on board - if it jumps out of the water & then falls again to find floatation equilibriums then the height it jumped to above the settled equilibrium water height is PE gained & a demonstration of its OU potential / or not ?
EDIT: TK speculated a few pages back that perhaps capillary action had a part to play in the normal ZED & that was why Mr Wayne suggested that gaps & walls be a fine as practical but didn't work so well with larger gaps etc, IINM ?
It also might explain why the need for a optimal cycle sweet spot & limited working stroke distance to show OU, again IINM about that requirement.
Quote from: fletcher on September 04, 2012, 06:07:04 PM
...TK speculated a few pages back that perhaps capillary action had a part to play in the normal ZED & that was why Mr Wayne suggested that gaps & walls be a fine as practical but didn't work so well with larger gaps etc, IINM ?
Based on the preliminary sim results that I shared, the sweet spot being limited to a short stroke is caused by the destruction of virtual water with longer strokes (relative to the total height).
I love that term "virtual" water. To me, that is just the imaginary head added to the head via extra air pressure. The PSI of the air gets added to the weight of the water times the height of the water head. As such, a negative PSI causes the destruction of virtual water... LOL
The sweet spot is after we have created some virtual water, and before the rising stroke destroys more than we created. It is a negative feedback loop.
That is why it is important to me to have a careful real world check on the sim to verify this mechanism.
QuoteI am actually interested in more than one set of inputs from different models, since the measurements from different people will vary in accuracy, and the sim might have an error that does not show up in all configurations.
Bad form on my part.
I didn't intend to come across as saying my numbers would be the best but I can see how it might be taken that way. I'm really hoping to see anyone that's building something be able to demonstrate averages that are useful.
Back to the shop for a bit then calling it a day.
Dale
Quote from: see3d on September 04, 2012, 07:55:43 PM
I wanted to point out that I do realize that it would be stupid for me to build my sim model and operate it in a mode that had negative air PSI when it is so simple to avoid it. If for some reason I wanted to have a long stroke in this short ZED, then I would just open an air valve at the top of the ZED when I got down to zero PSI as it approached the top of the stroke. With the air valve open, the operation of the ZED reverts to a zero layer for the Pod area (Buoyancy only), for any additional input force. Since my starting and sunk PSI is zero (with no input force or load force applied), I could just remove the output load, then the input force, and the Riser would naturally sink back to the bottom. This can all be mechanically sequenced in a small model.
Quote from: see3d on September 04, 2012, 12:23:10 PM
Hi see3d,
your expectation of 100% is valid. You should not get more than that. Yesterday evening I finished calculation of input/ output energies on my model #1860 and got 100%. Energy needed to inject water (at bottom of column 3) to precharge and during lift step is my case 16. I got 16 by subtracting energy after step 3 (29) from energy after step 1 (13). Also Michel said ZED by itself is in principle perfect unity. It is how it interacts with outside makes him over 100%. That statement from Michel is contradicting what Mr Wayne said that 3riser is consistently overunity but I see it now with all respect to Mr Wayne and his team as a small of diversion.
regards,
Marcel
Hi all,
The key is in the use of another ZED! ZED by itself have perfect unity. The trick is that you inject volume V of water into it using energy A. He performs work producing energy B. And A=B. But you still have water at potential in it! Think about it! Look at water levels in after lift of step.
You just need to feed it another ZED2. This will get precharge step of ZED2 done completely and Lifting step partially for free! To fill the rest of water you still need energy C. But C is definitely less than A. In ideal I would say 50% less. Still ZED2 produces energy A and its waters can feed ZED1 closing the loop.
I hope this will open some eyes. I understood it this morning 5am and still thinking about its implications. Show me other system that you inject something (water) into it, it does work and still return water that can perform some work and by "accident" same water can be fed to another system starting its lift. Veery clever. Maybe Bessler figured it out how to do it without water.
Starting a bit to regret my recent investment in solar system.
big thanks Mr Wayne,
Marcel
Quote from: MT on September 05, 2012, 01:53:52 AM
The key is in the use of another ZED! The trick is ................................
Marcel, Congrats !
I can hear the pennies dropping around us.
It for sure needs a BIG THANKS to MR WAYNEThis is what Wayne has been saying all along, the markers are spread all over these pages
but he got shot down. because he shared his hard earned work unselfishly, but the greedy wanted more...more...give...(what a world we live in, they will kill to get something for free)
I hope the deaf of those days are unblocking their ears and will be forthcoming soon with a highly needed apology.
Like Wayne said, explore and you will find, follow the dots. The prize is too big to be given, it has to be earned.
You are well on the way. do remember you found only one of them, the Travis effect pod is a treasure trove of multiple gems that took some brilliant thinking by a fine inventor.
PS: An Einstein quote that fits, Great spirits have always encountered violent opposition from mediocre minds
Regards, Michel
Hi all,
Marcel
After more than a year of strange claims and weird contributions by the ZED proponents, this is the first statement making a bit of sense.All the talk about "pressure"!
Now we learn, the OU argument hovers around a pressure to be found in a system after water has been injected.
We learn, that the energy put in by injecting water is equal to the energy put out by rising a weight. (Well, what else did you expect?)
We learn, the mysterious "overpressure" then has to be fed to an other ZED. This explains the need to switch electric valves in an orchestrated manner.
Now, it has to be carefully studied what this "over pressure" really means and whether it can really do work.
May be TinselKoala can find this "overpressure" in his rig? (TKs rig is the only one that seems to be clearly specified and he seems to know what he is talking about, in stark contrast to the ZED proponents, whom it took more than a year to state a bit more clearly what they claim.)
And the ZED proponents could finally show how and where the water is pumped in and how and where they measure this "overpressure" after the weight (the risers) reach the final position.The ZED proponents could finally define what "one stroke" of a ZED really means:- Where are the risers before the water is pumped in?
- Exactly where is the water pumped in?
- Where are the risers after the water is pumped in?
- How is the movement of the risers constricted?
- Where exactly is the "over pressure" measured after the water is pumped in?
- Where is the "over pressure" led out to an other ZED?
Please answer these questions by help of a one, two or three riser system, whichever shows this "over pressure". A drawing would be extremely helpful. It would be helpful to show this with the least complicated system of risers. It would be helpful to explain how exactly the movement of the risers is constricted.
Why did we have to wait more than a year to learn the most basic things about a ZED? This is why I do not like this thread! This is strange! This is weird! This is not the right way to present an OU claim! I call this double talk! And I almost have no hope that we ever get clear and comprehensible answers!
Greetings, Conrad
P.S.: Yes, I am annoyed. One year of discussion for nothing. ZED proponents speak up or shut up. We can not talk about a system that is not clearly disclosed. If you do not want to disclose it, then say so.
Quote from: MT on September 05, 2012, 01:32:51 AM
................................................ Also Michel said ZED by itself is in principle perfect unity. It is how it interacts with outside makes him over 100%. That statement from Michel is contradicting what Mr Wayne said that 3riser is consistently overunity but I see it now with all respect to Mr Wayne and his team as a small of diversion.
regards, Marcel
Hi Marcel,
I think the contradiction comes from having different viewing angles or it was said in a different context.
There is the view of the Zed just as a "Layered buoyancy device" or as a "Complete System", this makes a difference.
To make it perhaps more confusing, most of the physical references made in previous pages were about the demo model version (which is already an old version zed). A lot has been learned by Wayne's team in the meantime and from what I gather and certain things that I deduced myself, several improvements can be made which changes the capabilities of the device that make it different from the old one.
The theoretical advantage of the layered buoyancy device increases as the number of layers increase, there is no doubt about that. The statement of "perfect unity" was maybe only 98% correct, the purpose was to clarify the detail that made it "over perfect unity".
Understanding comes from analyzing, to understand the pod, you need to look at all details within, all parameters that conspire or contradict each other, surface ratio's, pressure ratio's ...ect. and observe their relationships as you change one parameter, watch the response changes in the others, the key is to find mutual beneficial relationships and optimize those to bring the cost down. Do not focus on trying to create new energy, try to demand the greatest discount for your energy purchase. You cannot stay focused on one point only, as you analyze more from within, the familiarity will unfold the whole picture to you in due time.
The sim should assist a great deal in that and maybe reveal some new dynamic ratio changes
Also be very clear on the understanding of buoyancy, a clear view of standard & paradox Archimedes relationships is very helpfull
Good luck, Michel
Quote from: conradelektro on September 05, 2012, 03:24:15 AM
Conradelektro,
This saying should say it all
Give a hungry man a fish and he will eat for a day, teach him how to fish and he will never go hungry again
Hi .. I can't really imagine what you are conveying here - is this property of negative PSI you observe in your sim peculiar to compressible air or would it still happen with non compressible fluids ?
It appears to me that the 3 gaps form a system like a barometer which is a weight of fluid in a tube with a vacuum at the top - I talked about it being a type of syphon before but it has properties of both perhaps.
I would look closely at your transfer volumes & ratios between each concentric gap - obviously as fluid or air transfers from a gap of least radius to the the next of larger radius the same volume transferred will fill less of the next gap volume which is larger [assuming gap sizes are constant] - this variable transfer rate & gap volume is probably already factored in your sim but could be what is causing your pressure findings ?
One method to test this in the sim is to recalculate the gap sizes/volumes so that the same volume is transferred consistently [& transfer rate] from gap to gap as radius increases etc.
Just some thoughts.
Yes Conrad .. some of this does seem very strange for an open source site - especially not giving a schematic to work to for the builders - it almost invites failure IMO.
Quote from: fletcher on September 05, 2012, 04:59:24 AM
Gents,
You surprise me in several ways, I thought this was a forum where members can share information on a common interest topic on their own terms in the OU domain. They can reveal information to the limits set by themselves and are not obligated to any request or inquiry to reveal data that is still considered restricted from their viewpoint.
I looked around on this site to find a definition or guideline on "what can and what can not be posted", "how a topic should be handled", I couldn't find anything.
Questions** Where does the definition "open source site" come from ?
** What says it is an obligation to give a schematic to work to for the builders
** Where does it say that anything must be build to start of with, what about a theoretical concept development discussion ?
** Where does it say all must be revealed, meaning any partial disclosure, no matter how juicy is not allowed?
Let's get some perspective here.The invention revealed here (let it be a limited disclosure) is owned by a company with it's main business asset being certain intellectual property surrounding the Zed system. Lets assume it was General Electric to introduce a new novel concept, do you think they would provide you the blueprints and test data ? ( let throw it the summary analysis with it). I do not think so.
What is the alternative?The alternative would be, no information whatsoever about the Zed apart from a distant article in a newspaper. Be happy to receive what you got and "do not look a gifted horse in the mouth".
This is the way the inventor wanted to reveal is invention and his OU concept. It obviously didn't match your high home-delivery expectations, but I am sure there are many more out there who were very happy with the info and the level it was delivered at. If the concept didn't make sense to you in this forum, than obviously was not meant for you at this point in time.
Regards, Michel
Naah Michel .. the currency I deal in is facts - I don't like them sugar coated & wrapped up - patent applications protect your rights.
We will have to agree to disagree about your 'delivery strategy' & the motivations will remain unknown till the end.
Right now this saga is following a pattern - a few good men are trying to get to the bottom of this.
Quote from: mrwayne on August 20, 2012, 05:47:07 PM
Hello Webby,
My team is currently planning the build for our desk top self running water pump.
I would love to see your teams creativity with the ZED technology!
How about a new challenge for you and your team..a $5K ZED challenge.
Specifically designed by your team to ease measurements of input and output.
Two single five or six layer systems will do, or a combined system.
It does not need to be transparent.
Weight of the riser is not an issue works as a counterbalance - steel, aluminum may be used.
The risers may all be attached to one lid.
The system needs to be able to be measured and have access to each layer (tubing both air and water).
Part two: $10K ZED challenge ----5 layer, dual Z.E.D. water pump.
If your design team connects the system together for a self runner - I will double the 5K Challenge to 10K.
and each member of your team will receive a HER ownership certificate - valued at the current valuation and equal to the prize.
Five members max - pick them wisely.
Suggestions:
You do not have to beat our team - but time is important.
plan on 1/4 or 1/2 inch gaps between risers and ring walls - will work fine.
If you start with a pumping system and then size accordingly - a lot of time is saved.
The previous expectations apply - after a reasonable time of testing and reporting - you must send me the units, you are welcome to make an authorized extra set to keep for yourself.
Placard with your team members name and the name of the device Zydro Energy Device on all systems made.
What do you think? Up to it?
Wayne Travis
If you read the last paragraph, Wayne is recommending gaps of one quarter to one half of an inch, and that in a table top model. To me, that says that capilliary action plays no part in the working of a ZED.
@Conradelektro. In your last post , you asked a number of questions. Most of these questions have been previously answered, but I will try to answer them again.
1. Where are the risers before water is pumped in? See post number373 on page 25, which shows the Zed at various points through the cycle.
2Where is water pumped in? Through the bottom of the pod chamber at the centre of the base.
3. How is the movement of the risers restricted? In wayne`s current model, it is restricted by mechanical stops, as the production rams [hydraulic rams used as pumps,] reach the end of their travel.
4.Where are the risers after the water is pumped in? They are at the uppermost point of their travel, restrained mechanically.
5 .Where is the overpressure measured? It could be measure at the water inlet at the bottom of the pod chamber.
6. Where is the overpressure led out to another Zed? From the same point that it was pumped in previously, see [2]
I have done my best to answer your questions.
Just some thoughts.
fletcher,
This negative PSI state is because of the expanding air volume created by the upward movement of the Riser. It is independent of the type of fluid. I am still in context from the weekend and only refer to the sim model I have shown, not what others have shown. I know it is hard to keep track with individual threads being interspersed on this site.
I only have one air gap in my single layer model as shown.
All sim calculations take into consideration the differing areas and volumes of the rings and one key consistency check is the the total volume of the water did not change after any calculation of fluid transfer between H1 and H2.
It sure doesn't sound like capillary action is a likely candidate Neptune.
But this is a process of elimination until nothing further can be eliminated or discounted from the equation - remember, no one wants to tell us what their theories are about where the proposed excess energy comes from [ah humm .. excuse me, discounted cost of input energy gleaned from non conservative gravity].
Once you've eliminated the impossible you are left with the improbable.
That is assuming that there is any discounted energy input cost to be found - I don't take that as a given or statement of fact at all.
Eventually the build teams will report in & see3d will get his ZED sims working to his satisfaction & checked against real data - then we'll have a real chance to tell fact from fiction.
More power to their elbows so we can move onwards & upwards - maybe who knows, guys like MT might ditch their solar for a HydroEnergyRevolution house hold unit in a years time.
Quote from: fletcher on September 05, 2012, 07:20:49 AM
(snipped)
(snipped)
If one reads much on the topic by Don Lancaster, one might think that patents only provide you a right to sue somebody. And pay out a lot of money doing it, and still not win. He's not a big fan (http://www.tinaja.com/patnt01.shtml) of patents.
They offer no real protection he believes, other than guaranteeing you the right to spend up to $250,000 or more per violation to defend them, depending on situation and the pockets of the other party, who may seek to spend you out of the patent, or simply void the patent (he says this is quite simple for most), and other horrors. For example they can just outright copy it, and others can too, and by the time you are done defending it, and suing each and every other party copying it, they can alter it and patent their "improvements" of your technology as well.
Thank you all who have put forth the effort to understand the system -
Leadership is often..... better realized than explained.
Please remain respectful - as the pennies drop - great work and sharing.
From the postings and discussions - I see three of the stages of discovery have been answered.
It would be safe to share this tid bit - the next four are solvable - Let this be an encouragement to you - You have afforded effort to a challenge that has a successful end.
You who have afforded the effort - prove yourselves to be of the Pareto effect - the 20% - and yes that shows that you merit extra consideration now and in the future.
Learning is a process - this invention is a new frontier, the innovation will bring countless blessings.
Wayne Travis
President
HydroEnergy Revolution.com
Quote from: mrwayne on September 05, 2012, 08:38:07 AM
(snipped)
Wayne Travis
President
Wayne, I sure hope this is all you say and more, because the world could use some really good news like this.
But let's say naysayer worst case comes to pass (not saying it's the case, just saying if it does after all the testing) and you've instead created some "only" 98 percent efficient something that almost works by itself and quits 4 hours later, or longer, over time.
Seems to me, paying 2 percent input energy cost all day long is a far better thing than
anything we have now for power making. Why would that not be 'revolutionary' as well?
rc
@Fletcher.I do not blame you or anyone else to take the attitude of leaving no stone unturned-that is what I understand by"due dilligence". However if someone proposes a theory, and I have seen evidence to the contrary, I feel the need to point it out.
You know, there is something else bugging me. The current consensus of opinion seems to be, one zed alone is or can be 100% efficient, but we need two zeds working together to achieve OU. We gain OU by using the "exhaust" of one zed to partly charge a second Zed. I see the logic of that.
However, from that we can see that when the zed has completed its upstroke, and done work, the contents of the zed are still under pressure. So in a one Zed machine, instead of just releasing that pressure and wasting its energy,we could store at least some of that energy, and use it to partly recharge the same Zed.It could be stored in a "poor man`s hydraulic accumulator", that is a balloon, or even a vertical water column.
So suppose that at the start of the downstroke , the exhaust pressure of the zed is 10psi. WE connect it to the said accumulator. The accumulator fills until the pressure equalises at say 6 psi. We then release and waste some more pressure from the zed until its pressure falls to precharge pressure at say 2 psi.
Then , at the start of the upstroke we connect the accumulator to the Zed to partly recharge it. Thus saving part of the energy needed to recharge it.
Owing to the complexity of valves etc, it would probably be easier to use two zeds. But nevertheless, this would be a way to gain OU with a single Zed. Does this make sense to anyone, or am losing the plot?
Quote from: Artist_Guy on September 05, 2012, 08:47:34 AM
Seems to me, paying 2 percent input energy cost all day long is a far better thing than anything we have now for power making. Why would that not be 'revolutionary' as well?
rc
It is a funny thing - the Grant Committie - told me that if I would repackage and present our system as 79% they would be all over it - so I see your point, yet I am a man of honor.
Say it as it is (respectfully) and let the chips fall.
Yes, this is world changing - mechanical free energy - Nature provided a way for us to protect it - from us while benefiting us - a win win in my book.
Thank You
Wayne
Quote from: seamus103 on September 05, 2012, 09:26:09 AM
Please think hard about this. If one ZED has "excess exhaust energy" that can be fed to either another ZED (or an accumulator as you describe), then that SINGLE Zed must be OU in and of itself if the cycle is to be self running. It is a complete falsification to say that this exhaust can be fed from one ZED that is not OU of itself to another ZED that is not OU of itself and end up with an OU result.
Seamus,
Please think again hard about this. You approach the whole process in a too general sense, with too generalized conclusions, you missing the details. There is a catch 22.
Similar to the layered ratio of some posting ago, it is all in the nondescript details, I am sure you are still studying that one,
Talk your time, I will be only a post away
Regards, Michel
MR Wayne hinges part of his working principle on this falsehood.
I firmly believe ALL of this 'exhaust' needs to be fed back to the ZED just to reset the state of it back to the begining of the cycle. This results in NO increase in NET energy.
The same is true of the layering effect. This acts to reduce efficiency, not increase it as there are more losses involved with more moving parts. Note that layering WILL increase the leverage , but not the energy in the system.
OK........
Well, I think you need to think that out a bit more.
Wayne
Hi Fletcher,
When it comes to the Zed OU concept,No problem that 'you disagree' , you need to do your diligent verification process as any wise man will do.
I will not qualify for you what should be sufficient or not. We all went through the same process, so take all the time you need.
When it comes to what is sharedI still believe that it is the prerogative of the topic owner to release what he wants to release. In the same way the reader can accept or reject, investigate and learn from what has been presented. What happened on the forum site was something way beyond common respect and should not be tolerated (because certain people could NOT get exactly what they wanted)
Time will tell us the good news, Michel
See3d, Tks for the link.
In your ZED there are no surface 1 surface 2, ... which exist in Wayne Zed, I initialy thought that the vertical force on these surfaces were helping to lift the riser.
These surfaces are quite large (a disk of larger diameter than the pod itself in Wayne drawing, a small annulus in yours). Is your drawing according Wayne latest drawings?
I discover riser legs in your drawing, interesting.
Quote from: neptune on September 05, 2012, 08:52:26 AM
In the above quote I described a "thought experiment" of a way to improve the efficiency of a single Zed. I now realise that whilst the theory is valid, there is way to achieve the same thing in a far more simple way.
Consider a single Zed, used to lift a load . The input water is supplied by a simple plunger type pump, and the plunger is depressed by putting a weight on it . Suppose force x distance on the input = force times distance on the output. 100% efficiency[disregard losses.] Now when we come to raise the weight on the plunger to cause the risers to fall, we find that the work necessary to do this is less than expected. Why? because as the pressurised water goes from Zed to input pump, it is helping to lift the weight. [Wayne previously told us this in a cryptic sort of way, by saying something like "look at the cost of lifting this weight" .] So in effect, the input pump takes on a secondary function by acting as a hydraulic accumulator. When we lift the plunger weight, we are inputting energy for the next upstroke of the risers, pod and load.
But we are doing this at REDUCED COST. Is this making sense to anyone, or am I talking garbage?
Quote from: parisd on September 05, 2012, 10:55:55 AM
parsid, My drawing is not the same as Wayne's in the details. Mine is simplified to make it easier for the math to simulate, and designed for a small table top demonstration. I try to be self consistent in my terminology, but it may not perfectly match what others call things. For instance, some have separate risers for each layer. I only have one Riser-Pod combination part for any number of layers in the sim. I call the whole moving part a Riser, and refer to the Pod as the inside most closed bottom cylinder feature of the Riser.
It can be confusing when 5 conversations are going on at once in a single thread. I hope this helps clear thing up for you.
Dont be too happy with efficiency close but below 100%, 98% efficiency does not mean we need 2% input to run it, it means 2% of the input is lost. 100% is a usual thing, a simple electric heater is 100% efficient all the electrical energy is transformed in heat. If you lift a mass with a fluid, no viscosity to fight, no friction, no heat generated, you should expect exactly 100% efficiency (i.e all the energy you put in lifting the mass becomes available as potential energy for this mass), but where do we go with that ?
We have to look and explain the more than 100% claimed for the ZED and I have not seen it explained by equations up to now, I have seen numbers (1 layer 104%, 3 layers 160%, 6 layers 300%) no physical explanation only spreadsheet with small portion of equations and lots of numerical values difficult to verify and guess what like probably most of you I have not taken the time to verify any of them.
We should avoid numerical values and demonstrate OU by maths and physics equations. I have not tried to understand the 104% of a simple layer ZED but I am trying to understand how external layers give an additional 196% (if 6 layers), these are just columns of water and air compressed on top of them, they cannot bring any extra efficiency certainly not 196%, unless someone explain us how (not with numerical values, please).
I am more septical today than few days ago (was open especially after reading about the Archimede anomaly that says "you can lift a mass with less water that the volume of the mass").
The ZED by itself does not seems to be a sophisticated machine, if there is OU so easily capturable, it would have been done since centuries.
rc
Quote from: parisd on September 05, 2012, 02:38:38 PM
Airplanes and Penicillin DO seem so simple now,, don't they... :)
Different Subject: One thought recently made me chuckle a bit; the whole "conservation of gravity bit" - I'm not a scientist or engineer but if Newton's laws of gravity were in any way shape or form based on having an apple fall out of a tree.... What energy source raised the apple to that dangerous elevation?
Quote from: wildew on September 05, 2012, 03:13:57 PM
Hi Dale,
I would venture to say that the apple transformed light (sun) energy to gravitational energy
Michel
Wayne had previously mentioned that the Risers could be bolted together and wildew recently stated he would have a single top plate. Say what?
So attached is a single top plate zed example. The size of the air/water channels are exaggerated for visual clarity. Can't call it a 3 Riser anymore, must be a 3U. Sounds familiar ;D
Regards, Larry
Quote from: Red_Sunset on September 05, 2012, 03:21:26 PM
Hi Dale,
Michel
2 points Michel :)
Now that thunder cloud carrying a million gallons of desalinated seawater, WOW is that some potential !
They both have energy cycles and we have found ways to extract energy from them without causing the world to disintegrate. I don't see this one as being all that different. With energy from the sun powering those it's easy to comprehend "where the energy comes from".
One day I'll better understand the full energy cycle of this machine too.
Dale
I'm a few pages behind but wanted to report that my three layer (Pod and two risers) is functional and I've been able to play with it a bit today. Also got some time with it yesterday, but that was mostly for leak and functionality testing.
First thing I can say is I wish it was instrumented! Even with a fairly clear and relatively simple three layer setup it is difficult to see where the water and air levels are. I think I might need to tint the water slightly...
My ZED is up on a little stand. Below the stand is a Tee fitting that was glued to a central hole in the bottom of the Pod chamber. One remaining branch of the Tee goes by a short section of clear tubing to a valve. I use this valve to bleed off the ZED water pressure, or to insert air into the bottom of the Pod chamber.
The other remaining branch of the Tee goes to the cap of a 20 oz soda bottle. The bottom of that bottle is cut off and a hanger loop is attached so I can hang it on one of the racks beside my work bench above the ZED. So it is simply a funnel to allow water into the bottom of the Pod chamber. Just like a beer bong...
I've been having fits trying to find a sequence of adding pre and load weights, add water and air, locking the system, etc., that may lead to a repeatable process for charging. But I have no mass scale at the moment and I think my pre&load weights equal a sum way too close to the ideal at the moment. So it is very easy to blow skirts (not fun) or flood the top of my outer riser. On that last point, I have no outer riser head extender (yet) and now see much more reason for that particular feature.
I've only got a couple days left before a week long vacation/adventure, so I doubt I'll be able to report anything more substantial any time soon. But I wanted to pass this along to those who it might benefit and will do my best to answer any questions by forum or PM.
This is by far the weirdest acting contraption that I have ever built. So thank you, Wayne, for that alone!
M.
Quote from: Red_Sunset on September 05, 2012, 03:51:39 AM
Good luck, Michel
Hi Michel,
I'm still amazed that way how to achieve OU is clearly presented on this forum. After all these years. Personally I always wanted to understand an OU device and tell others how simple it is with no strings attached. Then for me this is sort of mission accomplished. I need to set new goals on what I would like to do with it now. You know it is like you would like to have something for long you do not believe it is possible (just hope it is) and suddenly you just get it. And honestly it got me by surprise. I though I'll never be here BUT here we are.
I was excited so I tried to explain the concept (with a simple Archimedes pod) to couple of colleagues. They could understand that reusing of potential but then got into doubts about how a pod can perform work and still water beneath it keeps potential. One was over concerned about losses. Maybe I just overwhelm them with details. All of them then continued in business as usual, I wonder whether somebody will come back to discuss it again.
About what to disclose:
I can understand a skeptic that tried to understand and analysed tens of ideas before ZED and is so disappointed/fed up with them not working that expects full disclosure of yet new idea somebody claiming is OU before he gets from his chair. Hopefully now even such sceptic understands it is worth it.
thank you all,
Marcel
Hi Marcel .. what is stopping you from posting a few photo's with explanations & arrows showing things etc ?
A few posts back you made the comment that a single layer ZED showed unity [100% I think you said] i.e. work input equaled work output, & you expected that.
Then immediately you said the unit still had potential [energy] that could be used to pre-charge another unit so an estimated reduction in input cost of estimated 50% & back & forth & so on.
This unity comment would now seem a contradiction - if the unit has additional potential after one complete cycle it can't be 100% because you haven't accounted for the raised potential in pressures or whatever.
Webby1 & Mondrasek are happy to post photo's with explanations of their finding as they progress forward - when you get over you euphoria perhaps you could find the time to post a pic or two ?
A complete logical cycle sequence would be good including pre-charge etc if there is any - thanks in advance.
Quote from: mondrasek on September 05, 2012, 06:01:09 PM
M.
Thanks for the update and the "warning" M.
No provision for extensions on mine at the moment either...
On the "tinting": Since I should have access to each water chamber I've considered adding some form of colorant (different colors) to each after getting the water volumes set. Not sure what might work without staining yet, need to look in to that.
You have fair sized gaps? Any chance of putting "floaters" into the riser / wall spaces during assembly?
Have fun!
Dale
To Replicators -
Wall extension will not hurt - and for later expansion of the system they help.
But you will find - after you work through the set up, practice, and stroke (up and down) - you will lower the water volume in the outer layer.
p.s. if you try to stroke to far - overflow will continue to be an issue.
Wayne
Well the tint worked pretty well.
Looking good, mond!
A couple LEDs inside the inner pod, a few clear plastic rulers from the dollar store or WalMart, a spring fish scale and a simple lever system to make it read "push" instead of "hang" when you want it to.... and with your input piston.... or simply an elevated "IV bottle" type means of obtaining a known head pressure for injection...... and you are ready to make some meaningful measurements.
Seamus,
QuoteI realise such abstactions might be difficult for people who only think in terms of concrete physical devices with real dimensions. The good news for them is you don't need to
I would guess that is where we differ, if I can not visualize it, I have problems to deal with it. The number analysis in a previous posting was based on a process flow that originated from a visualization based on known physics principles that represented the actual build and working model in Wayne's lab.
I think the following statement is why we divergeQuoteThe 'general' approach works without needing to analyze any specific configuration of a device at all.
If we always look with the same eyes and use the same approach, we will always see the same thing or the same experience. This is not a fertile environment for innovation.
Could you agree that a different or new angle could make us see something we did not see before, often just a simplification of a more complex problem will do that. Once this "new" is seen (visualized, recognized, discovered) we can still process it in the known traditional way.
*1 - If you do not agree, we have no need to discuss anything further.
*2 - If you agree, you would see why I would have an issue with your statement
I believe the reason that you are on this forum and still following this topic, is that deep down there is a faint believe of possibility of the impossible. We can complement each other, I got the looks, you got the brains.
I would guess that you are a mathematically inclined and would have modeled the zed system in numbers. Can you share your math findings in a post ?
A look at the Zed process flow, It all has been said and described before by Wayne, but let me expand zed process flow from one of Wayne's posting's, from a few months ago. Maybe this is easier to read with understanding
1.. The layered buoyancy device has the ability to stroke (go up) with great force and short stroke.
2.. We stroke @ 8psi, "we start and finish @ 8 psi".
3.. The lifter was held at the preparation stage before stroke and also at the top of the stroke.
4.. The lifter is loaded with RiserWeight and Payload
5.. We stroke @ 8psi
6.. At the top of stroke we remove the payload
7.. The lifter remains under the duress of 8psi. that is still the same force to lift the riserweight + Payload if the travel would allow it. it can not travel further up because it is held by a stopper
8.. So the lifter can only go down, to let it go down we pull the water plug at the bottom of the Z#1 water column, this is connected to the other zed (#2) pod area (z#2 water column bottom) and like any U bend, the water levels will equalize over both zeds.
9.. After equalization, the stroked lifter remains up, it did not descend, we need to help it
10.. So we pump water over to #2, it needs water in any case because we intend to make it stroke later (the zed in see-saw)
11.. While we pump, the zed#2 lifter remains stopped (locked)
11.. At a particular point, zed#1 will come down to its initial start point (the lifter was only prevented from rising further, not from descending)
12.. With Z#1 at its starting point we keep on pumping to make z#2 stroke
13.. This half process cycle ends with Z#2 stroke completed and Z#1 at its starting point
As your positive contribution to this topic, Please model mathematically what happens in this process (z1 stroke to z2 stroke) for both zed and please share it in a post
You can choose any model, doesn't matter if not optimized, the principle wouldn't change,
Prerequisite:When it comes to energy, invested energy to start with is one Zed at "equalization" and one at "full stroke"
Regards, Michel
Quote from: fletcher on September 05, 2012, 06:50:08 PM
I'm quite busy last days, I'll see what can be done later.
For the start please read my post
#1860 with 2D model there are three steps.
Then calculate whats is potential energy of water after each step in risers. Initial, precharge and stroke.
This is your input. Hope you will see work done equals energy needed to do precharge and lift step.
But still after work is done water has still potential to do some work, risers are full!
Marcel
Do not forget that not only are the risers still full, but the total head pressure is the SUM of the number of risers, giving more potential energy than you might think.
Hi,
I showed this to my colleagues.
Marcel
@MT. OK, let us be clear what your diagram is saying.
In Zed one on the left , water is pumped in under pressure . Energy consumed is A
Zed One rises, lifting a load. output energy is B
A=B, so Zed, in this ideal case is 100% efficient.At the top of the stroke there is still potential energy left in the system, which is exported to Zed Two.Call this D . This partially charges Zed two.
To complete the input of Zed Two, we need more energy,C. This energy is part of the output of Zed one, which is fed back.
So the input to a Zed is in two parts, the exhaust from its partner [D] plus extra energy from the output [lift] of its partner.
Is that a reasonable summary of what the diagram shows?
Quote from: neptune on September 06, 2012, 08:30:52 AM
Exactly. And
C < A, always. Usable energy remainder is in fact whats left of
B after feeding
C. Maybe somebody have a better diagram, this is how I see it.
thank you,
Marcel
Quote from: Red_Sunset on September 06, 2012, 02:38:24 AM
Hi Michel
Great post with I clarification. (unless I misunderstood your post)
Wayne stated a couple days ago that the risers are not locked after the initial setup. During normal cycling their motion is only constrained by the stops at both ends of travel and the load itself.
After thinking about that response a bit it made a lot of sense too; holding the risers down while water is flowing in would take more energy than necessary because the head pressure would keep climbing.
We need to cause the masses to shift with the least amount of effort possible.
Dale
Quote from: wildew on September 06, 2012, 09:38:24 AM
Hi Michel
Dale
A perspective point -
They are locked mechanically during set up, and by load during stroke, and by weight of the system during sink.
(Sink does not occur until enough head is transferred to the other ZED so they are locked naturally during stoke).
Wayne
Quote from: MT on September 06, 2012, 08:10:52 AM
Hi,
Marcel
Hope this helps.
@ All ..
There is a lot of talk of extraneous PE after a ZED cycle.
Seamus makes the point well that to be OU, Potential has to be raised, & he gives the easy to visualize example of water spontaneously flowing uphill as he eloquently puts it.
I will simplify it even further for clarity, also drawing on a simple visualization thought experiment to see a pattern or energy flow.
If two different density materials/objects are mixed together & one of those is a higher density fluid, then the lighter density material will rise to the surface - this is buoyancy - the buoyancy is a result of a pressure differential below the object & above it - IOW's the pressure below is greater than above when looked at in force terms [ F = P x A ].
The fluid has pressure because it has mass & due to gravity's acceleration on that mass - that pressure increase with depth is linear - if we artificially increase the pressure conditions by doing work on a fluid [ Pascal's principles ] the pressure changes with depth are still linear & the buoyancy force still the same.
That's a simple explanation of why things float.
Here's an even simpler visualization of buoyancy.
When two materials/objects of different densities are mixed together gravity acts on them both equally wanting to pull them down - the more dense fluid will find its way downwards while the lighter density object finds it way upwards - the more dense material always flows to a position beneath the less dense material & this is what forces it upwards.
After they have separated the Center of Mass [ CoM ] of the original homogenized mix has been lowered - i.e. the system has lost PE i.e. the separation is a natural event that allows the system to find its position of least PE.
The system had a higher PE at the start of the thought experiment because work had been done on it to cause the mixing & raise the CoM because of that mixing - the beginning of the cycle was when energy was put into it in the mixing of materials & raising of the system PE [ this is a factor of mass distribution ].
At no time do materials separate in a gravity field so that more dense materials sink underneath less dense materials and RAISE the PE of the system.
Happy hunting !
Quote from: TinselKoala on September 05, 2012, 08:15:16 PM
A couple LEDs inside the inner pod (snip)...
That statement alone has had me smiling every time I've had a chance to think about it since I read it yesterday! It is completely fitting for an OU device to have an LED in it somewhere, right? Good stuff. And thanks!
What would you propose that could fit inside the Pod that could be turned on externally, sealed, etc? I was thinking a surface mount LED with a tiny JT and battery on a board that could fit through the 1/4" hole in the bottom of my Pod (before sealing). But how to turn it on and off?
You KNOW we can't use wireless power transmission for reasons you have shown in other threads!
This idea is completely off topic, but hilarious (to me at least)! So I'd like to see a mock up or concept description of what a Koala would do.
M.
Quote from: mondrasek on September 06, 2012, 05:34:10 PM
Why does your pod have to be sealed on top? Could you have an open hole on top?
Could you use a read switch to turn it on with a small magnet that you set on top of the pod if sealed, or just a small switch on top?
Shine a light down from the top and just have a small piece of mirror at a 45 deg angle inside the pod.
I think it would be more fun to have a reflective 45 deg cone inside the pod that shines light all around from top illumination. So many possibilities! ;-)
Attached is the Simple Zed to Zed Flow.
No Flow - Valve closed
Free Equalization Flow - Valve open
Hydraulic Assist - Since the Zed water columns start equal, the input cost will be to change the actual Water Head between Zed's from 0 to 3.4 PSI. Edit: OU out the wazoo, for those who understand.
I used 8.4 as specified in Reply 963 by Wayne:
'Our pressure is:
Minimum 5.0, 8.4 max, and 6.7 post free flow.
Since the true input cost to each side it the diffirence between these pressures and the Max - this is very important.'
Regards, Larry
PS: The actual system doesn't transfer the water, since each retains it's own water supply. It just transfer the force to move each Zed's water supply.
Quote from: mrwayne on September 05, 2012, 07:11:19 PM
I will say that I can confirm the overflow issue. I am not 100% sure of the cause, but it could be, as you say, due to stroking too far.
It is definitely another weird phenomenon that I would not have predicted from my "understanding" of how the system should act.
I understand better now why Webby has been playing with his embodiment of a ZED for so long and still reporting new observations.
To all: I will not say a ZED is OU or not. But it is definitely a very unique construction that exhibits behavior that I could not have predicted. Take that as you will.
M.
Quote from: see3d on September 06, 2012, 05:51:07 PM
Heh! My limitations are only due to scale of the system and technique as far as I know! So you are right, D, that there are other ways that I have not even considered. And that is EXACTLY why I would toss such a wonderful idea out for group input.
Seriously, things have again become, well, a bit serious, on this thread. So I'd like us all to lighten up a bit and have some fun. Please ignore if you feel you must.
M.
Quote from: mondrasek on September 06, 2012, 07:19:16 PM
Excellent idea M. !
I'm getting close to having an assembled "something" to play with and M's and Webby's experiences using water head / flow appear to be similarly challenging. See3d's piston that can be better controlled is more in line with Wayne's bag system but I'm at a bit of a loss trying to come up with a garage / shop solution. It does need to be measurable and that's making me think harder. Ideas?
Dale
Hi,
Marcel
So the Zeds aren't "transitive" then? Are the two Zeds different, so you couldn't take the one on the right and put it where the one on the left is?
Because if A=B in the first Zed, and D is cycled around between the Zeds..... then why doesn't C =B as well...... that is, C must equal A. So if C+D = A.... then therefore.... D = 0.
If the two Zeds are the same, and a cycle is being performed, it seems to me that this must be true.
M.
I'd use some low-power cmos chip logic and a photodiode to make a switch that could be actuated by a laser pointer from outside. In the LED-off state, the power consumption could be made quite low, microwatts probably. I'd install a gastight port big enough to get the thing into wherever it belongs in the first place, rather than stuffing it through a quarter inch hole. But if that were really a design criterion, it could still be done with a long skinny PCB and SMDs and button cells. Koalas prefer DIPs, though.
But another idea that may even be better is to illuminate from below, through a clear base. Then you don't need to put anything in your pod, just position your bright LEDs below the structure to illuminate your desired areas, like your line gauges and your menisci.
And for those who are using tubes with a substantial wall thickness, you could try edge-illumination. If you shine the LED into the edge of the plastic, sometimes internal reflections will result in the whole piece glowing gently in the color of the LED.
ETA: Personally, I would have no objection to the use of my wireless power transfer system to illuminate a clear plastic Zed system from within. Unless of course you can make water climb walls with an 800kHz alternating magnetic field.
Quote from: wildew on September 06, 2012, 07:38:55 PM
Dale
I show a piston because it is easier to understand the exact mathematical relationships for a simulation. However, it is really supposed to be modeling the bags, which can be compressed without the friction loss of a piston seal.
OTOH, just raising a big fat water bucket to different heights with a siphon tube going into the bottom is too easy to ignore. It may or may not be the final configuration you want, depending on your goals, but for first time measurements to prove out the best operating point, it just does not get any easier than that.
Quote from: see3d on September 06, 2012, 08:31:55 PM
The ideal is to inject fluid at the level just beneath the pod chamber IINM - in the sim the piston is pushing with a large head on it because it looks like there is plenty of volume to spare, IINM - the important bit is that enough volume must be transferred to raise the water level up the sides & any more work than that is not required.
The lower in a tank you try to inject fluid the harder it is because of the pressure at your entry point [pgh] - think of it this way - if I have a tank of water & I puncture it at the top, middle & bottom of the sides the water will stream out horizontally a distance proportional to pgh which is depth, not mass or volume.
So ideally an injection point just below the pod riser has least resistance [force] to the force [work done] you provide to do that.
This is why some members have been asking WHERE are the entry & exit points.
P.S. the bag is a piston of another variety.
Quote from: fletcher on September 06, 2012, 09:19:37 PM
...in the sim the piston is pushing with a large head on it because it looks like there is plenty of volume to spare, IINM - the important bit is that enough volume must be transferred to raise the water level up the sides & any more work than that is not required...
In the sim, the volume of water is a calculated geometry to be just enough to fill the Pod chamber to the top with the stroke at the top. No water was harmed or wasted in the construction of this sim... LOL
Because all the water is counterbalanced in the sim, the total amount of water becomes irrelevant as far as input pressure goes. 100% of the input pressure gets transferred into the Pod head.
A "U" shaped tube going into the bottom of the pod water chamber will always balance out with the water in the pod head. Which also makes it easy to measure the pod water level from outside the ZED. Just pour water into the outside "U" tube until it reaches the desired water level inside. A drain at the bottom of the tube would let you lower the water level inside.
However, I thought it would be easier to just raise and lower a bucket (or glass) of water to the level you wanted to have the water head inside. You don't even have to put a hole in the bottom. :-)
QuoteHowever, I thought it would be easier to just raise and lower a bucket (or glass) of water to the level you wanted to have the water head inside. You don't even have to put a hole in the bottom. :-)
Maybe that's the secret of the Zed..... With no inlet and no outlet, everything is conserved, and you just tap off some of the energy of motion to turn your alternator. ;)
Actually, the elevated bucket, or rather cylindrical container, elevated to the necessary height (or...even easier, pressurised with compressed air to a known pressure) makes the perfect piston and push-force application system, I should think. You have no problems with piston-cylinder friction or sealing. All you need to do is know the area of the cylinder's cross-section and the pressure and the "stroke" or difference in the water heights in the cylinder, and you've got your perfect pressure injector, easily quantifiable in terms of work input to the Zed, and easily valved off to keep whatever it applies from backflowing.
This is the same thing that the bag does, I suppose, only the bag doesn't need to be elevated. The bag would seem to be harder to quantify in terms of work input, though.
Quote from: see3d on September 06, 2012, 09:47:05 PM
Yes, that sounds easy & quantifiable for a real world test.
Then just calculate the work done to lift the water to the desired height from the outlet height & voila you have the joules of energy to raise the PE of the water.
Quote from: TinselKoala on September 06, 2012, 11:03:02 PM
Measuring the small air pressure differentials in a table top system might not be that easy.
In my previous example of raising a glass of water, I made an error. The water level in the glass includes the virtual water in the pod head (i.e. the air PSI).
The total input work is a direct measurement of the glass area x distance raised x water weight per unit volume. Raise the glass until the pod just starts to rise - epsilon. Then put a load weight on the pod. Raise the glass higher until the pod just rises again and measure the distance required. That is the spring loss of the system. Then raise the glass further to make the pod stroke to the top. That is the direct output work -- weight x stroke. The input to do that is as I said before.
I think I got that input math right.
With a bag, you just add weight on top of it and see how much you added and far it drops to get your desired outputs. I think that is the most direct measurement of input work.
LarryC,
In your attached drawing, only the first 2 steps can work. How can we use the hydraulic assist to use the lower pressure Zed to pressurize the higher pressure Zed?
Quote from: LarryC on September 06, 2012, 05:52:33 PM
'Our pressure is:
Regards, Larry
Quote from: fletcher on September 06, 2012, 04:41:33 PM
Happy hunting !
Hi Fletcher,
You and Seamus are soooo close, you are seeing but not recognizing the energy conundrum.
The water doesn't flow uphill, only a charged-up supply is maintained charged and is recycled with great advantage which gives you the appearance of an uphill flow, the net effect is the same.
I regret not able to tell you outright the answer, self discovery was the intend of the inventor in this tread.
Sawing the seeds for inventive thinking. Making people think for themselves, instead of copycatting.
Innovation requires independent and out-of-the-box thinking, possibly someone here can take the principles of this invention to new unforeseen heights, then it would have served a purpose. Blueprint copying is China. I though most of the members here live in the western world, the home of invention and innovation since ........ Or have we given up on that and intent to position ourselves behind China
I hope some new seeds can also be sawed for people in general to start thinking for themselves, instead of just eating and believing whatever is said on TV or news media as the gospel truth. Especially in the upcoming American election which appears to be a done deal before I has begun.
That was quite a mouthful, couldn't resist,
Michel
Well Michel .. what I've been thinking for quite a while is this.
Given that the inventor has made 3 prototypes with lots of professional support & is in the external validation process, I have no doubt that he is sincere in his beliefs & that he has a very supportive family, friends & team.
That aside, & I'm not in the business of crushing dreams, but I am interested in the truth.
The truth will be revealed whether his beliefs were well founded or not by the process underway at the moment - if he has an OU device that uses buoyancy & a unique combination of channels etc then this will unfold, one way or another.
My learning says that gravity is the cause of buoyancy - heavy things fall down & IMO pressure doesn't change the buoyancy or relative density environment unless you are talking about the cartesian diver example already mentioned previously - I accept that the inventor says that buoyancy force isn't increased by a ZED but I do have trouble with the concept of reduced energy input or that gravity is not conservative.
The reason is that you use a pressurized system - it is very easy to hide true energy use, at least for a while, & even if unwittingly - I have been aware IINM that for the two ZED system that Mark Dansie came to inspect, that one ZED wasn't behaving properly, which was subsequently sorted out after the event - but with two ZED's of not equal performance & capability in a symbiotic pressure trading relationship the possibility exists for ambiguous results which might not be self evident - added to that that the engineers on board hadn't anticipated or adequately addressed good input & output gathering methods in three prototypes when the technology touted as game & world changing would go under the microscope with just these questions first & foremost on investigating minds.
The upshot is that the two ZEDs in question were 'equalized' IIRC & this is how it should be for another test of any duration - the dual ZED testing relies on machines of equal ability & capacity sharing a resource to give this reduced energy input that is touted - there should be no delay to this test that I can see.
Having said that whilst a one layer purportedly doesn't show OU [I think that was said by Wayne] multiple layers do - two multilayer systems do not have to interconnected so the builders, whether publicly here, or in private, will be able to determine the input & output energies required.
When that information is in I will reflect on what my beliefs are, or were, & how appropriate they were in hindsight - in the mean time I await real world empirical results that unambiguously answer relevant & important questions about multi layered ZEDs.
Hi all,
I noticed error in calculation of work out from my 2D model. I said you should get 100% efficiency while it is 50% and something, far from ideal. My apologies.
This error leads me to think whether is COP of 100% achievable in single ZED in reality. I remember Michel saying 98% is max pls correct me if I'm wrong. With how many layers we get 98% A 1000, 10000? It is interesting question at least for me.
It seems like adding more layers increases ZED EnergyOUT/EnergyIN efficiency and OU is got via recycling the exhaust. This theory is supported by recommendations that we should go at least 3, 5 or even 8 layers.
I tried to model different dimensions for pod, gaps and got different EnergyOUT/EnergyIN numbers. I'm just starting to see the complexities of cooking in the pans and it is even more interesting...
thank you,
Marcel
Quote from: TinselKoala on September 06, 2012, 08:04:13 PM
@TK.I see the logic of your thinking,.However, have you taken into account that A is part of the set-up[never to be repeated ] cost? I can not express this mathematically, but if you think about it, you will understand what I mean
C on the diagram is the input to Zed two. It is less than A, because it is supplemented by D.
Gents,
It appears to me that this discussion can not achieve anything near over-unity
Fletcher, Seamus, MT,
It looks to me looks that this discussion can never lead to anywhere good, the least over-unity, because you guys appear so preconceived, by needing everything into the latest details presented to you and then you will dispute and be unbelieving without giving any serious counter argument.
I can appreciate a logical counter argument, I have been trying to steer towards it but I am not getting it here.
I presented some overview and flow figures in previous postings that played out a theoretical positive over-unity scenario. You have been given the HW measurements, flow volumes, pressures, working details and processes, these have been described all over these pages but there is nowhere any counter analysis with figures that contradict or show the flaw that is presented.
The only thing that I see is " can never work, why who knows...." or there are generalized arguments referring to the conservation laws and water can not flow uphill or we wait for the validation. You starting to look naked on these pages, poor I say...
Lets advance and say that the validation reports "all is legitimate & OK & OU". What will you have then, you still wouldn't know more than you have today. Or am I missing something ?, please enlighten me
I could finish the cycle with putting everything on the table, but this is not my place to do that, I leave that to the master of this invention
Regards, Michel
To All,
Several times now I have seen a accidental aversion to the replication mission here - unintentional - but will confuse people later.
The single ZED's purpose is not to make a running machine, that is the use of a dual system.
It is possible to take a single ZED and have a recapture method of the system (instead of another Zed) and reuse that energy to supplement the next stroke - be very clear - this is not the best use of the ZED.
(A single Zed leaves out one of the four principal operations of the system - this group has yet to uncover one of the "Diamonds" - the shifting of the center of gravity during the Free Flow process. - This is for a later lesson).
On my instructions concerning the current replications: The point of using a three or four layer ZED - is to reach a point that Buoyancy/gravity - is as effective as a standard hydraulic cylinder - for the pV and - on a second note...to simplify the control of the air and water.
More layers adds complexity to the design - we have overcome these issues - we had to invent multiple ways to control the water and air (differential in layers larger than four).
At this stage of the learning process - being the person with the most experience - it is my opinion and our engineers' - to hold that issue off - or it will add complexity and slow the learning of the ZED system.
The Replication Challenge for a single ZED - was to show and report your findings - Just as Webby did - with a more stable and measurable set up.
Since I do not wish to be the director of "observation" - I leave that method and value up to the replicators.
A single system (105%) has only a paper value - you have nothing to give - but a dual system (160%-190%) leaves you room to make mistakes - have losses - and to feel confident in your construction.
Important Note: I have told no one "What" to expect to see - this is the Joy of discovery - not to be stolen- do not make the implications of an expectation - other than physical reporting of personal findings.
The single system only demonstrates half our system and it is much harder to utilize - can it be OU, yes - the right direction to head - no, good for measurement - and understanding - yes.
See3d is designing a single Zed "a teaching model" - perfectly fine - Now... if you want to blow Overunity .... with a practical application ..... you better use a dual system.
Next Note: The replication challenge for the DUAL system - is for a running system - reason is simple you have a lot more extra to play with - I want our teams to win - duh.
Good luck Teams - Thank you for the private progress reports - sharing here is encouraged - but up to you.
Wayne Travis
Okay, this is stupid, but I could not get it out of my head. I was stuck at home for a bit anyway and was (again) chuckling to myself about the LED lighting... Like I have any LEDs! I don't (except inside working devices). Or so I thought.
I happened to notice an old 3 LED mini flashlight that I inherited from someone who bought it and said it didn't work. So a few minutes later and you have the picture below! And the real beauty of this lighting scheme is the power! Its an old Toshiba laptop power brick regulated through a DC/DC buck/boost converter. And even hooked up with alligator test leads.
I hope this cracks you guys up as much as it does me!
Seriously though, I have not made it to the store to get a digital mass scale, so no real testing to be done anyway.
Cheers,
M.
Quote from: parisd on September 07, 2012, 12:36:23 AM
Thanks for the question. My statement:
Hydraulic Assist - Since the Zed water columns start equal, the input cost will be to change the actual Water Head between Zed's from 0 to 3.4 PSI Please see the attached picture. Water weight is .0361 pounds per cubic inch and creates a force of .0361 PSI. Water Head in this case is the difference in height between the two columns of water. The example on the left with the equalized columns has 0 PSI or 0 Water Head. For the example on the right, if the Hydraulic cylinder pushes down the left column 1 inch, this causes the right column to rise 1 inch and the difference is 2 inches or (.0361 * 2) or .0722 PSI or a 2 inch water head. So the Hydraulic cylinder had to use a force that went from 0 PSI to 0.0722 PSI. Because of gravity, your input cost only needs to account for the height difference in the two columns.
Hope this helps. Please excuse for stating facts that you allready know, but others are also learning.
Regards, Larry
Test data from previously shown model:
The lift mass is a 2.5lb free weight of unknown accuracy. The mass is used during the "lift" and then removed during the "sink" portions of a cycle. There is an unknown preweight that is never removed along with the mass of the Pod and Riser construction as well.
This experiment was run several times to verify that the measurements were at least "close" to prior runs. But all measuring apparatus are very far from precision instruments. Also, there is some stiction in the ZED model, but I tried to compensate for that by always loading from the same side (ie. all readings were taken after coming from a lower pressure/height up to the previous alignment marks).
Data (as it is):
Mass lifted: ~2.5 lbs
ZED stoke: ~ 11.5 mm.
Water removed and introduced again to obtain repeatable(ish) stroke as measured by a "rain gage" from my yard: ~87.5mm.
Overall change in the head in the elevated fill tube during the cycle is ~ 190 mm.
Now I have no idea which (if any) of those measurements I should have skewed higher or lower to prove anything one way or the other, so I think the data is pretty objective. Please send questions before revealing any results so you don't taint my objectivity.
Let me know what else you want/need for now.
M.
Here is another of those questions you probably did not know the answer to, but were too embarrassed to ask. Well I am not too embarrassed, and I dont mind being thought of as the village idiot if that makes people happy .
Question. In earlier diagrams of the Zed,we see that the risers are separate items , with an air gap between their tops or lids. But now, Wayne says that we can have all the risers sharing a common lid. { see post1922 on page129 for a diagram . } So now, if we take the outer riser as an example, compressed air was lifting the entire lid of the riser, in early diagrams. But in the later "common lid design" , lift is restricted to a narrow annulus between the outer risers wall, and the wall of the next riser. So how come we get the same lift with a much reduced lift area? the air pressure is the same.
My answer. The air in the gap between the lid of the outer riser and the lid of the next riser. gave extra lift. But this extra lift was cancelled out by that same air pocket pressing downwards on the lid of the next riser.
Anyone agree/disagree?
Quote from: neptune on September 07, 2012, 03:21:49 PM
Yes, that is right.
Neptune,
The same lift ?? yes and no, it all depends on the layer ratio,
Before the outer layer was the biggest lift area with the LOWEST pressure, now the outer area has a way smaller area with the same low pressure, the center pod area will become the largest area with the HIGHEST pressure. This means that the pod will produce the most lift and control the lift. I would imagine that the control will become more sensitive and possibly more difficult since the buffering up the water column will be way less than before
Michel
Quote from: mondrasek on September 07, 2012, 03:15:45 PM
Data (as it is):
I think the volume of water in your rain gage per mm height would be needed -- to get the mass. There may be more dimensions needed to calculate the work input.
Quote from: see3d on September 07, 2012, 03:58:09 PM
Yeah, I was considering that before posting. But I "assumed" that a rain gage must be some kind of standard. Like, 1" in the rain gage means 1 in^3 of water. And so 1 cm in the rain gage means 1 cm^3. I guess I can double check the scale on the side with a tape measure pretty easy. And if it turns out to just be a "relative" scale, I can get the ID for volumetric calcs.
M.
LarryC's drawing above shows water flowing from one unit to the other as a result of the hydraulic assist.
But earlier he said,
QuoteRegards, Larry
How is that drawing compatible with that statement? Just what is being transferred between the Zeds, and how is it being transferred, if no water is transferred? Just what is the physical nature of this "D" that is being recycled in the diagram that shows A=B and C=B, but A not equal to C?
And now it appears that MrWayne is telling us that a single Zed system, no matter the layers, can't be all that efficient.... 105 percent? Easily in the measurement noise floor, just like when I ran the set of good numbers from Webby.
@mond:
Looks great, I see that illumination from underneath works quite well. You could try different color LEDs, positioned to illuminate the different internal layers from underneath. You might get lucky and be able to have different colors in the different layers due to diffusion and internal reflections. Or it could just mix into a mess... but it will still look nice sitting next to the LavaLamp, anyway.
I like your data set, but can you please describe in painful detail just how a "trial" is conducted and just how repeatable the start and finish positions are, etc. And yes, I believe we need the cross sectional area of your input cylinder rain gauge... or if it's one of those silly tapered ones..... some other means of determining the mass (or volume really) of the total water you inject and recover during a trial. (The mass is important to find the pressure but it's the volume, I believe, that does the work in the Zeds.) This, combined with the pressure computed from the elevation of the center of mass of the raingauge water, will allow an input work figure to be calculated.
Quote from: seamus103 on September 07, 2012, 04:49:59 PM
On another note,would I be the only one assuming that Red_Sunset and Mr Wayne are one and the same person?
Your powers of observation need some serious sharpening if you are confused about that... LOL
I have upgraded my simulation to allow different wall thicknesses for the Tank and the Riser rings. I have also added the ability to specify the gap at the Pod and the Gap at the exit to have different values than the middle gaps.
I have put in some extreme ratios into the sim and got results that were close to, but not quite believable, so I must investigate the formulas some more.
These modifications to the sim should help me match to actual build measurements for verifications.
@TK. Water exits a Zed and enters a convoluted rubber bag or bellows. This is mechanically linked to a second bag, so that as the first bag expands, it squeezes the second bag. Thus the exhaust of the first Zed helps to charge the second Zed . When equilibrium is reached, and the pressures in the two Zeds are equal, this expanding and squeezing would stop. But is then it is forced to continue by a hydraulic ram powered from the systems hydraulic accumulator . So the waters of the Two Zeds are kept separate.
On another note, would I be the only one assuming that Red_Sunset and Mr Wayne are one and the same person?
Hi .. nahh .. Michel's enjoying red sunsets in Saudi Arabia.
http://hydroenergyrevolution.com/index.php/our-guest-book
Public Information - I guess that is what See3d's cryptic comment is about.
So the foundations of the laws of conservation of energy along with centuries of experimental validation of those are not sufficient logic for you?
LOL - What a compliment - I am not nearly as smart as Red_Sunset....
Seamus - You really should listen to him - your credibility is tanking as you hold fast against what is clearly presented.
(well it tanked when you were moderated and you came back - now you make it worse)
As I said when you began this campaign against us - you are going to be embarrassed - please - for your sake - get your hands wet -
If you won't do your own work at least notice that Red Sunset can speak your language -
To be clear: Learning something new is not the "embarrassment" - it is your continued assertion that you have the authority of all knowledge of the universe with your incorrect conclusions, assertions and unwillingness to look.
Man can't fly - so that man in his flying machine must be a fraud - we have been through this before.
I will be very glad when you and the three others realize you have been wrong in your claims against me.
I see that a valuable resource has been given to you.
Until Then...... good day.
Wayne
Quote from: TinselKoala on September 07, 2012, 04:35:13 PM
Each "run" is started at a full lift and with FULL LOAD (+ ~ 2.5 lb weight) at a position in which the single ZED is at a witness mark (eyeballed from the Outer Riser rim) while under support from (I guess) the water pressure and "pre-load" that was previously introduced to that single ZED.
So I guess I must back up and explain the pre-load...
I have introduced water and air (into the bottom of the Pod chamber) several times through the apparatus you can see in the pics (sorry I can't post vids). I have learned that having too much air or too much water causes "skirt blows" as I try to cycle repeatably. So I have lowered the stroke and adjusted the air and water until I can repeatably perform the same cycle without the above mentioned problems.
So, in other words, I have run this test cycle "up and down" too many times to count. And if the amount of air in the system or the amount of stroke (Hi Wayne!) is too much, you blow skirts. So I have repeatedly run this test while adjusting the air and water (in the outer most ring) until it will repeat without blowing bubbles (skirt blow), etc.
I have marked the input tube water height with masking tape and a fine "sharpie" when the ZED is at the top of it's lift (eyeballed, of course). I then remove the ~2.5 lb free weight. Then I vent water from the bottom of the "system" through the valve shown in the pics. I vented that fluid into the "rain gage" for those gross observations that I posted earlier.
Without the the added mass of the 2.5 lb "load" I let the system vent until it has dropped the previously reported distance. Again, I must let it drop a bit further than that and then cause the system to rise up to that data measurement line because stiction is an issue. This is done by supplying some of the previously vented water back into the system prior to measuring that "volume."
Once everything is at "equilibrium" at the bottom witness mark (that I marked previously with another "sparpie" and have been trying to replicate with this "cycle") I make sure the vent valve that is allowing water (and pressure) to escape the Pod chamber is closed.
At this point the reverse is easy (thank God!). I slowly (only because my gaps and input tube Reynolds friction forces may cause unexpected reactions if you don't go slow) reintroduce the collected (and measured in the rain gage) water that was required for the above described cycle.
Please let me know what else you might need.
M.
Sorry, I forgot...
The rain gage reads between 40.12 and 41.92mm on the ID with the verniers. It's made out of glass and from China... I have no idea what the real volumes would be down at the bottom.
Is this why I need a digital mass scale?
M.
Please find attached a picture from the 'Travis Water Height calculator based on Outer Retainer Water Drop Single Top 5 U. So it is a single top plate with 5 U's. Also added a few new fields:
1. At J3 Pod Retainer Water Drop value, as I realized that some may not know to take the Pod Retainer water height from the Ideal section and subtracting the Pod Retainer water height from the Outside Ret. Water Drop Section to know how much to drop your pod retainer water height to meet that PSI and lift value.
2. In the Channel Si Calculation section at the bottom the values for Total Water Volume and Total Water Volume Weight in Lb was added as requested by a replicator.
Those who are working with a single top 5 U please review and let me know of any problems.
Also, If any want a single top 4 U or 3 U please PM.
@Neptune,
I totally disagree that you are the village idiot. Your insight and wisdom has been very helpful to me and others.
I find your bravery to post in the face of the hostility, antagonistic, dogmatic and mind game attitudes of some, very admirable. From the PM's to me that is the reason we don't have many more posting directly here.
Thanks, for your excellent response to TK and feel free anytime.
Regards, Larry
Quote from: neptune on September 07, 2012, 05:22:36 PM
Thank you, that is the way I thought it was plumbed. So what is the point of LarryC's drawing that shows water being transferred between his simplified Zeds? Gratuitous obfuscation?
It seems to me to be a rather different system than what you are talking about. And I thought, from somebody's description earlier, that it was this "excess" water or its pressure, translated through the mechanics and the hydraulics, that provided the hydraulic "assist" in the first place? It still seems that all explanations eventually fall back to "pulling yourself up by your bootstraps". I'm still worried about how, if A=B and C=B, yet C =/= A.
And I'm also worried about the system that wasn't working right, the asymmetric system in the video from Mark D... If a single Zed is only 105 percent efficient and the two Zeds weren't working symmetrically.... how you can possibly get OU from the pair? If they both need to be able to make 105 percent OU for the combo to make 160 percent, or whatever the number was.... and one isn't working up to its full 105 percent... and in fact is considerably below that from the sound of things in the video..... how does the other unit make up the difference, if it, working alone, could make 105 percent? Not only do the Zeds not seem to be transitive, but they also seem to be able to read each other's minds and make up for deficits in their partners.
Quote from: mondrasek on September 07, 2012, 06:07:52 PM
Sorry, I forgot...
The rain gage reads between 40.12 and 40.92mm on the ID with the verniers. It's made out of glass and from China... I have no idea what the real volumes would be down at the bottom.
M.
Well... you can calibrate the raingauge without a digital scale, can't you? Got a syringe somewhere that's marked in mL?
By the way, I have a Sartorius 1106 lab scale that I will sell cheap. It's had some wear and tear, a replaced power switch, but works fine. 200 g range, 10 mg resolution. I also have a Mettler H10 analytical balance, in good condition, some cosmetic rash but fully functional. 160 g capacity and resolution below one milligram. This will cost a bit to ship properly but I'll also let it go cheap. Make an offer if interested.
However for the present purposes a simple "Chicago Electric" Chinese digital household scale, for twenty bux from Harbor Freight, would be sufficiently accurate enough I think. And a good fisherman's spring scale that could be modified to read pushes instead of pulls, by a simple lever system, would also be useful to the experimenters here, I think.
Quote from: TinselKoala on September 07, 2012, 06:31:52 PM
Okay. I might be able to do that.
I know, alright? I've checked it out on-line a couple days ago.
But I'm supposed to be on vacation. You know, that one week a year you can just relax? But so far it has not been a stellar start. I've got 680 miles to drive in the morning and the wife and child are not even home from "perparing" yet. So I'm a bit stressed on the front end of my supposed relaxation time so far.
Please switch to decaf for the moment. I only posted what I did in an effort to help with what I could while I could. I'm not happy with the resolution or the accuracy of any of it. Just thought it would be better than posting nothing for the next week.
M.
@Mond: Ok, thanks for the description, almost there with the detail. How is the water reintroduced from the rain gauge to make the upstroke? You have to elevate it from the position where it received the water from the downstroke?
It seems that the work output value is clear from your single dataset: Going in the lifting direction, you are lifting a mass of M of through a height increase of H against a force of G... so you have an increase in the PE of your lifted mass of MGH. (using caps to distinguish from input energy).
And your input.... let's just go by the position of the center of mass of the "slug" of water (no pun intended) in the raingauge before and after the recovery and injection of the water from it. Say your gauge is empty enough so the CofM of the water remaining is at 2 cm above the bottom, and when you recover the water from the sinking of the big mass the CofM of the gauge water is now at 8 cm above the bottom, for a height gain of h = 6 cm, and a mass of m grams, against that same force of g. So the change in PE of the input can also be measured, apparently fairly easily.
So, a series of multiple, similarly conducted trials that yield an average and a variance (mean and standard deviation) of the input and output PE values would be nice to see. If your fingers don't get all wrinkly and make it hard to type, that is.
ETA: Decaf? DECAFFF????? Surely you jest. I'd just as soon drink.... water. (yechh...)
So the CVS 5ml syringe rings out at about 50ml (yes, ten fills) to about 37 mm in the raingage (conservatively low reading).
And with your other investigative direction... I am bleeding off water from the bottom of the Pod center tank. And then RAISING it to pour into the "funnel" that drains down into my input water tube.
Is that raising PE? I think that is a valid argument! Either way, do you want a measurement?
M.
OK....So raingauge itself is at a fixed height supported on some kind of stand? With a tube and valve leading to the bottom inlet into the pod chamber of your Zed?
OK... so start with M in the full up position (call this HM) and some small amt. of water in the gauge. Mark the CofM of the water in the gauge, height h=0. It's OK, I think, to neglect the water in the tube at this point.
Now open your drain valve and let M sink and settle, collecting the water expressed in your cup or whatever. Close your valves. Weigh this water and record the weight. Lift up the cup of water using a hydraulic forklift, chain hoist, a jetpack, or your hand and arm. Pour the water into the rain gauge. This will raise the level of the rain gauge's water CofM by some amount to height h=hW. Measure this amount and record it.
Now open your valve to allow this water to run back into the Zed pod chamber, raising the M mass from height H=0 to height H=HM. Record.
Lather, rinse, repeat 20 times to get good data for stats. Make a data table; crunch to means and SDs, calculate PEs and deltas. Report.
How can you even think about taking a vacation at a time like this? You are about to provide the first, really solid, empirical energy input/output numbers from a tabletop overunity buoyancy device. Other than Webby's, of course. Can you beat the 102 percent or so that I calculated from Webby's single data point?
Quote from: TinselKoala on September 07, 2012, 08:34:37 PM
Ha! Okay, old man. Remember when I said this is not my baby to birth? THAT is why I can still go on vacation (I hope).
My "build" (as it is) and my "data" (as it was) is only presented to answer questions for anyone who wants something more touchy-feely that the word play in the forum.
Mom and child are home and safe now. So I've got to give up the fight for now and a few days. I hope to be on-line in NC by Monday.
Sweet dreams.
M.
Thanks Mike .. have a great time - I know you won't even give this discussion board a further thought ;)
Quote from: fletcher on September 07, 2012, 05:38:22 PM
Hi Fletcher,
Naaa...h, unfortunately no Red Sunset's in Riyadh, the dust makes the sun go down at ~25dgr altitude in a milky haze.
The name Red_Sunset was taken from the red sunset in Chesapeake Maryland, early last July while being on a sailboat we delivered to Georgetown on the Sassafras river in Chesapeake bay coming from the San Blas islands in Panama and loosing our mast in a storm 30 miles SW of Key West in the Florida Straits.
That was the time when you had an heatwave reaching 104dgrF. in Virginia / Maryland. Using the internet at sundown and seeing the stupid unconsidered attacks on Wayne, I created this name to reply in support of him. But there was some issue with the name confirmation, soit was not used at the time. It just happened to be a beautiful impressive sunset at the time, the reason for the name.
What have we achieved since then, the same old mucky dialog, and I think I will do the same thing than Wayne.Leave the tread.
Because the people can not advance because they can not help themselves, because they do not want to be helped. A lost cause. Better get on with developing improvements for the zed, bigger output for smaller size.
Regards, Michel
Thanks for that Michel - I'm in Fiji , so plenty of red sunsets but the name was taken.
That's one option you can take - leave I mean, & concentrate on improving performance of the ZED - just perhaps, now you have a better appreciation of the uphill battle to convince people that you have something so special that it is world changing.
A lot of that credibility is earned & comes from moving on two fronts simultaneously - having rigorous data collection & scientific method, that is indisputable, even to the most entrenched person reading this thread - that means a good versatile & adaptable model.
The second, especially for a mechanical system like this, is to use simple Newtonian mechanics which is even preferable given most understand it - that's why most skeptics here will concentrate on either a gain in Potential Energy or Kinetic Energy full cycle which would prove beyond doubt that gravity is not conservative.
I don't think there is any need to delve into Bernoulli fluid dynamics of fluid flow or Reynolds numbers etc & other higher order considerations of fluids & pressures - a simple 'it has so much work put in to it & it raises the PE thus' is usually a sufficiently detailed explanation IF the results conclusively back this up - you don't even have to close the loop because it is self evident that the loop could be closed.
Wayne said at the beginning that he had studied Rossi's E-Cat release & I think Steorn or was it ... well it doesn't matter, & had learned from that experience, yet even with his & yours proclaimed goodwill intent it has been tough going though not unexpectedly so IMO - what you do learn at public forums like this has more to do with human nature than anything else - this is an obstacle to overcome for yours or any new release of free-energy that might eventuate.
Probably the most interesting thing from my perspective is that HydroEnergyRevolution Inc has publicly plotted its course & set its sails, no going back in the box - in time [& I'm very patient] everything will come to light [I'm not prejudging that outcome] - nothing will be hidden except for improvements & developments in train & yet to be patented etc - at that time, not to distant future, all this apparent 'slow trawling out of information & you are bad boys for asking' will seem irrelevant - I understand why you guys are doing this re: "teach a man to fish & feed a man etc", & to give yourselves some insurance by spreading the word - usually that's done hard & fast & effectively & the teaching comes later.
Anyway, whatever you do it has actually mostly been a pleasure - I don't think you'd make a good teacher though & I'd probably be a bad pupil - don't particularly like authority etc ;) - may the sand not blow up your skirt.
P.S. these are just my opinions.
Gents,
Goodbye until there is a drastic change in this forum
I have nothing to gain or loose for being on this forum and I can no longer justify my time to be here
I start to be bothered by questions such as,
Why am I here ? taking time typing explanations, some philosophy ...ect, to what purpose? when I can be spending my time on a better and more productive purpose. I think I have full-filled my obligations in context with this forum (as repayment to previous gains)
What puzzles me on this forum,
What do you die-hard members want out of this forum?
Why do certain member behave, respond, the way they do?
Why give...give..give.., some members can not even search 2 pages back for the answer, so why repeat?
What do the notable emotions indicate ?
Why do milehigh, microcontroller, Tinselkaola sent me multiple private mail?
Why are they angry ?, is it a tantrum because they can not get what they ultimately want ?
What is their ultimate objective ?
They can be in control to satisfy their own frustration in a academic way, why do they take the chosen path ?
The forum is only 1/2 inch away of the final and main principle of OU, but you do not want to engage, why?
The mathematician seamus has still not shown one number to support his rejection, why ?
Why does seamus not prove in a detailed way why conservation prevents OU in the Zed ?
I am sure Seamus has done the analysis privately, why does he not share it online ?
What is Seamus objective ?
I am sure that Seamus, TinselKoala and several others understand exactly the principle of OU in the Zed, why do they want to frustrate others to know it ?
As a forum, how do you grow logical reasoning that leads to creativity ?
Do people want to understand a clever technique that exploits physics to great benefit?
Do people just want short term benefit for own gain, like a quick rip-off the creation of someone else ?
How much importance do the test values have with understanding vs understanding the concept working principles ?
If you want to create something new you have to come up with a new idea. New idea's are based on new things, revolutionary new idea's are based on new things that were not possible before. Invention and innovation is usually based on new idea's, new angles and techniques in a step-stone fashion. In order to make the next step in this process, you need to understand the previous step. If not, the process is at risk to fail on the first hurdle. Too my amazement, certain people will build this Zed device without understanding the pivotal technology principles that underpins its working. Maybe they hope it will reveal itself in due time, what is very possible but the risk is high. Logical reasoning leads to understanding as they are critical ingredients to avoid failure.
The cycle of life is giving in order to receive, a lesson of life that is very well understood by Wayne. Make no mistake, we can ALL learn more about Zed's and the physics that underpin it, that is why positive engagement is mutual beneficial. This story is far from finished.
All the best for the time being,
Michel
QuoteGoodbye until there is a drastic change in this forum
Don't let the door hit you in the butt!
Just FYI... If I never read this stupid forum again... NOBODY WOULD CARE! Why do you think that anyone cares if you login and read these messages?
Reading these posts is just something to pass the time...
Quote from: fletcher on September 08, 2012, 12:57:54 AM
Hi Fletcher,
Sorry missed your mail while busy with others, Nooop Fletcher, I thought you were the best pupil on this forum.
I am not teacher, I am usually way more patient in teaching someone, but I have no time for someone who is not prepared to make an effort to learn or understand what is being thought. For a student that shows he wants to know and makes an effort, I will go all the way without limitation to help.
I agree with your analysis on methods to introduce new concepts. There is a lot to be said for going on a forum to introduce a concept like this, I personally do not believe this is the best vehicle to do an introduction for this invention. Although it gave Wayne a good taste of the variation in reception can be expected from the academic and business worlds, I am sure that was what he was after. What is the best introduction ? I think is a good question, a good working model that produces ~ 1kwh running for a week at a strategic site like a mountain top feeding a rotating search light would make an impression.
I believe like in sailing, preparation is everything, any concept depends on communication of understanding, certain concepts require way more visual than words to describe it, and throw into the mix inventive methods that work their way around basic physics laws, you need a good thesis to support these claims.
To present it through this forum, I do not think you can get away with the reverse process "tell and then show', that requires too much of the average mind, it needs a "show than tell".
To help my investigations, I have been doing a write-up in order to formalize and structure all information relating to the Zed with my own deductions. This document is taking shape like something alike to "Zed for dummies" or the " Zed riddle explained" and is still in progress. By moving away from the forum, I should get more time to spent and finalize this.
I have always been receptive to a good creative idea, doesn't matter which science. The zed intrigued me, and initially I thought the same thing what you guys say on the web with the difference that I dug in deep, I wanted to understand where the OU entered the picture. This takes time to clearly understand these processes and connect the dots (I am in communication and project management, not in hydraulics) Wayne provided from time to time in addition to the forum some pointers along the way by request, it took a lot of sleeping over it, visualizations and simplifications of design...ect, but the penny dropped eventually. The realization of discovery is just too sweet. I have never build one, but the theory is sound and none of the individual processes violate the conservation law, sounds weird but that is how it is.
If you approach the issue from the conservation angle, you will be blind enough not to see it, analyze NOT to see it, do it step by step, do not overlook any part of the setup and you will see.
If you or seamus only presented to me your conservation analysis, I could have pointed out where the conundrum is, and you and we and I would have advanced. Even if you would be able to refute it in a logical argument that would be indisputable, I would accept being wrong. Although I do believe that Wayne has a working model to support it, that should reduce the possibility of a refute.
PS; We can be firm in our beliefs so long it doesn't close (shutdown) our brain, that is when the trouble starts. I see this tooo often.
Go well and hopefully our paths cross again, Michel
Just to set the record straight there, RED_SUNSET.... the PMs you got from me are ALL REPLIES to emails that other people sent.
Have you ever gotten a PM from me that wasn't in that category? IN FACT... going through my "sent" file... I save every PM that I send.... I see only one PM from me as a reply with you in the cc list, and ZERO PMs from me directly to you. It's possible that I may have deleted or forgotten to save something so... if you have a PM from me directly to you.... please feel free to post it publicly so all can see what you are complaining about.
You were included in the cc's for those emails out of courtesy, I think.... and now you want to make it seem like I am bothering you or hounding you with PMs, like some people do.
But is that really the case?
I don't really expect an answer, just more rationalization.
Quote from: Red_Sunset on September 08, 2012, 01:42:35 AM
Gents,
Hmm, thats pity (and I mean it), I like you insight, different angle than MrWayne and also that you took a bit of moderator role here. But if you think you should do it, then you should do it. Things said here should not be taken personally although I agree it is sometimes difficult.
Such a forum is very unefficient way to exchange information. I work in IT and have many colleagues in India. You can guess how much misunderstandings we had on both sides. Even by use of video, emails, chat and phone. And here is just chat somtimes pictures if somebody finds time to draw it. We miss a lot of non verbal comm (if not all).
respect,
Marcel
Oooops, a slip of the pen in my previous mail
Please replace,
PS; You can be firm in your beliefs so long it doesn't close (shutdown) your brain, that is when the trouble starts. I see this tooo often.
With
Tinselkoala, I have no problem with you sending me a personal mail, I just question your objective,
I didn’t do a forensic on the mail received, only the headline what said,
from: Free Energy - Freie Energie - energia libre - OverUnity.com harti@harti.com
date: Wed, Sep 5, 2012 at 6:24 PM
subject: New Personal Message: Re: trolling again in the ZED thread
mailed-by: harti.com
Important mainly because of the words in the message.
You have just been sent a personal message by TinselKoala on Free Energy - Freie Energie - energia libre - OverUnity.com.
IMPORTANT: Remember, this is just a notification. Please do not reply to this email.
Quote from: webby1 on September 08, 2012, 03:16:33 AM
TK,,
Man do you ever just do or mean one thing???
PM me with your address and I will send you some of this iced via coffee, it is good.
Lets have fun with some simple stuff,, I like simple.
Charge and discharge.
Sometimes. Let's just say that lately, I am especially "tetchy" about people saying things that just aren't true, about me or my work or my behaviour on this forum.
And I don't see how it could get much simpler than the way Mondrasek is doing it; I'm not clear enough on your system yet to see if your piston is likely to be better than his elevated water in the rain gauge.
Noo, no thanks on the iced coffee. I like mine lukewarm, and grey, with kreamie.
@Red_Sunset:
Here's the header from my "sent" mailbox for the PM you are referring to. Why didn't you include the full address list? Never mind, it's a rhetorical question.
QuoteRe: trolling again in the ZED thread « Sent to: hartiberlin (http://www.overunity.com/profile/hartiberlin.2/), neptune (http://www.overunity.com/profile/neptune.4158/), fletcher (http://www.overunity.com/profile/fletcher.6533/), mondrasek (http://www.overunity.com/profile/mondrasek.7703/), MileHigh (http://www.overunity.com/profile/milehigh.20740/), conradelektro (http://www.overunity.com/profile/conradelektro.22881/), mrwayne (http://www.overunity.com/profile/mrwayne.25139/), microcontroller (http://www.overunity.com/profile/microcontroller.26898/), Red_Sunset (http://www.overunity.com/profile/red_sunset.60531/), seamus103 (http://www.overunity.com/profile/seamus103.62828/) on: September 05, 2012, 05:24:45 PM »
This was a reply to a PM sent to us all by, I believe, MileHigh.
Just as I said. You question my objective? I question yours, right back.
I directed a couple of sentences to you directly in that PM. I was responding to some points with what I felt, and still feel, is a perfectly valid concern: the fact that you seem to "know it all" but you yourself haven't "gotten your hands wet" as far as I can tell ... but no skeptic has credibility unless they do get their hands wet, apparently. And the fact that your calculations are "too good" to be true... once the math error is corrected you have an embarrassment of overunity riches and the question becomes now....where did it all go? In other words, I think your calculations are suspect, not based on actual measurements of a real system, and not even measuring the right properties to answer the Big Question anyway.
Hi,
just created a model of dual system (0 layers) reusing exhaust. Also drawed expected water levels and pod positions for all steps. Needed 2hours to draw it :) Each square is air or water. If water than it = 1kg. Each square is 10cm=0.1m high.
I decided to not post yet complete energy in/out calculations as I'm not sure how to calculate work done while injecting water.
In Precharge step 8 liter if water is injected in the inlet. Columns 1 and 22 are connected so water rises 4 stories high in both.
Have 2 questions:
1. What is the potential energy of water in both columns
Ep = m*g*h = 1 * 10 * h
EpColumn1= 4 + 3 + 2 +1 = 10
EpColumn22= 4 + 3 + 2 +1 = 10
Ep = 20 is this correct?
2. Is potential energy gained under ideal equal to the work done?
I think yes for precharge step. What do you think?
respect,
Marcel
@RED_SUNSET
I for one have found your input helpful and I also agree with many of your frustrations. This is a rather different group than any of the other forms I'm a member of, ALL forums have a distinct personality. Personal choice to remain a member or not. And if I'm the person that has you puzzled because I "build without understanding" - sorry, don't know any other way.
That does raise a point I find both amusing and confusing; a year from now, if this plays out to the point of modifying / amending / adding to certain rules of physics... Any one with an interest will be able to study the principles, theories and dynamics all at once . The entire documentation will be available with the diagrams and examples well defined and illustrated for the simple minded like me.
I have not once complained about the way this is being handled now or demanded answers or proof. I've asked several questions and done my best to understand the answers. I fully intend to continue "being me" to the end.
Won't be the first time I've taken a "risky" approach to solving a problem and I often DO find the solution.
Dale
@Red_Sunset. I do hope you will find the time to pop in now and then. IMO your contribution has been very valuable. Regarding building without understanding. As Wildew says, that is the only way for some of us. Then there who build thinking they understand all, but do not. I say, full marks to those who at least try to build, whatever their level of understanding. They are bound to learn something, and in the process may teach the rest of us.
Michel
Why? [your post 1996]
I like to think of it as a Balance....
besides .. the experience builds muscles and keeps us grounded in reality !
Very true your observation about sharing..... "giving it away" to keep it !!
On to whom so ever much is given much is required!!
thx
Chet
PS
Secrets don't change things ,they just cause resentment and reinforce the status quo.
If you believe you understand the mechanism at work here?
SHARE.............{its good for the soul!:,}
Quote from: webby1 on September 08, 2012, 11:42:32 AM
I am running with 4 risers now and am back to using a reservoir that I raise and lower for the input.
webby1,
The description you give is generally consistent with my expectations, based on my simulation.
You say you have a 4 riser system. However, I believe it can be a 1, 2, 3, or 4 riser system just by leaving out the water in the outside water pockets. That leaves the free air able to go to any inner riser you want as the last one.
An interesting experiment would be to measure the difference in operation between a 1, 2, 3, or 4 riser system, keeping everything else the same -- assuming you don't blow the skirt of the last one.
If you have the time to make some measurements in a 1 riser configuration, I could use those to help verify my simulation.
Let me know if you would be willing to do that.
Thanks,
Dennis
Quote from: see3d on September 08, 2012, 12:08:34 PM
It would be indeed interesting, it is also not clear to me how adding layers helps here. I think it helps increase COP of device so for same amount of water injected you get more work out but I still need to prove it in numbers. I'm bit stuck in calculating work done for injection of water from bottom.
respect,
Marcel
Quote from: webby1 on September 08, 2012, 12:21:25 PM
I will do what I can to help. I need to know what the setup needs to be...
Thanks webby,
I can input any dimensions into the simulation for a single riser ZED at this point.
I would have to know the exact diameters of your parts (or average if not quite round):
Pod
First Tank ring ID or OD, and wall
First Riser ring ID or OD, and wall
Exit Tank ring ID
Internal Heights of parts
The gap at the top and bottom of the walls when at the bottom most position
The riser/pod combined dry weight
My sim usually starts with:
The Pod at the bottom
Water just touching the bottom of the Pod, or as deep a needed to make it start to float
Zero air PSI
Pocket water at about 75% of the way up the total riser height
However, I can adjust things in the sim as needed.
The measurements taken would be for a load weight that gives a meaningful stroke without blowing the skirt:
3 water heads and riser stroke for each of the following -- the amount of water added would be calculated from the Pod head:
When the Pod first moves off the bottom
1 or 2 partial stroke points. These could not be averaged, so must be just individual single point observations
At the top of the stroke
Averaging several measurements at the bottom (just lifting), and top (just touching top) of stroke would help with accuracy.
I would have to back calculate the actual input force and air PSI from the geometry and internal states. I would in essence play with inputs to the sim to match the observations.
Thanks,
Dennis
@TK, let us take another look at the Diagram By MT. This is my analysis. Figures quoted are just examples.Losses are ignored.
Let A = 12 units of energy.
B= 12 units.
C=6units- .These 6 units come from the B above Zed one, leaving 6 units as output.
D= 6units which are added to C to form the total input to Zed Two.
That makes sense to me . Does it make sense to you?
@MT: Thanks for your drawing, I know how hard "simple" computer graphics can be. I think you are right about the PE change being equal to the input work, this is as it should be.
However.... you are showing water flowing from one "simple zed" into the other. We've been told several times that this isn't the case in the actual device. The water flows out into an external bag for one zed and each zed has its own bag, and these bags are pressed on, or they press back against, some mechanical/hydraulic leverage system, I think, right?
There must be a reason for this, otherwise the simplification you have shown would have been used in the real device. I don't know what difference it makes but there must be one, and if we keep ignoring the bags in our sims and sketches we might never understand what the bags are actually for.
@Webby: You've described the perfect system for getting actual work in/work out measurements, using your elevated reservoir, going up and down to get the water in and out of your zed and making the load mass rise and sink.
When you repeat the cycle, do you find that you are lifting and lowering the elevated reservoir the same amount each time? (This is an important question, not just from the standpoint of repeatability of a cycle. If there is excess energy being created, or evolved or whatever.... where does it go to, in your system?)
So, if you've got a repeatable setup, and the practice in making it work, you could take some measurements, like I suggested for mondrasek. Load and "prime" your plumbing so that you have a little water left in the elevated reservoir at the end of the input, so you can get a good measurement of the overall quantity being transferred. Then do the cycles, raising and lowering the reservoir to the required height smoothly and quickly, and holding it there until the water is transferred. If we know the amount of water and the heights of the centers of mass of the "slug" of water in the reservoir at the bottom and the top, we can calculate the input work, I think, if I am understanding your arrangement correctly. I think we can neglect the water that remains in the plumbing tube from the elevated reservoir to the zed input port.
So it's as if the reservoir you are raising and lowering is the "bag" and you are providing pressure by manipulating the head height, instead of pressing on the bag with levers, I think, right?
Quote from: neptune on September 08, 2012, 01:47:49 PM
B= 12 units.
No, not quite.
Let A = 12 units, fine.
B
1 = 12 units, also fine--- until the next step.
C = 6 units.... from the "B above Zed one, leaving 6 as output." so 6 are in C, input to Zed two, and six are in B
1, the output, right? So we've input twice the amount of energy units than we get in this Zed's B output, and half of this input energy is actually going over to the second Zed. Right? Half of our input 12 units winds up in B
1 and the other half winds up in C, going into Zed two.
D = six units which are added to C..... six units coming from where? Out the side of Zed One? Or from B
1, leaving nothing in B
1? Where does this D come from, if not from the "D" that is coming in from the left side, the recycled D from Zed two?
I agree that C+D should equal A. But you are either using the same D to add to C in the second zed that you have input into the first Zed before the cycle, or you are making it from nothing. Or.... it is equal to zero _in this schematic_, which makes more sense to me. In other words, I see no mechanism for any gain in what has been described in this sketch. Not only that, you seem to be left with only six units in B
1 unless you add D to them, no matter where D comes from ....
QuoteFrom TK
One good reason for this is a continually over looked principle of the system.
It's frequently stated that once the riser of one ZED has lifted, the cycle is reversed by pressing down on the riser -
This is incorrectIt was also discussed just a few pages ago.....
Once the free-flow ends, the process of transferring water from the POD of one ZED to the POD of the other is assisted. VERY important point.
Are there other ways? Sure, but I can't think of an easier one.
@Webby: I'm really not sure of the importance of the timespan of lifting; I just thought that "instant" would be simpler from a calculation point of view but from a work standpoint it shouldn't make any difference. Until we get into power issues, that is, which is the rate at which work is done, distinct from the quantity of work.
But it sounds like you've got the procedure down, and the skill to do the repeatable measurements.
Running your numbers:
25 g water, 26 inches from rest to lift: input
600 g removable mass, 15/16 inch lift: output
converting to metric,
26 inches x 2.54 cm/inch = 66 cm
and
15/16 inch x 2.54 cm/inch = (15 x 2.54)/16 = 2.4 cm
So input work is proportional to 25 g x 66 cm = 1650 g-cm
and output work is proportional to 600 g x 2.4 cm = 1440 g-cm
for an efficiency of 1440/1650 = 0.87 or 87 percent, a perfectly reasonable figure.
Please check my work, and if I've made any wrong assumptions or errors let me know so I can correct them. And thanks for the clear reporting!
@Wildew.... you are right mostly I think, but we have been told that there is no water transferred between the Zeds, just force, apparently, between the bags: as one fills the other is squashed, but there isn't any interchange of the actual water.
I think. It would be nice to be clear on this point, especially in the sketches, sims and thought experiments. Sometimes oversimplification can lead one astray.
QuoteFrom MT
I was going over one of Larry's spreadsheets for the umpteenth time and finally let something sink in that's been mentioned many many times.....
Guess I'm just as guilty as many for not seeing something the first, or second, or third time.
The pressure and lift values for the innermost riser are the highest of the five, WT?
Oh yeah, DUH, being so accustomed to standard hydraulics I just wanted to "see" that the riser with the greatest area would have the greatest lift, CRAP!
What to the other risers accomplish? They provide resistance against the incoming fluid ( frictionless hydraulic cylinder ) so the pressure in that inner-most riser will be the highest. Two forces there too, hydraulic lift from pressure and buoyant lift from displacement.
The other risers DO also contribute to lift from both pressure and buoyancy so all parts are contributing in multiple ways.
No wonder the math guys are having trouble......
QuoteTK I think. It would be nice to be clear on this point, especially in the sketches, sims and thought experiments. Sometimes oversimplification can lead one astray.
Wholeheartedly agreed!
Maybe sketches should show a different colored separation between masses of water there. From thought experiments, a mostly frictionless cylinder of sorts. Energy calcs should also take into account the force required there to stroke. I believe roughly 30 percent of the stroke output from one ZED is applied there to cause the opposite one to stroke.
@Webby: Now, "lift efficiency" is one thing... but is there any other usable output where excess energy could make an appearance? How about some extra pressure, that could be bled off to a second Zed somehow, like by compressing a bag or helping with a hydraulic assist? It seems to me that this is what the "extra" work claims boil down to, as in the sketches and drawings above.
I don't really see how any excess pressure could be in there at the end or during a cycle, without the creation of excess matter, and I really _really_ hope we aren't going to be claiming that. And I don't see how it could be used without "bleeding it off" somehow, removing it from the system. Otherwise it's just a spring, returning what you put into it.
@TK. The main question you are asking me, is where does D come from.
After a Zed has lifted, the contents are still under pressure, and the water heads are raised. The "load weight" is then removed from the Zed, leaving sufficient residual weight to cause the Zed to lower its pod and risers. At this point, water under pressure exits the Zed. The energy in this pressurised water is D. So , in a sense a Zed has two outputs, B, and D.
Nothing against MT's diagram, as it is easy to understand for most, but Michel (Red_Sunset) diagram has much more detail if you want to understand the Zed Flow.
In the first picture Michel's diagram is broken out from the original document for ease of your discussions.
The second picture is the original document sent by Wayne and created by Michel.
The third picture is of the Bag and Lever Arm.
The hydraulic cylinder assisting the bags used as Hydraulic pumps is the chosen method used by the Zed engineers. It's location is optimal, but it is not important that bags be used in any simplified diagrams, only that there is a hydraulic pump with hydraulic assist indicated. The purpose of a simplified diagram is to reduce the complexity and increase the understanding. Including the full Bag and Lever Arm setup is contrary to the concept of simplified.
Regards, Larry
Quote from: neptune on September 08, 2012, 03:13:22 PM
Uh huh... and by your explanation, what is left in B is only one half of A, because you have taken D out and moved it to add to C..... So what is left in B and the D add up to the original full B which is equal to A. But you are adding the D from the other Zed to the first B to make up the difference. Doesn't this then remove it from the recirculation cycle? It still seems to me that you are trying to use the same chunk of energy twice somehow, both taking it out from B to use in the other zed but putting it back in _from_ the other zed, and the only way this can happen as you have described it is for extra pressure to come from somewhere. And if the geometry is the same at the beginning and the end, extra pressure can only mean extra mass, extra material.
And you can't just magically "remove" the load weight, can you? Doesn't this "removal" require work input? What is a full cycle if you do not reset back to original positions with everything? You are doing something to "remove" the load weight. Just latch it at the top and let the riser sink away from it? How does it get back down then, do you just drop it?
You still have to explain how you start with one geometry and pressure, go through a cycle and wind back up at that exact same configuration, but with excess pressure. The extra matter has to come from somewhere. You can't have the same geometry with two different pressures, unless there is more compressible matter in one of them. If it is your "D" that you are recirculating, there is no gain there because it comes from the other Zed's B output, by your description. Just like squeezing a partially filled balloon and watching the compressed bubble squirt from one end of the balloon to the other.... it's not going to get any bigger on its own.
Let me tell you a little story.
Three travellers check into a motel. The newly hired night clerk says "I'm not sure what the rate is for all three in one room; just give me 30 dollars and I'll send the bellhop up with your change."
So each of the travellers gives the clerk a ten dollar bill. So the clerk has collected thirty dollars, and the travellers go to their room and settle in.
Later, when the night clerk has checked, he finds that the room rate is only 25 dollars a night, so he gives the bellhop five ones and sends him to the room to give our travellers their change back. But the bellhop figures, well, there's no way to give five dollars evenly to three people, and they don't know the difference anyway, so he'll just give them one dollar back each... three dollars.... and pocket the two dollars as a tip. So he does that.
Now, each traveller has given out ten dollars and gotten back one. So each of the three travellers has spent nine dollars. Three times nine is 27. And the bellhop has two dollars in his pocket. 27 + 2 = 29. Yet there were thirty dollars to begin with. Where is the other dollar?
The point of this story is that "creative accounting" can be used to clear things up... or to muddy the waters and make you look in the wrong place for your quantities and operations.
@Webby1
When M gets back from vacation and I hopefully have a leak free assembly to work with ( man it's hard watching glue dry )
Maybe we could come up with a common cycle reporting method that would make it easier to compare notes / results ?
The "exhaust" is what is driving many questions and is an area I really want to try to measure.
What I'm considering: ( and it sounds like M has done similar )
- System set up and riser weight / input head balanced ( starting point )
- Risers loaded with an additional weight to lift ( and probably held at the starting point )
- Input head raised X inches by adding a measured amount of water OR lifting the container until the load is lifted to its upper limit.
- Load removed ( in a hydraulic system, a check valve can accomplish this... )
- Bring the input container / head back to the starting point.
- Measure the amount of water than flows back out of the pod chamber and the riser sink distance ( if any - this is the recapture )
- The big question: How far BELOW the starting point does that container need to go before the risers sink...
And how much of the potential of the lifted load will it take to get the input back up to the starting point ?
The question I hope to be able to answer for myself..... soon enough
Dale
Quote from: webby1 on September 08, 2012, 07:32:34 PM
When the risers are at top of lift they are held in place by a full stop, they can not rise any further, thus removing the load does not change the internal charge value of the ZED, this pressure with fluid volume MUST exit the ZED to allow the risers to sink.
Right, no problem, except "removing the load". When the risers hit the top stop... is that what is meant by "removing the load?" Because if the pressure is enough to hold them against the top stop they can't "feel" the load at that point, can they? I mean you could physically remove the load and the riser couldn't tell the difference, as long as the riser doesn't itself move, right?
Anyway, I'm not clear on just what is meant by "removing the load". At first I thought you meant actually reaching out and taking it off physically and moving it somewhere else until the riser is back down, then replacing it. But that can'
